[PATCH] spi: stm32: Add ofdata_to_platdata() callback
Parse DT in ofdata_to_platdata() callback instead of probe().
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
drivers/spi/stm32_spi.c | 224 +++++++++++++++++++++++----------------- 1 file changed, 132 insertions(+), 92 deletions(-)
diff --git a/drivers/spi/stm32_spi.c b/drivers/spi/stm32_spi.c index bd8514033d..fe5419e851 100644 --- a/drivers/spi/stm32_spi.c +++ b/drivers/spi/stm32_spi.c @@ -97,11 +97,14 @@ #define SPI_SIMPLEX_RX 2 #define SPI_HALF_DUPLEX 3
-struct stm32_spi_priv { +struct stm32_spi_plat { void __iomem *base; struct clk clk; struct reset_ctl rst_ctl; struct gpio_desc cs_gpios[MAX_CS_COUNT]; +}; + +struct stm32_spi_priv { ulong bus_clk_rate; unsigned int fifo_size; unsigned int cur_bpw; @@ -115,28 +118,32 @@ struct stm32_spi_priv { bool cs_high; };
-static void stm32_spi_write_txfifo(struct stm32_spi_priv *priv) +static void stm32_spi_write_txfifo(struct udevice *bus) { + struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base; + while ((priv->tx_len > 0) && - (readl(priv->base + STM32_SPI_SR) & SPI_SR_TXP)) { + (readl(base + STM32_SPI_SR) & SPI_SR_TXP)) { u32 offs = priv->cur_xferlen - priv->tx_len;
if (priv->tx_len >= sizeof(u32) && IS_ALIGNED((uintptr_t)(priv->tx_buf + offs), sizeof(u32))) { const u32 *tx_buf32 = (const u32 *)(priv->tx_buf + offs);
- writel(*tx_buf32, priv->base + STM32_SPI_TXDR); + writel(*tx_buf32, base + STM32_SPI_TXDR); priv->tx_len -= sizeof(u32); } else if (priv->tx_len >= sizeof(u16) && IS_ALIGNED((uintptr_t)(priv->tx_buf + offs), sizeof(u16))) { const u16 *tx_buf16 = (const u16 *)(priv->tx_buf + offs);
- writew(*tx_buf16, priv->base + STM32_SPI_TXDR); + writew(*tx_buf16, base + STM32_SPI_TXDR); priv->tx_len -= sizeof(u16); } else { const u8 *tx_buf8 = (const u8 *)(priv->tx_buf + offs);
- writeb(*tx_buf8, priv->base + STM32_SPI_TXDR); + writeb(*tx_buf8, base + STM32_SPI_TXDR); priv->tx_len -= sizeof(u8); } } @@ -144,9 +151,12 @@ static void stm32_spi_write_txfifo(struct stm32_spi_priv *priv) log_debug("%d bytes left\n", priv->tx_len); }
-static void stm32_spi_read_rxfifo(struct stm32_spi_priv *priv) +static void stm32_spi_read_rxfifo(struct udevice *bus) { - u32 sr = readl(priv->base + STM32_SPI_SR); + struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base; + u32 sr = readl(base + STM32_SPI_SR); u32 rxplvl = (sr & SPI_SR_RXPLVL) >> SPI_SR_RXPLVL_SHIFT;
while ((priv->rx_len > 0) && @@ -158,7 +168,7 @@ static void stm32_spi_read_rxfifo(struct stm32_spi_priv *priv) (priv->rx_len >= sizeof(u32) || (sr & SPI_SR_RXWNE))) { u32 *rx_buf32 = (u32 *)(priv->rx_buf + offs);
- *rx_buf32 = readl(priv->base + STM32_SPI_RXDR); + *rx_buf32 = readl(base + STM32_SPI_RXDR); priv->rx_len -= sizeof(u32); } else if (IS_ALIGNED((uintptr_t)(priv->rx_buf + offs), sizeof(u16)) && (priv->rx_len >= sizeof(u16) || @@ -166,38 +176,38 @@ static void stm32_spi_read_rxfifo(struct stm32_spi_priv *priv) (rxplvl >= 2 || priv->cur_bpw > 8)))) { u16 *rx_buf16 = (u16 *)(priv->rx_buf + offs);
- *rx_buf16 = readw(priv->base + STM32_SPI_RXDR); + *rx_buf16 = readw(base + STM32_SPI_RXDR); priv->rx_len -= sizeof(u16); } else { u8 *rx_buf8 = (u8 *)(priv->rx_buf + offs);
- *rx_buf8 = readb(priv->base + STM32_SPI_RXDR); + *rx_buf8 = readb(base + STM32_SPI_RXDR); priv->rx_len -= sizeof(u8); }
- sr = readl(priv->base + STM32_SPI_SR); + sr = readl(base + STM32_SPI_SR); rxplvl = (sr & SPI_SR_RXPLVL) >> SPI_SR_RXPLVL_SHIFT; }
log_debug("%d bytes left\n", priv->rx_len); }
-static int stm32_spi_enable(struct stm32_spi_priv *priv) +static int stm32_spi_enable(void __iomem *base) { log_debug("\n");
/* Enable the SPI hardware */ - setbits_le32(priv->base + STM32_SPI_CR1, SPI_CR1_SPE); + setbits_le32(base + STM32_SPI_CR1, SPI_CR1_SPE);
return 0; }
-static int stm32_spi_disable(struct stm32_spi_priv *priv) +static int stm32_spi_disable(void __iomem *base) { log_debug("\n");
/* Disable the SPI hardware */ - clrbits_le32(priv->base + STM32_SPI_CR1, SPI_CR1_SPE); + clrbits_le32(base + STM32_SPI_CR1, SPI_CR1_SPE);
return 0; } @@ -205,45 +215,48 @@ static int stm32_spi_disable(struct stm32_spi_priv *priv) static int stm32_spi_claim_bus(struct udevice *slave) { struct udevice *bus = dev_get_parent(slave); - struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base;
dev_dbg(slave, "\n");
/* Enable the SPI hardware */ - return stm32_spi_enable(priv); + return stm32_spi_enable(base); }
static int stm32_spi_release_bus(struct udevice *slave) { struct udevice *bus = dev_get_parent(slave); - struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base;
/* Disable the SPI hardware */ - return stm32_spi_disable(priv); + return stm32_spi_disable(base); }
static void stm32_spi_stopxfer(struct udevice *dev) { - struct stm32_spi_priv *priv = dev_get_priv(dev); + struct stm32_spi_plat *plat = dev_get_plat(dev); + void __iomem *base = plat->base; u32 cr1, sr; int ret;
dev_dbg(dev, "\n");
- cr1 = readl(priv->base + STM32_SPI_CR1); + cr1 = readl(base + STM32_SPI_CR1);
if (!(cr1 & SPI_CR1_SPE)) return;
/* Wait on EOT or suspend the flow */ - ret = readl_poll_timeout(priv->base + STM32_SPI_SR, sr, + ret = readl_poll_timeout(base + STM32_SPI_SR, sr, !(sr & SPI_SR_EOT), 100000); if (ret < 0) { if (cr1 & SPI_CR1_CSTART) { - writel(cr1 | SPI_CR1_CSUSP, priv->base + STM32_SPI_CR1); - if (readl_poll_timeout(priv->base + STM32_SPI_SR, + writel(cr1 | SPI_CR1_CSUSP, base + STM32_SPI_CR1); + if (readl_poll_timeout(base + STM32_SPI_SR, sr, !(sr & SPI_SR_SUSP), 100000) < 0) dev_err(dev, "Suspend request timeout\n"); @@ -251,11 +264,12 @@ static void stm32_spi_stopxfer(struct udevice *dev) }
/* clear status flags */ - setbits_le32(priv->base + STM32_SPI_IFCR, SPI_IFCR_ALL); + setbits_le32(base + STM32_SPI_IFCR, SPI_IFCR_ALL); }
static int stm32_spi_set_cs(struct udevice *dev, unsigned int cs, bool enable) { + struct stm32_spi_plat *plat = dev_get_plat(dev); struct stm32_spi_priv *priv = dev_get_priv(dev);
dev_dbg(dev, "cs=%d enable=%d\n", cs, enable); @@ -263,18 +277,20 @@ static int stm32_spi_set_cs(struct udevice *dev, unsigned int cs, bool enable) if (cs >= MAX_CS_COUNT) return -ENODEV;
- if (!dm_gpio_is_valid(&priv->cs_gpios[cs])) + if (!dm_gpio_is_valid(&plat->cs_gpios[cs])) return -EINVAL;
if (priv->cs_high) enable = !enable;
- return dm_gpio_set_value(&priv->cs_gpios[cs], enable ? 1 : 0); + return dm_gpio_set_value(&plat->cs_gpios[cs], enable ? 1 : 0); }
static int stm32_spi_set_mode(struct udevice *bus, uint mode) { struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base; u32 cfg2_clrb = 0, cfg2_setb = 0;
dev_dbg(bus, "mode=%d\n", mode); @@ -295,7 +311,7 @@ static int stm32_spi_set_mode(struct udevice *bus, uint mode) cfg2_clrb |= SPI_CFG2_LSBFRST;
if (cfg2_clrb || cfg2_setb) - clrsetbits_le32(priv->base + STM32_SPI_CFG2, + clrsetbits_le32(base + STM32_SPI_CFG2, cfg2_clrb, cfg2_setb);
if (mode & SPI_CS_HIGH) @@ -308,6 +324,8 @@ static int stm32_spi_set_mode(struct udevice *bus, uint mode) static int stm32_spi_set_fthlv(struct udevice *dev, u32 xfer_len) { struct stm32_spi_priv *priv = dev_get_priv(dev); + struct stm32_spi_plat *plat = dev_get_plat(dev); + void __iomem *base = plat->base; u32 fthlv, half_fifo;
/* data packet should not exceed 1/2 of fifo space */ @@ -321,7 +339,7 @@ static int stm32_spi_set_fthlv(struct udevice *dev, u32 xfer_len)
if (!fthlv) fthlv = 1; - clrsetbits_le32(priv->base + STM32_SPI_CFG1, SPI_CFG1_FTHLV, + clrsetbits_le32(base + STM32_SPI_CFG1, SPI_CFG1_FTHLV, (fthlv - 1) << SPI_CFG1_FTHLV_SHIFT);
return 0; @@ -330,6 +348,8 @@ static int stm32_spi_set_fthlv(struct udevice *dev, u32 xfer_len) static int stm32_spi_set_speed(struct udevice *bus, uint hz) { struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base; u32 mbrdiv; long div;
@@ -353,7 +373,7 @@ static int stm32_spi_set_speed(struct udevice *bus, uint hz) if (!mbrdiv) return -EINVAL;
- clrsetbits_le32(priv->base + STM32_SPI_CFG1, SPI_CFG1_MBR, + clrsetbits_le32(base + STM32_SPI_CFG1, SPI_CFG1_MBR, (mbrdiv - 1) << SPI_CFG1_MBR_SHIFT);
priv->cur_hz = hz; @@ -367,6 +387,8 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen, struct udevice *bus = dev_get_parent(slave); struct dm_spi_slave_plat *slave_plat; struct stm32_spi_priv *priv = dev_get_priv(bus); + struct stm32_spi_plat *plat = dev_get_plat(bus); + void __iomem *base = plat->base; u32 sr; u32 ifcr = 0; u32 xferlen; @@ -376,7 +398,7 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen, xferlen = bitlen / 8;
if (xferlen <= SPI_CR2_TSIZE) - writel(xferlen, priv->base + STM32_SPI_CR2); + writel(xferlen, base + STM32_SPI_CR2); else return -EMSGSIZE;
@@ -396,15 +418,15 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen, priv->cur_xferlen = xferlen;
/* Disable the SPI hardware to unlock CFG1/CFG2 registers */ - stm32_spi_disable(priv); + stm32_spi_disable(base);
- clrsetbits_le32(priv->base + STM32_SPI_CFG2, SPI_CFG2_COMM, + clrsetbits_le32(base + STM32_SPI_CFG2, SPI_CFG2_COMM, mode << SPI_CFG2_COMM_SHIFT);
stm32_spi_set_fthlv(bus, xferlen);
/* Enable the SPI hardware */ - stm32_spi_enable(priv); + stm32_spi_enable(base); }
dev_dbg(bus, "priv->tx_len=%d priv->rx_len=%d\n", @@ -416,12 +438,12 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen,
/* Be sure to have data in fifo before starting data transfer */ if (priv->tx_buf) - stm32_spi_write_txfifo(priv); + stm32_spi_write_txfifo(bus);
- setbits_le32(priv->base + STM32_SPI_CR1, SPI_CR1_CSTART); + setbits_le32(base + STM32_SPI_CR1, SPI_CR1_CSTART);
while (1) { - sr = readl(priv->base + STM32_SPI_SR); + sr = readl(base + STM32_SPI_SR);
if (sr & SPI_SR_OVR) { dev_err(bus, "Overrun: RX data lost\n"); @@ -433,7 +455,7 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen, dev_warn(bus, "System too slow is limiting data throughput\n");
if (priv->rx_buf && priv->rx_len > 0) - stm32_spi_read_rxfifo(priv); + stm32_spi_read_rxfifo(bus);
ifcr |= SPI_SR_SUSP; } @@ -443,23 +465,23 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen,
if (sr & SPI_SR_TXP) if (priv->tx_buf && priv->tx_len > 0) - stm32_spi_write_txfifo(priv); + stm32_spi_write_txfifo(bus);
if (sr & SPI_SR_RXP) if (priv->rx_buf && priv->rx_len > 0) - stm32_spi_read_rxfifo(priv); + stm32_spi_read_rxfifo(bus);
if (sr & SPI_SR_EOT) { if (priv->rx_buf && priv->rx_len > 0) - stm32_spi_read_rxfifo(priv); + stm32_spi_read_rxfifo(bus); break; }
- writel(ifcr, priv->base + STM32_SPI_IFCR); + writel(ifcr, base + STM32_SPI_IFCR); }
/* clear status flags */ - setbits_le32(priv->base + STM32_SPI_IFCR, SPI_IFCR_ALL); + setbits_le32(base + STM32_SPI_IFCR, SPI_IFCR_ALL); stm32_spi_stopxfer(bus);
if (flags & SPI_XFER_END) @@ -470,42 +492,72 @@ static int stm32_spi_xfer(struct udevice *slave, unsigned int bitlen,
static int stm32_spi_get_fifo_size(struct udevice *dev) { - struct stm32_spi_priv *priv = dev_get_priv(dev); + struct stm32_spi_plat *plat = dev_get_plat(dev); + void __iomem *base = plat->base; u32 count = 0;
- while (readl(priv->base + STM32_SPI_SR) & SPI_SR_TXP) - writeb(++count, priv->base + STM32_SPI_TXDR); + while (readl(base + STM32_SPI_SR) & SPI_SR_TXP) + writeb(++count, base + STM32_SPI_TXDR);
dev_dbg(dev, "%d x 8-bit fifo size\n", count);
return count; }
+static int stm32_spi_of_to_plat(struct udevice *dev) +{ + struct stm32_spi_plat *plat = dev_get_plat(dev); + int ret; + + plat->base = dev_read_addr_ptr(dev); + if (!plat->base) { + dev_err(dev, "can't get registers base address\n"); + return -ENOENT; + } + + ret = clk_get_by_index(dev, 0, &plat->clk); + if (ret < 0) + return ret; + + ret = reset_get_by_index(dev, 0, &plat->rst_ctl); + if (ret < 0) + goto clk_err; + + ret = gpio_request_list_by_name(dev, "cs-gpios", plat->cs_gpios, + ARRAY_SIZE(plat->cs_gpios), 0); + if (ret < 0) { + dev_err(dev, "Can't get %s cs gpios: %d", dev->name, ret); + ret = -ENOENT; + goto clk_err; + } + + return 0; + +clk_err: + clk_free(&plat->clk); + + return ret; +} + static int stm32_spi_probe(struct udevice *dev) { + struct stm32_spi_plat *plat = dev_get_plat(dev); struct stm32_spi_priv *priv = dev_get_priv(dev); + void __iomem *base = plat->base; unsigned long clk_rate; int ret; unsigned int i;
- priv->base = dev_remap_addr(dev); - if (!priv->base) - return -EINVAL; - /* enable clock */ - ret = clk_get_by_index(dev, 0, &priv->clk); + ret = clk_enable(&plat->clk); if (ret < 0) return ret;
- ret = clk_enable(&priv->clk); - if (ret < 0) - return ret; - - clk_rate = clk_get_rate(&priv->clk); + clk_rate = clk_get_rate(&plat->clk); if (!clk_rate) { ret = -EINVAL; goto clk_err; @@ -514,46 +566,34 @@ static int stm32_spi_probe(struct udevice *dev) priv->bus_clk_rate = clk_rate;
/* perform reset */ - ret = reset_get_by_index(dev, 0, &priv->rst_ctl); - if (ret < 0) - goto clk_err; - - reset_assert(&priv->rst_ctl); + reset_assert(&plat->rst_ctl); udelay(2); - reset_deassert(&priv->rst_ctl); - - ret = gpio_request_list_by_name(dev, "cs-gpios", priv->cs_gpios, - ARRAY_SIZE(priv->cs_gpios), 0); - if (ret < 0) { - dev_err(dev, "Can't get cs gpios: %d", ret); - goto reset_err; - } + reset_deassert(&plat->rst_ctl);
priv->fifo_size = stm32_spi_get_fifo_size(dev); - priv->cur_mode = SPI_FULL_DUPLEX; priv->cur_xferlen = 0; priv->cur_bpw = SPI_DEFAULT_WORDLEN; - clrsetbits_le32(priv->base + STM32_SPI_CFG1, SPI_CFG1_DSIZE, + clrsetbits_le32(base + STM32_SPI_CFG1, SPI_CFG1_DSIZE, priv->cur_bpw - 1);
- for (i = 0; i < ARRAY_SIZE(priv->cs_gpios); i++) { - if (!dm_gpio_is_valid(&priv->cs_gpios[i])) + for (i = 0; i < ARRAY_SIZE(plat->cs_gpios); i++) { + if (!dm_gpio_is_valid(&plat->cs_gpios[i])) continue;
- dm_gpio_set_dir_flags(&priv->cs_gpios[i], + dm_gpio_set_dir_flags(&plat->cs_gpios[i], GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE); }
/* Ensure I2SMOD bit is kept cleared */ - clrbits_le32(priv->base + STM32_SPI_I2SCFGR, SPI_I2SCFGR_I2SMOD); + clrbits_le32(base + STM32_SPI_I2SCFGR, SPI_I2SCFGR_I2SMOD);
/* * - SS input value high * - transmitter half duplex direction * - automatic communication suspend when RX-Fifo is full */ - setbits_le32(priv->base + STM32_SPI_CR1, + setbits_le32(base + STM32_SPI_CR1, SPI_CR1_SSI | SPI_CR1_HDDIR | SPI_CR1_MASRX);
/* @@ -562,40 +602,38 @@ static int stm32_spi_probe(struct udevice *dev) * SS input value is determined by the SSI bit * - keep control of all associated GPIOs */ - setbits_le32(priv->base + STM32_SPI_CFG2, + setbits_le32(base + STM32_SPI_CFG2, SPI_CFG2_MASTER | SPI_CFG2_SSM | SPI_CFG2_AFCNTR);
-reset_err: - reset_free(&priv->rst_ctl); - clk_err: - clk_disable(&priv->clk); - clk_free(&priv->clk); + clk_disable(&plat->clk); + clk_free(&plat->clk);
return ret; };
static int stm32_spi_remove(struct udevice *dev) { - struct stm32_spi_priv *priv = dev_get_priv(dev); + struct stm32_spi_plat *plat = dev_get_plat(dev); + void __iomem *base = plat->base; int ret;
stm32_spi_stopxfer(dev); - stm32_spi_disable(priv); + stm32_spi_disable(base);
- ret = reset_assert(&priv->rst_ctl); + ret = reset_assert(&plat->rst_ctl); if (ret < 0) return ret;
- reset_free(&priv->rst_ctl); + reset_free(&plat->rst_ctl);
- ret = clk_disable(&priv->clk); + ret = clk_disable(&plat->clk); if (ret < 0) return ret;
- clk_free(&priv->clk); + clk_free(&plat->clk);
return ret; }; @@ -618,7 +656,9 @@ U_BOOT_DRIVER(stm32_spi) = { .id = UCLASS_SPI, .of_match = stm32_spi_ids, .ops = &stm32_spi_ops, - .priv_auto = sizeof(struct stm32_spi_priv), + .of_to_plat = stm32_spi_of_to_plat, + .plat_auto = sizeof(struct stm32_spi_plat), + .priv_auto = sizeof(struct stm32_spi_priv), .probe = stm32_spi_probe, .remove = stm32_spi_remove, };
Hi Patrice,
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Hi
- struct stm32_spi_plat *plat = dev_get_plat(bus);
- void __iomem *base = plat->base;
- while ((priv->tx_len > 0) &&
} else if (priv->tx_len >= sizeof(u16) && IS_ALIGNED((uintptr_t)(priv->tx_buf + offs), sizeof(u16))) { const u16 *tx_buf16 = (const u16 *)(priv->tx_buf + offs);writel(*tx_buf32, base + STM32_SPI_TXDR); priv->tx_len -= sizeof(u32);
} else { const u8 *tx_buf8 = (const u8 *)(priv->tx_buf + offs);writew(*tx_buf16, base + STM32_SPI_TXDR); priv->tx_len -= sizeof(u16);
} }writeb(*tx_buf8, base + STM32_SPI_TXDR); priv->tx_len -= sizeof(u8);
} else if (IS_ALIGNED((uintptr_t)(priv->rx_buf + offs), sizeof(u16)) && (priv->rx_len >= sizeof(u16) ||*rx_buf32 = readl(base + STM32_SPI_RXDR); priv->rx_len -= sizeof(u32);
} else { u8 *rx_buf8 = (u8 *)(priv->rx_buf + offs);*rx_buf16 = readw(base + STM32_SPI_RXDR); priv->rx_len -= sizeof(u16);
}*rx_buf8 = readb(base + STM32_SPI_RXDR); priv->rx_len -= sizeof(u8);
- return stm32_spi_enable(base);
- return stm32_spi_disable(base);
dev_dbg(dev, "\n");
- ret = readl_poll_timeout(base + STM32_SPI_SR, sr, !(sr & SPI_SR_EOT), 100000); if (ret < 0) { if (cr1 & SPI_CR1_CSTART) {
- setbits_le32(base + STM32_SPI_IFCR, SPI_IFCR_ALL);
- return dm_gpio_set_value(&plat->cs_gpios[cs], enable ? 1 : 0);
- void __iomem *base = plat->base; u32 mbrdiv; long div;
priv->cur_hz = hz;
- void __iomem *base = plat->base; u32 sr; u32 ifcr = 0; u32 xferlen;
else return -EMSGSIZE;writel(xferlen, base + STM32_SPI_CR2);
while (1) {
stm32_spi_read_rxfifo(bus); ifcr |= SPI_SR_SUSP;
}stm32_spi_read_rxfifo(bus); break;
- struct stm32_spi_plat *plat = dev_get_plat(dev);
- void __iomem *base = plat->base; u32 count = 0;
- stm32_spi_enable(base);
- while (readl(base + STM32_SPI_SR) & SPI_SR_TXP)
return count;
- int ret;
- plat->base = dev_read_addr_ptr(dev);
- if (!plat->base) {
return -ENOENT;
- ret = clk_get_by_index(dev, 0, &plat->clk);
- if (ret < 0)
return ret;
- ret = reset_get_by_index(dev, 0, &plat->rst_ctl);
- if (ret < 0)
goto clk_err;
- ret = gpio_request_list_by_name(dev, "cs-gpios", plat->cs_gpios,
- if (ret < 0) {
ret = -ENOENT;
goto clk_err;
+clk_err:
- clk_free(&plat->clk);
- return ret;
- struct stm32_spi_plat *plat = dev_get_plat(dev); struct stm32_spi_priv *priv = dev_get_priv(dev);
- void __iomem *base = plat->base; unsigned long clk_rate; int ret; unsigned int i;
- if (!priv->base)
return -EINVAL;
- ret = clk_enable(&plat->clk); if (ret < 0) return ret;
- if (ret < 0)
return ret;
- clk_rate = clk_get_rate(&plat->clk); if (!clk_rate) { ret = -EINVAL; goto clk_err;
/* perform reset */
- if (ret < 0)
goto clk_err;
- reset_assert(&plat->rst_ctl); udelay(2);
- if (ret < 0) {
goto reset_err;
- clrsetbits_le32(base + STM32_SPI_CFG1, SPI_CFG1_DSIZE, priv->cur_bpw - 1);
- for (i = 0; i < ARRAY_SIZE(plat->cs_gpios); i++) {
-reset_err:
clk_err:
return ret;
- stm32_spi_disable(base);
- ret = reset_assert(&plat->rst_ctl); if (ret < 0) return ret;
- reset_free(&plat->rst_ctl);
- ret = clk_disable(&plat->clk); if (ret < 0) return ret;
return ret;
- .of_to_plat = stm32_spi_of_to_plat,
- .plat_auto = sizeof(struct stm32_spi_plat),
- .priv_auto = sizeof(struct stm32_spi_priv), .probe = stm32_spi_probe, .remove = stm32_spi_remove,
Applied on u-boot-stm32 for next
Thanks Patrice
Patrice CHOTARD
Patrice Chotard
Patrick DELAUNAY
