[PATCH 1/1] dm: syscon: typo alerady
* Fix typo: %s/alerady/already/. * Add missing 'the'. * Reformat a comment.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- drivers/core/syscon-uclass.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index b5cd763b6b..9cbda4ebda 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -18,12 +18,16 @@
/* * Caution: - * This API requires the given device has alerady been bound to syscon driver. - * For example, + * This API requires the given device has already been bound to the syscon + * driver. For example, + * * compatible = "syscon", "simple-mfd"; + * * works, but + * * compatible = "simple-mfd", "syscon"; - * does not. The behavior is different from Linux. + * + * does not. The behavior is different from Linux. */ struct regmap *syscon_get_regmap(struct udevice *dev) { -- 2.28.0
On Fri, 21 Aug 2020 at 23:16, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
- Fix typo: %s/alerady/already/.
- Add missing 'the'.
- Reformat a comment.
- Caution:
- This API requires the given device has alerady been bound to syscon driver.
- For example,
- This API requires the given device has already been bound to the syscon
- driver. For example,
- compatible = "syscon", "simple-mfd";
- works, but
- compatible = "simple-mfd", "syscon";
- does not. The behavior is different from Linux.
Applied to u-boot-dm/next, thanks!
