[U-Boot] [PATCH 1/2] arm: dts: rock960: Enable booting from eMMC when using SPL
This commits enables booting from eMMC when using SPL on 96Boards Rock960 board by adding SDHCI to boot order. Since the SDHCI driver already has the reloc flag, this works straightaway.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/rk3399-rock960-u-boot.dtsi | 1 + arch/arm/dts/rk3399-rock960.dts | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/arch/arm/dts/rk3399-rock960-u-boot.dtsi b/arch/arm/dts/rk3399-rock960-u-boot.dtsi index 5256f6d3f2..7fb5072a9b 100644 --- a/arch/arm/dts/rk3399-rock960-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rock960-u-boot.dtsi @@ -3,4 +3,5 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "rk3399-u-boot.dtsi" #include "rk3399-sdram-lpddr3-2GB-1600.dtsi" diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts index 7e06bc97e5..c8b9075c73 100644 --- a/arch/arm/dts/rk3399-rock960.dts +++ b/arch/arm/dts/rk3399-rock960.dts @@ -12,6 +12,8 @@
chosen { stdout-path = "serial2:1500000n8"; + u-boot,spl-boot-order = \ + &sdhci, &sdmmc; }; };
This commits enables booting from eMMC when using SPL on 96Boards Ficus board by adding SDHCI to boot order. Since the SDHCI driver already has the reloc flag, this works straightaway.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/rk3399-ficus-u-boot.dtsi | 1 + arch/arm/dts/rk3399-ficus.dts | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/arch/arm/dts/rk3399-ficus-u-boot.dtsi b/arch/arm/dts/rk3399-ficus-u-boot.dtsi index eab86bdb30..67b63a8352 100644 --- a/arch/arm/dts/rk3399-ficus-u-boot.dtsi +++ b/arch/arm/dts/rk3399-ficus-u-boot.dtsi @@ -3,4 +3,5 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+#include "rk3399-u-boot.dtsi" #include "rk3399-sdram-ddr3-1600.dtsi" diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts index 4b2dd82b67..0f219f4a9c 100644 --- a/arch/arm/dts/rk3399-ficus.dts +++ b/arch/arm/dts/rk3399-ficus.dts @@ -15,6 +15,8 @@
clkin_gmac: external-gmac-clock {
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com
&sdhci, &sdmmc;
Ping!
Thanks,
- Kever
&sdhci, &sdmmc;
On Mon, May 20, 2019 at 4:47 PM Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
&sdhci, &sdmmc;
Shouldn't this be in the rk3399-ficus-u-boot.dtsi above? It would get lost with a resync of dts files from linux.
}; clkin_gmac: external-gmac-clock {
-- 2.17.1
Thanks, - Kever
};&sdhci, &sdmmc;
Ping!
Thanks,
- Kever
};&sdhci, &sdmmc;
&sdhci, &sdmmc;
Shouldn't this bit be in the rk3399-rock960-u-boot.dtsi not rk3399-rock960.dts because it's U-Boot specific?
-- 2.17.1
Hi Manivannan,
&sdhci, &sdmmc;
Peter is correct, all the update to dts by U-Boot should go to -u-boot.dtsi now,
could you update and send the patch again?
Thanks, - Kever
-- 2.17.1
Hi Peter,
&sdhci, &sdmmc;
Good catch! Will fix this and send next revision.
Thanks, Mani
-- 2.17.1
Kever Yang
Peter Robinson
