[U-Boot] [PATCH] arm946es: remove non used timer
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- cpu/arm946es/Makefile | 3 +- cpu/arm946es/interrupts.c | 158 --------------------------------------------- 2 files changed, 2 insertions(+), 159 deletions(-) delete mode 100644 cpu/arm946es/interrupts.c
diff --git a/cpu/arm946es/Makefile b/cpu/arm946es/Makefile index d5ac7d3..e81f2da 100644 --- a/cpu/arm946es/Makefile +++ b/cpu/arm946es/Makefile @@ -26,7 +26,8 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o -COBJS = interrupts.o cpu.o + +COBJS = cpu.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/cpu/arm946es/interrupts.c b/cpu/arm946es/interrupts.c deleted file mode 100644 index c13d309..0000000 --- a/cpu/arm946es/interrupts.c +++ /dev/null @@ -1,158 +0,0 @@ -/* - * (C) Copyright 2003 - * Texas Instruments <www.ti.com> - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Alex Zuepke azu@sysgo.de - * - * (C) Copyright 2002-2004 - * Gary Jennejohn, DENX Software Engineering, gj@denx.de - * - * (C) Copyright 2004 - * Philippe Robin, ARM Ltd. philippe.robin@arm.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <arm946es.h> - -#define TIMER_LOAD_VAL 0xffffffff -extern void reset_cpu(ulong addr); - -#ifdef CONFIG_INTEGRATOR - /* Timer functionality supplied by Integrator board (AP or CP) */ -#else - -static ulong timestamp; -static ulong lastdec; - -/* nothing really to do with interrupts, just starts up a counter. */ -int interrupt_init (void) -{ - /* init the timestamp and lastdec value */ - reset_timer_masked(); - - return (0); -} - -/* - * timer without interrupts - */ - -void reset_timer (void) -{ - reset_timer_masked (); -} - -ulong get_timer (ulong base) -{ - return get_timer_masked () - base; -} - -void set_timer (ulong t) -{ - timestamp = t; -} - -/* delay x useconds AND perserve advance timstamp value */ -void udelay(unsigned long usec) -{ - udelay_masked(usec); -} - -void reset_timer_masked (void) -{ - /* reset time */ - lastdec = READ_TIMER; /* capure current decrementer value time */ - timestamp = 0; /* start "advancing" time stamp from 0 */ -} - -ulong get_timer_raw (void) -{ - ulong now = READ_TIMER; /* current tick value */ - - if (lastdec >= now) { /* normal mode (non roll) */ - /* normal mode */ - timestamp += lastdec - now; /* move stamp fordward with absoulte diff ticks */ - } else { /* we have overflow of the count down timer */ - /* nts = ts + ld + (TLV - now) - * ts=old stamp, ld=time that passed before passing through -1 - * (TLV-now) amount of time after passing though -1 - * nts = new "advancing time stamp"...it could also roll and cause problems. - */ - timestamp += lastdec + TIMER_LOAD_VAL - now; - } - lastdec = now; - - return timestamp; -} - -ulong get_timer_masked (void) -{ - return get_timer_raw() / TIMER_LOAD_VAL; -} - -/* waits specified delay value and resets timestamp */ -void udelay_masked (unsigned long usec) -{ - ulong tmo; - - if(usec >= 1000){ /* if "big" number, spread normalization to seconds */ - tmo = usec / 1000; /* start to normalize for usec to ticks per sec */ - tmo *= CONFIG_SYS_HZ_CLOCK; /* find number of "ticks" to wait to achieve target */ - tmo /= 1000; /* finish normalize. */ - }else{ /* else small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ_CLOCK; - tmo /= (1000*1000); - } - - reset_timer_masked (); /* set "advancing" timestamp to 0, set lastdec vaule */ - - while (get_timer_raw () < tmo) /* wait for time stamp to overtake tick number.*/ - /*NOP*/; -} - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On ARM it returns the number of timer ticks per second. - */ -ulong get_tbclk (void) -{ - ulong tbclk; - - tbclk = CONFIG_SYS_HZ; - return tbclk; -} - -#endif /* CONFIG_INTEGRATOR */
