Pull request: SoCFPGA changes for commit 05dcb5be507a
Hi Tom,
Please pull the SoCFPGA changes as shown in below.
Thanks.
Best regards, Tien Fong
The following changes since commit 05dcb5be507a0580a0fc57dd363c632ac4a6b3c4:
mtd: mxs_nand_spl: fix nand_command protocol violation (2022-06-29 09:26:44 -0400)
https://github.com/tienfong/uboot_mainline.git ef5ba2cef4a08b68caaa9215fcac142d3025bbf7
for you to fetch changes up to ef5ba2cef4a08b68caaa9215fcac142d3025bbf7:
drivers: clk: Update license for Intel N5X device (2022-07-01 15:00:39 +0800)
---------------------------------------------------------------- Paweł Anikiel (11): arm: dts: Add Mercury+ AA1 devicetrees arm: dts: Add Chameleonv3 handoff headers arm: dts: Add Chameleonv3 devicetrees board: Add Chameleonv3 board dir config: Add Chameleonv3 config misc: atsha204a: Increase wake delay by tWHI sysreset: socfpga: Use parent device for reading base address socfpga: arria10: Replace delays with busy waiting in cm_full_cfg socfpga: arria10: Improve bitstream loading speed socfpga: arria10: Wait for fifo empty after writing bitstream socfpga: arria10: Allow dcache_enable before relocation
Teik Heng Chong (1): drivers: clk: Update license for Intel N5X device
arch/arm/dts/Makefile | 2 + arch/arm/dts/socfpga_arria10_chameleonv3.dts | 90 ++++++++++++++++ arch/arm/dts/socfpga_arria10_chameleonv3_270_3-u-boot.dtsi | 8 ++ arch/arm/dts/socfpga_arria10_chameleonv3_270_3.dts | 5 + arch/arm/dts/socfpga_arria10_chameleonv3_270_3_handoff.h | 305 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/socfpga_arria10_chameleonv3_480_2-u-boot.dtsi | 8 ++ arch/arm/dts/socfpga_arria10_chameleonv3_480_2.dts | 5 + arch/arm/dts/socfpga_arria10_chameleonv3_480_2_handoff.h | 305 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/socfpga_arria10_mercury_aa1-u-boot.dtsi | 54 ++++++++++ arch/arm/dts/socfpga_arria10_mercury_aa1.dtsi | 72 +++++++++++++ arch/arm/mach-socfpga/Kconfig | 7 ++ arch/arm/mach-socfpga/clock_manager_arria10.c | 31 ++++-- arch/arm/mach-socfpga/misc_arria10.c | 26 +++++ board/google/chameleonv3/Makefile | 5 + board/google/chameleonv3/board.c | 27 +++++ board/google/chameleonv3/fpga.its | 28 +++++ board/google/chameleonv3/fpga_early_io.its | 35 +++++++ board/google/chameleonv3/mercury_aa1.c | 43 ++++++++ board/google/chameleonv3/mercury_aa1.h | 12 +++ configs/socfpga_chameleonv3_defconfig | 29 ++++++ drivers/clk/altera/clk-mem-n5x.c | 4 +- drivers/clk/altera/clk-mem-n5x.h | 4 +- drivers/clk/altera/clk-n5x.c | 4 +- drivers/clk/altera/clk-n5x.h | 4 +- drivers/fpga/socfpga_arria10.c | 28 ++++- drivers/misc/atsha204a-i2c.c | 5 +- drivers/sysreset/sysreset_socfpga.c | 2 +- include/configs/socfpga_chameleonv3.h | 44 ++++++++ 28 files changed, 1170 insertions(+), 22 deletions(-) create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3.dts create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3_270_3-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3_270_3.dts create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3_270_3_handoff.h create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3_480_2-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3_480_2.dts create mode 100644 arch/arm/dts/socfpga_arria10_chameleonv3_480_2_handoff.h create mode 100644 arch/arm/dts/socfpga_arria10_mercury_aa1-u-boot.dtsi create mode 100644 arch/arm/dts/socfpga_arria10_mercury_aa1.dtsi create mode 100644 board/google/chameleonv3/Makefile create mode 100644 board/google/chameleonv3/board.c create mode 100644 board/google/chameleonv3/fpga.its create mode 100644 board/google/chameleonv3/fpga_early_io.its create mode 100644 board/google/chameleonv3/mercury_aa1.c create mode 100644 board/google/chameleonv3/mercury_aa1.h create mode 100644 configs/socfpga_chameleonv3_defconfig create mode 100644 include/configs/socfpga_chameleonv3.h
On Fri, Jul 01, 2022 at 09:00:38AM +0000, Chee, Tien Fong wrote:
Hi Tom,
Thanks.
Chee, Tien Fong
