[U-Boot] uboot and ZFS
Sorry if I am posting some kind of FAQ here,
I recently picked up a Cubox (arm) which uses uboot. Added ZFS to Linux and made it have a ZFS root filesystem. The only drawback is the small boot partition of ext2/fat to read uImage and initrd.
So I am curious about adding ZFS support to uboot. Looking at the sources http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=tree in particular, the ext2 work, I see it was once imported from GRUB.
Comparing that with https://github.com/pendor/grub-zfs/tree/master/grub-core/fs/zfs which is a fork for ZFS support to GRUB.
At first glance, it would suggest that it should be feasible to add ZFS to uboot. But since I only have 'usage-level knowledge' of both boot systems, I am unaware of any show-stoppers.
Perhaps memory/object-size is an issue? The ext2 code is some ~1100 lines in uboot, but ZFS is 2700 lines in GRUB. Or any of a thousand other issues I am unaware about.
Anyone already attempted such a project? Any resources available for such porting? Will I even be able to run my own version of uboot on the Cubox?
Lund
Dear Jorgen,
Don't worry - AFAICT thisis the first time ZFS came up here.
Technically it should be no unsolvable problem to add ZFS support to U-Boot. However, there are the same licensing issues that prevent ZFS to be included with the Linux kernel; see http://zfsonlinux.org/faq.html#WhatAboutTheLicensingIssue
Like Linux, U-Boot is released under GPL (v2+), which is not compatible with the Sun CDDL.
Dear Jorgen Lundman,
Oh please study this and submit a patch, I believe at least Pavel (CCed) would be glad to see it in :-)
Well the porting might be quite a long run indeed, but basic booting from this should not be that hard. Besides the code would be fairy separate, so it should be OK.
I don't know, sorry.
Lund
Best regards, Marek Vasut
I took the existing CuBox u-boot, and compiled. Then found the EXT4 patches done by Siemens, and practised merging that in, compiling, and flashing the cubox. I can now boot EXT4. So that is encouraging.
Looking at GRUB zfs, it defines similar functions, namely open(), mount(), read(), close() and list(). So perhaps I can get something done. Is there quicker ways to test uboot than to flash the hardware every time?
What is the general patch acceptance around, I see ext4 wasn't accepted, what are the chances my patches would be?
Lund
Samsung! My bad, credits where due!
If you correctly skip the HW init, you can try booting u-boot from u-boot ... (now, WD will hate me for bringing this up :-) ). It's possible, but unsupported operation. You might need to do some research on this matter :-)
Why wasn't ext4 accepted?
Lund
I was thinking more along the lines of; Since I am testing a filesystem driver, to have a small test binary I can run and just feed a patch to (be it block device, or raw file) to test it can traverse, and read the contents.
But it would not be so bad to simulate that with some #ifdefs I guess.
I have no idea. I found the patches back in Dec, and it is not in the repository. Although, I have patched it into my tree on github, it might help merging it into uboot. It does appear to work, whereas my zfs does not :)
CuBox>> zfsls usb 0:2 ** Bad partition - usb 0:2 ** CuBox>> zfsls usb 0:1 ** Bad partition - usb 0:1 ** CuBox>> zfsls usb 0:0 data abort pc : [<0063ea0c>] lr : [<0060eef0>] sp : 005ffe40 ip : 00000000 fp : 00000000 r10: 00000000 r9 : 00652a4c r8 : 005fffcc r7 : 00000000 r6 : 00000000 r5 : 007104b0 r4 : 006444a7 r3 : 00000000 r2 : 006f7b80 r1 : 00000000 r0 : ea000012 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
Dang :)
Lund
Am 07.05.2012 09:13, schrieb Jorgen Lundman:
You could use sandbox arch for this purpose and use an image of a zfs filesystem. You can then use your native toolchain to compile and debug u-boot.
Reagards Matthias
Dear Jorgen,
Did you miss my message of Wed, 02 May?
See http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/130638/focus=130671
Unfortunately there is no legal (license-conforming) way to include ZFS code into U-Boot and distribute it.
That means, there is no chance to get this added to mainline.
My apologies, I did mean to reply to that.
The reason the GRUB boot loader can only handle single/mirror device root pool (ie, no raidz) is because Sun did not want to commit "any more than they had to" to GRUB, which would force the source to GPL.
The source that was written by Sun, for GRUB, is indeed GPL license (version 2).
I do not see this as a problem, unless suddenly you do not accept GPL licenses. (like 95% of your existing sources). (2000 .c files out of 2412).
Please advice if this is this not acceptable to u-boot. It does not change that I want it, so I will simply have to maintain a fork.
Lund
Hi Jorgen Lundman,
Technically, U-Boot is GPLv2+ so GPLv2 only code _may_ not be accepted That is for Wolfgang to decide, but you have been warned :)
Regards,
Graeme
Naturally, he is king after all. There will be a thousand reasons to reject it, but hopefully not due to license.
I based my GITHUB after the CuBox fork of u-boot. I will leave it up to those guys to submit their patches separately.
My fork of u-boot is here:
** https://github.com/lundman/u-boot
To see only the change set for adding ZFS:
** https://github.com/lundman/u-boot/compare/zfs
Since I merged in EXT4 patches to get a feel for u-boot, they are here:
** https://github.com/lundman/u-boot/compare/ext4
Only minor strings changes of "ext2" -> "ext4", otherwise the Samsung patch V4 posted in here.
Lund
Useless sample output:
CuBox>> zfsls usb 0:2 /ROOT/@/ zfs reading label 0 at sector 0 (byte 0) ZFS Pool GUID: 8349310002080761692 (73deb535d9a3c75c) Label: GUID: 1229383784885 2426185 (aa9c7c635319edc9), txg: 1348, SPA v28, ashift: 9
ZPOOL label 'rpool'
zfs fsname = '/ROOT/' snapname='<NULL>' filename = '/' <DIR> lib <DIR> sbin <DIR> var <DIR> bin <DIR> dev <DIR> selinux <DIR> usr <DIR> root <DIR> home <DIR> srv <DIR> ttt <DIR> proc <DIR> tmp <DIR> mnt <DIR> etc <DIR> media <DIR> boot <DIR> opt <DIR> sys <DIR> .old-root <DIR> src rootfile.txt <DIR> rpool
CuBox>> zfsload usb 0:2 0x00200000 /ROOT/@/boot/uImage Loading file "/ROOT/@/boot/uImage" from usb device 0:2 usbda2 zfs reading label 0 at sector 0 (byte 0) ........... ZFS Pool GUID: 8349310002080761692 (73deb535d9a3c75c) Label: GUID: 12293837848852426185 (aa9c7c635319edc9), txg: 1348, SPA v28, ashift: 9 zfs endian set to little zfs fsname = '/ROOT/' snapname='<NULL>' filename = '/boot/uImage' 3623192 bytes read
CuBox>> bootm ## Booting kernel from Legacy Image at 00200000 ... Image Name: Linux-2.6.32.9-dove-5.4.2 Created: 2012-01-07 10:23:53 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3623128 Bytes = 3.5 MB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK
Starting kernel ...
[ 0.000000] Linux version 2.6.32.9-dove-5.4.2 (rabeeh@kossay-desktop) (gcc version 4.3.2 (sdk3.2rc1-ct-ng-1.4.1) ) #46 PREEMPT Sat Jan 7 12:23:38 IST 2012
I wonder ... Germany never was a kingdom, or am I wrong? :-) So maybe emperor* might be more fitting (it was empire I think)?
Yay, so the ext4 works for you? Why wasn't ext4 merged? Can you post the reasoning (maybe links to gmane or something?)
Thanks!
Lund
ZPOOL label 'rpool'
Starting kernel ...
* Not the star-wars kind :-)
I have no idea. I just needed ext4 support, and saw someone had done the hard work back in Dec. I took the patches and applied them.
I have been informed that ext4 can't read volumes over 1TB. I could take a look at fixing that too, if there is enough interest.
ZFS pools over 1TB appears to work.
Lund
Hi Jorgen Lundman,
I think there was still some question as to how the ext4 code was going to replace the ext2 code and be git-bisectable. I'm personally really looking forward to the ext4 code going mainline
I suppose the question would be how big the code change is versus how many people will actually benefit. If it result in a 'big' increase in .text or .data then it may need to be a compile time option (CONFIG_SYS_HUGE_EXT4 or something)
Regards,
Graeme
I was guess that the issue lies in that the sector offset is a signed 32bit int, and that is what goes wrong. I think it should make no size difference at all, but would take a while to track down all calls that pass them along.
participants (6)
Graeme Russ
Jorgen Lundman
Matthias Weißer
