Hello Tom,
Sorry for being a little late, but I was on vacation ...
In this pull request there is a fix for debug warnings in tools/env from Marcin. A DM conversion and improvements series for the mvtwsi driver from Mario and last but not least a DM series for the omap24xx driver from Mugunthan V N, so I think this can go in though rc1 is out ...
The following changes since commit 4579720412744dd13266a3505bb38ce2da819b4f:
Prepare v2016.09-rc1 (2016-07-25 22:25:52 -0400)
git://git.denx.de/u-boot-i2c.git master
for you to fetch changes up to 6e677caf8cf0cc1a2310f2e4e9f27b81c674bc95:
i2c: mvtwsi: Add documentation (2016-07-26 10:20:38 +0200)
---------------------------------------------------------------- Marcin Niestroj (1): tools: env: Fix format warnings in debug
Mugunthan V N (14): omap4: i2c: correct register offset for sync register omap5/dra7: i2c: correct register offset for sync register drivers: i2c: uclass: parse dt parameters only when CONFIG_OF_CONTROL is enable ti_armv7_common: i2c: do not define DM_I2C for spl drivers: i2c: omap24xx_i2c: prepare driver for DM conversion drivers: i2c: omap24xx_i2c: adopt omap_i2c driver to driver model defconfig: am335x_boneblack_vboot: enable i2c driver model defconfig: am335x_evm: enable i2c driver model defconfig: am43xx_evm: enable i2c driver model defconfig: am43xx_hs_evm: enable i2c driver model defconfig: dra7xx_evm: enable i2c driver model defconfig: dra7xx_hs_evm: enable i2c driver model defconfig: am57xx_evm: enable i2c driver model defconfig: am57xx_hs_evm: enable i2c driver model
mario.six@gdsys.cc (13): i2c: mvtwsi: Fix style violations i2c: mvtwsi: Streamline code and add documentation i2c: mvtwsi: Improve and fix comments i2c: mvtwsi: Eliminate flags parameter i2c: mvtwsi: Get rid of status parameter i2c: mvtwsi: Use 'uint' instead of 'unsigned int' i2c: mvtwsi: Add compatibility functions i2c: mvtwsi: Factor out adap parameter i2c: mvtwsi: Make address length variable i2c: mvtwsi: Add compatibility to DM i2c: mvtwsi: Handle zero-length offsets properly i2c: mvtwsi: Make delay times frequency-dependent i2c: mvtwsi: Add documentation
arch/arm/include/asm/arch-omap4/i2c.h | 6 +- arch/arm/include/asm/arch-omap5/i2c.h | 6 +- configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_hs_evm_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_hs_evm_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_hs_evm_defconfig | 1 + drivers/i2c/Kconfig | 7 ++ drivers/i2c/i2c-uclass.c | 14 +++ drivers/i2c/mvtwsi.c | 777 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------- drivers/i2c/omap24xx_i2c.c | 407 +++++++++++++++++++++++++++++++++++++++-------------------- include/configs/ti_armv7_common.h | 16 +++ tools/env/fw_env.c | 17 +-- 16 files changed, 898 insertions(+), 360 deletions(-)
buildman showed no new errors.
bye, Heiko
On Tue, Jul 26, 2016 at 02:26:08PM +0200, Heiko Schocher wrote:
Hello Tom,
And I did -rc1 a bit early, so I'll be a bit more lax for -rc2 this timme too.
Heiko Schocher
