[PATCH 1/1] efi_loader: partition numbers are hexadecimal
If we want to address partition 15 of virtio block device 11, we have to write:
virtio b:f
When calling sprintf() we must use %x for the device and partition numbers.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_disk.c | 4 ++-- lib/efi_loader/efi_var_file.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index 307d5d759b..988907ecb9 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -476,7 +476,7 @@ static efi_status_t efi_disk_add_dev( efi_system_partition.if_type = desc->if_type; efi_system_partition.devnum = desc->devnum; efi_system_partition.part = part; - EFI_PRINT("EFI system partition: %s %d:%d\n", + EFI_PRINT("EFI system partition: %s %x:%x\n", blk_get_if_type_name(desc->if_type), desc->devnum, part); } @@ -521,7 +521,7 @@ int efi_disk_create_partitions(efi_handle_t parent, struct blk_desc *desc,
if (part_get_info(desc, part, &info)) continue; - snprintf(devname, sizeof(devname), "%s:%d", pdevname, + snprintf(devname, sizeof(devname), "%s:%x", pdevname, part); ret = efi_disk_add_dev(parent, dp, if_typename, desc, diskid, &info, part, NULL); diff --git a/lib/efi_loader/efi_var_file.c b/lib/efi_loader/efi_var_file.c index b171d2d1a8..de076b8cbc 100644 --- a/lib/efi_loader/efi_var_file.c +++ b/lib/efi_loader/efi_var_file.c @@ -35,7 +35,7 @@ static efi_status_t __maybe_unused efi_set_blk_dev_to_system_partition(void) log_err("No EFI system partition\n"); return EFI_DEVICE_ERROR; } - snprintf(part_str, PART_STR_LEN, "%u:%u", + snprintf(part_str, PART_STR_LEN, "%x:%x", efi_system_partition.devnum, efi_system_partition.part); r = fs_set_blk_dev(blk_get_if_type_name(efi_system_partition.if_type), part_str, FS_TYPE_ANY); -- 2.32.0.rc0
