[U-Boot] [PATCH] mx53loco: use print_cpuinfo() defined in imx-common
use print_cpuinfo() defined in imx-common/cpu.c, instead of duplicating function.
Signed-off-by: Ashok Kumar Reddy kourla ashokkourla2000@gmail.com --- board/freescale/mx53loco/mx53loco.c | 14 -------------- include/configs/mx53loco.h | 1 + 2 files changed, 1 insertion(+), 14 deletions(-)
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index d8e027c..cc57bb3 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -478,20 +478,6 @@ int board_early_init_f(void) return 0; }
-int print_cpuinfo(void) -{ - u32 cpurev; - - cpurev = get_cpu_rev(); - printf("CPU: Freescale i.MX%x family rev%d.%d at %d MHz\n", - (cpurev & 0xFF000) >> 12, - (cpurev & 0x000F0) >> 4, - (cpurev & 0x0000F) >> 0, - mxc_get_clock(MXC_ARM_CLK) / 1000000); - printf("Reset cause: %s\n", get_reset_cause()); - return 0; -} - #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 8b4e008..29fa6b4 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -28,6 +28,7 @@ #define CONFIG_SYS_MX5_HCLK 24000000 #define CONFIG_SYS_MX5_CLK32 32768 #define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_CPUINFO
#define CONFIG_MACH_TYPE MACH_TYPE_MX53_LOCO
Hi Ashok,
The reason for duplicating this function is that we cannot print the CPU info right in the beginning, because if we do so the frequency of 800MHz would be reported, instead of the 1GHz that is only set later via I2C commands to the PMIC.
So, please let the code as is to avoid wrong CPU frequency to be reported.
Regards,
Fabio Estevam
On 23-06-2012 21:05, Fabio Estevam wrote:
Hi Ashok,
Regards,
Fabio Estevam
Hi Fabio,
Thanks for the information.
Regards, Ashok
Ashok
Fabio Estevam
