[U-Boot] [PATCH][v2] mpc85xx/u-boot*.lds: remove _GLOBAL_OFFSET_TABLE_ definition
In binutils-2.25, the _GLOBAL_OFFSET_TABLE_ symbols defined by PROVIDE in u-boot.lds overrides the linker built-in symbols (https://sourceware.org/git/gitweb.cgi?p=binutils-gdb.git;a=commitdiff; h=b893397a4b1316610f49819344817715e4305de9), so the linker is treating _GLOBAL_OFFSET_TABLE_ as a definition into the .reloc section.
To align with the change of binutils-2.25, the _GLOBAL_OFFSET_TABLE_ symbol should not be defined in sections, and the symbols in linker generated .got section should be used(https://sourceware.org/ml/binutils/2008-09/ msg00122.html)
Fixed the following build errors with binutils-2.25: | powerpc-poky-linux-gnuspe-ld.bfd: _GLOBAL_OFFSET_TABLE_ not defined in linker created .got
Signed-off-by: Zhenhua Luo zhenhua.luo@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: Updated Subject
arch/powerpc/cpu/mpc85xx/u-boot-nand.lds | 1 - arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds | 1 - arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 1 - arch/powerpc/cpu/mpc85xx/u-boot.lds | 1 - 4 files changed, 4 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds b/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds index f933b21..0399f93 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds @@ -44,7 +44,6 @@ SECTIONS _GOT2_TABLE_ = .; KEEP(*(.got2)) KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); _FIXUP_TABLE_ = .; KEEP(*(.fixup)) } diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds index b83c553..f044564 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds @@ -22,7 +22,6 @@ SECTIONS _GOT2_TABLE_ = .; KEEP(*(.got2)) KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); _FIXUP_TABLE_ = .; KEEP(*(.fixup)) } diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index 5ae7b3e..889a4c2 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -29,7 +29,6 @@ SECTIONS _GOT2_TABLE_ = .; KEEP(*(.got2)) KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); _FIXUP_TABLE_ = .; KEEP(*(.fixup)) } diff --git a/arch/powerpc/cpu/mpc85xx/u-boot.lds b/arch/powerpc/cpu/mpc85xx/u-boot.lds index 2cf0b25..f15eaf3 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot.lds @@ -50,7 +50,6 @@ SECTIONS _GOT2_TABLE_ = .; KEEP(*(.got2)) KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); _FIXUP_TABLE_ = .; KEEP(*(.fixup)) }
Prabhakar/Zhenghua,
Have you addressed Tom's comment (on rev 1 patch)? Quote, "What happens when we use older binutils? I'd like some run-time testing too please".
York
hmm, what was the reson for this change in binutils? As I recall, PROVIDE should only add a symbol when there is none and now binutils just ignores this, strange.
Yes, where do you want it instead? what is the difference with/without PROVIDE?
To align with the change of binutils-2.25, the _GLOBAL_OFFSET_TABLE_ symbol should not be defined in sections, and the symbols in linker generated .got section should be used(https://sourceware.org/ml/binutils/2008-09/ msg00122.html) Fixed the following build errors with binutils-2.25:
linker created .got
Prabhakar/Zhenghua,
York
[Resending with old email address]
I want to add why PROVIDE was added in the first place: In theory it is possible to build an u-boot without ld defining _GLOBAL_OFFSET_TABLE_, in that case we create _GLOBAL_OFFSET_TABLE_ ourself.
Should we start using -fPIC* one day this will we will be close to an u-boot without _GLOBAL_OFFSET_TABLE_ and the __got2_entries calculation will fail.
*older gcc's will automatically promote -fpic to -fPIC when used with -mrelocatable I wrote a small patch in 2010 to fix this: https://gcc.gnu.org/ml/gcc-patches/2010-10/msg02301.html Cannot remember what gcc version(4.6?) that went into.
About the same time support for -msingle-pic-base was added to powerpc gcc This would reduce code size further, possibly interesting for SPL? I sent som patches for that but there were something holding them back.
linker created .got
Prabhakar/Zhenghua,
York
participants (5)
Joakim Tjernlund
Joakim Tjernlund
Prabhakar Kushwaha
York Sun
