[U-Boot] [PATCH 1/2] arm: socfpga: Fix typos in DT files (environmnet -> environment)
Fix a small typo in some of the SoCFPGA dts files that has spread via copy-and-paste.
Signed-off-by: Stefan Roese sr@denx.de Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- arch/arm/dts/socfpga_arria5_socdk.dts | 2 +- arch/arm/dts/socfpga_cyclone5_socdk.dts | 2 +- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/socfpga_arria5_socdk.dts b/arch/arm/dts/socfpga_arria5_socdk.dts index 9ac48a1..7265058 100644 --- a/arch/arm/dts/socfpga_arria5_socdk.dts +++ b/arch/arm/dts/socfpga_arria5_socdk.dts @@ -21,7 +21,7 @@ };
aliases { - /* this allow the ethaddr uboot environmnet variable contents + /* this allow the ethaddr uboot environment variable contents * to be added to the gmac1 device tree blob. */ ethernet0 = &gmac1; diff --git a/arch/arm/dts/socfpga_cyclone5_socdk.dts b/arch/arm/dts/socfpga_cyclone5_socdk.dts index da13435..d4df1a1 100644 --- a/arch/arm/dts/socfpga_cyclone5_socdk.dts +++ b/arch/arm/dts/socfpga_cyclone5_socdk.dts @@ -21,7 +21,7 @@ };
aliases { - /* this allow the ethaddr uboot environmnet variable contents + /* this allow the ethaddr uboot environment variable contents * to be added to the gmac1 device tree blob. */ ethernet0 = &gmac1; diff --git a/arch/arm/dts/socfpga_cyclone5_sr1500.dts b/arch/arm/dts/socfpga_cyclone5_sr1500.dts index 32c6aad..739bbb7 100644 --- a/arch/arm/dts/socfpga_cyclone5_sr1500.dts +++ b/arch/arm/dts/socfpga_cyclone5_sr1500.dts @@ -16,7 +16,7 @@
aliases { /* - * This allows the ethaddr uboot environmnet variable + * This allows the ethaddr uboot environment variable * contents to be added to the gmac1 device tree blob. */ ethernet0 = &gmac1;
This enables full ethernet usage, including U-Boot to write the board specific MAC address (ethaddr) into the DT blob before passing it to Linux.
Without this, the ethaddr is not detected in U-Boot at all, resulting in this error upon bootup:
... Model: EBV SOCrates Net: Error: ethernet@ff702000 address not set. No ethernet found.
Signed-off-by: Stefan Roese sr@denx.de Cc: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- arch/arm/dts/socfpga_cyclone5_socrates.dts | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index 591d96c..d2ab3b3 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -15,6 +15,11 @@ };
aliases { + /* + * This allows the ethaddr uboot environment variable + * contents to be added to the gmac1 device tree blob. + */ + ethernet0 = &gmac1; udc0 = &usb1; };
Thanks!
Acked-by: Marek Vasut marex@denx.de
aliases {
udc0 = &usb1; };ethernet0 = &gmac1;
aliases {
- to be added to the gmac1 device tree blob.
aliases {
aliases { /*
- contents to be added to the gmac1 device tree blob.
Stefan Roese
