[U-Boot] [PATCH 2/6] usb: host: xhci-omap: fix double weak board_usb_init functions
A weak version of the function board_usb_init is implemented in: common/usb.c drivers/usb/host/xhci-omap.c
To fix the double implementations: * Convert the board_usb_init function in drivers/usb/host/xhci-omap.c normal (not weak). * The function board_usb_init in drivers/usb/host/xhci-omap.c calls to the weak function omap_xhci_board_usb_init. * Rename board version of the function board_usb_init to omap_xhci_board_usb_init. Done only for boards that defines CONFIG_USB_XHCI_OMAP.
To achieve the same flexibility with the function board_usb_cleanup: * Add a normal (not weak) implementation of the function board_usb_cleanup in drivers/usb/host/xhci-omap.c * The function board_usb_cleanup in drivers/usb/host/xhci-omap.c calls to the weak function omap_xhci_board_usb_cleanup. * Rename board version of the function board_usb_cleanup to omap_xhci_board_usb_cleanup. Done only for boards that defines CONFIG_USB_XHCI_OMAP.
Signed-off-by: Uri Mashiach uri.mashiach@compulab.co.il --- board/compulab/cl-som-am57x/cl-som-am57x.c | 2 +- board/ti/am43xx/board.c | 4 ++-- board/ti/am57xx/board.c | 4 ++-- board/ti/dra7xx/evm.c | 4 ++-- drivers/usb/host/xhci-omap.c | 23 +++++++++++++++++++++-- 5 files changed, 28 insertions(+), 9 deletions(-)
diff --git a/board/compulab/cl-som-am57x/cl-som-am57x.c b/board/compulab/cl-som-am57x/cl-som-am57x.c index bdd0a2b..fe1468f 100644 --- a/board/compulab/cl-som-am57x/cl-som-am57x.c +++ b/board/compulab/cl-som-am57x/cl-som-am57x.c @@ -54,7 +54,7 @@ int board_mmc_init(bd_t *bis) #endif /* CONFIG_GENERIC_MMC */
#ifdef CONFIG_USB_XHCI_OMAP -int board_usb_init(int index, enum usb_init_type init) +int omap_xhci_board_usb_init(int index, enum usb_init_type init) { setbits_le32((*prcm)->cm_l3init_usb_otg_ss1_clkctrl, OTG_SS_CLKCTRL_MODULEMODE_HW | OPTFCLKEN_REFCLK960M); diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 390cc16..2572029 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -694,7 +694,7 @@ int usb_gadget_handle_interrupts(int index) #endif /* CONFIG_USB_DWC3 */
#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) -int board_usb_init(int index, enum usb_init_type init) +int omap_xhci_board_usb_init(int index, enum usb_init_type init) { enable_usb_clocks(index); #ifdef CONFIG_USB_DWC3 @@ -725,7 +725,7 @@ int board_usb_init(int index, enum usb_init_type init) return 0; }
-int board_usb_cleanup(int index, enum usb_init_type init) +int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) { #ifdef CONFIG_USB_DWC3 switch (index) { diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 5f2d4df..96fad0f 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -616,7 +616,7 @@ int usb_gadget_handle_interrupts(int index) #endif /* CONFIG_USB_DWC3 */
#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_OMAP) -int board_usb_init(int index, enum usb_init_type init) +int omap_xhci_board_usb_init(int index, enum usb_init_type init) { enable_usb_clocks(index); switch (index) { @@ -650,7 +650,7 @@ int board_usb_init(int index, enum usb_init_type init) return 0; }
-int board_usb_cleanup(int index, enum usb_init_type init) +int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) { #ifdef CONFIG_USB_DWC3 switch (index) { diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index bd1c809..21fa824 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -727,7 +727,7 @@ static struct ti_usb_phy_device usb_phy2_device = { .index = 1, };
-int board_usb_init(int index, enum usb_init_type init) +int omap_xhci_board_usb_init(int index, enum usb_init_type init) { enable_usb_clocks(index); switch (index) { @@ -764,7 +764,7 @@ int board_usb_init(int index, enum usb_init_type init) return 0; }
-int board_usb_cleanup(int index, enum usb_init_type init) +int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) { switch (index) { case 0: diff --git a/drivers/usb/host/xhci-omap.c b/drivers/usb/host/xhci-omap.c index b881b19..ceee12a 100644 --- a/drivers/usb/host/xhci-omap.c +++ b/drivers/usb/host/xhci-omap.c @@ -27,12 +27,31 @@ DECLARE_GLOBAL_DATA_PTR;
static struct omap_xhci omap;
-__weak int __board_usb_init(int index, enum usb_init_type init) +__weak int __omap_xhci_board_usb_init(int index, enum usb_init_type init) { return 0; } + +int omap_xhci_board_usb_init(int index, enum usb_init_type init) + __attribute__((weak, alias("__omap_xhci_board_usb_init"))); + int board_usb_init(int index, enum usb_init_type init) - __attribute__((weak, alias("__board_usb_init"))); +{ + return omap_xhci_board_usb_init(index, init); +} + +__weak int __omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) +{ + return 0; +} + +int omap_xhci_board_usb_cleanup(int index, enum usb_init_type init) + __attribute__((weak, alias("__omap_xhci_board_usb_cleanup"))); + +int board_usb_cleanup(int index, enum usb_init_type init) +{ + return omap_xhci_board_usb_cleanup(index, init); +}
static int omap_xhci_core_init(struct omap_xhci *omap) {
- Convert the board_usb_init function in drivers/usb/host/xhci-omap.c normal (not weak).
- The function board_usb_init in drivers/usb/host/xhci-omap.c calls to the weak function omap_xhci_board_usb_init.
- Rename board version of the function board_usb_init to omap_xhci_board_usb_init. Done only for boards that defines CONFIG_USB_XHCI_OMAP.
- Add a normal (not weak) implementation of the function board_usb_cleanup in drivers/usb/host/xhci-omap.c
- The function board_usb_cleanup in drivers/usb/host/xhci-omap.c calls to the weak function omap_xhci_board_usb_cleanup.
- Rename board version of the function board_usb_cleanup to omap_xhci_board_usb_cleanup. Done only for boards that defines CONFIG_USB_XHCI_OMAP.
- __attribute__((weak, alias("__omap_xhci_board_usb_init")));
You can just use __weak instead of this attribute block .
- return omap_xhci_board_usb_init(index, init);
- __attribute__((weak, alias("__omap_xhci_board_usb_cleanup")));
- return omap_xhci_board_usb_cleanup(index, init);
Hello Marek,
With the attribute block it is possible to call to __omap_xhci_board_usb_init from the board file. Do you think it's redundant?
On 02/09/2017 12:36 PM, Uri Mashiach wrote:
Hello Marek,
Hi!
Yes, but feel free to prove me wrong, I'm not an omap expert.
Hello Marek,
Hi!
This isn't an omap issue, it's a compiler issue. IFF we need both omap_xhci_board_usb_init and __omap_xhci_board_usb_init then we need the above declaration as that provides both. IFF we only need one function, name it as needed and use __weak. __weak just sets the weak attribute (and __alias(foo) will just set the alias attribute).
Hello Marek,
Hi!
Currently only the omap_xhci_board_usb_init function is needed. I will go for the __weak instead of this attribute block in V2.
Uri Mashiach
