[U-Boot] [PATCH] arm: socfpga: Move Stratix 10 SDRAM driver to DM
Convert Stratix 10 SDRAM driver to device model.
Get rid of call to socfpga_per_reset() and use reset framework.
SPL is changed from calling function in SDRAM driver directly to just probing UCLASS_RAM.
Move sdram_s10.h from arch to driver/ddr/altera directory.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/Kconfig | 4 +- arch/arm/dts/socfpga_stratix10.dtsi | 10 + arch/arm/dts/socfpga_stratix10_socdk.dts | 4 + arch/arm/mach-socfpga/Kconfig | 1 + arch/arm/mach-socfpga/spl_s10.c | 9 +- drivers/ddr/altera/Kconfig | 2 +- drivers/ddr/altera/sdram_s10.c | 246 ++++++++++++------ .../mach => drivers/ddr/altera}/sdram_s10.h | 4 - include/configs/socfpga_stratix10_socdk.h | 5 - 9 files changed, 195 insertions(+), 90 deletions(-) rename {arch/arm/mach-socfpga/include/mach => drivers/ddr/altera}/sdram_s10.h (97%)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 77a534f81fd..a2d4f7f4c25 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -821,14 +821,14 @@ config ARCH_SOCFPGA select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select OF_CONTROL - select RAM if TARGET_SOCFPGA_GEN5 + select RAM if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_STRATIX10 select SPL_DM_RESET if DM_RESET select SPL_DM_SERIAL select SPL_LIBCOMMON_SUPPORT select SPL_LIBGENERIC_SUPPORT select SPL_NAND_SUPPORT if SPL_NAND_DENALI select SPL_OF_CONTROL - select SPL_RAM if TARGET_SOCFPGA_GEN5 + select SPL_RAM if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_STRATIX10 select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 select SPL_SERIAL_SUPPORT select SPL_WATCHDOG_SUPPORT diff --git a/arch/arm/dts/socfpga_stratix10.dtsi b/arch/arm/dts/socfpga_stratix10.dtsi index ee93725d648..15d0f88f182 100644 --- a/arch/arm/dts/socfpga_stratix10.dtsi +++ b/arch/arm/dts/socfpga_stratix10.dtsi @@ -245,6 +245,16 @@ u-boot,dm-pre-reloc; };
+ sdr: sdr@f8000400 { + compatible = "altr,sdr-ctl-s10"; + reg = <0xf8000400 0x80>, + <0xf8010000 0x190>, + <0xf8011000 0x500>; + resets = <&rst DDRSCH_RESET>; + u-boot,dm-pre-reloc; + status = "disabled"; + }; + spi0: spi@ffda4000 { compatible = "snps,dw-apb-ssi"; #address-cells = <1>; diff --git a/arch/arm/dts/socfpga_stratix10_socdk.dts b/arch/arm/dts/socfpga_stratix10_socdk.dts index c59b77d8298..dcaca77ea69 100644 --- a/arch/arm/dts/socfpga_stratix10_socdk.dts +++ b/arch/arm/dts/socfpga_stratix10_socdk.dts @@ -87,6 +87,10 @@ smplsel = <0>; };
+&sdr { + status = "okay"; +}; + &uart0 { status = "okay"; }; diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 441b9d41291..9aa7f062932 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -38,6 +38,7 @@ config TARGET_SOCFPGA_GEN5
config TARGET_SOCFPGA_STRATIX10 bool + select ALTERA_SDRAM select ARMV8_MULTIENTRY select ARMV8_SET_SMPEN select ARMV8_PSCI diff --git a/arch/arm/mach-socfpga/spl_s10.c b/arch/arm/mach-socfpga/spl_s10.c index 393c9949d08..9f763b2dd4d 100644 --- a/arch/arm/mach-socfpga/spl_s10.c +++ b/arch/arm/mach-socfpga/spl_s10.c @@ -15,9 +15,9 @@ #include <asm/arch/firewall_s10.h> #include <asm/arch/mailbox_s10.h> #include <asm/arch/reset_manager.h> -#include <asm/arch/sdram_s10.h> #include <asm/arch/system_manager.h> #include <watchdog.h> +#include <dm/uclass.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -119,6 +119,7 @@ void board_init_f(ulong dummy) { const struct cm_config *cm_default_cfg = cm_get_default_config(); int ret; + struct udevice *dev;
#ifdef CONFIG_HW_WATCHDOG /* Ensure watchdog is paused when debugging is happening */ @@ -178,9 +179,9 @@ void board_init_f(ulong dummy) clrbits_le32(CCU_REG_ADDR(CCU_IOM_MPRT_ADMASK_MEM_RAM0), CCU_ADMASK_P_MASK | CCU_ADMASK_NS_MASK);
- debug("DDR: Initializing Hard Memory Controller\n"); - if (sdram_mmr_init_full(0)) { - puts("DDR: Initialization failed.\n"); + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); hang(); }
diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig index 7370d4133a6..a64e406355e 100644 --- a/drivers/ddr/altera/Kconfig +++ b/drivers/ddr/altera/Kconfig @@ -1,6 +1,6 @@ config ALTERA_SDRAM bool "SoCFPGA DDR SDRAM driver" depends on RAM - depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 + depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 || TARGET_SOCFPGA_STRATIX10 help Enable DDR SDRAM controller for the SoCFPGA devices. diff --git a/drivers/ddr/altera/sdram_s10.c b/drivers/ddr/altera/sdram_s10.c index e4d4a02ca2c..d2f32726094 100644 --- a/drivers/ddr/altera/sdram_s10.c +++ b/drivers/ddr/altera/sdram_s10.c @@ -5,17 +5,32 @@ */
#include <common.h> +#include <dm.h> #include <errno.h> #include <div64.h> #include <fdtdec.h> -#include <asm/io.h> +#include <ram.h> +#include <reset.h> +#include "sdram_s10.h" #include <wait_bit.h> #include <asm/arch/firewall_s10.h> -#include <asm/arch/sdram_s10.h> #include <asm/arch/system_manager.h> #include <asm/arch/reset_manager.h> +#include <asm/io.h> #include <linux/sizes.h>
+#ifdef CONFIG_SPL_BUILD + +struct altera_sdram_priv { + struct ram_info info; +}; + +struct altera_sdram_platdata { + void __iomem *hmc; + void __iomem *ddr_sch; + void __iomem *iomhc; +}; + DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_system_manager *sysmgr_regs = @@ -51,25 +66,26 @@ u32 ddr_config[] = { DDR_CONFIG(1, 4, 10, 17), };
-static u32 hmc_readl(u32 reg) +static u32 hmc_readl(struct altera_sdram_platdata *plat, u32 reg) { - return readl(((void __iomem *)SOCFPGA_HMC_MMR_IO48_ADDRESS + (reg))); + return readl(plat->iomhc + (reg)); }
-static u32 hmc_ecc_readl(u32 reg) +static u32 hmc_ecc_readl(struct altera_sdram_platdata *plat, u32 reg) { - return readl((void __iomem *)SOCFPGA_SDR_ADDRESS + (reg)); + return readl(plat->hmc + (reg)); }
-static u32 hmc_ecc_writel(u32 data, u32 reg) +static u32 hmc_ecc_writel(struct altera_sdram_platdata *plat, + u32 data, u32 reg) { - return writel(data, (void __iomem *)SOCFPGA_SDR_ADDRESS + (reg)); + return writel(data, plat->hmc + (reg)); }
-static u32 ddr_sch_writel(u32 data, u32 reg) +static u32 ddr_sch_writel(struct altera_sdram_platdata *plat, u32 data, + u32 reg) { - return writel(data, - (void __iomem *)SOCFPGA_SDR_SCHEDULER_ADDRESS + (reg)); + return writel(data, plat->ddr_sch + (reg)); }
int match_ddr_conf(u32 ddr_conf) @@ -83,37 +99,38 @@ int match_ddr_conf(u32 ddr_conf) return 0; }
-static int emif_clear(void) +static int emif_clear(struct altera_sdram_platdata *plat) { - hmc_ecc_writel(0, RSTHANDSHAKECTRL); + hmc_ecc_writel(plat, 0, RSTHANDSHAKECTRL);
- return wait_for_bit_le32((const void *)(SOCFPGA_SDR_ADDRESS + + return wait_for_bit_le32((const void *)(plat->hmc + RSTHANDSHAKESTAT), DDR_HMC_RSTHANDSHAKE_MASK, false, 1000, false); }
-static int emif_reset(void) +static int emif_reset(struct altera_sdram_platdata *plat) { u32 c2s, s2c, ret;
- c2s = hmc_ecc_readl(RSTHANDSHAKECTRL) & DDR_HMC_RSTHANDSHAKE_MASK; - s2c = hmc_ecc_readl(RSTHANDSHAKESTAT) & DDR_HMC_RSTHANDSHAKE_MASK; + c2s = hmc_ecc_readl(plat, RSTHANDSHAKECTRL) & DDR_HMC_RSTHANDSHAKE_MASK; + s2c = hmc_ecc_readl(plat, RSTHANDSHAKESTAT) & DDR_HMC_RSTHANDSHAKE_MASK;
debug("DDR: c2s=%08x s2c=%08x nr0=%08x nr1=%08x nr2=%08x dst=%08x\n", - c2s, s2c, hmc_readl(NIOSRESERVED0), hmc_readl(NIOSRESERVED1), - hmc_readl(NIOSRESERVED2), hmc_readl(DRAMSTS)); + c2s, s2c, hmc_readl(plat, NIOSRESERVED0), + hmc_readl(plat, NIOSRESERVED1), hmc_readl(plat, NIOSRESERVED2), + hmc_readl(plat, DRAMSTS));
- if (s2c && emif_clear()) { + if (s2c && emif_clear(plat)) { printf("DDR: emif_clear() failed\n"); return -1; }
debug("DDR: Triggerring emif reset\n"); - hmc_ecc_writel(DDR_HMC_CORE2SEQ_INT_REQ, RSTHANDSHAKECTRL); + hmc_ecc_writel(plat, DDR_HMC_CORE2SEQ_INT_REQ, RSTHANDSHAKECTRL);
/* if seq2core[3] = 0, we are good */ - ret = wait_for_bit_le32((const void *)(SOCFPGA_SDR_ADDRESS + + ret = wait_for_bit_le32((const void *)(plat->hmc + RSTHANDSHAKESTAT), DDR_HMC_SEQ2CORE_INT_RESP_MASK, false, 1000, false); @@ -122,7 +139,7 @@ static int emif_reset(void) return ret; }
- ret = emif_clear(); + ret = emif_clear(plat); if (ret) { printf("DDR: emif_clear() failed\n"); return ret; @@ -240,13 +257,37 @@ static void sdram_size_check(bd_t *bd) debug("DDR: SDRAM size check passed!\n"); }
+/** + * sdram_calculate_size() - Calculate SDRAM size + * + * Calculate SDRAM device size based on SDRAM controller parameters. + * Size is specified in bytes. + */ +static phys_size_t sdram_calculate_size(struct altera_sdram_platdata *plat) +{ + u32 dramaddrw = hmc_readl(plat, DRAMADDRW); + + phys_size_t size = 1 << (DRAMADDRW_CFG_CS_ADDR_WIDTH(dramaddrw) + + DRAMADDRW_CFG_BANK_GRP_ADDR_WIDTH(dramaddrw) + + DRAMADDRW_CFG_BANK_ADDR_WIDTH(dramaddrw) + + DRAMADDRW_CFG_ROW_ADDR_WIDTH(dramaddrw) + + DRAMADDRW_CFG_COL_ADDR_WIDTH(dramaddrw)); + + size *= (2 << (hmc_ecc_readl(plat, DDRIOCTRL) & + DDR_HMC_DDRIOCTRL_IOSIZE_MSK)); + + return size; +} + /** * sdram_mmr_init_full() - Function to initialize SDRAM MMR * * Initialize the SDRAM MMR. */ -int sdram_mmr_init_full(unsigned int unused) +static int sdram_mmr_init_full(struct udevice *dev) { + struct altera_sdram_platdata *plat = dev->platdata; + struct altera_sdram_priv *priv = dev_get_priv(dev); u32 update_value, io48_value, ddrioctl; u32 i; int ret; @@ -303,19 +344,16 @@ int sdram_mmr_init_full(unsigned int unused) return -1; }
- /* release DDR scheduler from reset */ - socfpga_per_reset(SOCFPGA_RESET(SDR), 0); - /* Try 3 times to do a calibration */ for (i = 0; i < 3; i++) { - ret = wait_for_bit_le32((const void *)(SOCFPGA_SDR_ADDRESS + + ret = wait_for_bit_le32((const void *)(plat->hmc + DDRCALSTAT), DDR_HMC_DDRCALSTAT_CAL_MSK, true, 1000, false); if (!ret) break;
- emif_reset(); + emif_reset(plat); }
if (ret) { @@ -324,16 +362,16 @@ int sdram_mmr_init_full(unsigned int unused) } debug("DDR: Calibration success\n");
- u32 ctrlcfg0 = hmc_readl(CTRLCFG0); - u32 ctrlcfg1 = hmc_readl(CTRLCFG1); - u32 dramaddrw = hmc_readl(DRAMADDRW); - u32 dramtim0 = hmc_readl(DRAMTIMING0); - u32 caltim0 = hmc_readl(CALTIMING0); - u32 caltim1 = hmc_readl(CALTIMING1); - u32 caltim2 = hmc_readl(CALTIMING2); - u32 caltim3 = hmc_readl(CALTIMING3); - u32 caltim4 = hmc_readl(CALTIMING4); - u32 caltim9 = hmc_readl(CALTIMING9); + u32 ctrlcfg0 = hmc_readl(plat, CTRLCFG0); + u32 ctrlcfg1 = hmc_readl(plat, CTRLCFG1); + u32 dramaddrw = hmc_readl(plat, DRAMADDRW); + u32 dramtim0 = hmc_readl(plat, DRAMTIMING0); + u32 caltim0 = hmc_readl(plat, CALTIMING0); + u32 caltim1 = hmc_readl(plat, CALTIMING1); + u32 caltim2 = hmc_readl(plat, CALTIMING2); + u32 caltim3 = hmc_readl(plat, CALTIMING3); + u32 caltim4 = hmc_readl(plat, CALTIMING4); + u32 caltim9 = hmc_readl(plat, CALTIMING9);
/* * Configure the DDR IO size [0xFFCFB008] @@ -349,12 +387,12 @@ int sdram_mmr_init_full(unsigned int unused) * bit[9:6] = Minor Release # * bit[14:10] = Major Release # */ - update_value = hmc_readl(NIOSRESERVED0); - hmc_ecc_writel(((update_value & 0xFF) >> 5), DDRIOCTRL); - ddrioctl = hmc_ecc_readl(DDRIOCTRL); + update_value = hmc_readl(plat, NIOSRESERVED0); + hmc_ecc_writel(plat, ((update_value & 0xFF) >> 5), DDRIOCTRL); + ddrioctl = hmc_ecc_readl(plat, DDRIOCTRL);
/* enable HPS interface to HMC */ - hmc_ecc_writel(DDR_HMC_HPSINTFCSEL_ENABLE_MASK, HPSINTFCSEL); + hmc_ecc_writel(plat, DDR_HMC_HPSINTFCSEL_ENABLE_MASK, HPSINTFCSEL);
/* Set the DDR Configuration */ io48_value = DDR_CONFIG(CTRLCFG1_CFG_ADDR_ORDER(ctrlcfg1), @@ -365,10 +403,10 @@ int sdram_mmr_init_full(unsigned int unused)
update_value = match_ddr_conf(io48_value); if (update_value) - ddr_sch_writel(update_value, DDR_SCH_DDRCONF); + ddr_sch_writel(plat, update_value, DDR_SCH_DDRCONF);
/* Configure HMC dramaddrw */ - hmc_ecc_writel(hmc_readl(DRAMADDRW), DRAMADDRWIDTH); + hmc_ecc_writel(plat, hmc_readl(plat, DRAMADDRW), DRAMADDRWIDTH);
/* * Configure DDR timing @@ -392,7 +430,7 @@ int sdram_mmr_init_full(unsigned int unused) CALTIMING0_CFG_ACT_TO_RDWR(caltim0) + CALTIMING4_CFG_PCH_TO_VALID(caltim4));
- ddr_sch_writel(((CALTIMING0_CFG_ACT_TO_ACT(caltim0) << + ddr_sch_writel(plat, ((CALTIMING0_CFG_ACT_TO_ACT(caltim0) << DDR_SCH_DDRTIMING_ACTTOACT_OFF) | (update_value << DDR_SCH_DDRTIMING_RDTOMISS_OFF) | (io48_value << DDR_SCH_DDRTIMING_WRTOMISS_OFF) | @@ -406,12 +444,12 @@ int sdram_mmr_init_full(unsigned int unused) DDR_SCH_DDRTIMING);
/* Configure DDR mode [precharge = 0] */ - ddr_sch_writel(((ddrioctl ? 0 : 1) << + ddr_sch_writel(plat, ((ddrioctl ? 0 : 1) << DDR_SCH_DDRMOD_BWRATIOEXTENDED_OFF), DDR_SCH_DDRMODE);
/* Configure the read latency */ - ddr_sch_writel((DRAMTIMING0_CFG_TCL(dramtim0) >> 1) + + ddr_sch_writel(plat, (DRAMTIMING0_CFG_TCL(dramtim0) >> 1) + DDR_READ_LATENCY_DELAY, DDR_SCH_READ_LATENCY);
@@ -419,7 +457,7 @@ int sdram_mmr_init_full(unsigned int unused) * Configuring timing values concerning activate commands * [FAWBANK alway 1 because always 4 bank DDR] */ - ddr_sch_writel(((CALTIMING0_CFG_ACT_TO_ACT_DB(caltim0) << + ddr_sch_writel(plat, ((CALTIMING0_CFG_ACT_TO_ACT_DB(caltim0) << DDR_SCH_ACTIVATE_RRD_OFF) | (CALTIMING9_CFG_4_ACT_TO_ACT(caltim9) << DDR_SCH_ACTIVATE_FAW_OFF) | @@ -431,7 +469,7 @@ int sdram_mmr_init_full(unsigned int unused) * Configuring timing values concerning device to device data bus * ownership change */ - ddr_sch_writel(((CALTIMING1_CFG_RD_TO_RD_DC(caltim1) << + ddr_sch_writel(plat, ((CALTIMING1_CFG_RD_TO_RD_DC(caltim1) << DDR_SCH_DEVTODEV_BUSRDTORD_OFF) | (CALTIMING1_CFG_RD_TO_WR_DC(caltim1) << DDR_SCH_DEVTODEV_BUSRDTOWR_OFF) | @@ -440,7 +478,7 @@ int sdram_mmr_init_full(unsigned int unused) DDR_SCH_DEVTODEV);
/* assigning the SDRAM size */ - unsigned long long size = sdram_calculate_size(); + unsigned long long size = sdram_calculate_size(plat); /* If the size is invalid, use default Config size */ if (size <= 0) hw_size = PHYS_SDRAM_1_SIZE; @@ -462,18 +500,17 @@ int sdram_mmr_init_full(unsigned int unused)
/* Enable or disable the SDRAM ECC */ if (CTRLCFG1_CFG_CTRL_EN_ECC(ctrlcfg1)) { - setbits_le32(SOCFPGA_SDR_ADDRESS + ECCCTRL1, + setbits_le32(plat->hmc + ECCCTRL1, (DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK | DDR_HMC_ECCCTL_CNT_RST_SET_MSK | DDR_HMC_ECCCTL_ECC_EN_SET_MSK)); - clrbits_le32(SOCFPGA_SDR_ADDRESS + ECCCTRL1, + clrbits_le32(plat->hmc + ECCCTRL1, (DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK | DDR_HMC_ECCCTL_CNT_RST_SET_MSK)); - setbits_le32(SOCFPGA_SDR_ADDRESS + ECCCTRL2, + setbits_le32(plat->hmc + ECCCTRL2, (DDR_HMC_ECCCTL2_RMW_EN_SET_MSK | DDR_HMC_ECCCTL2_AWB_EN_SET_MSK)); - writel(DDR_HMC_ERRINTEN_INTMASK, - SOCFPGA_SDR_ADDRESS + ERRINTENS); + hmc_ecc_writel(plat, DDR_HMC_ERRINTEN_INTMASK, ERRINTENS);
/* Enable non-secure writes to HMC Adapter for SDRAM ECC */ writel(FW_HMC_ADAPTOR_MPU_MASK, FW_HMC_ADAPTOR_REG_ADDR); @@ -482,39 +519,100 @@ int sdram_mmr_init_full(unsigned int unused) if (!cpu_has_been_warmreset()) sdram_init_ecc_bits(&bd); } else { - clrbits_le32(SOCFPGA_SDR_ADDRESS + ECCCTRL1, + clrbits_le32(plat->hmc + ECCCTRL1, (DDR_HMC_ECCCTL_AWB_CNT_RST_SET_MSK | DDR_HMC_ECCCTL_CNT_RST_SET_MSK | DDR_HMC_ECCCTL_ECC_EN_SET_MSK)); - clrbits_le32(SOCFPGA_SDR_ADDRESS + ECCCTRL2, + clrbits_le32(plat->hmc + ECCCTRL2, (DDR_HMC_ECCCTL2_RMW_EN_SET_MSK | DDR_HMC_ECCCTL2_AWB_EN_SET_MSK)); }
sdram_size_check(&bd);
+ priv->info.base = bd.bi_dram[0].start; + priv->info.size = gd->ram_size; + debug("DDR: HMC init success\n"); return 0; }
-/** - * sdram_calculate_size() - Calculate SDRAM size - * - * Calculate SDRAM device size based on SDRAM controller parameters. - * Size is specified in bytes. - */ -phys_size_t sdram_calculate_size(void) +static int altera_sdram_ofdata_to_platdata(struct udevice *dev) { - u32 dramaddrw = hmc_readl(DRAMADDRW); + struct altera_sdram_platdata *plat = dev->platdata; + fdt_addr_t addr;
- phys_size_t size = 1 << (DRAMADDRW_CFG_CS_ADDR_WIDTH(dramaddrw) + - DRAMADDRW_CFG_BANK_GRP_ADDR_WIDTH(dramaddrw) + - DRAMADDRW_CFG_BANK_ADDR_WIDTH(dramaddrw) + - DRAMADDRW_CFG_ROW_ADDR_WIDTH(dramaddrw) + - DRAMADDRW_CFG_COL_ADDR_WIDTH(dramaddrw)); + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->ddr_sch = (void __iomem *)addr;
- size *= (2 << (hmc_ecc_readl(DDRIOCTRL) & - DDR_HMC_DDRIOCTRL_IOSIZE_MSK)); + addr = dev_read_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->iomhc = (void __iomem *)addr;
- return size; + addr = dev_read_addr_index(dev, 2); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->hmc = (void __iomem *)addr; + + return 0; +} + +static int altera_sdram_probe(struct udevice *dev) +{ + int ret; + struct reset_ctl_bulk resets; + + ret = reset_get_bulk(dev, &resets); + if (ret) { + dev_err(dev, "Can't get reset: %d\n", ret); + return -ENODEV; + } + reset_deassert_bulk(&resets); + + if (sdram_mmr_init_full(dev) != 0) { + puts("SDRAM init failed.\n"); + goto failed; + } + + return 0; + +failed: + reset_release_bulk(&resets); + return -ENODEV; } + +static int altera_sdram_get_info(struct udevice *dev, + struct ram_info *info) +{ + struct altera_sdram_priv *priv = dev_get_priv(dev); + + info->base = priv->info.base; + info->size = priv->info.size; + + return 0; +} + +static struct ram_ops altera_sdram_ops = { + .get_info = altera_sdram_get_info, +}; + +static const struct udevice_id altera_sdram_ids[] = { + { .compatible = "altr,sdr-ctl-s10" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(altera_sdram) = { + .name = "altr_sdr_ctl", + .id = UCLASS_RAM, + .of_match = altera_sdram_ids, + .ops = &altera_sdram_ops, + .ofdata_to_platdata = altera_sdram_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sdram_platdata), + .probe = altera_sdram_probe, + .priv_auto_alloc_size = sizeof(struct altera_sdram_priv), +}; + +#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/mach-socfpga/include/mach/sdram_s10.h b/drivers/ddr/altera/sdram_s10.h similarity index 97% rename from arch/arm/mach-socfpga/include/mach/sdram_s10.h rename to drivers/ddr/altera/sdram_s10.h index f39206ca1ee..096c06cba21 100644 --- a/arch/arm/mach-socfpga/include/mach/sdram_s10.h +++ b/drivers/ddr/altera/sdram_s10.h @@ -7,10 +7,6 @@ #ifndef _SDRAM_S10_H_ #define _SDRAM_S10_H_
-phys_size_t sdram_calculate_size(void); -int sdram_mmr_init_full(unsigned int sdr_phy_reg); -int sdram_calibration_full(void); - #define DDR_TWR 15 #define DDR_READ_LATENCY_DELAY 40 #define DDR_ACTIVATE_FAWBANK 0x1 diff --git a/include/configs/socfpga_stratix10_socdk.h b/include/configs/socfpga_stratix10_socdk.h index c68a73ceaeb..8e7c808ce7f 100644 --- a/include/configs/socfpga_stratix10_socdk.h +++ b/include/configs/socfpga_stratix10_socdk.h @@ -139,11 +139,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_SYS_MEMTEST_START 0 #define CONFIG_SYS_MEMTEST_END PHYS_SDRAM_1_SIZE - 0x200000
-/* - * SDRAM controller - */ -#define CONFIG_ALTERA_SDRAM - /* * Serial / UART configurations */
Nice to see that :-)
sdr: sdr@f8000400 {
<0xf8010000 0x190>,
<0xf8011000 0x500>;
Why is this optional? The SPL won't work without that any more by default, or would it? I would have thought it's enabled by default?
+&sdr {
status = "okay";
if (ret) {
void __iomem *hmc;
u32 data, u32 reg)
u32 reg)
return writel(data,
s2c = hmc_ecc_readl(plat, RSTHANDSHAKESTAT) & DDR_HMC_RSTHANDSHAKE_MASK; debug("DDR: c2s=%08x s2c=%08x nr0=%08x nr1=%08x nr2=%08x dst=%08x\n",
if (s2c && emif_clear(plat)) { printf("DDR: emif_clear() failed\n"); return -1; } debug("DDR: Triggerring emif reset\n");
hmc_ecc_writel(plat, DDR_HMC_CORE2SEQ_INT_REQ, RSTHANDSHAKECTRL); /* if seq2core[3] = 0, we are good */
ret = emif_clear();
- sdram_calculate_size() - Calculate SDRAM size
- Calculate SDRAM device size based on SDRAM controller parameters.
- Size is specified in bytes.
return size;
- sdram_mmr_init_full() - Function to initialize SDRAM MMR
- Initialize the SDRAM MMR.
emif_reset();
emif_reset(plat); } if (ret) {
u32 caltim9 = hmc_readl(plat, CALTIMING9); /* * Configure the DDR IO size [0xFFCFB008]
ddrioctl = hmc_ecc_readl(plat, DDRIOCTRL); /* enable HPS interface to HMC */
hmc_ecc_writel(plat, DDR_HMC_HPSINTFCSEL_ENABLE_MASK, HPSINTFCSEL); /* Set the DDR Configuration */ io48_value = DDR_CONFIG(CTRLCFG1_CFG_ADDR_ORDER(ctrlcfg1),
ddr_sch_writel(plat, update_value, DDR_SCH_DDRCONF); /* Configure HMC dramaddrw */
hmc_ecc_writel(plat, hmc_readl(plat, DRAMADDRW), DRAMADDRWIDTH); /* * Configure DDR timing
ddr_sch_writel(plat, ((ddrioctl ? 0 : 1) << DDR_SCH_DDRMOD_BWRATIOEXTENDED_OFF), DDR_SCH_DDRMODE); /* Configure the read latency */
hmc_ecc_writel(plat, DDR_HMC_ERRINTEN_INTMASK, ERRINTENS); /* Enable non-secure writes to HMC Adapter for SDRAM ECC */ writel(FW_HMC_ADAPTOR_MPU_MASK, FW_HMC_ADAPTOR_REG_ADDR);
clrbits_le32(plat->hmc + ECCCTRL2, (DDR_HMC_ECCCTL2_RMW_EN_SET_MSK | DDR_HMC_ECCCTL2_AWB_EN_SET_MSK)); } sdram_size_check(&bd);
fdt_addr_t addr;
return -EINVAL;
return -EINVAL;
return size;
return -EINVAL;
int ret;
if (ret) {
return -ENODEV;
goto failed;
+failed:
return -ENODEV;
{ /* sentinel */ }
.id = UCLASS_RAM,
- SDRAM controller
- Serial / UART configurations
2.19.0
On Wed, Mar 27, 2019 at 7:34 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
sdr: sdr@f8000400 {
<0xf8010000 0x190>,
<0xf8011000 0x500>;
Customer can use either SDRAM controller in HPS or in FPGA. We don't need this driver if SDRAM controller is in FPGA. All initialization process will handled by HW. I think we just need a very simple sdram driver for sdram controller in FPGA, just to setup get_info().
Regards Ley Foon
sdr: sdr@f8000400 {
<0xf8010000 0x190>,
<0xf8011000 0x500>;
Fair enough. But how often will this be used? Would it make sense to use the internal SDRAM controller by default and let the customers with a controller in the FPGA override it or is this a common use case?
On Thu, Mar 28, 2019 at 5:24 PM Simon Goldschmidt simon.k.r.goldschmidt@gmail.com wrote:
sdr: sdr@f8000400 {
<0xf8010000 0x190>,
<0xf8011000 0x500>;
Yes, will make HPS SDRAM as default and customer needs to disable it if they use FPGA SDRAM.
Thanks.
Regard Ley Foon
Ley Foon Tan
Ley Foon Tan
Simon Goldschmidt
