[u-boot-test-hooks PATCH] travis-ci: Correct the memory size for Xilinx Zynq QEMU
Currently the memory is specified to be an insane size of about 38TB. This happens to be not an issue with QEMU 4.2.0 which is what U-Boot CI is currently using, but it does not make newer QEMU (e.g.: 6.0.0) happy. Change it to use a 1G memory size.
Fixes: 4fcc1d95a39f ("Add support for Xilinx Zynq Virtual platform") Signed-off-by: Bin Meng bmeng.cn@gmail.com
bin/travis-ci/conf.xilinx_zynq_virt_qemu | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bin/travis-ci/conf.xilinx_zynq_virt_qemu b/bin/travis-ci/conf.xilinx_zynq_virt_qemu index eef7904..a6af659 100644 --- a/bin/travis-ci/conf.xilinx_zynq_virt_qemu +++ b/bin/travis-ci/conf.xilinx_zynq_virt_qemu @@ -21,7 +21,7 @@ console_impl=qemu qemu_machine="xilinx-zynq-a9" qemu_binary="qemu-system-arm" -qemu_extra_args="-display none -m 40000000 -nographic -serial /dev/null -serial mon:stdio -monitor null" +qemu_extra_args="-display none -m 1G -nographic -serial /dev/null -serial mon:stdio -monitor null" qemu_kernel_args="-device loader,file=${U_BOOT_BUILD_DIR}/u-boot-dtb.bin,addr=0x4000000,cpu-num=0" reset_impl=none flash_impl=none
Applied to u-boot-test-hooks/master, thanks!
Bin Meng
