[PATCH 0/9] Enable u-boot splash screen for AM62x
Enable TI Display Subsystem (TIDSS) driver as UCLASS_VIDEO. Enable splash screen support, to display TI logo during boot-up. Tested on microtips panel (Model No: 13-101HIEBCAF0-S) which is supported by AM62x.
Nikhil M Jain (9): drivers: video: tidss: TIDSS video driver support for AM62x drivers: video: simple_panel: make simple panel independent of backlight arm: dts: k3-am62-main: Add device tree node for TIDSS arm: dts: k3-am625-sk: Add pin control for TIDSS and add panel device tree node arm: dts: k3-am625-sk-u-boot: Add u-boot,dm-pre-reloc flag for dss and panel video: Add support to build TIDSS include: configs: am62x_evm: Add environment variables for splash screen board: ti: am62x: evm: Add splash screen support configs: am62x_evm_a53_defconfig: Enable splash screen using tidss
MAINTAINERS | 1 + arch/arm/dts/k3-am62-main.dtsi | 41 ++ arch/arm/dts/k3-am625-sk-u-boot.dtsi | 8 + arch/arm/dts/k3-am625-sk.dts | 82 +++ board/ti/am62x/MAINTAINERS | 1 + board/ti/am62x/evm.c | 27 + configs/am62x_evm_a53_defconfig | 17 + drivers/video/Kconfig | 5 +- drivers/video/Makefile | 1 + drivers/video/simple_panel.c | 20 +- drivers/video/tidss/Kconfig | 7 + drivers/video/tidss/Makefile | 1 + drivers/video/tidss/tidss_drv.c | 971 +++++++++++++++++++++++++++ drivers/video/tidss/tidss_drv.h | 152 +++++ drivers/video/tidss/tidss_regs.h | 292 ++++++++ include/configs/am62x_evm.h | 6 +- 16 files changed, 1622 insertions(+), 10 deletions(-) create mode 100644 drivers/video/tidss/Kconfig create mode 100644 drivers/video/tidss/Makefile create mode 100644 drivers/video/tidss/tidss_drv.c create mode 100644 drivers/video/tidss/tidss_drv.h create mode 100644 drivers/video/tidss/tidss_regs.h
Added tidss video driver support which enables display on oldi panel using AM62x, it creates a simple pipeline framebuffer==>vidl1==>ovr1==>vp1==>oldi_panel and sets clock rates for panel, pixel format and the media bus format for panel.
TIDSS is ported from linux kernel version 5.10.145.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- MAINTAINERS | 1 + board/ti/am62x/MAINTAINERS | 1 + drivers/video/tidss/Kconfig | 7 + drivers/video/tidss/Makefile | 1 + drivers/video/tidss/tidss_drv.c | 971 +++++++++++++++++++++++++++++++ drivers/video/tidss/tidss_drv.h | 152 +++++ drivers/video/tidss/tidss_regs.h | 292 ++++++++++ 7 files changed, 1425 insertions(+) create mode 100644 drivers/video/tidss/Kconfig create mode 100644 drivers/video/tidss/Makefile create mode 100644 drivers/video/tidss/tidss_drv.c create mode 100644 drivers/video/tidss/tidss_drv.h create mode 100644 drivers/video/tidss/tidss_regs.h
diff --git a/MAINTAINERS b/MAINTAINERS index 3fc4cd0f12..665f97b2d9 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -642,6 +642,7 @@ F: drivers/soc/ti/ F: drivers/sysreset/sysreset-ti-sci.c F: drivers/thermal/ti-bandgap.c F: drivers/timer/omap-timer.c +F: drivers/video/tidss/ F: drivers/watchdog/omap_wdt.c F: include/linux/pruss_driver.h F: include/linux/soc/ti/ diff --git a/board/ti/am62x/MAINTAINERS b/board/ti/am62x/MAINTAINERS index 105e741995..7e6cc0b55e 100644 --- a/board/ti/am62x/MAINTAINERS +++ b/board/ti/am62x/MAINTAINERS @@ -6,3 +6,4 @@ F: board/ti/am62x/ F: include/configs/am62x_evm.h F: configs/am62x_evm_r5_defconfig F: configs/am62x_evm_a53_defconfig +F: diff --git a/drivers/video/tidss/Kconfig b/drivers/video/tidss/Kconfig new file mode 100644 index 0000000000..9d137f83d8 --- /dev/null +++ b/drivers/video/tidss/Kconfig @@ -0,0 +1,7 @@ +menuconfig VIDEO_TIDSS + bool "Enable TIDSS video support" + depends on VIDEO + help + TIDSS supports video output options LVDS and + DPI . This option enables these supports which can be used on + devices which have OLDI or HDMI display connected. \ No newline at end of file diff --git a/drivers/video/tidss/Makefile b/drivers/video/tidss/Makefile new file mode 100644 index 0000000000..fd323f2949 --- /dev/null +++ b/drivers/video/tidss/Makefile @@ -0,0 +1 @@ +obj-${CONFIG_VIDEO_TIDSS} = tidss_drv.o \ No newline at end of file diff --git a/drivers/video/tidss/tidss_drv.c b/drivers/video/tidss/tidss_drv.c new file mode 100644 index 0000000000..ff2fe965f5 --- /dev/null +++ b/drivers/video/tidss/tidss_drv.c @@ -0,0 +1,971 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 Texas Instruments Incorporated - https://www.ti.com/ + * Nikhil M Jain, n-jain1@ti.com + * + * based on the linux tidss driver, which is + * + * (C) Copyright 2018 Texas Instruments Incorporated - https://www.ti.com/ + * Author: Tomi Valkeinen tomi.valkeinen@ti.com + */ + +#include <dm.h> +#include <clk.h> +#include <log.h> +#include <video.h> +#include <errno.h> +#include <panel.h> +#include <reset.h> +#include <malloc.h> +#include <fdtdec.h> +#include <common.h> +#include <syscon.h> +#include <regmap.h> +#include <linux/iopoll.h> +#include <cpu_func.h> +#include <media_bus_format.h> + +#include <asm/io.h> +#include <asm/cache.h> +#include <asm/utils.h> +#include <asm/bitops.h> + +#include <linux/bug.h> + +#include <dm/devres.h> +#include <dm/of_access.h> +#include <dm/device_compat.h> +#include <dm/device-internal.h> + +#include <linux/delay.h> +#include <linux/err.h> + +#include "tidss_drv.h" +#include "tidss_regs.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* Panel parameters */ +enum { + LCD_MAX_WIDTH = 1920, + LCD_MAX_HEIGHT = 1200, + LCD_MAX_LOG2_BPP = VIDEO_BPP32, +}; + +static const u16 *dss_common_regmap; + +static const u16 tidss_am62x_common_regs[DSS_COMMON_REG_TABLE_LEN] = { + [DSS_REVISION_OFF] = 0x4, + [DSS_SYSCONFIG_OFF] = 0x8, + [DSS_SYSSTATUS_OFF] = 0x20, + [DSS_IRQ_EOI_OFF] = 0x24, + [DSS_IRQSTATUS_RAW_OFF] = 0x28, + [DSS_IRQSTATUS_OFF] = 0x2c, + [DSS_IRQENABLE_SET_OFF] = 0x30, + [DSS_IRQENABLE_CLR_OFF] = 0x40, + [DSS_VID_IRQENABLE_OFF] = 0x44, + [DSS_VID_IRQSTATUS_OFF] = 0x58, + [DSS_VP_IRQENABLE_OFF] = 0x70, + [DSS_VP_IRQSTATUS_OFF] = 0x7c, + + [WB_IRQENABLE_OFF] = 0x88, + [WB_IRQSTATUS_OFF] = 0x8c, + + [DSS_GLOBAL_MFLAG_ATTRIBUTE_OFF] = 0x90, + [DSS_GLOBAL_OUTPUT_ENABLE_OFF] = 0x94, + [DSS_GLOBAL_BUFFER_OFF] = 0x98, + [DSS_CBA_CFG_OFF] = 0x9c, + [DSS_DBG_CONTROL_OFF] = 0xa0, + [DSS_DBG_STATUS_OFF] = 0xa4, + [DSS_CLKGATING_DISABLE_OFF] = 0xa8, + [DSS_SECURE_DISABLE_OFF] = 0xac, +}; + +/* TIDSS AM62x Features */ +const struct dss_features dss_am625_feats = { + .max_pclk_khz = { + [DSS_VP_DPI] = 165000, + [DSS_VP_OLDI] = 165000, + }, + + .subrev = DSS_AM625, + + .common = "common", + .common_regs = tidss_am62x_common_regs, + + .num_vps = 2, + .vp_name = { "vp1", "vp2" }, + .ovr_name = { "ovr1", "ovr2" }, + .vpclk_name = { "vp1", "vp2" }, + .vp_bus_type = { DSS_VP_OLDI, DSS_VP_DPI }, + + .vp_feat = { .color = { + .has_ctm = true, + .gamma_size = 256, + .gamma_type = TIDSS_GAMMA_8BIT, + }, + }, + + .num_planes = 2, + /* note: vid is plane_id 0 and vidl1 is plane_id 1 */ + .vid_name = { "vidl1", "vid1" }, + .vid_lite = { true, false }, + .vid_order = { 1, 0 }, +}; + +/* Wrapper functions to write and read TI_DSS registers */ +static void dss_write(struct tidss_drv_priv *priv, u16 reg, u32 val) +{ + writel(val, priv->base_common + reg); +} + +static u32 dss_read(struct tidss_drv_priv *priv, u16 reg) +{ + return readl(priv->base_common + reg); +} + +static void dss_vid_write(struct tidss_drv_priv *priv, u32 hw_plane, u16 reg, u32 val) +{ + void __iomem *base = priv->base_vid[hw_plane]; + + writel(val, base + reg); +} + +static u32 dss_vid_read(struct tidss_drv_priv *priv, u32 hw_plane, u16 reg) +{ + void __iomem *base = priv->base_vid[hw_plane]; + + return readl(base + reg); +} + +static void dss_ovr_write(struct tidss_drv_priv *priv, u32 hw_videoport, + u16 reg, u32 val) +{ + void __iomem *base = priv->base_ovr[hw_videoport]; + + writel(val, base + reg); +} + +static u32 dss_ovr_read(struct tidss_drv_priv *priv, u32 hw_videoport, u16 reg) +{ + void __iomem *base = priv->base_ovr[hw_videoport]; + + return readl(base + reg); +} + +static void dss_vp_write(struct tidss_drv_priv *priv, u32 hw_videoport, + u16 reg, u32 val) +{ + void __iomem *base = priv->base_vp[hw_videoport]; + + writel(val, base + reg); +} + +static u32 dss_vp_read(struct tidss_drv_priv *priv, u32 hw_videoport, u16 reg) +{ + void __iomem *base = priv->base_vp[hw_videoport]; + + return readl(base + reg); +} + +static u32 FLD_MASK(u32 start, u32 end) +{ + return ((1 << (start - end + 1)) - 1) << end; +} + +static u32 FLD_VAL(u32 val, u32 start, u32 end) +{ + return (val << end) & FLD_MASK(start, end); +} + +static u32 FLD_GET(u32 val, u32 start, u32 end) +{ + return (val & FLD_MASK(start, end)) >> end; +} + +static u32 FLD_MOD(u32 orig, u32 val, u32 start, u32 end) +{ + return (orig & ~FLD_MASK(start, end)) | FLD_VAL(val, start, end); +} + +__maybe_unused +static u32 REG_GET(struct tidss_drv_priv *priv, u32 idx, u32 start, u32 end) +{ + return FLD_GET(dss_read(priv, idx), start, end); +} + +static void REG_FLD_MOD(struct tidss_drv_priv *priv, u32 idx, u32 val, + u32 start, u32 end) +{ + dss_write(priv, idx, FLD_MOD(dss_read(priv, idx), val, + start, end)); +} + +static u32 VID_REG_GET(struct tidss_drv_priv *priv, u32 hw_plane, u32 idx, + u32 start, u32 end) +{ + return FLD_GET(dss_vid_read(priv, hw_plane, idx), start, end); +} + +static void VID_REG_FLD_MOD(struct tidss_drv_priv *priv, u32 hw_plane, u32 idx, + u32 val, u32 start, u32 end) +{ + dss_vid_write(priv, hw_plane, idx, + FLD_MOD(dss_vid_read(priv, hw_plane, idx), + val, start, end)); +} + +__maybe_unused +static u32 VP_REG_GET(struct tidss_drv_priv *priv, u32 vp, u32 idx, + u32 start, u32 end) +{ + return FLD_GET(dss_vp_read(priv, vp, idx), start, end); +} + +static void VP_REG_FLD_MOD(struct tidss_drv_priv *priv, u32 vp, u32 idx, u32 val, + u32 start, u32 end) +{ + dss_vp_write(priv, vp, idx, FLD_MOD(dss_vp_read(priv, vp, idx), + val, start, end)); +} + +__maybe_unused +static u32 OVR_REG_GET(struct tidss_drv_priv *priv, u32 ovr, u32 idx, + u32 start, u32 end) +{ + return FLD_GET(dss_ovr_read(priv, ovr, idx), start, end); +} + +static void OVR_REG_FLD_MOD(struct tidss_drv_priv *priv, u32 ovr, u32 idx, + u32 val, u32 start, u32 end) +{ + dss_ovr_write(priv, ovr, idx, FLD_MOD(dss_ovr_read(priv, ovr, idx), + val, start, end)); +} + +static void dss_oldi_tx_power(struct tidss_drv_priv *priv, bool power) +{ + u32 val; + + if (WARN_ON(!priv->oldi_io_ctrl)) + return; + + if (priv->feat->subrev == DSS_AM625) { + if (power) { + switch (priv->oldi_mode) { + case OLDI_SINGLE_LINK_SINGLE_MODE: + /* Power down OLDI TX 1 */ + val = OLDI1_PWRDN_TX; + break; + case OLDI_DUAL_LINK: + /* No Power down */ + val = 0; + break; + default: + /* Power down both the OLDI TXes */ + val = OLDI_BANDGAP_PWR | OLDI0_PWRDN_TX | OLDI1_PWRDN_TX; + break; + } + } else { + val = OLDI_BANDGAP_PWR | OLDI0_PWRDN_TX | OLDI1_PWRDN_TX; + } + regmap_update_bits(priv->oldi_io_ctrl, OLDI_PD_CTRL, + OLDI_BANDGAP_PWR | OLDI0_PWRDN_TX | OLDI1_PWRDN_TX, val); + } +} + +static void dss_set_num_datalines(struct tidss_drv_priv *priv, + u32 hw_videoport) +{ + int v; + u32 num_lines = priv->bus_format->data_width; + + switch (num_lines) { + case 12: + v = 0; break; + case 16: + v = 1; break; + case 18: + v = 2; break; + case 24: + v = 3; break; + case 30: + v = 4; break; + case 36: + v = 5; break; + default: + WARN_ON(1); + v = 3; + } + + VP_REG_FLD_MOD(priv, hw_videoport, DSS_VP_CONTROL, v, 10, 8); +} + +static void dss_enable_oldi(struct tidss_drv_priv *priv, u32 hw_videoport) +{ + u32 oldi_cfg = 0; + u32 oldi_reset_bit = BIT(5 + hw_videoport); + int count = 0; + + /* + * For the moment MASTERSLAVE, and SRC bits of DSS_VP_DSS_OLDI_CFG are + * set statically to 0. + */ + + if (priv->bus_format->data_width == 24) + oldi_cfg |= BIT(8); /* MSB */ + else if (priv->bus_format->data_width != 18) + dev_warn(priv->dev, "%s: %d port width not supported\n", + __func__, priv->bus_format->data_width); + + oldi_cfg |= BIT(7); /* DEPOL */ + + oldi_cfg = FLD_MOD(oldi_cfg, priv->bus_format->oldi_mode_reg_val, 3, 1); + + oldi_cfg |= BIT(12); /* SOFTRST */ + + oldi_cfg |= BIT(0); /* ENABLE */ + + switch (priv->oldi_mode) { + case OLDI_MODE_OFF: + oldi_cfg &= ~BIT(0); /* DISABLE */ + break; + + case OLDI_SINGLE_LINK_SINGLE_MODE: + /* All configuration is done for this mode. */ + break; + + case OLDI_SINGLE_LINK_DUPLICATE_MODE: + oldi_cfg |= BIT(5); /* DUPLICATE MODE */ + break; + + case OLDI_DUAL_LINK: + oldi_cfg |= BIT(11); /* DUALMODESYNC */ + oldi_cfg |= BIT(3); /* data-mapping field also indicates dual-link mode */ + break; + + default: + dev_warn(priv->dev, "%s: Incorrect oldi mode. Returning.\n", + __func__); + return; + } + + dss_vp_write(priv, hw_videoport, DSS_VP_DSS_OLDI_CFG, oldi_cfg); + + while (!(oldi_reset_bit & dss_read(priv, DSS_SYSSTATUS)) && + count < 10000) + count++; + + if (!(oldi_reset_bit & dss_read(priv, DSS_SYSSTATUS))) + dev_warn(priv->dev, "%s: timeout waiting OLDI reset done\n", + __func__); +} + +static const struct dss_color_lut dss_vp_gamma_default_lut[] = { + { .red = 0, .green = 0, .blue = 0, }, + { .red = U16_MAX, .green = U16_MAX, .blue = U16_MAX, }, +}; + +static void dss_vp_write_gamma_table(struct tidss_drv_priv *priv, + u32 hw_videoport) +{ + u32 *table = priv->vp_data[hw_videoport].gamma_table; + u32 hwlen = priv->feat->vp_feat.color.gamma_size; + unsigned int i; + + dev_dbg(priv->dev, "%s: hw_videoport %d\n", __func__, hw_videoport); + + for (i = 0; i < hwlen; ++i) { + u32 v = table[i]; + + v |= i << 24; + + dss_vp_write(priv, hw_videoport, DSS_VP_GAMMA_TABLE, v); + } +} + +static void dss_vp_set_gamma(struct tidss_drv_priv *priv, + u32 hw_videoport, const struct dss_color_lut *lut, + unsigned int length) +{ + u32 *table = priv->vp_data[hw_videoport].gamma_table; + u32 hwlen = priv->feat->vp_feat.color.gamma_size; + u32 hwbits; + unsigned int i; + + dev_dbg(priv->dev, "%s: hw_videoport %d, lut len %u, hw len %u\n", + __func__, hw_videoport, length, hwlen); + + if (priv->feat->vp_feat.color.gamma_type == TIDSS_GAMMA_10BIT) + hwbits = 10; + else + hwbits = 8; + + lut = dss_vp_gamma_default_lut; + length = ARRAY_SIZE(dss_vp_gamma_default_lut); + + for (i = 0; i < length - 1; ++i) { + unsigned int first = i * (hwlen - 1) / (length - 1); + unsigned int last = (i + 1) * (hwlen - 1) / (length - 1); + unsigned int w = last - first; + u16 r, g, b; + unsigned int j; + + if (w == 0) + continue; + + for (j = 0; j <= w; j++) { + r = (lut[i].red * (w - j) + lut[i + 1].red * j) / w; + g = (lut[i].green * (w - j) + lut[i + 1].green * j) / w; + b = (lut[i].blue * (w - j) + lut[i + 1].blue * j) / w; + + r >>= 16 - hwbits; + g >>= 16 - hwbits; + b >>= 16 - hwbits; + + table[first + j] = (r << (hwbits * 2)) | + (g << hwbits) | b; + } + } + + dss_vp_write_gamma_table(priv, hw_videoport); +} + +void dss_vp_enable(struct tidss_drv_priv *priv, u32 hw_videoport, struct display_timing *timing) +{ + bool align, onoff, rf, ieo, ipc, ihs, ivs; + u32 hsw, hfp, hbp, vsw, vfp, vbp; + + dss_set_num_datalines(priv, hw_videoport); + + hfp = timing->hfront_porch.typ; + hsw = timing->hsync_len.typ; + hbp = timing->hback_porch.typ; + vfp = timing->vfront_porch.typ; + vsw = timing->vsync_len.typ; + vbp = timing->vback_porch.typ; + + dss_vp_write(priv, hw_videoport, DSS_VP_TIMING_H, + FLD_VAL(hsw - 1, 7, 0) | + FLD_VAL(hfp - 1, 19, 8) | FLD_VAL(hbp - 1, 31, 20)); + + dss_vp_write(priv, hw_videoport, DSS_VP_TIMING_V, + FLD_VAL(vsw - 1, 7, 0) | + FLD_VAL(vfp, 19, 8) | FLD_VAL(vbp, 31, 20)); + + ivs = !!(timing->flags & (1 << 3)); + + ihs = !!(timing->flags & (1 << 1)); + + ieo = 0; + + ipc = 0; + + /* always use the 'rf' setting */ + onoff = true; + + rf = true; + + /* always use aligned syncs */ + align = true; + + /* always use DE_HIGH for OLDI */ + if (priv->feat->vp_bus_type[hw_videoport] == DSS_VP_OLDI) + ieo = false; + + dss_vp_write(priv, hw_videoport, DSS_VP_POL_FREQ, + FLD_VAL(align, 18, 18) | + FLD_VAL(onoff, 17, 17) | + FLD_VAL(rf, 16, 16) | + FLD_VAL(ieo, 15, 15) | + FLD_VAL(ipc, 14, 14) | + FLD_VAL(ihs, 13, 13) | + FLD_VAL(ivs, 12, 12)); + + dss_vp_write(priv, hw_videoport, DSS_VP_SIZE_SCREEN, + FLD_VAL(timing->hactive.typ - 1, 11, 0) | + FLD_VAL(timing->vactive.typ - 1, 27, 16)); + + VP_REG_FLD_MOD(priv, hw_videoport, DSS_VP_CONTROL, 1, 0, 0); +} + +enum c8_to_c12_mode { C8_TO_C12_REPLICATE, C8_TO_C12_MAX, C8_TO_C12_MIN }; + +static u16 c8_to_c12(u8 c8, enum c8_to_c12_mode mode) +{ + u16 c12; + + c12 = c8 << 4; + + switch (mode) { + case C8_TO_C12_REPLICATE: + /* Copy c8 4 MSB to 4 LSB for full scale c12 */ + c12 |= c8 >> 4; + break; + case C8_TO_C12_MAX: + c12 |= 0xF; + break; + default: + case C8_TO_C12_MIN: + break; + } + + return c12; +} + +static u64 argb8888_to_argb12121212(u32 argb8888, enum c8_to_c12_mode m) +{ + u8 a, r, g, b; + u64 v; + + a = (argb8888 >> 24) & 0xff; + r = (argb8888 >> 16) & 0xff; + g = (argb8888 >> 8) & 0xff; + b = (argb8888 >> 0) & 0xff; + + v = ((u64)c8_to_c12(a, m) << 36) | ((u64)c8_to_c12(r, m) << 24) | + ((u64)c8_to_c12(g, m) << 12) | (u64)c8_to_c12(b, m); + + return v; +} + +static void dss_vp_set_default_color(struct tidss_drv_priv *priv, + u32 hw_videoport, u32 default_color) +{ + u64 v; + + v = argb8888_to_argb12121212(default_color, C8_TO_C12_REPLICATE); + dss_ovr_write(priv, hw_videoport, + DSS_OVR_DEFAULT_COLOR, v & 0xffffffff); + dss_ovr_write(priv, hw_videoport, + DSS_OVR_DEFAULT_COLOR2, (v >> 32) & 0xffff); +} + +int dss_vp_enable_clk(struct tidss_drv_priv *priv, u32 hw_videoport) +{ + int ret = clk_prepare_enable(&priv->vp_clk[hw_videoport]); + + if (ret) + dev_dbg(priv->dev, "%s: enabling clk failed: %d\n", __func__, + ret); + + return ret; +} + +void dss_vp_prepare(struct tidss_drv_priv *priv, u32 hw_videoport) +{ + dss_vp_set_gamma(priv, hw_videoport, NULL, 0); + dss_vp_set_default_color(priv, 0, 0); + + if (priv->feat->vp_bus_type[hw_videoport] == DSS_VP_OLDI) { + dss_oldi_tx_power(priv, true); + dss_enable_oldi(priv, hw_videoport); + } +} + +static +unsigned int dss_pclk_diff(unsigned long rate, unsigned long real_rate) +{ + int r = rate / 100, rr = real_rate / 100; + + return (unsigned int)(abs(((rr - r) * 100) / r)); +} + +int dss_vp_set_clk_rate(struct tidss_drv_priv *priv, u32 hw_videoport, + unsigned long rate) +{ + int r; + unsigned long new_rate; + + /* + * For AM625 OLDI video ports, the requested pixel clock needs to take into account the + * serial clock required for the serialization of DPI signals into LVDS signals. The + * incoming pixel clock on the OLDI video port gets divided by 7 whenever OLDI enable bit + * gets set. + */ + if (priv->feat->vp_bus_type[hw_videoport] == DSS_VP_OLDI && + priv->feat->subrev == DSS_AM625) + rate *= 7; + + r = clk_set_rate(&priv->vp_clk[hw_videoport], rate); + + new_rate = clk_get_rate(&priv->vp_clk[hw_videoport]); + + if (dss_pclk_diff(rate, new_rate) > 5) + dev_warn(priv->dev, + "vp%d: Clock rate %lu differs over 5%% from requested %lu\n", + hw_videoport, new_rate, rate); + + dev_dbg(priv->dev, "vp%d: new rate %lu Hz (requested %lu Hz)\n", + hw_videoport, clk_get_rate(&priv->vp_clk[hw_videoport]), rate); + return 0; +} + +static void dss_ovr_set_plane(struct tidss_drv_priv *priv, + u32 hw_plane, u32 hw_ovr, + u32 x, u32 y, u32 layer) +{ + OVR_REG_FLD_MOD(priv, hw_ovr, DSS_OVR_ATTRIBUTES(layer), + 0x1, 4, 1); + OVR_REG_FLD_MOD(priv, hw_ovr, DSS_OVR_ATTRIBUTES(layer), + x, 17, 6); + OVR_REG_FLD_MOD(priv, hw_ovr, DSS_OVR_ATTRIBUTES(layer), + y, 30, 19); +} + +void dss_ovr_enable_layer(struct tidss_drv_priv *priv, + u32 hw_ovr, u32 layer, bool enable) +{ + OVR_REG_FLD_MOD(priv, hw_ovr, DSS_OVR_ATTRIBUTES(layer), + !!enable, 0, 0); +} + +static void dss_vid_csc_enable(struct tidss_drv_priv *priv, u32 hw_plane, + bool enable) +{ + VID_REG_FLD_MOD(priv, hw_plane, DSS_VID_ATTRIBUTES, !!enable, 9, 9); +} + +int dss_plane_setup(struct tidss_drv_priv *priv, u32 hw_plane, u32 hw_videoport) +{ + VID_REG_FLD_MOD(priv, hw_plane, DSS_VID_ATTRIBUTES, + priv->pixel_format, 6, 1); + + dss_vid_write(priv, hw_plane, DSS_VID_PICTURE_SIZE, + ((LCD_MAX_WIDTH - 1) | ((LCD_MAX_HEIGHT - 1) << 16))); + + dss_vid_csc_enable(priv, hw_plane, false); + + dss_vid_write(priv, hw_plane, DSS_VID_GLOBAL_ALPHA, 0xFF); + + VID_REG_FLD_MOD(priv, hw_plane, DSS_VID_ATTRIBUTES, 1, 28, 28); + return 0; +} + +int dss_plane_enable(struct tidss_drv_priv *priv, u32 hw_plane, bool enable) +{ + VID_REG_FLD_MOD(priv, hw_plane, DSS_VID_ATTRIBUTES, !!enable, 0, 0); + + return 0; +} + +static u32 dss_vid_get_fifo_size(struct tidss_drv_priv *priv, u32 hw_plane) +{ + return VID_REG_GET(priv, hw_plane, DSS_VID_BUF_SIZE_STATUS, 15, 0); +} + +static void dss_vid_set_mflag_threshold(struct tidss_drv_priv *priv, + u32 hw_plane, u32 low, u32 high) +{ + dss_vid_write(priv, hw_plane, DSS_VID_MFLAG_THRESHOLD, + FLD_VAL(high, 31, 16) | FLD_VAL(low, 15, 0)); +} + +static +void dss_vid_set_buf_threshold(struct tidss_drv_priv *priv, + u32 hw_plane, u32 low, u32 high) +{ + dss_vid_write(priv, hw_plane, DSS_VID_BUF_THRESHOLD, + FLD_VAL(high, 31, 16) | FLD_VAL(low, 15, 0)); +} + +static void dss_plane_init(struct tidss_drv_priv *priv) +{ + unsigned int hw_plane; + u32 cba_lo_pri = 1; + u32 cba_hi_pri = 0; + + REG_FLD_MOD(priv, DSS_CBA_CFG, cba_lo_pri, 2, 0); + REG_FLD_MOD(priv, DSS_CBA_CFG, cba_hi_pri, 5, 3); + + /* MFLAG_CTRL = ENABLED */ + REG_FLD_MOD(priv, DSS_GLOBAL_MFLAG_ATTRIBUTE, 2, 1, 0); + /* MFLAG_START = MFLAGNORMALSTARTMODE */ + REG_FLD_MOD(priv, DSS_GLOBAL_MFLAG_ATTRIBUTE, 0, 6, 6); + + for (hw_plane = 0; hw_plane < priv->feat->num_planes; hw_plane++) { + u32 size = dss_vid_get_fifo_size(priv, hw_plane); + u32 thr_low, thr_high; + u32 mflag_low, mflag_high; + u32 preload; + + thr_high = size - 1; + thr_low = size / 2; + + mflag_high = size * 2 / 3; + mflag_low = size / 3; + + preload = thr_low; + + dev_dbg(priv->dev, + "%s: bufsize %u, buf_threshold %u/%u, mflag threshold %u/%u preload %u\n", + priv->feat->vid_name[hw_plane], + size, + thr_high, thr_low, + mflag_high, mflag_low, + preload); + + dss_vid_set_buf_threshold(priv, hw_plane, + thr_low, thr_high); + dss_vid_set_mflag_threshold(priv, hw_plane, + mflag_low, mflag_high); + + dss_vid_write(priv, hw_plane, DSS_VID_PRELOAD, preload); + + /* Prefech up to PRELOAD value */ + VID_REG_FLD_MOD(priv, hw_plane, DSS_VID_ATTRIBUTES, 0, + 19, 19); + } +} + +static void dss_vp_init(struct tidss_drv_priv *priv) +{ + unsigned int i; + + /* Enable the gamma Shadow bit-field for all VPs*/ + for (i = 0; i < priv->feat->num_vps; i++) + VP_REG_FLD_MOD(priv, i, DSS_VP_CONFIG, 1, 2, 2); +} + +static int dss_init_am65x_oldi_io_ctrl(struct udevice *dev, + struct tidss_drv_priv *priv) +{ + struct udevice *syscon; + struct regmap *regmap; + int ret = 0; + + ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, "ti,am65x-oldi-io-ctrl", + &syscon); + if (ret) { + debug("unable to find ti,am65x-oldi-io-ctrl syscon device (%d)\n", ret); + return ret; + } + + /* get grf-reg base address */ + regmap = syscon_get_regmap(syscon); + if (!regmap) { + debug("unable to find rockchip grf regmap\n"); + return -ENODEV; + } + priv->oldi_io_ctrl = regmap; + return 0; +} + +int tidss_drv_init(struct tidss_drv_priv *priv) +{ + dss_plane_init(priv); + dss_vp_init(priv); + return 0; +} + +static int tidss_drv_probe(struct udevice *dev) +{ + struct video_uc_plat *uc_plat = dev_get_uclass_plat(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct tidss_drv_priv *priv = dev_get_priv(dev); + struct udevice *panel = NULL; + struct display_timing timings; + unsigned int i; + int ret = 0; + const char *mode; + u32 *width; + + priv = devm_kzalloc(dev, sizeof(*priv), GFP_KERNEL); + if (!priv) + return -ENOMEM; + + priv->dev = dev; + + priv->feat = &dss_am625_feats; + + /* + * set your plane format based on your bmp image + * Supported 24bpp and 32bpp bmpimages + */ + + priv->pixel_format = DSS_FORMAT_XRGB8888; + + dss_common_regmap = priv->feat->common_regs; + + ret = uclass_first_device_err(UCLASS_PANEL, &panel); + if (ret) { + if (ret != -ENODEV) + dev_err(dev, "panel device error %d\n", ret); + return ret; + } + + ret = panel_get_display_timing(panel, &timings); + if (ret) { + ret = ofnode_decode_display_timing(dev_ofnode(panel), + 0, &timings); + if (ret) { + dev_err(dev, "decode display timing error %d\n", ret); + return ret; + } + } + + mode = ofnode_read_string(dev_ofnode(panel), "data-mapping"); + if (!mode) { + debug("%s: Could not read mode property\n", dev->name); + return -EINVAL; + } + + ret = ofnode_read_u32(dev_ofnode(panel), "data-width", width); + if (ret) { + debug("%s: Could not read mode property\n", dev->name); + return -EINVAL; + } + + if (*width == 24) { + uc_priv->bpix = VIDEO_BPP32; + if (!strcmp(mode, "vesa")) + priv->bus_format = &dss_bus_formats[7]; + else + priv->bus_format = &dss_bus_formats[8]; + } else { + uc_priv->bpix = VIDEO_BPP16; + priv->bus_format = &dss_bus_formats[6]; + } + + /* Common address */ + priv->base_common = dev_remap_addr_index(dev, 0); + if (!priv->base_common) + return -EINVAL; + + /* plane address setup and enable */ + for (i = 0; i < priv->feat->num_planes; i++) { + priv->base_vid[i] = dev_remap_addr_index(dev, i + 2); + if (!priv->base_vid[i]) + return -EINVAL; + } + + dss_vid_write(priv, 0, DSS_VID_BA_0, uc_plat->base & 0xffffffff); + dss_vid_write(priv, 0, DSS_VID_BA_EXT_0, (u64)uc_plat->base >> 32); + dss_vid_write(priv, 0, DSS_VID_BA_1, uc_plat->base & 0xffffffff); + dss_vid_write(priv, 0, DSS_VID_BA_EXT_1, (u64)uc_plat->base >> 32); + + ret = dss_plane_setup(priv, 0, 0); + if (ret) { + dss_plane_enable(priv, 0, false); + return ret; + } + + dss_plane_enable(priv, 0, true); + dss_plane_init(priv); + + /* video port address clocks and enable */ + for (i = 0; i < priv->feat->num_vps; i++) { + priv->base_ovr[i] = dev_remap_addr_index(dev, i + 4); + priv->base_vp[i] = dev_remap_addr_index(dev, i + 6); + } + + ret = clk_get_by_name(dev, "vp1", &priv->vp_clk[0]); + if (ret) { + dev_err(dev, "video port %d clock enable error %d\n", i, ret); + return ret; + } + + dss_ovr_set_plane(priv, 1, 0, 0, 0, 0); + dss_ovr_enable_layer(priv, 0, 0, true); + + /* Video Port cloks */ + dss_vp_enable_clk(priv, 0); + + dss_vp_set_clk_rate(priv, 0, timings.pixelclock.typ * 1000); + + priv->oldi_mode = OLDI_MODE_OFF; + uc_priv->xsize = timings.hactive.typ; + uc_priv->ysize = timings.vactive.typ; + if (priv->feat->subrev == DSS_AM65X || priv->feat->subrev == DSS_AM625) { + priv->oldi_mode = OLDI_DUAL_LINK; + if (priv->oldi_mode) { + ret = dss_init_am65x_oldi_io_ctrl(dev, priv); + if (ret) + return ret; + } + } + + dss_vp_prepare(priv, 0); + dss_vp_enable(priv, 0, &timings); + dss_vp_init(priv); + + ret = clk_get_by_name(dev, "fck", &priv->fclk); + if (ret) { + dev_err(dev, "peripheral clock get error %d\n", ret); + return ret; + } + + ret = clk_enable(&priv->fclk); + if (ret) { + dev_err(dev, "peripheral clock enable error %d\n", ret); + return ret; + } + + if (IS_ERR(&priv->fclk)) { + dev_err(dev, "%s: Failed to get fclk: %ld\n", + __func__, PTR_ERR(&priv->fclk)); + return PTR_ERR(&priv->fclk); + } + + dev_dbg(dev, "DSS fclk %lu Hz\n", clk_get_rate(&priv->fclk)); + + video_set_flush_dcache(dev, true); + return 0; +} + +static int tidss_drv_remove(struct udevice *dev) +{ + u32 val; + int ret; + struct tidss_drv_priv *priv = dev_get_priv(dev); + + priv->base_common = dev_remap_addr_index(dev, 0); + REG_FLD_MOD(priv, DSS_SYSCONFIG, 1, 1, 1); + /* Wait for reset to complete */ + ret = readl_poll_timeout(priv->base_common + DSS_SYSSTATUS, + val, val & 1, 5000); + if (ret) + dev_warn(priv->dev, "failed to reset priv\n"); + return ret; + return 0; +} + +static int tidss_drv_bind(struct udevice *dev) +{ + struct video_uc_plat *uc_plat = dev_get_uclass_plat(dev); + + uc_plat->size = ((LCD_MAX_WIDTH * LCD_MAX_HEIGHT * + (1 << LCD_MAX_LOG2_BPP)) >> 3) + 0x20; + return 0; +} + +static const struct udevice_id tidss_drv_ids[] = { + { .compatible = "ti,am625-dss" }, + { } +}; + +static int tidss_ofdata_to_platdata(struct udevice *dev) +{ + ofnode node; + + node = ofnode_by_compatible(ofnode_null(), "ti,am625-dss"); + + if (!ofnode_valid(node)) { + dev_err(dev, "missing 'ti,am625-dss' node\n"); + return -ENXIO; + } + + return 0; +} + +U_BOOT_DRIVER(tidss_drv) = { + .name = "tidss_drv", + .id = UCLASS_VIDEO, + .of_match = tidss_drv_ids, + .bind = tidss_drv_bind, + .of_to_plat = tidss_ofdata_to_platdata, + .probe = tidss_drv_probe, + .remove = tidss_drv_remove, + .priv_auto = sizeof(struct tidss_drv_priv), + .flags = DM_FLAG_OS_PREPARE, +}; diff --git a/drivers/video/tidss/tidss_drv.h b/drivers/video/tidss/tidss_drv.h new file mode 100644 index 0000000000..669c6d642e --- /dev/null +++ b/drivers/video/tidss/tidss_drv.h @@ -0,0 +1,152 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2023 Texas Instruments Incorporated - https://www.ti.com/ + * Nikhil M Jain, n-jain1@ti.com + * + * based on the linux tidss driver, which is + * + * (C) Copyright 2018 Texas Instruments Incorporated - https://www.ti.com/ + * Author: Tomi Valkeinen tomi.valkeinen@ti.com + */ + +#ifndef __TIDSS_DRV_H__ +#define __TIDSS_DRV_H__ + +#include <media_bus_format.h> + +#define TIDSS_MAX_PORTS 4 +#define TIDSS_MAX_PLANES 4 + +enum dss_vp_bus_type { + DSS_VP_DPI, /* DPI output */ + DSS_VP_OLDI, /* OLDI (LVDS) output */ + DSS_VP_INTERNAL, /* SoC internal routing */ + DSS_VP_MAX_BUS_TYPE, +}; + +enum dss_oldi_modes { + OLDI_MODE_OFF, /* OLDI turned off / tied off in IP. */ + OLDI_SINGLE_LINK_SINGLE_MODE, /* Single Output over OLDI 0. */ + OLDI_SINGLE_LINK_DUPLICATE_MODE, /* Duplicate Output over OLDI 0 and 1. */ + OLDI_DUAL_LINK, /* Combined Output over OLDI 0 and 1. */ +}; + +struct dss_features_scaling { + u32 in_width_max_5tap_rgb; + u32 in_width_max_3tap_rgb; + u32 in_width_max_5tap_yuv; + u32 in_width_max_3tap_yuv; + u32 upscale_limit; + u32 downscale_limit_5tap; + u32 downscale_limit_3tap; + u32 xinc_max; +}; + +enum tidss_gamma_type { TIDSS_GAMMA_8BIT, TIDSS_GAMMA_10BIT }; + +enum dss_subrevision { + DSS_K2G, + DSS_AM65X, + DSS_J721E, + DSS_AM625, +}; + +struct tidss_vp_feat { + struct tidss_vp_color_feat { + u32 gamma_size; + enum tidss_gamma_type gamma_type; + bool has_ctm; + } color; +}; + +struct tidss_scale_coefs { + s16 c2[16]; + s16 c1[16]; + u16 c0[9]; +}; + +struct dss_color_lut { + /* + * Data is U0.16 fixed point format. + */ + __u16 red; + __u16 green; + __u16 blue; + __u16 reserved; +}; + +struct dss_vp_data { + u32 *gamma_table; +}; + +struct dss_features { + int min_pclk_khz; + int max_pclk_khz[DSS_VP_MAX_BUS_TYPE]; + + struct dss_features_scaling scaling; + + enum dss_subrevision subrev; + + const char *common; + const u16 *common_regs; + u32 num_vps; + const char *vp_name[TIDSS_MAX_PORTS]; /* Should match dt reg names */ + const char *ovr_name[TIDSS_MAX_PORTS]; /* Should match dt reg names */ + const char *vpclk_name[TIDSS_MAX_PORTS]; /* Should match dt clk names */ + const enum dss_vp_bus_type vp_bus_type[TIDSS_MAX_PORTS]; + struct tidss_vp_feat vp_feat; + u32 num_planes; + const char *vid_name[TIDSS_MAX_PLANES]; /* Should match dt reg names */ + bool vid_lite[TIDSS_MAX_PLANES]; + u32 vid_order[TIDSS_MAX_PLANES]; +}; + +enum dss_oldi_mode_reg_val { SPWG_18 = 0, JEIDA_24 = 1, SPWG_24 = 2 }; + +struct dss_bus_format { + u32 bus_fmt; + u32 data_width; + bool is_oldi_fmt; + enum dss_oldi_mode_reg_val oldi_mode_reg_val; +}; + +static struct dss_bus_format dss_bus_formats[] = { + { MEDIA_BUS_FMT_RGB444_1X12, 12, false, 0 }, + { MEDIA_BUS_FMT_RGB565_1X16, 16, false, 0 }, + { MEDIA_BUS_FMT_RGB666_1X18, 18, false, 0 }, + { MEDIA_BUS_FMT_RGB888_1X24, 24, false, 0 }, + { MEDIA_BUS_FMT_RGB101010_1X30, 30, false, 0 }, + { MEDIA_BUS_FMT_RGB121212_1X36, 36, false, 0 }, + { MEDIA_BUS_FMT_RGB666_1X7X3_SPWG, 18, true, SPWG_18 }, + { MEDIA_BUS_FMT_RGB888_1X7X4_SPWG, 24, true, SPWG_24 }, + { MEDIA_BUS_FMT_RGB888_1X7X4_JEIDA, 24, true, JEIDA_24 }, +}; + +struct tidss_drv_priv { + struct udevice *dev; + void __iomem *base_common; + void __iomem *base_vid[TIDSS_MAX_PLANES]; + void __iomem *base_ovr[TIDSS_MAX_PORTS]; + void __iomem *base_vp[TIDSS_MAX_PORTS]; + struct regmap *oldi_io_ctrl; + + struct clk vp_clk[TIDSS_MAX_PORTS]; + + const struct dss_features *feat; + + struct clk fclk; + + bool is_enabled; + + struct dss_vp_data vp_data[TIDSS_MAX_PORTS]; + + enum dss_oldi_modes oldi_mode; + + struct dss_bus_format *bus_format; + + u32 pixel_format; + + u32 memory_bandwidth_limit; +}; + +#endif diff --git a/drivers/video/tidss/tidss_regs.h b/drivers/video/tidss/tidss_regs.h new file mode 100644 index 0000000000..440db8d1c7 --- /dev/null +++ b/drivers/video/tidss/tidss_regs.h @@ -0,0 +1,292 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2023 Texas Instruments Incorporated - https://www.ti.com/ + * Nikhil M Jain, n-jain1@ti.com + * + * based on the linux tidss driver, which is + * + * Copyright (C) 2016-2018 Texas Instruments Incorporated - https://www.ti.com/ + * Author: Jyri Sarha jsarha@ti.com + */ + +#ifndef __TIDSS_REGS_H +#define __TIDSS_REGS_H + +enum dss_common_regs { + NOT_APPLICABLE_OFF = 0, + DSS_REVISION_OFF, + DSS_SYSCONFIG_OFF, + DSS_SYSSTATUS_OFF, + DSS_IRQ_EOI_OFF, + DSS_IRQSTATUS_RAW_OFF, + DSS_IRQSTATUS_OFF, + DSS_IRQENABLE_SET_OFF, + DSS_IRQENABLE_CLR_OFF, + DSS_VID_IRQENABLE_OFF, + DSS_VID_IRQSTATUS_OFF, + DSS_VP_IRQENABLE_OFF, + DSS_VP_IRQSTATUS_OFF, + WB_IRQENABLE_OFF, + WB_IRQSTATUS_OFF, + DSS_GLOBAL_MFLAG_ATTRIBUTE_OFF, + DSS_GLOBAL_OUTPUT_ENABLE_OFF, + DSS_GLOBAL_BUFFER_OFF, + DSS_CBA_CFG_OFF, + DSS_DBG_CONTROL_OFF, + DSS_DBG_STATUS_OFF, + DSS_CLKGATING_DISABLE_OFF, + DSS_SECURE_DISABLE_OFF, + FBDC_REVISION_1_OFF, + FBDC_REVISION_2_OFF, + FBDC_REVISION_3_OFF, + FBDC_REVISION_4_OFF, + FBDC_REVISION_5_OFF, + FBDC_REVISION_6_OFF, + FBDC_COMMON_CONTROL_OFF, + FBDC_CONSTANT_COLOR_0_OFF, + FBDC_CONSTANT_COLOR_1_OFF, + DSS_CONNECTIONS_OFF, + DSS_MSS_VP1_OFF, + DSS_MSS_VP3_OFF, + DSS_COMMON_REG_TABLE_LEN, +}; + +/* + * dss_common_regmap should be defined as const u16 * and pointing + * to a valid dss common register map for the platform, before the + * macros bellow can be used. + */ + +#define REG(r) (dss_common_regmap[r ## _OFF]) + +#define DSS_REVISION REG(DSS_REVISION) +#define DSS_SYSCONFIG REG(DSS_SYSCONFIG) +#define DSS_SYSSTATUS REG(DSS_SYSSTATUS) +#define DSS_IRQ_EOI REG(DSS_IRQ_EOI) +#define DSS_IRQSTATUS_RAW REG(DSS_IRQSTATUS_RAW) +#define DSS_IRQSTATUS REG(DSS_IRQSTATUS) +#define DSS_IRQENABLE_SET REG(DSS_IRQENABLE_SET) +#define DSS_IRQENABLE_CLR REG(DSS_IRQENABLE_CLR) +#define DSS_VID_IRQENABLE(n) (REG(DSS_VID_IRQENABLE) + (n) * 4) +#define DSS_VID_IRQSTATUS(n) (REG(DSS_VID_IRQSTATUS) + (n) * 4) +#define DSS_VP_IRQENABLE(n) (REG(DSS_VP_IRQENABLE) + (n) * 4) +#define DSS_VP_IRQSTATUS(n) (REG(DSS_VP_IRQSTATUS) + (n) * 4) +#define WB_IRQENABLE REG(WB_IRQENABLE) +#define WB_IRQSTATUS REG(WB_IRQSTATUS) + +#define DSS_GLOBAL_MFLAG_ATTRIBUTE REG(DSS_GLOBAL_MFLAG_ATTRIBUTE) +#define DSS_GLOBAL_OUTPUT_ENABLE REG(DSS_GLOBAL_OUTPUT_ENABLE) +#define DSS_GLOBAL_BUFFER REG(DSS_GLOBAL_BUFFER) +#define DSS_CBA_CFG REG(DSS_CBA_CFG) +#define DSS_DBG_CONTROL REG(DSS_DBG_CONTROL) +#define DSS_DBG_STATUS REG(DSS_DBG_STATUS) +#define DSS_CLKGATING_DISABLE REG(DSS_CLKGATING_DISABLE) +#define DSS_SECURE_DISABLE REG(DSS_SECURE_DISABLE) + +#define FBDC_REVISION_1 REG(FBDC_REVISION_1) +#define FBDC_REVISION_2 REG(FBDC_REVISION_2) +#define FBDC_REVISION_3 REG(FBDC_REVISION_3) +#define FBDC_REVISION_4 REG(FBDC_REVISION_4) +#define FBDC_REVISION_5 REG(FBDC_REVISION_5) +#define FBDC_REVISION_6 REG(FBDC_REVISION_6) +#define FBDC_COMMON_CONTROL REG(FBDC_COMMON_CONTROL) +#define FBDC_CONSTANT_COLOR_0 REG(FBDC_CONSTANT_COLOR_0) +#define FBDC_CONSTANT_COLOR_1 REG(FBDC_CONSTANT_COLOR_1) +#define DSS_CONNECTIONS REG(DSS_CONNECTIONS) +#define DSS_MSS_VP1 REG(DSS_MSS_VP1) +#define DSS_MSS_VP3 REG(DSS_MSS_VP3) + +/* VID */ + +#define DSS_VID_ACCUH_0 0x0 +#define DSS_VID_ACCUH_1 0x4 +#define DSS_VID_ACCUH2_0 0x8 +#define DSS_VID_ACCUH2_1 0xc +#define DSS_VID_ACCUV_0 0x10 +#define DSS_VID_ACCUV_1 0x14 +#define DSS_VID_ACCUV2_0 0x18 +#define DSS_VID_ACCUV2_1 0x1c +#define DSS_VID_ATTRIBUTES 0x20 +#define DSS_VID_ATTRIBUTES2 0x24 +#define DSS_VID_BA_0 0x28 +#define DSS_VID_BA_1 0x2c +#define DSS_VID_BA_UV_0 0x30 +#define DSS_VID_BA_UV_1 0x34 +#define DSS_VID_BUF_SIZE_STATUS 0x38 +#define DSS_VID_BUF_THRESHOLD 0x3c +#define DSS_VID_CSC_COEF(n) (0x40 + (n) * 4) + +#define DSS_VID_FIRH 0x5c +#define DSS_VID_FIRH2 0x60 +#define DSS_VID_FIRV 0x64 +#define DSS_VID_FIRV2 0x68 + +#define DSS_VID_FIR_COEFS_H0 0x6c +#define DSS_VID_FIR_COEF_H0(phase) (0x6c + (phase) * 4) +#define DSS_VID_FIR_COEFS_H0_C 0x90 +#define DSS_VID_FIR_COEF_H0_C(phase) (0x90 + (phase) * 4) + +#define DSS_VID_FIR_COEFS_H12 0xb4 +#define DSS_VID_FIR_COEF_H12(phase) (0xb4 + (phase) * 4) +#define DSS_VID_FIR_COEFS_H12_C 0xf4 +#define DSS_VID_FIR_COEF_H12_C(phase) (0xf4 + (phase) * 4) + +#define DSS_VID_FIR_COEFS_V0 0x134 +#define DSS_VID_FIR_COEF_V0(phase) (0x134 + (phase) * 4) +#define DSS_VID_FIR_COEFS_V0_C 0x158 +#define DSS_VID_FIR_COEF_V0_C(phase) (0x158 + (phase) * 4) + +#define DSS_VID_FIR_COEFS_V12 0x17c +#define DSS_VID_FIR_COEF_V12(phase) (0x17c + (phase) * 4) +#define DSS_VID_FIR_COEFS_V12_C 0x1bc +#define DSS_VID_FIR_COEF_V12_C(phase) (0x1bc + (phase) * 4) + +#define DSS_VID_GLOBAL_ALPHA 0x1fc +#define DSS_VID_K2G_IRQENABLE 0x200 /* K2G */ +#define DSS_VID_K2G_IRQSTATUS 0x204 /* K2G */ +#define DSS_VID_MFLAG_THRESHOLD 0x208 +#define DSS_VID_PICTURE_SIZE 0x20c +#define DSS_VID_PIXEL_INC 0x210 +#define DSS_VID_K2G_POSITION 0x214 /* K2G */ +#define DSS_VID_PRELOAD 0x218 +#define DSS_VID_ROW_INC 0x21c +#define DSS_VID_SIZE 0x220 +#define DSS_VID_BA_EXT_0 0x22c +#define DSS_VID_BA_EXT_1 0x230 +#define DSS_VID_BA_UV_EXT_0 0x234 +#define DSS_VID_BA_UV_EXT_1 0x238 +#define DSS_VID_CSC_COEF7 0x23c +#define DSS_VID_ROW_INC_UV 0x248 +#define DSS_VID_CLUT 0x260 +#define DSS_VID_SAFETY_ATTRIBUTES 0x2a0 +#define DSS_VID_SAFETY_CAPT_SIGNATURE 0x2a4 +#define DSS_VID_SAFETY_POSITION 0x2a8 +#define DSS_VID_SAFETY_REF_SIGNATURE 0x2ac +#define DSS_VID_SAFETY_SIZE 0x2b0 +#define DSS_VID_SAFETY_LFSR_SEED 0x2b4 +#define DSS_VID_LUMAKEY 0x2b8 +#define DSS_VID_DMA_BUFSIZE 0x2bc /* J721E */ + +/* OVR */ + +#define DSS_OVR_CONFIG 0x0 +#define DSS_OVR_VIRTVP 0x4 /* J721E */ +#define DSS_OVR_DEFAULT_COLOR 0x8 +#define DSS_OVR_DEFAULT_COLOR2 0xc +#define DSS_OVR_TRANS_COLOR_MAX 0x10 +#define DSS_OVR_TRANS_COLOR_MAX2 0x14 +#define DSS_OVR_TRANS_COLOR_MIN 0x18 +#define DSS_OVR_TRANS_COLOR_MIN2 0x1c +#define DSS_OVR_ATTRIBUTES(n) (0x20 + (n) * 4) +#define DSS_OVR_ATTRIBUTES2(n) (0x34 + (n) * 4) /* J721E */ +/* VP */ + +#define DSS_VP_CONFIG 0x0 +#define DSS_VP_CONTROL 0x4 +#define DSS_VP_CSC_COEF0 0x8 +#define DSS_VP_CSC_COEF1 0xc +#define DSS_VP_CSC_COEF2 0x10 +#define DSS_VP_DATA_CYCLE_0 0x14 +#define DSS_VP_DATA_CYCLE_1 0x18 +#define DSS_VP_K2G_GAMMA_TABLE 0x20 /* K2G */ +#define DSS_VP_K2G_IRQENABLE 0x3c /* K2G */ +#define DSS_VP_K2G_IRQSTATUS 0x40 /* K2G */ +#define DSS_VP_DATA_CYCLE_2 0x1c +#define DSS_VP_LINE_NUMBER 0x44 +#define DSS_VP_POL_FREQ 0x4c +#define DSS_VP_SIZE_SCREEN 0x50 +#define DSS_VP_TIMING_H 0x54 +#define DSS_VP_TIMING_V 0x58 +#define DSS_VP_CSC_COEF3 0x5c +#define DSS_VP_CSC_COEF4 0x60 +#define DSS_VP_CSC_COEF5 0x64 +#define DSS_VP_CSC_COEF6 0x68 +#define DSS_VP_CSC_COEF7 0x6c +#define DSS_VP_SAFETY_ATTRIBUTES_0 0x70 +#define DSS_VP_SAFETY_ATTRIBUTES_1 0x74 +#define DSS_VP_SAFETY_ATTRIBUTES_2 0x78 +#define DSS_VP_SAFETY_ATTRIBUTES_3 0x7c +#define DSS_VP_SAFETY_CAPT_SIGNATURE_0 0x90 +#define DSS_VP_SAFETY_CAPT_SIGNATURE_1 0x94 +#define DSS_VP_SAFETY_CAPT_SIGNATURE_2 0x98 +#define DSS_VP_SAFETY_CAPT_SIGNATURE_3 0x9c +#define DSS_VP_SAFETY_POSITION_0 0xb0 +#define DSS_VP_SAFETY_POSITION_1 0xb4 +#define DSS_VP_SAFETY_POSITION_2 0xb8 +#define DSS_VP_SAFETY_POSITION_3 0xbc +#define DSS_VP_SAFETY_REF_SIGNATURE_0 0xd0 +#define DSS_VP_SAFETY_REF_SIGNATURE_1 0xd4 +#define DSS_VP_SAFETY_REF_SIGNATURE_2 0xd8 +#define DSS_VP_SAFETY_REF_SIGNATURE_3 0xdc +#define DSS_VP_SAFETY_SIZE_0 0xf0 +#define DSS_VP_SAFETY_SIZE_1 0xf4 +#define DSS_VP_SAFETY_SIZE_2 0xf8 +#define DSS_VP_SAFETY_SIZE_3 0xfc +#define DSS_VP_SAFETY_LFSR_SEED 0x110 +#define DSS_VP_GAMMA_TABLE 0x120 +#define DSS_VP_DSS_OLDI_CFG 0x160 +#define DSS_VP_DSS_OLDI_STATUS 0x164 +#define DSS_VP_DSS_OLDI_LB 0x168 +#define DSS_VP_DSS_MERGE_SPLIT 0x16c /* J721E */ +#define DSS_VP_DSS_DMA_THREADSIZE 0x170 /* J721E */ +#define DSS_VP_DSS_DMA_THREADSIZE_STATUS 0x174 /* J721E */ + +/* + * OLDI IO_CTRL register offsets. On AM654 the registers are found + * from CTRL_MMR0, there the syscon regmap should map 0x14 bytes from + * CTRLMMR0P1_OLDI_DAT0_IO_CTRL to CTRLMMR0P1_OLDI_CLK_IO_CTRL + * register range. + */ +#define OLDI_DAT0_IO_CTRL 0x00 +#define OLDI_DAT1_IO_CTRL 0x04 +#define OLDI_DAT2_IO_CTRL 0x08 +#define OLDI_DAT3_IO_CTRL 0x0C +#define OLDI_CLK_IO_CTRL 0x10 + +/* Only for AM625 OLDI TX */ +#define OLDI_PD_CTRL 0x100 +#define OLDI_LB_CTRL 0x104 + +#define OLDI_BANDGAP_PWR BIT(8) +#define OLDI_PWRDN_TX BIT(8) +#define OLDI0_PWRDN_TX BIT(0) +#define OLDI1_PWRDN_TX BIT(1) + +/* Supported plane formats */ +#define DSS_FORMAT_ARGB4444 0x0 +#define DSS_FORMAT_ABGR4444 0x1 +#define DSS_FORMAT_RGBA4444 0x2 + +#define DSS_FORMAT_RGB565 0x3 +#define DSS_FORMAT_BGR565 0x4 + +#define DSS_FORMAT_ARGB1555 0x5 +#define DSS_FORMAT_ABGR1555 0x6 + +#define DSS_FORMAT_ARGB8888 0x7 +#define DSS_FORMAT_ABGR8888 0x8 +#define DSS_FORMAT_RGBA8888 0x9 +#define DSS_FORMAT_BGRA8888 0xa + +#define DSS_FORMAT_RGB888 0xb +#define DSS_FORMAT_BGR888 0xc + +#define DSS_FORMAT_ARGB2101010 0xe +#define DSS_FORMAT_ABGR2101010 0xf + +#define DSS_FORMAT_XRGB4444 0x20 +#define DSS_FORMAT_XBGR4444 0x21 +#define DSS_FORMAT_RGBX4444 0x22 + +#define DSS_FORMAT_XRGB1555 0x25 +#define DSS_FORMAT_XBGR1555 0x26 + +#define DSS_FORMAT_XRGB8888 0x27 +#define DSS_FORMAT_XBGR8888 0x28 +#define DSS_FORMAT_RGBX8888 0x29 +#define DSS_FORMAT_BGRX8888 0x2a + +#define DSS_FORMAT_XRGB2101010 0x2e, +#define DSS_FORMAT_XBGR2101010 0x2f, + +#endif /* __TIDSS_DSS_REGS_H */
I don't have any big comments, just a few small things. [snip]
Not needed.
- bool "Enable TIDSS video support"
- depends on VIDEO
- help
And there should be newlines at the end of files.
This patch updates the necessary Kconfigs to make simple panel driver independent of backlight driver and compiling backlight related code in simple-panel driver conditionally to when user has set CONFIG_BACKLIGHT.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- drivers/video/Kconfig | 3 +-- drivers/video/simple_panel.c | 20 +++++++++++++------- 2 files changed, 14 insertions(+), 9 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index c841b99bb3..5030586d9f 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -28,7 +28,6 @@ config VIDEO_LOGO
config BACKLIGHT bool "Enable panel backlight uclass support" - default y help This provides backlight uclass driver that enables basic panel backlight support. @@ -206,7 +205,7 @@ config PANEL
config SIMPLE_PANEL bool "Enable simple panel support" - depends on PANEL && BACKLIGHT && DM_GPIO + depends on PANEL && DM_GPIO default y help This turns on a simple panel driver that enables a compatible diff --git a/drivers/video/simple_panel.c b/drivers/video/simple_panel.c index c8f7022ea6..905087bcbd 100644 --- a/drivers/video/simple_panel.c +++ b/drivers/video/simple_panel.c @@ -18,6 +18,7 @@ struct simple_panel_priv { struct gpio_desc enable; };
+#ifdef CONFIG_BACKLIGHT static int simple_panel_enable_backlight(struct udevice *dev) { struct simple_panel_priv *priv = dev_get_priv(dev); @@ -47,6 +48,7 @@ static int simple_panel_set_backlight(struct udevice *dev, int percent)
return 0; } +#endif
static int simple_panel_of_to_plat(struct udevice *dev) { @@ -63,11 +65,13 @@ static int simple_panel_of_to_plat(struct udevice *dev) return ret; } } - ret = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, - "backlight", &priv->backlight); - if (ret) { - debug("%s: Cannot get backlight: ret=%d\n", __func__, ret); - return log_ret(ret); + if (IS_ENABLED(CONFIG_BACKLIGHT)) { + ret = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, + "backlight", &priv->backlight); + if (ret) { + debug("%s: Cannot get backlight: ret=%d\n", __func__, ret); + return log_ret(ret); + } } ret = gpio_request_by_name(dev, "enable-gpios", 0, &priv->enable, GPIOD_IS_OUT); @@ -97,8 +101,10 @@ static int simple_panel_probe(struct udevice *dev) }
static const struct panel_ops simple_panel_ops = { - .enable_backlight = simple_panel_enable_backlight, - .set_backlight = simple_panel_set_backlight, +#ifdef CONFIG_BACKLIGHT + .enable_backlight = simple_panel_enable_backlight, + .set_backlight = simple_panel_set_backlight, +#endif };
static const struct udevice_id simple_panel_ids[] = {
Have you made sure this didn't disable / remove code on other platforms?
[snip]
+#endif };
This shouldn't get indented more.
Add device tree node which includes the register regions to write properties of planes (vidl1 and vid1), overlays (ovr1 and ovr2),and video ports(vp1 and vp2). TIDSS uses 3 clocks, fck- for its internal logic and clk vp1 and vp2 for oldi and HDMI ports.
To control the oldi panel its register region is added in dss_oldi_io_ctrl.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- arch/arm/dts/k3-am62-main.dtsi | 41 ++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi index 4b6ba98dd0..a70061050e 100644 --- a/arch/arm/dts/k3-am62-main.dtsi +++ b/arch/arm/dts/k3-am62-main.dtsi @@ -54,6 +54,11 @@ reg = <0x4044 0x8>; #phy-cells = <1>; }; + + dss_oldi_io_ctrl: dss-oldi-io-ctrl@8600 { + compatible = "syscon"; + reg = <0x8600 0x200>; + }; };
dmss: bus@48000000 { @@ -515,6 +520,42 @@ }; };
+ dss: dss@30200000 { + compatible = "ti,am625-dss"; + status = "okay"; + + reg = <0x00 0x30200000 0x00 0x1000>, /* common */ + <0x00 0x30201000 0x00 0x1000>, /* common1 */ + <0x00 0x30202000 0x00 0x1000>, /* vidl1 */ + <0x00 0x30206000 0x00 0x1000>, /* vid */ + <0x00 0x30207000 0x00 0x1000>, /* ovr1 */ + <0x00 0x30208000 0x00 0x1000>, /* ovr2 */ + <0x00 0x3020a000 0x00 0x1000>, /* vp1: Used for OLDI */ + <0x00 0x3020b000 0x00 0x1000>; /* vp2: Used as DPI Out */ + + reg-names = "common", "common1", + "vidl1", "vid", + "ovr1", "ovr2", + "vp1", "vp2"; + + ti,am65x-oldi-io-ctrl = <&dss_oldi_io_ctrl>; + power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>; + + clocks = <&k3_clks 186 6>, + <&k3_clks 186 0>, + <&k3_clks 186 2>; + + clock-names = "fck", "vp1", "vp2"; + + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + + dss_ports: ports { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + hwspinlock: spinlock@2a000000 { compatible = "ti,am64-hwspinlock"; reg = <0x00 0x2a000000 0x00 0x1000>;
Can we not get this with a re-sync of the dts upstream? We should do that instead.
Hi, Tom
On linux side pathces have been sent upstream, waiting for patches to be accepted.
link: https://lore.kernel.org/linux-arm-kernel/20220505134303.23208-2-a-bhatia1@ti...
Is it possible to accept these patches now and resync the dts when the patches on the linux side gets accepted.
Thank you
On Tue, Jan 17, 2023 at 10:09:00AM +0530, Nikhl M Jain wrote:
Hi, Tom
Based on the link you give here, they haven't been accepted, they've had changes requested: https://lore.kernel.org/linux-arm-kernel/20220505134303.23208-2-a-bhatia1@ti...
Hi Nikhil,
Hi, Tom
Please wait for the kernel bindings to settle down. Else we will end up with different sets of bindings for kernel and u-boot. I don't see why DSS should be exempted from the rule that kernel bindings and DT being accepted.
Device tree node for panel(Microtips-Model No: 13-101HIEBCAF0-S) is created, which includes timing parameters of the panel, data-mapping and ports which are read by the code to set bus formats, clock required by the panel. Generic simple_panel driver is being used.
Link dss and panel by setting the port name in remote-endpoint.
main_dss0_pins_default - setting for pinmux.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- arch/arm/dts/k3-am625-sk.dts | 82 ++++++++++++++++++++++++++++++++++++ 1 file changed, 82 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts index 76b06ea239..1580fd073a 100644 --- a/arch/arm/dts/k3-am625-sk.dts +++ b/arch/arm/dts/k3-am625-sk.dts @@ -56,6 +56,39 @@ no-map; }; }; + + panel { + compatible = "simple-panel"; + status= "okay"; + width-mm = <217>; + height-mm = <136>; + data-mapping = "vesa"; + data-width = <24>; + display-timings { + timings@0 { + clock-frequency = <150274>; + hactive = <1920>; + vactive = <1200>; + hback-porch = <32>; + hfront-porch = <52>; + vback-porch = <24>; + vfront-porch = <8>; + hsync-len = <24>; + vsync-len = <3>; + de-active = <1>; + }; + }; + ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + lvds_in0: endpoint { + remote-endpoint = <&oldi_out0>; + }; + }; + }; + }; };
&main_pmx0 { @@ -77,6 +110,39 @@ AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */ >; }; + + main_dss0_pins_default: main-dss0-pins-default { + pinctrl-single,pins = < + AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */ + AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */ + AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */ + AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */ + AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ + AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */ + AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */ + AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */ + AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */ + AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */ + AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */ + AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */ + AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */ + AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */ + AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */ + AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */ + AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */ + AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */ + AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */ + AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */ + AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */ + AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */ + AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */ + AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */ + AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ + AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */ + AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */ + AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */ + >; + }; };
&wkup_uart0 { @@ -148,3 +214,19 @@ ti,driver-strength-ohm = <50>; disable-wp; }; + +&dss { + pinctrl-names = "default"; + pinctrl-0 = <&main_dss0_pins_default>; +}; + +&dss_ports { + #address-cells = <1>; + #size-cells = <0>; + port@0 { + reg = <0>; + oldi_out0: endpoint { + remote-endpoint = <&lvds_in0>; + }; + }; +};
Same comment as the previous patch about preferring a re-sync.
TIDSS and panel are marked with the dm-pre-reloc flag, it sets up display related drivers before relocation as video_uclass base driver which expects framebuffer memory to be set early before relocation.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- arch/arm/dts/k3-am625-sk-u-boot.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/k3-am625-sk-u-boot.dtsi b/arch/arm/dts/k3-am625-sk-u-boot.dtsi index 159fa36bbe..5a13beae15 100644 --- a/arch/arm/dts/k3-am625-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-sk-u-boot.dtsi @@ -17,6 +17,10 @@ memory@80000000 { u-boot,dm-spl; }; + + panel { + u-boot,dm-pre-reloc; + }; };
&cbass_main{ @@ -102,3 +106,7 @@ &main_mmc1_pins_default { u-boot,dm-spl; }; + +&dss{ + u-boot,dm-pre-reloc; +};
To compile TIDSS when user sets CONFIG_VIDEO_TIDSS add rule in Makefile. Include tidss folder location in Kconfig.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- drivers/video/Kconfig | 2 ++ drivers/video/Makefile | 1 + 2 files changed, 3 insertions(+)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 5030586d9f..6f94f90697 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -630,6 +630,8 @@ config VIDEO_SANDBOX_SDL
source "drivers/video/stm32/Kconfig"
+source "drivers/video/tidss/Kconfig" + config VIDEO_TEGRA20 bool "Enable LCD support on Tegra20" depends on OF_CONTROL diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 40a871d638..4c14cc2663 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -26,6 +26,7 @@ obj-${CONFIG_EXYNOS_FB} += exynos/ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/ obj-${CONFIG_VIDEO_STM32} += stm32/ obj-${CONFIG_VIDEO_TEGRA124} += tegra124/ +obj-${CONFIG_VIDEO_TIDSS} += tidss/
obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o
This should be part of the first patch.
Set splash screen related env variables. Default splash source is set to mmc where user is expected to keep bmp in compressed format with name ti.gz on first partition of mmc.
Splash file will be uncompressed to DDR at address 0x82000000 and splash position is set to middle of screen.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- include/configs/am62x_evm.h | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/include/configs/am62x_evm.h b/include/configs/am62x_evm.h index 78201adc07..acbcfe0526 100644 --- a/include/configs/am62x_evm.h +++ b/include/configs/am62x_evm.h @@ -29,7 +29,11 @@ "console=ttyS2,115200n8\0" \ "args_all=setenv optargs ${optargs} earlycon=ns16550a,mmio32,0x02800000 " \ "${mtdparts}\0" \ - "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" + "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" \ + "splashsource=mmc\0" \ + "splashfile=ti.gz\0" \ + "splashimage=0x82000000\0" \ + "splashpos=m,m\0" \
/* U-Boot MMC-specific configuration */ #define EXTRA_ENV_AM625_BOARD_SETTINGS_MMC \
- "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" \
- "splashsource=mmc\0" \
- "splashfile=ti.gz\0" \
- "splashimage=0x82000000\0" \
- "splashpos=m,m\0" \
Can we please convert this board to plain text environment and then add more?
Are you suggesting to move all the env settings done in this file into a separate bootscript text file (as done in board/boundary/nitrogen6x/6x_bootscript.txt ) which user needs to import using env import commnand or have it as a bootscript?
My preference was to append new env settings to am62x_evm.h itself, to avoid extra step to import environment or run a boot script and have faster boot.
No, I'm saying you should move this in to a plain text environment similar to board/qualcomm/dragonboard410c/dragonboard410c.env or for more complex examples, board/keymile/*/*.env.
Splash screen function needs splash source information to load image and display it, splash_location provides the necessary info, Set default_splash_location to MMC 1st partition. Probe TIDSS for splash screen display.
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- board/ti/am62x/evm.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index d65ee1d696..87d7ebc578 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -10,6 +10,8 @@ #include <asm/io.h> #include <spl.h> #include <dm/uclass.h> +#include <video.h> +#include <splash.h> #include <k3-ddrss.h> #include <fdt_support.h> #include <asm/arch/hardware.h> @@ -18,8 +20,33 @@
+#ifdef CONFIG_SPLASH_SCREEN + static struct splash_location default_splash_locations[] = { + { + .name = "mmc", + .storage = SPLASH_STORAGE_MMC, + .flags = SPLASH_STORAGE_FS, + .devpart = "1:1", + }, + }; + +int splash_screen_prepare(void) +{ + return splash_source_load(default_splash_locations, + ARRAY_SIZE(default_splash_locations)); +} +#endif + int board_init(void) { + if (IS_ENABLED(CONFIG_VIDEO_TIDSS)) { + int ret; + struct udevice *dev; + + ret = uclass_get_device_by_name(UCLASS_VIDEO, "dss@30200000", &dev); + if (ret) + panic("Cannot get DSS device: %d\n", ret); + } return 0; }
This enables splash screen support on AM62x using tidss video driver.
Allows to display bmp and gzipped bmp images on a black background hiding the u-boot version.
By default ti logo gets displayed, if user wants to splash different image, user must use a compressed 24bpp or 32bpp bmp image and rename it as ti.gz and save it in 1st partition of the mmc device, the next time user reboots, user will see the new image.
User can also stop at u-boot and display image saved in 1st partition of mmc device. Steps 1. fatload mmc boot_partition $loadaddr /image_name.bmp 2. bmp display $loadaddr x y
Signed-off-by: Nikhil M Jain n-jain1@ti.com --- configs/am62x_evm_a53_defconfig | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index ff258bcbc1..bbffc80080 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -74,3 +74,20 @@ CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_DM_GPIO=y +CONFIG_VIDEO=y +CONFIG_VIDEO_TIDSS=y +CONFIG_SPLASH_SCREEN=y +CONFIG_VIDEO_BMP_GZIP=y +CONFIG_CMD_UNZIP=y +CONFIG_CMD_BMP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_VIDEO_COPY=y +CONFIG_VIDEO_LOGO_MAX_SIZE=0x100000 +CONFIG_SPLASH_SOURCE=y +CONFIG_HIDE_LOGO_VERSION=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_SYS_WHITE_ON_BLACK=y
- fatload mmc boot_partition $loadaddr /image_name.bmp
- bmp display $loadaddr x y
I don't think this was done with "make savedefconfig".
Nikhil M Jain
Nikhl M Jain
Vignesh Raghavendra
