[U-Boot] [PATCH 1/2] at91sam9263ek: enable useful commands
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com cc: Stelian Pop stelian@popies.net --- include/configs/at91sam9263ek.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index f2163f1..2d46502 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -108,10 +108,8 @@ * Command line configuration. */ #include <config_cmd_default.h> -#undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_SOURCE
The old update script uses 'load_addr' which is never set. Use 'fileaddr' instead whic his automagically set by e.g. dhcp.
Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com cc: Stelian Pop stelian@popies.net --- include/configs/at91sam9263ek.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 2d46502..f93a436 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -163,7 +163,7 @@ "update=" \ "protect off ${monitor_base} +${filesize};" \ "erase ${monitor_base} +${filesize};" \ - "cp.b ${load_addr} ${monitor_base} ${filesize};" \ + "cp.b ${fileaddr} ${monitor_base} ${filesize};" \ "protect on ${monitor_base} +${filesize}\0"
#ifndef CONFIG_SKIP_LOWLEVEL_INIT
- Command line configuration.
NAK, enabling imls breaks all the configurations where NOR is not enabled:
---8<--- Configuring for at91sam9263ek_nandflash - Board: at91sam9263ek, Options: AT91SAM9263,SYS_USE_NANDFLASH /home/abiessmann/source/git_projects/u-boot-atmel/include/mtd/cfi_flash.h:174:22: error: unknown type name 'flash_info_t' /home/abiessmann/source/git_projects/u-boot-atmel/include/mtd/cfi_flash.h:174:43: error: unknown type name 'flash_sect_t' cmd_bootm.c:82:1: error: unknown type name 'flash_info_t' cmd_bootm.c:1164:2: error: unknown type name 'flash_info_t' cmd_bootm.c:1169:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function) cmd_bootm.c:1171:11: error: request for member 'flash_id' in something not a structure or union cmd_bootm.c:1171:25: error: 'FLASH_UNKNOWN' undeclared (first use in this function) cmd_bootm.c:1173:23: error: request for member 'sector_count' in something not a structure or union cmd_bootm.c:1175:22: error: request for member 'start' in something not a structure or union --->8---
Andreas Bießmann
