[U-Boot] [PATCH 0/7] driver: net: ti: clean up and code optimization
This series contains set of code clean up and optimizations for TI networking drivers. Patch 1 - Adds drivers/net/ti/ folder and moves all TI's networking code in this folder. Patches 2,3 - keystone2 clean up Patch 5 - introduces common TI MDIO support library as existing TI SoCs network HW IPs have similar MDIO implementation. Patches 6-7 - conversation of TI CPSW and keystone_net drivers to use common TI MDIO support library
tested dhcp and kernel boot on: - k2e/g/hk/l evms - am437x-gpevm and AM5748 IDK
TODO: TODO: As per code and documentation davinci_emac.c seems also can be re-worked to use common TI MDIO support library and network PHYs framework. Unfortunately, I have no HW to work with.
Grygorii Strashko (7): driver: net: consolidate ti's code in separate folder configs: net: convert DRIVER_TI_KEYSTONE_NET kconfig drivers: net: keystone_net: drop non dm code driver: net: ti: cpsw: update to use SPDX identifier driver: net: ti: introduce common mdio support library driver: net: ti: cpsw: switch to use common mdio lib driver: net: ti: keystone_net: switch to use common mdio lib
arch/arm/include/asm/ti-common/keystone_net.h | 27 -- arch/arm/mach-davinci/dp83848.c | 2 +- arch/arm/mach-davinci/et1011c.c | 2 +- arch/arm/mach-davinci/ksz8873.c | 2 +- arch/arm/mach-davinci/lxt972.c | 2 +- board/ti/ks2_evm/board.c | 53 ---- board/ti/ks2_evm/board.h | 3 - board/ti/ks2_evm/board_k2e.c | 74 ----- board/ti/ks2_evm/board_k2g.c | 18 -- board/ti/ks2_evm/board_k2hk.c | 42 --- board/ti/ks2_evm/board_k2l.c | 42 --- configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + drivers/net/Kconfig | 13 +- drivers/net/Makefile | 4 +- drivers/net/ti/Kconfig | 20 ++ drivers/net/ti/Makefile | 7 + drivers/net/{ => ti}/cpsw-common.c | 0 drivers/net/{ => ti}/cpsw.c | 146 +--------- drivers/net/ti/cpsw_mdio.c | 205 +++++++++++++ drivers/net/ti/cpsw_mdio.h | 18 ++ drivers/net/{ => ti}/davinci_emac.c | 0 drivers/net/{ => ti}/davinci_emac.h | 0 drivers/net/{ => ti}/keystone_net.c | 401 +------------------------- include/configs/ti_armv7_keystone2.h | 1 - 31 files changed, 288 insertions(+), 802 deletions(-) create mode 100644 drivers/net/ti/Kconfig create mode 100644 drivers/net/ti/Makefile rename drivers/net/{ => ti}/cpsw-common.c (100%) rename drivers/net/{ => ti}/cpsw.c (90%) create mode 100644 drivers/net/ti/cpsw_mdio.c create mode 100644 drivers/net/ti/cpsw_mdio.h rename drivers/net/{ => ti}/davinci_emac.c (100%) rename drivers/net/{ => ti}/davinci_emac.h (100%) rename drivers/net/{ => ti}/keystone_net.c (68%)
Add drivers/net/ti/ folder and move all TI's code in this folder for better maintenance.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- arch/arm/mach-davinci/dp83848.c | 2 +- arch/arm/mach-davinci/et1011c.c | 2 +- arch/arm/mach-davinci/ksz8873.c | 2 +- arch/arm/mach-davinci/lxt972.c | 2 +- drivers/net/Kconfig | 13 +------------ drivers/net/Makefile | 4 +--- drivers/net/ti/Kconfig | 15 +++++++++++++++ drivers/net/ti/Makefile | 7 +++++++ drivers/net/{ => ti}/cpsw-common.c | 0 drivers/net/{ => ti}/cpsw.c | 0 drivers/net/{ => ti}/davinci_emac.c | 0 drivers/net/{ => ti}/davinci_emac.h | 0 drivers/net/{ => ti}/keystone_net.c | 0 13 files changed, 28 insertions(+), 19 deletions(-) create mode 100644 drivers/net/ti/Kconfig create mode 100644 drivers/net/ti/Makefile rename drivers/net/{ => ti}/cpsw-common.c (100%) rename drivers/net/{ => ti}/cpsw.c (100%) rename drivers/net/{ => ti}/davinci_emac.c (100%) rename drivers/net/{ => ti}/davinci_emac.h (100%) rename drivers/net/{ => ti}/keystone_net.c (100%)
diff --git a/arch/arm/mach-davinci/dp83848.c b/arch/arm/mach-davinci/dp83848.c index 595e3ca..7115d7b 100644 --- a/arch/arm/mach-davinci/dp83848.c +++ b/arch/arm/mach-davinci/dp83848.c @@ -12,7 +12,7 @@ #include <net.h> #include <dp83848.h> #include <asm/arch/emac_defs.h> -#include "../../../drivers/net/davinci_emac.h" +#include "../../../drivers/net/ti/davinci_emac.h"
#ifdef CONFIG_DRIVER_TI_EMAC
diff --git a/arch/arm/mach-davinci/et1011c.c b/arch/arm/mach-davinci/et1011c.c index 3d02274..bfb7ff2 100644 --- a/arch/arm/mach-davinci/et1011c.c +++ b/arch/arm/mach-davinci/et1011c.c @@ -9,7 +9,7 @@ #include <net.h> #include <miiphy.h> #include <asm/arch/emac_defs.h> -#include "../../../drivers/net/davinci_emac.h" +#include "../../../drivers/net/ti/davinci_emac.h"
diff --git a/arch/arm/mach-davinci/ksz8873.c b/arch/arm/mach-davinci/ksz8873.c index 899cff0..85b0c26 100644 --- a/arch/arm/mach-davinci/ksz8873.c +++ b/arch/arm/mach-davinci/ksz8873.c @@ -19,7 +19,7 @@ #include <net.h> #include <asm/arch/emac_defs.h> #include <asm/io.h> -#include "../../../drivers/net/davinci_emac.h" +#include "../../../drivers/net/ti/davinci_emac.h"
int ksz8873_is_phy_connected(int phy_addr) { diff --git a/arch/arm/mach-davinci/lxt972.c b/arch/arm/mach-davinci/lxt972.c index 170e4a5..b54f67d 100644 --- a/arch/arm/mach-davinci/lxt972.c +++ b/arch/arm/mach-davinci/lxt972.c @@ -13,7 +13,7 @@ #include <miiphy.h> #include <lxt971a.h> #include <asm/arch/emac_defs.h> -#include "../../../drivers/net/davinci_emac.h" +#include "../../../drivers/net/ti/davinci_emac.h"
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index f1f0e2d..e904c5e 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -1,5 +1,6 @@ source "drivers/net/phy/Kconfig" source "drivers/net/pfe_eth/Kconfig" +source "drivers/net/ti/Kconfig"
config DM_ETH bool "Enable Driver Model for Ethernet drivers" @@ -11,13 +12,6 @@ config DM_ETH This is currently implemented in net/eth-uclass.c Look in include/net.h for details.
-config DRIVER_TI_CPSW - bool "TI Common Platform Ethernet Switch" - select PHYLIB - help - This driver supports the TI three port switch gigabit ethernet - subsystem found in the TI SoCs. - menuconfig NETDEVICES bool "Network device support" depends on NET @@ -322,11 +316,6 @@ config SH_ETHER help This driver supports the Ethernet for Renesas SH and ARM SoCs.
-config DRIVER_TI_EMAC - bool "TI Davinci EMAC" - help - Support for davinci emac - config XILINX_AXIEMAC depends on DM_ETH && (MICROBLAZE || ARCH_ZYNQ || ARCH_ZYNQMP) select PHYLIB diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 48a2878..8e33d7a 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -30,7 +30,6 @@ obj-$(CONFIG_FTGMAC100) += ftgmac100.o obj-$(CONFIG_FTMAC110) += ftmac110.o obj-$(CONFIG_FTMAC100) += ftmac100.o obj-$(CONFIG_GMAC_ROCKCHIP) += gmac_rockchip.o -obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o obj-$(CONFIG_LAN91C96) += lan91c96.o obj-$(CONFIG_LPC32XX_ETH) += lpc32xx_eth.o @@ -56,9 +55,7 @@ obj-$(CONFIG_SH_ETHER) += sh_eth.o obj-$(CONFIG_RENESAS_RAVB) += ravb.o obj-$(CONFIG_SMC91111) += smc91111.o obj-$(CONFIG_SMC911X) += smc911x.o -obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o -obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o obj-$(CONFIG_ULI526X) += uli526x.o obj-$(CONFIG_VSC7385_ENET) += vsc7385.o @@ -73,3 +70,4 @@ obj-$(CONFIG_PIC32_ETH) += pic32_mdio.o pic32_eth.o obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_FSL_PFE) += pfe_eth/ obj-$(CONFIG_SNI_AVE) += sni_ave.o +obj-y += ti/ diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig new file mode 100644 index 0000000..35a6b5d --- /dev/null +++ b/drivers/net/ti/Kconfig @@ -0,0 +1,15 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + +config DRIVER_TI_CPSW + bool "TI Common Platform Ethernet Switch" + select PHYLIB + help + This driver supports the TI three port switch gigabit ethernet + subsystem found in the TI SoCs. + +config DRIVER_TI_EMAC + bool "TI Davinci EMAC" + help + Support for davinci emac diff --git a/drivers/net/ti/Makefile b/drivers/net/ti/Makefile new file mode 100644 index 0000000..4ab4a27 --- /dev/null +++ b/drivers/net/ti/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + +obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o +obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o +obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o diff --git a/drivers/net/cpsw-common.c b/drivers/net/ti/cpsw-common.c similarity index 100% rename from drivers/net/cpsw-common.c rename to drivers/net/ti/cpsw-common.c diff --git a/drivers/net/cpsw.c b/drivers/net/ti/cpsw.c similarity index 100% rename from drivers/net/cpsw.c rename to drivers/net/ti/cpsw.c diff --git a/drivers/net/davinci_emac.c b/drivers/net/ti/davinci_emac.c similarity index 100% rename from drivers/net/davinci_emac.c rename to drivers/net/ti/davinci_emac.c diff --git a/drivers/net/davinci_emac.h b/drivers/net/ti/davinci_emac.h similarity index 100% rename from drivers/net/davinci_emac.h rename to drivers/net/ti/davinci_emac.h diff --git a/drivers/net/keystone_net.c b/drivers/net/ti/keystone_net.c similarity index 100% rename from drivers/net/keystone_net.c rename to drivers/net/ti/keystone_net.c
On Thu, Oct 25, 2018 at 10:40 PM Grygorii Strashko grygorii.strashko@ti.com wrote:
Convert DRIVER_TI_KEYSTONE_NET to Kconfig.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- configs/k2e_evm_defconfig | 1 + configs/k2e_hs_evm_defconfig | 1 + configs/k2g_evm_defconfig | 1 + configs/k2g_hs_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2hk_hs_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/k2l_hs_evm_defconfig | 1 + drivers/net/ti/Kconfig | 5 +++++ include/configs/ti_armv7_keystone2.h | 1 - 10 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index d744cb1..67b1f30 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -56,3 +56,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 87faf3d..1abda84 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -49,3 +49,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index a96029c..bc4b92b 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -60,3 +60,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 9e75500..66d8220 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -53,3 +53,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 8c7d362..f66d922 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -56,3 +56,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index c8f4bbe..dd91a51 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -49,3 +49,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index dd91aa5..4f04caa 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -56,3 +56,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index ac400e4..9ce23de 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -48,3 +48,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_DRIVER_TI_KEYSTONE_NET=y diff --git a/drivers/net/ti/Kconfig b/drivers/net/ti/Kconfig index 35a6b5d..c38e273 100644 --- a/drivers/net/ti/Kconfig +++ b/drivers/net/ti/Kconfig @@ -13,3 +13,8 @@ config DRIVER_TI_EMAC bool "TI Davinci EMAC" help Support for davinci emac + +config DRIVER_TI_KEYSTONE_NET + bool "TI Keystone 2 Ethernet" + help + This driver supports the TI Keystone 2 Ethernet subsystem \ No newline at end of file diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index cc823c5..5e504f6 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -128,7 +128,6 @@ #define CONFIG_KSNAV_NETCP_PDMA_TX_SND_QUEUE KS2_NETCP_PDMA_TX_SND_QUEUE
/* Keystone net */ -#define CONFIG_DRIVER_TI_KEYSTONE_NET #define CONFIG_KSNET_MAC_ID_BASE KS2_MAC_ID_BASE_ADDR #define CONFIG_KSNET_NETCP_BASE KS2_NETCP_BASE #define CONFIG_KSNET_SERDES_SGMII_BASE KS2_SGMII_SERDES_BASE
On Thu, Oct 25, 2018 at 10:41 PM Grygorii Strashko grygorii.strashko@ti.com wrote:
Networking support for all TI K2 boards converted to use DM model and CONFIG_DM_ETH enabled in all corresponding defconfig files, hence drop unused non DM K2 networking code.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- arch/arm/include/asm/ti-common/keystone_net.h | 14 -- board/ti/ks2_evm/board.c | 53 ----- board/ti/ks2_evm/board.h | 3 - board/ti/ks2_evm/board_k2e.c | 74 ------- board/ti/ks2_evm/board_k2g.c | 18 -- board/ti/ks2_evm/board_k2hk.c | 42 ---- board/ti/ks2_evm/board_k2l.c | 42 ---- drivers/net/ti/keystone_net.c | 287 +------------------------- 8 files changed, 1 insertion(+), 532 deletions(-)
diff --git a/arch/arm/include/asm/ti-common/keystone_net.h b/arch/arm/include/asm/ti-common/keystone_net.h index f89e043..bef1867 100644 --- a/arch/arm/include/asm/ti-common/keystone_net.h +++ b/arch/arm/include/asm/ti-common/keystone_net.h @@ -242,18 +242,4 @@ struct mdio_regs { u32 userphysel1; };
-struct eth_priv_t { - char int_name[32]; - int rx_flow; - int phy_addr; - int slave_port; - int sgmii_link_type; - phy_interface_t phy_if; - struct phy_device *phy_dev; -}; - -int keystone2_emac_initialize(struct eth_priv_t *eth_priv); -void sgmii_serdes_setup_156p25mhz(void); -void sgmii_serdes_shutdown(void); - #endif /* _KEYSTONE_NET_H_ */ diff --git a/board/ti/ks2_evm/board.c b/board/ti/ks2_evm/board.c index d81c8e6..72709c0 100644 --- a/board/ti/ks2_evm/board.c +++ b/board/ti/ks2_evm/board.c @@ -66,59 +66,6 @@ int board_init(void) return 0; }
-#ifdef CONFIG_DRIVER_TI_KEYSTONE_NET -#ifndef CONFIG_DM_ETH -int get_eth_env_param(char *env_name) -{ - char *env; - int res = -1; - - env = env_get(env_name); - if (env) - res = simple_strtol(env, NULL, 0); - - return res; -} - -int board_eth_init(bd_t *bis) -{ - int j; - int res; - int port_num; - char link_type_name[32]; - - if (cpu_is_k2g()) - writel(KS2_ETHERNET_RGMII, KS2_ETHERNET_CFG); - - /* By default, select PA PLL clock as PA clock source */ -#ifndef CONFIG_SOC_K2G - if (psc_enable_module(KS2_LPSC_PA)) - return -1; -#endif - if (psc_enable_module(KS2_LPSC_CPGMAC)) - return -1; - if (psc_enable_module(KS2_LPSC_CRYPTO)) - return -1; - - if (cpu_is_k2e() || cpu_is_k2l()) - pll_pa_clk_sel(); - - port_num = get_num_eth_ports(); - - for (j = 0; j < port_num; j++) { - sprintf(link_type_name, "sgmii%d_link_type", j); - res = get_eth_env_param(link_type_name); - if (res >= 0) - eth_priv_cfg[j].sgmii_link_type = res; - - keystone2_emac_initialize(ð_priv_cfg[j]); - } - - return 0; -} -#endif -#endif - #ifdef CONFIG_SPL_BUILD void spl_board_init(void) { diff --git a/board/ti/ks2_evm/board.h b/board/ti/ks2_evm/board.h index 250b649..d0cfbf5 100644 --- a/board/ti/ks2_evm/board.h +++ b/board/ti/ks2_evm/board.h @@ -12,8 +12,6 @@ #include <asm/ti-common/keystone_net.h> #include "../common/board_detect.h"
-extern struct eth_priv_t eth_priv_cfg[]; - #if defined(CONFIG_TI_I2C_BOARD_DETECT) static inline int board_is_k2g_gp(void) { @@ -38,7 +36,6 @@ static inline int board_is_k2g_ice(void) } #endif
-int get_num_eth_ports(void); void spl_init_keystone_plls(void);
#endif diff --git a/board/ti/ks2_evm/board_k2e.c b/board/ti/ks2_evm/board_k2e.c index f86a836..ecd4a42 100644 --- a/board/ti/ks2_evm/board_k2e.c +++ b/board/ti/ks2_evm/board_k2e.c @@ -89,80 +89,6 @@ struct pll_init_data *get_pll_init_data(int pll) return data; }
-#ifdef CONFIG_DRIVER_TI_KEYSTONE_NET -struct eth_priv_t eth_priv_cfg[] = { - { - .int_name = "K2E_EMAC0", - .rx_flow = 0, - .phy_addr = 0, - .slave_port = 1, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC1", - .rx_flow = 8, - .phy_addr = 1, - .slave_port = 2, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC2", - .rx_flow = 16, - .phy_addr = 2, - .slave_port = 3, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC3", - .rx_flow = 24, - .phy_addr = 3, - .slave_port = 4, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC4", - .rx_flow = 32, - .phy_addr = 4, - .slave_port = 5, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC5", - .rx_flow = 40, - .phy_addr = 5, - .slave_port = 6, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC6", - .rx_flow = 48, - .phy_addr = 6, - .slave_port = 7, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2E_EMAC7", - .rx_flow = 56, - .phy_addr = 7, - .slave_port = 8, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, -}; - -int get_num_eth_ports(void) -{ - return sizeof(eth_priv_cfg) / sizeof(struct eth_priv_t); -} -#endif - #if defined(CONFIG_MULTI_DTB_FIT) int board_fit_config_name_match(const char *name) { diff --git a/board/ti/ks2_evm/board_k2g.c b/board/ti/ks2_evm/board_k2g.c index 9bc94fb..87dc4d0 100644 --- a/board/ti/ks2_evm/board_k2g.c +++ b/board/ti/ks2_evm/board_k2g.c @@ -354,24 +354,6 @@ void spl_init_keystone_plls(void) } #endif
-#ifdef CONFIG_DRIVER_TI_KEYSTONE_NET -struct eth_priv_t eth_priv_cfg[] = { - { - .int_name = "K2G_EMAC", - .rx_flow = 0, - .phy_addr = 0, - .slave_port = 1, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_RGMII, - }, -}; - -int get_num_eth_ports(void) -{ - return sizeof(eth_priv_cfg) / sizeof(struct eth_priv_t); -} -#endif - #ifdef CONFIG_TI_SECURE_DEVICE void board_pmmc_image_process(ulong pmmc_image, size_t pmmc_size) { diff --git a/board/ti/ks2_evm/board_k2hk.c b/board/ti/ks2_evm/board_k2hk.c index abc89d8..4c0acd6 100644 --- a/board/ti/ks2_evm/board_k2hk.c +++ b/board/ti/ks2_evm/board_k2hk.c @@ -96,48 +96,6 @@ struct pll_init_data *get_pll_init_data(int pll) return data; }
-#ifdef CONFIG_DRIVER_TI_KEYSTONE_NET -struct eth_priv_t eth_priv_cfg[] = { - { - .int_name = "K2HK_EMAC", - .rx_flow = 22, - .phy_addr = 0, - .slave_port = 1, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2HK_EMAC1", - .rx_flow = 23, - .phy_addr = 1, - .slave_port = 2, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2HK_EMAC2", - .rx_flow = 24, - .phy_addr = 2, - .slave_port = 3, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2HK_EMAC3", - .rx_flow = 25, - .phy_addr = 3, - .slave_port = 4, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, -}; - -int get_num_eth_ports(void) -{ - return sizeof(eth_priv_cfg) / sizeof(struct eth_priv_t); -} -#endif - #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { diff --git a/board/ti/ks2_evm/board_k2l.c b/board/ti/ks2_evm/board_k2l.c index c28fad5..e49d8b3 100644 --- a/board/ti/ks2_evm/board_k2l.c +++ b/board/ti/ks2_evm/board_k2l.c @@ -84,48 +84,6 @@ struct pll_init_data *get_pll_init_data(int pll) return data; }
-#ifdef CONFIG_DRIVER_TI_KEYSTONE_NET -struct eth_priv_t eth_priv_cfg[] = { - { - .int_name = "K2L_EMAC", - .rx_flow = 0, - .phy_addr = 0, - .slave_port = 1, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2L_EMAC1", - .rx_flow = 8, - .phy_addr = 1, - .slave_port = 2, - .sgmii_link_type = SGMII_LINK_MAC_PHY, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2L_EMAC2", - .rx_flow = 16, - .phy_addr = 2, - .slave_port = 3, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, - { - .int_name = "K2L_EMAC3", - .rx_flow = 32, - .phy_addr = 3, - .slave_port = 4, - .sgmii_link_type = SGMII_LINK_MAC_MAC_FORCED, - .phy_if = PHY_INTERFACE_MODE_SGMII, - }, -}; - -int get_num_eth_ports(void) -{ - return sizeof(eth_priv_cfg) / sizeof(struct eth_priv_t); -} -#endif - #ifdef CONFIG_BOARD_EARLY_INIT_F int board_early_init_f(void) { diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index d4d909b..5550572 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -24,12 +24,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifndef CONFIG_DM_ETH -unsigned int emac_open; -static struct mii_dev *mdio_bus; -static unsigned int sys_has_mdio = 1; -#endif - #ifdef KEYSTONE2_EMAC_GIG_ENABLE #define emac_gigabit_enable(x) keystone2_eth_gigabit_enable(x) #else @@ -43,17 +37,6 @@ static unsigned int sys_has_mdio = 1;
static u8 rx_buffs[RX_BUFF_NUMS * RX_BUFF_LEN] __aligned(16);
-#ifndef CONFIG_DM_ETH -struct rx_buff_desc net_rx_buffs = { - .buff_ptr = rx_buffs, - .num_buffs = RX_BUFF_NUMS, - .buff_len = RX_BUFF_LEN, - .rx_flow = 22, -}; -#endif - -#ifdef CONFIG_DM_ETH - enum link_type { LINK_TYPE_SGMII_MAC_TO_MAC_AUTO = 0, LINK_TYPE_SGMII_MAC_TO_PHY_MODE = 1, @@ -83,7 +66,7 @@ enum link_type { #define DEVICE_EMACSW_BASE(base, x) ((base) + EMAC_EMACSW_PORT_BASE_OFS + \ (x) * 0x30)
-#elif defined CONFIG_KSNET_NETCP_V1_5 +#elif defined(CONFIG_KSNET_NETCP_V1_5)
#define EMAC_EMACSW_PORT_BASE_OFS 0x222000
@@ -113,7 +96,6 @@ struct ks2_eth_priv { bool emac_open; bool has_mdio; }; -#endif
/* MDIO */
@@ -184,31 +166,6 @@ static int keystone2_mdio_write(struct mii_dev *bus, return 0; }
-#ifndef CONFIG_DM_ETH -static void __attribute__((unused)) - keystone2_eth_gigabit_enable(struct eth_device *dev) -{ - u_int16_t data; - struct eth_priv_t *eth_priv = (struct eth_priv_t *)dev->priv; - - if (sys_has_mdio) { - data = keystone2_mdio_read(mdio_bus, eth_priv->phy_addr, - MDIO_DEVAD_NONE, 0); - /* speed selection MSB */ - if (!(data & (1 << 6))) - return; - } - - /* - * Check if link detected is giga-bit - * If Gigabit mode detected, enable gigbit in MAC - */ - writel(readl(DEVICE_EMACSL_BASE(eth_priv->slave_port - 1) + - CPGMACSL_REG_CTL) | - EMAC_MACCONTROL_GIGFORCE | EMAC_MACCONTROL_GIGABIT_ENABLE, - DEVICE_EMACSL_BASE(eth_priv->slave_port - 1) + CPGMACSL_REG_CTL); -} -#else static void __attribute__((unused)) keystone2_eth_gigabit_enable(struct udevice *dev) { @@ -232,7 +189,6 @@ static void __attribute__((unused)) EMAC_MACCONTROL_GIGFORCE | EMAC_MACCONTROL_GIGABIT_ENABLE, DEVICE_EMACSL_BASE(priv->slave_port - 1) + CPGMACSL_REG_CTL); } -#endif
#ifdef CONFIG_SOC_K2G int keystone_rgmii_config(struct phy_device *phy_dev) @@ -497,246 +453,6 @@ static void keystone2_net_serdes_setup(void) } #endif
-#ifndef CONFIG_DM_ETH - -int keystone2_eth_read_mac_addr(struct eth_device *dev) -{ - struct eth_priv_t *eth_priv; - u32 maca = 0; - u32 macb = 0; - - eth_priv = (struct eth_priv_t *)dev->priv; - - /* Read the e-fuse mac address */ - if (eth_priv->slave_port == 1) { - maca = __raw_readl(MAC_ID_BASE_ADDR); - macb = __raw_readl(MAC_ID_BASE_ADDR + 4); - } - - dev->enetaddr[0] = (macb >> 8) & 0xff; - dev->enetaddr[1] = (macb >> 0) & 0xff; - dev->enetaddr[2] = (maca >> 24) & 0xff; - dev->enetaddr[3] = (maca >> 16) & 0xff; - dev->enetaddr[4] = (maca >> 8) & 0xff; - dev->enetaddr[5] = (maca >> 0) & 0xff; - - return 0; -} - -int32_t cpmac_drv_send(u32 *buffer, int num_bytes, int slave_port_num) -{ - if (num_bytes < EMAC_MIN_ETHERNET_PKT_SIZE) - num_bytes = EMAC_MIN_ETHERNET_PKT_SIZE; - - return ksnav_send(&netcp_pktdma, buffer, - num_bytes, (slave_port_num) << 16); -} - -/* Eth device open */ -static int keystone2_eth_open(struct eth_device *dev, bd_t *bis) -{ - struct eth_priv_t *eth_priv = (struct eth_priv_t *)dev->priv; - struct phy_device *phy_dev = eth_priv->phy_dev; - - debug("+ emac_open\n"); - - net_rx_buffs.rx_flow = eth_priv->rx_flow; - - sys_has_mdio = - (eth_priv->sgmii_link_type == SGMII_LINK_MAC_PHY) ? 1 : 0; - - if (sys_has_mdio) - keystone2_mdio_reset(mdio_bus); - -#ifdef CONFIG_SOC_K2G - keystone_rgmii_config(phy_dev); -#else - keystone_sgmii_config(phy_dev, eth_priv->slave_port - 1, - eth_priv->sgmii_link_type); -#endif - - udelay(10000); - - /* On chip switch configuration */ - ethss_config(target_get_switch_ctl(), SWITCH_MAX_PKT_SIZE); - - /* TODO: add error handling code */ - if (qm_init()) { - printf("ERROR: qm_init()\n"); - return -1; - } - if (ksnav_init(&netcp_pktdma, &net_rx_buffs)) { - qm_close(); - printf("ERROR: netcp_init()\n"); - return -1; - } - - /* - * Streaming switch configuration. If not present this - * statement is defined to void in target.h. - * If present this is usually defined to a series of register writes - */ - hw_config_streaming_switch(); - - if (sys_has_mdio) { - keystone2_mdio_reset(mdio_bus); - - phy_startup(phy_dev); - if (phy_dev->link == 0) { - ksnav_close(&netcp_pktdma); - qm_close(); - return -1; - } - } - - emac_gigabit_enable(dev); - - ethss_start(); - - debug("- emac_open\n"); - - emac_open = 1; - - return 0; -} - -/* Eth device close */ -void keystone2_eth_close(struct eth_device *dev) -{ - struct eth_priv_t *eth_priv = (struct eth_priv_t *)dev->priv; - struct phy_device *phy_dev = eth_priv->phy_dev; - - debug("+ emac_close\n"); - - if (!emac_open) - return; - - ethss_stop(); - - ksnav_close(&netcp_pktdma); - qm_close(); - phy_shutdown(phy_dev); - - emac_open = 0; - - debug("- emac_close\n"); -} - -/* - * This function sends a single packet on the network and returns - * positive number (number of bytes transmitted) or negative for error - */ -static int keystone2_eth_send_packet(struct eth_device *dev, - void *packet, int length) -{ - int ret_status = -1; - struct eth_priv_t *eth_priv = (struct eth_priv_t *)dev->priv; - struct phy_device *phy_dev = eth_priv->phy_dev; - - genphy_update_link(phy_dev); - if (phy_dev->link == 0) - return -1; - - if (cpmac_drv_send((u32 *)packet, length, eth_priv->slave_port) != 0) - return ret_status; - - return length; -} - -/* - * This function handles receipt of a packet from the network - */ -static int keystone2_eth_rcv_packet(struct eth_device *dev) -{ - void *hd; - int pkt_size; - u32 *pkt; - - hd = ksnav_recv(&netcp_pktdma, &pkt, &pkt_size); - if (hd == NULL) - return 0; - - net_process_received_packet((uchar *)pkt, pkt_size); - - ksnav_release_rxhd(&netcp_pktdma, hd); - - return pkt_size; -} - -#ifdef CONFIG_MCAST_TFTP -static int keystone2_eth_bcast_addr(struct eth_device *dev, u32 ip, u8 set) -{ - return 0; -} -#endif - -/* - * This function initializes the EMAC hardware. - */ -int keystone2_emac_initialize(struct eth_priv_t *eth_priv) -{ - int res; - struct eth_device *dev; - struct phy_device *phy_dev; - struct mdio_regs *adap_mdio = (struct mdio_regs *)EMAC_MDIO_BASE_ADDR; - - dev = malloc(sizeof(struct eth_device)); - if (dev == NULL) - return -1; - - memset(dev, 0, sizeof(struct eth_device)); - - strcpy(dev->name, eth_priv->int_name); - dev->priv = eth_priv; - - keystone2_eth_read_mac_addr(dev); - - dev->iobase = 0; - dev->init = keystone2_eth_open; - dev->halt = keystone2_eth_close; - dev->send = keystone2_eth_send_packet; - dev->recv = keystone2_eth_rcv_packet; -#ifdef CONFIG_MCAST_TFTP - dev->mcast = keystone2_eth_bcast_addr; -#endif - - eth_register(dev); - - /* Register MDIO bus if it's not registered yet */ - if (!mdio_bus) { - mdio_bus = mdio_alloc(); - mdio_bus->read = keystone2_mdio_read; - mdio_bus->write = keystone2_mdio_write; - mdio_bus->reset = keystone2_mdio_reset; - mdio_bus->priv = (void *)EMAC_MDIO_BASE_ADDR; - strcpy(mdio_bus->name, "ethernet-mdio"); - - res = mdio_register(mdio_bus); - if (res) - return res; - } - -#ifndef CONFIG_SOC_K2G - keystone2_net_serdes_setup(); -#endif - - /* Create phy device and bind it with driver */ -#ifdef CONFIG_KSNET_MDIO_PHY_CONFIG_ENABLE - phy_dev = phy_connect(mdio_bus, eth_priv->phy_addr, - dev, eth_priv->phy_if); - phy_config(phy_dev); -#else - phy_dev = phy_find_by_mask(mdio_bus, 1 << eth_priv->phy_addr, - eth_priv->phy_if); - phy_dev->dev = dev; -#endif - eth_priv->phy_dev = phy_dev; - - return 0; -} - -#else - static int ks2_eth_start(struct udevice *dev) { struct ks2_eth_priv *priv = dev_get_priv(dev); @@ -1167,4 +883,3 @@ U_BOOT_DRIVER(eth_ks2) = { .platdata_auto_alloc_size = sizeof(struct eth_pdata), .flags = DM_FLAG_ALLOC_PRIV_DMA, }; -#endif
On Thu, Oct 25, 2018 at 10:42 PM Grygorii Strashko grygorii.strashko@ti.com wrote:
Update to use SPDX license identifier.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/net/ti/cpsw.c | 12 ++---------- 1 file changed, 2 insertions(+), 10 deletions(-)
diff --git a/drivers/net/ti/cpsw.c b/drivers/net/ti/cpsw.c index 8e2a48c..fe43d14 100644 --- a/drivers/net/ti/cpsw.c +++ b/drivers/net/ti/cpsw.c @@ -1,16 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0+ /* * CPSW Ethernet Switch Driver * - * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/ - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation version 2. - * - * This program is distributed "as is" WITHOUT ANY WARRANTY of any - * kind, whether express or implied; without even the implied warranty - * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. + * Copyright (C) 2010-2018 Texas Instruments Incorporated - http://www.ti.com/ */
#include <common.h>
On Thu, Oct 25, 2018 at 10:43 PM Grygorii Strashko grygorii.strashko@ti.com wrote:
All existing TI SoCs network HW have similar MDIO implementation, so introduce common mdio support library which can be reused by TI networking drivers.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/net/ti/Makefile | 2 +- drivers/net/ti/cpsw_mdio.c | 205 +++++++++++++++++++++++++++++++++++++++++++++ drivers/net/ti/cpsw_mdio.h | 18 ++++ 3 files changed, 224 insertions(+), 1 deletion(-) create mode 100644 drivers/net/ti/cpsw_mdio.c create mode 100644 drivers/net/ti/cpsw_mdio.h
diff --git a/drivers/net/ti/Makefile b/drivers/net/ti/Makefile index 4ab4a27..d2b6f20 100644 --- a/drivers/net/ti/Makefile +++ b/drivers/net/ti/Makefile @@ -2,6 +2,6 @@ # # Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
-obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o +obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o cpsw_mdio.o obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o diff --git a/drivers/net/ti/cpsw_mdio.c b/drivers/net/ti/cpsw_mdio.c new file mode 100644 index 0000000..ed9dd27 --- /dev/null +++ b/drivers/net/ti/cpsw_mdio.c @@ -0,0 +1,205 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * CPSW MDIO generic driver for TI AMxx/K2x/EMAC devices. + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <common.h> +#include <asm/io.h> +#include <miiphy.h> + +struct cpsw_mdio_regs { + u32 version; + u32 control; +#define CONTROL_IDLE BIT(31) +#define CONTROL_ENABLE BIT(30) +#define CONTROL_FAULT BIT(19) +#define CONTROL_FAULT_ENABLE BIT(18) +#define CONTROL_DIV_MASK GENMASK(15, 0) + + u32 alive; + u32 link; + u32 linkintraw; + u32 linkintmasked; + u32 __reserved_0[2]; + u32 userintraw; + u32 userintmasked; + u32 userintmaskset; + u32 userintmaskclr; + u32 __reserved_1[20]; + + struct { + u32 access; + u32 physel; +#define USERACCESS_GO BIT(31) +#define USERACCESS_WRITE BIT(30) +#define USERACCESS_ACK BIT(29) +#define USERACCESS_READ (0) +#define USERACCESS_PHY_REG_SHIFT (21) +#define USERACCESS_PHY_ADDR_SHIFT (16) +#define USERACCESS_DATA GENMASK(15, 0) + } user[0]; +}; + +#define CPSW_MDIO_DIV_DEF 0xff +#define PHY_REG_MASK 0x1f +#define PHY_ID_MASK 0x1f + +/* + * This timeout definition is a worst-case ultra defensive measure against + * unexpected controller lock ups. Ideally, we should never ever hit this + * scenario in practice. + */ +#define CPSW_MDIO_TIMEOUT 100 /* msecs */ + +struct cpsw_mdio { + struct cpsw_mdio_regs *regs; + struct mii_dev *bus; + int div; +}; + +/* wait until hardware is ready for another user access */ +static inline u32 cpsw_mdio_wait_for_user_access(struct cpsw_mdio *mdio) +{ + u32 reg = 0; + int timeout = CPSW_MDIO_TIMEOUT; + + while (timeout-- && ((reg = readl(&mdio->regs->user[0].access)) + & USERACCESS_GO)) + udelay(10); + + if (timeout == -1) { + printf("wait_for_user_access Timeout\n"); + return -ETIMEDOUT; + } + + return reg; +} + +static int cpsw_mdio_read(struct mii_dev *bus, int phy_id, + int dev_addr, int phy_reg) +{ + struct cpsw_mdio *mdio = bus->priv; + int data; + u32 reg; + + if (phy_reg & ~PHY_REG_MASK || phy_id & ~PHY_ID_MASK) + return -EINVAL; + + cpsw_mdio_wait_for_user_access(mdio); + reg = (USERACCESS_GO | USERACCESS_READ | + (phy_reg << USERACCESS_PHY_REG_SHIFT) | + (phy_id << USERACCESS_PHY_ADDR_SHIFT)); + writel(reg, &mdio->regs->user[0].access); + reg = cpsw_mdio_wait_for_user_access(mdio); + + data = (reg & USERACCESS_ACK) ? (reg & USERACCESS_DATA) : -1; + return data; +} + +static int cpsw_mdio_write(struct mii_dev *bus, int phy_id, int dev_addr, + int phy_reg, u16 data) +{ + struct cpsw_mdio *mdio = bus->priv; + u32 reg; + + if (phy_reg & ~PHY_REG_MASK || phy_id & ~PHY_ID_MASK) + return -EINVAL; + + cpsw_mdio_wait_for_user_access(mdio); + reg = (USERACCESS_GO | USERACCESS_WRITE | + (phy_reg << USERACCESS_PHY_REG_SHIFT) | + (phy_id << USERACCESS_PHY_ADDR_SHIFT) | + (data & USERACCESS_DATA)); + writel(reg, &mdio->regs->user[0].access); + cpsw_mdio_wait_for_user_access(mdio); + + return 0; +} + +u32 cpsw_mdio_get_alive(struct mii_dev *bus) +{ + struct cpsw_mdio *mdio = bus->priv; + u32 val; + + val = readl(&mdio->regs->control); + return val & GENMASK(15, 0); +} + +struct mii_dev *cpsw_mdio_init(const char *name, u32 mdio_base, + u32 bus_freq, int fck_freq) +{ + struct cpsw_mdio *cpsw_mdio; + int ret; + + cpsw_mdio = calloc(1, sizeof(*cpsw_mdio)); + if (!cpsw_mdio) { + debug("failed to alloc cpsw_mdio\n"); + return NULL; + } + + cpsw_mdio->bus = mdio_alloc(); + if (!cpsw_mdio->bus) { + debug("failed to alloc mii bus\n"); + free(cpsw_mdio); + return NULL; + } + + cpsw_mdio->regs = (struct cpsw_mdio_regs *)mdio_base; + + if (!bus_freq || !fck_freq) + cpsw_mdio->div = CPSW_MDIO_DIV_DEF; + else + cpsw_mdio->div = (fck_freq / bus_freq) - 1; + cpsw_mdio->div &= CONTROL_DIV_MASK; + + /* set enable and clock divider */ + writel(cpsw_mdio->div | CONTROL_ENABLE | CONTROL_FAULT | + CONTROL_FAULT_ENABLE, &cpsw_mdio->regs->control); + while (readl(&cpsw_mdio->regs->control) & CONTROL_IDLE) + ; + + /* + * wait for scan logic to settle: + * the scan time consists of (a) a large fixed component, and (b) a + * small component that varies with the mii bus frequency. These + * were estimated using measurements at 1.1 and 2.2 MHz on tnetv107x + * silicon. Since the effect of (b) was found to be largely + * negligible, we keep things simple here. + */ + udelay(1000); + + cpsw_mdio->bus->read = cpsw_mdio_read; + cpsw_mdio->bus->write = cpsw_mdio_write; + cpsw_mdio->bus->priv = cpsw_mdio; + strcpy(cpsw_mdio->bus->name, name); + + ret = mdio_register(cpsw_mdio->bus); + if (ret < 0) { + debug("failed to register mii bus\n"); + goto free_bus; + } + + return cpsw_mdio->bus; + +free_bus: + free(cpsw_mdio->bus); + free(cpsw_mdio); + return NULL; +} + +void cpsw_mdio_free(struct mii_dev *bus) +{ + struct cpsw_mdio *mdio = bus->priv; + u32 reg; + + /* disable mdio */ + reg = readl(&mdio->regs->control); + reg &= ~CONTROL_ENABLE; + writel(reg, &mdio->regs->control); + + mdio_unregister(bus); + mdio_free(bus); + free(mdio); +} diff --git a/drivers/net/ti/cpsw_mdio.h b/drivers/net/ti/cpsw_mdio.h new file mode 100644 index 0000000..4a76d4e --- /dev/null +++ b/drivers/net/ti/cpsw_mdio.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * CPSW MDIO generic driver API for TI AMxx/K2x/EMAC devices. + * + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#ifndef CPSW_MDIO_H_ +#define CPSW_MDIO_H_ + +struct cpsw_mdio; + +struct mii_dev *cpsw_mdio_init(const char *name, u32 mdio_base, + u32 bus_freq, int fck_freq); +void cpsw_mdio_free(struct mii_dev *bus); +u32 cpsw_mdio_get_alive(struct mii_dev *bus); + +#endif /* CPSW_MDIO_H_ */
Hi, why we don't combine this with: http://patchwork.ozlabs.org/patch/939726/ ? looks much more elegant to me.
cheers, Hannes
On Mon, Oct 29, 2018 at 8:04 AM Hannes Schmelzer hannes@schmelzer.or.at wrote:
I agree we should be moving that direction, but consolidating TI MDIO implementation is fairly orthogonal. Also haven't heard back from Ken on feedback to that patch.
cheers, Hannes
The mdio here is not modeled as device/driver and I, honestly, see no reasons for this at least now.
On Thu, Oct 25, 2018 at 10:39 PM Grygorii Strashko grygorii.strashko@ti.com wrote:
- CPSW MDIO generic driver for TI AMxx/K2x/EMAC devices.
- Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/
u32 version;
u32 control;
u32 alive;
u32 link;
u32 linkintraw;
u32 linkintmasked;
u32 userintraw;
u32 userintmasked;
u32 userintmaskset;
u32 userintmaskclr;
struct {
u32 access;
u32 physel;
} user[0];
- This timeout definition is a worst-case ultra defensive measure against
- unexpected controller lock ups. Ideally, we should never ever hit this
- scenario in practice.
+struct cpsw_mdio {
int div;
u32 reg = 0;
& USERACCESS_GO))
udelay(10);
Seems we should be using wait_for_bit instead of this function.
return -ETIMEDOUT;
return reg;
int data;
u32 reg;
return -EINVAL;
return data;
u32 reg;
return -EINVAL;
u32 val;
int ret;
if (!cpsw_mdio) {
return NULL;
free(cpsw_mdio);
return NULL;
else
udelay(1000);
mdelay(1);
snprintf(cpsw_mdio->bus->name, sizeof(cpsw_mdio->bus->name), name);
if (ret < 0) {
goto free_bus;
+free_bus:
mdio_free(cpsw_mdio->bus);
free(cpsw_mdio);
return NULL;
u32 reg;
/* disable mdio */
mdio_free(bus);
free(mdio);
- CPSW MDIO generic driver API for TI AMxx/K2x/EMAC devices.
+struct cpsw_mdio;
2.10.5
Update TI CPSW driver to re-use common mdio lib
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- drivers/net/ti/cpsw.c | 134 +++----------------------------------------------- 1 file changed, 6 insertions(+), 128 deletions(-)
diff --git a/drivers/net/ti/cpsw.c b/drivers/net/ti/cpsw.c index fe43d14..f5fd02e 100644 --- a/drivers/net/ti/cpsw.c +++ b/drivers/net/ti/cpsw.c @@ -21,11 +21,11 @@ #include <dm.h> #include <fdt_support.h>
+#include "cpsw_mdio.h" + DECLARE_GLOBAL_DATA_PTR;
#define BITMASK(bits) (BIT(bits) - 1) -#define PHY_REG_MASK 0x1f -#define PHY_ID_MASK 0x1f #define NUM_DESCS (PKTBUFSRX * 2) #define PKT_MIN 60 #define PKT_MAX (1500 + 14 + 4 + 4) @@ -76,37 +76,8 @@ DECLARE_GLOBAL_DATA_PTR; * unexpected controller lock ups. Ideally, we should never ever hit this * scenario in practice. */ -#define MDIO_TIMEOUT 100 /* msecs */ #define CPDMA_TIMEOUT 100 /* msecs */
-struct cpsw_mdio_regs { - u32 version; - u32 control; -#define CONTROL_IDLE BIT(31) -#define CONTROL_ENABLE BIT(30) - - u32 alive; - u32 link; - u32 linkintraw; - u32 linkintmasked; - u32 __reserved_0[2]; - u32 userintraw; - u32 userintmasked; - u32 userintmaskset; - u32 userintmaskclr; - u32 __reserved_1[20]; - - struct { - u32 access; - u32 physel; -#define USERACCESS_GO BIT(31) -#define USERACCESS_WRITE BIT(30) -#define USERACCESS_ACK BIT(29) -#define USERACCESS_READ (0) -#define USERACCESS_DATA (0xffff) - } user[0]; -}; - struct cpsw_regs { u32 id_ver; u32 control; @@ -484,100 +455,6 @@ static inline void cpsw_ale_port_state(struct cpsw_priv *priv, int port, __raw_writel(tmp, priv->ale_regs + offset); }
-static struct cpsw_mdio_regs *mdio_regs; - -/* wait until hardware is ready for another user access */ -static inline u32 wait_for_user_access(void) -{ - u32 reg = 0; - int timeout = MDIO_TIMEOUT; - - while (timeout-- && - ((reg = __raw_readl(&mdio_regs->user[0].access)) & USERACCESS_GO)) - udelay(10); - - if (timeout == -1) { - printf("wait_for_user_access Timeout\n"); - return -ETIMEDOUT; - } - return reg; -} - -/* wait until hardware state machine is idle */ -static inline void wait_for_idle(void) -{ - int timeout = MDIO_TIMEOUT; - - while (timeout-- && - ((__raw_readl(&mdio_regs->control) & CONTROL_IDLE) == 0)) - udelay(10); - - if (timeout == -1) - printf("wait_for_idle Timeout\n"); -} - -static int cpsw_mdio_read(struct mii_dev *bus, int phy_id, - int dev_addr, int phy_reg) -{ - int data; - u32 reg; - - if (phy_reg & ~PHY_REG_MASK || phy_id & ~PHY_ID_MASK) - return -EINVAL; - - wait_for_user_access(); - reg = (USERACCESS_GO | USERACCESS_READ | (phy_reg << 21) | - (phy_id << 16)); - __raw_writel(reg, &mdio_regs->user[0].access); - reg = wait_for_user_access(); - - data = (reg & USERACCESS_ACK) ? (reg & USERACCESS_DATA) : -1; - return data; -} - -static int cpsw_mdio_write(struct mii_dev *bus, int phy_id, int dev_addr, - int phy_reg, u16 data) -{ - u32 reg; - - if (phy_reg & ~PHY_REG_MASK || phy_id & ~PHY_ID_MASK) - return -EINVAL; - - wait_for_user_access(); - reg = (USERACCESS_GO | USERACCESS_WRITE | (phy_reg << 21) | - (phy_id << 16) | (data & USERACCESS_DATA)); - __raw_writel(reg, &mdio_regs->user[0].access); - wait_for_user_access(); - - return 0; -} - -static void cpsw_mdio_init(const char *name, u32 mdio_base, u32 div) -{ - struct mii_dev *bus = mdio_alloc(); - - mdio_regs = (struct cpsw_mdio_regs *)mdio_base; - - /* set enable and clock divider */ - __raw_writel(div | CONTROL_ENABLE, &mdio_regs->control); - - /* - * wait for scan logic to settle: - * the scan time consists of (a) a large fixed component, and (b) a - * small component that varies with the mii bus frequency. These - * were estimated using measurements at 1.1 and 2.2 MHz on tnetv107x - * silicon. Since the effect of (b) was found to be largely - * negligible, we keep things simple here. - */ - udelay(1000); - - bus->read = cpsw_mdio_read; - bus->write = cpsw_mdio_write; - strcpy(bus->name, name); - - mdio_register(bus); -} - /* Set a self-clearing bit in a register, and wait for it to clear */ static inline void setbit_and_wait_for_clear32(void *addr) { @@ -1003,7 +880,7 @@ static int cpsw_phy_init(struct cpsw_priv *priv, struct cpsw_slave *slave) static void cpsw_phy_addr_update(struct cpsw_priv *priv) { struct cpsw_platform_data *data = &priv->data; - u16 alive = mdio_regs->alive & GENMASK(15, 0); + u16 alive = cpsw_mdio_get_alive(priv->bus); int active = data->active_slave; int new_addr = ffs(alive) - 1;
@@ -1044,11 +921,12 @@ int _cpsw_register(struct cpsw_priv *priv) idx = idx + 1; }
- cpsw_mdio_init(priv->dev->name, data->mdio_base, data->mdio_div); + priv->bus = cpsw_mdio_init(priv->dev->name, data->mdio_base, 0, 0); + if (!priv->bus) + return -EFAULT;
cpsw_phy_addr_update(priv);
- priv->bus = miiphy_get_dev_by_name(priv->dev->name); for_active_slave(slave, priv) cpsw_phy_init(priv, slave);
On Thu, Oct 25, 2018 at 10:38 PM Grygorii Strashko grygorii.strashko@ti.com wrote:
Update TI Keystone 2 driver to re-use common mdio lib.
Signed-off-by: Grygorii Strashko grygorii.strashko@ti.com --- arch/arm/include/asm/ti-common/keystone_net.h | 13 --- drivers/net/ti/Makefile | 2 +- drivers/net/ti/keystone_net.c | 118 ++++---------------------- 3 files changed, 18 insertions(+), 115 deletions(-)
diff --git a/arch/arm/include/asm/ti-common/keystone_net.h b/arch/arm/include/asm/ti-common/keystone_net.h index bef1867..bba1048 100644 --- a/arch/arm/include/asm/ti-common/keystone_net.h +++ b/arch/arm/include/asm/ti-common/keystone_net.h @@ -57,19 +57,6 @@ /* MDIO clock output frequency */ #define EMAC_MDIO_CLOCK_FREQ 2500000 /* 2.5 MHz */
-/* MII Status Register */ -#define MII_STATUS_REG 1 -#define MII_STATUS_LINK_MASK 0x4 - -#define MDIO_CONTROL_IDLE 0x80000000 -#define MDIO_CONTROL_ENABLE 0x40000000 -#define MDIO_CONTROL_FAULT_ENABLE 0x40000 -#define MDIO_CONTROL_FAULT 0x80000 -#define MDIO_USERACCESS0_GO 0x80000000 -#define MDIO_USERACCESS0_WRITE_READ 0x0 -#define MDIO_USERACCESS0_WRITE_WRITE 0x40000000 -#define MDIO_USERACCESS0_ACK 0x20000000 - #define EMAC_MACCONTROL_MIIEN_ENABLE 0x20 #define EMAC_MACCONTROL_FULLDUPLEX_ENABLE 0x1 #define EMAC_MACCONTROL_GIGABIT_ENABLE BIT(7) diff --git a/drivers/net/ti/Makefile b/drivers/net/ti/Makefile index d2b6f20..ee3e4eb 100644 --- a/drivers/net/ti/Makefile +++ b/drivers/net/ti/Makefile @@ -4,4 +4,4 @@
obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o cpsw-common.o cpsw_mdio.o obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o -obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o +obj-$(CONFIG_DRIVER_TI_KEYSTONE_NET) += keystone_net.o cpsw_mdio.o diff --git a/drivers/net/ti/keystone_net.c b/drivers/net/ti/keystone_net.c index 5550572..a3ba91c 100644 --- a/drivers/net/ti/keystone_net.c +++ b/drivers/net/ti/keystone_net.c @@ -22,6 +22,8 @@ #include <asm/ti-common/keystone_serdes.h> #include <asm/arch/psc_defs.h>
#ifdef KEYSTONE2_EMAC_GIG_ENABLE @@ -97,93 +99,20 @@ struct ks2_eth_priv { bool has_mdio; };
-/* MDIO */ - -static int keystone2_mdio_reset(struct mii_dev *bus) -{ - u_int32_t clkdiv; - struct mdio_regs *adap_mdio = bus->priv; - - clkdiv = (EMAC_MDIO_BUS_FREQ / EMAC_MDIO_CLOCK_FREQ) - 1; - - writel((clkdiv & 0xffff) | MDIO_CONTROL_ENABLE | - MDIO_CONTROL_FAULT | MDIO_CONTROL_FAULT_ENABLE, - &adap_mdio->control); - - while (readl(&adap_mdio->control) & MDIO_CONTROL_IDLE) - ; - - return 0; -} - -/** - * keystone2_mdio_read - read a PHY register via MDIO interface. - * Blocks until operation is complete. - */ -static int keystone2_mdio_read(struct mii_dev *bus, - int addr, int devad, int reg) -{ - int tmp; - struct mdio_regs *adap_mdio = bus->priv; - - while (readl(&adap_mdio->useraccess0) & MDIO_USERACCESS0_GO) - ; - - writel(MDIO_USERACCESS0_GO | MDIO_USERACCESS0_WRITE_READ | - ((reg & 0x1f) << 21) | ((addr & 0x1f) << 16), - &adap_mdio->useraccess0); - - /* Wait for command to complete */ - while ((tmp = readl(&adap_mdio->useraccess0)) & MDIO_USERACCESS0_GO) - ; - - if (tmp & MDIO_USERACCESS0_ACK) - return tmp & 0xffff; - - return -1; -} - -/** - * keystone2_mdio_write - write to a PHY register via MDIO interface. - * Blocks until operation is complete. - */ -static int keystone2_mdio_write(struct mii_dev *bus, - int addr, int devad, int reg, u16 val) -{ - struct mdio_regs *adap_mdio = bus->priv; - - while (readl(&adap_mdio->useraccess0) & MDIO_USERACCESS0_GO) - ; - - writel(MDIO_USERACCESS0_GO | MDIO_USERACCESS0_WRITE_WRITE | - ((reg & 0x1f) << 21) | ((addr & 0x1f) << 16) | - (val & 0xffff), &adap_mdio->useraccess0); - - /* Wait for command to complete */ - while (readl(&adap_mdio->useraccess0) & MDIO_USERACCESS0_GO) - ; - - return 0; -} - static void __attribute__((unused)) keystone2_eth_gigabit_enable(struct udevice *dev) { struct ks2_eth_priv *priv = dev_get_priv(dev); - u_int16_t data; - - if (priv->has_mdio) { - data = keystone2_mdio_read(priv->mdio_bus, priv->phy_addr, - MDIO_DEVAD_NONE, 0); - /* speed selection MSB */ - if (!(data & (1 << 6))) - return; - }
/* * Check if link detected is giga-bit * If Gigabit mode detected, enable gigbit in MAC */ + if (priv->has_mdio) { + if (priv->phydev->speed != 1000) + return; + } + writel(readl(DEVICE_EMACSL_BASE(priv->slave_port - 1) + CPGMACSL_REG_CTL) | EMAC_MACCONTROL_GIGFORCE | EMAC_MACCONTROL_GIGABIT_ENABLE, @@ -484,8 +413,6 @@ static int ks2_eth_start(struct udevice *dev) hw_config_streaming_switch();
if (priv->has_mdio) { - keystone2_mdio_reset(priv->mdio_bus); - phy_startup(priv->phydev); if (priv->phydev->link == 0) { pr_err("phy startup failed\n"); @@ -605,9 +532,9 @@ static int ks2_eth_probe(struct udevice *dev) { struct ks2_eth_priv *priv = dev_get_priv(dev); struct mii_dev *mdio_bus; - int ret;
priv->dev = dev; + priv->emac_open = false;
/* These clock enables has to be moved to common location */ if (cpu_is_k2g()) @@ -626,45 +553,36 @@ static int ks2_eth_probe(struct udevice *dev) if (cpu_is_k2e() || cpu_is_k2l()) pll_pa_clk_sel();
- priv->net_rx_buffs.buff_ptr = rx_buffs; priv->net_rx_buffs.num_buffs = RX_BUFF_NUMS; priv->net_rx_buffs.buff_len = RX_BUFF_LEN;
if (priv->slave_port == 1) { +#ifndef CONFIG_SOC_K2G + keystone2_net_serdes_setup(); +#endif /* * Register MDIO bus for slave 0 only, other slave have * to re-use the same */ - mdio_bus = mdio_alloc(); + mdio_bus = cpsw_mdio_init("ethernet-mdio", + (u32)priv->mdio_base, + EMAC_MDIO_CLOCK_FREQ, + EMAC_MDIO_BUS_FREQ); if (!mdio_bus) { pr_err("MDIO alloc failed\n"); return -ENOMEM; } priv->mdio_bus = mdio_bus; - mdio_bus->read = keystone2_mdio_read; - mdio_bus->write = keystone2_mdio_write; - mdio_bus->reset = keystone2_mdio_reset; - mdio_bus->priv = priv->mdio_base; - sprintf(mdio_bus->name, "ethernet-mdio"); - - ret = mdio_register(mdio_bus); - if (ret) { - pr_err("MDIO bus register failed\n"); - return ret; - } } else { /* Get the MDIO bus from slave 0 device */ struct ks2_eth_priv *parent_priv;
parent_priv = dev_get_priv(dev->parent); priv->mdio_bus = parent_priv->mdio_bus; + priv->mdio_base = parent_priv->mdio_base; }
-#ifndef CONFIG_SOC_K2G - keystone2_net_serdes_setup(); -#endif - priv->netcp_pktdma = &netcp_pktdma;
if (priv->has_mdio) { @@ -680,9 +598,7 @@ int ks2_eth_remove(struct udevice *dev) { struct ks2_eth_priv *priv = dev_get_priv(dev);
- free(priv->phydev); - mdio_unregister(priv->mdio_bus); - mdio_free(priv->mdio_bus); + cpsw_mdio_free(priv->mdio_bus);
return 0; }
Grygorii Strashko
Hannes Schmelzer
Joe Hershberger
