[U-Boot] [PATCH] travis: Add efi_loader grub2 test
We have all the building blocks now to run arbitrary efi applications in travis. The most important one out there is grub2, so let's add a simple test to verify that grub2 still comes up.
Signed-off-by: Alexander Graf agraf@suse.de
This patch depends on the previous travis efi_loader enablement --- .travis.yml | 8 ++++++ test/py/tests/test_efi_loader.py | 55 ++++++++++++++++++++++++++++++++-------- 2 files changed, 53 insertions(+), 10 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 1957734..8d8a754 100644 --- a/.travis.yml +++ b/.travis.yml @@ -29,6 +29,9 @@ addons: - gcc-arm-linux-gnueabihf - gcc-aarch64-linux-gnu - iasl + - grub-efi-ia32-bin + - rpm2cpio + - wget
install: # install latest device tree compiler @@ -45,6 +48,9 @@ install: - virtualenv /tmp/venv - . /tmp/venv/bin/activate - pip install pytest + - grub-mkimage -o ~/grub_x86.efi -O i386-efi normal echo lsefimmap lsefi lsefisystab efinet tftp minicmd + - mkdir ~/grub2-arm + - cd ~/grub2-arm; wget -O - http://download.opensuse.org/ports/armv7hl/distribution/leap/42.2/repo/oss/s... | rpm2cpio | cpio -di
env: global: @@ -88,6 +94,8 @@ script: # "-k something" even when $TEST_PY_TEST_SPEC doesnt need a custom # value. - export UBOOT_TRAVIS_BUILD_DIR=`cd .. && pwd`/.bm-work/${TEST_PY_BD}; + cp ~/grub_x86.efi $UBOOT_TRAVIS_BUILD_DIR/ + cp ~/grub2-arm/usr/lib/grub2/arm-efi/grub.efi $UBOOT_TRAVIS_BUILD_DIR/grub_arm.efi if [[ "${TEST_PY_BD}" != "" ]]; then ./test/py/test.py --bd ${TEST_PY_BD} ${TEST_PY_ID} -k "${TEST_PY_TEST_SPEC:-not a_test_which_does_not_exist}" diff --git a/test/py/tests/test_efi_loader.py b/test/py/tests/test_efi_loader.py index 7bf0170..43c0b9d 100644 --- a/test/py/tests/test_efi_loader.py +++ b/test/py/tests/test_efi_loader.py @@ -104,20 +104,18 @@ def test_efi_setup_static(u_boot_console): global net_set_up net_set_up = True
-@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') -def test_efi_helloworld_net(u_boot_console): - """Run the helloworld.efi binary via TFTP. +def fetch_tftp_file(u_boot_console, env_conf): + """Grab an env described file via TFTP and return its address
- The helloworld.efi file is downloaded from the TFTP server and gets - executed. + A file as described by an env config <env_conf> is downloaded from the TFTP + server. The address to that file is returned. """ - if not net_set_up: pytest.skip('Network not initialized')
- f = u_boot_console.config.env.get('env__efi_loader_helloworld_file', None) + f = u_boot_console.config.env.get(env_conf, None) if not f: - pytest.skip('No hello world binary specified in environment') + pytest.skip('No %s binary specified in environment' % env_conf)
addr = f.get('addr', None) if not addr: @@ -133,14 +131,26 @@ def test_efi_helloworld_net(u_boot_console):
expected_crc = f.get('crc32', None) if not expected_crc: - return + return addr
if u_boot_console.config.buildconfig.get('config_cmd_crc32', 'n') != 'y': - return + return addr
output = u_boot_console.run_command('crc32 %x $filesize' % addr) assert expected_crc in output
+ return addr + +@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +def test_efi_helloworld_net(u_boot_console): + """Run the helloworld.efi binary via TFTP. + + The helloworld.efi file is downloaded from the TFTP server and gets + executed. + """ + + addr = fetch_tftp_file(u_boot_console, 'env__efi_loader_helloworld_file') + output = u_boot_console.run_command('bootefi %x' % addr) expected_text = 'Hello, world' assert expected_text in output @@ -156,3 +166,28 @@ def test_efi_helloworld_builtin(u_boot_console): output = u_boot_console.run_command('bootefi hello') expected_text = 'Hello, world' assert expected_text in output + +@pytest.mark.buildconfigspec('cmd_bootefi') +def test_efi_grub_net(u_boot_console): + """Run the grub.efi binary via TFTP. + + The grub.efi file is downloaded from the TFTP server and gets + executed. + """ + + addr = fetch_tftp_file(u_boot_console, 'env__efi_loader_grub_file') + + u_boot_console.run_command('bootefi %x' % addr, wait_for_prompt=False) + + # Verify that we have an SMBIOS table + u_boot_console.wait_for('grub>') + output = u_boot_console.run_command('lsefisystab', wait_for_prompt=False, wait_for_echo=False) + u_boot_console.wait_for('SMBIOS') + + # Then exit cleanly + u_boot_console.wait_for('grub>') + output = u_boot_console.run_command('exit', wait_for_prompt=False, wait_for_echo=False) + u_boot_console.wait_for('r = 0') + + # And give us our U-Boot prompt back + u_boot_console.run_command('')
Alexander Graf
