[PATCH 1/1] sandbox: enable CONFIG_EFI_CAPSULE_AUTHENTICATE
Without CONFIG_EFI_CAPSULE_AUTHENTICATE=y the following tests are skipped:
* test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py * test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- configs/sandbox_defconfig | 1 + configs/sandbox_flattree_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ca95b2c5d2..01c191818d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -335,6 +335,7 @@ CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index e9fcc5b0cb..8c2bceae22 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -226,6 +226,7 @@ CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y
On Fri, 14 Apr 2023 at 11:39, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py
- test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index ca95b2c5d2..01c191818d 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -335,6 +335,7 @@ CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index e9fcc5b0cb..8c2bceae22 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -226,6 +226,7 @@ CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_EFI_CAPSULE_AUTHENTICATE=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y -- 2.39.2
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Hi Heinrich,
On Fri, 14 Apr 2023 at 02:39, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
This still has the problem that it reboots in the middle of the test. Can we get that fixed? If someone at Linaro isn't interested I could take a look at it.
On Tue, Apr 18, 2023 at 10:47:24AM -0600, Simon Glass wrote:
Hi Heinrich,
I think we discussed this in the past. We *need* to reboot as that's what the EFI describes. Why is it a problem?
Regards /Ilias
Hi Ilias,
On Wed, 19 Apr 2023 at 18:05, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Heinrich,
Would you like me to provide a patch that shows it not rebooting? It is a simple matter of kicking off the update process, which we can do directly, without a reboot.
Hi Simon,
On Thu, 20 Apr 2023 at 01:41, Simon Glass sjg@chromium.org wrote:
Hi Ilias,
Hi Heinrich,
I know it's a single efidebug command to trigger this without a reboot. However it is not going to test the final code which is meant to run capsule updates on a reboot as the spec defines. So again, why is rebooting a problem?
Regards /Ilias
On Thu, Apr 20, 2023 at 09:30:24AM +0300, Ilias Apalodimas wrote:
Hi Simon,
Hi Ilias,
Hi Heinrich,
I guess that what we are looking for are different. Simon's aim is to do, so called, an unit test first, using an internal function, while what I, rather we?, intended to do a system test or standard-conformance test.
I believe that we need to have some consensus on test methodology to be added to U-Boot repository.
-Takahiro Akashi
Regards /Ilias
Hi Simon,
Hi Ilias,
Hi Heinrich,
-Takahiro Akashi
Unit tests could cover aspects of capsule updates. But what we enable here are the integration tests. For such a complicated functionality as capsule updates unit tests alone are inadequate. They could be added on top to test individual functions.
Best regards
Heinrich
Hi Heinrich,
On Thu, 20 Apr 2023 at 01:34, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Simon,
Hi Ilias,
Hi Heinrich,
On Fri, 14 Apr 2023 at 02:39, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote: > > Without CONFIG_EFI_CAPSULE_AUTHENTICATE=y the following tests are skipped: > > * test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py > * test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py > > Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com > --- > configs/sandbox_defconfig | 1 + > configs/sandbox_flattree_defconfig | 1 + > 2 files changed, 2 insertions(+) >
-Takahiro Akashi
I would be happy with an architecture that splits the tests into parts. But today all we have is the functional test. When it fails, where do I look?
I'm not so wedded to unit tests, or at least not in the traditional sense. Most of the tests in U-Boot are hybrid, in that they test one subsystem / function while relying on lots of others to work as expected. For example, we require block devices, partitions, environment variables, etc. to work in the case of capsule updates, but we are not actually trying to test those things. We mostly use traditional unit tests only for 'leaf' functionality, like GPIOs, string processing, environment.
In any case, we need to design our code for testing, to actually find bugs and to tell you where the bug is, so far as possible.
AKASHI Takahiro
Ilias Apalodimas
