[U-Boot-Users] [PATCH 5/6] mpc83xx: migrate remaining freescale boards to libfdt
this adds libfdt support code for the freescale mpc8313erdb, mpc832xemds, mpc8349emds, mpc8349itx, and gp boards.
Boards remain compatible with OF_FLAT_TREE.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- board/freescale/mpc8323erdb/mpc8323erdb.c | 15 ++++++++-- board/mpc8313erdb/mpc8313erdb.c | 19 ++++++++----- board/mpc832xemds/mpc832xemds.c | 18 +++++++----- board/mpc832xemds/pci.c | 24 ++++++++++++++++- board/mpc8349emds/mpc8349emds.c | 18 +++++++----- board/mpc8349emds/pci.c | 41 ++++++++++++++++++++++++++++- board/mpc8349itx/mpc8349itx.c | 18 +++++++----- board/mpc8349itx/pci.c | 39 ++++++++++++++++++++++++++- board/mpc8360emds/mpc8360emds.c | 11 +++----- cpu/mpc83xx/pci.c | 15 ++++++++-- 10 files changed, 170 insertions(+), 48 deletions(-)
diff --git a/board/freescale/mpc8323erdb/mpc8323erdb.c b/board/freescale/mpc8323erdb/mpc8323erdb.c index 81b82b7..850d1c3 100644 --- a/board/freescale/mpc8323erdb/mpc8323erdb.c +++ b/board/freescale/mpc8323erdb/mpc8323erdb.c @@ -184,12 +184,21 @@ void pci_init_board(void) }
#if defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup(void *blob, bd_t *bd) +void ft_board_setup(void *blob, bd_t *bd) { +#if defined(CONFIG_OF_FLAT_TREE) + u32 *p; + int len; + + p = ft_get_prop(blob, "/memory/reg", &len); + if (p != NULL) { + *p++ = cpu_to_be32(bd->bi_memstart); + *p = cpu_to_be32(bd->bi_memsize); + } +#endif ft_cpu_setup(blob, bd); #ifdef CONFIG_PCI ft_pci_setup(blob, bd); #endif } -#endif /* CONFIG_OF_BOARD_SETUP */ +#endif diff --git a/board/mpc8313erdb/mpc8313erdb.c b/board/mpc8313erdb/mpc8313erdb.c index 999fe9e..861c143 100644 --- a/board/mpc8313erdb/mpc8313erdb.c +++ b/board/mpc8313erdb/mpc8313erdb.c @@ -23,7 +23,11 @@ */
#include <common.h> +#if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#endif #include <pci.h> #include <mpc83xx.h>
@@ -96,21 +100,22 @@ void pci_init_board(void) mpc83xx_pci_init(1, reg, warmboot); }
-#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) +#if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { +#if defined(CONFIG_OF_FLAT_TREE) u32 *p; int len;
-#ifdef CONFIG_PCI - ft_pci_setup(blob, bd); -#endif - ft_cpu_setup(blob, bd); - p = ft_get_prop(blob, "/memory/reg", &len); - if (p) { + if (p != NULL) { *p++ = cpu_to_be32(bd->bi_memstart); *p = cpu_to_be32(bd->bi_memsize); } +#endif + ft_cpu_setup(blob, bd); +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif } #endif diff --git a/board/mpc832xemds/mpc832xemds.c b/board/mpc832xemds/mpc832xemds.c index 772da67..f70783e 100644 --- a/board/mpc832xemds/mpc832xemds.c +++ b/board/mpc832xemds/mpc832xemds.c @@ -29,6 +29,8 @@ #endif #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> #endif
const qe_iop_conf_t qe_iop_conf_tab[] = { @@ -155,22 +157,22 @@ int checkboard(void) return 0; }
-#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup(void *blob, bd_t *bd) +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) { +#if defined(CONFIG_OF_FLAT_TREE) u32 *p; int len;
-#ifdef CONFIG_PCI - ft_pci_setup(blob, bd); -#endif - ft_cpu_setup(blob, bd); - p = ft_get_prop(blob, "/memory/reg", &len); if (p != NULL) { *p++ = cpu_to_be32(bd->bi_memstart); *p = cpu_to_be32(bd->bi_memsize); } +#endif + ft_cpu_setup(blob, bd); +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif } #endif diff --git a/board/mpc832xemds/pci.c b/board/mpc832xemds/pci.c index d0a407a..c2f61ea 100644 --- a/board/mpc832xemds/pci.c +++ b/board/mpc832xemds/pci.c @@ -20,6 +20,8 @@ #include <i2c.h> #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> #endif
#include <asm/fsl_i2c.h> @@ -299,7 +301,27 @@ void pci_init_board(void) } #endif /* CONFIG_PCISLAVE */
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_LIBFDT) +void +ft_pci_setup(void *blob, bd_t *bd) +{ + int nodeoffset; + int err; + int tmp[2]; + + nodeoffset = fdt_find_node_by_path(blob, "/" OF_SOC "/pci@8500"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(hose[0].first_busno); + tmp[1] = cpu_to_be32(hose[0].last_busno); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); + } +} +#elif defined(CONFIG_OF_FLAT_TREE) void ft_pci_setup(void *blob, bd_t *bd) { diff --git a/board/mpc8349emds/mpc8349emds.c b/board/mpc8349emds/mpc8349emds.c index 521d1bb..2ad25ec 100644 --- a/board/mpc8349emds/mpc8349emds.c +++ b/board/mpc8349emds/mpc8349emds.c @@ -34,6 +34,8 @@ #endif #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> #endif
int fixed_sdram(void); @@ -257,22 +259,22 @@ void sdram_init(void) } #endif
-#ifdef CONFIG_PCI - ft_pci_setup(blob, bd); -#endif - ft_cpu_setup(blob, bd); - p = ft_get_prop(blob, "/memory/reg", &len); if (p != NULL) { *p++ = cpu_to_be32(bd->bi_memstart); *p = cpu_to_be32(bd->bi_memsize); } +#endif + ft_cpu_setup(blob, bd); +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif } #endif diff --git a/board/mpc8349emds/pci.c b/board/mpc8349emds/pci.c index d6a12b8..ae94a2f 100644 --- a/board/mpc8349emds/pci.c +++ b/board/mpc8349emds/pci.c @@ -25,6 +25,12 @@ #include <pci.h> #include <asm/mpc8349_pci.h> #include <i2c.h> +#if defined(CONFIG_OF_FLAT_TREE) +#include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> +#endif +
DECLARE_GLOBAL_DATA_PTR;
@@ -382,7 +388,40 @@ pci_init_board(void)
-#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_LIBFDT) +void +ft_pci_setup(void *blob, bd_t *bd) +{ + int nodeoffset; + int err; + int tmp[2]; + + nodeoffset = fdt_find_node_by_path(blob, "/" OF_SOC "/pci@8500"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(pci_hose[0].first_busno); + tmp[1] = cpu_to_be32(pci_hose[0].last_busno); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); + } +#ifdef CONFIG_MPC83XX_PCI2 + nodeoffset = fdt_find_node_by_path(blob, "/" OF_SOC "/pci@8600"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(pci_hose[1].first_busno); + tmp[1] = cpu_to_be32(pci_hose[1].last_busno); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); + } +#endif +} +#elif defined(CONFIG_OF_FLAT_TREE) void ft_pci_setup(void *blob, bd_t *bd) { diff --git a/board/mpc8349itx/mpc8349itx.c b/board/mpc8349itx/mpc8349itx.c index 178b1d3..125e6c0 100644 --- a/board/mpc8349itx/mpc8349itx.c +++ b/board/mpc8349itx/mpc8349itx.c @@ -39,6 +39,8 @@ #endif #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> #endif
#ifndef CONFIG_SPD_EEPROM @@ -385,22 +387,22 @@ int misc_init_r(void) return rc; }
-#ifdef CONFIG_PCI - ft_pci_setup(blob, bd); -#endif - ft_cpu_setup(blob, bd); - p = ft_get_prop(blob, "/memory/reg", &len); if (p != NULL) { *p++ = cpu_to_be32(bd->bi_memstart); *p = cpu_to_be32(bd->bi_memsize); } +#endif + ft_cpu_setup(blob, bd); +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif } #endif diff --git a/board/mpc8349itx/pci.c b/board/mpc8349itx/pci.c index e81ad27..5ca094d 100644 --- a/board/mpc8349itx/pci.c +++ b/board/mpc8349itx/pci.c @@ -31,6 +31,8 @@ #include <i2c.h> #if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> +#elif defined(CONFIG_OF_LIBFDT) +#include <libfdt.h> #endif
DECLARE_GLOBAL_DATA_PTR; @@ -332,8 +334,40 @@ void pci_init_board(void) #endif }
-#endif /* CONFIG_PCI */ -#ifdef CONFIG_OF_FLAT_TREE +#if defined(CONFIG_OF_LIBFDT) +void +ft_pci_setup(void *blob, bd_t *bd) +{ + int nodeoffset; + int err; + int tmp[2]; + + nodeoffset = fdt_find_node_by_path(blob, "/" OF_SOC "/pci@8500"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(pci_hose[0].first_busno); + tmp[1] = cpu_to_be32(pci_hose[0].last_busno); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); + } +#ifdef CONFIG_MPC83XX_PCI2 + nodeoffset = fdt_find_node_by_path(blob, "/" OF_SOC "/pci@8500"); + if (nodeoffset >= 0) { + tmp[0] = cpu_to_be32(pci_hose[1].first_busno); + tmp[1] = cpu_to_be32(pci_hose[1].last_busno); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); + } +#endif +} +#elif defined(CONFIG_OF_FLAT_TREE) void ft_pci_setup(void *blob, bd_t *bd) { @@ -355,3 +389,4 @@ ft_pci_setup(void *blob, bd_t *bd) #endif } #endif /* CONFIG_OF_FLAT_TREE */ +#endif /* CONFIG_PCI */ diff --git a/board/mpc8360emds/mpc8360emds.c b/board/mpc8360emds/mpc8360emds.c index eec46fb..3861733 100644 --- a/board/mpc8360emds/mpc8360emds.c +++ b/board/mpc8360emds/mpc8360emds.c @@ -284,10 +284,8 @@ void sdram_init(void) } #endif
-#if (defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT)) \ - && defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup(void *blob, bd_t *bd) +#if defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) { #if defined(CONFIG_OF_FLAT_TREE) u32 *p; @@ -299,10 +297,9 @@ ft_board_setup(void *blob, bd_t *bd) *p = cpu_to_be32(bd->bi_memsize); } #endif - + ft_cpu_setup(blob, bd); #ifdef CONFIG_PCI ft_pci_setup(blob, bd); #endif - ft_cpu_setup(blob, bd); } -#endif /* CONFIG_OF_x */ +#endif diff --git a/cpu/mpc83xx/pci.c b/cpu/mpc83xx/pci.c index 2298218..5675afe 100644 --- a/cpu/mpc83xx/pci.c +++ b/cpu/mpc83xx/pci.c @@ -28,7 +28,6 @@
#if defined(CONFIG_OF_LIBFDT) #include <libfdt.h> -#include <libfdt_env.h> #elif defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> #endif @@ -184,7 +183,12 @@ void ft_pci_setup(void *blob, bd_t *bd) if (nodeoffset >= 0) { tmp[0] = cpu_to_be32(pci_hose[0].first_busno); tmp[1] = cpu_to_be32(pci_hose[0].last_busno); - err = fdt_setprop(blob, nodeoffset, "bus-range", tmp, sizeof(tmp)); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); }
if (pci_num_buses < 2) @@ -194,7 +198,12 @@ void ft_pci_setup(void *blob, bd_t *bd) if (nodeoffset >= 0) { tmp[0] = cpu_to_be32(pci_hose[0].first_busno); tmp[1] = cpu_to_be32(pci_hose[0].last_busno); - err = fdt_setprop(blob, nodeoffset, "bus-range", tmp, sizeof(tmp)); + err = fdt_setprop(blob, nodeoffset, "bus-range", + tmp, sizeof(tmp)); + + tmp[0] = cpu_to_be32(gd->pci_clk); + err = fdt_setprop(blob, nodeoffset, "clock-frequency", + tmp, sizeof(tmp[0])); } } #elif CONFIG_OF_FLAT_TREE
Kim Phillips
