Re: [PATCH 4/5] dm: adc: Add SPL_ADC Kconfig symbol for use of ADC in SPL
Hi Quentin,
On 2024-08-01 11:26, Quentin Schulz wrote:
Hi Jonas,
On 7/31/24 4:10 PM, Jonas Karlman wrote:
Hi Quentin,
On 2024-07-31 14:42, Quentin Schulz wrote:
Hi Jonas,
On 7/31/24 8:50 AM, Jonas Karlman wrote:
What model of Radxa ZERO 3W/3E boards can be identified using ADC at runtime, add a Kconfig symbol to allow use of ADC in SPL.
This will be used to identify board model in SPL to allow loading correct FIT configuration and FDT for U-Boot proper at SPL phase.
Signed-off-by: Jonas Karlman jonas@kwiboo.se
drivers/Makefile | 2 +- drivers/adc/Kconfig | 4 ++++ 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/Makefile b/drivers/Makefile index 9195dafd37e0..1acd94f3c17e 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -1,5 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
+obj-$(CONFIG_$(SPL_TPL_)ADC) += adc/ obj-$(CONFIG_$(SPL_TPL_)BIOSEMU) += bios_emulator/ obj-$(CONFIG_$(SPL_TPL_)BLK) += block/ obj-$(CONFIG_$(SPL_TPL_)BOOTCOUNT_LIMIT) += bootcount/ @@ -81,7 +82,6 @@ endif
ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),)
-obj-y += adc/ obj-y += ata/ obj-$(CONFIG_DM_DEMO) += demo/ obj-y += block/ diff --git a/drivers/adc/Kconfig b/drivers/adc/Kconfig index c9cdbe6942de..eb705f9e0fb8 100644 --- a/drivers/adc/Kconfig +++ b/drivers/adc/Kconfig @@ -11,6 +11,10 @@ config ADC - support supply's phandle with auto-enable - supply polarity setting in fdt
+config SPL_ADC
bool "Enable ADC drivers using Driver Model in SPL"
depends on ADC
This is just because you didn't modify the drivers/adc/Makefile to have obj-$(CONFIG_$(SPL_TPL_)ADC) += adc-uclass.o I assume? It's a bit odd to require a "proper" symbol for an SPL symbol.
Additionally, since you use $(SPL_TPL_) maybe add that TPL symbol too in the Kconfig?
Agree, this could have been done differently, I added the depends on ADC a few minutes before I send the series to ensure next user of ADC in SPL does not miss it.
I would rather not depend on a hack if we can avoid it. I believe: obj-$(CONFIG_$(SPL_TPL_)ADC) += adc-uclass.o should be enough of a change here?
I thinks so to, will change to that in a v2.
I'm actually wondering if we can't simply have obj-y += adc-uclass.o ? considering that this Makefile is only included if $(CONFIG_$(SPL_TPL_)ADC)?
Should be possible, but it is probably better to be explicit in case the condition in drivers/Makefile ever changes in the future.
Regards, Jonas
Cheers, Quentin
Jonas Karlman
