[U-Boot] [PULL] rpi patch queue 2018-04-06
Hi Tom,
This is my current patch queue for rpi. Please pull.
Alex
The following changes since commit 645b5afbb8215b3386cd6fc2dc3119bd68e4c760:
Prepare v2018.05-rc1 (2018-04-02 20:31:36 -0400)
git://github.com/agraf/u-boot.git tags/signed-rpi-next
for you to fetch changes up to 91e1bc53c4b61cd7b871d485f4c136084245e9a2:
rpi: Complete table of models with new revision code scheme (2018-04-06 11:04:29 +0200)
---------------------------------------------------------------- Patch queue for rpi - 2018-04-06
Highlights this time around:
- Support for new RPi3 B+ model - Fix for some SD cards on newer RPi firmware
---------------------------------------------------------------- Alexander Graf (3): rpi: Allow to boot without serial rpi3: Enable lan78xx driver rpi: Add identifier for the new RPi3 B+
Jonathan Gray (2): mmc: use core clock frequency in bcm2835 sdhost rpi: Complete table of models with new revision code scheme
Peter Robinson (1): rpi3_32b: Enable lan78xx driver
arch/arm/mach-bcm283x/include/mach/msg.h | 3 ++- arch/arm/mach-bcm283x/msg.c | 4 ++-- board/raspberrypi/rpi/rpi.c | 35 ++++++++++++++++++++++++++++++++ configs/rpi_0_w_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 2 ++ configs/rpi_3_defconfig | 2 ++ configs/rpi_defconfig | 1 + drivers/mmc/bcm2835_sdhci.c | 2 +- drivers/mmc/bcm2835_sdhost.c | 3 ++- 10 files changed, 49 insertions(+), 5 deletions(-)
On Fri, Apr 06, 2018 at 11:16:50AM +0200, Alexander Graf wrote:
Hi Tom,
Alex
Alexander Graf
