[PATCH V5 0/4] arm64: imx8mp: Read values from M24C32-D write-lockable page on DHCOM i.MX8MP
The new i.MX8M Plus DHCOM rev.200 is populated with M24C32-D EEPROM that contains an additional write-lockable page called ID page, which is populated with a structure containing ethernet MAC addresses, DH item number and DH serial number.
This patch series prepare the device tree of the DHCOM i.MX8MP for reading the EEPROM ID page. Add the reading of the content and set the correspondent environment variable. It also synchronize two serial number environment variable via callback functions and fixing recursive calling of them.
To ensure that the environment callback functions work, this patch series depends on patch [1].
[1] https://patchwork.ozlabs.org/project/uboot/patch/20241120160135.28262-1-cnie...
Christoph Niedermaier (4): arm64: dts: imx8mp: Add aliases for the access to the EEPROM ID page node arm64: imx8mp: Read values from M24C32-D write-lockable page on DHCOM i.MX8MP lib: hashtable: Prevent recursive calling of callback functions board: dhelectronics: Sync env variable dh_som_serial_number with SN
arch/arm/dts/imx8mp-dhcom-u-boot.dtsi | 2 + board/dhelectronics/common/dh_common.c | 166 +++++++++++++++++- board/dhelectronics/common/dh_common.h | 79 ++++++++- .../dh_imx8mp/imx8mp_dhcom_pdk2.c | 75 +++++++- configs/dhsom.config | 1 + lib/hashtable.c | 27 ++- 6 files changed, 339 insertions(+), 11 deletions(-)
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com
The new i.MX8M Plus DHCOM rev.200 is populated with M24C32-D EEPROM that contains an additional write-lockable page called ID page. Add aliases eeprom0wl and eeprom1wl for the access to the EEPROM ID page node.
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com Reviewed-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com --- V3: - Add this patch to the series V4: - Typo in subject and commit message corrected V5: - Add Reviewed-by tag --- arch/arm/dts/imx8mp-dhcom-u-boot.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi b/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi index c065fb8299..546490a4a8 100644 --- a/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-dhcom-u-boot.dtsi @@ -9,6 +9,8 @@ aliases { eeprom0 = &eeprom0; eeprom1 = &eeprom1; + eeprom0wl = &eeprom0wl; + eeprom1wl = &eeprom1wl; mmc0 = &usdhc2; /* MicroSD */ mmc1 = &usdhc3; /* eMMC */ mmc2 = &usdhc1; /* SDIO */
Because the write-lockable page is not present on rev.100 i.MX8MP DHCOM SoM, test whether EEPROM ID page exists by setting up the i2c driver.
There may be multiple EEPROMs with an ID page on this platform, always use the first one. The evaluation of the EEPROM ID page is done in two steps. First, the content is read and checked. This is done to cache the content of the EEPROM ID page. Second, the content is extracted from the EEPROM buffer by requesting it.
For the ethernet MAC address the i.MX8M Plus DHCOM currently supports parsing address from multiple sources in the following priority order:
1) U-Boot environment 'ethaddr'/'eth1addr' environment variable 2) SoC OTP fuses 3) On-SoM EEPROM
Add support for parsing the content of this new EEPROM ID page and place it between 2) and 3) on the priority list. The new entry is 2.5) On-SoM EEPROM write-lockable page.
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com --- V2: - Merging the two previous patches "arm64: imx8mp: Read MAC address from M24C32-D write-lockable page on DH i.MX8MP DHCOM if available" and "arm64: imx8mp: Read item and serial number from EEPROM ID page on DH i.MX8MP DHCOM" - Split function for reading the EEPROM ID page - One for reading the content and check the header to cache the EEPROM ID page - Second for requesting values from the content buffer - Use an EEPROM buffer array in function board_late_init() to cache the EEPROM ID page content - Add namespaces for defines - Improve request values names (enum) - Add function for reading the hardware coding - Adjust the mac address function to use the EEPROM ID page content buffer - Arrange valiables in reverse xmas tree order V3: - Add #defines for the version of the EEPROM ID page data located in the header - Reference EEPROM ID page directly by new aliases - Read EEPROM content directly to the buffer by the given parameter - Give some variables a more meaningful name - Improve determination of the EEPROM ID page size - Validation of the EEPROM ID page data in the reading function - Shorten the reading function - Add namespace to all defines and enums - Use more local variable in the evaluation function for a better reading - Fix wrong return of the function __weak int dh_setup_mac_address() - Remove function for reading the hardware revision - Use printf for output throughout - After EEPROM ID page reading error call the function dh_setup_mac_address() with parameter NULL - Suppress error message for the hardware rev. 100 in case of return value -ENODEV V4: - Divide main structure into header and payload - Use of a pointer of the main structure for the handover to the functions - Improve error handling for EEPROM ID page size determination - Extend error message for the validation of the header ID - Extend error message for calculating the header checksum - Extend error message for calculating the payload checksum - Place variables fin_chr and soc_coded at the beginning of the function - Move main structure definition and defines to the header file v5: - Remove unnecessary else if when checking the EEPROM size - Inversion of the version check --- board/dhelectronics/common/dh_common.c | 149 +++++++++++++++++- board/dhelectronics/common/dh_common.h | 79 +++++++++- .../dh_imx8mp/imx8mp_dhcom_pdk2.c | 75 ++++++++- 3 files changed, 295 insertions(+), 8 deletions(-)
diff --git a/board/dhelectronics/common/dh_common.c b/board/dhelectronics/common/dh_common.c index 32c50b4f0f..6a942909cc 100644 --- a/board/dhelectronics/common/dh_common.c +++ b/board/dhelectronics/common/dh_common.c @@ -7,6 +7,7 @@ #include <dm.h> #include <i2c_eeprom.h> #include <net.h> +#include <u-boot/crc.h>
#include "dh_common.h"
@@ -30,6 +31,149 @@ int dh_get_mac_is_enabled(const char *alias) return 0; }
+int dh_read_eeprom_id_page(u8 *eeprom_buffer, const char *alias) +{ + struct eeprom_id_page *eip = (struct eeprom_id_page *)eeprom_buffer; + struct udevice *dev; + size_t payload_len; + int eeprom_size; + u16 crc16_calc; + u16 crc16_eip; + u8 crc8_calc; + ofnode node; + int ret; + + node = ofnode_path(alias); + + ret = uclass_get_device_by_ofnode(UCLASS_I2C_EEPROM, node, &dev); + if (ret) + return ret; + + eeprom_size = i2c_eeprom_size(dev); + if (eeprom_size < 0) { + printf("%s: Error getting EEPROM ID page size! ret = %d\n", __func__, ret); + return eeprom_size; + } + + if (eeprom_size == 0 || eeprom_size > DH_EEPROM_ID_PAGE_MAX_SIZE) { + eeprom_size = DH_EEPROM_ID_PAGE_MAX_SIZE; + printf("Get invalid EEPROM ID page size %d bytes! Try to read %d bytes.\n", + eeprom_size, DH_EEPROM_ID_PAGE_MAX_SIZE); + } + + ret = i2c_eeprom_read(dev, 0x0, eeprom_buffer, eeprom_size); + if (ret) { + printf("%s: Error reading EEPROM ID page! ret = %d\n", __func__, ret); + return ret; + } + + /* Validate header ID */ + if (eip->hdr.id[0] != 'D' || eip->hdr.id[1] != 'H' || eip->hdr.id[2] != 'E') { + printf("%s: Error validating header ID! (got %c%c%c (0x%02x 0x%02x 0x%02x) != expected DHE)\n", + __func__, isprint(eip->hdr.id[0]) ? eip->hdr.id[0] : '.', + isprint(eip->hdr.id[1]) ? eip->hdr.id[1] : '.', + isprint(eip->hdr.id[2]) ? eip->hdr.id[2] : '.', + eip->hdr.id[0], eip->hdr.id[1], eip->hdr.id[2]); + return -EINVAL; + } + + /* Validate header checksum */ + crc8_calc = crc8(0xff, eeprom_buffer, offsetof(struct eeprom_id_page, hdr.crc8_hdr)); + if (eip->hdr.crc8_hdr != crc8_calc) { + printf("%s: Error validating header checksum! (got 0x%02x != calc 0x%02x)\n", + __func__, eip->hdr.crc8_hdr, crc8_calc); + return -EINVAL; + } + + /* + * Validate header version + * The payload is defined by the version specified in the header. + * Currently only version 0x10 is defined, so take the length of + * the only defined payload as the payload length. + */ + if (eip->hdr.version != DH_EEPROM_ID_PAGE_V1_0) { + printf("%s: Error validating version! (0x%02X is not supported)\n", + __func__, eip->hdr.version); + return -EINVAL; + } + payload_len = sizeof(eip->pl); + + /* Validate payload checksum */ + crc16_eip = (eip->hdr.crc16_pl[1] << 8) | eip->hdr.crc16_pl[0]; + crc16_calc = crc16(0xffff, eeprom_buffer + sizeof(eip->hdr), payload_len); + if (crc16_eip != crc16_calc) { + printf("%s: Error validating data checksum! (got 0x%02x != calc 0x%02x)\n", + __func__, crc16_eip, crc16_calc); + return -EINVAL; + } + + return 0; +} + +int dh_get_value_from_eeprom_buffer(enum eip_request_values request, u8 *data, int data_len, + struct eeprom_id_page *eip) +{ + const char fin_chr = (eip->pl.item_prefix & DH_ITEM_PREFIX_FIN_BIT) ? + DH_ITEM_PREFIX_FIN_FLASHED_CHR : DH_ITEM_PREFIX_FIN_HALF_CHR; + const u8 soc_coded = eip->pl.item_prefix & 0xf; + char soc_chr; + + if (!eip) + return -EINVAL; + + /* Copy requested data */ + switch (request) { + case DH_MAC0: + if (!is_valid_ethaddr(eip->pl.mac0)) + return -EINVAL; + + if (data_len >= sizeof(eip->pl.mac0)) + memcpy(data, eip->pl.mac0, sizeof(eip->pl.mac0)); + else + return -EINVAL; + break; + case DH_MAC1: + if (!is_valid_ethaddr(eip->pl.mac1)) + return -EINVAL; + + if (data_len >= sizeof(eip->pl.mac1)) + memcpy(data, eip->pl.mac1, sizeof(eip->pl.mac1)); + else + return -EINVAL; + break; + case DH_ITEM_NUMBER: + if (data_len < 8) /* String length must be 7 characters + string termination */ + return -EINVAL; + + if (soc_coded == DH_ITEM_PREFIX_NXP) + soc_chr = DH_ITEM_PREFIX_NXP_CHR; + else if (soc_coded == DH_ITEM_PREFIX_ST) + soc_chr = DH_ITEM_PREFIX_ST_CHR; + else + return -EINVAL; + + snprintf(data, data_len, "%c%c%05d", fin_chr, soc_chr, + (eip->pl.item_num[0] << 16) | (eip->pl.item_num[1] << 8) | + eip->pl.item_num[2]); + break; + case DH_SERIAL_NUMBER: + /* + * data_len must be greater than the size of eip->pl.serial, + * because there is a string termination needed. + */ + if (data_len <= sizeof(eip->pl.serial)) + return -EINVAL; + + data[sizeof(eip->pl.serial)] = 0; + memcpy(data, eip->pl.serial, sizeof(eip->pl.serial)); + break; + default: + return -EINVAL; + } + + return 0; +} + int dh_get_mac_from_eeprom(unsigned char *enetaddr, const char *alias) { struct udevice *dev; @@ -62,7 +206,7 @@ int dh_get_mac_from_eeprom(unsigned char *enetaddr, const char *alias) return 0; }
-__weak int dh_setup_mac_address(void) +__weak int dh_setup_mac_address(struct eeprom_id_page *eip) { unsigned char enetaddr[6];
@@ -72,6 +216,9 @@ __weak int dh_setup_mac_address(void) if (dh_get_mac_is_enabled("ethernet0")) return 0;
+ if (!dh_get_value_from_eeprom_buffer(DH_MAC0, enetaddr, sizeof(enetaddr), eip)) + return eth_env_set_enetaddr("ethaddr", enetaddr); + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) return eth_env_set_enetaddr("ethaddr", enetaddr);
diff --git a/board/dhelectronics/common/dh_common.h b/board/dhelectronics/common/dh_common.h index a2de5b1553..c4693c6061 100644 --- a/board/dhelectronics/common/dh_common.h +++ b/board/dhelectronics/common/dh_common.h @@ -3,6 +3,52 @@ * Copyright 2022 DENX Software Engineering GmbH, Philip Oberfichtner pro@denx.de */
+#define DH_EEPROM_ID_PAGE_MAX_SIZE 64 + +enum eip_request_values { + DH_MAC0, + DH_MAC1, + DH_ITEM_NUMBER, + DH_SERIAL_NUMBER, +}; + +/* DH item: Vendor coding */ +#define DH_ITEM_PREFIX_NXP 0x01 +#define DH_ITEM_PREFIX_NXP_CHR 'I' +#define DH_ITEM_PREFIX_ST 0x02 +#define DH_ITEM_PREFIX_ST_CHR 'S' + +/* + * DH item: Finished state coding + * Bit = 0 means half finished + * Prefix is 'H' + * Bit = 1 means finished with a customer image flashed + * Prefix is 'F' + */ +#define DH_ITEM_PREFIX_FIN_BIT BIT(7) +#define DH_ITEM_PREFIX_FIN_HALF_CHR 'H' +#define DH_ITEM_PREFIX_FIN_FLASHED_CHR 'F' + +struct eeprom_id_page { + /* Header */ + struct { + u8 id[3]; /* Identifier 'D', 'H', 'E' - 'D' is at index 0 */ + u8 version; /* 0x10 -- Version 1.0 */ + u8 crc16_pl[2]; /* Checksum payload, [1] is MSbyte */ + u8 crc8_hdr; /* Checksum header */ + } hdr; + /* Payload */ + struct { + u8 mac0[6]; + u8 mac1[6]; + u8 item_prefix; /* H/F is coded in MSbits, Vendor coding starts at LSbits */ + u8 item_num[3]; /* [2] is MSbyte */ + u8 serial[9]; /* [8] is MSbyte */ + } pl; +}; + +#define DH_EEPROM_ID_PAGE_V1_0 0x10 + /* * dh_mac_is_in_env - Check if MAC address is already set * @@ -28,9 +74,40 @@ int dh_get_mac_is_enabled(const char *alias); */ int dh_get_mac_from_eeprom(unsigned char *enetaddr, const char *alias);
+/* + * dh_read_eeprom_id_page() - Read EEPROM ID page content into given buffer + * @eeprom_buffer: Buffer for EEPROM ID page content + * @alias: Alias for EEPROM ID page device tree node + * + * Read the content of the EEPROM ID page into the given buffer (parameter + * eeprom_buffer). The EEPROM ID page device is selected via alias device + * tree name (parameter alias). The data of the EEPROM ID page is verified. + * An error is returned for reading failures and invalid data. + * + * Return: 0 if OK, other value on error + */ +int dh_read_eeprom_id_page(u8 *eeprom_buffer, const char *alias); + +/* + * dh_get_value_from_eeprom_buffer() - Get value from EEPROM buffer + * @eip_request_values: Requested value as enum + * @data: Buffer where value is to be stored + * @data_len: Length of the value buffer + * @eip: Pointer to EEPROM ID page struct from which the data is parsed + * + * Gets the value specified by the parameter eip_request_values from the EEPROM + * data struct (parameter eip). The data is written to the specified data + * buffer (parameter data). If the length of the data (parameter data_len) is + * not sufficient to copy the data into the buffer, an error is returned. + * + * Return: 0 if OK, other value on error + */ +int dh_get_value_from_eeprom_buffer(enum eip_request_values request, u8 *data, int data_len, + struct eeprom_id_page *eip); + /* * dh_setup_mac_address - Try to get MAC address from various locations and write it to env * * Return: 0 if OK, other value on error */ -int dh_setup_mac_address(void); +int dh_setup_mac_address(struct eeprom_id_page *eip); diff --git a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c index 78aae41235..4af3cbe9fe 100644 --- a/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c +++ b/board/dhelectronics/dh_imx8mp/imx8mp_dhcom_pdk2.c @@ -40,7 +40,7 @@ int board_phys_sdram_size(phys_size_t *size) return 0; }
-static int dh_imx8_setup_ethaddr(void) +static int dh_imx8_setup_ethaddr(struct eeprom_id_page *eip) { unsigned char enetaddr[6];
@@ -53,6 +53,9 @@ static int dh_imx8_setup_ethaddr(void) if (!dh_imx_get_mac_from_fuse(enetaddr)) goto out;
+ if (!dh_get_value_from_eeprom_buffer(DH_MAC0, enetaddr, sizeof(enetaddr), eip)) + goto out; + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom0")) goto out;
@@ -62,7 +65,7 @@ out: return eth_env_set_enetaddr("ethaddr", enetaddr); }
-static int dh_imx8_setup_eth1addr(void) +static int dh_imx8_setup_eth1addr(struct eeprom_id_page *eip) { unsigned char enetaddr[6];
@@ -75,6 +78,9 @@ static int dh_imx8_setup_eth1addr(void) if (!dh_imx_get_mac_from_fuse(enetaddr)) goto increment_out;
+ if (!dh_get_value_from_eeprom_buffer(DH_MAC1, enetaddr, sizeof(enetaddr), eip)) + goto out; + if (!dh_get_mac_from_eeprom(enetaddr, "eeprom1")) goto out;
@@ -95,21 +101,58 @@ out: return eth_env_set_enetaddr("eth1addr", enetaddr); }
-int dh_setup_mac_address(void) +int dh_setup_mac_address(struct eeprom_id_page *eip) { int ret;
- ret = dh_imx8_setup_ethaddr(); + ret = dh_imx8_setup_ethaddr(eip); if (ret) printf("%s: Unable to setup ethaddr! ret = %d\n", __func__, ret);
- ret = dh_imx8_setup_eth1addr(); + ret = dh_imx8_setup_eth1addr(eip); if (ret) printf("%s: Unable to setup eth1addr! ret = %d\n", __func__, ret);
return ret; }
+void dh_add_item_number_and_serial_to_env(struct eeprom_id_page *eip) +{ + char *item_number_env; + char item_number[8]; /* String with 7 characters + string termination */ + char *serial_env; + char serial[10]; /* String with 9 characters + string termination */ + int ret; + + ret = dh_get_value_from_eeprom_buffer(DH_ITEM_NUMBER, item_number, sizeof(item_number), + eip); + if (ret) { + printf("%s: Unable to get DHSOM item number from EEPROM ID page! ret = %d\n", + __func__, ret); + } else { + item_number_env = env_get("dh_som_item_number"); + if (!item_number_env) + env_set("dh_som_item_number", item_number); + else if (strcmp(item_number_env, item_number)) + printf("Warning: Environment dh_som_item_number differs from EEPROM ID page value (%s != %s)\n", + item_number_env, item_number); + } + + ret = dh_get_value_from_eeprom_buffer(DH_SERIAL_NUMBER, serial, sizeof(serial), + eip); + if (ret) { + printf("%s: Unable to get DHSOM serial number from EEPROM ID page! ret = %d\n", + __func__, ret); + } else { + serial_env = env_get("dh_som_serial_number"); + if (!serial_env) + env_set("dh_som_serial_number", serial); + else if (strcmp(serial_env, serial)) + printf("Warning: Environment dh_som_serial_number differs from EEPROM ID page value (%s != %s)\n", + serial_env, serial); + } +} + int board_init(void) { return 0; @@ -117,7 +160,27 @@ int board_init(void)
int board_late_init(void) { - dh_setup_mac_address(); + u8 eeprom_buffer[DH_EEPROM_ID_PAGE_MAX_SIZE] = { 0 }; + struct eeprom_id_page *eip = (struct eeprom_id_page *)eeprom_buffer; + int ret; + + ret = dh_read_eeprom_id_page(eeprom_buffer, "eeprom0wl"); + if (ret) { + /* + * The EEPROM ID page is available on SoM rev. 200 and greater. + * For SoM rev. 100 the return value will be -ENODEV. Suppress + * the error message for that, because the absence cannot be + * treated as an error. + */ + if (ret != -ENODEV) + printf("%s: Cannot read valid data from EEPROM ID page! ret = %d\n", + __func__, ret); + dh_setup_mac_address(NULL); + } else { + dh_setup_mac_address(eip); + dh_add_item_number_and_serial_to_env(eip); + } + return 0; }
- U-Boot environment 'ethaddr'/'eth1addr' environment variable
- SoC OTP fuses
- On-SoM EEPROM
In case there are two variables which each implement env callback that performs env_set() on the other variable, the callbacks will call each other recursively until the stack runs out. Prevent such a recursion from happening.
Example which triggers this behavior: static int on_foo(...) { env_set("bar", 0); ... } static int on_bar(...) { env_set("foo", 0); ... } U_BOOT_ENV_CALLBACK(foo, on_foo); U_BOOT_ENV_CALLBACK(bar, on_bar);
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com Suggested-by: Marek Vasut marex@denx.de --- Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Marek Vasut marex@denx.de Cc: u-boot@dh-electronics.com --- V4: - Add this patch to the series v5: - No functional changes, but changed the order of the patches --- lib/hashtable.c | 27 ++++++++++++++++++++++++--- 1 file changed, 24 insertions(+), 3 deletions(-)
diff --git a/lib/hashtable.c b/lib/hashtable.c index e8a59e2dca..75c263b505 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -221,11 +221,32 @@ static int do_callback(const struct env_entry *e, const char *name, const char *value, enum env_op op, int flags) { + int ret = 0; + #ifndef CONFIG_XPL_BUILD - if (e->callback) - return e->callback(name, value, op, flags); + static bool in_callback; + + if (!e->callback || in_callback) + return 0; + + /* + * In case there are two variables which each implement env callback + * that performs env_set() on the other variable, the callbacks will + * call each other recursively until the stack runs out. Prevent such + * a recursion from happening. + * + * Example which triggers this behavior: + * static int on_foo(...) { env_set("bar", 0); ... } + * static int on_bar(...) { env_set("foo", 0); ... } + * U_BOOT_ENV_CALLBACK(foo, on_foo); + * U_BOOT_ENV_CALLBACK(bar, on_bar); + */ + in_callback = true; + ret = e->callback(name, value, op, flags); + in_callback = false; #endif - return 0; + + return ret; }
The env variable "SN" is used to store the serial number on DH electronics SoMs. New SoMs will use the variable "dh_som_serial_number". To ensure compatibility, these env variables are synchronized. This is achieved using callback functions.
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com --- V3: - Add this patch to the series V4: - Remove the recursion prevention from the callback functions => The recursion prevention will be generally solved in the callback function call in a separate patch v5: - No functional changes, but changed the order of the patches --- board/dhelectronics/common/dh_common.c | 17 +++++++++++++++++ configs/dhsom.config | 1 + 2 files changed, 18 insertions(+)
diff --git a/board/dhelectronics/common/dh_common.c b/board/dhelectronics/common/dh_common.c index 6a942909cc..71010803f5 100644 --- a/board/dhelectronics/common/dh_common.c +++ b/board/dhelectronics/common/dh_common.c @@ -11,6 +11,23 @@
+static int on_dh_som_serial_number(const char *name, const char *value, enum env_op op, + int flags) +{ + env_set("SN", value); + return 0; +} + +U_BOOT_ENV_CALLBACK(dh_som_serial_number, on_dh_som_serial_number); + +static int on_SN(const char *name, const char *value, enum env_op op, int flags) +{ + env_set("dh_som_serial_number", value); + return 0; +} + +U_BOOT_ENV_CALLBACK(SN, on_SN); + bool dh_mac_is_in_env(const char *env) { unsigned char enetaddr[6]; diff --git a/configs/dhsom.config b/configs/dhsom.config index fc76632630..380bedaa5d 100644 --- a/configs/dhsom.config +++ b/configs/dhsom.config @@ -49,6 +49,7 @@ CONFIG_CMD_UUID=y CONFIG_CMD_WGET=y CONFIG_CMD_XXD=y CONFIG_CRC32_VERIFY=y +CONFIG_ENV_CALLBACK_LIST_STATIC="dh_som_serial_number:dh_som_serial_number,SN:SN," CONFIG_HASH_VERIFY=y CONFIG_MD5SUM_VERIFY=y CONFIG_SHA1SUM_VERIFY=y
