[U-Boot] [PATCH 00/12] regulator: Change get_enable return type to integer from bool
Change get_enable return type to int so errors can be returned. The series converts the return type of get_enable hook in the dm_regulator_ops to integer from bool. This enables it to return any error values if any.
Compile tested.
Keerthy (12): regulator: Change get_enable return type to integer from bool power: regulator: fixed: get_enable should return integer power: regulator: act8846: get_enable should return integer power: regulator: max77686: get_enable should return integer power: regulator: palmas: get_enable should return integer power: regulator: pfuze100: get_enable should return integer power: regulator: tps65090: get_enable should return integer power: regulator: rk8xx: get_enable should return integer power: sandbox: fixed: get_enable should return integer power: regulator: s5m8767: get_enable should return integer power: regulator: lp873x: get_enable should return integer power: regulator: lp87565: get_enable should return integer
drivers/power/regulator/act8846.c | 2 +- drivers/power/regulator/fixed.c | 2 +- drivers/power/regulator/lp873x_regulator.c | 4 ++-- drivers/power/regulator/lp87565_regulator.c | 2 +- drivers/power/regulator/max77686.c | 4 ++-- drivers/power/regulator/palmas_regulator.c | 4 ++-- drivers/power/regulator/pfuze100.c | 2 +- drivers/power/regulator/regulator-uclass.c | 2 +- drivers/power/regulator/rk8xx.c | 6 +++--- drivers/power/regulator/s5m8767.c | 4 ++-- drivers/power/regulator/sandbox.c | 4 ++-- drivers/power/regulator/tps65090_regulator.c | 2 +- include/power/regulator.h | 8 ++++---- 13 files changed, 23 insertions(+), 23 deletions(-)
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/regulator-uclass.c | 2 +- include/power/regulator.h | 8 ++++---- 2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/power/regulator/regulator-uclass.c b/drivers/power/regulator/regulator-uclass.c index 0a1d1b3..426a933 100644 --- a/drivers/power/regulator/regulator-uclass.c +++ b/drivers/power/regulator/regulator-uclass.c @@ -96,7 +96,7 @@ int regulator_set_current(struct udevice *dev, int uA) return ops->set_current(dev, uA); }
-bool regulator_get_enable(struct udevice *dev) +int regulator_get_enable(struct udevice *dev) { const struct dm_regulator_ops *ops = dev_get_driver_ops(dev);
diff --git a/include/power/regulator.h b/include/power/regulator.h index 1a8e575..2bbc1e5 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -211,9 +211,9 @@ struct dm_regulator_ops { * @dev - regulator device * Sets: * @enable - set true - enable or false - disable - * @return true/false for get; or 0 / -errno for set. + * @return true/false for get or -errno if fail; 0 / -errno for set. */ - bool (*get_enable)(struct udevice *dev); + int (*get_enable)(struct udevice *dev); int (*set_enable)(struct udevice *dev, bool enable);
/** @@ -291,9 +291,9 @@ int regulator_set_current(struct udevice *dev, int uA); * regulator_get_enable: get regulator device enable state. * * @dev - pointer to the regulator device - * @return - true/false of enable state + * @return - true/false of enable state or -errno val if fails */ -bool regulator_get_enable(struct udevice *dev); +int regulator_get_enable(struct udevice *dev);
/** * regulator_set_enable: set regulator enable state
Thanks!
get_enable should be able to return error values. Hence change the return type to integer.
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/fixed.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/fixed.c b/drivers/power/regulator/fixed.c index 656371b..35c2922 100644 --- a/drivers/power/regulator/fixed.c +++ b/drivers/power/regulator/fixed.c @@ -89,7 +89,7 @@ static int fixed_regulator_get_current(struct udevice *dev) return uc_pdata->min_uA; }
-static bool fixed_regulator_get_enable(struct udevice *dev) +static int fixed_regulator_get_enable(struct udevice *dev) { struct fixed_regulator_platdata *dev_pdata = dev_get_platdata(dev);
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/act8846.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/act8846.c b/drivers/power/regulator/act8846.c index d506165..7d86aae 100644 --- a/drivers/power/regulator/act8846.c +++ b/drivers/power/regulator/act8846.c @@ -115,7 +115,7 @@ static int reg_set_enable(struct udevice *dev, bool enable) enable ? LDO_EN_MASK : 0); }
-static bool reg_get_enable(struct udevice *dev) +static int reg_get_enable(struct udevice *dev) { int reg = dev->driver_data; int ret;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/max77686.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/max77686.c b/drivers/power/regulator/max77686.c index 5e5815f..8780806 100644 --- a/drivers/power/regulator/max77686.c +++ b/drivers/power/regulator/max77686.c @@ -688,7 +688,7 @@ static int ldo_set_value(struct udevice *dev, int uV) return max77686_ldo_val(dev, PMIC_OP_SET, &uV); }
-static bool ldo_get_enable(struct udevice *dev) +static int ldo_get_enable(struct udevice *dev) { bool enable = false; int ret; @@ -752,7 +752,7 @@ static int buck_set_value(struct udevice *dev, int uV) return max77686_buck_val(dev, PMIC_OP_SET, &uV); }
-static bool buck_get_enable(struct udevice *dev) +static int buck_get_enable(struct udevice *dev) { bool enable = false; int ret;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/palmas_regulator.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/palmas_regulator.c b/drivers/power/regulator/palmas_regulator.c index 841c03a..99614b0 100644 --- a/drivers/power/regulator/palmas_regulator.c +++ b/drivers/power/regulator/palmas_regulator.c @@ -304,7 +304,7 @@ static int ldo_set_value(struct udevice *dev, int uV) return palmas_ldo_val(dev, PMIC_OP_SET, &uV); }
-static bool ldo_get_enable(struct udevice *dev) +static int ldo_get_enable(struct udevice *dev) { bool enable = false; int ret; @@ -411,7 +411,7 @@ static int smps_set_value(struct udevice *dev, int uV) return palmas_smps_val(dev, PMIC_OP_SET, &uV); }
-static bool smps_get_enable(struct udevice *dev) +static int smps_get_enable(struct udevice *dev) { bool enable = false; int ret;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/pfuze100.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/pfuze100.c b/drivers/power/regulator/pfuze100.c index 4702161..3edc2aa 100644 --- a/drivers/power/regulator/pfuze100.c +++ b/drivers/power/regulator/pfuze100.c @@ -516,7 +516,7 @@ static int pfuze100_regulator_set_value(struct udevice *dev, int uV) return pfuze100_regulator_val(dev, PMIC_OP_SET, &uV); }
-static bool pfuze100_regulator_get_enable(struct udevice *dev) +static int pfuze100_regulator_get_enable(struct udevice *dev) { int ret; bool enable = false;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/tps65090_regulator.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/tps65090_regulator.c b/drivers/power/regulator/tps65090_regulator.c index affc504..32aeab9 100644 --- a/drivers/power/regulator/tps65090_regulator.c +++ b/drivers/power/regulator/tps65090_regulator.c @@ -23,7 +23,7 @@ static int tps65090_fet_probe(struct udevice *dev) return 0; }
-static bool tps65090_fet_get_enable(struct udevice *dev) +static int tps65090_fet_get_enable(struct udevice *dev) { struct udevice *pmic = dev_get_parent(dev); int ret, fet_id;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/rk8xx.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/power/regulator/rk8xx.c b/drivers/power/regulator/rk8xx.c index c1ece96..3dc15e4 100644 --- a/drivers/power/regulator/rk8xx.c +++ b/drivers/power/regulator/rk8xx.c @@ -164,7 +164,7 @@ static int buck_set_enable(struct udevice *dev, bool enable) return _buck_set_enable(dev->parent, buck, enable); }
-static bool buck_get_enable(struct udevice *dev) +static int buck_get_enable(struct udevice *dev) { int buck = dev->driver_data - 1; int ret; @@ -223,7 +223,7 @@ static int ldo_set_enable(struct udevice *dev, bool enable) enable ? mask : 0); }
-static bool ldo_get_enable(struct udevice *dev) +static int ldo_get_enable(struct udevice *dev) { int ldo = dev->driver_data - 1; int ret; @@ -249,7 +249,7 @@ static int switch_set_enable(struct udevice *dev, bool enable) enable ? mask : 0); }
-static bool switch_get_enable(struct udevice *dev) +static int switch_get_enable(struct udevice *dev) { int sw = dev->driver_data - 1; int ret;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/sandbox.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/sandbox.c b/drivers/power/regulator/sandbox.c index 2cca579..06c09fd 100644 --- a/drivers/power/regulator/sandbox.c +++ b/drivers/power/regulator/sandbox.c @@ -234,7 +234,7 @@ static int buck_set_current(struct udevice *dev, int uA) buck_current_range, uA); }
-static bool buck_get_enable(struct udevice *dev) +static int buck_get_enable(struct udevice *dev) { if (out_get_mode(dev) == BUCK_OM_OFF) return false; @@ -310,7 +310,7 @@ static int ldo_set_current(struct udevice *dev, int uA) ldo_current_range, uA); }
-static bool ldo_get_enable(struct udevice *dev) +static int ldo_get_enable(struct udevice *dev) { if (out_get_mode(dev) == LDO_OM_OFF) return false;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/s5m8767.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/s5m8767.c b/drivers/power/regulator/s5m8767.c index 93a3c94..871da12 100644 --- a/drivers/power/regulator/s5m8767.c +++ b/drivers/power/regulator/s5m8767.c @@ -186,7 +186,7 @@ static int reg_set_enable(struct udevice *dev, const struct s5m8767_para *param, return ret; }
-static bool ldo_get_enable(struct udevice *dev) +static int ldo_get_enable(struct udevice *dev) { int ldo = dev->driver_data;
@@ -226,7 +226,7 @@ static int buck_set_value(struct udevice *dev, int uv) return reg_set_value(dev, &buck_param[buck], uv); }
-static bool buck_get_enable(struct udevice *dev) +static int buck_get_enable(struct udevice *dev) { int buck = dev->driver_data;
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/lp873x_regulator.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/lp873x_regulator.c b/drivers/power/regulator/lp873x_regulator.c index dcb19ff..11371a7 100644 --- a/drivers/power/regulator/lp873x_regulator.c +++ b/drivers/power/regulator/lp873x_regulator.c @@ -256,7 +256,7 @@ static int ldo_set_value(struct udevice *dev, int uV) return lp873x_ldo_val(dev, PMIC_OP_SET, &uV); }
-static bool ldo_get_enable(struct udevice *dev) +static int ldo_get_enable(struct udevice *dev) { bool enable = false; int ret; @@ -310,7 +310,7 @@ static int buck_set_value(struct udevice *dev, int uV) return lp873x_buck_val(dev, PMIC_OP_SET, &uV); }
Signed-off-by: Keerthy j-keerthy@ti.com --- drivers/power/regulator/lp87565_regulator.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/lp87565_regulator.c b/drivers/power/regulator/lp87565_regulator.c index 2a0b8ca..d908f6d 100644 --- a/drivers/power/regulator/lp87565_regulator.c +++ b/drivers/power/regulator/lp87565_regulator.c @@ -166,7 +166,7 @@ static int buck_set_value(struct udevice *dev, int uV) return lp87565_buck_val(dev, PMIC_OP_SET, &uV); }
Jaehoon,
Are you planning to pull this series?
Regards, Keerthy
Compile tested.
Hi Keerthy,
Jaehoon,
Sorry for late..I will review the pending patches on Tomorrow. After it, I will pull these.
Sorry again.
Best Regards, Jaehoon Chung
Regards, Keerthy
Compile tested.
Compile tested.
Applied to u-boot-mmc for pmic. Thanks!
Jaehoon Chung
Keerthy
