[PATCH] bootstd: Correct default boot command
The patch to relax flag requirements was not accepted[1], so we still have to have separate bootcommands depending on CMD_BOOTFLOW_FULL.
The previous attempt at this did not work, since it used the wrong name for the options.
Fix this and change the message to mention BOOTSTD_FULL since this affects not just the flags, but all functionality, so is more likely what the user wants.
Drop the useless condition on CMD_BOOTFLOW_FULL while we are here.
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230329071655.1959513-2-sj...
Signed-off-by: Simon Glass sjg@chromium.org Fixes: a91492b6e9c ("bootstd: Provide a default command") ---
boot/Kconfig | 4 ++-- cmd/Kconfig | 2 +- cmd/bootflow.c | 2 +- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 9882812eecb8..fad8e530b17f 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -1554,8 +1554,8 @@ config USE_BOOTCOMMAND config BOOTCOMMAND string "bootcmd value" depends on USE_BOOTCOMMAND && !USE_DEFAULT_ENV_FILE - default "bootflow scan -lb" if BOOTSTD_BOOTCOMMAND && CMD_BOOTFLOW_FULL - default "bootflow scan" if BOOTSTD_BOOTCOMMAND && !CMD_BOOTFLOW_FULL + default "bootflow scan -lb" if BOOTSTD_DEFAULTS && CMD_BOOTFLOW_FULL + default "bootflow scan" if BOOTSTD_DEFAULTS && !CMD_BOOTFLOW_FULL default "run distro_bootcmd" if !BOOTSTD_BOOTCOMMAND && DISTRO_DEFAULTS help This is the string of commands that will be used as bootcmd and if diff --git a/cmd/Kconfig b/cmd/Kconfig index e45b8847aef7..a630a343e25d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -258,7 +258,7 @@ config CMD_BOOTFLOW config CMD_BOOTFLOW_FULL bool "bootflow - extract subcommands" depends on BOOTSTD_FULL - default y if BOOTSTD_FULL + default y help Add the ability to list the available bootflows, select one and obtain information about it. diff --git a/cmd/bootflow.c b/cmd/bootflow.c index cfe342269896..6cc58e48c7d0 100644 --- a/cmd/bootflow.c +++ b/cmd/bootflow.c @@ -125,7 +125,7 @@ static int do_bootflow_scan(struct cmd_tbl *cmdtp, int flag, int argc, dev = std->cur_bootdev; } else { if (has_args) { - printf("Flags not supported: enable CONFIG_BOOTFLOW_FULL\n"); + printf("Flags not supported: enable CONFIG_BOOTSTD_FULL\n"); return CMD_RET_USAGE; } boot = true;
