Fw: [U-Boot-Users] [PATCH] Fix for configuration has both dataflash and parallel flash
Hi Denk,
You really need to look at this patch.
Forwarded by Wang Jian lark@linux.net.cn ----------------------- Original Message ----------------------- From: Wang Jian lark@linux.net.cn To: u-boot-users@lists.sourceforge.net Date: Mon, 03 Apr 2006 15:22:31 +0800 Subject: [U-Boot-Users] [PATCH] Fix for configuration has both dataflash and parallel flash ----
When the board has both dataflash and parallel flash, using 'cp' command will write to parallel flash and then fail.
The patch below fixes the problem. BTW, I think "addr" is typo of "dest" in the dataflash test, so the patch may be as simple as s/addr/dest/ in dataflash test. I am in a hurry, so let suitable person to decide.
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index 0f4f9b7..a01c2a5 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -423,6 +423,7 @@ int do_mem_cp ( cmd_tbl_t *cmdtp, int fl /* check if we are copying to Flash */ if ( (addr2info(dest) != NULL) #ifdef CONFIG_HAS_DATAFLASH + && (!addr_dataflash(dest)) && (!addr_dataflash(addr)) #endif ) {
Wang Jian
