[PATCH] mtd: nand: pxa3xx: set mtd->dev
Currently the pxa3xx driver does not set the udevice in the mtd_info struct and this prevents the mtd from parsing the partitions via DTS like for SPI-NOR.
So simply set the mtd->dev to the driver udevice.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- drivers/mtd/nand/raw/pxa3xx_nand.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/nand/raw/pxa3xx_nand.c b/drivers/mtd/nand/raw/pxa3xx_nand.c index 8ff58a7038..eb739bb3b9 100644 --- a/drivers/mtd/nand/raw/pxa3xx_nand.c +++ b/drivers/mtd/nand/raw/pxa3xx_nand.c @@ -1913,6 +1913,7 @@ static int pxa3xx_nand_probe(struct udevice *dev) * user's mtd partitions configuration would get broken. */ mtd->name = "pxa3xx_nand-0"; + mtd->dev = dev; info->cs = cs; ret = pxa3xx_nand_scan(mtd); if (ret) {
Thanks, Stefan
info->cs = cs; ret = pxa3xx_nand_scan(mtd); if (ret) {mtd->dev = dev;
Viele Grüße, Stefan Roese
Signed-off-by: Robert Marko robert.marko@sartura.hr Reviewed-by: Stefan Roese sr@denx.de
Robert Marko
Stefan Roese
