[PATCH 1/7] net: Kconfig: add CONFIG_WGET symbol
Let net/wget.c and net/lwip/wget.c depend on CONFIG_WGET, and cmd/wget.c depend on CONFIG_CMD_WGET. This way, the wget code can be used regardless of whether the wget command is available.
Signed-off-by: Adriano Cordova adrianox@gmail.com --- cmd/Kconfig | 5 +---- net/Kconfig | 9 +++++++++ net/Makefile | 2 +- net/lwip/Makefile | 2 +- 4 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 636833646f..8f3ad94089 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2115,11 +2115,8 @@ config CMD_TFTPBOOT
config CMD_WGET bool "wget" - depends on CMD_NET default y if SANDBOX - select PROT_TCP if NET - select PROT_TCP_LWIP if NET_LWIP - select PROT_DNS_LWIP if NET_LWIP + select WGET help wget is a simple command to download kernel, or other files, from a http server over TCP. diff --git a/net/Kconfig b/net/Kconfig index 76ab7d91ee..b4bb68dd61 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -244,6 +244,15 @@ config NET_RANDOM_ETHADDR generated. It will be saved to the appropriate environment variable, too.
+config WGET + bool "Enable wget" + select PROT_TCP if NET + select PROT_TCP_LWIP if NET_LWIP + select PROT_DNS_LWIP if NET_LWIP + help + Selecting this will enable wget, an interface to send HTTP requests + via the network stack. + config TFTP_BLOCKSIZE int "TFTP block size" default 1468 diff --git a/net/Makefile b/net/Makefile index 209377aeb2..7c917b318c 100644 --- a/net/Makefile +++ b/net/Makefile @@ -29,7 +29,7 @@ obj-$(CONFIG_$(PHASE_)TCP_FUNCTION_FASTBOOT) += fastboot_tcp.o obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_PROT_UDP) += udp.o obj-$(CONFIG_PROT_TCP) += tcp.o -obj-$(CONFIG_CMD_WGET) += wget.o +obj-$(CONFIG_WGET) += wget.o
# Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) diff --git a/net/lwip/Makefile b/net/lwip/Makefile index f2558f8763..79dd6b3fb5 100644 --- a/net/lwip/Makefile +++ b/net/lwip/Makefile @@ -5,4 +5,4 @@ obj-$(CONFIG_CMD_DHCP) += dhcp.o obj-$(CONFIG_CMD_DNS) += dns.o obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_TFTPBOOT) += tftp.o -obj-$(CONFIG_CMD_WGET) += wget.o +obj-$(CONFIG_WGET) += wget.o
- select WGET help wget is a simple command to download kernel, or other files, from a http server over TCP.
+config WGET
- bool "Enable wget"
- help
Reviewed-by: Jerome Forissier jerome.forissier@linaro.org
Thanks,
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
+config WGET
- help
- config TFTP_BLOCKSIZE int "TFTP block size" default 1468
Adriano Cordova
Jerome Forissier
