[U-Boot] [PATCH 0/3 v2] Add ACE HW support for SHA 256
This patch set adds hardware acceleration for SHA 256 with the help of ACE.
Changes since v1: - Patch-1: Fixed few nits. - Patch-2: Removed not required config. - Patch-3: Added sha256 to hash command instead of new sha256 command.
Akshay Saraswat (3): Exynos: Add hardware accelerated SHA 256 Exynos: config: Enable ACE HW for SHA 256 for Exynos gen: Add sha256 option to hash command
Makefile | 1 + arch/arm/include/asm/arch-exynos/cpu.h | 4 + common/cmd_hash.c | 46 ++++- drivers/crypto/Makefile | 47 +++++ drivers/crypto/ace_sfr.h | 310 +++++++++++++++++++++++++++++++++ drivers/crypto/ace_sha.c | 122 +++++++++++++ include/ace_sha.h | 41 +++++ include/configs/exynos5250-dt.h | 4 + 8 files changed, 574 insertions(+), 1 deletion(-) create mode 100644 drivers/crypto/Makefile create mode 100644 drivers/crypto/ace_sfr.h create mode 100644 drivers/crypto/ace_sha.c create mode 100644 include/ace_sha.h
SHA-256 and SHA-1 accelerated using ACE hardware.
Tested with command "hash sha256 0x40008000 0x2B 0x40009000". Used mm and md to write a standard string to memory location 0x40008000 and ran the above command to verify the output.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- Changes since v1: - Moved code to drivers/crypto. - Fixed few other nits.
Makefile | 1 + arch/arm/include/asm/arch-exynos/cpu.h | 4 + drivers/crypto/Makefile | 47 +++++ drivers/crypto/ace_sfr.h | 310 +++++++++++++++++++++++++++++++++ drivers/crypto/ace_sha.c | 122 +++++++++++++ include/ace_sha.h | 41 +++++ 6 files changed, 525 insertions(+) create mode 100644 drivers/crypto/Makefile create mode 100644 drivers/crypto/ace_sfr.h create mode 100644 drivers/crypto/ace_sha.c create mode 100644 include/ace_sha.h
diff --git a/Makefile b/Makefile index fc18dd4..4c41130 100644 --- a/Makefile +++ b/Makefile @@ -272,6 +272,7 @@ LIBS-y += disk/libdisk.o LIBS-y += drivers/bios_emulator/libatibiosemu.o LIBS-y += drivers/block/libblock.o LIBS-$(CONFIG_BOOTCOUNT_LIMIT) += drivers/bootcount/libbootcount.o +LIBS-y += drivers/crypto/libcrypto.o LIBS-y += drivers/dma/libdma.o LIBS-y += drivers/fpga/libfpga.o LIBS-y += drivers/gpio/libgpio.o diff --git a/arch/arm/include/asm/arch-exynos/cpu.h b/arch/arm/include/asm/arch-exynos/cpu.h index eb34422..2a20558 100644 --- a/arch/arm/include/asm/arch-exynos/cpu.h +++ b/arch/arm/include/asm/arch-exynos/cpu.h @@ -62,6 +62,7 @@ #define EXYNOS4_GPIO_PART4_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_DP_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4_SPI_ISP_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4_ACE_SFR_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS4X12 */ #define EXYNOS4X12_GPIO_PART3_BASE 0x03860000 @@ -95,6 +96,7 @@ #define EXYNOS4X12_I2S_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_SPI_BASE DEVICE_NOT_AVAILABLE #define EXYNOS4X12_SPI_ISP_BASE DEVICE_NOT_AVAILABLE +#define EXYNOS4X12_ACE_SFR_BASE DEVICE_NOT_AVAILABLE
/* EXYNOS5 Common*/ #define EXYNOS5_I2C_SPACING 0x10000 @@ -106,6 +108,7 @@ #define EXYNOS5_SWRESET 0x10040400 #define EXYNOS5_SYSREG_BASE 0x10050000 #define EXYNOS5_WATCHDOG_BASE 0x101D0000 +#define EXYNOS5_ACE_SFR_BASE 0x10830000 #define EXYNOS5_DMC_PHY0_BASE 0x10C00000 #define EXYNOS5_DMC_PHY1_BASE 0x10C10000 #define EXYNOS5_GPIO_PART3_BASE 0x10D10000 @@ -205,6 +208,7 @@ static inline unsigned int samsung_get_base_##device(void) \
SAMSUNG_BASE(adc, ADC_BASE) SAMSUNG_BASE(clock, CLOCK_BASE) +SAMSUNG_BASE(ace_sfr, ACE_SFR_BASE) SAMSUNG_BASE(dp, DP_BASE) SAMSUNG_BASE(sysreg, SYSREG_BASE) SAMSUNG_BASE(fimd, FIMD_BASE) diff --git a/drivers/crypto/Makefile b/drivers/crypto/Makefile new file mode 100644 index 0000000..2c54793 --- /dev/null +++ b/drivers/crypto/Makefile @@ -0,0 +1,47 @@ +# +# Copyright (c) 2013 Samsung Electronics Co., Ltd. +# http://www.samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)libcrypto.o + +COBJS-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o + +COBJS := $(COBJS-y) +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +all: $(LIB) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################## diff --git a/drivers/crypto/ace_sfr.h b/drivers/crypto/ace_sfr.h new file mode 100644 index 0000000..8f1c893 --- /dev/null +++ b/drivers/crypto/ace_sfr.h @@ -0,0 +1,310 @@ +/* + * Header file for Advanced Crypto Engine - SFR definitions + * + * Copyright (c) 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ + +#ifndef __ACE_SFR_H +#define __ACE_SFR_H + +struct exynos_ace_sfr { + unsigned int fc_intstat; /* base + 0 */ + unsigned int fc_intenset; + unsigned int fc_intenclr; + unsigned int fc_intpend; + unsigned int fc_fifostat; + unsigned int fc_fifoctrl; + unsigned int fc_global; + unsigned int res1; + unsigned int fc_brdmas; + unsigned int fc_brdmal; + unsigned int fc_brdmac; + unsigned int res2; + unsigned int fc_btdmas; + unsigned int fc_btdmal; + unsigned int fc_btdmac; + unsigned int res3; + unsigned int fc_hrdmas; + unsigned int fc_hrdmal; + unsigned int fc_hrdmac; + unsigned int res4; + unsigned int fc_pkdmas; + unsigned int fc_pkdmal; + unsigned int fc_pkdmac; + unsigned int fc_pkdmao; + unsigned char res5[0x1a0]; + + unsigned int aes_control; /* base + 0x200 */ + unsigned int aes_status; + unsigned char res6[0x8]; + unsigned int aes_in[4]; + unsigned int aes_out[4]; + unsigned int aes_iv[4]; + unsigned int aes_cnt[4]; + unsigned char res7[0x30]; + unsigned int aes_key[8]; + unsigned char res8[0x60]; + + unsigned int tdes_control; /* base + 0x300 */ + unsigned int tdes_status; + unsigned char res9[0x8]; + unsigned int tdes_key[6]; + unsigned int tdes_iv[2]; + unsigned int tdes_in[2]; + unsigned int tdes_out[2]; + unsigned char res10[0xc0]; + + unsigned int hash_control; /* base + 0x400 */ + unsigned int hash_control2; + unsigned int hash_fifo_mode; + unsigned int hash_byteswap; + unsigned int hash_status; + unsigned char res11[0xc]; + unsigned int hash_msgsize_low; + unsigned int hash_msgsize_high; + unsigned int hash_prelen_low; + unsigned int hash_prelen_high; + unsigned int hash_in[16]; + unsigned int hash_key_in[16]; + unsigned int hash_iv[8]; + unsigned char res12[0x30]; + unsigned int hash_result[8]; + unsigned char res13[0x20]; + unsigned int hash_seed[8]; + unsigned int hash_prng[8]; + unsigned char res14[0x180]; + + unsigned int pka_sfr[5]; /* base + 0x700 */ +}; + +/* ACE_FC_INT */ +#define ACE_FC_PKDMA (1 << 0) +#define ACE_FC_HRDMA (1 << 1) +#define ACE_FC_BTDMA (1 << 2) +#define ACE_FC_BRDMA (1 << 3) +#define ACE_FC_PRNG_ERROR (1 << 4) +#define ACE_FC_MSG_DONE (1 << 5) +#define ACE_FC_PRNG_DONE (1 << 6) +#define ACE_FC_PARTIAL_DONE (1 << 7) + +/* ACE_FC_FIFOSTAT */ +#define ACE_FC_PKFIFO_EMPTY (1 << 0) +#define ACE_FC_PKFIFO_FULL (1 << 1) +#define ACE_FC_HRFIFO_EMPTY (1 << 2) +#define ACE_FC_HRFIFO_FULL (1 << 3) +#define ACE_FC_BTFIFO_EMPTY (1 << 4) +#define ACE_FC_BTFIFO_FULL (1 << 5) +#define ACE_FC_BRFIFO_EMPTY (1 << 6) +#define ACE_FC_BRFIFO_FULL (1 << 7) + +/* ACE_FC_FIFOCTRL */ +#define ACE_FC_SELHASH_MASK (3 << 0) +#define ACE_FC_SELHASH_EXOUT (0 << 0) /* independent source */ +#define ACE_FC_SELHASH_BCIN (1 << 0) /* blk cipher input */ +#define ACE_FC_SELHASH_BCOUT (2 << 0) /* blk cipher output */ +#define ACE_FC_SELBC_MASK (1 << 2) +#define ACE_FC_SELBC_AES (0 << 2) /* AES */ +#define ACE_FC_SELBC_DES (1 << 2) /* DES */ + +/* ACE_FC_GLOBAL */ +#define ACE_FC_SSS_RESET (1 << 0) +#define ACE_FC_DMA_RESET (1 << 1) +#define ACE_FC_AES_RESET (1 << 2) +#define ACE_FC_DES_RESET (1 << 3) +#define ACE_FC_HASH_RESET (1 << 4) +#define ACE_FC_AXI_ENDIAN_MASK (3 << 6) +#define ACE_FC_AXI_ENDIAN_LE (0 << 6) +#define ACE_FC_AXI_ENDIAN_BIBE (1 << 6) +#define ACE_FC_AXI_ENDIAN_WIBE (2 << 6) + +/* Feed control - BRDMA control */ +#define ACE_FC_BRDMACFLUSH_OFF (0 << 0) +#define ACE_FC_BRDMACFLUSH_ON (1 << 0) +#define ACE_FC_BRDMACSWAP_ON (1 << 1) +#define ACE_FC_BRDMACARPROT_MASK (0x7 << 2) +#define ACE_FC_BRDMACARPROT_OFS (2) +#define ACE_FC_BRDMACARCACHE_MASK (0xf << 5) +#define ACE_FC_BRDMACARCACHE_OFS (5) + +/* Feed control - BTDMA control */ +#define ACE_FC_BTDMACFLUSH_OFF (0 << 0) +#define ACE_FC_BTDMACFLUSH_ON (1 << 0) +#define ACE_FC_BTDMACSWAP_ON (1 << 1) +#define ACE_FC_BTDMACAWPROT_MASK (0x7 << 2) +#define ACE_FC_BTDMACAWPROT_OFS (2) +#define ACE_FC_BTDMACAWCACHE_MASK (0xf << 5) +#define ACE_FC_BTDMACAWCACHE_OFS (5) + +/* Feed control - HRDMA control */ +#define ACE_FC_HRDMACFLUSH_OFF (0 << 0) +#define ACE_FC_HRDMACFLUSH_ON (1 << 0) +#define ACE_FC_HRDMACSWAP_ON (1 << 1) +#define ACE_FC_HRDMACARPROT_MASK (0x7 << 2) +#define ACE_FC_HRDMACARPROT_OFS (2) +#define ACE_FC_HRDMACARCACHE_MASK (0xf << 5) +#define ACE_FC_HRDMACARCACHE_OFS (5) + +/* Feed control - PKDMA control */ +#define ACE_FC_PKDMACBYTESWAP_ON (1 << 3) +#define ACE_FC_PKDMACDESEND_ON (1 << 2) +#define ACE_FC_PKDMACTRANSMIT_ON (1 << 1) +#define ACE_FC_PKDMACFLUSH_ON (1 << 0) + +/* Feed control - PKDMA offset */ +#define ACE_FC_SRAMOFFSET_MASK (0xfff) + +/* AES control */ +#define ACE_AES_MODE_MASK (1 << 0) +#define ACE_AES_MODE_ENC (0 << 0) +#define ACE_AES_MODE_DEC (1 << 0) +#define ACE_AES_OPERMODE_MASK (3 << 1) +#define ACE_AES_OPERMODE_ECB (0 << 1) +#define ACE_AES_OPERMODE_CBC (1 << 1) +#define ACE_AES_OPERMODE_CTR (2 << 1) +#define ACE_AES_FIFO_MASK (1 << 3) +#define ACE_AES_FIFO_OFF (0 << 3) /* CPU mode */ +#define ACE_AES_FIFO_ON (1 << 3) /* FIFO mode */ +#define ACE_AES_KEYSIZE_MASK (3 << 4) +#define ACE_AES_KEYSIZE_128 (0 << 4) +#define ACE_AES_KEYSIZE_192 (1 << 4) +#define ACE_AES_KEYSIZE_256 (2 << 4) +#define ACE_AES_KEYCNGMODE_MASK (1 << 6) +#define ACE_AES_KEYCNGMODE_OFF (0 << 6) +#define ACE_AES_KEYCNGMODE_ON (1 << 6) +#define ACE_AES_SWAP_MASK (0x1f << 7) +#define ACE_AES_SWAPKEY_OFF (0 << 7) +#define ACE_AES_SWAPKEY_ON (1 << 7) +#define ACE_AES_SWAPCNT_OFF (0 << 8) +#define ACE_AES_SWAPCNT_ON (1 << 8) +#define ACE_AES_SWAPIV_OFF (0 << 9) +#define ACE_AES_SWAPIV_ON (1 << 9) +#define ACE_AES_SWAPDO_OFF (0 << 10) +#define ACE_AES_SWAPDO_ON (1 << 10) +#define ACE_AES_SWAPDI_OFF (0 << 11) +#define ACE_AES_SWAPDI_ON (1 << 11) +#define ACE_AES_COUNTERSIZE_MASK (3 << 12) +#define ACE_AES_COUNTERSIZE_128 (0 << 12) +#define ACE_AES_COUNTERSIZE_64 (1 << 12) +#define ACE_AES_COUNTERSIZE_32 (2 << 12) +#define ACE_AES_COUNTERSIZE_16 (3 << 12) + +/* AES status */ +#define ACE_AES_OUTRDY_MASK (1 << 0) +#define ACE_AES_OUTRDY_OFF (0 << 0) +#define ACE_AES_OUTRDY_ON (1 << 0) +#define ACE_AES_INRDY_MASK (1 << 1) +#define ACE_AES_INRDY_OFF (0 << 1) +#define ACE_AES_INRDY_ON (1 << 1) +#define ACE_AES_BUSY_MASK (1 << 2) +#define ACE_AES_BUSY_OFF (0 << 2) +#define ACE_AES_BUSY_ON (1 << 2) + +/* TDES control */ +#define ACE_TDES_MODE_MASK (1 << 0) +#define ACE_TDES_MODE_ENC (0 << 0) +#define ACE_TDES_MODE_DEC (1 << 0) +#define ACE_TDES_OPERMODE_MASK (1 << 1) +#define ACE_TDES_OPERMODE_ECB (0 << 1) +#define ACE_TDES_OPERMODE_CBC (1 << 1) +#define ACE_TDES_SEL_MASK (3 << 3) +#define ACE_TDES_SEL_DES (0 << 3) +#define ACE_TDES_SEL_TDESEDE (1 << 3) /* TDES EDE mode */ +#define ACE_TDES_SEL_TDESEEE (3 << 3) /* TDES EEE mode */ +#define ACE_TDES_FIFO_MASK (1 << 5) +#define ACE_TDES_FIFO_OFF (0 << 5) /* CPU mode */ +#define ACE_TDES_FIFO_ON (1 << 5) /* FIFO mode */ +#define ACE_TDES_SWAP_MASK (0xf << 6) +#define ACE_TDES_SWAPKEY_OFF (0 << 6) +#define ACE_TDES_SWAPKEY_ON (1 << 6) +#define ACE_TDES_SWAPIV_OFF (0 << 7) +#define ACE_TDES_SWAPIV_ON (1 << 7) +#define ACE_TDES_SWAPDO_OFF (0 << 8) +#define ACE_TDES_SWAPDO_ON (1 << 8) +#define ACE_TDES_SWAPDI_OFF (0 << 9) +#define ACE_TDES_SWAPDI_ON (1 << 9) + +/* TDES status */ +#define ACE_TDES_OUTRDY_MASK (1 << 0) +#define ACE_TDES_OUTRDY_OFF (0 << 0) +#define ACE_TDES_OUTRDY_ON (1 << 0) +#define ACE_TDES_INRDY_MASK (1 << 1) +#define ACE_TDES_INRDY_OFF (0 << 1) +#define ACE_TDES_INRDY_ON (1 << 1) +#define ACE_TDES_BUSY_MASK (1 << 2) +#define ACE_TDES_BUSY_OFF (0 << 2) +#define ACE_TDES_BUSY_ON (1 << 2) + +/* Hash control */ +#define ACE_HASH_ENGSEL_MASK (0xf << 0) +#define ACE_HASH_ENGSEL_SHA1HASH (0x0 << 0) +#define ACE_HASH_ENGSEL_SHA1HMAC (0x1 << 0) +#define ACE_HASH_ENGSEL_SHA1HMACIN (0x1 << 0) +#define ACE_HASH_ENGSEL_SHA1HMACOUT (0x9 << 0) +#define ACE_HASH_ENGSEL_MD5HASH (0x2 << 0) +#define ACE_HASH_ENGSEL_MD5HMAC (0x3 << 0) +#define ACE_HASH_ENGSEL_MD5HMACIN (0x3 << 0) +#define ACE_HASH_ENGSEL_MD5HMACOUT (0xb << 0) +#define ACE_HASH_ENGSEL_SHA256HASH (0x4 << 0) +#define ACE_HASH_ENGSEL_SHA256HMAC (0x5 << 0) +#define ACE_HASH_ENGSEL_PRNG (0x8 << 0) +#define ACE_HASH_STARTBIT_ON (1 << 4) +#define ACE_HASH_USERIV_EN (1 << 5) + +/* Hash control 2 */ +#define ACE_HASH_PAUSE_ON (1 << 0) + +/* Hash control - FIFO mode */ +#define ACE_HASH_FIFO_MASK (1 << 0) +#define ACE_HASH_FIFO_OFF (0 << 0) +#define ACE_HASH_FIFO_ON (1 << 0) + +/* Hash control - byte swap */ +#define ACE_HASH_SWAP_MASK (0xf << 0) +#define ACE_HASH_SWAPKEY_OFF (0 << 0) +#define ACE_HASH_SWAPKEY_ON (1 << 0) +#define ACE_HASH_SWAPIV_OFF (0 << 1) +#define ACE_HASH_SWAPIV_ON (1 << 1) +#define ACE_HASH_SWAPDO_OFF (0 << 2) +#define ACE_HASH_SWAPDO_ON (1 << 2) +#define ACE_HASH_SWAPDI_OFF (0 << 3) +#define ACE_HASH_SWAPDI_ON (1 << 3) + +/* Hash status */ +#define ACE_HASH_BUFRDY_MASK (1 << 0) +#define ACE_HASH_BUFRDY_OFF (0 << 0) +#define ACE_HASH_BUFRDY_ON (1 << 0) +#define ACE_HASH_SEEDSETTING_MASK (1 << 1) +#define ACE_HASH_SEEDSETTING_OFF (0 << 1) +#define ACE_HASH_SEEDSETTING_ON (1 << 1) +#define ACE_HASH_PRNGBUSY_MASK (1 << 2) +#define ACE_HASH_PRNGBUSY_OFF (0 << 2) +#define ACE_HASH_PRNGBUSY_ON (1 << 2) +#define ACE_HASH_PARTIALDONE_MASK (1 << 4) +#define ACE_HASH_PARTIALDONE_OFF (0 << 4) +#define ACE_HASH_PARTIALDONE_ON (1 << 4) +#define ACE_HASH_PRNGDONE_MASK (1 << 5) +#define ACE_HASH_PRNGDONE_OFF (0 << 5) +#define ACE_HASH_PRNGDONE_ON (1 << 5) +#define ACE_HASH_MSGDONE_MASK (1 << 6) +#define ACE_HASH_MSGDONE_OFF (0 << 6) +#define ACE_HASH_MSGDONE_ON (1 << 6) +#define ACE_HASH_PRNGERROR_MASK (1 << 7) +#define ACE_HASH_PRNGERROR_OFF (0 << 7) +#define ACE_HASH_PRNGERROR_ON (1 << 7) + +#endif diff --git a/drivers/crypto/ace_sha.c b/drivers/crypto/ace_sha.c new file mode 100644 index 0000000..867904b --- /dev/null +++ b/drivers/crypto/ace_sha.c @@ -0,0 +1,122 @@ +/* + * Advanced Crypto Engine - SHA Firmware + * Copyright (c) 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ +#include <common.h> +#include <sha256.h> +#include <sha1.h> +#include <ace_sha.h> +#include "ace_sfr.h" + +/* Timeout for data size above 8MB */ +#define TIMEOUT_MS 500 +/* Maximum input data size is 8 MB */ +#define BUF_LIMIT 8*1024*1024 + +/* SHA1 value for the message of zero length */ +static const unsigned char sha1_digest_emptymsg[SHA1_SUM_LEN] = { + 0xDA, 0x39, 0xA3, 0xEE, 0x5E, 0x6B, 0x4B, 0x0D, + 0x32, 0x55, 0xBF, 0xFF, 0x95, 0x60, 0x18, 0x90, + 0xAF, 0xD8, 0x07, 0x09}; + +/* SHA256 value for the message of zero length */ +static const unsigned char sha256_digest_emptymsg[SHA256_SUM_LEN] = { + 0xE3, 0xB0, 0xC4, 0x42, 0x98, 0xFC, 0x1C, 0x14, + 0x9A, 0xFB, 0xF4, 0xC8, 0x99, 0x6F, 0xB9, 0x24, + 0x27, 0xAE, 0x41, 0xE4, 0x64, 0x9B, 0x93, 0x4C, + 0xA4, 0x95, 0x99, 0x1B, 0x78, 0x52, 0xB8, 0x55}; + +int ace_sha_hash_digest( + unsigned char *pout, unsigned char *pbuf, + unsigned int buf_len, unsigned int hash_type) +{ + unsigned int i, reg, len; + unsigned int *pdigest; + ulong start; + struct exynos_ace_sfr *ace_sha_reg = + (struct exynos_ace_sfr *) samsung_get_base_ace_sfr(); + + if (buf_len == 0) { + /* ACE H/W cannot compute hash value for empty string */ + if (hash_type == ACE_SHA_TYPE_SHA1) + memcpy(pout, sha1_digest_emptymsg, SHA1_SUM_LEN); + else + memcpy(pout, sha256_digest_emptymsg, SHA256_SUM_LEN); + return 0; + } else if (buf_len > BUF_LIMIT) { + debug("%s: Buffer length beyond limit\n", __func__); + return -1; + } + + /* Flush HRDMA */ + writel(ACE_FC_HRDMACFLUSH_ON, &ace_sha_reg->fc_hrdmac); + writel(ACE_FC_HRDMACFLUSH_OFF, &ace_sha_reg->fc_hrdmac); + + /* Set byte swap of data in */ + writel(ACE_HASH_SWAPDI_ON | ACE_HASH_SWAPDO_ON | ACE_HASH_SWAPIV_ON, + &ace_sha_reg->hash_byteswap); + + /* Select Hash input mux as external source */ + reg = readl(&ace_sha_reg->fc_fifoctrl); + reg = (reg & ~ACE_FC_SELHASH_MASK) | ACE_FC_SELHASH_EXOUT; + writel(reg, &ace_sha_reg->fc_fifoctrl); + + /* Set Hash as SHA1 or SHA256 and start Hash engine */ + reg = (hash_type == ACE_SHA_TYPE_SHA1) ? + ACE_HASH_ENGSEL_SHA1HASH : ACE_HASH_ENGSEL_SHA256HASH; + reg |= ACE_HASH_STARTBIT_ON; + writel(reg, &ace_sha_reg->hash_control); + + /* Enable FIFO mode */ + writel(ACE_HASH_FIFO_ON, &ace_sha_reg->hash_fifo_mode); + + /* Set message length */ + writel(buf_len, &ace_sha_reg->hash_msgsize_low); + writel(0, &ace_sha_reg->hash_msgsize_high); + + /* Set HRDMA */ + writel((unsigned int)pbuf, &ace_sha_reg->fc_hrdmas); + writel(buf_len, &ace_sha_reg->fc_hrdmal); + + start = get_timer(0); + + while ((readl(&ace_sha_reg->hash_status) & ACE_HASH_MSGDONE_MASK) == + ACE_HASH_MSGDONE_OFF) { + + if (get_timer(start) > TIMEOUT_MS) { + debug("%s: Timeout waiting for ACE\n", __func__); + return -1; + } + } + + /* Clear MSG_DONE bit */ + writel(ACE_HASH_MSGDONE_ON, &ace_sha_reg->hash_status); + + /* Read hash result */ + pdigest = (unsigned int *)pout; + len = (hash_type == ACE_SHA_TYPE_SHA1) ? SHA1_SUM_LEN / 4 + : SHA256_SUM_LEN / 4; + + for (i = 0; i < len ; i++) + pdigest[i] = readl(&ace_sha_reg->hash_result[i]); + + /* Clear HRDMA pending bit */ + writel(ACE_FC_HRDMA, &ace_sha_reg->fc_intpend); + + return 0; +} diff --git a/include/ace_sha.h b/include/ace_sha.h new file mode 100644 index 0000000..ed4e4d5 --- /dev/null +++ b/include/ace_sha.h @@ -0,0 +1,41 @@ +/* + * Header file for SHA firmware + * + * Copyright (c) 2012 Samsung Electronics + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + * + */ +#ifndef __ACE_FW_SHA1_H +#define __ACE_FW_SHA1_H + +#define ACE_SHA_TYPE_SHA1 1 +#define ACE_SHA_TYPE_SHA256 2 + +/** + * Computes hash value of input pbuf using ACE + * + * @param pout A pointer to the output buffer. When complete + * 32 bytes are copied to pout[0]...pout[31]. Thus, a user + * should allocate at least 32 bytes at pOut in advance. + * @param pbuf A pointer to the input buffer + * @param buflen Byte length of input buffer + * @param hash_type SHA1 or SHA256 + * + * @return 0 Success + */ +int ace_sha_hash_digest(uchar *pout, uchar *pbuf, uint buflen, uint hash_type); + +#endif
Hi Akshay,
This looks OK but I think the plumbing in the other patch needs to move to hash.c before I can do a final review.
On Thu, 28 Feb 2013 06:00:21 -0500 Akshay Saraswat akshay.s@samsung.com wrote:
Changes since v1:
be more specific wrt changes between revisions.
- if (buf_len == 0) {
else
- } else if (buf_len > BUF_LIMIT) {
return -1;
erroring out just because the user asked for a hash on something larger than 8MB is unacceptable: any hash implementation that replaces a corresponding software implementation must not introduce new limitations and regressions.
If the hardware supports hash updating - which is likely - use that to perform hashes >8MB. If not, revert to software. And for the 0 length case.
- start = get_timer(0);
- while ((readl(&ace_sha_reg->hash_status) & ACE_HASH_MSGDONE_MASK) ==
alignment - the 'A' in ACE_H*_OFF should fall directly below the '(' in 'readl('.
see my other email to v1 of this patch wrt timing-out.
- len = (hash_type == ACE_SHA_TYPE_SHA1) ? SHA1_SUM_LEN / 4
alignment
a more recent version of checkpatch finds other such problems:
CHECK: No space is necessary after a cast #610: FILE: drivers/crypto/ace_sha.c:52: + struct exynos_ace_sfr *ace_sha_reg = + (struct exynos_ace_sfr *) samsung_get_base_ace_sfr();
CHECK: Alignment should match open parenthesis #630: FILE: drivers/crypto/ace_sha.c:72: + writel(ACE_HASH_SWAPDI_ON | ACE_HASH_SWAPDO_ON | ACE_HASH_SWAPIV_ON, + &ace_sha_reg->hash_byteswap);
CHECK: Blank lines aren't necessary after an open brace '{' #658: FILE: drivers/crypto/ace_sha.c:100: + ACE_HASH_MSGDONE_OFF) { +
CHECK: space prohibited before semicolon #673: FILE: drivers/crypto/ace_sha.c:115: + for (i = 0; i < len ; i++)
Kim
This enables SHA 256 for exynos.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- Changes since v1: - Removed not required config.
include/configs/exynos5250-dt.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index cabd2f2..f6df734 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -45,6 +45,9 @@ /* Keep L2 Cache Disabled */ #define CONFIG_SYS_DCACHE_OFF
+/* Enable ACE acceleration for SHA256 */ +#define CONFIG_EXYNOS_ACE_SHA + #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_TEXT_BASE 0x43E00000
Hi Akshay,
and SHA1?
-- 1.8.0
sha256 support is added to "hash" command which can be used to test SHA 256 hash algorithm.
Signed-off-by: ARUN MANKUZHI arun.m@samsung.com Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- Changes since v1: - Added sha256 support to "hash" command instead of new sha256 command.
common/cmd_hash.c | 46 ++++++++++++++++++++++++++++++++++++++++- include/configs/exynos5250-dt.h | 1 + 2 files changed, 46 insertions(+), 1 deletion(-)
diff --git a/common/cmd_hash.c b/common/cmd_hash.c index 689c608..a2cb65a 100644 --- a/common/cmd_hash.c +++ b/common/cmd_hash.c @@ -26,13 +26,55 @@ #include <common.h> #include <command.h> #include <hash.h> +#ifdef CONFIG_EXYNOS_ACE_SHA +#include <ace_sha.h> +#else +#include <sha256.h> +#endif + +static int do_sha256(const char *input, const char *length, const char *output) +{ + unsigned long in_len; + unsigned char *in_addr, *out_addr; + int i; + +#ifndef CONFIG_EXYNOS_ACE_SHA + sha256_context sha_cnxt; +#endif + in_addr = (unsigned char *)simple_strtoul(input, NULL, 16); + in_len = simple_strtoul(length, NULL, 16); + out_addr = (unsigned char *)simple_strtoul(output, NULL, 16); + +#ifdef CONFIG_EXYNOS_ACE_SHA + ace_sha_hash_digest(out_addr, in_addr, in_len, 2); +#else + sha256_starts(&sha_cnxt); + + sha256_update(&sha_cnxt, in_addr, in_len); + + sha256_finish(&sha_cnxt, out_addr); +#endif + + for (i = 0; i < 32; i++) + printf("0x%02X ", out_addr[i]); + printf("\n"); + + return 0; +}
static int do_hash(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { #ifdef CONFIG_HASH_VERIFY int verify = 0;
- if (!strcmp(argv[1], "-v")) { + if (!strcmp(argv[1], "sha256")) { + if (argc < 5) { + printf("usage: hash sha256 <input-address>" + " <length> <output-address>\n"); + return 0; + } + return do_sha256(argv[2], argv[3], argv[4]); + } else if (!strcmp(argv[1], "-v")) { verify = 1; argc--; argv++; @@ -48,6 +90,7 @@ static int do_hash(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( hash, 6, 1, do_hash, "compute hash message digest", + "hash sha256 <input-address> <length> <output-address>\n" "algorithm address count [[*]sum_dest]\n" " - compute message digest [save to env var / *address]\n" "hash -v algorithm address count [*]sum\n" @@ -57,6 +100,7 @@ U_BOOT_CMD( U_BOOT_CMD( hash, 5, 1, do_hash, "compute message digest", + "hash sha256 <input-address> <length> <output-address>\n" "algorithm address count [[*]sum_dest]\n" " - compute message digest [save to env var / *address]" ); diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index f6df734..4a4a2bb 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -116,6 +116,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_NET +#define CONFIG_CMD_HASH
#define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK
Hi Akshay,
This code should go in hash.c. Please see 'struct hash_algo' at the top of this file. You can add your new hash function in there. There really is no need to change cmd_hash I think.
Also the config file change should go in a separate patch.
Akshay Saraswat
Kim Phillips
