[U-Boot] [PATCH v2 00/29] Kconfig: Move console options to Kconfig
This series moves a number of console-related CONFIG options to Kconfig. Those that are not currently used are removed.
A few unused video drivers are also removed and there are a few minor adjustments to improve the code. But mostly this follows the output of the moveconfig tool.
It is tested with buildman -K to make sure no CONFIGs change overall, and also for building.
Changes in v2: - Drop the changes to Kconfig defaults - Change CONFIG_PRE_CON_BUF_SZ default to 4096 - Change CONFIG_PRE_CON_BUF_SZ to 'int' type - Drop the depend clause on the CONFIG_PRE_CON_BUF_SZ default - Move CONFIG_PRE_CON_BUF_ADDR default to common/Kconfig - Make CONSOLE_MUX default y if DM_VIDEO || VIDEO || LCD - Make CONFIG_SYS_CONSOLE_INFO_QUIET the default if !CONFIG_MUX - Add new patch to convert CONFIG_USB_KEYBOARD to Kconfig - Make CONFIG_SYS_STDIO_DEREGISTER the default if USB_KEYBOARD - Drop Kconfig changes
Simon Glass (29): Remove some merge markers Convert SILENT_CONSOLE options to Kconfig Convert CONSOLE_PRE_CONSOLE_BUFFER options to Kconfig Convert CONFIG_SYS_CONSOLE_IS_IN_ENV et al to Kconfig config: Drop CONFIG_CONSOLE config: Drop CONFIG_CONSOLE_DEV Convert CONFIG_VIDEO to Kconfig Convert CONFIG_CFB_CONSOLE to Kconfig Convert CONFIG_CFB_CONSOLE_ANSI to Kconfig Convert CONFIG_VIDEO_CT69000 to Kconfig Convert CONFIG_SYS_CONSOLE_BG_COL et al to Kconfig video: Drop the smiLynxEM driver video: Drop the imx25lcdc driver video: Drop the s3c-fb driver video: Drop the sed13806 driver Convert CONFIG_VGA_AS_SINGLE_DEVICE to Kconfig video: Drop CONFIG_VIDEO_HW_CURSOR Convert CONFIG_VIDEO_SW_CURSOR to Kconfig video: Drop CONFIG_VIDEO_SW_CURSOR Convert CONFIG_CONSOLE_EXTRA_INFO to Kconfig video: Move video_get_info_str() prototype to a header file video: Drop CONFIG_CONSOLE_INFO_QUIET Convert CONFIG_LCD to Kconfig Convert CONFIG_CONSOLE_SCROLL_LINES to Kconfig Convert CONFIG_SYS_CONSOLE_ENV_OVERWRITE to Kconfig Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to Kconfig Convert CONFIG_SYS_CONSOLE_INFO_QUIET to Kconfig Convert CONFIG_USB_KEYBOARD to Kconfig Convert CONFIG_SYS_STDIO_DEREGISTER to Kconfig
README | 131 ---- board/liebherr/lwmon5/lwmon5.c | 1 + board/mosaixtech/icon/icon.c | 1 + board/mpl/common/common_util.c | 1 + board/sunxi/Kconfig | 3 + board/tqc/tqm5200/tqm5200.c | 1 + common/Kconfig | 143 ++++ common/console.c | 6 +- common/stdio.c | 6 +- common/usb_kbd.c | 2 +- configs/A10-OLinuXino-Lime_defconfig | 2 + configs/A10s-OLinuXino-M_defconfig | 2 + configs/A13-OLinuXinoM_defconfig | 2 + configs/A13-OLinuXino_defconfig | 2 + configs/A20-OLinuXino-Lime2_defconfig | 2 + configs/A20-OLinuXino-Lime_defconfig | 2 + configs/A20-OLinuXino_MICRO_defconfig | 2 + configs/A20-Olimex-SOM-EVB_defconfig | 2 + configs/A33-OLinuXino_defconfig | 2 + configs/Ainol_AW1_defconfig | 2 + configs/Ampe_A76_defconfig | 2 + configs/Auxtek-T003_defconfig | 2 + configs/Auxtek-T004_defconfig | 2 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/Bananapi_defconfig | 2 + configs/Bananapro_defconfig | 2 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_defconfig | 2 + configs/CSQ_CS908_defconfig | 2 + configs/Chuwi_V7_CW0825_defconfig | 2 + configs/Colombus_defconfig | 2 + configs/Cubieboard2_defconfig | 2 + configs/Cubieboard_defconfig | 2 + configs/Cubietruck_defconfig | 2 + configs/Cubietruck_plus_defconfig | 2 + configs/Cyrus_P5020_defconfig | 3 + configs/Cyrus_P5040_defconfig | 3 + configs/Empire_electronix_d709_defconfig | 2 + configs/Empire_electronix_m712_defconfig | 2 + configs/Hummingbird_A31_defconfig | 2 + configs/Hyundai_A7HD_defconfig | 2 + configs/Itead_Ibox_A20_defconfig | 2 + configs/Lamobo_R1_defconfig | 2 + configs/Linksprite_pcDuino3_Nano_defconfig | 2 + configs/Linksprite_pcDuino3_defconfig | 2 + configs/Linksprite_pcDuino_defconfig | 2 + configs/MIP405T_defconfig | 7 + configs/MIP405_defconfig | 8 + configs/MK808C_defconfig | 2 + configs/MPC8536DS_36BIT_defconfig | 2 + configs/MPC8536DS_SDCARD_defconfig | 2 + configs/MPC8536DS_SPIFLASH_defconfig | 2 + configs/MPC8536DS_defconfig | 2 + configs/MPC8544DS_defconfig | 2 + configs/MPC8572DS_36BIT_defconfig | 2 + configs/MPC8572DS_defconfig | 2 + configs/MPC8610HPCD_defconfig | 3 + configs/MPC8641HPCN_36BIT_defconfig | 3 + configs/MPC8641HPCN_defconfig | 3 + configs/MSI_Primo73_defconfig | 2 + configs/MSI_Primo81_defconfig | 2 + configs/Marsboard_A10_defconfig | 2 + configs/Mele_A1000G_quad_defconfig | 2 + configs/Mele_A1000_defconfig | 2 + configs/Mele_I7_defconfig | 2 + configs/Mele_M3_defconfig | 2 + configs/Mele_M5_defconfig | 2 + configs/Mele_M9_defconfig | 2 + configs/Merrii_A80_Optimus_defconfig | 2 + configs/Mini-X_defconfig | 2 + configs/MiniFAP_defconfig | 4 + configs/Orangepi_defconfig | 2 + configs/Orangepi_mini_defconfig | 2 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + .../P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/PATI_defconfig | 1 + configs/PIP405_defconfig | 8 + configs/PMC440_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 2 + configs/Sinlinx_SinA33_defconfig | 2 + configs/Sinovoip_BPI_M2_defconfig | 2 + configs/Sinovoip_BPI_M3_defconfig | 2 + configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 4 + configs/T1024QDS_DDR4_defconfig | 4 + configs/T1024QDS_NAND_defconfig | 4 + configs/T1024QDS_SDCARD_defconfig | 4 + configs/T1024QDS_SECURE_BOOT_defconfig | 4 + configs/T1024QDS_SPIFLASH_defconfig | 4 + configs/T1024QDS_defconfig | 4 + configs/T1024RDB_NAND_defconfig | 2 + configs/T1024RDB_SDCARD_defconfig | 2 + configs/T1024RDB_SECURE_BOOT_defconfig | 2 + configs/T1024RDB_SPIFLASH_defconfig | 2 + configs/T1024RDB_defconfig | 2 + configs/T1040D4RDB_NAND_defconfig | 2 + configs/T1040D4RDB_SDCARD_defconfig | 2 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 2 + configs/T1040D4RDB_SPIFLASH_defconfig | 2 + configs/T1040D4RDB_defconfig | 2 + configs/T1040QDS_DDR4_defconfig | 4 + configs/T1040QDS_SECURE_BOOT_defconfig | 4 + configs/T1040QDS_defconfig | 4 + configs/T1040RDB_NAND_defconfig | 2 + configs/T1040RDB_SDCARD_defconfig | 2 + configs/T1040RDB_SECURE_BOOT_defconfig | 2 + configs/T1040RDB_SPIFLASH_defconfig | 2 + configs/T1040RDB_defconfig | 2 + configs/T1042D4RDB_NAND_defconfig | 5 + configs/T1042D4RDB_SDCARD_defconfig | 5 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 5 + configs/T1042D4RDB_SPIFLASH_defconfig | 5 + configs/T1042D4RDB_defconfig | 5 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 5 + configs/T1042RDB_PI_NAND_defconfig | 5 + configs/T1042RDB_PI_SDCARD_defconfig | 5 + configs/T1042RDB_PI_SPIFLASH_defconfig | 5 + configs/T1042RDB_PI_defconfig | 5 + configs/T1042RDB_SECURE_BOOT_defconfig | 2 + configs/T1042RDB_defconfig | 2 + configs/TQM5200_B_HIGHBOOT_defconfig | 4 + configs/TQM5200_B_defconfig | 4 + configs/TQM5200_STK100_defconfig | 4 + configs/TQM5200_defconfig | 4 + configs/TQM823L_LCD_defconfig | 3 +- configs/TTTech_defconfig | 3 +- configs/UTOO_P66_defconfig | 2 + configs/VCMA9_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 2 + configs/Wits_Pro_A20_DKT_defconfig | 2 + configs/Wobo_i5_defconfig | 2 + configs/Yones_Toptech_BD1078_defconfig | 2 + configs/Yones_Toptech_BS1078_V2_defconfig | 2 + configs/a3m071_defconfig | 1 + configs/a4m072_defconfig | 1 + configs/a4m2k_defconfig | 1 + configs/apalis_t30_defconfig | 2 + configs/aristainetos2_defconfig | 4 + configs/aristainetos2b_defconfig | 4 + configs/aristainetos_defconfig | 4 + configs/arndale_defconfig | 3 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 2 + configs/at91sam9261ek_dataflash_cs3_defconfig | 2 + configs/at91sam9261ek_nandflash_defconfig | 2 + configs/at91sam9263ek_dataflash_cs0_defconfig | 2 + configs/at91sam9263ek_dataflash_defconfig | 2 + configs/at91sam9263ek_nandflash_defconfig | 2 + configs/at91sam9263ek_norflash_boot_defconfig | 2 + configs/at91sam9263ek_norflash_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 + configs/at91sam9g10ek_nandflash_defconfig | 2 + configs/at91sam9m10g45ek_mmc_defconfig | 2 + configs/at91sam9m10g45ek_nandflash_defconfig | 2 + configs/at91sam9n12ek_mmc_defconfig | 2 + configs/at91sam9n12ek_nandflash_defconfig | 2 + configs/at91sam9n12ek_spiflash_defconfig | 2 + configs/at91sam9rlek_dataflash_defconfig | 2 + configs/at91sam9rlek_mmc_defconfig | 2 + configs/at91sam9rlek_nandflash_defconfig | 2 + configs/at91sam9x5ek_dataflash_defconfig | 2 + configs/at91sam9x5ek_mmc_defconfig | 2 + configs/at91sam9x5ek_nandflash_defconfig | 2 + configs/at91sam9x5ek_spiflash_defconfig | 2 + configs/ba10_tv_box_defconfig | 2 + configs/bayleybay_defconfig | 6 + configs/bct-brettl2_defconfig | 1 + configs/beaver_defconfig | 2 + configs/bf518f-ezbrd_defconfig | 1 + configs/bf526-ezbrd_defconfig | 1 + configs/bf527-ad7160-eval_defconfig | 1 + configs/bf527-ezkit-v2_defconfig | 1 + configs/bf527-ezkit_defconfig | 1 + configs/bf527-sdp_defconfig | 1 + configs/bf533-ezkit_defconfig | 1 + configs/bf533-stamp_defconfig | 1 + configs/bf537-pnav_defconfig | 1 + configs/bf537-stamp_defconfig | 1 + configs/bf538f-ezkit_defconfig | 1 + configs/bf548-ezkit_defconfig | 1 + configs/bf561-acvilon_defconfig | 1 + configs/bf561-ezkit_defconfig | 1 + configs/br4_defconfig | 1 + configs/brppt1_mmc_defconfig | 4 + configs/brppt1_nand_defconfig | 4 + configs/brppt1_spi_defconfig | 4 + configs/brxre1_defconfig | 4 + configs/cardhu_defconfig | 2 + configs/cei-tk1-som_defconfig | 2 + configs/cgtqmx6eval_defconfig | 5 + configs/charon_defconfig | 4 + configs/chromebook_jerry_defconfig | 3 + configs/chromebook_link_defconfig | 6 + configs/chromebook_samus_defconfig | 4 + configs/chromebox_panther_defconfig | 6 + configs/cm-bf527_defconfig | 1 + configs/cm-bf533_defconfig | 1 + configs/cm-bf537e_defconfig | 1 + configs/cm-bf537u_defconfig | 1 + configs/cm-bf548_defconfig | 2 + configs/cm-bf561_defconfig | 1 + configs/cm5200_defconfig | 1 + configs/cm_fx6_defconfig | 3 + configs/cm_t3517_defconfig | 2 + configs/cm_t35_defconfig | 2 + configs/colibri_imx7_defconfig | 3 + configs/colibri_t20_defconfig | 2 + configs/colibri_t30_defconfig | 2 + configs/colorfly_e708_q1_defconfig | 2 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 6 + configs/conga-qeval20-qa3-e3845_defconfig | 6 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 3 + configs/controlcenterd_36BIT_SDCARD_defconfig | 3 + .../controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 6 + configs/cougarcanyon2_defconfig | 4 + configs/crownbay_defconfig | 6 + configs/d2net_v2_defconfig | 2 + configs/dalmore_defconfig | 2 + configs/dfi-bt700-q7x-151_defconfig | 6 + configs/difrnce_dit4350_defconfig | 2 + configs/digsy_mtc_RAMBOOT_defconfig | 3 + configs/digsy_mtc_defconfig | 3 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 3 + configs/digsy_mtc_rev5_defconfig | 3 + configs/dms-ba16-1g_defconfig | 5 + configs/dms-ba16_defconfig | 5 + configs/dns325_defconfig | 2 + configs/dserve_dsrv9703c_defconfig | 2 + configs/duovero_defconfig | 1 + configs/e2220-1170_defconfig | 2 + configs/ea20_defconfig | 5 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/efi-x86_defconfig | 4 + configs/espresso7420_defconfig | 3 + configs/evb-rk3288_defconfig | 3 + configs/fennec-rk3288_defconfig | 3 + configs/firefly-rk3288_defconfig | 3 + configs/fo300_defconfig | 4 + configs/ga10h_v1_1_defconfig | 2 + configs/galileo_defconfig | 4 + configs/ge_b450v3_defconfig | 2 + configs/ge_b650v3_defconfig | 2 + configs/ge_b850v3_defconfig | 2 + configs/goflexhome_defconfig | 2 + configs/gt90h_v4_defconfig | 2 + configs/gurnard_defconfig | 1 + configs/gwventana_defconfig | 4 + configs/h2200_defconfig | 1 + configs/h8_homlet_v2_defconfig | 2 + configs/haleakala_defconfig | 1 + configs/harmony_defconfig | 2 + configs/i12-tvbox_defconfig | 2 + configs/iNet_3F_defconfig | 2 + configs/iNet_3W_defconfig | 2 + configs/iNet_86VS_defconfig | 2 + configs/iNet_D978_rev2_defconfig | 2 + configs/ibf-dsp561_defconfig | 1 + configs/icnova-a20-swac_defconfig | 2 + configs/icon_defconfig | 4 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0030_nand_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 3 + configs/inet1_defconfig | 2 + configs/inet86dz_defconfig | 2 + configs/inet97fv2_defconfig | 2 + configs/inet98v_rev2_defconfig | 2 + configs/inet9f_rev03_defconfig | 2 + configs/inet_q972_defconfig | 2 + configs/inetspace_v2_defconfig | 2 + configs/io64_defconfig | 1 + configs/ip04_defconfig | 1 + configs/ipek01_defconfig | 4 + configs/jesurun_q5_defconfig | 2 + configs/jetson-tk1_defconfig | 2 + configs/kc1_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 4 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 4 + configs/ls1021aqds_nand_defconfig | 4 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 4 + configs/ls1021aqds_nor_defconfig | 4 + configs/ls1021aqds_nor_lpuart_defconfig | 4 + configs/ls1021aqds_qspi_defconfig | 4 + configs/ls1021aqds_sdcard_ifc_defconfig | 4 + configs/ls1021aqds_sdcard_qspi_defconfig | 4 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 4 + configs/ls1021atwr_nor_defconfig | 4 + configs/ls1021atwr_nor_lpuart_defconfig | 4 + configs/ls1021atwr_qspi_defconfig | 4 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 4 + configs/ls1021atwr_sdcard_ifc_defconfig | 4 + configs/ls1021atwr_sdcard_qspi_defconfig | 4 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/lwmon5_defconfig | 5 + configs/m28evk_defconfig | 3 + configs/m53evk_defconfig | 3 + configs/makalu_defconfig | 1 + configs/marsboard_defconfig | 4 + configs/mcx_defconfig | 3 + configs/medcom-wide_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/miniarm-rk3288_defconfig | 3 + configs/minnowmax_defconfig | 6 + configs/mixtile_loftq_defconfig | 2 + configs/mk802_a10s_defconfig | 2 + configs/mk802_defconfig | 2 + configs/mk802ii_defconfig | 2 + configs/mt_ventoux_defconfig | 3 + configs/mx23evk_defconfig | 3 + configs/mx28evk_auart_console_defconfig | 3 + configs/mx28evk_defconfig | 3 + configs/mx28evk_nand_defconfig | 3 + configs/mx28evk_spi_defconfig | 3 + configs/mx51evk_defconfig | 4 + configs/mx53loco_defconfig | 4 + configs/mx6cuboxi_defconfig | 4 + configs/mx6dlsabreauto_defconfig | 4 + configs/mx6dlsabresd_defconfig | 4 + configs/mx6qpsabreauto_defconfig | 4 + configs/mx6qsabreauto_defconfig | 4 + configs/mx6qsabrelite_defconfig | 5 + configs/mx6qsabresd_defconfig | 4 + configs/mx6sabresd_spl_defconfig | 4 + configs/mx6sxsabresd_defconfig | 3 + configs/mx6sxsabresd_spl_defconfig | 3 + configs/mx6ul_14x14_evk_defconfig | 9 +- configs/mx6ul_9x9_evk_defconfig | 9 +- configs/mx7dsabresd_defconfig | 3 + configs/mx7dsabresd_secure_defconfig | 3 + configs/nanopi_neo_defconfig | 2 + configs/net2big_v2_defconfig | 2 + configs/netspace_lite_v2_defconfig | 2 + configs/netspace_max_v2_defconfig | 2 + configs/netspace_mini_v2_defconfig | 2 + configs/netspace_v2_defconfig | 2 + configs/nitrogen6dl2g_defconfig | 5 + configs/nitrogen6dl_defconfig | 5 + configs/nitrogen6q2g_defconfig | 5 + configs/nitrogen6q_defconfig | 5 + configs/nitrogen6s1g_defconfig | 5 + configs/nitrogen6s_defconfig | 5 + configs/nokia_rx51_defconfig | 4 + configs/novena_defconfig | 4 + configs/nyan-big_defconfig | 1 + configs/odroid-xu3_defconfig | 3 + configs/odroid_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/orangepi_2_defconfig | 2 + configs/orangepi_lite_defconfig | 2 + configs/orangepi_one_defconfig | 2 + configs/orangepi_pc_defconfig | 2 + configs/orangepi_pc_plus_defconfig | 2 + configs/orangepi_plus2e_defconfig | 2 + configs/orangepi_plus_defconfig | 2 + configs/origen_defconfig | 1 + configs/p2371-0000_defconfig | 2 + configs/p2371-2180_defconfig | 2 + configs/p2571_defconfig | 2 + configs/p2771-0000-000_defconfig | 2 + configs/p2771-0000-500_defconfig | 2 + configs/parrot_r16_defconfig | 2 + configs/paz00_defconfig | 2 + configs/pdm360ng_defconfig | 3 + configs/peach-pi_defconfig | 3 + configs/peach-pit_defconfig | 3 + configs/picosam9g45_defconfig | 2 + configs/pine64_plus_defconfig | 2 + configs/plutux_defconfig | 2 + configs/pm9261_defconfig | 2 + configs/pm9263_defconfig | 2 + configs/polaroid_mid2407pxe03_defconfig | 2 + configs/polaroid_mid2809pxe04_defconfig | 2 + configs/popmetal-rk3288_defconfig | 3 + configs/pov_protab2_ips9_defconfig | 2 + configs/pr1_defconfig | 1 + configs/pxm2_defconfig | 5 + configs/q8_a13_tablet_defconfig | 2 + configs/q8_a23_tablet_800x480_defconfig | 2 + configs/q8_a33_tablet_1024x600_defconfig | 2 + configs/q8_a33_tablet_800x480_defconfig | 2 + configs/qemu-x86_defconfig | 6 + configs/qemu-x86_efi_payload32_defconfig | 6 + configs/qemu-x86_efi_payload64_defconfig | 6 + configs/r7-tv-dongle_defconfig | 2 + configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/riotboard_defconfig | 4 + configs/rock2_defconfig | 3 + configs/rpi_2_defconfig | 3 + configs/rpi_3_32b_defconfig | 3 + configs/rpi_3_defconfig | 3 + configs/rpi_defconfig | 3 + configs/rut_defconfig | 5 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 2 + configs/sama5d3xek_nandflash_defconfig | 2 + configs/sama5d3xek_spiflash_defconfig | 2 + configs/sama5d4ek_mmc_defconfig | 2 + configs/sama5d4ek_nandflash_defconfig | 2 + configs/sama5d4ek_spiflash_defconfig | 2 + configs/sandbox_defconfig | 2 + configs/sandbox_noblk_defconfig | 2 + configs/sandbox_spl_defconfig | 2 + configs/sansa_fuze_plus_defconfig | 3 + configs/seaboard_defconfig | 3 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/smdk2410_defconfig | 1 + configs/smdk5250_defconfig | 3 + configs/smdk5420_defconfig | 3 + configs/sniper_defconfig | 1 + configs/snow_defconfig | 3 + configs/socfpga_arria5_defconfig | 3 + configs/socfpga_cyclone5_defconfig | 3 + configs/socfpga_de0_nano_soc_defconfig | 3 + configs/socfpga_is1_defconfig | 3 + configs/socfpga_mcvevk_defconfig | 3 + configs/socfpga_sockit_defconfig | 3 + configs/socfpga_socrates_defconfig | 3 + configs/socfpga_sr1500_defconfig | 3 + configs/socfpga_vining_fpga_defconfig | 3 + configs/socrates_defconfig | 4 + configs/som-db5800-som-6867_defconfig | 6 + configs/spring_defconfig | 3 + configs/sunxi_Gemei_G9_defconfig | 2 + configs/tbs2910_defconfig | 7 + configs/tcm-bf518_defconfig | 1 + configs/tcm-bf537_defconfig | 1 + configs/tec-ng_defconfig | 2 + configs/tec_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 6 + configs/theadorable_debug_defconfig | 3 + configs/theadorable_defconfig | 3 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/trimslice_defconfig | 2 + configs/venice2_defconfig | 2 + configs/ventana_defconfig | 3 + configs/wandboard_defconfig | 4 + configs/whistler_defconfig | 2 + configs/wtk_defconfig | 3 +- configs/xfi3_defconfig | 3 + configs/zipitz2_defconfig | 1 + drivers/net/ax88180.c | 6 +- drivers/serial/serial-uclass.c | 2 +- drivers/usb/host/isp116x-hcd.c | 6 +- drivers/video/Kconfig | 145 ++++ drivers/video/Makefile | 4 - drivers/video/cfb_console.c | 236 ++---- drivers/video/ct69000.c | 78 -- drivers/video/imx25lcdc.c | 121 --- drivers/video/s3c-fb.c | 172 ----- drivers/video/sed13806.c | 286 ------- drivers/video/smiLynxEM.c | 835 --------------------- include/asm-generic/global_data.h | 2 +- include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/B4860QDS.h | 3 - include/configs/BSC9131RDB.h | 2 - include/configs/BSC9132QDS.h | 2 - include/configs/C29XPCIE.h | 2 - include/configs/CPCI2DP.h | 2 - include/configs/CPCI4052.h | 2 - include/configs/M52277EVB.h | 1 - include/configs/M5249EVB.h | 1 - include/configs/MIP405.h | 12 - include/configs/MPC8349ITX.h | 6 +- include/configs/MPC8536DS.h | 4 - include/configs/MPC8544DS.h | 4 - include/configs/MPC8572DS.h | 4 - include/configs/MPC8610HPCD.h | 6 - include/configs/MPC8641HPCN.h | 6 - include/configs/MigoR.h | 4 - include/configs/P1010RDB.h | 2 - include/configs/P1022DS.h | 8 - include/configs/PATI.h | 1 - include/configs/PIP405.h | 12 - include/configs/PLU405.h | 2 - include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 2 - include/configs/T102xQDS.h | 6 - include/configs/T102xRDB.h | 6 - include/configs/T1040QDS.h | 6 - include/configs/T104xRDB.h | 9 - include/configs/TQM5200.h | 7 - include/configs/UCP1020.h | 4 - include/configs/VCMA9.h | 2 - include/configs/VOM405.h | 2 - include/configs/a3m071.h | 3 - include/configs/a4m072.h | 1 - include/configs/ac14xx.h | 5 - include/configs/advantech_dms-ba16.h | 10 +- include/configs/am3517_crane.h | 1 - include/configs/amcc-common.h | 1 - include/configs/amcore.h | 1 - include/configs/ap325rxa.h | 3 - include/configs/ap_sh4a_4a.h | 3 - include/configs/aria.h | 6 - include/configs/aristainetos-common.h | 7 +- include/configs/aristainetos.h | 2 +- include/configs/aristainetos2.h | 2 +- include/configs/aristainetos2b.h | 2 +- include/configs/armadillo-800eva.h | 3 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9261ek.h | 3 - include/configs/at91sam9263ek.h | 2 - include/configs/at91sam9m10g45ek.h | 2 - include/configs/at91sam9n12ek.h | 2 - include/configs/at91sam9rlek.h | 2 - include/configs/at91sam9x5ek.h | 2 - include/configs/bf527-ezkit.h | 3 - include/configs/bf533-stamp.h | 1 - include/configs/bf548-ezkit.h | 1 - include/configs/bfin_adi_common.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/bur_cfg_common.h | 3 - include/configs/cgtqmx6eval.h | 10 +- include/configs/chromebook_jerry.h | 1 - include/configs/chromebook_samus.h | 2 - include/configs/clearfog.h | 1 - include/configs/cm-bf548.h | 1 - include/configs/cm5200.h | 1 - include/configs/cm_fx6.h | 7 - include/configs/cm_t35.h | 2 - include/configs/cm_t3517.h | 2 - include/configs/colibri_imx7.h | 5 - include/configs/colibri_pxa270.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/controlcenterd.h | 5 - include/configs/cougarcanyon2.h | 4 - include/configs/cyrus.h | 4 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/digsy_mtc.h | 5 - include/configs/dns325.h | 2 - include/configs/ea20.h | 6 - include/configs/eb_cpu5282.h | 2 - include/configs/ecovec.h | 3 - include/configs/edminiv2.h | 1 - include/configs/efi-x86.h | 2 - include/configs/el6x_common.h | 2 +- include/configs/embestmx6boards.h | 7 +- include/configs/evb_rk3288.h | 1 - include/configs/evb_rk3399.h | 1 - include/configs/exynos5-common.h | 3 - include/configs/exynos5-dt-common.h | 1 - include/configs/exynos7420-common.h | 3 - include/configs/fennec_rk3288.h | 1 - include/configs/firefly-rk3288.h | 1 - include/configs/galileo.h | 4 - include/configs/ge_bx50v3.h | 10 +- include/configs/goflexhome.h | 2 - include/configs/gr_ep2s60.h | 1 - include/configs/gw_ventana.h | 6 - include/configs/h2200.h | 1 - include/configs/harmony.h | 1 - include/configs/hrcon.h | 2 - include/configs/icon.h | 5 - include/configs/imx31_phycore.h | 5 - include/configs/io64.h | 2 - include/configs/ipek01.h | 6 - include/configs/kc1.h | 2 - include/configs/kilauea.h | 2 - include/configs/km/km_arm.h | 1 - include/configs/kzm9g.h | 3 - include/configs/lacie_kw.h | 2 - include/configs/ls1021aqds.h | 7 - include/configs/ls1021atwr.h | 7 - include/configs/lsxl.h | 2 - include/configs/lwmon5.h | 8 - include/configs/m28evk.h | 1 - include/configs/m53evk.h | 4 - include/configs/ma5d4evk.h | 2 - include/configs/makalu.h | 2 - include/configs/maxbcm.h | 1 - include/configs/mcx.h | 4 - include/configs/microblaze-generic.h | 2 - include/configs/miniarm_rk3288.h | 1 - include/configs/mpc5121ads.h | 4 - include/configs/ms7722se.h | 3 - include/configs/mt_ventoux.h | 4 - include/configs/mv-common.h | 1 - include/configs/mx23evk.h | 2 - include/configs/mx28evk.h | 1 - include/configs/mx51evk.h | 5 - include/configs/mx53loco.h | 5 - include/configs/mx6cuboxi.h | 10 +- include/configs/mx6qsabreauto.h | 2 +- include/configs/mx6sabre_common.h | 7 +- include/configs/mx6sabresd.h | 2 +- include/configs/mx6sxsabresd.h | 5 - include/configs/mx6ul_14x14_evk.h | 5 - include/configs/mx7dsabresd.h | 5 - include/configs/mxs.h | 4 - include/configs/nitrogen6x.h | 7 - include/configs/nokia_rx51.h | 5 - include/configs/novena.h | 7 - include/configs/o2dnt-common.h | 6 +- include/configs/odroid.h | 2 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/openrisc-generic.h | 1 - include/configs/origen.h | 2 - include/configs/paz00.h | 1 - include/configs/pcm058.h | 2 +- include/configs/pdm360ng.h | 4 - include/configs/peach-pi.h | 1 - include/configs/picosam9g45.h | 2 - include/configs/pm9261.h | 2 - include/configs/pm9263.h | 2 - include/configs/popmetal_rk3288.h | 1 - include/configs/pxm2.h | 5 - include/configs/r0p7734.h | 3 - include/configs/rcar-gen2-common.h | 3 - include/configs/rcar-gen3-common.h | 3 - include/configs/rk3288_common.h | 6 - include/configs/rock2.h | 1 - include/configs/rpi.h | 6 - include/configs/rut.h | 5 - include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 2 - include/configs/sama5d2_xplained.h | 2 - include/configs/sama5d3xek.h | 2 - include/configs/sama5d4_xplained.h | 2 - include/configs/sama5d4ek.h | 2 - include/configs/sandbox.h | 5 - include/configs/sansa_fuze_plus.h | 2 - include/configs/seaboard.h | 2 - include/configs/sequoia.h | 6 - include/configs/sh7752evb.h | 3 - include/configs/sh7753evb.h | 3 - include/configs/sh7757lcr.h | 3 - include/configs/sh7785lcr.h | 3 - include/configs/siemens-am33x-common.h | 1 - include/configs/smdk2410.h | 1 - include/configs/smdk5250.h | 1 - include/configs/smdk5420.h | 1 - include/configs/snapper9g45.h | 2 - include/configs/sniper.h | 2 - include/configs/socfpga_common.h | 3 - include/configs/socfpga_sr1500.h | 1 - include/configs/socrates.h | 6 - include/configs/spear-common.h | 1 - include/configs/strider.h | 2 - include/configs/sunxi-common.h | 13 - include/configs/tbs2910.h | 13 - include/configs/tegra-common.h | 6 - include/configs/theadorable.h | 4 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/ti_omap4_common.h | 1 - include/configs/tqma6.h | 2 +- include/configs/tqma6_mba6.h | 2 +- include/configs/tqma6_wru4.h | 2 +- include/configs/trats.h | 2 - include/configs/trats2.h | 2 - include/configs/tricorder.h | 2 - include/configs/vct.h | 1 - include/configs/ventana.h | 2 - include/configs/wandboard.h | 5 - include/configs/x600.h | 1 - include/configs/x86-common.h | 12 - include/configs/xfi3.h | 2 - include/configs/xilinx-ppc.h | 1 - include/configs/xpress.h | 1 - include/configs/zc5202.h | 2 +- include/configs/zc5601.h | 2 +- include/configs/zipitz2.h | 1 - include/lcd_console.h | 3 - include/sed13806.h | 81 -- include/stdio_dev.h | 2 +- include/video.h | 11 + include/video_fb.h | 12 - scripts/config_whitelist.txt | 28 - 755 files changed, 1639 insertions(+), 2597 deletions(-) delete mode 100644 drivers/video/imx25lcdc.c delete mode 100644 drivers/video/s3c-fb.c delete mode 100644 drivers/video/sed13806.c delete mode 100644 drivers/video/smiLynxEM.c delete mode 100644 include/sed13806.h
These two files have patch merge markers in them, within comments or strings. Remove then, so that a search for merge markers does not show up matches in these files.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
drivers/net/ax88180.c | 6 +----- drivers/usb/host/isp116x-hcd.c | 6 +++--- 2 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/net/ax88180.c b/drivers/net/ax88180.c index 43a67a5..261fde0 100644 --- a/drivers/net/ax88180.c +++ b/drivers/net/ax88180.c @@ -698,11 +698,7 @@ static void ax88180_read_mac_addr (struct eth_device *dev) } }
-/* -=========================================================================== -<<<<<< Exported SubProgram Bodies >>>>>> -=========================================================================== -*/ +/* Exported SubProgram Bodies */ int ax88180_initialize (bd_t * bis) { struct eth_device *dev; diff --git a/drivers/usb/host/isp116x-hcd.c b/drivers/usb/host/isp116x-hcd.c index 0556f32..32874d7 100644 --- a/drivers/usb/host/isp116x-hcd.c +++ b/drivers/usb/host/isp116x-hcd.c @@ -428,10 +428,10 @@ static int isp116x_interrupt(struct isp116x *isp116x) isp116x_write_reg16(isp116x, HCuPINTENB, 0); irqstat = isp116x_read_reg16(isp116x, HCuPINT); isp116x_write_reg16(isp116x, HCuPINT, irqstat); - DBG(">>>>>> irqstat %x <<<<<<", irqstat); + DBG("------ irqstat %x ------", irqstat);
if (irqstat & HCuPINT_ATL) { - DBG(">>>>>> HCuPINT_ATL <<<<<<"); + DBG("------ HCuPINT_ATL ------"); udelay(500); ret = 1; } @@ -439,7 +439,7 @@ static int isp116x_interrupt(struct isp116x *isp116x) if (irqstat & HCuPINT_OPR) { intstat = isp116x_read_reg32(isp116x, HCINTSTAT); isp116x_write_reg32(isp116x, HCINTSTAT, intstat); - DBG(">>>>>> HCuPINT_OPR %x <<<<<<", intstat); + DBG("------ HCuPINT_OPR %x ------", intstat);
if (intstat & HCINT_UE) { ERR("unrecoverable error, controller disabled");
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes.
README | 5 --- common/Kconfig | 45 ++++++++++++++++++++++ configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/a4m072_defconfig | 1 + configs/arndale_defconfig | 1 + configs/bct-brettl2_defconfig | 1 + configs/bf518f-ezbrd_defconfig | 1 + configs/bf526-ezbrd_defconfig | 1 + configs/bf527-ad7160-eval_defconfig | 1 + configs/bf527-ezkit-v2_defconfig | 1 + configs/bf527-ezkit_defconfig | 1 + configs/bf527-sdp_defconfig | 1 + configs/bf533-ezkit_defconfig | 1 + configs/bf533-stamp_defconfig | 1 + configs/bf537-pnav_defconfig | 1 + configs/bf537-stamp_defconfig | 1 + configs/bf538f-ezkit_defconfig | 1 + configs/bf548-ezkit_defconfig | 1 + configs/bf561-acvilon_defconfig | 1 + configs/bf561-ezkit_defconfig | 1 + configs/br4_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/cm-bf527_defconfig | 1 + configs/cm-bf533_defconfig | 1 + configs/cm-bf537e_defconfig | 1 + configs/cm-bf537u_defconfig | 1 + configs/cm-bf548_defconfig | 1 + configs/cm-bf561_defconfig | 1 + configs/cm5200_defconfig | 1 + configs/espresso7420_defconfig | 1 + configs/evb-rk3288_defconfig | 1 + configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/fo300_defconfig | 1 + configs/ibf-dsp561_defconfig | 1 + configs/ip04_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/miniarm-rk3288_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/pdm360ng_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/popmetal-rk3288_defconfig | 1 + configs/pr1_defconfig | 1 + configs/rock2_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/tcm-bf518_defconfig | 1 + configs/tcm-bf537_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/UCP1020.h | 4 -- include/configs/a4m072.h | 1 - include/configs/bfin_adi_common.h | 1 - include/configs/cm5200.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/exynos7420-common.h | 1 - include/configs/ls1021aqds.h | 3 -- include/configs/ls1021atwr.h | 3 -- include/configs/pdm360ng.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/sandbox.h | 1 - include/configs/tricorder.h | 2 - scripts/config_whitelist.txt | 3 -- 125 files changed, 150 insertions(+), 33 deletions(-)
diff --git a/README b/README index d916ee7..1b6f8ec 100644 --- a/README +++ b/README @@ -853,11 +853,6 @@ The following options need to be configured: default i/o. Serial console can be forced with environment 'console=serial'.
- When CONFIG_SILENT_CONSOLE is defined, all console - messages (by U-Boot and Linux!) can be silenced with - the "silent" environment variable. See - doc/README.silent for more information. - CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default is 0x00. CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default diff --git a/common/Kconfig b/common/Kconfig index c69c141..bbd5633 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -170,6 +170,8 @@ config BOOTDELAY
See doc/README.autoboot for details.
+menu "Console" + config CONSOLE_RECORD bool "Console recording" help @@ -203,6 +205,49 @@ config IDENT_STRING help This options adds the board specific name to u-boot version.
+config SILENT_CONSOLE + bool "Support a silent console" + help + This option allows the console to be silenced, meaning that no + output will appear on the console devices. This is controlled by + setting the environment vaariable 'silent' to a non-empty value. + Note this also silences the console when booting Linux. + + When the console is set up, the variable is checked, and the + GD_FLG_SILENT flag is set. Changing the environment variable later + will update the flag. + +config SILENT_U_BOOT_ONLY + bool "Only silence the U-Boot console" + depends on SILENT_CONSOLE + help + Normally when the U-Boot console is silenced, Linux's console is + also silenced (assuming the board boots into Linux). This option + allows the linux console to operate normally, even if U-Boot's + is silenced. + +config SILENT_CONSOLE_UPDATE_ON_SET + bool "Changes to the 'silent' environment variable update immediately" + depends on SILENT_CONSOLE + default y if SILENT_CONSOLE + help + When the 'silent' environment variable is changed, update the + console silence flag immediately. This allows 'setenv' to be used + to silence or un-silence the console. + + The effect is that any change to the variable will affect the + GD_FLG_SILENT flag. + +config SILENT_CONSOLE_UPDATE_ON_RELOC + bool "Allow flags to take effect on relocation" + depends on SILENT_CONSOLE + help + In some cases the environment is not available until relocation + (e.g. NAND). This option makes the value of the 'silent' + environment variable take effect at relocation. + +endmenu + config SYS_NO_FLASH bool "Disable support for parallel NOR flash" default n diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 828bb9b..395330d 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 7767e0d..fd1f2f0 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 7173342..a62560a 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index a1c93ae..5a2f3f9 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 371d5f6..04787a0 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index f134850..1a96a63 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index b0e9827..6f6fc86 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 91beb24..737c648 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 11aceb8..444d7f8 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 70961ec..2eada3f 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 09fe6c4..2c0f761 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index e013fdc..aa24d57 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index e9c7708..b1d1159 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 098ef3b..5a3a00f 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index d727450..e437f3e 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 002346a..55671a6 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index fc28d1f..f68d6f2 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 4f470aa..bda4fb3 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index ae6aacf..4ec922a 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index dd53bb4..6de7d31 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 9e5a409..e144a88 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index a43304b..aa3f0f8 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index e0887de..00e5b12 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 1782e07..466bdd7 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 28b7bb4..422a738 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index d2772fe..d631eca 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index f8c5d45..aeea55f 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index fa3c412..d6ceeba 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index fca6122..66a2c44 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index f611baf..71dabd9 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index aa02cec..6d01cf2 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND,SECURE_BOOT" CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 96985ac..0377d25 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index fd5da57..1894c62 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index bf41ff5..1cb34a5 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 7d70b57..ef8332b 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 1539c85..224d1d8 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 817c0dc..ee35e43 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" CONFIG_BOOTDELAY=10 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index 18dddd9..bf4ac25 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_A4M072=y CONFIG_OF_BOARD_SETUP=y +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index e04ff5b..f78a88c 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for ARNDALE" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " diff --git a/configs/bct-brettl2_defconfig b/configs/bct-brettl2_defconfig index ad894a2..5dae665 100644 --- a/configs/bct-brettl2_defconfig +++ b/configs/bct-brettl2_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BCT_BRETTL2=y CONFIG_BOOTDELAY=1 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index e17c969..7f30237 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF518F_EZBRD=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf526-ezbrd_defconfig b/configs/bf526-ezbrd_defconfig index d3cab9b..663a6a3 100644 --- a/configs/bf526-ezbrd_defconfig +++ b/configs/bf526-ezbrd_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF526_EZBRD=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf527-ad7160-eval_defconfig b/configs/bf527-ad7160-eval_defconfig index 45f4149..ccbb148 100644 --- a/configs/bf527-ad7160-eval_defconfig +++ b/configs/bf527-ad7160-eval_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_AD7160_EVAL=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/bf527-ezkit-v2_defconfig b/configs/bf527-ezkit-v2_defconfig index 3677e0a..d247280 100644 --- a/configs/bf527-ezkit-v2_defconfig +++ b/configs/bf527-ezkit-v2_defconfig @@ -2,6 +2,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y CONFIG_SYS_EXTRA_OPTIONS="BF527_EZKIT_REV_2_1" CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf527-ezkit_defconfig b/configs/bf527-ezkit_defconfig index da41fe6..f011277 100644 --- a/configs/bf527-ezkit_defconfig +++ b/configs/bf527-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf527-sdp_defconfig b/configs/bf527-sdp_defconfig index fec1307..0c5c4fd 100644 --- a/configs/bf527-sdp_defconfig +++ b/configs/bf527-sdp_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_SDP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf533-ezkit_defconfig b/configs/bf533-ezkit_defconfig index 853a5d4..53cd831 100644 --- a/configs/bf533-ezkit_defconfig +++ b/configs/bf533-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bf533-stamp_defconfig b/configs/bf533-stamp_defconfig index e0f5de9..f31b54b 100644 --- a/configs/bf533-stamp_defconfig +++ b/configs/bf533-stamp_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_STAMP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/bf537-pnav_defconfig b/configs/bf537-pnav_defconfig index bbc171d..4fd2936 100644 --- a/configs/bf537-pnav_defconfig +++ b/configs/bf537-pnav_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_PNAV=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/bf537-stamp_defconfig b/configs/bf537-stamp_defconfig index d189ad4..b691702 100644 --- a/configs/bf537-stamp_defconfig +++ b/configs/bf537-stamp_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_STAMP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf538f-ezkit_defconfig b/configs/bf538f-ezkit_defconfig index 8507b40..4e835cc 100644 --- a/configs/bf538f-ezkit_defconfig +++ b/configs/bf538f-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF538F_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/bf548-ezkit_defconfig b/configs/bf548-ezkit_defconfig index 8514d85..19ac4e9 100644 --- a/configs/bf548-ezkit_defconfig +++ b/configs/bf548-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF548_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/configs/bf561-acvilon_defconfig b/configs/bf561-acvilon_defconfig index 6428d18..744eb1c 100644 --- a/configs/bf561-acvilon_defconfig +++ b/configs/bf561-acvilon_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF561_ACVILON=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="Acvilon> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/bf561-ezkit_defconfig b/configs/bf561-ezkit_defconfig index f8206b8..abb612c 100644 --- a/configs/bf561-ezkit_defconfig +++ b/configs/bf561-ezkit_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF561_EZKIT=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/br4_defconfig b/configs/br4_defconfig index db5d915..90ce839 100644 --- a/configs/br4_defconfig +++ b/configs/br4_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BR4=y +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="br4>" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 3729722..9677e60 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DM_KEYBOARD=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-jerry" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/cm-bf527_defconfig b/configs/cm-bf527_defconfig index 773edfb..bc280a4 100644 --- a/configs/cm-bf527_defconfig +++ b/configs/cm-bf527_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF527=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/cm-bf533_defconfig b/configs/cm-bf533_defconfig index 6fa231d..5bc851a 100644 --- a/configs/cm-bf533_defconfig +++ b/configs/cm-bf533_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF533=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/cm-bf537e_defconfig b/configs/cm-bf537e_defconfig index 16f129b..db636e1 100644 --- a/configs/cm-bf537e_defconfig +++ b/configs/cm-bf537e_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537E=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/cm-bf537u_defconfig b/configs/cm-bf537u_defconfig index 68e8659..f4726b0 100644 --- a/configs/cm-bf537u_defconfig +++ b/configs/cm-bf537u_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537U=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index 0589803..bcf6d8f 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF548=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/cm-bf561_defconfig b/configs/cm-bf561_defconfig index 5a32f56..3acbc53 100644 --- a/configs/cm-bf561_defconfig +++ b/configs/cm-bf561_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF561=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/cm5200_defconfig b/configs/cm5200_defconfig index 8b98484..f8e28d9 100644 --- a/configs/cm5200_defconfig +++ b/configs/cm5200_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_CM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index e7163d3..e782710 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_EXYNOS7=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" for ESPRESSO7420" CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="ESPRESSO7420 # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index c7396a5..7ae03a6 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_EVB_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index a5c089b..5d25ee4 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_FENNEC_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-fennec" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index ba461b9..f640fce 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_FIREFLY_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index e7370d3..697a147 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/ibf-dsp561_defconfig b/configs/ibf-dsp561_defconfig index 036a92f..c598298 100644 --- a/configs/ibf-dsp561_defconfig +++ b/configs/ibf-dsp561_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IBF_DSP561=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/ip04_defconfig b/configs/ip04_defconfig index 277988c..1e05d3e 100644 --- a/configs/ip04_defconfig +++ b/configs/ip04_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IP04=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 8761b60..2df48c2 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 5bb475e..7951f65 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 628f2d5..e75297e 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index b511eb0..a54cfc6 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index a59d339..84ab1bd 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index c7db8b7..074d18e 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 49c88a6..ad40e12 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index f856ad7..6812bfb 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 09df451..e226071 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -14,6 +14,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 34cbb4d..e5a0eca 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 307153f..43ba7fe 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 2f95780..8cfaeaf 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index e8ae266..4762425 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index fefd174..25760e4 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SECURE_BOOT" CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 68848d8..5f9efdf 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 9faba8d..e272ea7 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index 6354d1a..557fdfc 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_MINIARM_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-miniarm" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index af2e4f7..177434e 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index f3de685..42f532b 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_CMD_I2C=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 9472bb0..e5f34a1 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for Peach-Pi" CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pi # " diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index d208d68..ddcb451 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for Peach-Pit" CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pit # " diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 112e6ae..d7f60a1 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_POPMETAL_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/pr1_defconfig b/configs/pr1_defconfig index e7cf5e8..a26ba61 100644 --- a/configs/pr1_defconfig +++ b/configs/pr1_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_PR1=y +CONFIG_SILENT_CONSOLE=y CONFIG_SYS_PROMPT="pr1>" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index fc9ff78..5ba7769 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -5,6 +5,7 @@ CONFIG_ROCKCHIP_RK3288=y CONFIG_TARGET_ROCK2=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" +CONFIG_SILENT_CONSOLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index fc9b4ac..143dd09 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 85610ed..9ad5274 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_SILENT_CONSOLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index ebaf768..cd6f694 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -22,6 +22,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 6e335f0..de62cb3 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for SMDK5250" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index c1d8c45..04521f2 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for SMDK5420" CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 3d8c8ea..a5754f8 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for snow" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="snow # " diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 74287ea..0c394c8 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -6,6 +6,7 @@ CONFIG_IDENT_STRING=" for spring" CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="spring # " diff --git a/configs/tcm-bf518_defconfig b/configs/tcm-bf518_defconfig index fd31cfc..9288e56 100644 --- a/configs/tcm-bf518_defconfig +++ b/configs/tcm-bf518_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF518=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y diff --git a/configs/tcm-bf537_defconfig b/configs/tcm-bf537_defconfig index d66e499..8459390 100644 --- a/configs/tcm-bf537_defconfig +++ b/configs/tcm-bf537_defconfig @@ -1,6 +1,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF537=y CONFIG_BOOTDELAY=5 +CONFIG_SILENT_CONSOLE=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index 5c1837c..abd21d4 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_TRICORDER=y CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP3 Tricorder # " diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 351a820..77620c1 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_TRICORDER=y CONFIG_SYS_EXTRA_OPTIONS="FLASHCARD" CONFIG_BOOTDELAY=0 +CONFIG_SILENT_CONSOLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index f7f0acb..eb3cfc0 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -34,7 +34,6 @@
#define CONFIG_DEEP_SLEEP #if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F #endif
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index e61c80d..0d6051e 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -39,7 +39,6 @@ #define CONFIG_DEEP_SLEEP #endif #if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F #endif
diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 9488db2..d64611a 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -46,7 +46,6 @@ /* support deep sleep */ #define CONFIG_DEEP_SLEEP #if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE #define CONFIG_BOARD_EARLY_INIT_F #endif
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 02633b6..e115bdd 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -118,7 +118,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_DEEP_SLEEP #if defined(CONFIG_DEEP_SLEEP) #define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_SILENT_CONSOLE #endif
#ifndef CONFIG_SYS_TEXT_BASE diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 14e06fb..814b879 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -52,7 +52,6 @@
#ifdef CONFIG_FO300 #define CONFIG_SYS_DEVICE_NULLDEV 1 /* enable null device */ -#define CONFIG_SILENT_CONSOLE 1 /* enable silent startup */ #define CONFIG_BOARD_EARLY_INIT_F 1 /* used to detect S1 switch position */ #define CONFIG_USB_BIN_FIXUP 1 /* for a buggy USB device */ #if 0 diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 57748b4..051d44e 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -54,10 +54,6 @@
#define CONFIG_LAST_STAGE_INIT
-#if !defined(CONFIG_DONGLE) -#define CONFIG_SILENT_CONSOLE -#endif - #endif
#if defined(CONFIG_TARGET_UCP1020) diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index bdc81ff..96c6826 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -36,7 +36,6 @@ #define CONFIG_BAUDRATE 9600 /* ... at 9600 bps */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } /* define to enable silent console */ -#define CONFIG_SILENT_CONSOLE #define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */
/* diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 502ddad..c401b73 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -78,7 +78,6 @@ #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_LOADS_ECHO 1 #define CONFIG_JTAG_CONSOLE -#define CONFIG_SILENT_CONSOLE #ifndef CONFIG_BAUDRATE # define CONFIG_BAUDRATE 57600 #endif diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index 065e700..93ba952 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -35,7 +35,6 @@ #define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ #define CONFIG_BAUDRATE 57600 /* ... at 57600 bps */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } -#define CONFIG_SILENT_CONSOLE 1 /* needed to silence i2c_init() */
/* * Ethernet configuration diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 51a0d19..111b23d 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -42,7 +42,6 @@ /* select serial console configuration */ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 -#define CONFIG_SILENT_CONSOLE #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_CONSOLE_MUX
diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index 9e03962..907b5ea 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -54,7 +54,6 @@
/* select serial console configuration */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SILENT_CONSOLE #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_CONSOLE_MUX
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 554c13c..c641234 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -22,9 +22,6 @@ #define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_DEEP_SLEEP -#if defined(CONFIG_DEEP_SLEEP) -#define CONFIG_SILENT_CONSOLE -#endif
/* * Size of malloc() pool diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index e5ac50e..d3ef614 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -21,9 +21,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_DEEP_SLEEP -#ifdef CONFIG_DEEP_SLEEP -#define CONFIG_SILENT_CONSOLE -#endif
/* * Size of malloc() pool diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index 6d03d69..e0b4d36 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -37,7 +37,6 @@
/* Used for silent command in environment */ #define CONFIG_SYS_DEVICE_NULLDEV -#define CONFIG_SILENT_CONSOLE
/* Video */ #define CONFIG_VIDEO diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index e8bf987..7ac3a5e 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -39,7 +39,6 @@ #define CONFIG_SPL_STACK 0xff718000 #define CONFIG_SPL_TEXT_BASE 0xff704004
-#define CONFIG_SILENT_CONSOLE #ifndef CONFIG_SPL_BUILD # define CONFIG_SYS_CONSOLE_IS_IN_ENV # define CONFIG_CONSOLE_MUX diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 94e024b..bd005fc 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -67,7 +67,6 @@
#define CONFIG_SYS_LONGHELP /* #undef to save memory */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#define CONFIG_SILENT_CONSOLE
/* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 37425c7..4af33c7 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -43,8 +43,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
-#define CONFIG_SILENT_CONSOLE - /* Clock Defines */ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK >> 1) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cb4516f..4e2500a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4103,9 +4103,6 @@ CONFIG_SIEMENS_DRACO CONFIG_SIEMENS_MACH_TYPE CONFIG_SIEMENS_PXM2 CONFIG_SIEMENS_RUT -CONFIG_SILENT_CONSOLE -CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC -CONFIG_SILENT_CONSOLE_UPDATE_ON_SET CONFIG_SIMU CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION CONFIG_SKIP_LOWLEVEL_INIT
Changes in v2: - Change CONFIG_PRE_CON_BUF_SZ default to 4096 - Change CONFIG_PRE_CON_BUF_SZ to 'int' type - Drop the depend clause on the CONFIG_PRE_CON_BUF_SZ default - Move CONFIG_PRE_CON_BUF_ADDR default to common/Kconfig
README | 17 ---------------- board/sunxi/Kconfig | 3 +++ common/Kconfig | 42 +++++++++++++++++++++++++++++++++++++++ common/console.c | 6 +++--- configs/tbs2910_defconfig | 2 ++ include/asm-generic/global_data.h | 2 +- include/configs/sunxi-common.h | 6 ------ include/configs/tbs2910.h | 4 ---- scripts/config_whitelist.txt | 3 --- 9 files changed, 51 insertions(+), 34 deletions(-)
diff --git a/README b/README index 1b6f8ec..26a53e2 100644 --- a/README +++ b/README @@ -872,23 +872,6 @@ The following options need to be configured: must be defined, to setup the maximum idle timeout for the SMC.
-- Pre-Console Buffer: - Prior to the console being initialised (i.e. serial UART - initialised etc) all console output is silently discarded. - Defining CONFIG_PRE_CONSOLE_BUFFER will cause U-Boot to - buffer any console messages prior to the console being - initialised to a buffer of size CONFIG_PRE_CON_BUF_SZ - bytes located at CONFIG_PRE_CON_BUF_ADDR. The buffer is - a circular buffer, so if more than CONFIG_PRE_CON_BUF_SZ - bytes are output before the console is initialised, the - earlier bytes are discarded. - - Note that when printing the buffer a copy is made on the - stack so CONFIG_PRE_CON_BUF_SZ must fit on the stack. - - 'Sane' compilers will generate smaller code if - CONFIG_PRE_CON_BUF_SZ is a power of 2 - - Autoboot Command: CONFIG_BOOTCOMMAND Only needed when CONFIG_BOOTDELAY is enabled; diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index b139d1c..c0ffeb3 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -3,6 +3,9 @@ if ARCH_SUNXI config IDENT_STRING default " Allwinner Technology"
+config PRE_CONSOLE_BUFFER + default y + config SPL_GPIO_SUPPORT default y
diff --git a/common/Kconfig b/common/Kconfig index bbd5633..6ee67ac 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -246,6 +246,48 @@ config SILENT_CONSOLE_UPDATE_ON_RELOC (e.g. NAND). This option makes the value of the 'silent' environment variable take effect at relocation.
+config PRE_CONSOLE_BUFFER + bool "Buffer characters before the console is available" + help + Prior to the console being initialised (i.e. serial UART + initialised etc) all console output is silently discarded. + Defining CONFIG_PRE_CONSOLE_BUFFER will cause U-Boot to + buffer any console messages prior to the console being + initialised to a buffer. The buffer is a circular buffer, so + if it overflows, earlier output is discarded. + + Note that this is not currently supported in SPL. It would be + useful to be able to share the pre-console buffer with SPL. + +config PRE_CON_BUF_SZ + int "Sets the size of the pre-console buffer" + depends on PRE_CONSOLE_BUFFER + default 4096 + help + The size of the pre-console buffer affects how much console output + can be held before it overflows and starts discarding earlier + output. Normally there is very little output at this early stage, + unless debugging is enabled, so allow enough for ~10 lines of + text. + + This is a useful feature if you are using a video console and + want to see the full boot output on the console. Without this + option only the post-relocation output will be displayed. + +config PRE_CON_BUF_ADDR + hex "Address of the pre-console buffer" + depends on PRE_CONSOLE_BUFFER + default 0x2f000000 if ARCH_SUNXI && MACH_SUN9I + default 0x4f000000 if ARCH_SUNXI && !MACH_SUN9I + help + This sets the start address of the pre-console buffer. This must + be in available memory and is accessed before relocation and + possibly before DRAM is set up. Therefore choose an address + carefully. + + We should consider removing this option and allocating the memory + in board_init_f_init_reserve() instead. + endmenu
config SYS_NO_FLASH diff --git a/common/console.c b/common/console.c index 12293f3..31a9b3e 100644 --- a/common/console.c +++ b/common/console.c @@ -201,7 +201,7 @@ static void console_putc(int file, const char c) } }
-#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) static void console_puts_noserial(int file, const char *s) { int i; @@ -247,7 +247,7 @@ static inline void console_putc(int file, const char c) stdio_devices[file]->putc(stdio_devices[file], c); }
-#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) static inline void console_puts_noserial(int file, const char *s) { if (strcmp(stdio_devices[file]->name, "serial") != 0) @@ -413,7 +413,7 @@ int tstc(void) #define PRE_CONSOLE_FLUSHPOINT1_SERIAL 0 #define PRE_CONSOLE_FLUSHPOINT2_EVERYTHING_BUT_SERIAL 1
-#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) #define CIRC_BUF_IDX(idx) ((idx) % (unsigned long)CONFIG_PRE_CON_BUF_SZ)
static void pre_console_putc(const char c) diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index fbff9fe..0871408 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y +CONFIG_PRE_CONSOLE_BUFFER=y +CONFIG_PRE_CON_BUF_ADDR=0x7c000000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_HUSH_PARSER=y diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index dc4cbdb..e02863d 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -45,7 +45,7 @@ typedef struct global_data { unsigned long board_type; #endif unsigned long have_console; /* serial_init() was called */ -#ifdef CONFIG_PRE_CONSOLE_BUFFER +#if CONFIG_IS_ENABLED(PRE_CONSOLE_BUFFER) unsigned long precon_buf_idx; /* Pre-Console buffer index */ #endif unsigned long env_addr; /* Address of Environment struct */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index deb2e8d..16c86d9 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x20000000 #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* default load address */ #define CONFIG_SYS_TEXT_BASE 0x2a000000 -#define CONFIG_PRE_CON_BUF_ADDR 0x2f000000 /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ @@ -80,7 +79,6 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define CONFIG_SYS_LOAD_ADDR 0x42000000 /* default load address */ #define CONFIG_SYS_TEXT_BASE 0x4a000000 -#define CONFIG_PRE_CON_BUF_ADDR 0x4f000000 /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ @@ -378,10 +376,6 @@ extern int soft_i2c_gpio_scl; #ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h>
-/* Enable pre-console buffer to get complete log on the VGA console */ -#define CONFIG_PRE_CONSOLE_BUFFER -#define CONFIG_PRE_CON_BUF_SZ 4096 /* Aprox 2 80*25 screens */ - #ifdef CONFIG_ARM64 /* * Boards seem to come with at least 512MB of DRAM. diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 85501bc..ddd53dd 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -50,10 +50,6 @@ #define CONFIG_CONSOLE_MUX #define CONFIG_CONS_INDEX 1
-#define CONFIG_PRE_CONSOLE_BUFFER -#define CONFIG_PRE_CON_BUF_SZ 4096 -#define CONFIG_PRE_CON_BUF_ADDR 0x7C000000 - /* *** Command definition *** */ #define CONFIG_CMD_BMODE
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4e2500a..28fc43d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3734,9 +3734,6 @@ CONFIG_PQ_MDS_PIB CONFIG_PQ_MDS_PIB_ATM CONFIG_PRAM CONFIG_PREBOOT -CONFIG_PRE_CONSOLE_BUFFER -CONFIG_PRE_CON_BUF_ADDR -CONFIG_PRE_CON_BUF_SZ CONFIG_PRIMEVIEW_V16C6448AC CONFIG_PRINTK CONFIG_PROC_FS
On Sat, Sep 24, 2016 at 06:16:59PM -0600, Simon Glass wrote:
Move these option to Kconfig and tidy up existing uses.
Signed-off-by: Simon Glass sjg@chromium.org
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_IS_IN_ENV CONFIG_CONSOLE_MUX
Changes in v2: - Make CONSOLE_MUX default y if DM_VIDEO || VIDEO || LCD
README | 6 ------ common/Kconfig | 20 ++++++++++++++++++++ configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A33-OLinuXino_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + .../BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Cubietruck_plus_defconfig | 2 ++ configs/Cyrus_P5020_defconfig | 2 ++ configs/Cyrus_P5040_defconfig | 2 ++ configs/Empire_electronix_d709_defconfig | 1 + configs/Empire_electronix_m712_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 2 ++ configs/Mini-X_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/PATI_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/PMC440_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 2 ++ configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/UTOO_P66_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/a3m071_defconfig | 1 + configs/a4m2k_defconfig | 1 + configs/apalis_t30_defconfig | 2 ++ configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/arndale_defconfig | 2 ++ configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bayleybay_defconfig | 2 ++ configs/beaver_defconfig | 2 ++ configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cardhu_defconfig | 2 ++ configs/cei-tk1-som_defconfig | 2 ++ configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link_defconfig | 2 ++ configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 2 ++ configs/cm_fx6_defconfig | 2 ++ configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 2 ++ configs/colorfly_e708_q1_defconfig | 1 + .../conga-qeval20-qa3-e3845-internal-uart_defconfig | 2 ++ configs/conga-qeval20-qa3-e3845_defconfig | 2 ++ .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig | 1 + configs/controlcenterd_TRAILBLAZER_defconfig | 1 + configs/coreboot-x86_defconfig | 2 ++ configs/cougarcanyon2_defconfig | 2 ++ configs/crownbay_defconfig | 2 ++ configs/d2net_v2_defconfig | 2 ++ configs/dalmore_defconfig | 2 ++ configs/dfi-bt700-q7x-151_defconfig | 2 ++ configs/difrnce_dit4350_defconfig | 1 + configs/digsy_mtc_RAMBOOT_defconfig | 1 + configs/digsy_mtc_defconfig | 1 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 1 + configs/digsy_mtc_rev5_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/dns325_defconfig | 2 ++ configs/dserve_dsrv9703c_defconfig | 1 + configs/duovero_defconfig | 1 + configs/e2220-1170_defconfig | 2 ++ configs/ea20_defconfig | 1 + configs/efi-x86_defconfig | 2 ++ configs/espresso7420_defconfig | 2 ++ configs/evb-rk3288_defconfig | 2 ++ configs/fennec-rk3288_defconfig | 2 ++ configs/firefly-rk3288_defconfig | 1 + configs/fo300_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/galileo_defconfig | 2 ++ configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/goflexhome_defconfig | 2 ++ configs/gt90h_v4_defconfig | 1 + configs/gurnard_defconfig | 1 + configs/gwventana_defconfig | 2 ++ configs/h2200_defconfig | 1 + configs/h8_homlet_v2_defconfig | 2 ++ configs/haleakala_defconfig | 1 + configs/harmony_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0030_nand_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/inetspace_v2_defconfig | 2 ++ configs/io64_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/jetson-tk1_defconfig | 2 ++ configs/kc1_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/makalu_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mcx_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/miniarm-rk3288_defconfig | 2 ++ configs/minnowmax_defconfig | 2 ++ configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6cuboxi_defconfig | 2 ++ configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 2 ++ configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 7 ++++--- configs/mx6ul_9x9_evk_defconfig | 7 ++++--- configs/mx7dsabresd_defconfig | 1 + configs/mx7dsabresd_secure_defconfig | 1 + configs/nanopi_neo_defconfig | 2 ++ configs/net2big_v2_defconfig | 2 ++ configs/netspace_lite_v2_defconfig | 2 ++ configs/netspace_max_v2_defconfig | 2 ++ configs/netspace_mini_v2_defconfig | 2 ++ configs/netspace_v2_defconfig | 2 ++ configs/nitrogen6dl2g_defconfig | 2 ++ configs/nitrogen6dl_defconfig | 2 ++ configs/nitrogen6q2g_defconfig | 2 ++ configs/nitrogen6q_defconfig | 2 ++ configs/nitrogen6s1g_defconfig | 2 ++ configs/nitrogen6s_defconfig | 2 ++ configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 2 ++ configs/nyan-big_defconfig | 1 + configs/odroid-xu3_defconfig | 2 ++ configs/odroid_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/orangepi_2_defconfig | 2 ++ configs/orangepi_lite_defconfig | 2 ++ configs/orangepi_one_defconfig | 2 ++ configs/orangepi_pc_defconfig | 2 ++ configs/orangepi_pc_plus_defconfig | 2 ++ configs/orangepi_plus2e_defconfig | 2 ++ configs/orangepi_plus_defconfig | 2 ++ configs/origen_defconfig | 1 + configs/p2371-0000_defconfig | 2 ++ configs/p2371-2180_defconfig | 2 ++ configs/p2571_defconfig | 2 ++ configs/p2771-0000-000_defconfig | 2 ++ configs/p2771-0000-500_defconfig | 2 ++ configs/parrot_r16_defconfig | 1 + configs/paz00_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pine64_plus_defconfig | 2 ++ configs/plutux_defconfig | 2 ++ configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/popmetal-rk3288_defconfig | 2 ++ configs/pov_protab2_ips9_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/qemu-x86_defconfig | 2 ++ configs/qemu-x86_efi_payload32_defconfig | 2 ++ configs/qemu-x86_efi_payload64_defconfig | 2 ++ configs/r7-tv-dongle_defconfig | 1 + configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/rock2_defconfig | 1 + configs/rpi_2_defconfig | 2 ++ configs/rpi_3_32b_defconfig | 2 ++ configs/rpi_3_defconfig | 2 ++ configs/rpi_defconfig | 2 ++ configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sandbox_noblk_defconfig | 1 + configs/sandbox_spl_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/smdk5250_defconfig | 2 ++ configs/smdk5420_defconfig | 2 ++ configs/sniper_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 2 ++ configs/spring_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tbs2910_defconfig | 2 ++ configs/tec-ng_defconfig | 2 ++ configs/tec_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 2 ++ configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/trimslice_defconfig | 2 ++ configs/venice2_defconfig | 2 ++ configs/ventana_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/whistler_defconfig | 2 ++ configs/xfi3_defconfig | 1 + include/configs/B4860QDS.h | 3 --- include/configs/BSC9131RDB.h | 2 -- include/configs/BSC9132QDS.h | 2 -- include/configs/C29XPCIE.h | 2 -- include/configs/MIP405.h | 1 - include/configs/P1010RDB.h | 2 -- include/configs/PATI.h | 1 - include/configs/PIP405.h | 1 - include/configs/PMC440.h | 2 -- include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 3 --- include/configs/TQM5200.h | 1 - include/configs/a3m071.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/at91sam9261ek.h | 2 -- include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 2 -- include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 2 -- include/configs/cyrus.h | 2 -- include/configs/digsy_mtc.h | 1 - include/configs/dns325.h | 2 -- include/configs/ea20.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/exynos5-common.h | 2 -- include/configs/exynos7420-common.h | 2 -- include/configs/ge_bx50v3.h | 1 - include/configs/goflexhome.h | 2 -- include/configs/gw_ventana.h | 2 -- include/configs/h2200.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/io64.h | 2 -- include/configs/ipek01.h | 1 - include/configs/kc1.h | 2 -- include/configs/kilauea.h | 2 -- include/configs/lacie_kw.h | 2 -- include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lsxl.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/makalu.h | 2 -- include/configs/mcx.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/mt_ventoux.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 2 -- include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nitrogen6x.h | 2 -- include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 2 -- include/configs/odroid.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_pandora.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/origen.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/rk3288_common.h | 5 ----- include/configs/rpi.h | 2 -- include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/sandbox.h | 2 -- include/configs/sequoia.h | 2 -- include/configs/snapper9g45.h | 2 -- include/configs/sniper.h | 2 -- include/configs/socfpga_common.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 3 --- include/configs/tbs2910.h | 2 -- include/configs/tegra-common.h | 2 -- include/configs/ti_omap4_common.h | 1 - include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/wandboard.h | 1 - include/configs/x86-common.h | 2 -- scripts/config_whitelist.txt | 2 -- 554 files changed, 561 insertions(+), 155 deletions(-)
diff --git a/README b/README index 26a53e2..391f743 100644 --- a/README +++ b/README @@ -3679,12 +3679,6 @@ Configuration Settings: - CONFIG_SYS_CONSOLE_INFO_QUIET Suppress display of console information at boot.
-- CONFIG_SYS_CONSOLE_IS_IN_ENV - If the board specific function - extern int overwrite_console (void); - returns 1, the stdin, stderr and stdout are switched to the - serial port, else the settings in the environment are used. - - CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Enable the call to overwrite_console().
diff --git a/common/Kconfig b/common/Kconfig index 6ee67ac..8e600f7 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -288,6 +288,26 @@ config PRE_CON_BUF_ADDR We should consider removing this option and allocating the memory in board_init_f_init_reserve() instead.
+config CONSOLE_MUX + bool "Enable console multiplexing" + default y if DM_VIDEO || VIDEO || LCD + help + This allows multiple devices to be used for each console 'file'. + For example, stdout can be set to go to serial and video. + Similarly, stdin can be set to come from serial and keyboard. + Input can be provided from either source. Console multiplexing + adds a small amount of size to U-Boot. Changes to the environment + variables stdout, stdin and stderr will take effect immediately. + +config SYS_CONSOLE_IS_IN_ENV + bool "Select console devices from the environment" + help + This allows multiple input/output devices to be set at boot time. + For example, if stdout is set to "serial,video" then output will + be sent to both the serial and video devices on boot. The + environment variables can be updated after boot to change the + input/output devices. + endmenu
config SYS_NO_FLASH diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 04b720d..1240544 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -9,6 +9,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index e2bebf8..9a637d3 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -10,6 +10,7 @@ CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 361d90a..e501e51 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 64109a6..f1dc8d1 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 54343de..2d5bd0e 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -9,6 +9,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index c4f6e1a..9220185 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 5809345..8e78ecd 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -10,6 +10,7 @@ CONFIG_VIDEO_VGA=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 7a14a7b..445e644 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -12,6 +12,7 @@ CONFIG_USB0_VBUS_DET="PH5" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index 2909987..f476035 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="PB2" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 46c5309..fde5954 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-ainol-aw1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 5020724..f1a5a7b 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 1e248a7..f259791 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -8,6 +8,7 @@ CONFIG_USB1_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 55f956e..6b22dfd 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index c192177..d3cf286 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 2c2e3c2..2dd25fe 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index bfd64af..406241a 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index d01baaa..00fe182 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 75124a8..2923547 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index 52f78be..80e729e 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index cd80c91..09c8a5b 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index 1f642e3..31f64ab 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_SF=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index babcdd5..e2a8103 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND,SYS_CLK_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index ad00622..c9cfaf8 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 9045567..9694709 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH,SYS_CLK_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index 178618c..367ba78 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index e678144..3615b6c 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index e6fde47..e3a76b3 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index 1d9b541..c204783 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 235f304..de42f7b 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index f193c4b..dc9e3f8 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index 4c9c955..748a247 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 74c3385..bd1da16 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index 4bc83ef..dd13d06 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 0bea345..8723279 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index f16b1b1..6e56dae 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index d24f216..ac9a16c 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index a9555db..ca2853e 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index 06a1770..afb14d2 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index c86ce6f..47a037b 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index 6f6f2dc..2087b46 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index da71c54..d87aa5c 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 366ef24..1b8ef23 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -8,6 +8,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 9b39124..b8dafd3 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -10,6 +10,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index 1c03d44..c3cc168 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,NAND" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index f932373..15d89f1 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,SECURE_BOOT" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 7f4189e..49799be 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index ff16c7a..9f89263 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,SPIFLASH" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 8dd57d2..83493d4 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE" CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 296a0b5..972e110 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -9,6 +9,7 @@ CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_DFU=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 448ce95..55f1459 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -7,6 +7,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 8507f73..ed375ae 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-chuwi-v7-cw0825" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index d8272c5..3c5ccec 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index ad6eb62..a69b478 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 9b4f483..6cdffd9 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 9e44cf7..97f5e40 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -12,6 +12,7 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index f2c6fe7..84ed0eb 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -13,6 +13,8 @@ CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index d8c8957..9dd8742 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -7,6 +7,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5020" CONFIG_BOOTDELAY=10 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index f5d3cc2..ff36be4 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -7,6 +7,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5040" CONFIG_BOOTDELAY=10 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GREPENV=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 831949a..433938a 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 4b51380..2dfe489 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index dc4133d..a3e8469 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 41cb877..09ad379 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 1a8fad7..08945dd 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index c2fc2b3..dcfe1b1 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -8,6 +8,7 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index a916e5d..e290249 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -9,6 +9,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 8eea214..6cb05aa 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_ZQ=122 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index ab094a6..36ab5d8 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -7,6 +7,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index e5910cd..0f4f12f 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -3,6 +3,7 @@ CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10082-001 released" CONFIG_4xx=y CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index a38eac1..b749a41 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -3,6 +3,7 @@ CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10072-001 released" CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 1e8f9db..21a0c25 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -5,6 +5,7 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-mk808c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 87fd3b9..39988bc 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -10,6 +10,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-primo73" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 8847271..5744771 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-primo81" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index b1d6b23..246b0cd 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -4,6 +4,7 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 4097e5b..f629c72 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -8,6 +8,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index eae5ead..591ef3a 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -7,6 +7,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index eb3c74c..3d7dbc1 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -7,6 +7,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 037e768..a90de55 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -10,6 +10,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 124dc22..6659c5d 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -9,6 +9,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,STATUSLED=234" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index c4e5993..dec9e87 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -7,6 +7,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 198fda9..bc57aaa 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -7,6 +7,8 @@ CONFIG_SYS_CLK_FREQ=1008000000 CONFIG_MMC0_CD_PIN="PH18" CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 87fac82..28687a8 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -6,6 +6,7 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index 266f2ce..aec6b9a 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MINIFAP" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index c3eaae2..de20da3 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -11,6 +11,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 2903d83..b1a795b 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -13,6 +13,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 864643c..986dc7f 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index fc14f50..7155011 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index 17dd94b..f687a84 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 6de688f..cf42d2f 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 4006383..f3f0fca 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index 6ff1f50..94a1c22 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 94f1501..c56d9e3 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 911f607..df0cc7a 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index db003ef..f6943a8 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index 9599528..50166ce 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index e25da5c..6a6bcaf 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index d8d069e..64959d7 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index 7050462..a4073f6 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index b8229fa..eea19e6 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index 55da2e4..3ac3839 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index dd170a5..406a58a 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -11,6 +11,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index 166df05..a1375b3 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index e751041..c95c28c 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index b907459..38fbb18 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index f26fa72..f201f13 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index e87c9d6..87e23dd 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 7fad176..ececb7e 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 11f0866..f45db61 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -10,6 +10,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_TPL=y CONFIG_TPL_ENV_SUPPORT=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 6282ccb..ecafb24 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index d477a88..231c806 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 613131a..14f67b0 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index c2238d6..524afd9 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index fb7334b..591075f 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/PATI_defconfig b/configs/PATI_defconfig index 80f077a..45be3bb 100644 --- a/configs/PATI_defconfig +++ b/configs/PATI_defconfig @@ -3,6 +3,7 @@ CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10084-001 released" CONFIG_5xx=y CONFIG_TARGET_PATI=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="pati=> " # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 87f2f31..02c9c1b 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -3,6 +3,7 @@ CONFIG_IDENT_STRING="\n(c) 2002 by MPL AG Switzerland, MEV-10066-001 released" CONFIG_4xx=y CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index af38882..cd2f0d2 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_PMC440=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9ac8912..97894f4 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -11,6 +11,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index b41bf67..d7832fe 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PB4" CONFIG_USB0_ID_DET="PH8" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 267aaf8..c6bfa4b 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -7,6 +7,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index a9c7fc1..47ac144 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -14,6 +14,8 @@ CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index b24d21b..fed2560 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index 7f84498..c45de13 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -14,6 +14,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index fa538f3..3e5765e 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,SECURE_BOOT" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index c75abbb..9ec82d5 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index af99ff0..c0fe36b 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 395330d..93637e4 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index fd1f2f0..ac419b4 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index a62560a..6ed4e9e 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 5a2f3f9..243b2b1 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 04787a0..e3a249f 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 1a96a63..8a8b854 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 6f6fc86..b5c6c1e 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 737c648..dfc9697 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 444d7f8..15545d8 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 2eada3f..43ba56b 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 2c0f761..99d2a40 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index aa24d57..72fc86f 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MEMTEST=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index b1d1159..c420dc3 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 5a3a00f..ff4bbe3 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index e437f3e..f548e21 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 55671a6..00feb36 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index f68d6f2..55adc62 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index bda4fb3..8526426 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 4ec922a..6dee606 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 6de7d31..716490b 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index e144a88..da6ef10 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index aa3f0f8..49b6221 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 00e5b12..98e7855 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 466bdd7..31ea589 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 422a738..b898f93 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index d631eca..ce34ec1 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index aeea55f..63e88df 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index d6ceeba..9035ab9 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 66a2c44..b26304c 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 71dabd9..ff39f15 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 6d01cf2..3e4e9e2 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND,SECURE_BOOT" CONFIG_BOOTDELAY=0 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 0377d25..5fd9c1e 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 1894c62..95a4c8a 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 1cb34a5..f05e33c 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -16,6 +16,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index ef8332b..07faad5 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 224d1d8..e9d4145 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index ee35e43..8e11872 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" CONFIG_BOOTDELAY=10 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GREPENV=y CONFIG_CMD_MMC=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index be90d79..353fdc1 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,SYS_TEXT_BASE=0xFFF00000" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index a405e92..ec3655d 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 904fcd1..823e2ae 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="STK52XX_REV100" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index e478f4c..c47ff76 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index 205c9e2..a4a1b20 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -20,6 +20,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_TL059WV5C0=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-utoo-p66" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index ecde5db..3fdee51 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index d83cee7..55b73c6 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 907afe5..b1c2d50 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -7,6 +7,7 @@ CONFIG_MMC0_CD_PIN="PB3" CONFIG_USB1_VBUS_PIN="PG12" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 1e42a68..28811fd 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -19,6 +19,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-yones-toptech-bd1078" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 958104e..7a47252 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-yones-toptech-bs1078-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/a3m071_defconfig b/configs/a3m071_defconfig index 18237b7..e579677 100644 --- a/configs/a3m071_defconfig +++ b/configs/a3m071_defconfig @@ -8,6 +8,7 @@ CONFIG_TARGET_A3M071=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/a4m2k_defconfig b/configs/a4m2k_defconfig index 3f2a58a..1d71fab 100644 --- a/configs/a4m2k_defconfig +++ b/configs/a4m2k_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="A4M2K" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 882d409..df21628 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA30=y CONFIG_TARGET_APALIS_T30=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-apalis" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis T30 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 84e3bf6..c8118db 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARISTAINETOS2=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 21765aa..aae082f 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARISTAINETOS2B=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 1e6954e..85631bb 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ARISTAINETOS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index f78a88c..bb1fd59 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -7,6 +7,8 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 51b3ec1..99bb49e 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index f5ffbcd..014e50e 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index c985d3a..e0e8fea 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 09a1404..38b9635 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 09a1404..38b9635 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 3a18c3b..317d9c2 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index e4608d2..a26d7d1 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_BOOT_NORFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 4c97c9f..8b72678 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 1ee26d9..0293aa6 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS0" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index de6cacd..777d234 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS3" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 257593d..788e7e1 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9261EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 0aaa888..9604af9 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 05140ac..e1aebb1 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 3eb8666..ce62edf 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9N12EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 15e1970..3b7ebc2 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index ebed1db..26c93af 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 69be1d2..494a630 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9RLEK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index c49bf18..f0ea3f0 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9RLEK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 142122e..0a414e4 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9RLEK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9RL,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 6771f57..ac51cc7 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 7995c23..e6910a0 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index b8766fd..c232324 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index b6ed43a..b8a772d 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c60766c..e256eed 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -10,6 +10,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 64e3d31..adb1c73 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -15,6 +15,8 @@ CONFIG_SEABIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 28c1b28..3f9d339 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA30=y CONFIG_TARGET_BEAVER=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-beaver" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 15365b9..e990f03 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 05fc1e0..8872f4a 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 4855acc..c04dde8 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 8fe1100..0251088 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 2d361c3..c6bbfa3 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA30=y CONFIG_TARGET_CARDHU=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-cardhu" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index ea515f2..29123d7 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA124=y CONFIG_TARGET_CEI_TK1_SOM=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-cei-tk1-som" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (TK1-SOM) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 645923c..e2d8b6a 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 724441e..8517f2b 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 9677e60..f0c151d 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DM_KEYBOARD=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-jerry" CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 8c91bfe..b279a7b 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -10,6 +10,8 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 1822970..e1b92ea 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -10,6 +10,7 @@ CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 2557d35..b5fbdae 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -8,6 +8,8 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 998bc05..a40e6f8 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -13,6 +13,8 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-FX6 # " diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index dfc2539..b131b27 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_CM_T3517=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3517 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 79fa39c..9a2f624 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_CM_T35=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 5302fe3..c1779ec 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -5,6 +5,7 @@ CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_imx7/imximage.cfg,MX7D" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri iMX7 # " # CONFIG_CMD_BOOTD is not set diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index fb5055b..2c1189d 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_COLIBRI_T20=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T20 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index bd0250a..6c6ebcb 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA30=y CONFIG_TARGET_COLIBRI_T30=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-colibri" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T30 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index ae67c37..33d406e 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-colorfly-e708-q1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index f0da176..7da23e0 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 63c2cbd..3a122b8 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 88d189a..cdd466a 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD,DEVELOP" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index c8679e2..28951e0 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -9,6 +9,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig index e94d72f..56179af 100644 --- a/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_DEVELOP_defconfig @@ -4,6 +4,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH,DEVELOP" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_TRAILBLAZER_defconfig b/configs/controlcenterd_TRAILBLAZER_defconfig index 257fa85..c40a205 100644 --- a/configs/controlcenterd_TRAILBLAZER_defconfig +++ b/configs/controlcenterd_TRAILBLAZER_defconfig @@ -4,6 +4,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y CONFIG_SYS_EXTRA_OPTIONS="TRAILBLAZER,SPIFLASH" CONFIG_BOOTDELAY=-2 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 378d75f..6dafb37 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index a55e4a3..2841eb6 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -2,6 +2,8 @@ CONFIG_X86=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="cougarcanyon2" CONFIG_TARGET_COUGARCANYON2=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index d0cd9db..30ddd94 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -8,6 +8,8 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 3b94de4..2faf300 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NET2BIG_V2=y CONFIG_IDENT_STRING=" D2 v2" CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="d2v2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 9c7d3c9..ac21424 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA114=y CONFIG_TARGET_DALMORE=y CONFIG_DEFAULT_DEVICE_TREE="tegra114-dalmore" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 245d0c7..c5fdcad 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 6149c94..cb07388 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index d0743c8..2494412 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index e2156a1..1f4c15c 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index 3b7a7c1..8d77864 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000,DIGSY_REV5" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 75888ff..56e14e1 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DIGSY_REV5" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index db5adcf..5042a82 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index e36f3dc..da741b4 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 450e13e..d748c39 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -3,6 +3,8 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_DNS325=y CONFIG_IDENT_STRING="\nD-Link DNS-325" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index ebcfe58..69db058 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 64f9cbc..351e133 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP44XX=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_DUOVERO=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index ca6705a..7fa34cb 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -3,6 +3,8 @@ CONFIG_TEGRA=y CONFIG_TEGRA210=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-e2220-1170" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (E2220-1170) # " # CONFIG_CMD_IMI is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 5e31c1b..d209de8 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_EA20=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index eb55e93..7c1ca1f 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -3,6 +3,8 @@ CONFIG_VENDOR_EFI=y CONFIG_DEFAULT_DEVICE_TREE="efi" CONFIG_TARGET_EFI=y CONFIG_FIT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/espresso7420_defconfig b/configs/espresso7420_defconfig index e782710..d3a3b25 100644 --- a/configs/espresso7420_defconfig +++ b/configs/espresso7420_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_IDENT_STRING=" for ESPRESSO7420" CONFIG_DEFAULT_DEVICE_TREE="exynos7420-espresso7420" CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="ESPRESSO7420 # " # CONFIG_AUTOBOOT is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 7ae03a6..c9612ef 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -6,6 +6,8 @@ CONFIG_TARGET_EVB_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 5d25ee4..e3ef029 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -6,6 +6,8 @@ CONFIG_TARGET_FENNEC_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-fennec" CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index f640fce..471273a 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_FIREFLY_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index 697a147..eda7a14 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -5,6 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y CONFIG_LOOPW=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 02a8a78..66cf6f4 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index f79ee2e..ecbf11b 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -9,6 +9,8 @@ CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 8577167..29010f3 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B450V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index c5f391e..e0eeb46 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B650V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 2c5aa05..9b4b917 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B850V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 8d67f77..34ec8aa 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -3,6 +3,8 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_GOFLEXHOME=y CONFIG_IDENT_STRING="\nSeagate GoFlex Home" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="GoFlexHome> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 913a763..b5f7d6f 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gurnard_defconfig b/configs/gurnard_defconfig index d2ef958..a2b484c 100644 --- a/configs/gurnard_defconfig +++ b/configs/gurnard_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="at91sam9g45-gurnard" CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 5198962..f3f3295 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -16,6 +16,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index 22f0759..3b031e0 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_H2200=y CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="> " # CONFIG_CMD_BDI is not set diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index c4bd2c5..0b13130 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -9,6 +9,8 @@ CONFIG_USB1_VBUS_PIN="PL6" CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-allwinner-h8homlet-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 270d2a3..5861769 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="HALEAKALA" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 4fbca28..cd70004 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_HARMONY=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 8012c07..ec9e6cf 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -7,6 +7,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 052454d..bd6b8cf 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3f" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index 03d7ec9..ab5015f 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3w" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 1901125..22b261e 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index d5e6309..5c95e27 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -17,6 +17,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-inet-d978-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 78cc3bb..2aeaf68 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 6da10ba..5ba346d 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -4,6 +4,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 66371d6..5584d5d 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/igep0030_nand_defconfig b/configs/igep0030_nand_defconfig index f63bcac..64305f4 100644 --- a/configs/igep0030_nand_defconfig +++ b/configs/igep0030_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 991d9d7..ca6d9f5 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_MTD_SUPPORT=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index 96252c3..a210abb 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y CONFIG_SYS_EXTRA_OPTIONS="IMX31_PHYCORE_EET" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 4fcd2d4..947bbe5 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 4ed94dc..b5bb6b6 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-inet86dz" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index bef3cd8..4636cf6 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet97fv2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 7c306f8..fc80308 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index cc051bd..d1750df 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet9f-rev03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index dcaaae4..81de9fd 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-inet-q972" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 3a5bf5e..430cc8a 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" IS v2" CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 6215c77..87ef11e 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index 54b873f..0042d3f 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_IPEK01=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_LOOPW=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 6e4e6ca..671dedd 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -8,6 +8,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 21b5747..8227b9c 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA124=y CONFIG_TARGET_JETSON_TK1=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-jetson-tk1" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 4827934..b73a2de 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_KC1=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="kc1 # " diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index f740b0b..a497408 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="KILAUEA" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 2df48c2..746eba6 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 7951f65..74d5f86 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index e75297e..808a981 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_NAND_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index a54cfc6..ce53a4c 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 84ab1bd..21c8705 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 074d18e..88344ba 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index ad40e12..f4efb45 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 6812bfb..7a35354 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index e226071..f8a3d50 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index e5a0eca..fdbcbf0 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 43ba7fe..dce1592 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -7,6 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 8cfaeaf..cd37246 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 4762425..07f7023 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_QSPI_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 25760e4..ab1a558 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -15,6 +15,7 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SECURE_BOOT" CONFIG_BOOTDELAY=0 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_CRYPTO_SUPPORT=y CONFIG_SPL_HASH_SUPPORT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 5f9efdf..52dc6f0 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index e272ea7..6e7289e 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_SD_BOOT=y CONFIG_BOOTDELAY=3 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT=y CONFIG_HUSH_PARSER=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 5393084..834d822 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-CHLv2" CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 48bacaa..fb7d90f 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-XHL" CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index b6a0bef..609a218 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_LWMON5=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 46f427b..2f691c6 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 9779ae4..c08b2d2 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index bb9ee2f..3e45de5 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index dd94d22..a31d213 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index eb88e6b..a3d233d 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -5,6 +5,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_MCX=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mcx # " diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 24cace6..e5ae55c 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_MEDCOM_WIDE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-medcom-wide" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 15c6b00..61bfcd7 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="microblaze-generic" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=-1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_NOR_SUPPORT=y diff --git a/configs/miniarm-rk3288_defconfig b/configs/miniarm-rk3288_defconfig index 557fdfc..ee00484 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/miniarm-rk3288_defconfig @@ -6,6 +6,8 @@ CONFIG_TARGET_MINIARM_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-miniarm" CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 3d3a30d..f54a58b 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -15,6 +15,8 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 8ca8467..f18add0 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -8,6 +8,7 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index bfd591a..325c6b1 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -7,6 +7,7 @@ CONFIG_DRAM_EMR1=0 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 47bbf62..bef2880 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -5,6 +5,7 @@ CONFIG_USB2_VBUS_PIN="PH12" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index f9516d1..33f9061 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802ii" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index ffa23ad..e7fb6c5 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -4,6 +4,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_MT_VENTOUX=y CONFIG_FIT=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 8db7064..e70eaf7 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index e7bb119..638be85 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 19467d7..4e8d5da 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index d4f14a8..afddfb3 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 569e72c..6eec4be 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index c903b41..d68d001 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX51EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index b75ba01..0bd4f26 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX53LOCO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 27c3d3b..8128a7b 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index 5f4b979..e911efa 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 300e9d9..5b3d66d 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 891f819..40a6bb6 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 08c9bb7..474aac9 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 4b42d08..786d4b5 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 2bfdd53..de45698 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index e9edba6..9cfeae9 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index c9bd1f0..96209e5 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index d013cb0..8fdd0cf 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index a829a18..f878970 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y @@ -30,10 +31,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_FSL_QSPI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index eaf3cfd..4b5b41a 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y @@ -30,10 +31,10 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_FSL_QSPI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 8eac2b7..98c5f5d 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -6,6 +6,7 @@ CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index 0a43134..5e83633 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -6,6 +6,7 @@ CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set CONFIG_CMD_BOOTZ=y diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 5adf1ff..960d04c 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -6,6 +6,8 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-neo" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 122ed7a..d3794ac 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NET2BIG_V2=y CONFIG_IDENT_STRING=" 2Big v2" CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="2big2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 0547aa6..6e4a1f0 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2 Lite" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index e72815d..c213a1c 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS Max v2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 1422787..5a1a002 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2 Mini" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 6373255..5af1943 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 849772f..3eaed06 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 4a62c56..d45081d 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 68cdb89..f9c9d35 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index a380502..e55d689 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 3c7b903..0dd1ab9 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 590bb27..4fd9eed 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index da10392..9db8b86 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_NOKIA_RX51=y CONFIG_BOOTDELAY=30 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Nokia RX-51 # " CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 1ffdddc..3f5a9d2 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -13,6 +13,8 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 26ee388..9c9ea7d 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra124-nyan-big" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Nyan-big) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 177434e..f969725 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -7,6 +7,8 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 4e47032..a3e6f1b 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4412-odroid" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Odroid # " CONFIG_CMD_BOOTZ=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index 0c2c12b..0ee349c 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_PANDORA=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Pandora # " diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index e92d9c6..3f255ea 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_ZOOM1=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index e496afe..43283c2 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -4,6 +4,7 @@ CONFIG_OMAP44XX=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_OMAP4_PANDA=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index ea62104..37461f9 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP44XX=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_OMAP4_SDP4430=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 2207b81..d736cbe 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -8,6 +8,8 @@ CONFIG_DRAM_ODT_EN=y CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_lite_defconfig b/configs/orangepi_lite_defconfig index a72d506..a6fe5de 100644 --- a/configs/orangepi_lite_defconfig +++ b/configs/orangepi_lite_defconfig @@ -6,6 +6,8 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-lite" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 5a7aba1..621b428 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -6,6 +6,8 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 3f8010c..dc2f965 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -7,6 +7,8 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_pc_plus_defconfig b/configs/orangepi_pc_plus_defconfig index f8f6dab..ff983c8 100644 --- a/configs/orangepi_pc_plus_defconfig +++ b/configs/orangepi_pc_plus_defconfig @@ -8,6 +8,8 @@ CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index cfae5f0..0c7989f 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -9,6 +9,8 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 6c99aa2..2d5c611 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -10,6 +10,8 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11),MACPWR=SUNXI_GPD(6)" +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 0eff767..5875556 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -4,6 +4,7 @@ CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ORIGEN=y CONFIG_IDENT_STRING=" for ORIGEN" CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ORIGEN # " diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 7a6b823..ea02d59 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2371_0000=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-0000" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-0000) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 180dde3..6b5bf43 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2371_2180=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-2180" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index fa6ca23..3d66ded 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2571=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2571" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2571) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index 4c4606a..1c19680 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -3,6 +3,8 @@ CONFIG_TEGRA=y CONFIG_TEGRA186=y CONFIG_DEFAULT_DEVICE_TREE="tegra186-p2771-0000-000" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-000) # " # CONFIG_CMD_IMI is not set diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index b32df1c..46b7676 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -3,6 +3,8 @@ CONFIG_TEGRA=y CONFIG_TEGRA186=y CONFIG_DEFAULT_DEVICE_TREE="tegra186-p2771-0000-500" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra186 (P2771-0000-500) # " # CONFIG_CMD_IMI is not set diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index ffe15e5..ac0242d 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -11,6 +11,7 @@ CONFIG_USB1_VBUS_PIN="PD12" CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-r16-parrot" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index b86f76c..5cf6cfd 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_PAZ00=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-paz00" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " CONFIG_CMD_BOOTZ=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index e5f34a1..33b7f70 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pi # " diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index ddcb451..c2b6d97 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pit # " diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 2536ca7..a3a4f5d 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 6f82190..9986ae1 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -6,6 +6,8 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881915 CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index b1997fe..49363cc 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -5,6 +5,8 @@ CONFIG_TARGET_PLUTUX=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-plutux" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 361e9bb..63637e7 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9261=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="pm9261> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index f9f56d2..7ffde4b 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9263=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 2ac6f4c..d6d16d4 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index d9bcd4f..d9b6051 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index d7f60a1..2641af1 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -6,6 +6,8 @@ CONFIG_TARGET_POPMETAL_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 8e81e69..b79b6be 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 6b516db..66be94a 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 971dcea..02da50f 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index f99e347..73de6bd 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 182bd9a..a2a8444 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 769adf6..293d7f0 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -8,6 +8,8 @@ CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 75e7203..6c46d8f 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -5,6 +5,8 @@ CONFIG_MAX_CPUS=2 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 4bcd0dc..6980bf1 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -5,6 +5,8 @@ CONFIG_MAX_CPUS=2 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index afbc9a6..35f0908 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=384 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index c0e647e..744ef2d 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 7030fe4..8c85258 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 652b13f..e9e5191 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 5ba7769..02f891d 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_ROCK2=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index bda4e95..c95385c 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_2=y CONFIG_OF_BOARD_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 8e2c410..9b1dbfd 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_3_32B=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OF_BOARD_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index b7354eb..0596281 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -3,6 +3,8 @@ CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_3=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OF_BOARD_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index ea39231..d511a33 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI=y CONFIG_OF_BOARD_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index b381e21..8d59ca2 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_S5PC1XX=y CONFIG_TARGET_S5P_GONI=y CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-goni" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Goni # " # CONFIG_AUTOBOOT is not set diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 5eb7a40..cfc6017 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_S5PC210_UNIVERSAL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-universal_c210" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Universal # " CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index ccc0b19..8cee4c2 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 2ed8a33..8dc5e24 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 81be7f5..019869c 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_SERIALFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index e7398dd..f9c766a 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index e4032f9..c8456d0 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 903ddcb..a061c4d 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 143dd09..cf68de6 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y diff --git a/configs/sandbox_noblk_defconfig b/configs/sandbox_noblk_defconfig index 9ad5274..9b6e939 100644 --- a/configs/sandbox_noblk_defconfig +++ b/configs/sandbox_noblk_defconfig @@ -16,6 +16,7 @@ CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index cd6f694..d43131b 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -23,6 +23,7 @@ CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index de07139..4ede451 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 12cc9b6..3b73b30 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_SEABOARD=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-seaboard" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 9bdab0b..5304bf4 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 65ae39a..2a8193d 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index de62cb3..f731e83 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -7,6 +7,8 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 04521f2..a6f182a 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -7,6 +7,8 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index a44082e..02b51c4 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_SNIPER=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="sniper # " diff --git a/configs/snow_defconfig b/configs/snow_defconfig index a5754f8..949b38c 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="snow # " diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index abb89b2..45dc5eb 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index c73a9f2..76e2256 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index fa174be..43930ac 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 5c80372..dacdfeb 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_IS1=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index e6f2a81..73e13a9 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_DENX_MCVEVK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 16d06d2..65d4554 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 7cc6f32..1694438 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_EBV_SOCRATES=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index fa15fc3..8274e0b 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_FIT=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index a5a9501..5e9cbb6 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_FIT=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 75db38f..fd79510 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 4cfaeda..c59f8a3 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 0c394c8..87e7dcd 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_SILENT_CONSOLE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="spring # " diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 7309022..43394e8 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-gemei-g9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 0871408..1905b85 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -5,6 +5,8 @@ CONFIG_PRE_CONSOLE_BUFFER=y CONFIG_PRE_CON_BUF_ADDR=0x7c000000 CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " CONFIG_CMD_BOOTZ=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 9441b17..2258077 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -5,6 +5,8 @@ CONFIG_TARGET_TEC_NG=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-tec-ng" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index d8ecde2..6feb59b 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_TEC=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-tec" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TEC) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index cea91b6..cff59ec 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -14,6 +14,8 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 1362ffb..485f9d7 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4412-trats2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats2 # " CONFIG_CMD_BOOTZ=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 525bbef..d18e4f2 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_TRATS=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-trats" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats # " CONFIG_CMD_BOOTZ=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 201a870..09fc4c4 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA20=y CONFIG_TARGET_TRIMSLICE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index bd6c96c..688a8f9 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA124=y CONFIG_TARGET_VENICE2=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-venice2" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 8288c86..09f5fa5 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_VENTANA=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-ventana" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 5a91de4..345a25b 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index 33aa977..9eff63d 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -4,6 +4,8 @@ CONFIG_TEGRA20=y CONFIG_TARGET_WHISTLER=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-whistler" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_CONSOLE_MUX=y +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Whistler) # " CONFIG_CMD_BOOTZ=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 9f0c378..55b1442 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 8710307..311e52a 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -485,9 +485,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ -#endif
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 92c69e5..458c3b0 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -231,8 +231,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_NS16550_MIN_FUNCTIONS #endif
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ - #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 4276f65..059456f 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -411,8 +411,6 @@ combinations. this should be removed later #define CONFIG_NS16550_MIN_FUNCTIONS #endif
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index a61e25c..a448e1f 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -374,8 +374,6 @@ #define CONFIG_NS16550_MIN_FUNCTIONS #endif
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index bf75209..b006e31 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -105,7 +105,6 @@ /*************************************************************** * defines if the console is stored in the environment ***************************************************************/ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* stdin, stdout and stderr are in evironment */ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index ab8993b..9dca8c7 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -578,8 +578,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_NS16550_MIN_FUNCTIONS #endif
diff --git a/include/configs/PATI.h b/include/configs/PATI.h index ebabdff..c8d0a58 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -57,7 +57,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* stdin, stdout and stderr are in evironment */ #define CONFIG_PREBOOT
#define CONFIG_SYS_LONGHELP /* undef to save memory */ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 7d08f0c..d6c38c7 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -101,7 +101,6 @@ /*************************************************************** * defines if the console is stored in the environment ***************************************************************/ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* stdin, stdout and stderr are in evironment */ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index 956c787..aceddc4 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -286,8 +286,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ - #define CONFIG_SUPPORT_VFAT
/*----------------------------------------------------------------------- diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index eb3cfc0..6934e65 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -494,7 +494,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
/* Video */ #ifdef CONFIG_PPC_T1024 /* no DIU on T1023 */ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 0d6051e..c363719 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -494,7 +494,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
/* Video */ #undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index d64611a..5f25d55 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -407,7 +407,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
/* Video */ #define CONFIG_FSL_DIU_FB diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index e115bdd..8e2f299 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -475,9 +475,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ -#endif
#if defined(CONFIG_T1042RDB_PI) || defined(CONFIG_T1042D4RDB) /* Video */ diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 814b879..19703cd 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -113,7 +113,6 @@ #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif /* #ifndef CONFIG_TQM5200S */
/* Partitions */ diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index a09224b..f3e4f77 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -54,7 +54,6 @@ #define CONFIG_BOOTP_SERVERIP #define CONFIG_NET_RETRY_COUNT 3 #define CONFIG_NETCONSOLE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* needed for UBI */ #define CONFIG_FLASH_CFI_MTD diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 992948a..22410ce 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -279,7 +279,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 698c924..fdfbb55 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -112,7 +112,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 /* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 #define CONFIG_USBD_PRODUCTID 0x5678 diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 6dc419e..7d6a7bf 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -238,7 +238,6 @@ /* check this console not needed, after test remove it */ #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 867bd69..591c7d4 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -61,8 +61,6 @@ #define CONFIG_ATMEL_LCD_BGR555 #endif
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /* LED */ #define CONFIG_AT91_LED #define CONFIG_RED_LED AT91_PIN_PA23 /* this is the power led */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 854caf3..ecc87ea 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK 1 #define CONFIG_ATMEL_LCD 1 #define CONFIG_ATMEL_LCD_BGR555 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* LED */ #define CONFIG_AT91_LED diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 9968b14..e89c19b 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -50,7 +50,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_LCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* board specific(not enough SRAM) */ #define CONFIG_AT91SAM9G45_LCD_BASE 0x73E00000
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index c3d07a1..a54e59e 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -49,7 +49,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index a383de6..1bbfb9e 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -57,7 +57,6 @@ #define CONFIG_ATMEL_LCD_RGB565 1 /* Let board_init_f handle the framebuffer allocation */ #undef CONFIG_FB_ADDR -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* LED */ #define CONFIG_AT91_LED diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 716f8d0..34f452e 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -45,7 +45,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 85510f0..277f36e 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -41,7 +41,6 @@
#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
/* As stated above, the following choices are optional. */ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 36a29f1..637bed2 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -97,7 +97,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 46584fd..4e08846 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -259,8 +259,6 @@ #define CONFIG_IMX_HDMI #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX #define CONFIG_VIDEO_SW_CURSOR
#define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index e4c9358..0cd2f3c 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -102,7 +102,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE #define CONFIG_USB_TTY -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* commands to include */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index a408fbf..893d637 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -85,7 +85,6 @@ #define CONFIG_CONS_INDEX 3 #define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 #define CONFIG_SERIAL3 3 /* UART3 */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 2ec392e..84c958d 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -234,7 +234,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index fbe9c82..37972a8 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -340,8 +340,6 @@
#define CONFIG_SYS_EXTRA_ENV_RELOC
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /* * Command line configuration. */ diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index c1abcb6..78eb567 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -452,8 +452,6 @@ #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL /* _VIA_CONTROL_EP */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
#ifdef CONFIG_MMC diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 8cf0283..c2ad92d 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -84,7 +84,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 23c173e..68ce795 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -77,8 +77,6 @@ /* * Console configuration */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* * Display cpu info at boot diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 910bcd4..ee58dcb 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -111,7 +111,6 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #endif
diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 809ec21..87f16d9 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -121,7 +121,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 111b23d..12ceb2c 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -42,8 +42,6 @@ /* select serial console configuration */ #define CONFIG_BAUDRATE 115200 #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX
#define CONFIG_CMD_HASH
diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index 907b5ea..e8c0eaf 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -54,8 +54,6 @@
/* select serial console configuration */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX
#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000)
diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 52f096e..435b0ca 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -302,7 +302,6 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index ae6539c..c17c5e9 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -43,8 +43,6 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_CMD_ENV #define CONFIG_CMD_NAND diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index b7945c2..904fdda 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -185,11 +185,9 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 3e419c6..8e77982 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -131,7 +131,6 @@
#define CONFIG_BOOTARGS "root=/dev/ram0 ro console=ttyS0,115200n8"
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_USB_DEV_PULLUP_GPIO 33 /* USB VBUS GPIO 3 */
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 50dfc11..614e2ad 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -187,7 +187,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP diff --git a/include/configs/io64.h b/include/configs/io64.h index 894da84..7f2cbd5 100644 --- a/include/configs/io64.h +++ b/include/configs/io64.h @@ -394,8 +394,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x00800000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /*----------------------------------------------------------------------- * External Bus Controller (EBC) Setup *----------------------------------------------------------------------*/ diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 126e02e..16eee33 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -54,7 +54,6 @@ #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 32be528..61fcab2 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -135,8 +135,6 @@ * Console */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index 227504f..9741398 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -387,8 +387,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x00800000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ - /*----------------------------------------------------------------------- * PCI stuff *----------------------------------------------------------------------*/ diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index bd6c83e..3e670e6 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -145,8 +145,6 @@ /* * Console configuration */ -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* * Environment variables configurations diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index c641234..0907e02 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -449,7 +449,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_I2C_DVI_BUS_NUM 0 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index d3ef614..d05141a 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -337,7 +337,6 @@ #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_FSL_DCU_SII9022A #define CONFIG_SYS_I2C_DVI_BUS_NUM 1 diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index baa35db..6084c8e 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -36,7 +36,6 @@ #define CONFIG_KIRKWOOD_GPIO
#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_INFO_QUIET
/* diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 7b88ad5..d8398ee 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -255,7 +255,6 @@ /* Reserve GPT0_COMP1-COMP5 for logbuffer header */ #define CONFIG_ALT_LH_ADDR (CONFIG_SYS_PERIPHERAL_BASE + GPT0_COMP1) #define CONFIG_ALT_LB_ADDR (CONFIG_SYS_OCM_BASE) -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */
/* * I2C diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index b159fde..d39d69c 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -205,7 +205,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index b156e42..8fe5db6 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -82,7 +82,6 @@ #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_ATMEL_HLCD -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
/* diff --git a/include/configs/makalu.h b/include/configs/makalu.h index dcfe3d7..dea340d 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -252,8 +252,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x00800000 /* free virtual address */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* Otherwise it catches logbuffer as output */ - /*----------------------------------------------------------------------- * PCI stuff *----------------------------------------------------------------------*/ diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 03c1c91..679826b 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -379,6 +379,5 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP #define CONFIG_VIDEO_OMAP3 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#endif /* __CONFIG_H */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index c744d16..ab24da4 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -259,8 +259,6 @@
#define CONFIG_CMDLINE_EDITING
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV - /* Enable flat device tree support */ #define CONFIG_LMB 1
diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 29564d7..5f44d5f 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -58,7 +58,6 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP #define CONFIG_VIDEO_OMAP3 /* DSS Support */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \ "bootcmd=run net_nfs\0" diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 072aafd..7a3f1f3 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -100,7 +100,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index d259f53..69245f1 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -219,7 +219,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 237ef04..d48fcc2 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -38,7 +38,6 @@ #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN @@ -48,7 +47,6 @@ #define CONFIG_IMX_HDMI #define CONFIG_CMD_HDMIDETECT #define CONFIG_IMX_VIDEO_SKIP -#define CONFIG_CONSOLE_MUX
/* USB */ #define CONFIG_USB_EHCI diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 1ee880d..656b9f7 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -212,7 +212,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 4c61999..70f2162 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -212,7 +212,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 925a418..37bd13e 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -235,7 +235,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index f6a636d..d15b546 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -264,7 +264,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mxs.h b/include/configs/mxs.h index d15dd5f..634556d 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -147,7 +147,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
/* MMC */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 6ad4a3e..c66a936 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -96,7 +96,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN @@ -106,7 +105,6 @@ #define CONFIG_BMP_16BPP #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index cdae544..e9086b0 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -118,7 +118,6 @@ #define CONFIG_USBD_MANUFACTURER "Nokia" #define CONFIG_USBD_PRODUCT_NAME "N900"
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_NO_FLASH
/* commands to include */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 8cb0282..cba0604 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -164,14 +164,12 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT -#define CONFIG_CONSOLE_MUX #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP #endif diff --git a/include/configs/odroid.h b/include/configs/odroid.h index a28244d..704d1e7 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -44,7 +44,6 @@
/* Console configuration */ #define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 740b588..4cdf178 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -244,7 +244,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE #define CONFIG_USB_TTY -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 1f30710..2f372ad 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -65,7 +65,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index b664319..49f3f41 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -29,7 +29,6 @@
#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 #define CONFIG_SYS_DEVICE_NULLDEV 1
/* diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index 6397051..8c056e9 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -55,7 +55,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 /* Change these to suit your needs */ #define CONFIG_USBD_VENDORID 0x0451 #define CONFIG_USBD_PRODUCTID 0x5678 diff --git a/include/configs/origen.h b/include/configs/origen.h index 0f76d32..a075b54 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -38,7 +38,6 @@
/* Console configuration */ #define CONFIG_SYS_CONSOLE_INFO_QUIET -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 206bfa7..8ebf336 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -53,7 +53,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_LCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV /* board specific(not enough SRAM) */ #define CONFIG_AT91SAM9G45_LCD_BASE 0x23E00000
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 537a6d8..fbb7146 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -160,7 +160,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK 1 #define CONFIG_ATMEL_LCD 1 #define CONFIG_ATMEL_LCD_BGR555 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* LED */ #define CONFIG_AT91_LED diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 9993248..a4672b0 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -173,7 +173,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK 1 #define CONFIG_ATMEL_LCD 1 #define CONFIG_ATMEL_LCD_BGR555 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
#define CONFIG_LCD_IN_PSRAM 1
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 7ac3a5e..d033866 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -39,11 +39,6 @@ #define CONFIG_SPL_STACK 0xff718000 #define CONFIG_SPL_TEXT_BASE 0xff704004
-#ifndef CONFIG_SPL_BUILD -# define CONFIG_SYS_CONSOLE_IS_IN_ENV -# define CONFIG_CONSOLE_MUX -#endif - /* MMC/SD IP block */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 8d4ad5d..decf35a 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -130,8 +130,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_SYS_LOAD_ADDR 0x1000000 -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_PREBOOT "usb start"
/* Shell */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 61c5663..2a6e217 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -137,7 +137,6 @@ #define CONFIG_MISC_INIT_R
#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 9915306..e2d814f 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -30,7 +30,6 @@
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index e684d2a..c20d6f9 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
#ifdef CONFIG_SYS_USE_MMC diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 8b73a1b..c149e5b 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -48,7 +48,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
/* board specific (not enough SRAM) */ #define CONFIG_SAMA5D3_LCD_BASE 0x23E00000 diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index c90e1e6..0890cf5 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -104,7 +104,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif
#ifdef CONFIG_SYS_USE_SERIALFLASH diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index b9927e9..36da48c 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -103,7 +103,6 @@ #define CONFIG_SYS_WHITE_ON_BLACK #define CONFIG_ATMEL_HLCD #define CONFIG_ATMEL_LCD_RGB565 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#ifdef CONFIG_SYS_USE_SERIALFLASH /* override the bootcmd, bootargs and other configuration for spi flash env*/ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index bd005fc..b6533c3 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -149,8 +149,6 @@ /* LCD and keyboard require SDL support */ #ifdef CONFIG_SANDBOX_SDL #define CONFIG_CMD_BMP -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define LCD_BPP LCD_COLOR16 #define CONFIG_LCD_BMP_RLE8 #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index ac783d3..1afe374 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -266,8 +266,6 @@ #define CONFIG_LOGBUFFER #define CONFIG_SYS_POST_CACHE_ADDR 0x7fff0000 /* free virtual address */
/* diff --git a/include/configs/snapper9g45.h b/include/configs/snapper9g45.h index aab286f..6ccb31d 100644 --- a/include/configs/snapper9g45.h +++ b/include/configs/snapper9g45.h @@ -78,8 +78,6 @@
/* LCD */ #define CONFIG_ATMEL_LCD -#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_GURNARD_SPLASH
#define CONFIG_ATMEL_SPI diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 3bc9819..3fe5983 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -146,8 +146,6 @@ * Console */
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 93fe315..ba2004e 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -256,7 +256,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* * U-Boot environment */ -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_ENV_OVERWRITE #if !defined(CONFIG_ENV_SIZE) diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 29f9522..85cc457 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -179,7 +179,6 @@ #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 16c86d9..b06514a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -298,7 +298,6 @@ extern int soft_i2c_gpio_scl; #define VIDEO_LINE_LEN (pGD->plnSizeX)
/* allow both serial and cfb console. */ -#define CONFIG_CONSOLE_MUX /* stop x86 thinking in cfbconsole from trying to init a pc keyboard */ #define CONFIG_VGA_AS_SINGLE_DEVICE
@@ -357,7 +356,6 @@ extern int soft_i2c_gpio_scl; #endif
#ifdef CONFIG_USB_KEYBOARD -#define CONFIG_CONSOLE_MUX #define CONFIG_PREBOOT #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE @@ -371,7 +369,6 @@ extern int soft_i2c_gpio_scl; #endif
#define CONFIG_MISC_INIT_R -#define CONFIG_SYS_CONSOLE_IS_IN_ENV
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index ddd53dd..d470e04 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -46,8 +46,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */ #define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CONSOLE_MUX #define CONFIG_CONS_INDEX 1
/* *** Command definition *** */ diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 29614e0..6a344a4 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -66,8 +66,6 @@
-#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_STDIO_DEREGISTER #endif diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 4115c78..52c0563 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -75,7 +75,6 @@ /* USB device configuration */ #define CONFIG_USB_DEVICE 1 #define CONFIG_USB_TTY 1 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* * Environment setup diff --git a/include/configs/trats.h b/include/configs/trats.h index 22b0c90..9fc6513 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -42,7 +42,6 @@
/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ #define MACH_TYPE_TRATS 3928 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 1febaae..c437c13 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -39,7 +39,6 @@
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 69d0fd5..1b99719 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -78,7 +78,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 74b2522..42c8f0a 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -62,8 +62,6 @@ 9600, 19200, 38400, 115200} #define CONFIG_SYS_NS16550_PORT_MAPPED
-#define CONFIG_CONSOLE_MUX -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_STDIO_DEREGISTER
#define CONFIG_CMDLINE_EDITING diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 28fc43d..196cd6c 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -679,7 +679,6 @@ CONFIG_CONSOLE CONFIG_CONSOLE_DEV CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET -CONFIG_CONSOLE_MUX CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE @@ -4629,7 +4628,6 @@ CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_ENV_OVERWRITE CONFIG_SYS_CONSOLE_FG_COL CONFIG_SYS_CONSOLE_INFO_QUIET -CONFIG_SYS_CONSOLE_IS_IN_ENV CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE
On Sat, Sep 24, 2016 at 06:17:00PM -0600, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_IS_IN_ENV CONFIG_CONSOLE_MUX
Signed-off-by: Simon Glass sjg@chromium.org
Changes in v2:
- Make CONSOLE_MUX default y if DM_VIDEO || VIDEO || LCD
README | 6 ------ common/Kconfig | 20 ++++++++++++++++++++
[snip]
diff --git a/common/Kconfig b/common/Kconfig index 6ee67ac..8e600f7 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -288,6 +288,26 @@ config PRE_CON_BUF_ADDR We should consider removing this option and allocating the memory in board_init_f_init_reserve() instead.
+config CONSOLE_MUX
- bool "Enable console multiplexing"
- default y if DM_VIDEO || VIDEO || LCD
- help
This allows multiple devices to be used for each console 'file'.
For example, stdout can be set to go to serial and video.
Similarly, stdin can be set to come from serial and keyboard.
Input can be provided from either source. Console multiplexing
adds a small amount of size to U-Boot. Changes to the environment
variables stdout, stdin and stderr will take effect immediately.
+config SYS_CONSOLE_IS_IN_ENV
- bool "Select console devices from the environment"
- help
This allows multiple input/output devices to be set at boot time.
For example, if stdout is set to "serial,video" then output will
be sent to both the serial and video devices on boot. The
environment variables can be updated after boot to change the
input/output devices.
OK, it looks like we should say SYS_CONSOLE_IS_IN_ENV is default y if CONSOLE_MUX. This won't cover all of the defconfig additions (something else needs to be done for boards with > 1 uart and not all of that is in Kconfig yet either) but it will help.
This is not really a config. Rename it to avoid confusion.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
include/configs/MPC8349ITX.h | 6 +++--- scripts/config_whitelist.txt | 1 - 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 177718e..0fbc1fd 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -358,7 +358,7 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
-#define CONFIG_CONSOLE ttyS0 +#define CONSOLE ttyS0 #define CONFIG_BAUDRATE 115200
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) @@ -740,10 +740,10 @@ boards, we say we have two, but don't display a message if we find only one. */ __stringify(CONFIG_GATEWAYIP) ":" \ __stringify(CONFIG_NETMASK) ":" \ CONFIG_HOSTNAME ":" CONFIG_NETDEV ":off" \ - " console=" __stringify(CONFIG_CONSOLE) "," __stringify(CONFIG_BAUDRATE) + " console=" __stringify(CONSOLE) "," __stringify(CONFIG_BAUDRATE)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "console=" __stringify(CONFIG_CONSOLE) "\0" \ + "console=" __stringify(CONSOLE) "\0" \ "netdev=" CONFIG_NETDEV "\0" \ "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 196cd6c..40e621e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -675,7 +675,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE CONFIG_CONSOLE_DEV CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET
Changes in v2: None
include/configs/advantech_dms-ba16.h | 4 ++-- include/configs/aristainetos-common.h | 2 +- include/configs/aristainetos.h | 2 +- include/configs/aristainetos2.h | 2 +- include/configs/aristainetos2b.h | 2 +- include/configs/cgtqmx6eval.h | 4 ++-- include/configs/el6x_common.h | 2 +- include/configs/embestmx6boards.h | 2 +- include/configs/ge_bx50v3.h | 4 ++-- include/configs/mx6cuboxi.h | 4 ++-- include/configs/mx6qsabreauto.h | 2 +- include/configs/mx6sabre_common.h | 2 +- include/configs/mx6sabresd.h | 2 +- include/configs/o2dnt-common.h | 6 +++--- include/configs/pcm058.h | 2 +- include/configs/tqma6.h | 2 +- include/configs/tqma6_mba6.h | 2 +- include/configs/tqma6_wru4.h | 2 +- include/configs/zc5202.h | 2 +- include/configs/zc5601.h | 2 +- scripts/config_whitelist.txt | 1 - 21 files changed, 26 insertions(+), 27 deletions(-)
diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 22410ce..4f07f23 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -16,7 +16,7 @@ #define CONFIG_DEFAULT_FDT_FILE "imx6q-dms-ba16.dtb"
#define CONFIG_MXC_UART_BASE UART4_BASE -#define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONSOLE_DEV "ttymxc3" #define CONFIG_EXTRA_BOOTARGS "panic=10"
#define CONFIG_BOOT_DIR "" @@ -117,7 +117,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=yes\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "sddev=0\0" \ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 7d6a7bf..c31d9ad 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -57,7 +57,7 @@ "rescue_sys_length=f10000\0" \ "panel=lb07wv8\0" \ "splashpos=m,m\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ diff --git a/include/configs/aristainetos.h b/include/configs/aristainetos.h index be93deb..1799cc1 100644 --- a/include/configs/aristainetos.h +++ b/include/configs/aristainetos.h @@ -18,7 +18,7 @@ #define CONFIG_BOARDNAME "aristainetos"
#define CONFIG_MXC_UART_BASE UART5_BASE -#define CONFIG_CONSOLE_DEV "ttymxc4" +#define CONSOLE_DEV "ttymxc4"
#define CONFIG_FEC_XCV_TYPE RMII
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 152f5e9..8fa3eb5 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -19,7 +19,7 @@ #define CONFIG_BOARD_LATE_INIT
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1"
#define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_PHY_MICREL_KSZ9031 diff --git a/include/configs/aristainetos2b.h b/include/configs/aristainetos2b.h index 78791db..df9b5c9 100644 --- a/include/configs/aristainetos2b.h +++ b/include/configs/aristainetos2b.h @@ -19,7 +19,7 @@ #define CONFIG_BOARD_LATE_INIT
#define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_PHY_MICREL_KSZ9031 diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 637bed2..6a25f2b 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -133,7 +133,7 @@ /* Command definition */
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1" #define CONFIG_MMCROOT "/dev/mmcblk0p2" #define CONFIG_SYS_MMC_ENV_DEV 0
@@ -145,7 +145,7 @@ "fdt_addr_r=0x18000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "dfuspi=dfu 0 sf 0:0:10000000:0\0" \ "dfu_alt_info_spl=spl raw 0x400\0" \ "dfu_alt_info_img=u-boot raw 0x10000\0" \ diff --git a/include/configs/el6x_common.h b/include/configs/el6x_common.h index 81b79b2..7e9bcb1 100644 --- a/include/configs/el6x_common.h +++ b/include/configs/el6x_common.h @@ -73,7 +73,7 @@ "board="__stringify(CONFIG_BOARD_NAME)"\0" \ "cma_size="__stringify(EL6Q_CMA_SIZE)"\0" \ "chp_size="__stringify(EL6Q_COHERENT_POOL_SIZE)"\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdtfile=undefined\0" \ "fdt_high=0xffffffff\0" \ "fdt_addr_r=0x18000000\0" \ diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 87f16d9..6266d95 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -14,7 +14,7 @@ #define __RIOTBOARD_CONFIG_H
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1" #define CONFIG_MMCROOT "/dev/mmcblk1p2"
#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 435b0ca..cf805b3 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -30,7 +30,7 @@ #endif
#define CONFIG_MXC_UART_BASE UART3_BASE -#define CONFIG_CONSOLE_DEV "ttymxc2" +#define CONSOLE_DEV "ttymxc2"
#define CONFIG_SUPPORT_EMMC_BOOT
@@ -139,7 +139,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=yes\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "sddev=0\0" \ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index d48fcc2..6e4a4f8 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -72,7 +72,7 @@ /* Command definition */
#define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONSOLE_DEV "ttymxc0" +#define CONSOLE_DEV "ttymxc0" #define CONFIG_SYS_FSL_USDHC_NUM 1 #define CONFIG_SYS_MMC_ENV_DEV 0 /* SDHC2 */
@@ -90,7 +90,7 @@ "initrd_high=0xffffffff\0" \ "fdt_high=0xffffffff\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "bootm_size=0x10000000\0" \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "update_sd_firmware=" \ diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 9cf3c2c..f849f34 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -11,7 +11,7 @@
#define CONFIG_MACH_TYPE 3529 #define CONFIG_MXC_UART_BASE UART4_BASE -#define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONSOLE_DEV "ttymxc3" #define CONFIG_MMCROOT "/dev/mmcblk0p2"
/* USB Configs */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 656b9f7..ff0e4db 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -74,7 +74,7 @@ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "dfuspi=dfu 0 sf 0:0:10000000:0\0" \ "dfu_alt_info_spl=spl raw 0x400\0" \ "dfu_alt_info_img=u-boot raw 0x10000\0" \ diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 5c2734d..789c407 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -15,7 +15,7 @@
#define CONFIG_MACH_TYPE 3980 #define CONFIG_MXC_UART_BASE UART1_BASE -#define CONFIG_CONSOLE_DEV "ttymxc0" +#define CONSOLE_DEV "ttymxc0" #define CONFIG_MMCROOT "/dev/mmcblk1p2"
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 8913784..e9cf190 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -95,8 +95,8 @@
#undef CONFIG_BOOTARGS
-#if !defined(CONFIG_CONSOLE_DEV) -#define CONFIG_CONSOLE_DEV "ttyPSC1" +#if !defined(CONSOLE_DEV) +#define CONSOLE_DEV "ttyPSC1" #endif
/* @@ -131,7 +131,7 @@ "addmem=setenv bootargs ${bootargs} ${memlimit}\0" \ "addmisc=sete bootargs ${bootargs} ${miscargs}\0" \ "addtty=sete bootargs ${bootargs} console=" \ - CONFIG_CONSOLE_DEV ",${baudrate}\0" \ + CONSOLE_DEV ",${baudrate}\0" \ "bootfile="CONFIG_BOARD_NAME"/uImage_"CONFIG_BOARD_NAME"_act\0" \ "kernel_addr_r=600000\0" \ "initrd_high=0x03e00000\0" \ diff --git a/include/configs/pcm058.h b/include/configs/pcm058.h index 193f06e..a6398d6 100644 --- a/include/configs/pcm058.h +++ b/include/configs/pcm058.h @@ -24,7 +24,7 @@ /* Serial */ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1"
diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 029eddd..983153f 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -295,7 +295,7 @@ "uboot=u-boot.imx\0" \ "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr="__stringify(TQMA6_FDT_ADDRESS)"\0" \ - "console=" CONFIG_CONSOLE_DEV "\0" \ + "console=" CONSOLE_DEV "\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "addtty=setenv bootargs ${bootargs} console=${console},${baudrate}\0" \ diff --git a/include/configs/tqma6_mba6.h b/include/configs/tqma6_mba6.h index 2f52598..3cae4fe 100644 --- a/include/configs/tqma6_mba6.h +++ b/include/configs/tqma6_mba6.h @@ -25,6 +25,6 @@ #define CONFIG_PHY_KSZ9031
#endif /* __CONFIG_TQMA6_MBA6_H */ diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index 8896bc3..3e88391 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -21,7 +21,7 @@
/* UART */ #define CONFIG_MXC_UART_BASE UART4_BASE -#define CONFIG_CONSOLE_DEV "ttymxc3" +#define CONSOLE_DEV "ttymxc3"
diff --git a/include/configs/zc5202.h b/include/configs/zc5202.h index 073a42c..8e75c40 100644 --- a/include/configs/zc5202.h +++ b/include/configs/zc5202.h @@ -10,7 +10,7 @@ #define __EL_ZC5202_H
#define CONFIG_DEFAULT_FDT_FILE "imx6q-zc5202.dtb" diff --git a/include/configs/zc5601.h b/include/configs/zc5601.h index 28b9c6b..6ede668 100644 --- a/include/configs/zc5601.h +++ b/include/configs/zc5601.h @@ -11,7 +11,7 @@
#define CONFIG_MXC_UART_BASE UART2_BASE -#define CONFIG_CONSOLE_DEV "ttymxc1" +#define CONSOLE_DEV "ttymxc1" #define CONFIG_MMCROOT "/dev/mmcblk0p1"
#define CONFIG_DEFAULT_FDT_FILE "imx6q-zc5601.dtb" diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 40e621e..edc5a11 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -675,7 +675,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_DEV CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET CONFIG_CONSOLE_SCROLL_LINES
This converts the following to Kconfig: CONFIG_VIDEO
Changes in v2: None
README | 5 ----- configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/cm-bf548_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/digsy_mtc_RAMBOOT_defconfig | 1 + configs/digsy_mtc_defconfig | 1 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 1 + configs/digsy_mtc_rev5_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ea20_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/fo300_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/icon_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mcx_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx7dsabresd_defconfig | 1 + configs/mx7dsabresd_secure_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/pdm360ng_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/rut_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/xfi3_defconfig | 1 + drivers/video/Kconfig | 9 +++++++++ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/aria.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/bf527-ezkit.h | 3 --- include/configs/bf533-stamp.h | 1 - include/configs/bf548-ezkit.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm-bf548.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/cougarcanyon2.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/ea20.h | 1 - include/configs/eb_cpu5282.h | 2 -- include/configs/efi-x86.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/galileo.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m28evk.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/mx23evk.h | 2 -- include/configs/mx28evk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 1 - include/configs/pdm360ng.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sansa_fuze_plus.h | 2 -- include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/wandboard.h | 1 - include/configs/x86-common.h | 1 - include/configs/xfi3.h | 2 -- 206 files changed, 147 insertions(+), 78 deletions(-)
diff --git a/README b/README index 391f743..6fbcfb8 100644 --- a/README +++ b/README @@ -1713,11 +1713,6 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO - - Define this to enable video support (for output to - video). - CONFIG_VIDEO_CT69000
Enable Chips & Technologies 69000 Video chip diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 0f4f12f..3adc776 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10082-001 released" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index b749a41..740d4e5 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2003 by MPL AG Switzerland, MEV-10072-001 released" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 27d5826..e6a73ab 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_PHYS_64BIT=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index eaeacca..78b11d6 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 525ccad..f161b61 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 0ff061b..aebf39d 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 13bbe84..d337b7a 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8544DS=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index ec57018..1f17fa0 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y CONFIG_PHYS_64BIT=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 0639b4f..0b744df 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_MPC8572DS=y CONFIG_FIT=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 10607e8..2c03ba2 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8610HPCD=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 2292360..0c3d60b 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y CONFIG_PHYS_64BIT=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index d8f74b3..d2250ec 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index aec6b9a..31602ab 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 02c9c1b..7f46376 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING="\n(c) 2002 by MPL AG Switzerland, MEV-10066-001 released" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index 93637e4..c46576d 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index ac419b4..7c1a07a 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 6ed4e9e..4069fa6 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 243b2b1..901668d 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index e3a249f..c38aa6b 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 8a8b854..8b8dddd 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index b5c6c1e..fac904e 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 8526426..7e336e7 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y CONFIG_FIT=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 6dee606..65fa78b 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 716490b..8fbb287 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T1040QDS=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index ce34ec1..e40fe49 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 63e88df..2665b05 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 9035ab9..1d2548b 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y # CONFIG_SYS_MALLOC_F is not set diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index b26304c..611881f 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index ff39f15..7f172cd 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 3e4e9e2..c80db93 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 5fd9c1e..cebe3c9 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 95a4c8a..433c856 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index f05e33c..6c3ba81 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 07faad5..8932572 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 353fdc1..cdba626 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index ec3655d..ddd356b 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 823e2ae..541a37a 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index c47ff76..1d31439 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index c8118db..1e2f1aa 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index aae082f..b0fed52 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2B=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 85631bb..8e50b7d 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index adb1c73..a483771 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="bayleybay" CONFIG_TARGET_BAYLEYBAY=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index e2d8b6a..b543817 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 8517f2b..a7e60b7 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index b279a7b..df83063 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -1,5 +1,6 @@ CONFIG_X86=y CONFIG_SYS_MALLOC_F_LEN=0x1800 +CONFIG_VIDEO=y CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebook_link" CONFIG_TARGET_CHROMEBOOK_LINK=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index b5fbdae..0fb3c6d 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_GOOGLE=y CONFIG_DEFAULT_DEVICE_TREE="chromebox_panther" CONFIG_TARGET_CHROMEBOX_PANTHER=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index bcf6d8f..f749392 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -1,4 +1,5 @@ CONFIG_BLACKFIN=y +# CONFIG_VIDEO is not set CONFIG_TARGET_CM_BF548=y CONFIG_BOOTDELAY=5 CONFIG_SILENT_CONSOLE=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index a40e6f8..caeff7f 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" CONFIG_BOOTDELAY=3 diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index c1779ec..674002e 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX7=y CONFIG_TARGET_COLIBRI_IMX7=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_imx7/imximage.cfg,MX7D" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 7da23e0..ebf3c4c 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 3a122b8..525f121 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_CONGATEC=y CONFIG_TARGET_CONGA_QEVAL20_QA3_E3845=y CONFIG_DEFAULT_DEVICE_TREE="conga-qeval20-qa3-e3845" diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index cdd466a..91c15a6 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" controlcenterd 0.01" +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y CONFIG_PHYS_64BIT=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 28951e0..203a043 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" controlcenterd 0.01" +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_CONTROLCENTERD=y CONFIG_PHYS_64BIT=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 6dafb37..a7af81b 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 30ddd94..00372b8 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="crownbay" CONFIG_TARGET_CROWNBAY=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index c5fdcad..74f4d83 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_DFI=y CONFIG_DEFAULT_DEVICE_TREE="dfi-bt700-q7x-151" CONFIG_TARGET_DFI_BT700=y diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index 2494412..695f5bb 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index 1f4c15c..2fae7a4 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index 8d77864..a0541d1 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 56e14e1..c66328d 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 5042a82..f0dcb1d 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index da741b4..468b3a7 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index d209de8..1302730 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_EA20=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index bf9177b..daaa345 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -1,4 +1,5 @@ CONFIG_M68K=y +CONFIG_VIDEO=y CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_TEXT_BASE=0xFF000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xFF000400" diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 4f6de89..90e0094 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -1,4 +1,5 @@ CONFIG_M68K=y +CONFIG_VIDEO=y CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xF0000418" diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index eda7a14..49fb0dc 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index f3f3295..7907f94 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SPL_STACK_R_ADDR=0x18000000 CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 6556fa6..565a337 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index a210abb..b43c81d 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX31_PHYCORE_EET" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index 0042d3f..ee36fab 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC5xxx=y CONFIG_TARGET_IPEK01=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 746eba6..465633a 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 74d5f86..14eafb9 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 808a981..a5918aa 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index ce53a4c..24178ef 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 21c8705..6cb0908 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 88344ba..5a70aed 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index f4efb45..49fadf8 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AQDS=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 7a35354..55ff45f 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index f8a3d50..bb61e11 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index fdbcbf0..8d2124f 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index dce1592..b076675 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index cd37246..7c9d4ef 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 07f7023..430fb5c 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021ATWR=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index ab1a558..3685a54 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 52dc6f0..f7b4984 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 6e7289e..25f6741 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 609a218..a2259b4 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_IDENT_STRING=" - v2.0" +CONFIG_VIDEO=y CONFIG_4xx=y CONFIG_TARGET_LWMON5=y CONFIG_FIT=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 2f691c6..d7a8acf 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index c08b2d2..ba9cd62 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index a31d213..bc76dfd 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index a3d233d..c5e28c2 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_GPIO_SUPPORT is not set # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_MCX=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index f54a58b..d9d71c1 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="minnowmax" CONFIG_TARGET_MINNOWMAX=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index e7fb6c5..0eff50a 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_MT_VENTOUX=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=10 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index e70eaf7..6a2afd3 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 638be85..2420cc6 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 4e8d5da..445a00b 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_BOOTDELAY=1 diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index afddfb3..84afa2d 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 6eec4be..6bec8e8 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index d68d001..02cbf57 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_MX51EVK=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 0bd4f26..f42758e 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_MX53LOCO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 8128a7b..4d5d965 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index e911efa..7b19320 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 5b3d66d..3972d0c 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 40a6bb6..37b31c2 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 474aac9..6ad805b 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 786d4b5..a1280ed 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index de45698..696c657 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 9cfeae9..6d58495 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 96209e5..22993ca 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 8fdd0cf..42d920a 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index f878970..9a29ff6 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 4b5b41a..8c5a0f3 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 98c5f5d..b9561f5 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MX7DSABRESD=y # CONFIG_ARMV7_VIRT is not set CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index 5e83633..c0f65da 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MX7DSABRESD=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 3eaed06..15ce0ad 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index d45081d..1d46e55 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index f9c9d35..c912dbc 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index e55d689..78f5d75 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 0dd1ab9..0e9cffa 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 4fd9eed..6334e11 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 9db8b86..43f0552 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_NOKIA_RX51=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=30 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 3f5a9d2..18ecd49 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_CONSOLE_MUX=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index 42f532b..8cb3461 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC512X=y CONFIG_TARGET_PDM360NG=y CONFIG_FIT=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index c3efe57..018cab1 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pxm50" CONFIG_FIT=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 293d7f0..0e38deb 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 6c46d8f..dcf0c2d 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 6980bf1..bfa8dbe 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="qemu-x86_i440fx" CONFIG_SMP=y CONFIG_MAX_CPUS=2 diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index e9e5191..9ad02e4 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 9430c22..5b53ee0 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="am335x-rut" CONFIG_FIT=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 4ede451..97a8bbf 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index fd79510..372918f 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_SOCRATES=y CONFIG_FIT=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index c59f8a3..ad0d2b2 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_ADVANTECH=y CONFIG_TARGET_SOM_DB5800_SOM_6867=y CONFIG_DEFAULT_DEVICE_TREE="baytrail_som-db5800-som-6867" diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 1905b85..6e98203 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y CONFIG_PRE_CONSOLE_BUFFER=y CONFIG_PRE_CON_BUF_ADDR=0x7c000000 +CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 CONFIG_CONSOLE_MUX=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index cff59ec..d98eec5 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -1,4 +1,5 @@ CONFIG_X86=y +CONFIG_VIDEO=y CONFIG_VENDOR_DFI=y CONFIG_DEFAULT_DEVICE_TREE="theadorable-x86-dfi-bt700" CONFIG_TARGET_DFI_BT700=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index ec6a8f1..2596d78 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index ecba1ec..dc39c18 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -8,6 +8,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +CONFIG_VIDEO=y CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 345a25b..329d5e4 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 55b1442..3a34993 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 8361a71..bc246c5 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -413,4 +413,13 @@ config VIDEO_TEGRA124
source "drivers/video/bridge/Kconfig"
+config VIDEO + bool "Enable legacy video support" + depends on !DM_VIDEO + help + Define this for video support, without using driver model. Some + drivers use this because they are not yet converted to driver + model. Video drivers typically provide a colour text console and + cursor. + endmenu diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index b006e31..e9101a0 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -342,7 +342,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO /*To enable video controller support */ #define CONFIG_VIDEO_CT69000 #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 3918160..5b638d9 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -504,7 +504,6 @@ /*#define VIDEO_IO_OFFSET CONFIG_SYS_PCI1_IO_VIRT*/
/* video */ -#define CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index d8dda87..11ba6dd 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -277,7 +277,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /*#define VIDEO_IO_OFFSET CONFIG_SYS_PCI1_IO_VIRT*/
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index e063c7a..26849fc 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -464,7 +464,6 @@ #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index c1b9b6e..35fc2c9 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -25,7 +25,6 @@
#ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 1885124..fa5b180 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -377,7 +377,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /*#define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT*/
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 41e3ee8..f7f1c4d 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -380,7 +380,6 @@
#ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR @@ -400,7 +399,6 @@
#ifdef CONFIG_ATI #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT -#define CONFIG_VIDEO #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index d6c38c7..8649cdb 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -302,7 +302,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO /*To enable video controller support */ #define CONFIG_VIDEO_CT69000 #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 6934e65..50e4046 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -501,7 +501,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index c363719..5760db9 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -499,7 +499,6 @@ unsigned long get_board_ddr_clk(void); #undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 5f25d55..4f320ce 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -413,7 +413,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 8e2f299..31b10ee 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -483,7 +483,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #ifdef CONFIG_FSL_DIU_FB #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 19703cd..ed2fccf 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -98,7 +98,6 @@ * Video console */ #ifndef CONFIG_TQM5200S /* No graphics controller on TQM5200S */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_SM501 #define CONFIG_VIDEO_SM501_32BPP #define CONFIG_CFB_CONSOLE diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 4f07f23..b771242 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -275,7 +275,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 3
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/aria.h b/include/configs/aria.h index cb50658..f91e183 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -38,7 +38,6 @@ #define CONFIG_SYS_TEXT_BASE 0xFFF00000
/* video */ -#undef CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define CONFIG_CFB_CONSOLE diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index c31d9ad..403094b 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -233,7 +233,6 @@ #define CONFIG_IMX_WATCHDOG
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ #define CONFIG_CFB_CONSOLE diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index ddc4a25..d945b8d 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -134,9 +134,6 @@ #endif
/* Don't waste time transferring a logo over the UART */ -#if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_UART) -/*# define CONFIG_VIDEO*/ -#endif
/* * Video Settings diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index c2466ca..ec4d93c 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -204,7 +204,6 @@ #endif
/* define to enable splash screen support */ -/* #define CONFIG_VIDEO */
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index 811dae8..9376283 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -167,7 +167,6 @@
#define CONFIG_ADI_GPIO2
-#undef CONFIG_VIDEO #ifdef CONFIG_VIDEO #define EASYLOGO_HEADER < asm/bfin_logo_230x230_gzip.h > #define CONFIG_DEB_DMA_URGENT diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 6a25f2b..dadefba 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -93,7 +93,6 @@ #define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index d1aa262..c5b82f7 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -113,7 +113,6 @@ #ifndef __ADSPBF542__ /* Don't waste time transferring a logo over the UART */ # if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_UART) -# define CONFIG_VIDEO # define EASYLOGO_HEADER <asm/bfin_logo_230x230_gzip.h> # endif # define CONFIG_DEB_DMA_URGENT diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 4e08846..a1f11cb 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -253,7 +253,6 @@ #define CONFIG_SPL_SPI_LOAD
/* Display */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 84c958d..eedcd6f 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -227,7 +227,6 @@ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M #define DFU_DEFAULT_POLL_TIMEOUT 300
-#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 37972a8..a952f62 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -225,7 +225,6 @@ */ #define CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP diff --git a/include/configs/cougarcanyon2.h b/include/configs/cougarcanyon2.h index 88845dc..ab87aa8 100644 --- a/include/configs/cougarcanyon2.h +++ b/include/configs/cougarcanyon2.h @@ -28,7 +28,6 @@ #define CONFIG_ENV_OFFSET 0x5ff000
/* Video is not supported for now */ -#undef CONFIG_VIDEO #undef CONFIG_CFB_CONSOLE
#endif /* __CONFIG_H */ diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index c2ad92d..0a960ad 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -73,7 +73,6 @@ /* * Video */ -#define CONFIG_VIDEO
#ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx diff --git a/include/configs/ea20.h b/include/configs/ea20.h index ee58dcb..9c0fba8 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -21,7 +21,6 @@ #define CONFIG_DRIVER_TI_EMAC_RMII_NO_NEGOTIATE #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_LATE_INIT -#define CONFIG_VIDEO #define CONFIG_PREBOOT
/* diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 6d469a3..4a868c5 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -251,8 +251,6 @@ * VIDEO configuration */
-#define CONFIG_VIDEO - #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_VCXK 1
diff --git a/include/configs/efi-x86.h b/include/configs/efi-x86.h index 95e46c5..7812870 100644 --- a/include/configs/efi-x86.h +++ b/include/configs/efi-x86.h @@ -15,7 +15,6 @@
#undef CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_IS_NOWHERE -#undef CONFIG_VIDEO #undef CONFIG_CFB_CONSOLE #undef CONFIG_SCSI_AHCI #undef CONFIG_SCSI diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 6266d95..97a912b 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -117,7 +117,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/galileo.h b/include/configs/galileo.h index 40f7fba..f4aceb9 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -32,7 +32,6 @@ #undef CONFIG_SCSI
/* Video is not supported in Quark SoC */ -#undef CONFIG_VIDEO #undef CONFIG_CFB_CONSOLE
/* SD/MMC support */ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 904fdda..91b04a1 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -181,7 +181,6 @@ #define CONFIG_USB_FUNCTION_MASS_STORAGE
/* Framebuffer and LCD */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/icon.h b/include/configs/icon.h index 7e9e7e6..7fc2da2 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -126,7 +126,6 @@ /* * Video options */ -#define CONFIG_VIDEO
#ifdef CONFIG_VIDEO #define CONFIG_VIDEO_SM501 diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 614e2ad..f39dd31 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -181,7 +181,6 @@
#define CONFIG_S6E63D6
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 16eee33..42019a2 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -44,7 +44,6 @@ /* * Video configuration for LIME GDC */ -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 0907e02..adf4b7d 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -443,7 +443,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DCU_FB
#ifdef CONFIG_FSL_DCU_FB -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index d05141a..e20b645 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -331,7 +331,6 @@ #define CONFIG_FSL_DCU_FB
#ifdef CONFIG_FSL_DCU_FB -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index d8398ee..00d0c19 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -353,7 +353,6 @@ #define CONFIG_PHY1_ADDR 1
/* Video console */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_CFB_CONSOLE diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index cdd24cd..cbce252 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -25,7 +25,6 @@ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_VIDEO
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index d39d69c..6ec7a64 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -33,7 +33,6 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_CMD_SATA -#define CONFIG_VIDEO
/* * Memory configurations diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 679826b..9f0670a 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -372,7 +372,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #endif
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index e329105..719335a 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -37,7 +37,6 @@ /* video */ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) -#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 5f44d5f..bb3da6f 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -51,7 +51,6 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index 0de5737..208b6b8 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -18,8 +18,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_VIDEO - /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index b2bf599..48ce6c9 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -23,7 +23,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_VIDEO
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 7a3f1f3..788740a 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -96,7 +96,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 69245f1..a4c08f3 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -215,7 +215,6 @@
/* Framebuffer and LCD */ #define CONFIG_PREBOOT -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 6e4a4f8..e658c52 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -33,7 +33,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CFB_CONSOLE diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index ff0e4db..31d66fa 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -208,7 +208,6 @@ #endif
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 70f2162..66bff1e 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -205,7 +205,6 @@ #endif
#ifndef CONFIG_SPL_BUILD -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 37bd13e..993be1a 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -228,7 +228,6 @@ #define CONFIG_IMX_THERMAL
#ifndef CONFIG_SPL_BUILD -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index d15b546..de26e67 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -257,7 +257,6 @@ #define CONFIG_DFU_MMC #define CONFIG_DFU_RAM
-#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c66a936..850d560 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -92,7 +92,6 @@ #define CONFIG_CMD_BMODE
/* Framebuffer and LCD */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index e9086b0..bf57dea 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -231,7 +231,6 @@ * Framebuffer */ /* Video console */ -#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI /* Enable ANSI escape codes in framebuffer */ #define CONFIG_VIDEO_LOGO diff --git a/include/configs/novena.h b/include/configs/novena.h index cba0604..7fcb2f8 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -24,7 +24,6 @@ #define CONFIG_FAT_WRITE #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA -#define CONFIG_VIDEO
/* U-Boot general configurations */
diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index e0b4d36..af4baa8 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_DEVICE_NULLDEV
/* Video */ -#define CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define CONFIG_CFB_CONSOLE diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 99a201c..541005c 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -124,7 +124,6 @@ #endif #endif /* CONFIG_SPL_BUILD */
-#define CONFIG_VIDEO #if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE diff --git a/include/configs/rut.h b/include/configs/rut.h index 5f62358..e19ed75 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -118,7 +118,6 @@ #undef CONFIG_HW_WATCHDOG #endif
-#define CONFIG_VIDEO #if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index d58b963..9fcca2c 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -14,8 +14,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
-#define CONFIG_VIDEO - /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 1afe374..7392fe3 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -45,7 +45,6 @@ * Define this if you want support for video console with radeon 9200 pci card * Also set CONFIG_SYS_TEXT_BASE to 0xFFF80000 in board/amcc/sequoia/config.mk in this case */ -#undef CONFIG_VIDEO
#ifdef CONFIG_VIDEO /* diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 85cc457..18c496f 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -169,7 +169,6 @@ #define CONFIG_SYS_BR2_PRELIM 0xc80018a1 /* UPMB, 32-bit */ #define CONFIG_SYS_OR2_PRELIM 0xfc000000 /* 64 MB */
-#define CONFIG_VIDEO #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_CFB_CONSOLE diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index d470e04..6b1094b 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -71,7 +71,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index d27ab9c..0c18dbf 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -96,7 +96,6 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
-#define CONFIG_VIDEO #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 1b99719..052742c 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -74,7 +74,6 @@ #define CONFIG_PHY_ATHEROS
/* Framebuffer */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 42c8f0a..7547c90 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -129,7 +129,6 @@ /*----------------------------------------------------------------------- * Video Configuration */ -#define CONFIG_VIDEO #define CONFIG_VIDEO_SW_CURSOR #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 69558fd..d780d67 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -14,8 +14,6 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DOS_PARTITION
This converts the following to Kconfig: CONFIG_CFB_CONSOLE
Changes in v2: None
README | 39 --------------------- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A33-OLinuXino_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Empire_electronix_d709_defconfig | 1 + configs/Empire_electronix_m712_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 3 +- configs/T1024QDS_SDCARD_defconfig | 3 +- configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 3 +- configs/T1042D4RDB_SDCARD_defconfig | 3 +- configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 3 +- configs/T1042RDB_PI_NAND_defconfig | 3 +- configs/T1042RDB_PI_SDCARD_defconfig | 3 +- configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/UTOO_P66_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/colibri_imx7_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + ...conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + .../controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/difrnce_dit4350_defconfig | 1 + configs/digsy_mtc_RAMBOOT_defconfig | 1 + configs/digsy_mtc_defconfig | 1 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 1 + configs/digsy_mtc_rev5_defconfig | 1 + configs/dms-ba16-1g_defconfig | 3 +- configs/dms-ba16_defconfig | 3 +- configs/dserve_dsrv9703c_defconfig | 1 + configs/ea20_defconfig | 1 + configs/fo300_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/icon_defconfig | 1 + configs/imx31_phycore_eet_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + .../ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mcx_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx7dsabresd_defconfig | 1 + configs/mx7dsabresd_secure_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/parrot_r16_defconfig | 1 + configs/pdm360ng_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/pov_protab2_ips9_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/r7-tv-dongle_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/rut_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/socrates_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/xfi3_defconfig | 1 + drivers/video/Kconfig | 40 ++++++++++++++++++++++ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/ac14xx.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/aria.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/chromebook_samus.h | 2 -- include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/cougarcanyon2.h | 3 -- include/configs/digsy_mtc.h | 1 - include/configs/ea20.h | 1 - include/configs/efi-x86.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/galileo.h | 3 -- include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 1 - include/configs/pdm360ng.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/wandboard.h | 1 - include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 285 files changed, 270 insertions(+), 116 deletions(-)
diff --git a/README b/README index 6fbcfb8..ce6ea7a 100644 --- a/README +++ b/README @@ -810,49 +810,10 @@ The following options need to be configured: port routines must be defined elsewhere (i.e. serial_init(), serial_getc(), ...)
- CONFIG_CFB_CONSOLE - Enables console device for a color framebuffer. Needs following - defines (cf. smiLynxEM, i8042) - VIDEO_FB_LITTLE_ENDIAN graphic memory organisation - (default big endian) - VIDEO_HW_RECTFILL graphic chip supports - rectangle fill - (cf. smiLynxEM) - VIDEO_HW_BITBLT graphic chip supports - bit-blit (cf. smiLynxEM) - VIDEO_VISIBLE_COLS visible pixel columns - (cols=pitch) - VIDEO_VISIBLE_ROWS visible pixel rows - VIDEO_PIXEL_SIZE bytes per pixel - VIDEO_DATA_FORMAT graphic data format - (0-5, cf. cfb_console.c) - VIDEO_FB_ADRS framebuffer address - VIDEO_KBD_INIT_FCT keyboard int fct - (i.e. rx51_kp_init()) - VIDEO_TSTC_FCT test char fct - (i.e. rx51_kp_tstc) - VIDEO_GETC_FCT get char fct - (i.e. rx51_kp_getc) - CONFIG_VIDEO_LOGO display Linux logo in - upper left corner - CONFIG_VIDEO_BMP_LOGO use bmp_logo.h instead of - linux_logo.h for logo. - Requires CONFIG_VIDEO_LOGO - CONFIG_CONSOLE_EXTRA_INFO - additional board info beside - the logo - CONFIG_HIDE_LOGO_VERSION - do not display bootloader - version string - When CONFIG_CFB_CONSOLE_ANSI is defined, console will support a limited number of ANSI escape sequences (cursor control, erase functions and limited graphics rendition control).
- When CONFIG_CFB_CONSOLE is defined, video console is - default i/o. Serial console can be forced with - environment 'console=serial'. - CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default is 0x00. CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 1240544..2d3af9d 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -17,3 +17,4 @@ CONFIG_SPL=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 9a637d3..90a2232 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -17,3 +17,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index e501e51..1ee15e1 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index f1dc8d1..b498ef3 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -31,3 +31,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 +CONFIG_CFB_CONSOLE=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 2d5bd0e..914cdc2 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -27,3 +27,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 +CONFIG_CFB_CONSOLE=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 9220185..e5d7e2a 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -16,3 +16,4 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 8e78ecd..3f70d82 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -19,3 +19,4 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 445e644..adb6d4f 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -22,3 +22,4 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index f476035..30ba971 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index fde5954..efbc380 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index f1a5a7b..937b825 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index f259791..156c536 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -15,3 +15,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 6b22dfd..e7f98ee 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 1b8ef23..e9baace 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -16,3 +16,4 @@ CONFIG_SPL=y CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index b8dafd3..f151bf0 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -19,3 +19,4 @@ CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO4_VOLT=2500 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 972e110..52171eb 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -23,3 +23,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 +CONFIG_CFB_CONSOLE=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 55f1459..5218cf0 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -17,3 +17,4 @@ CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index ed375ae..e4ad8c9 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" CONFIG_VIDEO_LCD_SPI_MOSI="PA2" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 3c5ccec..c757c8d 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -25,3 +25,4 @@ CONFIG_SPL=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index a69b478..a11cfcc 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -14,3 +14,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 6cdffd9..3f0e113 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 97f5e40..81c2f97 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -27,3 +27,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 +CONFIG_CFB_CONSOLE=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 433938a..1e569ba 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 2dfe489..325dee3 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index a3e8469..7d599d6 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -17,3 +17,4 @@ CONFIG_SPL=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 09ad379..53a0dce 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -21,3 +21,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 08945dd..ee9591c 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -14,3 +14,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index dcfe1b1..cd6986d 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -15,3 +15,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index e290249..5ac9267 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -16,3 +16,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 6cb05aa..92a13a5 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -14,3 +14,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 36ab5d8..c3b78eb 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 3adc776..0129346 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -14,3 +14,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 740d4e5..015d311 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -17,3 +17,4 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 21a0c25..5c06791 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -11,3 +11,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index e6a73ab..606d542 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 78b11d6..3c9d2f3 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index f161b61..0ae4f7a 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index aebf39d..aa3c082 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -22,4 +22,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index d337b7a..baacefc 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -17,4 +17,5 @@ CONFIG_RTL8139=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 1f17fa0..b5f0074 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -19,4 +19,5 @@ CONFIG_E1000=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 0b744df..e5bff6e 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -18,4 +18,5 @@ CONFIG_E1000=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 2c03ba2..6e2eb3d 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index 0c3d60b..a113e37 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -13,4 +13,5 @@ CONFIG_CMD_USB=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index d2250ec..80ab195 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -12,4 +12,5 @@ CONFIG_CMD_USB=y CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 39988bc..8d2fb5c 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -15,3 +15,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CFB_CONSOLE=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 5744771..a05cf5f 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -20,6 +20,7 @@ CONFIG_SPL=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_LCD_SSD2828_TX_CLK=27 CONFIG_VIDEO_LCD_SSD2828_RESET="PA26" CONFIG_VIDEO_LCD_SPI_CS="PH9" diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 246b0cd..7eddc13 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -11,3 +11,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index f629c72..f1eb121 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -20,3 +20,4 @@ CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 591ef3a..045589e 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 3d7dbc1..6a5b413 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -18,3 +18,4 @@ CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index a90de55..d09448a 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -17,3 +17,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 6659c5d..506c4eb 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -16,3 +16,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index dec9e87..49c3b8f 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -18,3 +18,4 @@ CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 28687a8..f082627 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index 31602ab..1613855 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index de20da3..4c73553 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -18,3 +18,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index b1a795b..a23c86c 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 7f46376..6393bca 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -17,3 +17,4 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 97894f4..179926f 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -19,3 +19,4 @@ CONFIG_SPL=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index d7832fe..247275e 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -20,3 +20,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 +CONFIG_CFB_CONSOLE=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index c6bfa4b..19a3d45 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -17,3 +17,4 @@ CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 CONFIG_AXP_DLDO1_VOLT=3000 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index c46576d..f0c1f34 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 7c1a07a..96f7532 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -29,4 +29,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 4069fa6..fd1c6c2 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y @@ -40,4 +39,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 901668d..66d22fa 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y @@ -40,4 +39,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index c38aa6b..6b04516 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 8b8dddd..cdaadf1 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -41,4 +41,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index fac904e..33779d8 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -31,4 +31,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 7e336e7..92f7534 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -31,4 +31,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 65fa78b..fa30020 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 8fbb287..7ea5ad0 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -31,4 +31,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index e40fe49..00b8471 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -38,4 +37,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 2665b05..bcc41a8 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -38,4 +37,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 1d2548b..dabd474 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 611881f..5d6dbbc 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -39,4 +39,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 7f172cd..9c271b4 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -29,4 +29,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index c80db93..931c93c 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -42,6 +41,8 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index cebe3c9..3af01b8 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -38,4 +37,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 433c856..c90a708 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -6,7 +6,6 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y -CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -38,4 +37,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 6c3ba81..6d8bc36 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -39,4 +39,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 8932572..a18e9ff 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -29,4 +29,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index cdba626..52d8772 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index ddd356b..1f70551 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 541a37a..12577e2 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 1d31439..978a07c 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index a4a1b20..cf08b84 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -27,3 +27,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 3fdee51..dd720a0 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 55b73c6..b6016e3 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -19,3 +19,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index b1c2d50..e55d260 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -15,3 +15,4 @@ CONFIG_SPL=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 28811fd..045d58f 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -25,3 +25,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 7a47252..af3c380 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 1e2f1aa..884d364 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index b0fed52..dfeb20c 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 8e50b7d..b973ebb 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index e256eed..46f7522 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -17,3 +17,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index a483771..5b48adc 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -56,6 +56,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index b543817..b7c387b 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -47,4 +47,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Congatec" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index a7e60b7..81d2384 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index df83063..163e565 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -60,6 +60,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 0fb3c6d..c2df7ae 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -52,6 +52,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index caeff7f..1296229 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -55,4 +55,5 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 674002e..56ff6bf 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -40,4 +40,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Toradex" CONFIG_G_DNL_VENDOR_NUM=0x1b67 CONFIG_G_DNL_PRODUCT_NUM=0x4020 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index 33d406e..e489033 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO2_VOLT=1800 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index ebf3c4c..d0fdc91 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -64,6 +64,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 525f121..dc41207 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -63,6 +63,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index 91c15a6..823bedc 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -31,5 +31,6 @@ CONFIG_FSL_ESPI=y CONFIG_TPM_AUTH_SESSIONS=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_TPM=y CONFIG_OF_LIBFDT=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 203a043..dc0b08f 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -31,5 +31,6 @@ CONFIG_FSL_ESPI=y CONFIG_TPM_AUTH_SESSIONS=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_TPM=y CONFIG_OF_LIBFDT=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index a7af81b..7c1f588 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -43,5 +43,6 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 00372b8..baf69d8 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -50,6 +50,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 74f4d83..dd4ca36 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -61,6 +61,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index cb07388..decebc8 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index 695f5bb..faabd15 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index 2fae7a4..7ba833b 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -22,4 +22,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index a0541d1..29aeb5b 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index c66328d..cdb77ce 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index f0dcb1d..fbe7370 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y -CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y @@ -33,4 +32,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Advantech" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 468b3a7..b2a2655 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y -CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y @@ -32,4 +31,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Advantech" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_VIDEO=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 69db058..b2c14f0 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 1302730..55c1ddc 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -21,3 +21,4 @@ CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index 49fb0dc..8bffeb7 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 66cf6f4..45fc37c 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -25,3 +25,4 @@ CONFIG_SPL=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index b5f7d6f..5c475a4 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 7907f94..cd40d51 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -54,4 +54,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Gateworks" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index ec9e6cf..b5e6965 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -14,3 +14,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index bd6b8cf..c3219c5 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index ab5015f..150471a 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 22b261e..29dac1b 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -19,3 +19,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index 5c95e27..a60a412 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -25,3 +25,4 @@ CONFIG_SPL=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 2aeaf68..fbd219a 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -21,3 +21,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 565a337..6218dd4 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index b43c81d..bfb8afe 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -8,3 +8,4 @@ CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 947bbe5..f38c5d0 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -21,3 +21,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index b5bb6b6..0e7a5c8 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index 4636cf6..53348b8 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -19,3 +19,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index fc80308..93aef8f 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index d1750df..fef24cc 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -19,3 +19,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index 81de9fd..b50a165 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index ee36fab..bf8d34d 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_MII=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 671dedd..1e814c4 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -15,3 +15,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 465633a..0e2c1e3 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -35,3 +35,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 14eafb9..2538fbd 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -35,3 +35,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index a5918aa..3092f9f 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -41,4 +41,5 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 24178ef..75fa91c 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -32,6 +32,7 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 6cb0908..a8f279c 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -34,3 +34,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 5a70aed..a6aee64 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -35,3 +35,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 49fadf8..f9bea58 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -41,3 +41,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 55ff45f..9c9c155 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -42,3 +42,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index bb61e11..ac4cfa0 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -49,3 +49,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 8d2124f..0497bdf 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -32,6 +32,7 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index b076675..e31733c 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -33,3 +33,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 7c9d4ef..553ecac 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -34,3 +34,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 430fb5c..6631233 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -42,3 +42,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 3685a54..84e579f 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index f7b4984..a04fb36 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -39,4 +39,5 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 25f6741..a00dfb5 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -50,3 +50,4 @@ CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index a2259b4..8d101fc 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index d7a8acf..61e13f0 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -33,4 +33,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index ba9cd62..c9f04e0 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -29,4 +29,5 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index bc76dfd..d5bd37c 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH_SST=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index c5e28c2..ce548f7 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -30,4 +30,5 @@ CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index d9d71c1..386a927 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -60,6 +60,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index f18add0..0b09756 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -16,3 +16,4 @@ CONFIG_SPL=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 325c6b1..d5a48ad 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -14,3 +14,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index bef2880..35fc8b9 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -12,3 +12,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 33f9061..bb6b015 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -10,3 +10,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 0eff50a..508e35e 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -27,4 +27,5 @@ CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 6a2afd3..699a8da 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 2420cc6..1f68823 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -31,4 +31,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 445a00b..1b16c8e 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -32,4 +32,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 84afa2d..008a54c 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -31,4 +31,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 6bec8e8..0852f79 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -31,4 +31,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 02cbf57..36a8c12 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -17,4 +17,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index f42758e..2297619 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 4d5d965..b0f89e1 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -35,4 +35,5 @@ CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index 7b19320..e345935 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -35,4 +35,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 3972d0c..2b13238 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -35,4 +35,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 37b31c2..8efe8d0 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -34,4 +34,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 6ad805b..eb26814 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -35,4 +35,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index a1280ed..776dfe8 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -39,4 +39,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 696c657..4e783cb 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -35,4 +35,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 6d58495..415627f 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -43,4 +43,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 22993ca..2bae2f0 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 42d920a..5006a91 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -37,4 +37,5 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 9a29ff6..7a2c3b3 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -38,4 +38,5 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 8c5a0f3..dc3fd44 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -38,4 +38,5 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index b9561f5..46313cb 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -41,4 +41,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx7dsabresd_secure_defconfig b/configs/mx7dsabresd_secure_defconfig index c0f65da..8e05df8 100644 --- a/configs/mx7dsabresd_secure_defconfig +++ b/configs/mx7dsabresd_secure_defconfig @@ -41,4 +41,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="FSL" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 15ce0ad..e97e523 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -37,4 +37,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 1d46e55..ab5e937 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -37,4 +37,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index c912dbc..9fef12f 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -37,4 +37,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 78f5d75..5a5986a 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -37,4 +37,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 0e9cffa..8bc6ca9 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -37,4 +37,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 6334e11..42676eb 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -37,4 +37,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Boundary" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 43f0552..71182fb 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -22,3 +22,4 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 18ecd49..5915010 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -41,4 +41,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index ac0242d..272b4d9 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -23,3 +23,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 +CONFIG_CFB_CONSOLE=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index 8cb3461..efdc8ea 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_I2C=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index d6d16d4..5798983 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index d9b6051..be9cda6 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index b79b6be..91ceb22 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -20,3 +20,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 018cab1..bc7245c 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -55,3 +55,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_CFB_CONSOLE=y diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 66be94a..62b2ff0 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -22,3 +22,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 02da50f..c300d54 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 73de6bd..51c0cfb 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index a2a8444..5c297af 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 0e38deb..cf43cad 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -47,6 +47,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index dcf0c2d..102c2f9 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -44,6 +44,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index bfa8dbe..133fb88 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -44,6 +44,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 35f0908..00e5ff1 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 9ad02e4..10cf974 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH_SST=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 5b53ee0..870f928 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -55,3 +55,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 +CONFIG_CFB_CONSOLE=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 97a8bbf..2da09bc 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 372918f..4ade2ff 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_EXT2=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index ad0d2b2..41bdd49 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -58,6 +58,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 43394e8..200e1f3 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -17,3 +17,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 6e98203..8ede221 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -39,4 +39,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="TBS" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index d98eec5..ea0b772 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -58,6 +58,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 2596d78..d45cb6e 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -49,4 +49,5 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_MVEBU=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index dc39c18..fb89510 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -39,6 +39,7 @@ CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y +CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_MVEBU=y CONFIG_REGEX=y CONFIG_LIB_RAND=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 329d5e4..1375ca2 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -35,4 +35,5 @@ CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 3a34993..b537a44 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -23,4 +23,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y +CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index bc246c5..33d85e7 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -422,4 +422,44 @@ config VIDEO model. Video drivers typically provide a colour text console and cursor.
+config CFB_CONSOLE + bool "Enable colour frame buffer console" + depends on VIDEO + help + Enables the colour frame buffer driver. This supports colour + output on a bitmap display from an in-memory frame buffer. + Several colour devices are supported along with various options to + adjust the supported features. The driver is implemented in + cfb_console.c + + The following defines are needed (cf. smiLynxEM, i8042) + VIDEO_FB_LITTLE_ENDIAN graphic memory organisation + (default big endian) + VIDEO_HW_RECTFILL graphic chip supports + rectangle fill (cf. smiLynxEM) + VIDEO_HW_BITBLT graphic chip supports + bit-blit (cf. smiLynxEM) + VIDEO_VISIBLE_COLS visible pixel columns (cols=pitch) + VIDEO_VISIBLE_ROWS visible pixel rows + VIDEO_PIXEL_SIZE bytes per pixel + VIDEO_DATA_FORMAT graphic data format + (0-5, cf. cfb_console.c) + VIDEO_FB_ADRS framebuffer address + VIDEO_KBD_INIT_FCT keyboard int fct (i.e. rx51_kp_init()) + VIDEO_TSTC_FCT test char fct (i.e. rx51_kp_tstc) + VIDEO_GETC_FCT get char fct (i.e. rx51_kp_getc) + CONFIG_VIDEO_LOGO display Linux logo in upper left corner + CONFIG_VIDEO_BMP_LOGO use bmp_logo.h instead of linux_logo.h + for logo. Requires CONFIG_VIDEO_LOGO + CONFIG_CONSOLE_EXTRA_INFO + additional board info beside + the logo + CONFIG_HIDE_LOGO_VERSION + do not display bootloader + version string + + When CONFIG_CFB_CONSOLE is defined, the video console is the + default console. The serial console can be forced by setting the + environment 'console=serial'. + endmenu diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index e9101a0..e9f0369 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -343,7 +343,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_CT69000 -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 5b638d9..e4fec53 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -507,7 +507,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 11ba6dd..23e8de4 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -280,7 +280,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 26849fc..1571c8a 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -467,7 +467,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 35fc2c9..699293c 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -26,7 +26,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index fa5b180..ce4e33f 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -380,7 +380,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index f7f1c4d..c4e3e65 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -381,7 +381,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO @@ -404,7 +403,6 @@ #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #endif
diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 8649cdb..6110f28 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -303,7 +303,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_CT69000 -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 50e4046..d8a53bc 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -502,7 +502,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 5760db9..d8792d6 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -500,7 +500,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 4f320ce..af63dd3 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -414,7 +414,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 31b10ee..6480e4e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -484,7 +484,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index ed2fccf..9ecc363 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -100,7 +100,6 @@ #ifndef CONFIG_TQM5200S /* No graphics controller on TQM5200S */ #define CONFIG_VIDEO_SM501 #define CONFIG_VIDEO_SM501_32BPP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO
#ifndef CONFIG_FO300 diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 699ac41..f1013c4 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -33,7 +33,6 @@ #define CONFIG_SYS_TEXT_BASE 0xFFF00000
#if defined(CONFIG_VIDEO) -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #endif
diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index b771242..840e3d9 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -276,7 +276,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/aria.h b/include/configs/aria.h index f91e183..7b7e6e2 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -40,7 +40,6 @@ /* video */
diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index 403094b..a472d76 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -235,7 +235,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index dadefba..8e5b538 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -94,7 +94,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/chromebook_samus.h b/include/configs/chromebook_samus.h index b89ba41..1234bff 100644 --- a/include/configs/chromebook_samus.h +++ b/include/configs/chromebook_samus.h @@ -16,8 +16,6 @@ #include <configs/x86-common.h> #include <configs/x86-chromebook.h>
-#undef CONFIG_CFB_CONSOLE - #undef CONFIG_STD_DEVICES_SETTINGS #define CONFIG_STD_DEVICES_SETTINGS "stdin=usbkbd,i8042-kbd,serial\0" \ "stdout=vidconsole,serial\0" \ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index a1f11cb..55a5f93 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -256,7 +256,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index eedcd6f..bbe9c81 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -228,7 +228,6 @@ #define DFU_DEFAULT_POLL_TIMEOUT 300
#ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index a952f62..47a3002 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -225,7 +225,6 @@ */ #define CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP
diff --git a/include/configs/cougarcanyon2.h b/include/configs/cougarcanyon2.h index ab87aa8..d20ad96 100644 --- a/include/configs/cougarcanyon2.h +++ b/include/configs/cougarcanyon2.h @@ -27,7 +27,4 @@ #define CONFIG_ENV_SECT_SIZE 0x1000 #define CONFIG_ENV_OFFSET 0x5ff000
-/* Video is not supported for now */ -#undef CONFIG_CFB_CONSOLE - #endif /* __CONFIG_H */ diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 0a960ad..b90554f 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -78,7 +78,6 @@ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_VIDEO_CORALP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 9c0fba8..eac37c3 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -102,7 +102,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/efi-x86.h b/include/configs/efi-x86.h index 7812870..5626061 100644 --- a/include/configs/efi-x86.h +++ b/include/configs/efi-x86.h @@ -15,7 +15,6 @@
#undef CONFIG_ENV_IS_IN_SPI_FLASH #define CONFIG_ENV_IS_NOWHERE -#undef CONFIG_CFB_CONSOLE #undef CONFIG_SCSI_AHCI #undef CONFIG_SCSI #undef CONFIG_INTEL_ICH6_GPIO diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 97a912b..e115fd5 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -118,7 +118,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/galileo.h b/include/configs/galileo.h index f4aceb9..034142c 100644 --- a/include/configs/galileo.h +++ b/include/configs/galileo.h @@ -31,9 +31,6 @@ #undef CONFIG_SCSI_AHCI #undef CONFIG_SCSI
-/* Video is not supported in Quark SoC */ -#undef CONFIG_CFB_CONSOLE - /* SD/MMC support */ #define CONFIG_MMC #define CONFIG_SDHCI diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index cf805b3..3baac67 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -307,7 +307,6 @@ /* Framebuffer */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 91b04a1..9f4d1a0 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -182,7 +182,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 diff --git a/include/configs/icon.h b/include/configs/icon.h index 7fc2da2..f858b99 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -132,7 +132,6 @@ #define CONFIG_VIDEO_SM501_32BPP #define CONFIG_VIDEO_SM501_PCI #define VIDEO_FB_LITTLE_ENDIAN -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index f39dd31..5a20437 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -181,7 +181,6 @@
#define CONFIG_S6E63D6
-#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 42019a2..99200d1 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -48,7 +48,6 @@ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index adf4b7d..95b68b4 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -444,7 +444,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_DCU_FB #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index e20b645..3c596f3 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -332,7 +332,6 @@
#ifdef CONFIG_FSL_DCU_FB #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 00d0c19..58446b5 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -355,7 +355,6 @@ /* Video console */ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 6ec7a64..9abd450 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -202,7 +202,6 @@ */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 9f0670a..1b95479 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -372,7 +372,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #endif
-#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 719335a..ac3ac35 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -38,7 +38,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index bb3da6f..3ec2358 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -51,7 +51,6 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
-#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 788740a..4ecd7fd 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -97,7 +97,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index a4c08f3..89e5557 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -216,7 +216,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index e658c52..158858f 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -35,7 +35,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 31d66fa..a45c589 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -209,7 +209,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 66bff1e..e288ad8 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -206,7 +206,6 @@
#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 993be1a..c9ca034 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -229,7 +229,6 @@
#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index de26e67..c0c9b12 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -258,7 +258,6 @@ #define CONFIG_DFU_RAM
#ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 634556d..52083c8 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -143,7 +143,6 @@
/* LCD */ #ifdef CONFIG_VIDEO -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 850d560..d18c177 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index bf57dea..a0b0537 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -231,7 +231,6 @@ * Framebuffer */ /* Video console */ -#define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI /* Enable ANSI escape codes in framebuffer */ #define CONFIG_VIDEO_LOGO #define VIDEO_FB_16BPP_PIXEL_SWAP diff --git a/include/configs/novena.h b/include/configs/novena.h index 7fcb2f8..40194f0 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -161,7 +161,6 @@ /* Video output */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index af4baa8..acadf72 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -41,7 +41,6 @@ /* Video */
#if defined(CONFIG_VIDEO) -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 541005c..ba14593 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -126,7 +126,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/rut.h b/include/configs/rut.h index e19ed75..ca812e4 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -120,7 +120,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 7392fe3..facfdac 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -410,7 +410,6 @@ #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO -#define CONFIG_CFB_CONSOLE #define CONFIG_SPLASH_SCREEN #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 18c496f..5abdd23 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -171,7 +171,6 @@
#define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL -#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index b06514a..d81dc21 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -290,7 +290,6 @@ extern int soft_i2c_gpio_scl;
#define CONFIG_VIDEO_SUNXI
-#define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_STD_TIMINGS diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 6b1094b..6ec1cc5 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -74,7 +74,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_CFB_CONSOLE #define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 0c18dbf..365019a 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -96,7 +96,6 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 052742c..aacf4ef 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -75,7 +75,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 7547c90..7633a43 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -132,7 +132,6 @@ #define CONFIG_VIDEO_SW_CURSOR #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_VGA_AS_SINGLE_DEVICE -#define CONFIG_CFB_CONSOLE #define CONFIG_CONSOLE_SCROLL_LINES 5
/*----------------------------------------------------------------------- diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index edc5a11..6ece1be 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -493,7 +493,6 @@ CONFIG_CDP_PORT_ID CONFIG_CDP_POWER_CONSUMPTION CONFIG_CDP_TRIGGER CONFIG_CDP_VERSION -CONFIG_CFB_CONSOLE CONFIG_CFB_CONSOLE_ANSI CONFIG_CFG_DATA_SECTOR CONFIG_CFG_FAT
On Sat, Sep 24, 2016 at 06:17:04PM -0600, Simon Glass wrote:
This converts the following to Kconfig: CONFIG_CFB_CONSOLE
Signed-off-by: Simon Glass sjg@chromium.org
[snip]
+config CFB_CONSOLE
- bool "Enable colour frame buffer console"
- depends on VIDEO
- help
cfb_console.c
the logo
version string
We're missing a default y here I think.
This converts the following to Kconfig: CONFIG_CFB_CONSOLE_ANSI
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
README | 4 ---- configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/tbs2910_defconfig | 1 + drivers/video/Kconfig | 9 +++++++++ include/configs/T104xRDB.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/tbs2910.h | 1 - scripts/config_whitelist.txt | 1 - 18 files changed, 21 insertions(+), 8 deletions(-)
diff --git a/README b/README index ce6ea7a..d3b0a1b 100644 --- a/README +++ b/README @@ -810,10 +810,6 @@ The following options need to be configured: port routines must be defined elsewhere (i.e. serial_init(), serial_getc(), ...)
- When CONFIG_CFB_CONSOLE_ANSI is defined, console will support - a limited number of ANSI escape sequences (cursor control, - erase functions and limited graphics rendition control). - CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default is 0x00. CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 00b8471..fff6c4d 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -39,4 +39,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index bcc41a8..657a2cb 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -39,4 +39,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index dabd474..5b2c36f 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -32,6 +32,7 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 5d6dbbc..9d8fa4f 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -40,4 +40,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 9c271b4..f5ca856 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -30,4 +30,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index 931c93c..c915b17 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index 3af01b8..ffd0ec1 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -39,4 +39,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index c90a708..9a41b6a 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -39,4 +39,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 6d8bc36..4f964c1 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -40,4 +40,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index a18e9ff..5d52f9b 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -30,4 +30,5 @@ CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 71182fb..21c6d39 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -23,3 +23,4 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 8ede221..b0f5f1e 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -40,4 +40,5 @@ CONFIG_G_DNL_MANUFACTURER="TBS" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 CONFIG_CFB_CONSOLE=y +CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 33d85e7..b73d1a3 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -462,4 +462,13 @@ config CFB_CONSOLE default console. The serial console can be forced by setting the environment 'console=serial'.
+config CFB_CONSOLE_ANSI + bool "Support ANSI escape sequences" + depends on CFB_CONSOLE + help + This allows the colour buffer frame buffer driver to support + a limited number of ANSI escape sequences (cursor control, + erase functions and limited graphics rendition control). Normal + output from U-Boot will pass through this filter. + endmenu diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 6480e4e..cf59eb7 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -484,7 +484,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index a0b0537..a78262c 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -231,7 +231,6 @@ * Framebuffer */ /* Video console */ -#define CONFIG_CFB_CONSOLE_ANSI /* Enable ANSI escape codes in framebuffer */ #define CONFIG_VIDEO_LOGO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 6ec1cc5..340ae9c 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -74,7 +74,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_CFB_CONSOLE_ANSI #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 6ece1be..e037e7a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -493,7 +493,6 @@ CONFIG_CDP_PORT_ID CONFIG_CDP_POWER_CONSUMPTION CONFIG_CDP_TRIGGER CONFIG_CDP_VERSION -CONFIG_CFB_CONSOLE_ANSI CONFIG_CFG_DATA_SECTOR CONFIG_CFG_FAT CONFIG_CFG_USB
This converts the following to Kconfig: CONFIG_VIDEO_CT69000
Changes in v2: None
README | 23 ----------------------- configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + drivers/video/Kconfig | 27 +++++++++++++++++++++++++++ include/configs/MIP405.h | 1 - include/configs/PIP405.h | 1 - scripts/config_whitelist.txt | 1 - 8 files changed, 30 insertions(+), 26 deletions(-)
diff --git a/README b/README index d3b0a1b..5df8b6b 100644 --- a/README +++ b/README @@ -1670,35 +1670,12 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO_CT69000 - - Enable Chips & Technologies 69000 Video chip - CONFIG_VIDEO_SMI_LYNXEM Enable Silicon Motion SMI 712/710/810 Video chip. The video output is selected via environment 'videoout' (1 = LCD and 2 = CRT). If videoout is undefined, CRT is assumed.
- For the CT69000 and SMI_LYNXEM drivers, videomode is - selected via environment 'videomode'. Two different ways - are possible: - - "videomode=num" 'num' is a standard LiLo mode numbers. - Following standard modes are supported (* is default): - - Colors 640x480 800x600 1024x768 1152x864 1280x1024 - -------------+--------------------------------------------- - 8 bits | 0x301* 0x303 0x305 0x161 0x307 - 15 bits | 0x310 0x313 0x316 0x162 0x319 - 16 bits | 0x311 0x314 0x317 0x163 0x31A - 24 bits | 0x312 0x315 0x318 ? 0x31B - -------------+--------------------------------------------- - (i.e. setenv videomode 317; saveenv; reset;) - - - "videomode=bootargs" all the video parameters are parsed - from the bootargs. (See drivers/video/videomodes.c) - - CONFIG_VIDEO_SED13806 Enable Epson SED13806 driver. This driver supports 8bpp and 16bpp modes defined by CONFIG_VIDEO_SED13806_8BPP diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 0129346..f0547bb 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -15,3 +15,4 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_CFB_CONSOLE=y +CONFIG_VIDEO_CT69000=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 015d311..ea66335 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -18,3 +18,4 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_VIDEO_CT69000=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 6393bca..8b4a7a8 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -18,3 +18,4 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_VIDEO_CT69000=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index b73d1a3..20ae11e 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -471,4 +471,31 @@ config CFB_CONSOLE_ANSI erase functions and limited graphics rendition control). Normal output from U-Boot will pass through this filter.
+config VIDEO_CT69000 + bool "Enable Chips & Technologies 69000 video driver" + depends on VIDEO + help + This enables a frame buffer driver for the Chips & Technologies + ct69000, a fairly old graphics device (circa 2000) which is used + on some hardware. It operates over the ISA bus, and supports + some acceleration features. + + For the CT69000 and SMI_LYNXEM drivers, videomode is + selected via environment 'videomode'. Two different ways + are possible: + - "videomode=num" 'num' is a standard LiLo mode numbers. + Following standard modes are supported (* is default): + + Colors 640x480 800x600 1024x768 1152x864 1280x1024 + -------------+--------------------------------------------- + 8 bits | 0x301* 0x303 0x305 0x161 0x307 + 15 bits | 0x310 0x313 0x316 0x162 0x319 + 16 bits | 0x311 0x314 0x317 0x163 0x31A + 24 bits | 0x312 0x315 0x318 ? 0x31B + -------------+--------------------------------------------- + (i.e. setenv videomode 317; saveenv; reset;) + + - "videomode=bootargs" all the video parameters are parsed + from the bootargs. (See drivers/video/videomodes.c) + endmenu diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index e9f0369..501411b 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -342,7 +342,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO_CT69000 #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 6110f28..54dbe4c 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -302,7 +302,6 @@ /************************************************************ * Video support ************************************************************/ -#define CONFIG_VIDEO_CT69000 #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VGA_AS_SINGLE_DEVICE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e037e7a..e5730b3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8282,7 +8282,6 @@ CONFIG_VIDEO_BMP_GZIP CONFIG_VIDEO_BMP_LOGO CONFIG_VIDEO_BMP_RLE8 CONFIG_VIDEO_CORALP -CONFIG_VIDEO_CT69000 CONFIG_VIDEO_DA8XX CONFIG_VIDEO_DT_SIMPLEFB CONFIG_VIDEO_FONT_4X6
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_FG_COL
Changes in v2: None
README | 5 --- configs/pxm2_defconfig | 2 + configs/rut_defconfig | 2 + drivers/video/Kconfig | 22 ++++++++++ drivers/video/cfb_console.c | 98 ++++++++++++++++++++++---------------------- drivers/video/ct69000.c | 3 +- include/configs/pxm2.h | 2 - include/configs/rut.h | 2 - include/video_fb.h | 8 ---- scripts/config_whitelist.txt | 2 - 10 files changed, 78 insertions(+), 68 deletions(-)
diff --git a/README b/README index 5df8b6b..e1d4dfc 100644 --- a/README +++ b/README @@ -810,11 +810,6 @@ The following options need to be configured: port routines must be defined elsewhere (i.e. serial_init(), serial_getc(), ...)
- CONFIG_SYS_CONSOLE_BG_COL: define the backgroundcolor, default - is 0x00. - CONFIG_SYS_CONSOLE_FG_COL: define the foregroundcolor, default - is 0xa0. - - Console Baudrate: CONFIG_BAUDRATE - in bps Select one of the baudrates listed in diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index bc7245c..bfac212 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -56,3 +56,5 @@ CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_CFB_CONSOLE=y +CONFIG_SYS_CONSOLE_BG_COL=0xff +CONFIG_SYS_CONSOLE_FG_COL=0x00 diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 870f928..eda5d7b 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -56,3 +56,5 @@ CONFIG_G_DNL_MANUFACTURER="Siemens AG" CONFIG_G_DNL_VENDOR_NUM=0x0908 CONFIG_G_DNL_PRODUCT_NUM=0x02d2 CONFIG_CFB_CONSOLE=y +CONFIG_SYS_CONSOLE_BG_COL=0xff +CONFIG_SYS_CONSOLE_FG_COL=0x00 diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 20ae11e..de6f419 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -498,4 +498,26 @@ config VIDEO_CT69000 - "videomode=bootargs" all the video parameters are parsed from the bootargs. (See drivers/video/videomodes.c)
+config SYS_CONSOLE_BG_COL + hex "Background colour" + depends on CFB_CONSOLE || VIDEO_CT69000 + default 0x00 + help + Defines the background colour for the console. The value is from + 0x00 to 0xff and the meaning depends on the graphics card. + Typically, 0x00 means black and 0xff means white. Do not set + the background and foreground to the same colour or you will see + nothing. + +config SYS_CONSOLE_FG_COL + hex "Foreground colour" + depends on CFB_CONSOLE || VIDEO_CT69000 + default 0xa0 + help + Defines the foreground colour for the console. The value is from + 0x00 to 0xff and the meaning depends on the graphics card. + Typically, 0x00 means black and 0xff means white. Do not set + the background and foreground to the same colour or you will see + nothing. + endmenu diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 30b53db..949187c 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -2093,70 +2093,72 @@ static int video_init(void) /* Init drawing pats */ switch (VIDEO_DATA_FORMAT) { case GDF__8BIT_INDEX: - video_set_lut(0x01, CONSOLE_FG_COL, CONSOLE_FG_COL, - CONSOLE_FG_COL); - video_set_lut(0x00, CONSOLE_BG_COL, CONSOLE_BG_COL, - CONSOLE_BG_COL); + video_set_lut(0x01, CONFIG_SYS_CONSOLE_FG_COL, + CONFIG_SYS_CONSOLE_FG_COL, + CONFIG_SYS_CONSOLE_FG_COL); + video_set_lut(0x00, CONFIG_SYS_CONSOLE_BG_COL, + CONFIG_SYS_CONSOLE_BG_COL, + CONFIG_SYS_CONSOLE_BG_COL); fgx = 0x01010101; bgx = 0x00000000; break; case GDF__8BIT_332RGB: - color8 = ((CONSOLE_FG_COL & 0xe0) | - ((CONSOLE_FG_COL >> 3) & 0x1c) | - CONSOLE_FG_COL >> 6); + color8 = ((CONFIG_SYS_CONSOLE_FG_COL & 0xe0) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) & 0x1c) | + CONFIG_SYS_CONSOLE_FG_COL >> 6); fgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | color8; - color8 = ((CONSOLE_BG_COL & 0xe0) | - ((CONSOLE_BG_COL >> 3) & 0x1c) | - CONSOLE_BG_COL >> 6); + color8 = ((CONFIG_SYS_CONSOLE_BG_COL & 0xe0) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) & 0x1c) | + CONFIG_SYS_CONSOLE_BG_COL >> 6); bgx = (color8 << 24) | (color8 << 16) | (color8 << 8) | color8; break; case GDF_15BIT_555RGB: - fgx = (((CONSOLE_FG_COL >> 3) << 26) | - ((CONSOLE_FG_COL >> 3) << 21) | - ((CONSOLE_FG_COL >> 3) << 16) | - ((CONSOLE_FG_COL >> 3) << 10) | - ((CONSOLE_FG_COL >> 3) << 5) | - (CONSOLE_FG_COL >> 3)); - bgx = (((CONSOLE_BG_COL >> 3) << 26) | - ((CONSOLE_BG_COL >> 3) << 21) | - ((CONSOLE_BG_COL >> 3) << 16) | - ((CONSOLE_BG_COL >> 3) << 10) | - ((CONSOLE_BG_COL >> 3) << 5) | - (CONSOLE_BG_COL >> 3)); + fgx = (((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 26) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 21) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 10) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 5) | + (CONFIG_SYS_CONSOLE_FG_COL >> 3)); + bgx = (((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 26) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 21) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 10) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 5) | + (CONFIG_SYS_CONSOLE_BG_COL >> 3)); break; case GDF_16BIT_565RGB: - fgx = (((CONSOLE_FG_COL >> 3) << 27) | - ((CONSOLE_FG_COL >> 2) << 21) | - ((CONSOLE_FG_COL >> 3) << 16) | - ((CONSOLE_FG_COL >> 3) << 11) | - ((CONSOLE_FG_COL >> 2) << 5) | - (CONSOLE_FG_COL >> 3)); - bgx = (((CONSOLE_BG_COL >> 3) << 27) | - ((CONSOLE_BG_COL >> 2) << 21) | - ((CONSOLE_BG_COL >> 3) << 16) | - ((CONSOLE_BG_COL >> 3) << 11) | - ((CONSOLE_BG_COL >> 2) << 5) | - (CONSOLE_BG_COL >> 3)); + fgx = (((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 27) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 2) << 21) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 3) << 11) | + ((CONFIG_SYS_CONSOLE_FG_COL >> 2) << 5) | + (CONFIG_SYS_CONSOLE_FG_COL >> 3)); + bgx = (((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 27) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 2) << 21) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 16) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 3) << 11) | + ((CONFIG_SYS_CONSOLE_BG_COL >> 2) << 5) | + (CONFIG_SYS_CONSOLE_BG_COL >> 3)); break; case GDF_32BIT_X888RGB: - fgx = (CONSOLE_FG_COL << 16) | - (CONSOLE_FG_COL << 8) | - CONSOLE_FG_COL; - bgx = (CONSOLE_BG_COL << 16) | - (CONSOLE_BG_COL << 8) | - CONSOLE_BG_COL; + fgx = (CONFIG_SYS_CONSOLE_FG_COL << 16) | + (CONFIG_SYS_CONSOLE_FG_COL << 8) | + CONFIG_SYS_CONSOLE_FG_COL; + bgx = (CONFIG_SYS_CONSOLE_BG_COL << 16) | + (CONFIG_SYS_CONSOLE_BG_COL << 8) | + CONFIG_SYS_CONSOLE_BG_COL; break; case GDF_24BIT_888RGB: - fgx = (CONSOLE_FG_COL << 24) | - (CONSOLE_FG_COL << 16) | - (CONSOLE_FG_COL << 8) | - CONSOLE_FG_COL; - bgx = (CONSOLE_BG_COL << 24) | - (CONSOLE_BG_COL << 16) | - (CONSOLE_BG_COL << 8) | - CONSOLE_BG_COL; + fgx = (CONFIG_SYS_CONSOLE_FG_COL << 24) | + (CONFIG_SYS_CONSOLE_FG_COL << 16) | + (CONFIG_SYS_CONSOLE_FG_COL << 8) | + CONFIG_SYS_CONSOLE_FG_COL; + bgx = (CONFIG_SYS_CONSOLE_BG_COL << 24) | + (CONFIG_SYS_CONSOLE_BG_COL << 16) | + (CONFIG_SYS_CONSOLE_BG_COL << 8) | + CONFIG_SYS_CONSOLE_BG_COL; break; } eorx = fgx ^ bgx; diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index 22b3441..349da5e 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -870,7 +870,8 @@ video_init_hw_cursor (int font_width, int font_height) xr_80 = ctRead_i (CT_XR_O, 0x80); xr_80 |= 0x1; /* alternate palette select */ ctWrite_i (CT_XR_O, 0x80, xr_80); - video_set_lut (4, CONSOLE_FG_COL, CONSOLE_FG_COL, CONSOLE_FG_COL); + video_set_lut(4, CONFIG_SYS_CONSOLE_FG_COL, CONFIG_SYS_CONSOLE_FG_COL, + CONFIG_SYS_CONSOLE_FG_COL); /* position 4 is color 0 cursor 0 */ xr_80 &= 0xfe; /* normal palette select */ ctWrite_i (CT_XR_O, 0x80, xr_80); diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index ba14593..6cc8d6c 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -136,8 +136,6 @@ #define DA8XX_LCD_CNTL_BASE LCD_CNTL_BASE #define PWM_TICKS 0x1388 #define PWM_DUTY 0x200 -#define CONFIG_SYS_CONSOLE_BG_COL 0xff -#define CONFIG_SYS_CONSOLE_FG_COL 0x00 #endif
#endif /* ! __CONFIG_PXM2_H */ diff --git a/include/configs/rut.h b/include/configs/rut.h index ca812e4..11f9a25 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -136,8 +136,6 @@ #define CONFIG_ARCH_EARLY_INIT_R #define CONFIG_FORMIKE #define DISPL_PLL_SPREAD_SPECTRUM -#define CONFIG_SYS_CONSOLE_BG_COL 0xff -#define CONFIG_SYS_CONSOLE_FG_COL 0x00 #endif
#endif /* ! __CONFIG_RUT_H */ diff --git a/include/video_fb.h b/include/video_fb.h index 55ec24d..b7e3aee 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -18,14 +18,6 @@ #ifndef _VIDEO_FB_H_ #define _VIDEO_FB_H_
-#if defined(CONFIG_SYS_CONSOLE_FG_COL) && defined(CONFIG_SYS_CONSOLE_BG_COL) -#define CONSOLE_BG_COL CONFIG_SYS_CONSOLE_BG_COL -#define CONSOLE_FG_COL CONFIG_SYS_CONSOLE_FG_COL -#else -#define CONSOLE_BG_COL 0x00 -#define CONSOLE_FG_COL 0xa0 -#endif - /* * Graphic Data Format (GDF) bits for VIDEO_DATA_FORMAT */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e5730b3..7eca0f4 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4620,9 +4620,7 @@ CONFIG_SYS_CMXFCR_VALUE1 CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE -CONFIG_SYS_CONSOLE_BG_COL CONFIG_SYS_CONSOLE_ENV_OVERWRITE -CONFIG_SYS_CONSOLE_FG_COL CONFIG_SYS_CONSOLE_INFO_QUIET CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM
This is not used in U-Boot anymore.
Changes in v2: None
README | 6 - drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 13 - drivers/video/smiLynxEM.c | 835 ------------------------------------------- scripts/config_whitelist.txt | 1 - 5 files changed, 856 deletions(-) delete mode 100644 drivers/video/smiLynxEM.c
diff --git a/README b/README index e1d4dfc..74ecb79 100644 --- a/README +++ b/README @@ -1665,12 +1665,6 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO_SMI_LYNXEM - Enable Silicon Motion SMI 712/710/810 Video chip. The - video output is selected via environment 'videoout' - (1 = LCD and 2 = CRT). If videoout is undefined, CRT is - assumed. - CONFIG_VIDEO_SED13806 Enable Epson SED13806 driver. This driver supports 8bpp and 16bpp modes defined by CONFIG_VIDEO_SED13806_8BPP diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 3f045fe..2df2015 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -53,7 +53,6 @@ obj-$(CONFIG_VIDEO_S3C) += s3c-fb.o videomodes.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o obj-$(CONFIG_VIDEO_SED13806) += sed13806.o obj-$(CONFIG_VIDEO_SM501) += sm501.o -obj-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o videomodes.o obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o videomodes.o obj-$(CONFIG_VIDEO_TEGRA20) += tegra.o obj-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 949187c..a087d2e 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -27,7 +27,6 @@ * * (for SMI LynxE graphic chip) * - * CONFIG_VIDEO_SMI_LYNXEM - use graphic driver for SMI 710,712,810 * VIDEO_FB_LITTLE_ENDIAN - framebuffer organisation default: big endian * VIDEO_HW_RECTFILL - graphic driver supports hardware rectangle fill * VIDEO_HW_BITBLT - graphic driver supports hardware bit blt @@ -87,18 +86,6 @@ #include <linux/compiler.h>
/* - * Console device defines with SMI graphic - * Any other graphic must change this section - */ - -#ifdef CONFIG_VIDEO_SMI_LYNXEM - -#define VIDEO_FB_LITTLE_ENDIAN -#define VIDEO_HW_RECTFILL -#define VIDEO_HW_BITBLT -#endif - -/* * Defines for the CT69000 driver */ #ifdef CONFIG_VIDEO_CT69000 diff --git a/drivers/video/smiLynxEM.c b/drivers/video/smiLynxEM.c deleted file mode 100644 index 1880ccc..0000000 --- a/drivers/video/smiLynxEM.c +++ /dev/null @@ -1,835 +0,0 @@ -/* - * (C) Copyright 1997-2002 ELTEC Elektronik AG - * Frank Gottschling fgottschling@eltec.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * smiLynxEM.c - * - * Silicon Motion graphic interface for sm810/sm710/sm712 accelerator - * - * modification history - * -------------------- - * 04-18-2002 Rewritten for U-Boot fgottschling@eltec.de. - * - * 18-03-2004 - Unify videomodes handling with the ct69000 - * - The video output can be set via the variable "videoout" - * in the environment. - * videoout=1 output on LCD - * videoout=2 output on CRT (default value) - * p.aubert@staubli.com - */ - -#include <common.h> - -#include <pci.h> -#include <video_fb.h> -#include "videomodes.h" -/* - * Export Graphic Device - */ -GraphicDevice smi; - -/* - * SMI 710/712 have 4MB internal RAM; SMI 810 2MB internal + 2MB external - */ -#define VIDEO_MEM_SIZE 0x400000 - - -/* - * ISA mapped regs - */ -#define SMI_INDX_C4 (pGD->isaBase + 0x03c4) /* index reg */ -#define SMI_DATA_C5 (pGD->isaBase + 0x03c5) /* data reg */ -#define SMI_INDX_D4 (pGD->isaBase + 0x03d4) /* index reg */ -#define SMI_DATA_D5 (pGD->isaBase + 0x03d5) /* data reg */ -#define SMI_ISR1 (pGD->isaBase + 0x03ca) -#define SMI_INDX_CE (pGD->isaBase + 0x03ce) /* index reg */ -#define SMI_DATA_CF (pGD->isaBase + 0x03cf) /* data reg */ -#define SMI_LOCK_REG (pGD->isaBase + 0x03c3) /* unlock/lock ext crt reg */ -#define SMI_MISC_REG (pGD->isaBase + 0x03c2) /* misc reg */ -#define SMI_LUT_MASK (pGD->isaBase + 0x03c6) /* lut mask reg */ -#define SMI_LUT_START (pGD->isaBase + 0x03c8) /* lut start index */ -#define SMI_LUT_RGB (pGD->isaBase + 0x03c9) /* lut colors auto incr.*/ -#define SMI_INDX_ATTR (pGD->isaBase + 0x03c0) /* attributes index reg */ - -/* - * Video processor control - */ -typedef struct { - unsigned int control; - unsigned int colorKey; - unsigned int colorKeyMask; - unsigned int start; - unsigned short offset; - unsigned short width; - unsigned int fifoPrio; - unsigned int fifoERL; - unsigned int YUVtoRGB; -} SmiVideoProc; - -/* - * Video window control - */ -typedef struct { - unsigned short top; - unsigned short left; - unsigned short bottom; - unsigned short right; - unsigned int srcStart; - unsigned short width; - unsigned short offset; - unsigned char hStretch; - unsigned char vStretch; -} SmiVideoWin; - -/* - * Capture port control - */ -typedef struct { - unsigned int control; - unsigned short topClip; - unsigned short leftClip; - unsigned short srcHeight; - unsigned short srcWidth; - unsigned int srcBufStart1; - unsigned int srcBufStart2; - unsigned short srcOffset; - unsigned short fifoControl; -} SmiCapturePort; - - -/* - * Register values for common video modes - */ -static char SMI_SCR[] = { - /* all modes */ - 0x10, 0xff, 0x11, 0xff, 0x12, 0xff, 0x13, 0xff, 0x15, 0x90, - 0x17, 0x20, 0x18, 0xb1, 0x19, 0x00, -}; -static char SMI_EXT_CRT[] = { - 0x31, 0x00, 0x32, 0x00, 0x33, 0x00, 0x34, 0x00, 0x35, 0x00, - 0x36, 0x00, 0x3b, 0x00, 0x3c, 0x00, 0x3d, 0x00, 0x3e, 0x00, 0x3f, 0x00, -}; -static char SMI_ATTR [] = { - 0x00, 0x00, 0x01, 0x01, 0x02, 0x02, 0x03, 0x03, 0x04, 0x04, 0x05, 0x05, - 0x06, 0x06, 0x07, 0x07, 0x08, 0x08, 0x09, 0x09, 0x0a, 0x0a, 0x0b, 0x0b, - 0x0c, 0x0c, 0x0d, 0x0d, 0x0e, 0x0e, 0x0f, 0x0f, 0x10, 0x41, 0x11, 0x00, - 0x12, 0x0f, 0x13, 0x00, 0x14, 0x00, -}; -static char SMI_GCR[18] = { - 0x00, 0x00, 0x01, 0x00, 0x02, 0x00, 0x03, 0x00, 0x04, 0x00, 0x05, 0x40, - 0x06, 0x05, 0x07, 0x0f, 0x08, 0xff, -}; -static char SMI_SEQR[] = { - 0x00, 0x00, 0x01, 0x01, 0x02, 0x0f, 0x03, 0x03, 0x04, 0x0e, 0x00, 0x03, -}; -static char SMI_PCR [] = { - 0x20, 0x04, 0x21, 0x30, 0x22, 0x00, 0x23, 0x00, 0x24, 0x00, -}; -static char SMI_MCR[] = { - 0x60, 0x01, 0x61, 0x00, -}; - -static char SMI_HCR[] = { - 0x80, 0xff, 0x81, 0x07, 0x82, 0x00, 0x83, 0xff, 0x84, 0xff, 0x88, 0x00, - 0x89, 0x02, 0x8a, 0x80, 0x8b, 0x01, 0x8c, 0xff, 0x8d, 0x00, -}; - - -/******************************************************************************* - * - * Write SMI ISA register - */ -static void smiWrite (unsigned short index, char reg, char val) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - out8 ((pGD->isaBase + index), reg); - out8 ((pGD->isaBase + index + 1), val); -} - -/******************************************************************************* - * - * Write a table of SMI ISA register - */ -static void smiLoadRegs ( - unsigned int iReg, - unsigned int dReg, - char *regTab, - unsigned int tabSize - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register int i; - - for (i=0; i<tabSize; i+=2) { - if (iReg == SMI_INDX_ATTR) { - /* Reset the Flip Flop */ - in8 (SMI_ISR1); - out8 (iReg, regTab[i]); - out8 (iReg, regTab[i+1]); - } else { - out8 (iReg, regTab[i]); - out8 (dReg, regTab[i+1]); - } - } -} - -/******************************************************************************* - * - * Init capture port registers - */ -static void smiInitCapturePort (void) -{ - SmiCapturePort smiCP = { 0x01400600, 0x30, 0x40, 480, 640, 0, 0, 2560, 6 }; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register SmiCapturePort *pCP = (SmiCapturePort *)&smiCP; - - out32r ((pGD->cprBase + 0x0004), ((pCP->topClip<<16) | pCP->leftClip)); - out32r ((pGD->cprBase + 0x0008), ((pCP->srcHeight<<16) | pCP->srcWidth)); - out32r ((pGD->cprBase + 0x000c), pCP->srcBufStart1/8); - out32r ((pGD->cprBase + 0x0010), pCP->srcBufStart2/8); - out32r ((pGD->cprBase + 0x0014), pCP->srcOffset/8); - out32r ((pGD->cprBase + 0x0018), pCP->fifoControl); - out32r ((pGD->cprBase + 0x0000), pCP->control); -} - - -/******************************************************************************* - * - * Init video processor registers - */ -static void smiInitVideoProcessor (void) -{ - SmiVideoProc smiVP = { 0x100000, 0, 0, 0, 0, 1600, 0x1200543, 4, 0xededed }; - SmiVideoWin smiVW = { 0, 0, 599, 799, 0, 1600, 0, 0, 0 }; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register SmiVideoProc *pVP = (SmiVideoProc *)&smiVP; - register SmiVideoWin *pVWin = (SmiVideoWin *)&smiVW; - - pVP->width = pGD->plnSizeX * pGD->gdfBytesPP; - pVP->control |= pGD->gdfIndex << 16; - pVWin->bottom = pGD->winSizeY - 1; - pVWin->right = pGD->winSizeX - 1; - pVWin->width = pVP->width; - - /* color key */ - out32r ((pGD->vprBase + 0x0004), pVP->colorKey); - - /* color key mask */ - out32r ((pGD->vprBase + 0x0008), pVP->colorKeyMask); - - /* data src start adrs */ - out32r ((pGD->vprBase + 0x000c), pVP->start / 8); - - /* data width and offset */ - out32r ((pGD->vprBase + 0x0010), - ((pVP->offset / 8 * pGD->gdfBytesPP) << 16) | - (pGD->plnSizeX / 8 * pGD->gdfBytesPP)); - - /* video window 1 */ - out32r ((pGD->vprBase + 0x0014), - ((pVWin->top << 16) | pVWin->left)); - - out32r ((pGD->vprBase + 0x0018), - ((pVWin->bottom << 16) | pVWin->right)); - - out32r ((pGD->vprBase + 0x001c), pVWin->srcStart / 8); - - out32r ((pGD->vprBase + 0x0020), - (((pVWin->offset / 8) << 16) | (pVWin->width / 8))); - - out32r ((pGD->vprBase + 0x0024), - (((pVWin->hStretch) << 8) | pVWin->vStretch)); - - /* video window 2 */ - out32r ((pGD->vprBase + 0x0028), - ((pVWin->top << 16) | pVWin->left)); - - out32r ((pGD->vprBase + 0x002c), - ((pVWin->bottom << 16) | pVWin->right)); - - out32r ((pGD->vprBase + 0x0030), - pVWin->srcStart / 8); - - out32r ((pGD->vprBase + 0x0034), - (((pVWin->offset / 8) << 16) | (pVWin->width / 8))); - - out32r ((pGD->vprBase + 0x0038), - (((pVWin->hStretch) << 8) | pVWin->vStretch)); - - /* fifo prio control */ - out32r ((pGD->vprBase + 0x0054), pVP->fifoPrio); - - /* fifo empty request levell */ - out32r ((pGD->vprBase + 0x0058), pVP->fifoERL); - - /* conversion constant */ - out32r ((pGD->vprBase + 0x005c), pVP->YUVtoRGB); - - /* vpr control word */ - out32r ((pGD->vprBase + 0x0000), pVP->control); -} - -/****************************************************************************** - * - * Init drawing engine registers - */ -static void smiInitDrawingEngine (void) -{ - GraphicDevice *pGD = (GraphicDevice *)&smi; - unsigned int val; - - /* don't start now */ - out32r ((pGD->dprBase + 0x000c), 0x000f0000); - - /* set rop2 to copypen */ - val = 0xffff3ff0 & in32r ((pGD->dprBase + 0x000c)); - out32r ((pGD->dprBase + 0x000c), (val | 0x8000 | 0x0c)); - - /* set clip rect */ - out32r ((pGD->dprBase + 0x002c), 0); - out32r ((pGD->dprBase + 0x0030), - ((pGD->winSizeY<<16) | pGD->winSizeX * pGD->gdfBytesPP )); - - /* src row pitch */ - val = 0xffff0000 & (in32r ((pGD->dprBase + 0x0010))); - out32r ((pGD->dprBase + 0x0010), - (val | pGD->plnSizeX * pGD->gdfBytesPP)); - - /* dst row pitch */ - val = 0x0000ffff & (in32r ((pGD->dprBase + 0x0010))); - out32r ((pGD->dprBase + 0x0010), - (((pGD->plnSizeX * pGD->gdfBytesPP)<<16) | val)); - - /* window width src/dst */ - out32r ((pGD->dprBase + 0x003c), - (((pGD->plnSizeX * pGD->gdfBytesPP & 0x0fff)<<16) | - (pGD->plnSizeX * pGD->gdfBytesPP & 0x0fff))); - out16r ((pGD->dprBase + 0x001e), 0x0000); - - /* src base adrs */ - out32r ((pGD->dprBase + 0x0040), - (((pGD->frameAdrs/8) & 0x000fffff))); - - /* dst base adrs */ - out32r ((pGD->dprBase + 0x0044), - (((pGD->frameAdrs/8) & 0x000fffff))); - - /* foreground color */ - out32r ((pGD->dprBase + 0x0014), pGD->fg); - - /* background color */ - out32r ((pGD->dprBase + 0x0018), pGD->bg); - - /* xcolor */ - out32r ((pGD->dprBase + 0x0020), 0x00ffffff); - - /* xcolor mask */ - out32r ((pGD->dprBase + 0x0024), 0x00ffffff); - - /* bit mask */ - out32r ((pGD->dprBase + 0x0028), 0x00ffffff); - - /* load mono pattern */ - out32r ((pGD->dprBase + 0x0034), 0); - out32r ((pGD->dprBase + 0x0038), 0); -} - -static struct pci_device_id supported[] = { - { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_710 }, - { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_712 }, - { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_810 }, - { } -}; - -/*****************************************************************************/ -static void smiLoadMsr (struct ctfb_res_modes *mode) -{ - unsigned char h_synch_high, v_synch_high; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - h_synch_high = (mode->sync & FB_SYNC_HOR_HIGH_ACT) ? 0 : 0x40; /* horizontal Synch High active */ - v_synch_high = (mode->sync & FB_SYNC_VERT_HIGH_ACT) ? 0 : 0x80; /* vertical Synch High active */ - out8 (SMI_MISC_REG, (h_synch_high | v_synch_high | 0x29)); - /* upper64K==0x20, CLC2select==0x08, RAMenable==0x02!(todo), CGA==0x01 - * Selects the upper 64KB page.Bit5=1 - * CLK2 (left reserved in standard VGA) Bit3|2=1|0 - * Disables CPU access to frame buffer. Bit1=0 - * Sets the I/O address decode for ST01, FCR, and all CR registers - * to the 3Dx I/O address range (CGA emulation). Bit0=1 - */ -} -/*****************************************************************************/ -static void smiLoadCrt (struct ctfb_res_modes *var, int bits_per_pixel) -{ - unsigned char cr[0x7a]; - int i; - unsigned int hd, hs, he, ht, hbs, hbe; /* Horizontal. */ - unsigned int vd, vs, ve, vt, vbs, vbe; /* vertical */ - unsigned int bpp, wd, dblscan, interlaced; - - const int LineCompare = 0x3ff; - unsigned int TextScanLines = 1; /* this is in fact a vertical zoom factor */ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - /* Horizontal */ - hd = (var->xres) / 8; /* HDisp. */ - hs = (var->xres + var->right_margin) / 8; /* HsStrt */ - he = (var->xres + var->right_margin + var->hsync_len) / 8; /* HsEnd */ - ht = (var->left_margin + var->xres + var->right_margin + var->hsync_len) / 8; /* HTotal */ - /* Blank */ - hbs = hd; - hbe = 0; /* Blank end at 0 */ - - /* Vertical */ - vd = var->yres; /* VDisplay */ - vs = var->yres + var->lower_margin; /* VSyncStart */ - ve = var->yres + var->lower_margin + var->vsync_len; /* VSyncEnd */ - vt = var->upper_margin + var->yres + var->lower_margin + var->vsync_len; /* VTotal */ - vbs = vd; - vbe = 0; - - bpp = bits_per_pixel; - dblscan = (var->vmode & FB_VMODE_DOUBLE) ? 1 : 0; - interlaced = var->vmode & FB_VMODE_INTERLACED; - - - if (bpp == 15) - bpp = 16; - wd = var->xres * bpp / 64; /* double words per line */ - if (interlaced) { /* we divide all vertical timings, exept vd */ - vs >>= 1; - vbs >>= 1; - ve >>= 1; - vt >>= 1; - } - - memset (cr, 0, sizeof (cr)); - cr[0x00] = ht - 5; - cr[0x01] = hd - 1; - cr[0x02] = hbs - 1; - cr[0x03] = (hbe & 0x1F); - cr[0x04] = hs; - cr[0x05] = ((hbe & 0x20) << 2) | (he & 0x1f); - - cr[0x06] = (vt - 2) & 0xFF; - cr[0x07] = (((vt - 2) & 0x100) >> 8) - | (((vd - 1) & 0x100) >> 7) - | ((vs & 0x100) >> 6) - | (((vbs - 1) & 0x100) >> 5) - | ((LineCompare & 0x100) >> 4) - | (((vt - 2) & 0x200) >> 4) - | (((vd - 1) & 0x200) >> 3) - | ((vs & 0x200) >> 2); - - cr[0x30] = ((vt - 2) & 0x400) >> 7 - | (((vd - 1) & 0x400) >> 8) - | (((vbs - 1) & 0x400) >> 9) - | ((vs & 0x400) >> 10) - | (interlaced) ? 0x80 : 0; - - - cr[0x08] = 0x00; - cr[0x09] = (dblscan << 7) - | ((LineCompare & 0x200) >> 3) - | (((vbs - 1) & 0x200) >> 4) - | (TextScanLines - 1); - - cr[0x10] = vs & 0xff; /* VSyncPulseStart */ - cr[0x11] = (ve & 0x0f); - cr[0x12] = (vd - 1) & 0xff; /* LineCount */ - cr[0x13] = wd & 0xff; - cr[0x14] = 0x40; - cr[0x15] = (vbs - 1) & 0xff; - cr[0x16] = vbe & 0xff; - cr[0x17] = 0xe3; /* but it does not work */ - cr[0x18] = 0xff & LineCompare; - cr[0x22] = 0x00; /* todo? */ - - - /* now set the registers */ - for (i = 0; i <= 0x18; i++) { /*CR00 .. CR18 */ - smiWrite (SMI_INDX_D4, i, cr[i]); - } - i = 0x22; /*CR22 */ - smiWrite (SMI_INDX_D4, i, cr[i]); - i = 0x30; /*CR30 */ - smiWrite (SMI_INDX_D4, i, cr[i]); -} - -/*****************************************************************************/ -#define REF_FREQ 14318180 -#define PMIN 1 -#define PMAX 255 -#define QMIN 1 -#define QMAX 63 - -static unsigned int FindPQ (unsigned int freq, unsigned int *pp, unsigned int *pq) -{ - unsigned int n = QMIN, m = 0; - long long int L = 0, P = freq, Q = REF_FREQ, H = P >> 1; - long long int D = 0x7ffffffffffffffLL; - - for (n = QMIN; n <= QMAX; n++) { - m = PMIN; /* p/q ~ freq/ref -> p*ref-freq*q ~ 0 */ - L = P * n - m * Q; - while (L > 0 && m < PMAX) { - L -= REF_FREQ; /* difference is greater as 0 subtract fref */ - m++; /* and increment m */ - } - /* difference is less or equal than 0 or m > maximum */ - if (m > PMAX) - break; /* no solution: if we increase n we get the same situation */ - /* L is <= 0 now */ - if (-L > H && m > PMIN) { /* if difference > the half fref */ - L += REF_FREQ; /* we take the situation before */ - m--; /* because its closer to 0 */ - } - L = (L < 0) ? -L : +L; /* absolute value */ - if (D < L) /* if last difference was better take next n */ - continue; - D = L; - *pp = m; - *pq = n; /* keep improved data */ - if (D == 0) - break; /* best result we can get */ - } - return (unsigned int) (0xffffffff & D); -} - -/*****************************************************************************/ -static void smiLoadCcr (struct ctfb_res_modes *var, unsigned short device_id) -{ - unsigned int p = 0; - unsigned int q = 0; - long long freq; - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - smiWrite (SMI_INDX_C4, 0x65, 0); - smiWrite (SMI_INDX_C4, 0x66, 0); - smiWrite (SMI_INDX_C4, 0x68, 0x50); - if (device_id == PCI_DEVICE_ID_SMI_810) { - smiWrite (SMI_INDX_C4, 0x69, 0x3); - } else { - smiWrite (SMI_INDX_C4, 0x69, 0x0); - } - - /* Memory clock */ - switch (device_id) { - case PCI_DEVICE_ID_SMI_710 : - smiWrite (SMI_INDX_C4, 0x6a, 0x75); - break; - case PCI_DEVICE_ID_SMI_712 : - smiWrite (SMI_INDX_C4, 0x6a, 0x80); - break; - default : - smiWrite (SMI_INDX_C4, 0x6a, 0x53); - break; - } - smiWrite (SMI_INDX_C4, 0x6b, 0x15); - - /* VCLK */ - freq = 1000000000000LL / var -> pixclock; - - FindPQ ((unsigned int)freq, &p, &q); - - smiWrite (SMI_INDX_C4, 0x6c, p); - smiWrite (SMI_INDX_C4, 0x6d, q); - -} - -/******************************************************************************* - * - * Init video chip with common Linux graphic modes (lilo) - */ -void *video_hw_init (void) -{ - GraphicDevice *pGD = (GraphicDevice *)&smi; - unsigned short device_id; - pci_dev_t devbusfn; - int videomode; - unsigned long t1, hsynch, vsynch; - unsigned int pci_mem_base, *vm; - char *penv; - int tmp, i, bits_per_pixel; - struct ctfb_res_modes *res_mode; - struct ctfb_res_modes var_mode; - unsigned char videoout; - - /* Search for video chip */ - printf("Video: "); - - if ((devbusfn = pci_find_devices(supported, 0)) < 0) - { - printf ("Controller not found !\n"); - return (NULL); - } - - /* PCI setup */ - pci_write_config_dword (devbusfn, PCI_COMMAND, (PCI_COMMAND_MEMORY | PCI_COMMAND_IO)); - pci_read_config_word (devbusfn, PCI_DEVICE_ID, &device_id); - pci_read_config_dword (devbusfn, PCI_BASE_ADDRESS_0, &pci_mem_base); - pci_mem_base = pci_mem_to_phys (devbusfn, pci_mem_base); - - tmp = 0; - - videomode = CONFIG_SYS_DEFAULT_VIDEO_MODE; - /* get video mode via environment */ - if ((penv = getenv ("videomode")) != NULL) { - /* deceide if it is a string */ - if (penv[0] <= '9') { - videomode = (int) simple_strtoul (penv, NULL, 16); - tmp = 1; - } - } else { - tmp = 1; - } - if (tmp) { - /* parameter are vesa modes */ - /* search params */ - for (i = 0; i < VESA_MODES_COUNT; i++) { - if (vesa_modes[i].vesanr == videomode) - break; - } - if (i == VESA_MODES_COUNT) { - printf ("no VESA Mode found, switching to mode 0x%x ", CONFIG_SYS_DEFAULT_VIDEO_MODE); - i = 0; - } - res_mode = - (struct ctfb_res_modes *) &res_mode_init[vesa_modes[i]. - resindex]; - bits_per_pixel = vesa_modes[i].bits_per_pixel; - } else { - - res_mode = (struct ctfb_res_modes *) &var_mode; - bits_per_pixel = video_get_params (res_mode, penv); - } - - /* calculate hsynch and vsynch freq (info only) */ - t1 = (res_mode->left_margin + res_mode->xres + - res_mode->right_margin + res_mode->hsync_len) / 8; - t1 *= 8; - t1 *= res_mode->pixclock; - t1 /= 1000; - hsynch = 1000000000L / t1; - t1 *= - (res_mode->upper_margin + res_mode->yres + - res_mode->lower_margin + res_mode->vsync_len); - t1 /= 1000; - vsynch = 1000000000L / t1; - - /* fill in Graphic device struct */ - sprintf (pGD->modeIdent, "%dx%dx%d %ldkHz %ldHz", res_mode->xres, - res_mode->yres, bits_per_pixel, (hsynch / 1000), - (vsynch / 1000)); - printf ("%s\n", pGD->modeIdent); - pGD->winSizeX = res_mode->xres; - pGD->winSizeY = res_mode->yres; - pGD->plnSizeX = res_mode->xres; - pGD->plnSizeY = res_mode->yres; - switch (bits_per_pixel) { - case 8: - pGD->gdfBytesPP = 1; - pGD->gdfIndex = GDF__8BIT_INDEX; - break; - case 15: - pGD->gdfBytesPP = 2; - pGD->gdfIndex = GDF_15BIT_555RGB; - break; - case 16: - pGD->gdfBytesPP = 2; - pGD->gdfIndex = GDF_16BIT_565RGB; - break; - case 24: - pGD->gdfBytesPP = 3; - pGD->gdfIndex = GDF_24BIT_888RGB; - break; - } - - pGD->isaBase = CONFIG_SYS_ISA_IO; - pGD->pciBase = pci_mem_base; - pGD->dprBase = (pci_mem_base + 0x400000 + 0x8000); - pGD->vprBase = (pci_mem_base + 0x400000 + 0xc000); - pGD->cprBase = (pci_mem_base + 0x400000 + 0xe000); - pGD->frameAdrs = pci_mem_base; - pGD->memSize = VIDEO_MEM_SIZE; - - /* Set up hardware : select color mode, - set Register base to isa 3dx for 3?x regs*/ - out8 (SMI_MISC_REG, 0x01); - - /* Turn off display */ - smiWrite (SMI_INDX_C4, 0x01, 0x20); - - /* Unlock ext. crt regs */ - out8 (SMI_LOCK_REG, 0x40); - - /* Unlock crt regs 0-7 */ - smiWrite (SMI_INDX_D4, 0x11, 0x0e); - - /* Sytem Control Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_SCR, sizeof(SMI_SCR)); - - /* extented CRT Register */ - smiLoadRegs (SMI_INDX_D4, SMI_DATA_D5, SMI_EXT_CRT, sizeof(SMI_EXT_CRT)); - - /* Attributes controller registers */ - smiLoadRegs (SMI_INDX_ATTR, SMI_INDX_ATTR, SMI_ATTR, sizeof(SMI_ATTR)); - - /* Graphics Controller Register */ - smiLoadRegs (SMI_INDX_CE, SMI_DATA_CF, SMI_GCR, sizeof(SMI_GCR)); - - /* Sequencer Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_SEQR, sizeof(SMI_SEQR)); - - /* Power Control Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_PCR, sizeof(SMI_PCR)); - - /* Memory Control Register */ - /* Register MSR62 is a power on configurable register. We don't */ - /* modify it */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_MCR, sizeof(SMI_MCR)); - - /* Set misc output register */ - smiLoadMsr (res_mode); - - /* Set CRT and Clock control registers */ - smiLoadCrt (res_mode, bits_per_pixel); - - smiLoadCcr (res_mode, device_id); - - /* Hardware Cusor Register */ - smiLoadRegs (SMI_INDX_C4, SMI_DATA_C5, SMI_HCR, sizeof(SMI_HCR)); - - /* Enable Display */ - videoout = 2; /* Default output is CRT */ - if ((penv = getenv ("videoout")) != NULL) { - /* deceide if it is a string */ - videoout = (int) simple_strtoul (penv, NULL, 16); - } - smiWrite (SMI_INDX_C4, 0x31, videoout); - - /* Video processor default setup */ - smiInitVideoProcessor (); - - /* Capture port default setup */ - smiInitCapturePort (); - - /* Drawing engine default setup */ - smiInitDrawingEngine (); - - /* Turn on display */ - smiWrite (0x3c4, 0x01, 0x01); - - /* Clear video memory */ - i = pGD->memSize/4; - vm = (unsigned int *)pGD->pciBase; - while(i--) - *vm++ = 0; - return ((void*)&smi); -} - -/******************************************************************************* - * - * Drawing engine fill on screen region - */ -void video_hw_rectfill ( - unsigned int bpp, /* bytes per pixel */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y, /* frame height */ - unsigned int color /* fill color */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register unsigned int control; - - dim_x *= bpp; - - out32r ((pGD->dprBase + 0x0014), color); - out32r ((pGD->dprBase + 0x0004), ((dst_x<<16) | dst_y)); - out32r ((pGD->dprBase + 0x0008), ((dim_x<<16) | dim_y)); - - control = 0x0000ffff & in32r ((pGD->dprBase + 0x000c)); - - control |= 0x80010000; - - out32r ((pGD->dprBase + 0x000c), control); - - /* Wait for drawing processor */ - do - { - out8 ((pGD->isaBase + 0x3c4), 0x16); - } while (in8 (pGD->isaBase + 0x3c5) & 0x08); -} - -/******************************************************************************* - * - * Drawing engine bitblt with screen region - */ -void video_hw_bitblt ( - unsigned int bpp, /* bytes per pixel */ - unsigned int src_x, /* source pos x */ - unsigned int src_y, /* source pos y */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y /* frame height */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - register unsigned int control; - - dim_x *= bpp; - - if ((src_y<dst_y) || ((src_y==dst_y) && (src_x<dst_x))) - { - out32r ((pGD->dprBase + 0x0000), (((src_x+dim_x-1)<<16) | (src_y+dim_y-1))); - out32r ((pGD->dprBase + 0x0004), (((dst_x+dim_x-1)<<16) | (dst_y+dim_y-1))); - control = 0x88000000; - } else { - out32r ((pGD->dprBase + 0x0000), ((src_x<<16) | src_y)); - out32r ((pGD->dprBase + 0x0004), ((dst_x<<16) | dst_y)); - control = 0x80000000; - } - - out32r ((pGD->dprBase + 0x0008), ((dim_x<<16) | dim_y)); - control |= (0x0000ffff & in32r ((pGD->dprBase + 0x000c))); - out32r ((pGD->dprBase + 0x000c), control); - - /* Wait for drawing processor */ - do - { - out8 ((pGD->isaBase + 0x3c4), 0x16); - } while (in8 (pGD->isaBase + 0x3c5) & 0x08); -} - -/******************************************************************************* - * - * Set a RGB color in the LUT (8 bit index) - */ -void video_set_lut ( - unsigned int index, /* color number */ - unsigned char r, /* red */ - unsigned char g, /* green */ - unsigned char b /* blue */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&smi; - - out8 (SMI_LUT_MASK, 0xff); - - out8 (SMI_LUT_START, (char)index); - - out8 (SMI_LUT_RGB, r>>2); /* red */ - udelay (10); - out8 (SMI_LUT_RGB, g>>2); /* green */ - udelay (10); - out8 (SMI_LUT_RGB, b>>2); /* blue */ - udelay (10); -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 7eca0f4..653eb35 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8300,7 +8300,6 @@ CONFIG_VIDEO_SM501_16BPP CONFIG_VIDEO_SM501_32BPP CONFIG_VIDEO_SM501_8BPP CONFIG_VIDEO_SM501_PCI -CONFIG_VIDEO_SMI_LYNXEM CONFIG_VIDEO_STD_TIMINGS CONFIG_VIDEO_SUNXI CONFIG_VIDEO_SW_CURSOR
This is not used anywhere in U-Boot.
Changes in v2: None
drivers/video/Makefile | 1 - drivers/video/imx25lcdc.c | 121 ---------------------------------------------- 2 files changed, 122 deletions(-) delete mode 100644 drivers/video/imx25lcdc.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 2df2015..6bb9e28 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -39,7 +39,6 @@ obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o obj-$(CONFIG_VIDEO_COREBOOT) += coreboot_fb.o obj-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o -obj-$(CONFIG_VIDEO_IMX25LCDC) += imx25lcdc.o videomodes.o obj-$(CONFIG_VIDEO_LCD_ANX9804) += anx9804.o obj-$(CONFIG_VIDEO_LCD_HITACHI_TX18D42VM) += hitachi_tx18d42vm_lcd.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o diff --git a/drivers/video/imx25lcdc.c b/drivers/video/imx25lcdc.c deleted file mode 100644 index ef5767b..0000000 --- a/drivers/video/imx25lcdc.c +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2011 - * Matthias Weisser weisserm@arcor.de - * - * SPDX-License-Identifier: GPL-2.0+ - * - * imx25lcdc.c - Graphic interface for i.MX25 lcd controller - */ - -#include <common.h> - -#include <malloc.h> -#include <asm/io.h> -#include <asm/arch/imx-regs.h> -#include <video_fb.h> -#include "videomodes.h" - -/* - * 4MB (at the end of system RAM) - */ -#define VIDEO_MEM_SIZE 0x400000 - -#define FB_SYNC_CLK_INV (1<<16) /* pixel clock inverted */ - -/* - * Graphic Device - */ -static GraphicDevice imx25fb; - -void *video_hw_init(void) -{ - struct lcdc_regs *lcdc = (struct lcdc_regs *)IMX_LCDC_BASE; - struct ccm_regs *ccm = (struct ccm_regs *)IMX_CCM_BASE; - GraphicDevice *pGD = &imx25fb; - char *s; - u32 *videomem; - - memset(pGD, 0, sizeof(GraphicDevice)); - - pGD->gdfIndex = GDF_16BIT_565RGB; - pGD->gdfBytesPP = 2; - pGD->memSize = VIDEO_MEM_SIZE; - pGD->frameAdrs = PHYS_SDRAM + PHYS_SDRAM_SIZE - VIDEO_MEM_SIZE; - - videomem = (u32 *)pGD->frameAdrs; - - s = getenv("videomode"); - if (s != NULL) { - struct ctfb_res_modes var_mode; - u32 lsr, lpcr, lhcr, lvcr; - unsigned long div; - int bpp; - - /* Disable all clocks of the LCDC */ - writel(readl(&ccm->cgr0) & ~((1<<7) | (1<<24)), &ccm->cgr0); - writel(readl(&ccm->cgr1) & ~(1<<29), &ccm->cgr1); - - bpp = video_get_params(&var_mode, s); - - if (bpp == 0) { - var_mode.xres = 320; - var_mode.yres = 240; - var_mode.pixclock = 154000; - var_mode.left_margin = 68; - var_mode.right_margin = 20; - var_mode.upper_margin = 4; - var_mode.lower_margin = 18; - var_mode.hsync_len = 40; - var_mode.vsync_len = 6; - var_mode.sync = 0; - var_mode.vmode = 0; - } - - /* Fill memory with white */ - memset(videomem, 0xFF, var_mode.xres * var_mode.yres * 2); - - imx25fb.winSizeX = var_mode.xres; - imx25fb.winSizeY = var_mode.yres; - - /* LCD base clock is 66.6MHZ. We do calculations in kHz */ - div = 66000 / (1000000000L / var_mode.pixclock); - if (div > 63) - div = 63; - if (0 == div) - div = 1; - - lsr = ((var_mode.xres / 16) << 20) | - var_mode.yres; - lpcr = (1 << 31) | - (1 << 30) | - (5 << 25) | - (1 << 23) | - (1 << 22) | - (1 << 19) | - (1 << 7) | - div; - lhcr = (var_mode.right_margin << 0) | - (var_mode.left_margin << 8) | - (var_mode.hsync_len << 26); - - lvcr = (var_mode.lower_margin << 0) | - (var_mode.upper_margin << 8) | - (var_mode.vsync_len << 26); - - writel((uint32_t)videomem, &lcdc->lssar); - writel(lsr, &lcdc->lsr); - writel(var_mode.xres * 2 / 4, &lcdc->lvpwr); - writel(lpcr, &lcdc->lpcr); - writel(lhcr, &lcdc->lhcr); - writel(lvcr, &lcdc->lvcr); - writel(0x00040060, &lcdc->ldcr); - - writel(0xA90300, &lcdc->lpccr); - - /* Ensable all clocks of the LCDC */ - writel(readl(&ccm->cgr0) | ((1<<7) | (1<<24)), &ccm->cgr0); - writel(readl(&ccm->cgr1) | (1<<29), &ccm->cgr1); - } - - return pGD; -}
This is not used in U-Boot.
Signed-off-by: Simon Glass sjg@chromium.org Acked-by: Minkyu Kang mk7.kang@samsung.com Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 2 +- drivers/video/s3c-fb.c | 172 -------------------------------------------- 3 files changed, 1 insertion(+), 174 deletions(-) delete mode 100644 drivers/video/s3c-fb.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 6bb9e28..412c948 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -48,7 +48,6 @@ obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o obj-$(CONFIG_VIDEO_MVEBU) += mvebu_lcd.o obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o -obj-$(CONFIG_VIDEO_S3C) += s3c-fb.o videomodes.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o obj-$(CONFIG_VIDEO_SED13806) += sed13806.o obj-$(CONFIG_VIDEO_SM501) += sm501.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index a087d2e..aca4444 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -104,7 +104,7 @@ #define VIDEO_HW_BITBLT #endif
-#if defined(CONFIG_VIDEO_MXS) || defined(CONFIG_VIDEO_S3C) +#if defined(CONFIG_VIDEO_MXS) #define VIDEO_FB_16BPP_WORD_SWAP #endif
diff --git a/drivers/video/s3c-fb.c b/drivers/video/s3c-fb.c deleted file mode 100644 index bea3e69..0000000 --- a/drivers/video/s3c-fb.c +++ /dev/null @@ -1,172 +0,0 @@ -/* - * S3C24x0 LCD driver - * - * NOTE: Only 16/24 bpp operation with TFT LCD is supported. - * - * Copyright (C) 2014 Marek Vasut marex@denx.de - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#include <common.h> -#include <malloc.h> -#include <video_fb.h> - -#include <linux/errno.h> -#include <asm/io.h> -#include <asm/arch/s3c24x0_cpu.h> - -#include "videomodes.h" - -static GraphicDevice panel; - -/* S3C requires the FB to be 4MiB aligned. */ -#define S3CFB_ALIGN (4 << 20) - -#define S3CFB_LCDCON1_CLKVAL(x) ((x) << 8) -#define S3CFB_LCDCON1_PNRMODE_TFT (0x3 << 5) -#define S3CFB_LCDCON1_BPPMODE_TFT_16BPP (0xc << 1) -#define S3CFB_LCDCON1_BPPMODE_TFT_24BPP (0xd << 1) - -#define S3CFB_LCDCON2_VBPD(x) ((x) << 24) -#define S3CFB_LCDCON2_LINEVAL(x) ((x) << 14) -#define S3CFB_LCDCON2_VFPD(x) ((x) << 6) -#define S3CFB_LCDCON2_VSPW(x) ((x) << 0) - -#define S3CFB_LCDCON3_HBPD(x) ((x) << 19) -#define S3CFB_LCDCON3_HOZVAL(x) ((x) << 8) -#define S3CFB_LCDCON3_HFPD(x) ((x) << 0) - -#define S3CFB_LCDCON4_HSPW(x) ((x) << 0) - -#define S3CFB_LCDCON5_BPP24BL (1 << 12) -#define S3CFB_LCDCON5_FRM565 (1 << 11) -#define S3CFB_LCDCON5_HWSWP (1 << 0) - -#define PS2KHZ(ps) (1000000000UL / (ps)) - -/* - * Example: - * setenv videomode video=ctfb:x:800,y:480,depth:16,mode:0,\ - * pclk:30066,le:41,ri:89,up:45,lo:12, - * hs:1,vs:1,sync:100663296,vmode:0 - */ -static void s3c_lcd_init(GraphicDevice *panel, - struct ctfb_res_modes *mode, int bpp) -{ - uint32_t clk_divider; - struct s3c24x0_lcd *regs = s3c24x0_get_base_lcd(); - - /* Stop the controller. */ - clrbits_le32(®s->lcdcon1, 1); - - /* Calculate clock divider. */ - clk_divider = (get_HCLK() / PS2KHZ(mode->pixclock)) / 1000; - clk_divider = DIV_ROUND_UP(clk_divider, 2); - if (clk_divider) - clk_divider -= 1; - - /* Program LCD configuration. */ - switch (bpp) { - case 16: - writel(S3CFB_LCDCON1_BPPMODE_TFT_16BPP | - S3CFB_LCDCON1_PNRMODE_TFT | - S3CFB_LCDCON1_CLKVAL(clk_divider), - ®s->lcdcon1); - writel(S3CFB_LCDCON5_HWSWP | S3CFB_LCDCON5_FRM565, - ®s->lcdcon5); - break; - case 24: - writel(S3CFB_LCDCON1_BPPMODE_TFT_24BPP | - S3CFB_LCDCON1_PNRMODE_TFT | - S3CFB_LCDCON1_CLKVAL(clk_divider), - ®s->lcdcon1); - writel(S3CFB_LCDCON5_BPP24BL, ®s->lcdcon5); - break; - } - - writel(S3CFB_LCDCON2_LINEVAL(mode->yres - 1) | - S3CFB_LCDCON2_VBPD(mode->upper_margin - 1) | - S3CFB_LCDCON2_VFPD(mode->lower_margin - 1) | - S3CFB_LCDCON2_VSPW(mode->vsync_len - 1), - ®s->lcdcon2); - - writel(S3CFB_LCDCON3_HBPD(mode->right_margin - 1) | - S3CFB_LCDCON3_HFPD(mode->left_margin - 1) | - S3CFB_LCDCON3_HOZVAL(mode->xres - 1), - ®s->lcdcon3); - - writel(S3CFB_LCDCON4_HSPW(mode->hsync_len - 1), - ®s->lcdcon4); - - /* Write FB address. */ - writel(panel->frameAdrs >> 1, ®s->lcdsaddr1); - writel((panel->frameAdrs + - (mode->xres * mode->yres * panel->gdfBytesPP)) >> 1, - ®s->lcdsaddr2); - writel(mode->xres * bpp / 16, ®s->lcdsaddr3); - - /* Start the controller. */ - setbits_le32(®s->lcdcon1, 1); -} - -void *video_hw_init(void) -{ - int bpp = -1; - char *penv; - void *fb; - struct ctfb_res_modes mode; - - puts("Video: "); - - /* Suck display configuration from "videomode" variable */ - penv = getenv("videomode"); - if (!penv) { - puts("S3CFB: 'videomode' variable not set!\n"); - return NULL; - } - - bpp = video_get_params(&mode, penv); - - /* fill in Graphic device struct */ - sprintf(panel.modeIdent, "%dx%dx%d", mode.xres, mode.yres, bpp); - - panel.winSizeX = mode.xres; - panel.winSizeY = mode.yres; - panel.plnSizeX = mode.xres; - panel.plnSizeY = mode.yres; - - switch (bpp) { - case 24: - panel.gdfBytesPP = 4; - panel.gdfIndex = GDF_32BIT_X888RGB; - break; - case 16: - panel.gdfBytesPP = 2; - panel.gdfIndex = GDF_16BIT_565RGB; - break; - default: - printf("S3CFB: Invalid BPP specified! (bpp = %i)\n", bpp); - return NULL; - } - - panel.memSize = mode.xres * mode.yres * panel.gdfBytesPP; - - /* Allocate framebuffer */ - fb = memalign(S3CFB_ALIGN, roundup(panel.memSize, S3CFB_ALIGN)); - if (!fb) { - printf("S3CFB: Error allocating framebuffer!\n"); - return NULL; - } - - /* Wipe framebuffer */ - memset(fb, 0, panel.memSize); - - panel.frameAdrs = (u32)fb; - - printf("%s\n", panel.modeIdent); - - /* Start framebuffer */ - s3c_lcd_init(&panel, &mode, bpp); - - return (void *)&panel; -}
Changes in v2: None
README | 5 - drivers/video/Makefile | 1 - drivers/video/cfb_console.c | 9 -- drivers/video/sed13806.c | 286 ------------------------------------------- include/sed13806.h | 81 ------------ scripts/config_whitelist.txt | 1 - 6 files changed, 383 deletions(-) delete mode 100644 drivers/video/sed13806.c delete mode 100644 include/sed13806.h
diff --git a/README b/README index 74ecb79..2dfdc52 100644 --- a/README +++ b/README @@ -1665,11 +1665,6 @@ CBFS (Coreboot Filesystem) support instead.
- Video support: - CONFIG_VIDEO_SED13806 - Enable Epson SED13806 driver. This driver supports 8bpp - and 16bpp modes defined by CONFIG_VIDEO_SED13806_8BPP - or CONFIG_VIDEO_SED13806_16BPP - CONFIG_FSL_DIU_FB Enable the Freescale DIU video driver. Reference boards for SOCs that have a DIU should define this macro to enable DIU diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 412c948..ff3617b 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -49,7 +49,6 @@ obj-$(CONFIG_VIDEO_MVEBU) += mvebu_lcd.o obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o -obj-$(CONFIG_VIDEO_SED13806) += sed13806.o obj-$(CONFIG_VIDEO_SM501) += sm501.o obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o videomodes.o obj-$(CONFIG_VIDEO_TEGRA20) += tegra.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index aca4444..ac7c402 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -95,15 +95,6 @@ #define VIDEO_HW_BITBLT #endif
-/* - * Defines for the SED13806 driver - */ -#ifdef CONFIG_VIDEO_SED13806 -#define VIDEO_FB_LITTLE_ENDIAN -#define VIDEO_HW_RECTFILL -#define VIDEO_HW_BITBLT -#endif - #if defined(CONFIG_VIDEO_MXS) #define VIDEO_FB_16BPP_WORD_SWAP #endif diff --git a/drivers/video/sed13806.c b/drivers/video/sed13806.c deleted file mode 100644 index cd7fac6..0000000 --- a/drivers/video/sed13806.c +++ /dev/null @@ -1,286 +0,0 @@ -/* - * (C) Copyright 2002 - * Stäubli Faverges - <www.staubli.com> - * Pierre AUBERT p.aubert@staubli.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -/* Video support for Epson SED13806 chipset */ - -#include <common.h> - -#include <video_fb.h> -#include <sed13806.h> - -#define readByte(ptrReg) \ - *(volatile unsigned char *)(sed13806.isaBase + ptrReg) - -#define writeByte(ptrReg,value) \ - *(volatile unsigned char *)(sed13806.isaBase + ptrReg) = value - -#define writeWord(ptrReg,value) \ - (*(volatile unsigned short *)(sed13806.isaBase + ptrReg) = ((value >> 8 ) & 0xff) | ((value << 8) & 0xff00)) - -GraphicDevice sed13806; - -/*----------------------------------------------------------------------------- - * EpsonSetRegs -- - *----------------------------------------------------------------------------- - */ -static void EpsonSetRegs (void) -{ - /* the content of the chipset register depends on the board (clocks, ...)*/ - const S1D_REGS *preg = board_get_regs (); - while (preg -> Index) { - writeByte (preg -> Index, preg -> Value); - preg ++; - } -} - -/*----------------------------------------------------------------------------- - * video_hw_init -- - *----------------------------------------------------------------------------- - */ -void *video_hw_init (void) -{ - unsigned int *vm, i; - - memset (&sed13806, 0, sizeof (GraphicDevice)); - - /* Initialization of the access to the graphic chipset - Retreive base address of the chipset - (see board/RPXClassic/eccx.c) */ - if ((sed13806.isaBase = board_video_init ()) == 0) { - return (NULL); - } - - sed13806.frameAdrs = sed13806.isaBase + FRAME_BUFFER_OFFSET; - sed13806.winSizeX = board_get_width (); - sed13806.winSizeY = board_get_height (); - -#if defined(CONFIG_VIDEO_SED13806_8BPP) - sed13806.gdfIndex = GDF__8BIT_INDEX; - sed13806.gdfBytesPP = 1; - -#elif defined(CONFIG_VIDEO_SED13806_16BPP) - sed13806.gdfIndex = GDF_16BIT_565RGB; - sed13806.gdfBytesPP = 2; - -#else -#error Unsupported SED13806 BPP -#endif - - sed13806.memSize = sed13806.winSizeX * sed13806.winSizeY * sed13806.gdfBytesPP; - - /* Load SED registers */ - EpsonSetRegs (); - - /* (see board/RPXClassic/RPXClassic.c) */ - board_validate_screen (sed13806.isaBase); - - /* Clear video memory */ - i = sed13806.memSize/4; - vm = (unsigned int *)sed13806.frameAdrs; - while(i--) - *vm++ = 0; - - - return (&sed13806); -} -/*----------------------------------------------------------------------------- - * Epson_wait_idle -- Wait for hardware to become idle - *----------------------------------------------------------------------------- - */ -static void Epson_wait_idle (void) -{ - while (readByte (BLT_CTRL0) & 0x80); - - /* Read a word in the BitBLT memory area to shutdown the BitBLT engine */ - *(volatile unsigned short *)(sed13806.isaBase + BLT_REG); -} - -/*----------------------------------------------------------------------------- - * video_hw_bitblt -- - *----------------------------------------------------------------------------- - */ -void video_hw_bitblt ( - unsigned int bpp, /* bytes per pixel */ - unsigned int src_x, /* source pos x */ - unsigned int src_y, /* source pos y */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y /* frame height */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&sed13806; - unsigned long srcAddr, dstAddr; - unsigned int stride = bpp * pGD -> winSizeX; - - srcAddr = (src_y * stride) + (src_x * bpp); - dstAddr = (dst_y * stride) + (dst_x * bpp); - - Epson_wait_idle (); - - writeByte(BLT_ROP,0x0C); /* source */ - writeByte(BLT_OP,0x02);/* move blit in positive direction with ROP */ - writeWord(BLT_MEM_OFF0, stride / 2); - if (pGD -> gdfIndex == GDF__8BIT_INDEX) { - writeByte(BLT_CTRL1,0x00); - } - else { - writeByte(BLT_CTRL1,0x01); - } - - writeWord(BLT_WIDTH0,(dim_x - 1)); - writeWord(BLT_HEIGHT0,(dim_y - 1)); - - /* set up blit registers */ - writeByte(BLT_SRC_ADDR0,srcAddr); - writeByte(BLT_SRC_ADDR1,srcAddr>>8); - writeByte(BLT_SRC_ADDR2,srcAddr>>16); - - writeByte(BLT_DST_ADDR0,dstAddr); - writeByte(BLT_DST_ADDR1,dstAddr>>8); - writeByte(BLT_DST_ADDR2,dstAddr>>16); - - /* Engage the blt engine */ - /* rectangular region for src and dst */ - writeByte(BLT_CTRL0,0x80); - - /* wait untill current blits finished */ - Epson_wait_idle (); -} -/*----------------------------------------------------------------------------- - * video_hw_rectfill -- - *----------------------------------------------------------------------------- - */ -void video_hw_rectfill ( - unsigned int bpp, /* bytes per pixel */ - unsigned int dst_x, /* dest pos x */ - unsigned int dst_y, /* dest pos y */ - unsigned int dim_x, /* frame width */ - unsigned int dim_y, /* frame height */ - unsigned int color /* fill color */ - ) -{ - register GraphicDevice *pGD = (GraphicDevice *)&sed13806; - unsigned long dstAddr; - unsigned int stride = bpp * pGD -> winSizeX; - - dstAddr = (dst_y * stride) + (dst_x * bpp); - - Epson_wait_idle (); - - /* set up blit registers */ - writeByte(BLT_DST_ADDR0,dstAddr); - writeByte(BLT_DST_ADDR1,dstAddr>>8); - writeByte(BLT_DST_ADDR2,dstAddr>>16); - - writeWord(BLT_WIDTH0,(dim_x - 1)); - writeWord(BLT_HEIGHT0,(dim_y - 1)); - writeWord(BLT_FGCOLOR0,color); - - writeByte(BLT_OP,0x0C); /* solid fill */ - writeWord(BLT_MEM_OFF0,stride / 2); - - if (pGD -> gdfIndex == GDF__8BIT_INDEX) { - writeByte(BLT_CTRL1,0x00); - } - else { - writeByte(BLT_CTRL1,0x01); - } - - /* Engage the blt engine */ - /* rectangular region for src and dst */ - writeByte(BLT_CTRL0,0x80); - - /* wait untill current blits finished */ - Epson_wait_idle (); -} - -/*----------------------------------------------------------------------------- - * video_set_lut -- - *----------------------------------------------------------------------------- - */ -void video_set_lut ( - unsigned int index, /* color number */ - unsigned char r, /* red */ - unsigned char g, /* green */ - unsigned char b /* blue */ - ) -{ - writeByte(REG_LUT_ADDR, index ); - writeByte(REG_LUT_DATA, r); - writeByte(REG_LUT_DATA, g); - writeByte(REG_LUT_DATA, b); -} -#ifdef CONFIG_VIDEO_HW_CURSOR -/*----------------------------------------------------------------------------- - * video_set_hw_cursor -- - *----------------------------------------------------------------------------- - */ -void video_set_hw_cursor (int x, int y) -{ - writeByte (LCD_CURSOR_XL, (x & 0xff)); - writeByte (LCD_CURSOR_XM, (x >> 8)); - writeByte (LCD_CURSOR_YL, (y & 0xff)); - writeByte (LCD_CURSOR_YM, (y >> 8)); -} - -/*----------------------------------------------------------------------------- - * video_init_hw_cursor -- - *----------------------------------------------------------------------------- - */ -void video_init_hw_cursor (int font_width, int font_height) -{ - volatile unsigned char *ptr; - unsigned char pattern; - int i; - - - /* Init cursor content - Cursor size is 64x64 pixels - Start of the cursor memory depends on panel type (dual panel ...) */ - if ((i = readByte (LCD_CURSOR_START)) == 0) { - ptr = (unsigned char *)(sed13806.frameAdrs + DEFAULT_VIDEO_MEMORY_SIZE - HWCURSORSIZE); - } - else { - ptr = (unsigned char *)(sed13806.frameAdrs + DEFAULT_VIDEO_MEMORY_SIZE - (i * 8192)); - } - - /* Fill the first line and the first empty line after cursor */ - for (i = 0, pattern = 0; i < 64; i++) { - if (i < font_width) { - /* Invert background */ - pattern |= 0x3; - - } - else { - /* Background */ - pattern |= 0x2; - } - if ((i & 3) == 3) { - *ptr = pattern; - *(ptr + font_height * 16) = 0xaa; - ptr ++; - pattern = 0; - } - pattern <<= 2; - } - - /* Duplicate this line */ - for (i = 1; i < font_height; i++) { - memcpy ((void *)ptr, (void *)(ptr - 16), 16); - ptr += 16; - } - - for (; i < 64; i++) { - memcpy ((void *)(ptr + 16), (void *)ptr, 16); - ptr += 16; - } - - /* Select cursor mode */ - writeByte (LCD_CURSOR_CNTL, 1); -} -#endif diff --git a/include/sed13806.h b/include/sed13806.h deleted file mode 100644 index 1cb0b86..0000000 --- a/include/sed13806.h +++ /dev/null @@ -1,81 +0,0 @@ -/* - * (C) Copyright 2002 - * Stäubli Faverges - <www.staubli.com> - * Pierre AUBERT p.aubert@staubli.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ -/* Video support for Epson SED13806 chipset */ - - -#ifndef _SED13806_H_ -#define _SED13806_H_ - - -/* General definitions */ -#define FRAME_BUFFER_OFFSET 0x200000 /* Frame buffer offset */ -#define TOTAL_SPACE_SIZE 0x400000 - -#define DEFAULT_VIDEO_MEMORY_SIZE 0x140000 /* Video Memory Size */ - -#define HWCURSORSIZE 1024 /* Size of memory reserved - for HW cursor*/ - -/* Offset of chipset registers */ -#define BLT_CTRL0 (0x0100) -#define BLT_CTRL1 (0x0101) -#define BLT_ROP (0x0102) -#define BLT_OP (0x0103) -#define BLT_SRC_ADDR0 (0x0104) -#define BLT_SRC_ADDR1 (0x0105) -#define BLT_SRC_ADDR2 (0x0106) -#define BLT_DST_ADDR0 (0x0108) -#define BLT_DST_ADDR1 (0x0109) -#define BLT_DST_ADDR2 (0x010A) -#define BLT_MEM_OFF0 (0x010C) -#define BLT_MEM_OFF1 (0x010D) -#define BLT_WIDTH0 (0x0110) -#define BLT_WIDTH1 (0x0111) -#define BLT_HEIGHT0 (0x0112) -#define BLT_HEIGHT1 (0x0113) -#define BLT_BGCOLOR0 (0x0114) -#define BLT_BGCOLOR1 (0x0115) -#define BLT_FGCOLOR0 (0x0118) -#define BLT_FGCOLOR1 (0x0119) - -#define BLT_REG (0x100000) - -/* Lookup table registers */ -#define REG_LUT_ADDR 0x1e2 -#define REG_LUT_DATA 0x1e4 - -/* Cursor/Ink registers */ -#define LCD_CURSOR_CNTL (0x0070) -#define LCD_CURSOR_START (0x0071) -#define LCD_CURSOR_XL (0x0072) -#define LCD_CURSOR_XM (0x0073) -#define LCD_CURSOR_YL (0x0074) -#define LCD_CURSOR_YM (0x0075) -#define LCD_CURSOR_COL0_B (0x0076) -#define LCD_CURSOR_COL0_G (0x0077) -#define LCD_CURSOR_COL0_R (0x0078) -#define LCD_CURSOR_COL1_B (0x007A) -#define LCD_CURSOR_COL1_G (0x007B) -#define LCD_CURSOR_COL1_R (0x007C) -#define LCD_CURSOR_FIFO (0x007E) - -typedef struct -{ - unsigned short Index; - unsigned char Value; -} S1D_REGS; - - -/* Board specific functions */ -unsigned int board_video_init (void); -void board_validate_screen (unsigned int base); -const S1D_REGS *board_get_regs (void); -int board_get_width (void); -int board_get_height (void); - -#endif /* _SED13806_H_ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 653eb35..2621cf4 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8294,7 +8294,6 @@ CONFIG_VIDEO_MXS CONFIG_VIDEO_MXS_MODE_SYSTEM CONFIG_VIDEO_OMAP3 CONFIG_VIDEO_ONBOARD -CONFIG_VIDEO_SED13806 CONFIG_VIDEO_SM501 CONFIG_VIDEO_SM501_16BPP CONFIG_VIDEO_SM501_32BPP
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this option.
Changes in v2: None
configs/Chuwi_V7_CW0825_defconfig | 2 +- configs/MSI_Primo81_defconfig | 2 +- configs/T1024QDS_NAND_defconfig | 2 +- configs/T1024QDS_SDCARD_defconfig | 2 +- configs/T1042D4RDB_NAND_defconfig | 2 +- configs/T1042D4RDB_SDCARD_defconfig | 2 +- configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig | 2 +- configs/T1042RDB_PI_NAND_defconfig | 2 +- configs/T1042RDB_PI_SDCARD_defconfig | 2 +- configs/bayleybay_defconfig | 3 +-- configs/chromebook_link_defconfig | 3 +-- configs/chromebox_panther_defconfig | 3 +-- configs/cm_fx6_defconfig | 1 - configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 3 +-- configs/conga-qeval20-qa3-e3845_defconfig | 3 +-- configs/coreboot-x86_defconfig | 1 - configs/crownbay_defconfig | 3 +-- configs/dfi-bt700-q7x-151_defconfig | 3 +-- configs/dms-ba16-1g_defconfig | 2 +- configs/dms-ba16_defconfig | 2 +- configs/gwventana_defconfig | 1 - configs/minnowmax_defconfig | 3 +-- configs/mx6cuboxi_defconfig | 1 - configs/mx6qsabrelite_defconfig | 1 - configs/nitrogen6dl2g_defconfig | 1 - configs/nitrogen6dl_defconfig | 1 - configs/nitrogen6q2g_defconfig | 1 - configs/nitrogen6q_defconfig | 1 - configs/nitrogen6s1g_defconfig | 1 - configs/nitrogen6s_defconfig | 1 - configs/novena_defconfig | 1 - configs/qemu-x86_defconfig | 3 +-- configs/qemu-x86_efi_payload32_defconfig | 3 +-- configs/qemu-x86_efi_payload64_defconfig | 3 +-- configs/som-db5800-som-6867_defconfig | 3 +-- configs/tbs2910_defconfig | 1 - configs/theadorable-x86-dfi-bt700_defconfig | 3 +-- configs/theadorable_debug_defconfig | 2 +- configs/theadorable_defconfig | 2 +- drivers/video/Kconfig | 10 ++++++++++ drivers/video/cfb_console.c | 6 ------ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/ac14xx.h | 4 ---- include/configs/advantech_dms-ba16.h | 1 - include/configs/aria.h | 4 ---- include/configs/aristainetos-common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/ea20.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/pdm360ng.h | 1 - include/configs/pxm2.h | 1 - include/configs/rut.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/theadorable.h | 1 - include/configs/wandboard.h | 1 - include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 98 files changed, 36 insertions(+), 122 deletions(-)
diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index e4ad8c9..147ee29 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -20,7 +20,7 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_MUSB_HOST=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" CONFIG_VIDEO_LCD_SPI_MOSI="PA2" +CONFIG_CFB_CONSOLE=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index a05cf5f..d4b2294 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -20,10 +20,10 @@ CONFIG_SPL=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_LCD_SSD2828_TX_CLK=27 CONFIG_VIDEO_LCD_SSD2828_RESET="PA26" CONFIG_VIDEO_LCD_SPI_CS="PH9" CONFIG_VIDEO_LCD_SPI_SCLK="PH10" CONFIG_VIDEO_LCD_SPI_MOSI="PH11" CONFIG_VIDEO_LCD_SPI_MISO="PH12" +CONFIG_CFB_CONSOLE=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index fd1c6c2..f37fb08 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y @@ -39,6 +40,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 66d22fa..09fff32 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T102XQDS=y CONFIG_FIT=y @@ -39,6 +40,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index fff6c4d..ba0dea2 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -37,7 +38,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 657a2cb..55b6ea8 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -37,7 +38,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig index c915b17..62f45db 100644 --- a/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_PI_NAND_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -41,7 +42,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_CFB_CONSOLE_ANSI=y CONFIG_RSA=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index ffd0ec1..63e4e92 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -37,7 +38,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 9a41b6a..833da15 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_VIDEO=y CONFIG_MPC85xx=y CONFIG_TARGET_T104XRDB=y CONFIG_FIT=y @@ -37,7 +38,6 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_CFB_CONSOLE_ANSI=y CONFIG_OF_LIBFDT=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 5b48adc..0a78639 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -16,7 +16,6 @@ CONFIG_SEABIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -56,8 +55,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 163e565..d850b4e 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -11,7 +11,6 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -60,9 +59,9 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index c2df7ae..74bf6f0 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -9,7 +9,6 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set @@ -52,9 +51,9 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 1296229..5e41aea 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index d0fdc91..779de99 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -64,8 +63,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index dc41207..7e720a4 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -63,8 +62,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 7c1f588..7d06350 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -5,7 +5,6 @@ CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index baf69d8..7b53184 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -9,7 +9,6 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -50,7 +49,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index dd4ca36..28b9edc 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -61,8 +60,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index fbe7370..e81e15c 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_SYS_DDR_1G=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y @@ -32,6 +33,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Advantech" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index b2a2655..17f3c2a 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_ADVANTECH_DMS_BA16=y +CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y @@ -31,6 +32,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Advantech" CONFIG_G_DNL_VENDOR_NUM=0x0525 CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -CONFIG_VIDEO=y CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index cd40d51..9acd83f 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -17,7 +17,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 386a927..e720094 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -16,7 +16,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -60,8 +59,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index b0f89e1..855edcb 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -12,7 +12,6 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 776dfe8..3ba2ef7 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index e97e523..23d173c 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index ab5e937..de711c6 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 9fef12f..c9909d2 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 5a5986a..b331043 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 8bc6ca9..30774c4 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 42676eb..fd9096e 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -4,7 +4,6 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 5915010..021711b 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -14,7 +14,6 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index cf43cad..4d4b85d 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -9,7 +9,6 @@ CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -47,8 +46,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 102c2f9..e55b285 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -6,7 +6,6 @@ CONFIG_MAX_CPUS=2 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -44,10 +43,10 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 133fb88..1c3138c 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -6,7 +6,6 @@ CONFIG_MAX_CPUS=2 CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -44,10 +43,10 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 41bdd49..d52c94c 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -58,8 +57,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index b0f5f1e..80bd31f 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -6,7 +6,6 @@ CONFIG_PRE_CON_BUF_ADDR=0x7c000000 CONFIG_VIDEO=y CONFIG_FIT=y CONFIG_BOOTDELAY=3 -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index ea0b772..7bb823b 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -15,7 +15,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y @@ -58,8 +57,8 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y +CONFIG_CFB_CONSOLE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index d45cb6e..51deddc 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -49,5 +49,5 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_MVEBU=y +CONFIG_CFB_CONSOLE=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index fb89510..9c7a79f 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -39,7 +39,7 @@ CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y -CONFIG_CFB_CONSOLE=y CONFIG_VIDEO_MVEBU=y +CONFIG_CFB_CONSOLE=y CONFIG_REGEX=y CONFIG_LIB_RAND=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index de6f419..c70f6a1 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -471,6 +471,16 @@ config CFB_CONSOLE_ANSI erase functions and limited graphics rendition control). Normal output from U-Boot will pass through this filter.
+config VGA_AS_SINGLE_DEVICE + bool "Set the video as an output-only device" + depends on CFB_CONSOLE + default y + help + If enable the framebuffer device will be initialized as an + output-only device. The Keyboard driver will not be set up. This + may be used if you have no keyboard device, or more than one + (USB Keyboard, AT Keyboard). + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index ac7c402..3a8e20b 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -58,12 +58,6 @@ * info); * that fills a info buffer at i=row. * s.a: board/eltec/bab7xx. - * CONFIG_VGA_AS_SINGLE_DEVICE - If set the framebuffer device will be - * initialized as an output only device. - * The Keyboard driver will not be - * set-up. This may be used, if you have - * no or more than one Keyboard devices - * (USB Keyboard, AT Keyboard). * * CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last * character. No blinking is provided. diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 501411b..0fc3131 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -344,7 +344,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #undef CONFIG_VIDEO_ONBOARD /************************************************************ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index e4fec53..0900540 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -508,7 +508,6 @@ #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE3_IO_VIRT diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 23e8de4..76eb674 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -281,7 +281,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 1571c8a..3f43d75 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -468,7 +468,6 @@ #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 699293c..c5295f9 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index ce4e33f..37dd44e 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -381,7 +381,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE2_IO_VIRT diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index c4e3e65..e391088 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -382,7 +382,6 @@ #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS @@ -403,7 +402,6 @@ #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET -#define CONFIG_VGA_AS_SINGLE_DEVICE #endif
/* I2C */ diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 54dbe4c..2b3cf19 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -304,7 +304,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_ONBOARD /* Video controller is on-board */
diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index d8a53bc..1c18495 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -503,7 +503,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index d8792d6..9b0b917 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -501,7 +501,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index af63dd3..2ae6573 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -415,7 +415,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index cf59eb7..4b5e451 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -485,7 +485,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 9ecc363..c5705f5 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -108,7 +108,6 @@ #define CONFIG_VIDEO_BMP_LOGO #endif
-#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #endif /* #ifndef CONFIG_TQM5200S */ diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index f1013c4..2f3668a 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -32,10 +32,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFFF00000
-#if defined(CONFIG_VIDEO) -#define CONFIG_VGA_AS_SINGLE_DEVICE -#endif - #define CONFIG_SYS_MPC512X_CLKIN 25000000 /* in Hz */ #define SCFR1_IPS_DIV 2 #define SCFR1_LPC_DIV 2 diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 840e3d9..2cbbac2 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -276,7 +276,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/aria.h b/include/configs/aria.h index 7b7e6e2..d7b043c 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -39,10 +39,6 @@
/* video */
-#if defined(CONFIG_VIDEO) -#define CONFIG_VGA_AS_SINGLE_DEVICE -#endif - /* CONFIG_PCI is defined at config time */
#define CONFIG_SYS_MPC512X_CLKIN 33000000 /* in Hz */ diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index a472d76..d786778 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -235,7 +235,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 8e5b538..9f6b950 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -94,7 +94,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 55a5f93..bb036dc 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -256,7 +256,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR
#define CONFIG_SPLASH_SCREEN diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index bbe9c81..d3b43eb 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -231,7 +231,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 47a3002..6770bd0 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -225,7 +225,6 @@ */ #define CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP
/* diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index b90554f..2551de4 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -81,7 +81,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index eac37c3..58493e9 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -102,7 +102,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_CONSOLE_INFO_QUIET diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index e115fd5..9e0c945 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -118,7 +118,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 3baac67..c1053f8 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -307,7 +307,6 @@ /* Framebuffer */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 9f4d1a0..050c055 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -182,7 +182,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_CMD_HDMIDETECT diff --git a/include/configs/icon.h b/include/configs/icon.h index f858b99..c38a254 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -134,7 +134,6 @@ #define VIDEO_FB_LITTLE_ENDIAN #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 5a20437..f833f7d 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -184,7 +184,6 @@ #define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 99200d1..436bc75 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -51,7 +51,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 95b68b4..5ffdd19 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -444,7 +444,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_DCU_FB #define CONFIG_CMD_BMP -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 3c596f3..d1e01fe 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -332,7 +332,6 @@
diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 58446b5..d812e66 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -360,7 +360,6 @@ #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 9abd450..aefe804 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -202,7 +202,6 @@ */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 1b95479..ed82b9c 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -372,7 +372,6 @@ #define CONFIG_NET_RETRY_COUNT 10 #endif
-#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index ac3ac35..50a6ccd 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) #define CONFIG_CMD_BMP #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 3ec2358..2420612 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -51,7 +51,6 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
-#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_CMD_BMP diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 4ecd7fd..968662d 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -97,7 +97,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 89e5557..258a856 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -216,7 +216,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 158858f..82957d6 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -35,7 +35,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index a45c589..71a4231 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -209,7 +209,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index e288ad8..b45ad72 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -209,7 +209,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index c9ca034..8002796 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -232,7 +232,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index c0c9b12..39ea3c2 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -261,7 +261,6 @@ #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 52083c8..33459d7 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -145,7 +145,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #endif
/* MMC */ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index d18c177..63ef4e7 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/novena.h b/include/configs/novena.h index 40194f0..0983b96 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -161,7 +161,6 @@ /* Video output */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index acadf72..f5fcef8 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -41,7 +41,6 @@ /* Video */
#if defined(CONFIG_VIDEO) -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_RLE8 diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 6cc8d6c..2aa184a 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -126,7 +126,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/rut.h b/include/configs/rut.h index 11f9a25..3d7b85f 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -120,7 +120,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index facfdac..153646f 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -411,7 +411,6 @@ #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_SPLASH_SCREEN -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CMD_BMP #endif
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 5abdd23..9d92a06 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -176,7 +176,6 @@ #define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index d81dc21..1c7b839 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -298,7 +298,6 @@ extern int soft_i2c_gpio_scl;
/* allow both serial and cfb console. */ /* stop x86 thinking in cfbconsole from trying to init a pc keyboard */ -#define CONFIG_VGA_AS_SINGLE_DEVICE
#endif /* CONFIG_VIDEO */
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 340ae9c..da1dea8 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -75,7 +75,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_VIDEO_SW_CURSOR -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 365019a..fe2ca6f 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -96,7 +96,6 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
/* FPGA programming support */ diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index aacf4ef..4d219e2 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -75,7 +75,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 7633a43..c1f6b91 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -131,7 +131,6 @@ */ #define CONFIG_VIDEO_SW_CURSOR #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_CONSOLE_SCROLL_LINES 5
/*----------------------------------------------------------------------- diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2621cf4..909aef1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8273,7 +8273,6 @@ CONFIG_VERY_BIG_RAM CONFIG_VEXPRESS_EXTENDED_MEMORY_MAP CONFIG_VEXPRESS_ORIGINAL_MEMORY_MAP CONFIG_VF610 -CONFIG_VGA_AS_SINGLE_DEVICE CONFIG_VID CONFIG_VIDEO_BCM2835 CONFIG_VIDEO_BMP_GZIP
This is not used in U-Boot.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
drivers/video/cfb_console.c | 33 +----------------- drivers/video/ct69000.c | 79 -------------------------------------------- include/video_fb.h | 4 --- scripts/config_whitelist.txt | 1 - 4 files changed, 1 insertion(+), 116 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 3a8e20b..a99fc00 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -63,14 +63,6 @@ * character. No blinking is provided. * Uses the macros CURSOR_SET and * CURSOR_OFF. - * - * CONFIG_VIDEO_HW_CURSOR: - Uses the hardware cursor capability - * of the graphic chip. Uses the macro - * CURSOR_SET. ATTENTION: If booting an - * OS, the display driver must disable - * the hardware register of the graphic - * chip. Otherwise a blinking field is - * displayed. */
#include <common.h> @@ -154,13 +146,8 @@ * CONFIG_VIDEO_SW_CURSOR: Draws a cursor after the last character. No * blinking is provided. Uses the macros CURSOR_SET * and CURSOR_OFF. - * CONFIG_VIDEO_HW_CURSOR: Uses the hardware cursor capability of the - * graphic chip. Uses the macro CURSOR_SET. - * ATTENTION: If booting an OS, the display driver - * must disable the hardware register of the graphic - * chip. Otherwise a blinking field is displayed */ -#if !defined(CONFIG_VIDEO_SW_CURSOR) && !defined(CONFIG_VIDEO_HW_CURSOR) +#if !defined(CONFIG_VIDEO_SW_CURSOR) /* no Cursor defined */ #define CURSOR_ON #define CURSOR_OFF @@ -168,10 +155,6 @@ #endif
#if defined(CONFIG_VIDEO_SW_CURSOR) -#if defined(CONFIG_VIDEO_HW_CURSOR) -#error only one of CONFIG_VIDEO_SW_CURSOR or CONFIG_VIDEO_HW_CURSOR can be \ - defined -#endif void console_cursor(int state);
#define CURSOR_ON console_cursor(1) @@ -179,17 +162,6 @@ void console_cursor(int state); #define CURSOR_SET video_set_cursor() #endif /* CONFIG_VIDEO_SW_CURSOR */
-#ifdef CONFIG_VIDEO_HW_CURSOR -#ifdef CURSOR_ON -#error only one of CONFIG_VIDEO_SW_CURSOR or CONFIG_VIDEO_HW_CURSOR can be \ - defined -#endif -#define CURSOR_ON -#define CURSOR_OFF -#define CURSOR_SET video_set_hw_cursor(console_col * VIDEO_FONT_WIDTH, \ - (console_row * VIDEO_FONT_HEIGHT) + video_logo_height) -#endif /* CONFIG_VIDEO_HW_CURSOR */ - #ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO #include <bmp_logo.h> @@ -2056,9 +2028,6 @@ static int video_init(void) return -1;
video_fb_address = (void *) VIDEO_FB_ADRS; -#ifdef CONFIG_VIDEO_HW_CURSOR - video_init_hw_cursor(VIDEO_FONT_WIDTH, VIDEO_FONT_HEIGHT); -#endif
cfb_do_flush_cache = cfb_fb_is_in_dram() && dcache_status();
diff --git a/drivers/video/ct69000.c b/drivers/video/ct69000.c index 349da5e..a74e4e6 100644 --- a/drivers/video/ct69000.c +++ b/drivers/video/ct69000.c @@ -804,85 +804,6 @@ video_dump_reg (void)
#endif
-#ifdef CONFIG_VIDEO_HW_CURSOR -/*************************************************************** - * Set Hardware Cursor in Pixel - */ -void -video_set_hw_cursor (int x, int y) -{ - int sig_x = 0, sig_y = 0; - if (x < 0) { - x *= -1; - sig_x = 1; - } - if (y < 0) { - y *= -1; - sig_y = 1; - } - ctWrite_i (CT_XR_O, 0xa4, x & 0xff); - ctWrite_i (CT_XR_O, 0xa5, (x >> 8) & 0x7); - ctWrite_i (CT_XR_O, 0xa6, y & 0xff); - ctWrite_i (CT_XR_O, 0xa7, (y >> 8) & 0x7); -} - -/*************************************************************** - * Init Hardware Cursor. To know the size of the Cursor, - * we have to know the Font size. - */ -void -video_init_hw_cursor (int font_width, int font_height) -{ - unsigned char xr_80; - unsigned long *curs, pattern; - int i; - int cursor_start; - GraphicDevice *pGD = (GraphicDevice *) & ctfb; - - cursor_start = pGD->dprBase; - xr_80 = ctRead_i (CT_XR_O, 0x80); - /* set start address */ - ctWrite_i (CT_XR_O, 0xa2, (cursor_start >> 8) & 0xf0); - ctWrite_i (CT_XR_O, 0xa3, (cursor_start >> 16) & 0x3f); - /* set cursor shape */ - curs = (unsigned long *) cursor_start; - i = 0; - while (i < 0x400) { - curs[i++] = 0xffffffff; /* AND mask */ - curs[i++] = 0xffffffff; /* AND mask */ - curs[i++] = 0; /* XOR mask */ - curs[i++] = 0; /* XOR mask */ - /* Transparent */ - } - pattern = 0xffffffff >> font_width; - i = 0; - while (i < (font_height * 2)) { - curs[i++] = pattern; /* AND mask */ - curs[i++] = pattern; /* AND mask */ - curs[i++] = 0; /* XOR mask */ - curs[i++] = 0; /* XOR mask */ - /* Cursor Color 0 */ - } - /* set blink rate */ - ctWrite_i (CT_FP_O, 0x19, 0xf); - - /* set cursors colors */ - xr_80 = ctRead_i (CT_XR_O, 0x80); - xr_80 |= 0x1; /* alternate palette select */ - ctWrite_i (CT_XR_O, 0x80, xr_80); - video_set_lut(4, CONFIG_SYS_CONSOLE_FG_COL, CONFIG_SYS_CONSOLE_FG_COL, - CONFIG_SYS_CONSOLE_FG_COL); - /* position 4 is color 0 cursor 0 */ - xr_80 &= 0xfe; /* normal palette select */ - ctWrite_i (CT_XR_O, 0x80, xr_80); - /* cursor enable */ - ctWrite_i (CT_XR_O, 0xa0, 0x91); - xr_80 |= 0x10; /* enable hwcursor */ - ctWrite_i (CT_XR_O, 0x80, xr_80); - video_set_hw_cursor (0, 0); -} -#endif /* CONFIG_VIDEO_HW_CURSOR */ - /*************************************************************** * Wait for BitBlt ready */ diff --git a/include/video_fb.h b/include/video_fb.h index b7e3aee..b008853 100644 --- a/include/video_fb.h +++ b/include/video_fb.h @@ -88,9 +88,5 @@ void video_set_lut ( unsigned char g, /* green */ unsigned char b /* blue */ ); -#ifdef CONFIG_VIDEO_HW_CURSOR -void video_set_hw_cursor(int x, int y); /* x y in pixel */ -void video_init_hw_cursor(int font_width, int font_height); -#endif
#endif /*_VIDEO_FB_H_ */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 909aef1..80a79fb 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8282,7 +8282,6 @@ CONFIG_VIDEO_CORALP CONFIG_VIDEO_DA8XX CONFIG_VIDEO_DT_SIMPLEFB CONFIG_VIDEO_FONT_4X6 -CONFIG_VIDEO_HW_CURSOR CONFIG_VIDEO_IPUV3 CONFIG_VIDEO_LCD_I2C_BUS CONFIG_VIDEO_LOGO
This converts the following to Kconfig: CONFIG_VIDEO_SW_CURSOR
Changes in v2: None
drivers/video/Kconfig | 10 ++++++++++ drivers/video/cfb_console.c | 6 ------ include/configs/MIP405.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8544DS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/P1022DS.h | 2 -- include/configs/PIP405.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/TQM5200.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/icon.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/ipek01.h | 1 - include/configs/lwmon5.h | 1 - include/configs/mpc5121ads.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/mxs.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/sequoia.h | 1 - include/configs/socrates.h | 1 - include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/x86-common.h | 1 - scripts/config_whitelist.txt | 1 - 34 files changed, 10 insertions(+), 39 deletions(-)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index c70f6a1..80b585b 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -481,6 +481,16 @@ config VGA_AS_SINGLE_DEVICE may be used if you have no keyboard device, or more than one (USB Keyboard, AT Keyboard).
+config VIDEO_SW_CURSOR + bool "Enable a software cursor" + depends on CFB_CONSOLE + default y if CFB_CONSOLE + help + This draws a cursor after the last character. No blinking is + provided. This makes it possible to see the current cursor + position when entering text on the console. It is recommended to + enable this. + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index a99fc00..56d3c15 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -141,12 +141,6 @@ #include <splash.h> #endif
-/* - * Cursor definition: - * CONFIG_VIDEO_SW_CURSOR: Draws a cursor after the last character. No - * blinking is provided. Uses the macros CURSOR_SET - * and CURSOR_OFF. - */ #if !defined(CONFIG_VIDEO_SW_CURSOR) /* no Cursor defined */ #define CURSOR_ON diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 0fc3131..257fa47 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -344,7 +344,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #undef CONFIG_VIDEO_ONBOARD /************************************************************ * USB support EXPERIMENTAL diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 0900540..cba393a 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -507,7 +507,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE3_IO_VIRT diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 76eb674..c3d69cb 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -280,7 +280,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 3f43d75..509728c 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -467,7 +467,6 @@
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index c5295f9..7882b35 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -26,7 +26,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 37dd44e..2c15f3d 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -380,7 +380,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#if defined(CONFIG_VIDEO) #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS CONFIG_SYS_PCIE2_IO_VIRT diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index e391088..347a88d 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -381,7 +381,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x10000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS @@ -398,7 +397,6 @@ #ifdef CONFIG_ATI #define VIDEO_IO_OFFSET CONFIG_SYS_PCIE1_IO_VIRT #define CONFIG_BIOSEMU -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 2b3cf19..70e75c1 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -304,7 +304,6 @@ ************************************************************/ #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_ONBOARD /* Video controller is on-board */
/************************************************************ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 1c18495..1a97858 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -502,7 +502,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 9b0b917..c471b60 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -500,7 +500,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 2ae6573..5808868 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -414,7 +414,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 4b5e451..d542d15 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -484,7 +484,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_FSL_DIU_CH7301 #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x180000) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index c5705f5..06d2be5 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -108,7 +108,6 @@ #define CONFIG_VIDEO_BMP_LOGO #endif
-#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #endif /* #ifndef CONFIG_TQM5200S */
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index bb036dc..325c019 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -256,7 +256,6 @@ #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 #define CONFIG_IMX_HDMI -#define CONFIG_VIDEO_SW_CURSOR
#define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SOURCE diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index d3b43eb..ba20384 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -230,7 +230,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 2551de4..26554b7 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -80,7 +80,6 @@ #define CONFIG_VIDEO_CORALP #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/icon.h b/include/configs/icon.h index c38a254..3a72a66 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -134,7 +134,6 @@ #define VIDEO_FB_LITTLE_ENDIAN #define CONFIG_VIDEO_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CFG_CONSOLE_IS_IN_ENV diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index f833f7d..968c26d 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -183,7 +183,6 @@
#define CONFIG_VIDEO_MX3 #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP #define CONFIG_BMP_16BPP diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 436bc75..5298376 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -51,7 +51,6 @@ #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CONSOLE_EXTRA_INFO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index d812e66..2e89b1a 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -360,7 +360,6 @@ #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP
/* diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 50a6ccd..509097f 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -38,7 +38,6 @@ #ifdef CONFIG_FSL_DIU_FB #define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) #define CONFIG_CMD_BMP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index b45ad72..ecaeccf 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -208,7 +208,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 8002796..df11e08 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -231,7 +231,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 39ea3c2..4cc9027 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -260,7 +260,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_CMD_BMP diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 33459d7..df0cc23 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -144,7 +144,6 @@ /* LCD */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS -#define CONFIG_VIDEO_SW_CURSOR #endif
/* MMC */ diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index a78262c..0064e12 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -234,7 +234,6 @@ #define CONFIG_VIDEO_LOGO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN
/* functions for cfb_console */ diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index 153646f..ff2f6c0 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -408,7 +408,6 @@ #define CONFIG_ATI_RADEON_FB /* use radeon framebuffer driver */ #define VIDEO_IO_OFFSET 0xe8000000 #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 9d92a06..16e4b02 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -176,7 +176,6 @@ #define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 1c7b839..e96f426 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -290,7 +290,6 @@ extern int soft_i2c_gpio_scl;
#define CONFIG_VIDEO_SUNXI
-#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_STD_TIMINGS #define CONFIG_I2C_EDID diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index da1dea8..8fdeaa1 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -74,7 +74,6 @@ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 #define CONFIG_IPUV3_CLK 260000000 -#define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index c1f6b91..352de68 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -129,7 +129,6 @@ /*----------------------------------------------------------------------- * Video Configuration */ -#define CONFIG_VIDEO_SW_CURSOR #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_CONSOLE_SCROLL_LINES 5
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 80a79fb..e246eb3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -8299,7 +8299,6 @@ CONFIG_VIDEO_SM501_8BPP CONFIG_VIDEO_SM501_PCI CONFIG_VIDEO_STD_TIMINGS CONFIG_VIDEO_SUNXI -CONFIG_VIDEO_SW_CURSOR CONFIG_VIDEO_VCXK CONFIG_VID_FLS_ENV CONFIG_VM86
Since all boards enable this, we may as well drop the option.
This is a separate patch from the previous one, so it can be skipped if someone identifies a need.
Changes in v2: None
README | 1 - drivers/video/Kconfig | 10 ---------- drivers/video/cfb_console.c | 46 ++++++++++++--------------------------------- 3 files changed, 12 insertions(+), 45 deletions(-)
diff --git a/README b/README index 2dfdc52..cf83fc3 100644 --- a/README +++ b/README @@ -1674,7 +1674,6 @@ CBFS (Coreboot Filesystem) support CONFIG_VIDEO CONFIG_CMD_BMP CONFIG_CFB_CONSOLE - CONFIG_VIDEO_SW_CURSOR CONFIG_VGA_AS_SINGLE_DEVICE CONFIG_VIDEO_LOGO CONFIG_VIDEO_BMP_LOGO diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 80b585b..c70f6a1 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -481,16 +481,6 @@ config VGA_AS_SINGLE_DEVICE may be used if you have no keyboard device, or more than one (USB Keyboard, AT Keyboard).
-config VIDEO_SW_CURSOR - bool "Enable a software cursor" - depends on CFB_CONSOLE - default y if CFB_CONSOLE - help - This draws a cursor after the last character. No blinking is - provided. This makes it possible to see the current cursor - position when entering text on the console. It is recommended to - enable this. - config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 56d3c15..c788651 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -58,11 +58,6 @@ * info); * that fills a info buffer at i=row. * s.a: board/eltec/bab7xx. - * - * CONFIG_VIDEO_SW_CURSOR: - Draws a cursor after the last - * character. No blinking is provided. - * Uses the macros CURSOR_SET and - * CURSOR_OFF. */
#include <common.h> @@ -141,21 +136,6 @@ #include <splash.h> #endif
-#if !defined(CONFIG_VIDEO_SW_CURSOR) -/* no Cursor defined */ -#define CURSOR_ON -#define CURSOR_OFF -#define CURSOR_SET -#endif - -#if defined(CONFIG_VIDEO_SW_CURSOR) -void console_cursor(int state); - -#define CURSOR_ON console_cursor(1) -#define CURSOR_OFF console_cursor(0) -#define CURSOR_SET video_set_cursor() -#endif /* CONFIG_VIDEO_SW_CURSOR */ - #ifdef CONFIG_VIDEO_LOGO #ifdef CONFIG_VIDEO_BMP_LOGO #include <bmp_logo.h> @@ -529,14 +509,6 @@ static void video_putchar(int xx, int yy, unsigned char c) video_drawchars(xx, yy + video_logo_height, &c, 1); }
-#if defined(CONFIG_VIDEO_SW_CURSOR) -static void video_set_cursor(void) -{ - if (cursor_state) - console_cursor(0); - console_cursor(1); -} - static void video_invertchar(int xx, int yy) { int firstx = xx * VIDEO_PIXEL_SIZE; @@ -552,7 +524,7 @@ static void video_invertchar(int xx, int yy) } }
-void console_cursor(int state) +static void console_cursor(int state) { if (cursor_state != state) { if (cursor_state) { @@ -573,7 +545,13 @@ void console_cursor(int state) if (cfb_do_flush_cache) flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); } -#endif + +static void video_set_cursor(void) +{ + if (cursor_state) + console_cursor(0); + console_cursor(1); +}
#ifndef VIDEO_HW_RECTFILL static void memsetl(int *p, int c, int v) @@ -779,7 +757,7 @@ static void parse_putc(const char c) static int nl = 1;
if (console_cursor_is_visible()) - CURSOR_OFF; + console_cursor(0);
switch (c) { case 13: /* back to first column */ @@ -820,7 +798,7 @@ static void parse_putc(const char c) }
if (console_cursor_is_visible()) - CURSOR_SET; + video_set_cursor(); }
static void video_putc(struct stdio_dev *dev, const char c) @@ -951,7 +929,7 @@ static void video_putc(struct stdio_dev *dev, const char c)
if (flush) { if (!ansi_cursor_hidden) - CURSOR_OFF; + console_cursor(0); ansi_buf_size = 0; switch (cchar) { case 'A': @@ -1025,7 +1003,7 @@ static void video_putc(struct stdio_dev *dev, const char c) break; } if (!ansi_cursor_hidden) - CURSOR_SET; + video_set_cursor(); } } else { parse_putc(c);
This converts the following to Kconfig: CONFIG_CONSOLE_EXTRA_INFO
Changes in v2: None
configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/charon_defconfig | 1 + configs/icon_defconfig | 1 + configs/ipek01_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/socrates_defconfig | 1 + drivers/video/Kconfig | 10 ++++++++++ include/configs/MIP405.h | 1 - include/configs/PIP405.h | 1 - include/configs/TQM5200.h | 1 - include/configs/icon.h | 1 - include/configs/ipek01.h | 1 - include/configs/lwmon5.h | 1 - include/configs/socrates.h | 1 - scripts/config_whitelist.txt | 1 - 22 files changed, 23 insertions(+), 8 deletions(-)
diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index f0547bb..bff1dd0 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index ea66335..22ee85d 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -18,4 +18,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index 1613855..d42d8a8 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 8b4a7a8..f950ff0 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -18,4 +18,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 52d8772..c52bc53 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index 1f70551..834fd11 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 12577e2..53ea06d 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 978a07c..497db0a 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 81d2384..004c4d2 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -20,4 +20,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 6218dd4..a61753b 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index bf8d34d..e93eaa2 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 8d101fc..317c8b6 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -22,4 +22,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 4ade2ff..034ee6a 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -21,4 +21,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_OF_LIBFDT=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index c70f6a1..5663a12 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -481,6 +481,16 @@ config VGA_AS_SINGLE_DEVICE may be used if you have no keyboard device, or more than one (USB Keyboard, AT Keyboard).
+config CONSOLE_EXTRA_INFO + bool "Display additional board information" + depends on CFB_CONSOLE + help + Display additional board information strings that normally go to + the serial port. When this option is enabled, a board-specific + function video_get_info_str() is called to get the string for + each line of the display. The function should return the string, + which can be empty if there is nothing to display for that line. + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 257fa47..43468ef 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -343,7 +343,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #undef CONFIG_VIDEO_ONBOARD /************************************************************ * USB support EXPERIMENTAL diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 70e75c1..685922c 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -303,7 +303,6 @@ * Video support ************************************************************/ #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VIDEO_ONBOARD /* Video controller is on-board */
/************************************************************ diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 06d2be5..5439ed6 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -103,7 +103,6 @@ #define CONFIG_VIDEO_LOGO
#ifndef CONFIG_FO300 -#define CONFIG_CONSOLE_EXTRA_INFO #else #define CONFIG_VIDEO_BMP_LOGO #endif diff --git a/include/configs/icon.h b/include/configs/icon.h index 3a72a66..c60df49 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -133,7 +133,6 @@ #define CONFIG_VIDEO_SM501_PCI #define VIDEO_FB_LITTLE_ENDIAN #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CFG_CONSOLE_IS_IN_ENV diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index 5298376..d53080b 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -50,7 +50,6 @@ #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define CONFIG_SPLASH_SCREEN #define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) /* decompressed img */ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 2e89b1a..2fed3e0 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -356,7 +356,6 @@ #define CONFIG_VIDEO_MB862xx #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_VIDEO_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 16e4b02..0ae2b78 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -173,7 +173,6 @@ #define CONFIG_VIDEO_MB862xx_ACCEL #define CONFIG_VIDEO_LOGO #define CONFIG_VIDEO_BMP_LOGO -#define CONFIG_CONSOLE_EXTRA_INFO #define VIDEO_FB_16BPP_PIXEL_SWAP #define VIDEO_FB_16BPP_WORD_SWAP #define CONFIG_SPLASH_SCREEN diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e246eb3..53976e5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -673,7 +673,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_EXTRA_INFO CONFIG_CONSOLE_INFO_QUIET CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL
This should be defined in a header file so that arguments are checked. Move it to video.h.
Changes in v2: None
board/liebherr/lwmon5/lwmon5.c | 1 + board/mosaixtech/icon/icon.c | 1 + board/mpl/common/common_util.c | 1 + board/tqc/tqm5200/tqm5200.c | 1 + drivers/video/cfb_console.c | 25 ++++++++----------------- include/video.h | 11 +++++++++++ 6 files changed, 23 insertions(+), 17 deletions(-)
diff --git a/board/liebherr/lwmon5/lwmon5.c b/board/liebherr/lwmon5/lwmon5.c index 8ad6712..bb99a3b 100644 --- a/board/liebherr/lwmon5/lwmon5.c +++ b/board/liebherr/lwmon5/lwmon5.c @@ -13,6 +13,7 @@ #include <asm/io.h> #include <post.h> #include <flash.h> +#include <video.h> #include <mtd/cfi_flash.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/mosaixtech/icon/icon.c b/board/mosaixtech/icon/icon.c index 1795464..7558234 100644 --- a/board/mosaixtech/icon/icon.c +++ b/board/mosaixtech/icon/icon.c @@ -11,6 +11,7 @@ #include <libfdt.h> #include <fdt_support.h> #include <netdev.h> +#include <video.h> #include <asm/processor.h> #include <asm/io.h> #include <asm/ppc4xx-gpio.h> diff --git a/board/mpl/common/common_util.c b/board/mpl/common/common_util.c index 3c110fa..a6edb6d 100644 --- a/board/mpl/common/common_util.c +++ b/board/mpl/common/common_util.c @@ -15,6 +15,7 @@ #include <pci.h> #include <malloc.h> #include <bzlib.h> +#include <video.h>
#ifdef CONFIG_PIP405 #include "../pip405/pip405.h" diff --git a/board/tqc/tqm5200/tqm5200.c b/board/tqc/tqm5200/tqm5200.c index 8b82c34..fef9d2b 100644 --- a/board/tqc/tqm5200/tqm5200.c +++ b/board/tqc/tqm5200/tqm5200.c @@ -18,6 +18,7 @@ #include <asm/processor.h> #include <libfdt.h> #include <netdev.h> +#include <video.h>
#ifdef CONFIG_VIDEO_SM501 #include <sm501.h> diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index c788651..b02a153 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -64,6 +64,7 @@ #include <fdtdec.h> #include <version.h> #include <malloc.h> +#include <video.h> #include <linux/compiler.h>
/* @@ -215,16 +216,6 @@ #endif #endif
-#ifdef CONFIG_CONSOLE_EXTRA_INFO -/* - * setup a board string: type, speed, etc. - * - * line_number: location to place info string beside logo - * info: buffer for info string - */ -extern void video_get_info_str(int line_number, char *info); -#endif - DECLARE_GLOBAL_DATA_PTR;
/* Locals */ @@ -801,7 +792,7 @@ static void parse_putc(const char c) video_set_cursor(); }
-static void video_putc(struct stdio_dev *dev, const char c) +static void cfb_video_putc(struct stdio_dev *dev, const char c) { #ifdef CONFIG_CFB_CONSOLE_ANSI int i; @@ -1015,7 +1006,7 @@ static void video_putc(struct stdio_dev *dev, const char c) flush_cache(VIDEO_FB_ADRS, VIDEO_SIZE); }
-static void video_puts(struct stdio_dev *dev, const char *s) +static void cfb_video_puts(struct stdio_dev *dev, const char *s) { int flush = cfb_do_flush_cache; int count = strlen(s); @@ -1024,7 +1015,7 @@ static void video_puts(struct stdio_dev *dev, const char *s) cfb_do_flush_cache = 0;
while (count--) - video_putc(dev, *s++); + cfb_video_putc(dev, *s++);
if (flush) { cfb_do_flush_cache = flush; @@ -1991,7 +1982,7 @@ void video_clear(void) #endif }
-static int video_init(void) +static int cfg_video_init(void) { unsigned char color8;
@@ -2117,7 +2108,7 @@ int drv_video_init(void) return 0;
/* Init video chip - returns with framebuffer cleared */ - if (video_init() == -1) + if (cfg_video_init() == -1) return 0;
if (board_cfb_skip()) @@ -2142,8 +2133,8 @@ int drv_video_init(void) memset(&console_dev, 0, sizeof(console_dev)); strcpy(console_dev.name, "vga"); console_dev.flags = DEV_FLAGS_OUTPUT; - console_dev.putc = video_putc; /* 'putc' function */ - console_dev.puts = video_puts; /* 'puts' function */ + console_dev.putc = cfb_video_putc; /* 'putc' function */ + console_dev.puts = cfb_video_puts; /* 'puts' function */
#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) if (have_keyboard && keyboard_ok) { diff --git a/include/video.h b/include/video.h index 0d5bd21..5b4e78b 100644 --- a/include/video.h +++ b/include/video.h @@ -245,6 +245,17 @@ int lg4573_spi_startup(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode); #endif
+/* + * video_get_info_str() - obtain a board string: type, speed, etc. + * + * This is called if CONFIG_CONSOLE_EXTRA_INFO is enabled. + * + * line_number: location to place info string beside logo + * info: buffer for info string (empty if nothing to display on this + * line) + */ +void video_get_info_str(int line_number, char *info); + #endif /* CONFIG_DM_VIDEO */
#endif
This is not used in U-Boot. Drop it.
Changes in v2: None
include/configs/edminiv2.h | 1 - include/configs/km/km_arm.h | 1 - include/configs/mv-common.h | 1 - scripts/config_whitelist.txt | 1 - 4 files changed, 4 deletions(-)
diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 982d526..51e17c5 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -208,7 +208,6 @@ /* * Other required minimal configurations */ -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_DISPLAY_CPUINFO /* Display cpu info */ diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 25db704..e2fade0 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -146,7 +146,6 @@ /* * Other required minimal configurations */ -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_DISPLAY_CPUINFO /* Display cpu info */ diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index dd223be..1af8913 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -83,7 +83,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_CONSOLE_INFO_QUIET /* some code reduction */ #define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ #define CONFIG_ARCH_MISC_INIT /* call arch_misc_init() */ #define CONFIG_BOARD_EARLY_INIT_F /* call board_init_f for early inits */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 53976e5..43d58b9 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -673,7 +673,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_INFO_QUIET CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE
This converts the following to Kconfig: CONFIG_LCD
Changes in v2: None
configs/TQM823L_LCD_defconfig | 3 ++- configs/TTTech_defconfig | 3 ++- configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/picosam9g45_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/snow_defconfig | 1 + configs/spring_defconfig | 1 + configs/wtk_defconfig | 3 ++- configs/zipitz2_defconfig | 1 + drivers/video/Kconfig | 8 ++++++++ include/configs/M52277EVB.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/brppt1.h | 1 - include/configs/brxre1.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/exynos5-dt-common.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/peach-pi.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/rpi.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/smdk5250.h | 1 - include/configs/smdk5420.h | 1 - include/configs/zipitz2.h | 1 - scripts/config_whitelist.txt | 1 - 77 files changed, 61 insertions(+), 29 deletions(-)
diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index 38f5119..9bc8c73 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -2,7 +2,7 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="LCD,NEC_NL6448BC20" +CONFIG_SYS_EXTRA_OPTIONS="NEC_NL6448BC20" CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y @@ -10,4 +10,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index e545848..9649012 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -2,7 +2,7 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ104V7DS01" +CONFIG_SYS_EXTRA_OPTIONS="SHARP_LQ104V7DS01" CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y @@ -10,4 +10,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 99bb49e..dbe656a 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 014e50e..98a152e 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index e0e8fea..2d4a9af 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 38b9635..5ec3176 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 38b9635..5ec3176 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 317d9c2..3838f94 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index a26d7d1..556845a 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 8b72678..18b67c9 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -21,4 +21,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 0293aa6..eb26ec9 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 777d234..c6ccbb5 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 788e7e1..22fc450 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 9604af9..57ea3ca 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -29,4 +29,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index e1aebb1..092b7f9 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -27,4 +27,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index ce62edf..e46c03e 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -21,4 +21,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 3b7ebc2..ee98054 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -27,4 +27,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 26c93af..8db4cbc 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index 494a630..8c8f350 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index f0ea3f0..9140b21 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 0a414e4..08a4639 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -18,4 +18,5 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_FAT=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index ac51cc7..0da245e 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -22,4 +22,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index e6910a0..7233560 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -22,4 +22,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index c232324..5358994 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -28,4 +28,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index b8a772d..ab54b66 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -29,4 +29,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index e990f03..0a3ea12 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -45,4 +45,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 8872f4a..0fabecc 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -45,4 +45,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index c04dde8..09fd2df 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -53,4 +53,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 0251088..27cdb62 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -44,5 +44,6 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index b131b27..3bca796 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -23,4 +23,5 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 9a2f624..0fbc08b 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -24,4 +24,5 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 33b7f70..8a4ff67 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -68,5 +68,6 @@ CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index c2b6d97..0f6b6e3 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -68,5 +68,6 @@ CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index a3a4f5d..5413f09 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -30,4 +30,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 63637e7..b1510cb 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -17,3 +17,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 7ffde4b..be58975 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -17,3 +17,4 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index c95385c..a97c910 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -22,5 +22,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 9b1dbfd..bbb1487 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -24,5 +24,6 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 0596281..bdb37e0 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -23,5 +23,6 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index d511a33..5510833 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -22,5 +22,6 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 8cee4c2..3e72e6a 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -31,4 +31,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 8dc5e24..cec7bb2 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -29,4 +29,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 019869c..eb60bfe 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -30,4 +30,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index f9c766a..63e9f27 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -32,4 +32,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index c8456d0..5a6def9 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -30,4 +30,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index a061c4d..9f87f15 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -31,4 +31,5 @@ CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 949b38c..83e3feb 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -76,5 +76,6 @@ CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_VIDEO_BRIDGE_NXP_PTN3460=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 87e7dcd..da4fe42 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -75,5 +75,6 @@ CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y +CONFIG_LCD=y CONFIG_TPM=y CONFIG_ERRNO_STR=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index 336d8e4..3e4f386 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -2,7 +2,7 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ065T9DR51U" +CONFIG_SYS_EXTRA_OPTIONS="SHARP_LQ065T9DR51U" CONFIG_BOOTDELAY=5 CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y @@ -10,4 +10,5 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_DHCP=y CONFIG_CMD_SNTP=y CONFIG_CMD_EXT2=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index a776055..08cd3a0 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -14,5 +14,6 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_LCD=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 5663a12..cc4be0f 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -540,4 +540,12 @@ config SYS_CONSOLE_FG_COL the background and foreground to the same colour or you will see nothing.
+config LCD + bool "Enable legacy LCD support" + help + Define this to enable LCD support (for output to LCD display). + You will also need to select an LCD driver using an additional + CONFIG option. See the README for details. Drives which have been + converted to driver model will instead used CONFIG_DM_VIDEO. + endmenu diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 898ed7d..6230948 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -84,7 +84,6 @@
/* LCD */ #ifdef CONFIG_CMD_BMP -#define CONFIG_LCD #define CONFIG_SPLASH_SCREEN #define CONFIG_LCD_LOGO #define CONFIG_SHARP_LQ035Q7DH06 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 591c7d4..e940ac0 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -49,7 +49,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index ecc87ea..f8ecc14 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -59,7 +59,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index e89c19b..2417950 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -41,7 +41,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index a54e59e..b8f149e 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -40,7 +40,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_LCD_LOGO diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 1bbfb9e..2211d8a 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -46,7 +46,6 @@ #define CONFIG_BAUDRATE 115200
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 34f452e..fd1f2b9 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -36,7 +36,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_LCD_LOGO diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index e01d535..1a76e2f 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -16,7 +16,6 @@ #include <configs/bur_am335x_common.h> /* ------------------------------------------------------------------------- */ #define CONFIG_AM335X_LCD -#define CONFIG_LCD #define CONFIG_LCD_ROTATION #define CONFIG_LCD_DT_SIMPLEFB #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 1e8426f..b9f69be 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -16,7 +16,6 @@ #include <configs/bur_am335x_common.h> /* ------------------------------------------------------------------------- */ #define CONFIG_AM335X_LCD -#define CONFIG_LCD #define CONFIG_LCD_NOSTDOUT #define CONFIG_SYS_WHITE_ON_BLACK #define LCD_BPP LCD_COLOR32 diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 0cd2f3c..7225c8a 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -286,7 +286,6 @@ #define CONFIG_VIDEO_OMAP3 #define LCD_BPP LCD_COLOR16
-#define CONFIG_LCD #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SOURCE #define CONFIG_CMD_BMP diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 893d637..07d30bd 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -287,7 +287,6 @@ #define CONFIG_VIDEO_OMAP3 #define LCD_BPP LCD_COLOR16
-#define CONFIG_LCD #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASHIMAGE_GUARD #define CONFIG_CMD_BMP diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 3d81f94..7cb3a29 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -27,7 +27,6 @@ #define CONFIG_BOARD_COMMON
/* Display */ -#define CONFIG_LCD #ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB #define CONFIG_EXYNOS_DP diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 8fe5db6..91037d6 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -21,7 +21,6 @@ */ #define CONFIG_DOS_PARTITION #define CONFIG_FAT_WRITE -/*#define CONFIG_LCD*/
/* * Memory configurations diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h index b01fe4c..296d77a 100644 --- a/include/configs/peach-pi.h +++ b/include/configs/peach-pi.h @@ -30,7 +30,6 @@ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
/* Display */ -#define CONFIG_LCD #ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB #define CONFIG_EXYNOS_DP diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 8ebf336..c44afa6 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -44,7 +44,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO #undef LCD_TEST_PATTERN diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index fbb7146..f61f567 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -151,7 +151,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index a4672b0..93f30d7 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -164,7 +164,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ -#define CONFIG_LCD 1 #define LCD_BPP LCD_COLOR8 #define CONFIG_LCD_LOGO 1 #undef LCD_TEST_PATTERN diff --git a/include/configs/rpi.h b/include/configs/rpi.h index decf35a..4ad98e1 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -71,7 +71,6 @@ /* GPIO */ #define CONFIG_BCM2835_GPIO /* LCD */ -#define CONFIG_LCD #define CONFIG_LCD_DT_SIMPLEFB #define LCD_BPP LCD_COLOR16 /* diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index c20d6f9..30fb9a4 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -86,7 +86,6 @@ #define CONFIG_MACB_SEARCH_PHY
/* LCD */ -/* #define CONFIG_LCD */
#ifdef CONFIG_LCD #define LCD_BPP LCD_COLOR16 diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index c149e5b..1b053a6 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -39,7 +39,6 @@ #define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 #define CONFIG_LCD_LOGO diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index 0890cf5..249e661 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -94,7 +94,6 @@ #define CONFIG_MACB_SEARCH_PHY
/* LCD */ -/* #define CONFIG_LCD */ #ifdef CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 24 diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 36da48c..00ed400 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -94,7 +94,6 @@ #define CONFIG_MACB_SEARCH_PHY
/* LCD */ -#define CONFIG_LCD #define LCD_BPP LCD_COLOR16 #define LCD_OUTPUT_BPP 18 #define CONFIG_LCD_LOGO diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 5c60887..c152459 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -13,7 +13,6 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
-#undef CONFIG_LCD #undef CONFIG_EXYNOS_FB #undef CONFIG_EXYNOS_DP #undef CONFIG_KEYBOARD diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index d8d095f..502772c 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -13,7 +13,6 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 6e83cc9..ed2c9ac 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -75,7 +75,6 @@ */ #ifdef CONFIG_CMD_SPI #define CONFIG_SOFT_SPI -#define CONFIG_LCD #define CONFIG_LCD_ROTATION #define CONFIG_PXA_LCD #define CONFIG_LMS283GF05 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 43d58b9..e2c7e20 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1886,7 +1886,6 @@ CONFIG_LAYERSCAPE_NS_ACCESS CONFIG_LBA48 CONFIG_LBD CONFIG_LBDAF -CONFIG_LCD CONFIG_LCD_ALIGNMENT CONFIG_LCD_BMP_RLE8 CONFIG_LCD_DT_SIMPLEFB
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
README | 6 ------ configs/bayleybay_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/harmony_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/paz00_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rock2_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/ventana_defconfig | 1 + drivers/video/Kconfig | 10 ++++++++++ include/configs/chromebook_jerry.h | 1 - include/configs/colibri_pxa270.h | 1 - include/configs/colibri_t20.h | 1 - include/configs/evb_rk3288.h | 1 - include/configs/evb_rk3399.h | 1 - include/configs/fennec_rk3288.h | 1 - include/configs/firefly-rk3288.h | 1 - include/configs/harmony.h | 1 - include/configs/miniarm_rk3288.h | 1 - include/configs/paz00.h | 1 - include/configs/popmetal_rk3288.h | 1 - include/configs/rock2.h | 1 - include/configs/rpi.h | 1 - include/configs/seaboard.h | 1 - include/configs/ventana.h | 1 - include/configs/x86-common.h | 1 - include/lcd_console.h | 3 --- scripts/config_whitelist.txt | 1 - 43 files changed, 33 insertions(+), 26 deletions(-)
diff --git a/README b/README index cf83fc3..8b9c04e 100644 --- a/README +++ b/README @@ -1743,12 +1743,6 @@ CBFS (Coreboot Filesystem) support here, since it is cheaper to change data cache settings on a per-section basis.
- CONFIG_CONSOLE_SCROLL_LINES - - When the console need to be scrolled, this is the number of - lines to scroll by. It defaults to 1. Increasing this makes - the console jump but can help speed up operation when scrolling - is slow.
CONFIG_LCD_ROTATION
diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 0a78639..542e516 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -59,4 +59,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index f0c151d..0b64261 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -79,6 +79,7 @@ CONFIG_SYSRESET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y +CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index d850b4e..73afd13 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -63,5 +63,6 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index e1b92ea..6152393 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -61,5 +61,6 @@ CONFIG_DM_VIDEO=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_VIDEO_BROADWELL_IGD=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 74bf6f0..47cb553 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -55,5 +55,6 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 2c1189d..fc66791 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -49,3 +49,4 @@ CONFIG_G_DNL_VENDOR_NUM=0x0955 CONFIG_G_DNL_PRODUCT_NUM=0x701a CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 779de99..560cf6c 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -67,4 +67,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 7e720a4..4c2b20c 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -66,4 +66,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 7d06350..dc67744 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -43,5 +43,6 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_TPM=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 7b53184..9ec8b1d 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -52,4 +52,5 @@ CONFIG_USB_STORAGE=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 28b9edc..505f7d6 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -64,4 +64,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 471273a..d779707 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -68,6 +68,7 @@ CONFIG_SYSRESET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y +CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index cd70004..fe1058c 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -40,3 +40,4 @@ CONFIG_USB_ULPI=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index e720094..9c5df0b 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -63,4 +63,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 5cf6cfd..296b2b3 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -38,3 +38,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 4d4b85d..5277af3 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -50,4 +50,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index e55b285..4a5e01f 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -47,6 +47,7 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index 1c3138c..ae8a9f1 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -47,6 +47,7 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_EFI=y CONFIG_EFI_STUB=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 02f891d..4e29bc2 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -64,6 +64,7 @@ CONFIG_SYSRESET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y +CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 3b73b30..4b4601a 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -39,3 +39,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index d52c94c..6c9d231 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -61,4 +61,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 7bb823b..687b296 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -61,4 +61,5 @@ CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y CONFIG_CFB_CONSOLE=y +CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 09f5fa5..e453cf6 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -38,3 +38,4 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y +CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index cc4be0f..e8d0c27 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -491,6 +491,16 @@ config CONSOLE_EXTRA_INFO each line of the display. The function should return the string, which can be empty if there is nothing to display for that line.
+config CONSOLE_SCROLL_LINES + int "Number of lines to scroll the console by" + depends on CFB_CONSOLE || DM_VIDEO || LCD + default 1 + help + When the console need to be scrolled, this is the number of + lines to scroll by. It defaults to 1. Increasing this makes the + console jump but can help speed up operation when scrolling + is slow. + config VIDEO_CT69000 bool "Enable Chips & Technologies 69000 video driver" depends on VIDEO diff --git a/include/configs/chromebook_jerry.h b/include/configs/chromebook_jerry.h index 180527a..b15cc26 100644 --- a/include/configs/chromebook_jerry.h +++ b/include/configs/chromebook_jerry.h @@ -23,6 +23,5 @@ #define CONFIG_KEYBOARD
#define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10
#endif diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index ba8d93c..429f571 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -67,7 +67,6 @@ #define CONFIG_PXA_LCD #define CONFIG_PXA_VGA #define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10 #define CONFIG_CMD_BMP #define CONFIG_LCD_LOGO #endif diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index d9954c1..f65b109 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -47,7 +47,6 @@
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10 #define CONFIG_CMD_BMP #define CONFIG_LCD_LOGO
diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/evb_rk3399.h b/include/configs/evb_rk3399.h index 047850a..f453640 100644 --- a/include/configs/evb_rk3399.h +++ b/include/configs/evb_rk3399.h @@ -21,6 +21,5 @@ #define SDRAM_BANK_SIZE (2UL << 30)
#endif diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly-rk3288.h index ee924c3..14fdead 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -23,6 +23,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/harmony.h b/include/configs/harmony.h index 2ecae65..3d6b5fc 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -54,7 +54,6 @@
#include "tegra-common-post.h"
diff --git a/include/configs/miniarm_rk3288.h b/include/configs/miniarm_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/miniarm_rk3288.h +++ b/include/configs/miniarm_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/paz00.h b/include/configs/paz00.h index 5e59ccb..a8bb3ff 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -45,7 +45,6 @@
diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_rk3288.h index 390c243..77b647e 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -19,6 +19,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/rock2.h b/include/configs/rock2.h index ee924c3..14fdead 100644 --- a/include/configs/rock2.h +++ b/include/configs/rock2.h @@ -23,6 +23,5 @@ #define CONFIG_ENV_OFFSET (96 * 1024)
#endif diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 4ad98e1..7fe469c 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -81,7 +81,6 @@ #define CONFIG_FB_ADDR 0 #define CONFIG_VIDEO_BCM2835 #define CONFIG_SYS_WHITE_ON_BLACK -#define CONFIG_CONSOLE_SCROLL_LINES 10
/* SD/MMC configuration */ #define CONFIG_GENERIC_MMC diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 3076ef4..fe68437 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -61,7 +61,6 @@
/* NAND support */ #define CONFIG_CMD_NAND diff --git a/include/configs/ventana.h b/include/configs/ventana.h index b282467..d3843d4 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -46,7 +46,6 @@
diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 352de68..ebb257b 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -130,7 +130,6 @@ * Video Configuration */ #define VIDEO_FB_16BPP_WORD_SWAP -#define CONFIG_CONSOLE_SCROLL_LINES 5
/*----------------------------------------------------------------------- * CPU Features diff --git a/include/lcd_console.h b/include/lcd_console.h index 2e0f56f..eac227f 100644 --- a/include/lcd_console.h +++ b/include/lcd_console.h @@ -5,9 +5,6 @@ */
/* By default we scroll by a single line */ -#ifndef CONFIG_CONSOLE_SCROLL_LINES -#define CONFIG_CONSOLE_SCROLL_LINES 1 -#endif
struct console_t { short curr_col, curr_row; diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index e2c7e20..9d8b389 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -673,7 +673,6 @@ CONFIG_COMMON_ENV_SETTINGS CONFIG_COMMON_ENV_UBI CONFIG_COMPACT_FLASH CONFIG_COMPAT -CONFIG_CONSOLE_SCROLL_LINES CONFIG_CONS_EXTC_PINSEL CONFIG_CONS_EXTC_RATE CONFIG_CONS_NONE
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_ENV_OVERWRITE
Changes in v2: None
README | 3 --- common/Kconfig | 9 +++++++++ configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + include/configs/MIP405.h | 1 - include/configs/MigoR.h | 1 - include/configs/PIP405.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/ecovec.h | 1 - include/configs/kzm9g.h | 1 - include/configs/ms7722se.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/socfpga_common.h | 1 - scripts/config_whitelist.txt | 1 - 29 files changed, 18 insertions(+), 21 deletions(-)
diff --git a/README b/README index 8b9c04e..f2e0809 100644 --- a/README +++ b/README @@ -3588,9 +3588,6 @@ Configuration Settings: - CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Enable the call to overwrite_console().
-- CONFIG_SYS_CONSOLE_ENV_OVERWRITE - Enable overwrite of previous console environment settings. - - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END: Begin and End addresses of the area used by the simple memory test. diff --git a/common/Kconfig b/common/Kconfig index 8e600f7..e02e797 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -308,6 +308,15 @@ config SYS_CONSOLE_IS_IN_ENV environment variables can be updated after boot to change the input/output devices.
+config SYS_CONSOLE_ENV_OVERWRITE + bool "Update environment variables during console init" + help + The console environment variables (stdout, stdin, stderr) can be + used to determine the correct console devices on start-up. This + option writes the console devices to these variables on console + start-up (after relocation). This causes the environment to be + updated to match the console devices actually chosen. + endmenu
config SYS_NO_FLASH diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 45dc5eb..44cc0a9 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 76e2256..333ffdf 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 43930ac..4a6fd3a 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index dacdfeb..505b0c7 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_STACK_R=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 73e13a9..459323b 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 65d4554..5f541a1 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 1694438..cb61762 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 8274e0b..17882da 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 5e9cbb6..eaff3ab 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_FIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 43468ef..8ad34b1 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -114,7 +114,6 @@ * defines if the overwrite_console should be stored in the * environment **************************************************************/ -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/************************************************************** * loads config diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index a4eabe5..588ddd4 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -43,7 +43,6 @@ #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (MIGO_R_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 685922c..b77aacb 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -110,7 +110,6 @@ * defines if the overwrite_console should be stored in the * environment **************************************************************/ -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/************************************************************** * loads config diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 32acb08..795a7d2 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -57,7 +57,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (AP325RXA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index d41b624..fc08d7b 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -73,7 +73,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index e3f4a7b..175a124 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -62,7 +62,6 @@ #define CONFIG_SCIF_A #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (ARMADILLO_800EVA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index c8508ff..8ab26e6 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -93,7 +93,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 409c30d..921474f 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -58,7 +58,6 @@ #define CONFIG_CONS_SCIF4 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END \ diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 9b0c166..d0b6e58 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -42,7 +42,6 @@ #define CONFIG_CONS_SCIF0 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (MS7722SE_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 2d7e326..408ae21 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -78,7 +78,6 @@ /* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 5733da6..ccd5026 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -44,7 +44,6 @@ /* console */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index 7655417..a435708 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -52,7 +52,6 @@ /* console */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index cfcde81..fd32ddc 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -46,7 +46,6 @@ #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index fefdbb4..57c8e76 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -46,7 +46,6 @@ #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 262d390..cb09a7c 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -46,7 +46,6 @@ #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 80e61a4..6eee51e 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -62,7 +62,6 @@ #define CONFIG_SCIF_EXT_CLOCK 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
#define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index ba2004e..cb285a6 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -257,7 +257,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * U-Boot environment */ #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE #if !defined(CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE 4096 #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 9d8b389..2f8c960 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4616,7 +4616,6 @@ CONFIG_SYS_CMXFCR_VALUE1 CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE -CONFIG_SYS_CONSOLE_ENV_OVERWRITE CONFIG_SYS_CONSOLE_INFO_QUIET CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
Changes in v2: None
README | 3 --- common/Kconfig | 9 +++++++++ configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/ea20_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/wandboard_defconfig | 1 + include/configs/MIP405.h | 1 - include/configs/MigoR.h | 1 - include/configs/PIP405.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/aristainetos-common.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/ea20.h | 1 - include/configs/ecovec.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_bx50v3.h | 2 -- include/configs/kzm9g.h | 1 - include/configs/ms7722se.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/wandboard.h | 1 - scripts/config_whitelist.txt | 1 - 76 files changed, 53 insertions(+), 34 deletions(-)
diff --git a/README b/README index f2e0809..752c8cb 100644 --- a/README +++ b/README @@ -3585,9 +3585,6 @@ Configuration Settings: - CONFIG_SYS_CONSOLE_INFO_QUIET Suppress display of console information at boot.
-- CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE - Enable the call to overwrite_console(). - - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END: Begin and End addresses of the area used by the simple memory test. diff --git a/common/Kconfig b/common/Kconfig index e02e797..b64e797 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -308,6 +308,15 @@ config SYS_CONSOLE_IS_IN_ENV environment variables can be updated after boot to change the input/output devices.
+config SYS_CONSOLE_OVERWRITE_ROUTINE + bool "Allow board control over console overwriting" + help + If this is enabled, and the board-specific function + overwrite_console() returns 1, the stdin, stderr and stdout are + switched to the serial port, else the settings in the environment + are used. If this is not enabled, the console will not be switched + to serial. + config SYS_CONSOLE_ENV_OVERWRITE bool "Update environment variables during console init" help diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index bff1dd0..aa402bf 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -5,6 +5,7 @@ CONFIG_4xx=y CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 22ee85d..5caf3a2 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -5,6 +5,7 @@ CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index f950ff0..81f2820 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -5,6 +5,7 @@ CONFIG_4xx=y CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 884d364..f3a09d2 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index dfeb20c..8e06d0d 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index b973ebb..062fcbd 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 0a3ea12..6a349ea 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 0fabecc..eec3848 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -13,6 +13,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 09fd2df..07f7d35 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 27cdb62..4851003 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index b7c387b..410e8d3 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index e81e15c..f5fcd31 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_DDR_1G=y CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index 17f3c2a..d0762b3 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_ADVANTECH_DMS_BA16=y CONFIG_VIDEO=y CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 55c1ddc..5bc6f04 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EA20=y CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 29010f3..117f68d 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GE_B450V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index e0eeb46..73b559b 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GE_B650V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 9b4b917..80d5315 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_GE_B850V3=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index d5bd37c..ee1d9cd 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 36a8c12..34cfd78 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -4,6 +4,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 2297619..8737e43 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -4,6 +4,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_BOOTDELAY=1 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index e345935..28762f9 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 2b13238..e3dc9ad 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 8efe8d0..4a17e97 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index eb26814..eb747af 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 3ba2ef7..a1535b1 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 4e783cb..4cc4edd 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 415627f..3444a2e 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 23d173c..193d905 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index de711c6..757abad 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index c9909d2..b8d4577 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index b331043..0a23849 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 30774c4..db25004 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index fd9096e..a7aeba3 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 10cf974..bf01a7b 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 44cc0a9..a6bb6ee 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 333ffdf..e55a2b4 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 4a6fd3a..fb1785a 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 505b0c7..9276c7a 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_is1" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 459323b..4a690ab 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 5f541a1..5c2997a 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index cb61762..107266e 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 17882da..89b7ab0 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index eaff3ab..9ffca0c 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_vining_fpga" CONFIG_FIT=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 1375ca2..fd680f2 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_VIDEO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 8ad34b1..1a4d602 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -108,7 +108,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index 588ddd4..b31d51b 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -42,7 +42,6 @@ #define CONFIG_CONS_SCIF0 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (MIGO_R_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index b77aacb..5f7706df 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -104,7 +104,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index 2cbbac2..bbf97c7 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -276,7 +276,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 795a7d2..153d162 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -56,7 +56,6 @@
/* Suppress display of console information at boot */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (AP325RXA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index fc08d7b..e922cdf 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -72,7 +72,6 @@
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index d786778..9c01f9d 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -235,7 +235,6 @@ /* Framebuffer */ #define CONFIG_VIDEO_IPUV3 /* check this console not needed, after test remove it */ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 175a124..e6761c3 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -61,7 +61,6 @@ #define SCIF4_BASE 0xe6c80000 #define CONFIG_SCIF_A #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (ARMADILLO_800EVA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 277f36e..16237e6 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -41,7 +41,6 @@
#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
/* As stated above, the following choices are optional. */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 9f6b950..722f1c5 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -94,7 +94,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 58493e9..c88eaa9 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -108,7 +108,6 @@ #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #endif
/* diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 8ab26e6..dd925a9 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -92,7 +92,6 @@
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 9e0c945..2106e86 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -118,7 +118,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index c1053f8..a3c2bd4 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -302,8 +302,6 @@
#define CONFIG_SYS_FSL_USDHC_NUM 3
-#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE - /* Framebuffer */ #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_IPUV3 diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 921474f..0aff6e8 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -57,7 +57,6 @@ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF4 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END \ diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index d0b6e58..17485b5 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -41,7 +41,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF0 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */ -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (MS7722SE_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 968662d..fda8bfe 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -97,7 +97,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 258a856..5628943 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -216,7 +216,6 @@ /* Framebuffer and LCD */ #define CONFIG_PREBOOT #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_BMP_16BPP diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 71a4231..0310c57 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -209,7 +209,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 63ef4e7..b32e49e 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -93,7 +93,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 408ae21..d7ecdb8 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -77,7 +77,6 @@
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index ccd5026..e02e2d1 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -43,7 +43,6 @@
/* console */ #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index a435708..a397e64 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -51,7 +51,6 @@
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index fd32ddc..bdb8101 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -45,7 +45,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 57c8e76..eaa862c 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -45,7 +45,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index cb09a7c..8e4ff1c 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -45,7 +45,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 6eee51e..86057c1 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -61,7 +61,6 @@ #define CONFIG_CONS_SCIF1 1 #define CONFIG_SCIF_EXT_CLOCK 1 #undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
#define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index cb285a6..72b153e 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -256,7 +256,6 @@ unsigned int cm_get_qspi_controller_clk_hz(void); /* * U-Boot environment */ -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #if !defined(CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE 4096 #endif diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 4d219e2..84e08e8 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -75,7 +75,6 @@
/* Framebuffer */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN #define CONFIG_SPLASH_SCREEN_ALIGN diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2f8c960..5a2c6e3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4617,7 +4617,6 @@ CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE CONFIG_SYS_CONSOLE_INFO_QUIET -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE CONFIG_SYS_CORTEX_R4
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_INFO_QUIET
Changes in v2: - Make CONFIG_SYS_CONSOLE_INFO_QUIET the default if !CONFIG_MUX
README | 3 --- common/Kconfig | 9 +++++++++ configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/brppt1_mmc_defconfig | 1 + configs/brppt1_nand_defconfig | 1 + configs/brppt1_spi_defconfig | 1 + configs/brxre1_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/ea20_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/icon_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rpi_2_defconfig | 1 - configs/rpi_3_32b_defconfig | 1 - configs/rpi_3_defconfig | 1 - configs/rpi_defconfig | 1 - configs/rut_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + include/configs/10m50_devboard.h | 1 - include/configs/3c120_devboard.h | 1 - include/configs/CPCI2DP.h | 2 -- include/configs/CPCI4052.h | 2 -- include/configs/M5249EVB.h | 1 - include/configs/MIP405.h | 1 - include/configs/MigoR.h | 2 -- include/configs/PIP405.h | 1 - include/configs/PLU405.h | 2 -- include/configs/PMC405DE.h | 1 - include/configs/VOM405.h | 2 -- include/configs/a3m071.h | 2 -- include/configs/amcc-common.h | 1 - include/configs/amcore.h | 1 - include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 1 - include/configs/armadillo-800eva.h | 1 - include/configs/bur_cfg_common.h | 1 - include/configs/clearfog.h | 1 - include/configs/db-88f6720.h | 1 - include/configs/db-88f6820-amc.h | 1 - include/configs/db-88f6820-gp.h | 1 - include/configs/db-mv784mp-gp.h | 1 - include/configs/ea20.h | 1 - include/configs/ecovec.h | 1 - include/configs/hrcon.h | 2 -- include/configs/kzm9g.h | 1 - include/configs/lsxl.h | 1 - include/configs/lwmon5.h | 2 -- include/configs/maxbcm.h | 1 - include/configs/ms7722se.h | 1 - include/configs/odroid.h | 1 - include/configs/openrisc-generic.h | 1 - include/configs/origen.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rcar-gen2-common.h | 1 - include/configs/rcar-gen3-common.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/siemens-am33x-common.h | 1 - include/configs/socfpga_sr1500.h | 1 - include/configs/spear-common.h | 1 - include/configs/strider.h | 2 -- include/configs/theadorable.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/vct.h | 1 - include/configs/x600.h | 1 - include/configs/x86-common.h | 2 -- include/configs/xilinx-ppc.h | 1 - include/configs/xpress.h | 1 - scripts/config_whitelist.txt | 1 - 96 files changed, 41 insertions(+), 75 deletions(-)
diff --git a/README b/README index 752c8cb..a032e56 100644 --- a/README +++ b/README @@ -3582,9 +3582,6 @@ Configuration Settings: - CONFIG_SYS_BAUDRATE_TABLE: List of legal baudrate settings for this board.
-- CONFIG_SYS_CONSOLE_INFO_QUIET - Suppress display of console information at boot. - - CONFIG_SYS_MEMTEST_START, CONFIG_SYS_MEMTEST_END: Begin and End addresses of the area used by the simple memory test. diff --git a/common/Kconfig b/common/Kconfig index b64e797..4d27f09 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -326,6 +326,15 @@ config SYS_CONSOLE_ENV_OVERWRITE start-up (after relocation). This causes the environment to be updated to match the console devices actually chosen.
+config SYS_CONSOLE_INFO_QUIET + bool "Don't display the console devices on boot" + default y if !CONSOLE_MUX + help + Normally U-Boot displays the current settings for stdout, stdin + and stderr on boot when the post-relocation console is set up. + Enable this option to supress this output. It can be obtained by + calling stdio_print_current_devices() from board code. + endmenu
config SYS_NO_FLASH diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index aa402bf..017e2e3 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MIP405T=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 5caf3a2..f73b4d4 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MIP405=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 81f2820..ed6764a 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_PIP405=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 542e516..e720245 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 6a349ea..021fa62 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index eec3848..18fdcad 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index 07f7d35..6a63db5 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -17,6 +17,7 @@ CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 4851003..afdb132 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -12,6 +12,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_BOOTDELAY=-2 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 73afd13..b09b70a 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 6152393..015d357 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -11,6 +11,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 47cb553..1ec10e9 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 560cf6c..9bb26c3 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 4c2b20c..bd5e3a0 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index dc67744..4a8985d 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 2841eb6..18113f4 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -4,6 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="cougarcanyon2" CONFIG_TARGET_COUGARCANYON2=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 9ec8b1d..7d4910b 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -10,6 +10,7 @@ CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 505f7d6..e079c3c 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 5bc6f04..3e9e731 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -5,6 +5,7 @@ CONFIG_VIDEO=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 7c1ca1f..f2aa4cb 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_EFI=y CONFIG_FIT=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index ecbf11b..db19e47 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -11,6 +11,7 @@ CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/icon_defconfig b/configs/icon_defconfig index a61753b..3a2a04c 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -4,6 +4,7 @@ CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 317c8b6..0d9c814 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=5 CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_HUSH_PARSER=y CONFIG_CMD_ASKENV=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 9c5df0b..802e5b2 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index bfac212..8aa512b 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pxm50" CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 5277af3..6d52ca6 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -10,6 +10,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index 4a5e01f..f0d3169 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index ae8a9f1..ad18ecd 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index a97c910..f01dc30 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_2=y CONFIG_OF_BOARD_SETUP=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index bbb1487..fa57de5 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_3_32B=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OF_BOARD_SETUP=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index bdb37e0..16f4178 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_3=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_OF_BOARD_SETUP=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 5510833..2436e93 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI=y CONFIG_OF_BOARD_SETUP=y -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/rut_defconfig b/configs/rut_defconfig index eda5d7b..86c2859 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="am335x-rut" CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 6c9d231..5f8081f 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 687b296..f965cb5 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -16,6 +16,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 51deddc..a400d6d 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index 9c7a79f..61ba811 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_BOOTDELAY=3 +CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y diff --git a/include/configs/10m50_devboard.h b/include/configs/10m50_devboard.h index ebe018a..c79e89a 100644 --- a/include/configs/10m50_devboard.h +++ b/include/configs/10m50_devboard.h @@ -19,7 +19,6 @@ * SERIAL */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */ #define CONFIG_SYS_NS16550_MEM32
/* diff --git a/include/configs/3c120_devboard.h b/include/configs/3c120_devboard.h index b2126a6..8835522 100644 --- a/include/configs/3c120_devboard.h +++ b/include/configs/3c120_devboard.h @@ -19,7 +19,6 @@ * SERIAL */ #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */
/* * CFI Flash diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 603de33..ea65bd4 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -75,8 +75,6 @@
#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */
#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 06c5d3b..9ac2531 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -96,8 +96,6 @@
#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 735c4da..d61c68f 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */
#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 1a4d602..db92967 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -108,7 +108,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the * environment diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index b31d51b..bb12785 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -40,8 +40,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF0 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console - information at boot */
#define CONFIG_SYS_MEMTEST_START (MIGO_R_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 5f7706df..1db7b5d 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -104,7 +104,6 @@ /*************************************************************** * defines if an overwrite_console function exists *************************************************************/ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /*************************************************************** * defines if the overwrite_console should be stored in the * environment diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 391a697..ed05e21 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -93,8 +93,6 @@
#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index 0b0db20..b076851 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -74,7 +74,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */
#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console info */
#define CONFIG_SYS_MEMTEST_START 0x0100000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x3000000 /* 1 ... 48 MB in DRAM */ diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index 5e30511..5dbc1e8 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -83,8 +83,6 @@
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - #define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */
diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index f3e4f77..0e0fc27 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -248,8 +248,6 @@
#define CONFIG_SYS_LOAD_ADDR 0x00100000
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/ - /* * Various low-level settings */ diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index f4261e9..7974c53 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -78,7 +78,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
#define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 5667680..a209659 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -40,7 +40,6 @@ /* Boot argument buffer size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* no console @ startup */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 153d162..9a4d2c9 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -55,7 +55,6 @@ #define CONFIG_CONS_SCIF5 1
/* Suppress display of console information at boot */ -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (AP325RXA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index e922cdf..93205aa 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -71,7 +71,6 @@ #define CONFIG_CONS_SCIF4 1
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index e6761c3..817ddab 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -60,7 +60,6 @@ #define SCIF2_BASE 0xe6c60000 #define SCIF4_BASE 0xe6c80000 #define CONFIG_SCIF_A -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (ARMADILLO_800EVA_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/bur_cfg_common.h b/include/configs/bur_cfg_common.h index 16237e6..5c99860 100644 --- a/include/configs/bur_cfg_common.h +++ b/include/configs/bur_cfg_common.h @@ -39,7 +39,6 @@ #define CONFIG_NETCONSOLE 1 #define CONFIG_BOOTP_MAY_FAIL /* if we don't have DHCP environment */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */
/* As stated above, the following choices are optional. */ diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 3990900..21b391b 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -87,7 +87,6 @@ #define CONFIG_PCI_SCAN_SHOW #endif
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_SYS_ALT_MEMTEST
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index a134889..282d5e8 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -50,7 +50,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* Additional FS support/configuration */ diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index a6d0221..446596e 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -72,7 +72,6 @@ #define CONFIG_SYS_NAND_USE_FLASH_BBT #define CONFIG_SYS_NAND_ONFI_DETECTION
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 48b4b2e..1f2f6b8 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -88,7 +88,6 @@ #define CONFIG_PCI_SCAN_SHOW #endif
/* Keep device tree and initrd in lower memory so the kernel can access them */ diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index c43dece..d81efa9 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -55,7 +55,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* SATA support */ diff --git a/include/configs/ea20.h b/include/configs/ea20.h index c88eaa9..acb01c9 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -104,7 +104,6 @@ #define CONFIG_VIDEO_DA8XX #define CONFIG_SPLASH_SCREEN_ALIGN #define CONFIG_VIDEO_LOGO -#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_VIDEO_BMP_LOGO #define CONFIG_CMD_BMP diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index dd925a9..e1e3c78 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -91,7 +91,6 @@ #define CONFIG_CONS_SCIF0 1
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 99dcb75..c2ffc08 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -539,8 +539,6 @@ void fpga_control_clear(unsigned int bus, int pin);
#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET - /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 0aff6e8..b8f73d6 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -56,7 +56,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF4 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (KZM_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END \ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 6084c8e..0caca4c 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -36,7 +36,6 @@ #define CONFIG_KIRKWOOD_GPIO
#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_CONSOLE_INFO_QUIET
/* * Enable u-boot API for standalone programs. diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 2fed3e0..638682f 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -426,8 +426,6 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/ - #ifndef DEBUG #define CONFIG_HW_WATCHDOG 1 /* Use external HW-Watchdog */ #endif diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index 29ed284..9f4308f 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -46,7 +46,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 17485b5..a473eec 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -40,7 +40,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF0 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress display of console information at boot */
#define CONFIG_SYS_MEMTEST_START (MS7722SE_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (60 * 1024 * 1024)) diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 704d1e7..2828f07 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -43,7 +43,6 @@ #define CONFIG_BAUDRATE 115200
/* Console configuration */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/openrisc-generic.h b/include/configs/openrisc-generic.h index 227c0ca..9decae7 100644 --- a/include/configs/openrisc-generic.h +++ b/include/configs/openrisc-generic.h @@ -38,7 +38,6 @@
#define CONFIG_BAUDRATE CONFIG_SYS_UART_BAUD #define CONFIG_SYS_BAUDRATE_TABLE {CONFIG_BAUDRATE} -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* Suppress console info */ #define CONSOLE_ARG "console=console=ttyS0,115200\0"
/* diff --git a/include/configs/origen.h b/include/configs/origen.h index a075b54..26fe402 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -37,7 +37,6 @@ #define CONFIG_BAUDRATE 115200
/* Console configuration */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
#define CONFIG_SYS_MEM_TOP_HIDE (1 << 20) /* ram console */ diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index d7ecdb8..0552003 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -76,7 +76,6 @@ #define CONFIG_CONS_SCIF3 1
/* SDRAM */ #define CONFIG_SYS_SDRAM_BASE (0x88000000) diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index e02e2d1..2d5c638 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -42,7 +42,6 @@ #define CONFIG_SH_GPIO_PFC
/* console */ -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/rcar-gen3-common.h b/include/configs/rcar-gen3-common.h index a397e64..29685ed 100644 --- a/include/configs/rcar-gen3-common.h +++ b/include/configs/rcar-gen3-common.h @@ -50,7 +50,6 @@ #define CONFIG_SH_GPIO_PFC
#define CONFIG_SYS_LONGHELP #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index e2d814f..0210c5b 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -29,7 +29,6 @@ #define CONFIG_BAUDRATE 115200
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run mmcboot" diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index bdb8101..38bf408 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -44,7 +44,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7752EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index eaa862c..3718bc5 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -44,7 +44,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7753EVB_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 8e4ff1c..8820e15 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -44,7 +44,6 @@ /* SCIF */ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF2 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7757LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 86057c1..11a4cf9 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -60,7 +60,6 @@ #define CONFIG_SCIF_CONSOLE 1 #define CONFIG_CONS_SCIF1 1 #define CONFIG_SCIF_EXT_CLOCK 1 -#undef CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 96b8df0..6bd3c10 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -110,7 +110,6 @@
-#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_SERIAL1 1 #define CONFIG_CONS_INDEX 1
diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 286e746..0407f03 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -25,7 +25,6 @@ #define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */
/* Ethernet on SoC (EMAC) */ #define CONFIG_PHY_INTERFACE_MODE PHY_INTERFACE_MODE_RGMII diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index a6973c5..c201d0a 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -190,7 +190,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LOAD_ADDR 0x00800000 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_SYS_FLASH_EMPTY_INFO
diff --git a/include/configs/strider.h b/include/configs/strider.h index 5cd37d7..92ad95e 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -573,8 +573,6 @@ void fpga_control_clear(unsigned int bus, int pin);
-#define CONFIG_SYS_CONSOLE_INFO_QUIET - /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index fe2ca6f..a51ffb5 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -63,7 +63,6 @@ #define CONFIG_PHY_MARVELL /* there is a marvell phy */ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
-#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_SYS_ALT_MEMTEST #define CONFIG_PREBOOT
diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 22a8e4f..e7f4fba 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -149,7 +149,6 @@
#define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
#define CONFIG_ENV_IS_NOWHERE
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index b3215a2..26998d7 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -114,7 +114,6 @@ #define CONFIG_SERIAL2 #define CONFIG_SERIAL3 #define CONFIG_CONS_INDEX 1 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index d8a8c4a..3825935 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -151,7 +151,6 @@ #else #define CONFIG_SYS_MALLOC_LEN (16 << 20) #endif -#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_BAUDRATE 115200 #define CONFIG_ENV_VARS_UBOOT_CONFIG /* Strongly encouraged */ #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ diff --git a/include/configs/trats.h b/include/configs/trats.h index 9fc6513..a26d663 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -41,7 +41,6 @@ #define CONFIG_BAUDRATE 115200
/* MACH_TYPE_TRATS macro will be removed once added to mach-types */ #define MACH_TYPE_TRATS 3928 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index c437c13..1633c67 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -38,7 +38,6 @@ #define CONFIG_BAUDRATE 115200
#define CONFIG_BOOTARGS "Please use defined boot" #define CONFIG_BOOTCOMMAND "run autoboot" diff --git a/include/configs/vct.h b/include/configs/vct.h index 168902c..357733b 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -142,7 +142,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_TIMESTAMP /* Print image info with timestamp */ #define CONFIG_CMDLINE_EDITING /* add command line history */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
/* * FLASH and environment organization diff --git a/include/configs/x600.h b/include/configs/x600.h index 9db4524..f433517 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -157,7 +157,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LOAD_ADDR 0x00800000 -#define CONFIG_SYS_CONSOLE_INFO_QUIET
/* Use last 2 lwords in internal SRAM for bootcounter */ #define CONFIG_BOOTCOUNT_LIMIT diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index ebb257b..7742020 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -84,8 +84,6 @@ #endif #define CONFIG_PARTITION_UUIDS
-#define CONFIG_SYS_CONSOLE_INFO_QUIET - /* x86 GPIOs are accessed through a PCI device */ #define CONFIG_INTEL_ICH6_GPIO
diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 6c52582..47c1ddf 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -57,7 +57,6 @@ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) diff --git a/include/configs/xpress.h b/include/configs/xpress.h index dd28e6a..3ea588a 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -45,7 +45,6 @@ #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR #define CONFIG_SYS_HZ 1000
-#define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_CMDLINE_EDITING
/* Physical Memory Map */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 5a2c6e3..b3401a3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4616,7 +4616,6 @@ CONFIG_SYS_CMXFCR_VALUE1 CONFIG_SYS_CMXFCR_VALUE2 CONFIG_SYS_CMXFCR_VALUE3 CONFIG_SYS_CMXSCR_VALUE -CONFIG_SYS_CONSOLE_INFO_QUIET CONFIG_SYS_CORE_SRAM CONFIG_SYS_CORE_SRAM_SIZE CONFIG_SYS_CORTEX_R4
This converts the following to Kconfig: CONFIG_USB_KEYBOARD
Changes in v2: - Add new patch to convert CONFIG_USB_KEYBOARD to Kconfig
configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/VCMA9_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/conga-qeval20-qa3-e3845-internal-uart_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 1 + configs/dms-ba16-1g_defconfig | 1 + configs/dms-ba16_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/galileo_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/novena_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu-x86_efi_payload32_defconfig | 1 + configs/qemu-x86_efi_payload64_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/smdk2410_defconfig | 1 + configs/som-db5800-som-6867_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/theadorable-x86-dfi-bt700_defconfig | 1 + configs/ventana_defconfig | 1 + include/configs/MIP405.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/PIP405.h | 1 - include/configs/VCMA9.h | 1 - include/configs/advantech_dms-ba16.h | 1 - include/configs/at91rm9200ek.h | 1 - include/configs/cgtqmx6eval.h | 1 - include/configs/cyrus.h | 1 - include/configs/ge_bx50v3.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/mx6cuboxi.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/rpi.h | 1 - include/configs/seaboard.h | 1 - include/configs/smdk2410.h | 1 - include/configs/tbs2910.h | 1 - include/configs/ventana.h | 1 - include/configs/x86-common.h | 1 - 66 files changed, 46 insertions(+), 20 deletions(-)
diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index 9dd8742..53342f2 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -27,4 +27,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index ff36be4..5929c08 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -27,4 +27,5 @@ CONFIG_SYS_NS16550=y CONFIG_FSL_ESPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index f73b4d4..8b03d70 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_CFB_CONSOLE=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index ed6764a..154352c 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_CFB_CONSOLE=y CONFIG_CONSOLE_EXTRA_INFO=y CONFIG_VIDEO_CT69000=y diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig index e6646fa..33d0991 100644 --- a/configs/VCMA9_defconfig +++ b/configs/VCMA9_defconfig @@ -13,3 +13,4 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index e4f7196..293cab0 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -14,4 +14,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index c04cd73..c5466d4 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -15,4 +15,5 @@ CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_OF_LIBFDT=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index e720245..6b8be86 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -56,6 +56,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 410e8d3..5d70a78 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -42,6 +42,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index b09b70a..039d0c5 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -60,6 +60,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 015d357..506530a 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -58,6 +58,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 1ec10e9..0a8a0a8 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -52,6 +52,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index 9bb26c3..dc0d556 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -64,6 +64,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index bd5e3a0..59f8cea 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -63,6 +63,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 4a8985d..9d25378 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -43,6 +43,7 @@ CONFIG_TPM_TIS_LPC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_CFB_CONSOLE=y CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 18113f4..914dc51 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -35,4 +35,5 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 7d4910b..dbfa5c1 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -50,6 +50,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_CFB_CONSOLE=y diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index e079c3c..3b015a9 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -61,6 +61,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index f5fcd31..5849f72 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index d0762b3..367579e 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index f2aa4cb..1cdd49d 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -33,4 +33,5 @@ CONFIG_ICH_SPI=y CONFIG_TIMER=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_EFI=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index db19e47..e3868b3 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -51,4 +51,5 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 9acd83f..3a6d03e 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -47,6 +47,7 @@ CONFIG_E1000=y CONFIG_DM_SERIAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 802e5b2..87caff3 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -60,6 +60,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 855edcb..a64be21 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -34,5 +34,6 @@ CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_CFB_CONSOLE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index a1535b1..c195134 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -33,6 +33,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 193d905..b0b6135 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 757abad..328a992 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index b8d4577..03a644c 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 0a23849..a04573b 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index db25004..39f88d3 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index a7aeba3..bf0c859 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -31,6 +31,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 021711b..0e0c4c5 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_CFB_CONSOLE=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 6d52ca6..8321c4e 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -47,6 +47,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/qemu-x86_efi_payload32_defconfig b/configs/qemu-x86_efi_payload32_defconfig index f0d3169..b700850 100644 --- a/configs/qemu-x86_efi_payload32_defconfig +++ b/configs/qemu-x86_efi_payload32_defconfig @@ -44,6 +44,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/qemu-x86_efi_payload64_defconfig b/configs/qemu-x86_efi_payload64_defconfig index ad18ecd..7b4571e 100644 --- a/configs/qemu-x86_efi_payload64_defconfig +++ b/configs/qemu-x86_efi_payload64_defconfig @@ -44,6 +44,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_111=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index f01dc30..8b961c5 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index fa57de5..1552b0f 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 16f4178..bd461dd 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_FS_GENERIC=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 2436e93..3261f8b 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_LCD=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 4b4601a..baaf37e 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -37,6 +37,7 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig index 3d098ba..50bc1ad 100644 --- a/configs/smdk2410_defconfig +++ b/configs/smdk2410_defconfig @@ -12,3 +12,4 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 5f8081f..e7aa970 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -58,6 +58,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_11A=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 80bd31f..91ce927 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -32,6 +32,7 @@ CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index f965cb5..b43b107 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -58,6 +58,7 @@ CONFIG_TIMER=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_VIDEO_VESA=y CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_114=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index e453cf6..eda46db 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -36,6 +36,7 @@ CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_CONSOLE_SCROLL_LINES=10 diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index db92967..0538332 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -346,7 +346,6 @@ ************************************************************/ #if !defined(CONFIG_TARGET_MIP405T) #define CONFIG_USB_UHCI -#define CONFIG_USB_KEYBOARD
/* Enable needed helper functions */ #define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 7882b35..b047466 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -285,7 +285,6 @@ ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 2c15f3d..fe0868f 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -363,7 +363,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 1db7b5d..eaa8b26 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -306,7 +306,6 @@ * USB support ************************************************************/ #define CONFIG_USB_UHCI -#define CONFIG_USB_KEYBOARD
/* Enable needed helper functions */ #define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index a368d81..25dfb82 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -100,7 +100,6 @@ /* USB support (currently only works with D-cache off) */ #define CONFIG_USB_OHCI #define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_USB_KEYBOARD #define CONFIG_DOS_PARTITION
/* Enable needed helper functions */ diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index bbf97c7..304994a 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -72,7 +72,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
#define CONFIG_USBD_HS diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 3cc8d89..ed0daf5 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -144,7 +144,6 @@ #define CONFIG_USB_ATMEL 1 #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 #define CONFIG_DOS_PARTITION 1
#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 722f1c5..2d9a40f 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -74,7 +74,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 /* Enabled USB controller number */ -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
#define CONFIG_USBD_HS diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 78eb567..31f2437 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -448,7 +448,6 @@ #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_EHCI_IS_TDI -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL /* _VIA_CONTROL_EP */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index a3c2bd4..4adb8e2 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -83,7 +83,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
#define CONFIG_CI_UDC diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 050c055..21c1ab5 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -170,7 +170,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_USBD_HS #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 82957d6..446b3bc 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -52,7 +52,6 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL #define CONFIG_PREBOOT \ "if hdmidet; then " \ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index b32e49e..8ab2486 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -85,7 +85,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP
/* Miscellaneous commands */ diff --git a/include/configs/novena.h b/include/configs/novena.h index 0983b96..ee4267a 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -142,7 +142,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 7fe469c..25a90cc 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -100,7 +100,6 @@ #define CONFIG_USB_ETHER_SMSC95XX #define CONFIG_TFTP_TSIZE #define CONFIG_MISC_INIT_R -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL #define CONFIG_SYS_STDIO_DEREGISTER #endif diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index fe68437..2b6509a 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -57,7 +57,6 @@ #define CONFIG_KEYBOARD
/* USB keyboard */ -#define CONFIG_USB_KEYBOARD
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index c8148bb..50e6bf8 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -50,7 +50,6 @@ ************************************************************/ #define CONFIG_USB_OHCI #define CONFIG_USB_OHCI_S3C24XX -#define CONFIG_USB_KEYBOARD #define CONFIG_DOS_PARTITION
/************************************************************ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 8fdeaa1..890bd69 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -112,7 +112,6 @@ #define CONFIG_USBD_HS #define CONFIG_USB_FUNCTION_MASS_STORAGE #endif /* CONFIG_CMD_USB_MASS_STORAGE */ -#define CONFIG_USB_KEYBOARD #ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE #define CONFIG_SYS_STDIO_DEREGISTER diff --git a/include/configs/ventana.h b/include/configs/ventana.h index d3843d4..7a38869 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -42,7 +42,6 @@ /* General networking support */
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 7742020..fa07417 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -166,7 +166,6 @@ #define CONFIG_USB_EHCI_PCI #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 12 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 -#define CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL
Signed-off-by: Simon Glass sjg@chromium.org
This converts the following to Kconfig: CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
Changes in v2: - Make CONFIG_SYS_STDIO_DEREGISTER the default if USB_KEYBOARD - Drop Kconfig changes
common/Kconfig | 9 +++++++++ common/stdio.c | 6 +++--- common/usb_kbd.c | 2 +- configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 1 + configs/MPC8641HPCN_defconfig | 1 + drivers/serial/serial-uclass.c | 2 +- include/configs/MIP405.h | 1 - include/configs/MPC8610HPCD.h | 1 - include/configs/MPC8641HPCN.h | 1 - include/configs/PIP405.h | 1 - include/configs/VCMA9.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cyrus.h | 1 - include/configs/gr_ep2s60.h | 1 - include/configs/novena.h | 1 - include/configs/rpi.h | 1 - include/configs/sandbox.h | 2 -- include/configs/sunxi-common.h | 1 - include/configs/tbs2910.h | 1 - include/configs/tegra-common.h | 4 ---- include/configs/x86-common.h | 2 -- include/stdio_dev.h | 2 +- scripts/config_whitelist.txt | 1 - 24 files changed, 18 insertions(+), 27 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 4d27f09..5615e39 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -335,6 +335,15 @@ config SYS_CONSOLE_INFO_QUIET Enable this option to supress this output. It can be obtained by calling stdio_print_current_devices() from board code.
+config SYS_STDIO_DEREGISTER + bool "Allow deregistering stdio devices" + default y if USB_KEYBOARD + help + Generally there is no need to deregister stdio devices since they + are never deactivated. But if a stdio device is used which can be + removed (for example a USB keyboard) then this option can be + enabled to ensure this is handled correctly. + endmenu
config SYS_NO_FLASH diff --git a/common/stdio.c b/common/stdio.c index f99cfe7..c849a9a 100644 --- a/common/stdio.c +++ b/common/stdio.c @@ -37,7 +37,7 @@ char *stdio_names[MAX_FILES] = { "stdin", "stdout", "stderr" }; #define CONFIG_SYS_DEVICE_NULLDEV 1 #endif
-#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) #define CONFIG_SYS_DEVICE_NULLDEV 1 #endif
@@ -177,7 +177,7 @@ int stdio_register(struct stdio_dev *dev) /* deregister the device "devname". * returns 0 if success, -1 if device is assigned and 1 if devname not found */ -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) int stdio_deregister_dev(struct stdio_dev *dev, int force) { int l; @@ -224,7 +224,7 @@ int stdio_deregister(const char *devname, int force)
return stdio_deregister_dev(dev, force); } -#endif /* CONFIG_SYS_STDIO_DEREGISTER */ +#endif /* CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) */
int stdio_init_tables(void) { diff --git a/common/usb_kbd.c b/common/usb_kbd.c index a9872a6..5f9a64a 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -570,7 +570,7 @@ int drv_usb_kbd_init(void) /* Deregister the keyboard. */ int usb_kbd_deregister(int force) { -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) struct stdio_dev *dev; struct usb_device *usb_kbd_dev; struct usb_kbd_pdata *data; diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 6e2eb3d..3facbb0 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_MPC8610HPCD=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index a113e37..77903bf 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_PHYS_64BIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 80ab195..06e75a5 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_BOOTDELAY=10 +CONFIG_SYS_STDIO_DEREGISTER=y CONFIG_HUSH_PARSER=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 19f38e1..43c028e 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -346,7 +346,7 @@ static int serial_post_probe(struct udevice *dev)
static int serial_pre_remove(struct udevice *dev) { -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) struct serial_dev_priv *upriv = dev_get_uclass_priv(dev);
if (stdio_deregister_dev(upriv->sdev, 0)) diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 0538332..9aba1dd 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -348,7 +348,6 @@ #define CONFIG_USB_UHCI
/* Enable needed helper functions */ -#define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ #endif /************************************************************ * Debug support diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index b047466..9c98738 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -285,7 +285,6 @@ ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index fe0868f..ef5653f 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -363,7 +363,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); ************************************************************/ #define CONFIG_PCI_OHCI 1 #define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL 1 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "ohci_pci" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index eaa8b26..8516eb7 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -308,7 +308,6 @@ #define CONFIG_USB_UHCI
/************************************************************ * Debug support diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 25dfb82..2352eb8 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -103,7 +103,6 @@ #define CONFIG_DOS_PARTITION
/* RTC */ #define CONFIG_RTC_S3C24X0 diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 325c019..8b1e30d 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -211,7 +211,6 @@ #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ -#define CONFIG_SYS_STDIO_DEREGISTER
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 31f2437..474eef1 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -448,7 +448,6 @@ #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_EHCI_IS_TDI -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL /* _VIA_CONTROL_EP */ #endif diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index fa10676..544e5fc 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -60,7 +60,6 @@ #if USE_GRUSB #define CONFIG_USB_UHCI /* Enable needed helper functions */ -#define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ #endif
/* diff --git a/include/configs/novena.h b/include/configs/novena.h index ee4267a..ecc7e7e 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -142,7 +142,6 @@ #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 25a90cc..45c8234 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -101,7 +101,6 @@ #define CONFIG_TFTP_TSIZE #define CONFIG_MISC_INIT_R #define CONFIG_SYS_USB_EVENT_POLL -#define CONFIG_SYS_STDIO_DEREGISTER #endif
/* Console UART */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index b6533c3..31ab765 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -25,8 +25,6 @@ #define CONFIG_SYS_TIMER_RATE 1000000 #endif
-#define CONFIG_SYS_STDIO_DEREGISTER - /* * Number of bits in a C 'long' on this architecture. Set this to 32 when * building on a 32-bit machine. diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index e96f426..a142b65 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -354,7 +354,6 @@ extern int soft_i2c_gpio_scl;
#ifdef CONFIG_USB_KEYBOARD #define CONFIG_PREBOOT -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE #endif
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 890bd69..fba345f 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -114,7 +114,6 @@ #endif /* CONFIG_CMD_USB_MASS_STORAGE */ #ifdef CONFIG_USB_KEYBOARD #define CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE -#define CONFIG_SYS_STDIO_DEREGISTER #define CONFIG_PREBOOT \ "usb start; " \ "if hdmidet; then " \ diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 6a344a4..759a4c0 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -66,10 +66,6 @@
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_STDIO_DEREGISTER -#endif - /* * Increasing the size of the IO buffer as default nfsargs size is more * than 256 and so it is not possible to edit it diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index fa07417..f9b7206 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -62,8 +62,6 @@ 9600, 19200, 38400, 115200} #define CONFIG_SYS_NS16550_PORT_MAPPED
-#define CONFIG_SYS_STDIO_DEREGISTER - #define CONFIG_CMDLINE_EDITING #define CONFIG_COMMAND_HISTORY #define CONFIG_AUTO_COMPLETE diff --git a/include/stdio_dev.h b/include/stdio_dev.h index 13f76be..e4fc8b1 100644 --- a/include/stdio_dev.h +++ b/include/stdio_dev.h @@ -100,7 +100,7 @@ int stdio_add_devices(void); int stdio_init(void);
void stdio_print_current_devices(void); -#ifdef CONFIG_SYS_STDIO_DEREGISTER +#if CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) int stdio_deregister(const char *devname, int force); int stdio_deregister_dev(struct stdio_dev *dev, int force); #endif diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index b3401a3..4d0e41d 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -7700,7 +7700,6 @@ CONFIG_SYS_STACK_LENGTH CONFIG_SYS_STACK_SIZE CONFIG_SYS_STATUS_C CONFIG_SYS_STATUS_OK -CONFIG_SYS_STDIO_DEREGISTER CONFIG_SYS_STMICRO_BOOT CONFIG_SYS_SUPPORT_64BIT_DATA CONFIG_SYS_SXCNFG_VAL
