[U-Boot-Users] Re: 8540 ADS board.
In message 3FB4BEB3.8050804@tnglwood.demon.co.uk you wrote:
I'm trying to compile u-boot for the 8540 ADS board. According to the comments this should be possible. But I'm getting error messages from the compiler objecting to the -me500 option. Am I doing somethig wrong, or do I need an updated compiler?
See doc/README.mpc85xxads
I'm not sure if the doc mentions it but you do need a newer binutils which has support for the e500 instruction set. The latest 2.14 release is sufficient.
- kumar
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de You can only live once, but if you do it right, once is enough.
This SF.Net email sponsored by: ApacheCon 2003, 16-19 November in Las Vegas. Learn firsthand the latest developments in Apache, PHP, Perl, XML, Java, MySQL, WebDAV, and more! http://www.apachecon.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Kumar Gala
