[PATCH] rockchip: io-domain: Add support for RK3308
Port the RK3308 part of the Rockchip IO Domain driver from linux.
This differs from linux version in that vccio3 iodomain bit is enabled in the write ops instead of in an init ops as in linux, this way we can avoid keeping a full state of all supply that have been configured.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/mach-rockchip/rk3308/syscon_rk3308.c | 3 ++ drivers/misc/rockchip-io-domain.c | 37 +++++++++++++++++++ 2 files changed, 40 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3308/syscon_rk3308.c b/arch/arm/mach-rockchip/rk3308/syscon_rk3308.c index 2d7e97110152..e77189eef6cf 100644 --- a/arch/arm/mach-rockchip/rk3308/syscon_rk3308.c +++ b/arch/arm/mach-rockchip/rk3308/syscon_rk3308.c @@ -16,4 +16,7 @@ U_BOOT_DRIVER(syscon_rk3308) = { .name = "rk3308_syscon", .id = UCLASS_SYSCON, .of_match = rk3308_syscon_ids, +#if CONFIG_IS_ENABLED(OF_REAL) + .bind = dm_scan_fdt_dev, +#endif }; diff --git a/drivers/misc/rockchip-io-domain.c b/drivers/misc/rockchip-io-domain.c index cf4f7c3984c7..025b6049a9f7 100644 --- a/drivers/misc/rockchip-io-domain.c +++ b/drivers/misc/rockchip-io-domain.c @@ -31,6 +31,10 @@ #define PX30_IO_VSEL_VCCIO6_SRC BIT(0) #define PX30_IO_VSEL_VCCIO6_SUPPLY_NUM 1
+#define RK3308_SOC_CON0 0x300 +#define RK3308_SOC_CON0_VCCIO3 BIT(8) +#define RK3308_SOC_VCCIO3_SUPPLY_NUM 3 + #define RK3328_SOC_CON4 0x410 #define RK3328_SOC_CON4_VCCIO2 BIT(7) #define RK3328_SOC_VCCIO2_SUPPLY_NUM 1 @@ -119,6 +123,22 @@ static int px30_iodomain_write(struct regmap *grf, uint offset, int idx, int uV) return ret; }
+static int rk3308_iodomain_write(struct regmap *grf, uint offset, int idx, int uV) +{ + int ret = rockchip_iodomain_write(grf, offset, idx, uV); + + if (!ret && idx == RK3308_SOC_VCCIO3_SUPPLY_NUM) { + /* + * set vccio3 iodomain to also use this framework + * instead of a special gpio. + */ + u32 val = RK3308_SOC_CON0_VCCIO3 | (RK3308_SOC_CON0_VCCIO3 << 16); + ret = regmap_write(grf, RK3308_SOC_CON0, val); + } + + return ret; +} + static int rk3328_iodomain_write(struct regmap *grf, uint offset, int idx, int uV) { int ret = rockchip_iodomain_write(grf, offset, idx, uV); @@ -189,6 +209,19 @@ static const struct rockchip_iodomain_soc_data soc_data_px30_pmu = { .write = rockchip_iodomain_write, };
+static const struct rockchip_iodomain_soc_data soc_data_rk3308 = { + .grf_offset = 0x300, + .supply_names = { + "vccio0-supply", + "vccio1-supply", + "vccio2-supply", + "vccio3-supply", + "vccio4-supply", + "vccio5-supply", + }, + .write = rk3308_iodomain_write, +}; + static const struct rockchip_iodomain_soc_data soc_data_rk3328 = { .grf_offset = 0x410, .supply_names = { @@ -256,6 +289,10 @@ static const struct udevice_id rockchip_iodomain_ids[] = { .compatible = "rockchip,px30-pmu-io-voltage-domain", .data = (ulong)&soc_data_px30_pmu, }, + { + .compatible = "rockchip,rk3308-io-voltage-domain", + .data = (ulong)&soc_data_rk3308, + }, { .compatible = "rockchip,rk3328-io-voltage-domain", .data = (ulong)&soc_data_rk3328,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- .bind = dm_scan_fdt_dev,
- #define RK3328_SOC_CON4 0x410 #define RK3328_SOC_CON4_VCCIO2 BIT(7) #define RK3328_SOC_VCCIO2_SUPPLY_NUM 1
- int ret = rockchip_iodomain_write(grf, offset, idx, uV);
- if (!ret && idx == RK3308_SOC_VCCIO3_SUPPLY_NUM) {
- return ret;
- static int rk3328_iodomain_write(struct regmap *grf, uint offset, int idx, int uV) { int ret = rockchip_iodomain_write(grf, offset, idx, uV);
- .grf_offset = 0x300,
- .supply_names = {
"vccio0-supply",
"vccio1-supply",
"vccio2-supply",
"vccio3-supply",
"vccio4-supply",
"vccio5-supply",
- .write = rk3308_iodomain_write,
- static const struct rockchip_iodomain_soc_data soc_data_rk3328 = { .grf_offset = 0x410, .supply_names = {
- }, { .compatible = "rockchip,rk3328-io-voltage-domain", .data = (ulong)&soc_data_rk3328,
Jonas Karlman
Kever Yang
