[U-Boot] [PATCH] TQM8xx: Fix CFI flash driver support for all TQM8xx based boards
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver was not removed yet.
Signed-off-by: Wolfgang Denk wd@denx.de --- board/tqc/tqm8xx/Makefile | 2 +- board/tqc/tqm8xx/flash.c | 834 -------------------------------------------- board/tqc/tqm8xx/tqm8xx.c | 123 +++++-- include/configs/FPS850L.h | 2 + include/configs/FPS860L.h | 2 + include/configs/HMI10.h | 2 +- include/configs/SM850.h | 17 +- include/configs/TQM823L.h | 2 + include/configs/TQM823M.h | 2 + include/configs/TQM850L.h | 2 + include/configs/TQM850M.h | 2 + include/configs/TQM855L.h | 2 + include/configs/TQM855M.h | 2 + include/configs/TQM860L.h | 2 + include/configs/TQM860M.h | 4 +- include/configs/TQM862L.h | 2 + include/configs/TQM862M.h | 4 +- include/configs/TQM866M.h | 4 +- include/configs/virtlab2.h | 2 + 19 files changed, 136 insertions(+), 876 deletions(-) delete mode 100644 board/tqc/tqm8xx/flash.c
diff --git a/board/tqc/tqm8xx/Makefile b/board/tqc/tqm8xx/Makefile index b48934b..280982d 100644 --- a/board/tqc/tqm8xx/Makefile +++ b/board/tqc/tqm8xx/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS = $(BOARD).o flash.o load_sernum_ethaddr.o +COBJS = $(BOARD).o load_sernum_ethaddr.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/tqc/tqm8xx/flash.c b/board/tqc/tqm8xx/flash.c deleted file mode 100644 index ca35e91..0000000 --- a/board/tqc/tqm8xx/flash.c +++ /dev/null @@ -1,834 +0,0 @@ -/* - * (C) Copyright 2000-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#if 0 -#define DEBUG -#endif - -#include <common.h> -#include <mpc8xx.h> -#include <environment.h> - -#include <asm/processor.h> - -DECLARE_GLOBAL_DATA_PTR; - -#if !defined(CONFIG_FLASH_CFI_DRIVER) /* do not use if CFI driver is configured */ - -#if defined(CONFIG_TQM8xxL) && !defined(CONFIG_TQM866M) \ - && !defined(CONFIG_TQM885D) -# ifndef CFG_OR_TIMING_FLASH_AT_50MHZ -# define CFG_OR_TIMING_FLASH_AT_50MHZ (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_2_CLK | OR_EHTR | OR_BI) -# endif -#endif /* CONFIG_TQM8xxL/M, !TQM866M, !TQM885D */ - -#ifndef CONFIG_ENV_ADDR -#define CONFIG_ENV_ADDR (CFG_FLASH_BASE + CONFIG_ENV_OFFSET) -#endif - -flash_info_t flash_info[CFG_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CFG_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size_b0, size_b1; - int i; - -#ifdef CFG_OR_TIMING_FLASH_AT_50MHZ - int scy, trlx, flash_or_timing, clk_diff; - - scy = (CFG_OR_TIMING_FLASH_AT_50MHZ & OR_SCY_MSK) >> 4; - if (CFG_OR_TIMING_FLASH_AT_50MHZ & OR_TRLX) { - trlx = OR_TRLX; - scy *= 2; - } else - trlx = 0; - - /* We assume that each 10MHz of bus clock require 1-clk SCY - * adjustment. - */ - clk_diff = (gd->bus_clk / 1000000) - 50; - - /* We need proper rounding here. This is what the "+5" and "-5" - * are here for. - */ - if (clk_diff >= 0) - scy += (clk_diff + 5) / 10; - else - scy += (clk_diff - 5) / 10; - - /* For bus frequencies above 50MHz, we want to use relaxed timing - * (OR_TRLX). - */ - if (gd->bus_clk >= 50000000) - trlx = OR_TRLX; - else - trlx = 0; - - if (trlx) - scy /= 2; - - if (scy > 0xf) - scy = 0xf; - if (scy < 1) - scy = 1; - - flash_or_timing = (scy << 4) | trlx | - (CFG_OR_TIMING_FLASH_AT_50MHZ & ~(OR_TRLX | OR_SCY_MSK)); -#endif - /* Init: no FLASHes known */ - for (i=0; i<CFG_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - debug ("\n## Get flash bank 1 size @ 0x%08x\n",FLASH_BASE0_PRELIM); - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - debug ("## Get flash bank 2 size @ 0x%08x\n",FLASH_BASE1_PRELIM); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - size_b1 = flash_get_size((vu_long *)FLASH_BASE1_PRELIM, &flash_info[1]); - - debug ("## Prelim. Flash bank sizes: %08lx + 0x%08lx\n",size_b0,size_b1); - - if (size_b1 > size_b0) { - printf ("## ERROR: " - "Bank 1 (0x%08lx = %ld MB) > Bank 0 (0x%08lx = %ld MB)\n", - size_b1, size_b1<<20, - size_b0, size_b0<<20 - ); - flash_info[0].flash_id = FLASH_UNKNOWN; - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[0].sector_count = -1; - flash_info[1].sector_count = -1; - flash_info[0].size = 0; - flash_info[1].size = 0; - return (0); - } - - debug ("## Before remap: " - "BR0: 0x%08x OR0: 0x%08x " - "BR1: 0x%08x OR1: 0x%08x\n", - memctl->memc_br0, memctl->memc_or0, - memctl->memc_br1, memctl->memc_or1); - - /* Remap FLASH according to real size */ -#ifndef CFG_OR_TIMING_FLASH_AT_50MHZ - memctl->memc_or0 = CFG_OR_TIMING_FLASH | (-size_b0 & OR_AM_MSK); -#else - memctl->memc_or0 = flash_or_timing | (-size_b0 & OR_AM_MSK); -#endif - memctl->memc_br0 = (CFG_FLASH_BASE & BR_BA_MSK) | BR_MS_GPCM | BR_V; - - debug ("## BR0: 0x%08x OR0: 0x%08x\n", - memctl->memc_br0, memctl->memc_or0); - - /* Re-do sizing to get full correct info */ - size_b0 = flash_get_size((vu_long *)CFG_FLASH_BASE, &flash_info[0]); - -#if CFG_MONITOR_BASE >= CFG_FLASH_BASE - /* monitor protection ON by default */ - debug ("Protect monitor: %08lx ... %08lx\n", - (ulong)CFG_MONITOR_BASE, - (ulong)CFG_MONITOR_BASE + monitor_flash_len - 1); - - flash_protect(FLAG_PROTECT_SET, - CFG_MONITOR_BASE, - CFG_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ -# ifdef CONFIG_ENV_ADDR_REDUND - debug ("Protect primary environment: %08lx ... %08lx\n", - (ulong)CONFIG_ENV_ADDR, - (ulong)CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1); -# else - debug ("Protect environment: %08lx ... %08lx\n", - (ulong)CONFIG_ENV_ADDR, - (ulong)CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1); -# endif - - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_ADDR_REDUND - debug ("Protect redundand environment: %08lx ... %08lx\n", - (ulong)CONFIG_ENV_ADDR_REDUND, - (ulong)CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1); - - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR_REDUND, - CONFIG_ENV_ADDR_REDUND + CONFIG_ENV_SECT_SIZE - 1, - &flash_info[0]); -#endif - - if (size_b1) { -#ifndef CFG_OR_TIMING_FLASH_AT_50MHZ - memctl->memc_or1 = CFG_OR_TIMING_FLASH | (-size_b1 & 0xFFFF8000); -#else - memctl->memc_or1 = flash_or_timing | (-size_b1 & 0xFFFF8000); -#endif - memctl->memc_br1 = ((CFG_FLASH_BASE + size_b0) & BR_BA_MSK) | - BR_MS_GPCM | BR_V; - - debug ("## BR1: 0x%08x OR1: 0x%08x\n", - memctl->memc_br1, memctl->memc_or1); - - /* Re-do sizing to get full correct info */ - size_b1 = flash_get_size((vu_long *)(CFG_FLASH_BASE + size_b0), - &flash_info[1]); - -#if CFG_MONITOR_BASE >= CFG_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CFG_MONITOR_BASE, - CFG_MONITOR_BASE+monitor_flash_len-1, - &flash_info[1]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR+CONFIG_ENV_SIZE-1, - &flash_info[1]); -#endif - } else { - memctl->memc_br1 = 0; /* invalidate bank */ - - flash_info[1].flash_id = FLASH_UNKNOWN; - flash_info[1].sector_count = -1; - flash_info[1].size = 0; - - debug ("## DISABLE BR1: 0x%08x OR1: 0x%08x\n", - memctl->memc_br1, memctl->memc_or1); - } - - debug ("## Final Flash bank sizes: %08lx + 0x%08lx\n",size_b0,size_b1); - - flash_info[0].size = size_b0; - flash_info[1].size = size_b1; - - return (size_b0 + size_b1); -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { -#ifdef CONFIG_TQM8xxM /* mirror bit flash */ - case FLASH_AMLV128U: printf ("AM29LV128ML (128Mbit, uniform sector size)\n"); - break; - case FLASH_AMLV320U: printf ("AM29LV320ML (32Mbit, uniform sector size)\n"); - break; - case FLASH_AMLV640U: printf ("AM29LV640ML (64Mbit, uniform sector size)\n"); - break; - case FLASH_AMLV320B: printf ("AM29LV320MB (32Mbit, bottom boot sect)\n"); - break; -# else /* ! TQM8xxM */ - case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: printf ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: printf ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; -#endif /* TQM8xxM */ - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AMDL163B: printf ("AM29DL163B (16 Mbit, bottom boot sect)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - ulong value; - ulong base = (ulong)addr; - - /* Write auto select command: read Manufacturer ID */ - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00900090; - - value = addr[0]; - - debug ("Manuf. ID @ 0x%08lx: 0x%08lx\n", (ulong)addr, value); - - switch (value) { - case AMD_MANUFACT: - debug ("Manufacturer: AMD\n"); - info->flash_id = FLASH_MAN_AMD; - break; - case FUJ_MANUFACT: - debug ("Manufacturer: FUJITSU\n"); - info->flash_id = FLASH_MAN_FUJ; - break; - default: - debug ("Manufacturer: *** unknown ***\n"); - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = addr[1]; /* device ID */ - - debug ("Device ID @ 0x%08lx: 0x%08lx\n", (ulong)(&addr[1]), value); - - switch (value) { -#ifdef CONFIG_TQM8xxM /* mirror bit flash */ - case AMD_ID_MIRROR: - debug ("Mirror Bit flash: addr[14] = %08lX addr[15] = %08lX\n", - addr[14], addr[15]); - /* Special case for AMLV320MH/L */ - if ((addr[14] & 0x00ff00ff) == 0x001d001d && - (addr[15] & 0x00ff00ff) == 0x00000000) { - debug ("Chip: AMLV320MH/L\n"); - info->flash_id += FLASH_AMLV320U; - info->sector_count = 64; - info->size = 0x00800000; /* => 8 MB */ - break; - } - switch(addr[14]) { - case AMD_ID_LV128U_2: - if (addr[15] != AMD_ID_LV128U_3) { - debug ("Chip: AMLV128U -> unknown\n"); - info->flash_id = FLASH_UNKNOWN; - } else { - debug ("Chip: AMLV128U\n"); - info->flash_id += FLASH_AMLV128U; - info->sector_count = 256; - info->size = 0x02000000; - } - break; /* => 32 MB */ - case AMD_ID_LV640U_2: - if (addr[15] != AMD_ID_LV640U_3) { - debug ("Chip: AMLV640U -> unknown\n"); - info->flash_id = FLASH_UNKNOWN; - } else { - debug ("Chip: AMLV640U\n"); - info->flash_id += FLASH_AMLV640U; - info->sector_count = 128; - info->size = 0x01000000; - } - break; /* => 16 MB */ - case AMD_ID_LV320B_2: - if (addr[15] != AMD_ID_LV320B_3) { - debug ("Chip: AMLV320B -> unknown\n"); - info->flash_id = FLASH_UNKNOWN; - } else { - debug ("Chip: AMLV320B\n"); - info->flash_id += FLASH_AMLV320B; - info->sector_count = 71; - info->size = 0x00800000; - } - break; /* => 8 MB */ - default: - debug ("Chip: *** unknown ***\n"); - info->flash_id = FLASH_UNKNOWN; - break; - } - break; -# else /* ! TQM8xxM */ - case AMD_ID_LV400T: - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case AMD_ID_LV400B: - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case AMD_ID_LV800T: - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case AMD_ID_LV800B: - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case AMD_ID_LV320T: - info->flash_id += FLASH_AM320T; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ - - case AMD_ID_LV320B: - info->flash_id += FLASH_AM320B; - info->sector_count = 71; - info->size = 0x00800000; - break; /* => 8 MB */ -#endif /* TQM8xxM */ - - case AMD_ID_LV160T: - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case AMD_ID_LV160B: - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case AMD_ID_DL163B: - info->flash_id += FLASH_AMDL163B; - info->sector_count = 39; - info->size = 0x00400000; - break; /* => 4 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - } - - /* set up sector start address table */ - switch (value) { -#ifdef CONFIG_TQM8xxM /* mirror bit flash */ - case AMD_ID_MIRROR: - switch (info->flash_id & FLASH_TYPEMASK) { - /* only known types here - no default */ - case FLASH_AMLV128U: - case FLASH_AMLV640U: - case FLASH_AMLV320U: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - base += 0x20000; - } - break; - case FLASH_AMLV320B: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - /* - * The first 8 sectors are 8 kB, - * all the other ones are 64 kB - */ - base += (i < 8) - ? 2 * ( 8 << 10) - : 2 * (64 << 10); - } - break; - } - break; -# else /* ! TQM8xxM */ - case AMD_ID_LV400B: - case AMD_ID_LV800B: - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00020000) - 0x00060000; - } - break; - case AMD_ID_LV400T: - case AMD_ID_LV800T: - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - break; - case AMD_ID_LV320B: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - /* - * The first 8 sectors are 8 kB, - * all the other ones are 64 kB - */ - base += (i < 8) - ? 2 * ( 8 << 10) - : 2 * (64 << 10); - } - break; - case AMD_ID_LV320T: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - /* - * The last 8 sectors are 8 kB, - * all the other ones are 64 kB - */ - base += (i < (info->sector_count - 8)) - ? 2 * (64 << 10) - : 2 * ( 8 << 10); - } - break; -#endif /* TQM8xxM */ - case AMD_ID_LV160B: - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00008000; - info->start[2] = base + 0x0000C000; - info->start[3] = base + 0x00010000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00020000) - 0x00060000; - } - break; - case AMD_ID_LV160T: - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00008000; - info->start[i--] = base + info->size - 0x0000C000; - info->start[i--] = base + info->size - 0x00010000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00020000; - } - break; - case AMD_ID_DL163B: - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base; - /* - * The first 8 sectors are 8 kB, - * all the other ones are 64 kB - */ - base += (i < 8) - ? 2 * ( 8 << 10) - : 2 * (64 << 10); - } - break; - default: - return (0); - break; - } - -#if 0 - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - addr = (volatile unsigned long *)(info->start[i]); - info->protect[i] = addr[2] & 1; - } -#endif - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - addr = (volatile unsigned long *)info->start[0]; - - *addr = 0x00F000F0; /* reset bank */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - vu_long *addr = (vu_long*)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - debug ("flash_erase: first: %d last: %d\n", s_first, s_last); - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > FLASH_AMD_COMP)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00800080; - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_long*)(info->start[sect]); - addr[0] = 0x00300030; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (vu_long*)(info->start[l_sect]); - while ((addr[0] & 0x00800080) != 0x00800080) { - if ((now = get_timer(start)) > CFG_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - -DONE: - /* reset to read mode */ - addr = (volatile unsigned long *)info->start[0]; - addr[0] = 0x00F000F0; /* reset bank */ - - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - vu_long *addr = (vu_long*)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_long *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0555] = 0x00AA00AA; - addr[0x02AA] = 0x00550055; - addr[0x0555] = 0x00A000A0; - - *((vu_long *)dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_long *)dest) & 0x00800080) != (data & 0x00800080)) { - if (get_timer(start) > CFG_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} - -/*----------------------------------------------------------------------- - */ - -#endif /* !defined(CONFIG_FLASH_CFI_DRIVER) */ diff --git a/board/tqc/tqm8xx/tqm8xx.c b/board/tqc/tqm8xx/tqm8xx.c index 96b6103..59bbdbc 100644 --- a/board/tqc/tqm8xx/tqm8xx.c +++ b/board/tqc/tqm8xx/tqm8xx.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2006 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -21,16 +21,14 @@ * MA 02111-1307 USA */
-#if 0 -#define DEBUG -#endif - #include <common.h> #include <mpc8xx.h> #ifdef CONFIG_PS2MULT #include <ps2mult.h> #endif
+extern flash_info_t flash_info[]; /* FLASH chips info */ + DECLARE_GLOBAL_DATA_PTR;
static long int dram_size (long int, long int *, long int); @@ -451,24 +449,107 @@ int board_early_init_r (void)
#endif /* CONFIG_PS2MULT */
-/* ---------------------------------------------------------------------------- */ -/* HMI10 specific stuff */ -/* ---------------------------------------------------------------------------- */ -#ifdef CONFIG_HMI10
+#ifdef CONFIG_MISC_INIT_R int misc_init_r (void) { -# ifdef CONFIG_IDE_LED - volatile immap_t *immap = (immap_t *) CFG_IMMR; + volatile immap_t *immap = (immap_t *)CFG_IMMR; + volatile memctl8xx_t *memctl = &immap->im_memctl; + +#ifdef CFG_OR_TIMING_FLASH_AT_50MHZ + int scy, trlx, flash_or_timing, clk_diff; + + scy = (CFG_OR_TIMING_FLASH_AT_50MHZ & OR_SCY_MSK) >> 4; + if (CFG_OR_TIMING_FLASH_AT_50MHZ & OR_TRLX) { + trlx = OR_TRLX; + scy *= 2; + } else + trlx = 0; + + /* + * We assume that each 10MHz of bus clock require 1-clk SCY + * adjustment. + */ + clk_diff = (gd->bus_clk / 1000000) - 50; + + /* + * We need proper rounding here. This is what the "+5" and "-5" + * are here for. + */ + if (clk_diff >= 0) + scy += (clk_diff + 5) / 10; + else + scy += (clk_diff - 5) / 10; + + /* + * For bus frequencies above 50MHz, we want to use relaxed timing + * (OR_TRLX). + */ + if (gd->bus_clk >= 50000000) + trlx = OR_TRLX; + else + trlx = 0; + + if (trlx) + scy /= 2; + + if (scy > 0xf) + scy = 0xf; + if (scy < 1) + scy = 1; + + flash_or_timing = (scy << 4) | trlx | + (CFG_OR_TIMING_FLASH_AT_50MHZ & ~(OR_TRLX | OR_SCY_MSK)); + + memctl->memc_or0 = flash_or_timing | (-flash_info[0].size & OR_AM_MSK); +#else + memctl->memc_or0 = CFG_OR_TIMING_FLASH | (-flash_info[0].size & OR_AM_MSK); +#endif + memctl->memc_br0 = (CFG_FLASH_BASE & BR_BA_MSK) | BR_MS_GPCM | BR_V; + + debug ("## BR0: 0x%08x OR0: 0x%08x\n", + memctl->memc_br0, memctl->memc_or0);
+ if (flash_info[1].size) { +#ifdef CFG_OR_TIMING_FLASH_AT_50MHZ + memctl->memc_or1 = flash_or_timing | + (-flash_info[1].size & 0xFFFF8000); +#else + memctl->memc_or1 = CFG_OR_TIMING_FLASH | + (-flash_info[1].size & 0xFFFF8000); +#endif + memctl->memc_br1 = ((CFG_FLASH_BASE + flash_info[0].size) & BR_BA_MSK) | + BR_MS_GPCM | BR_V; + + debug ("## BR1: 0x%08x OR1: 0x%08x\n", + memctl->memc_br1, memctl->memc_or1); + } else { + memctl->memc_br1 = 0; /* invalidate bank */ + + debug ("## DISABLE BR1: 0x%08x OR1: 0x%08x\n", + memctl->memc_br1, memctl->memc_or1); + } + +# ifdef CONFIG_IDE_LED /* Configure PA15 as output port */ immap->im_ioport.iop_padir |= 0x0001; immap->im_ioport.iop_paodr |= 0x0001; immap->im_ioport.iop_papar &= ~0x0001; immap->im_ioport.iop_padat &= ~0x0001; /* turn it off */ # endif + +#ifdef CONFIG_NSCU + /* wake up ethernet module */ + immap->im_ioport.iop_pcpar &= ~0x0004; /* GPIO pin */ + immap->im_ioport.iop_pcdir |= 0x0004; /* output */ + immap->im_ioport.iop_pcso &= ~0x0004; /* for clarity */ + immap->im_ioport.iop_pcdat |= 0x0004; /* enable */ +#endif /* CONFIG_NSCU */ + return (0); } +#endif /* CONFIG_MISC_INIT_R */ +
# ifdef CONFIG_IDE_LED void ide_led (uchar led, uchar status) @@ -483,26 +564,6 @@ void ide_led (uchar led, uchar status) } } # endif -#endif /* CONFIG_HMI10 */ - -/* ---------------------------------------------------------------------------- */ -/* NSCU specific stuff */ -/* ---------------------------------------------------------------------------- */ -#ifdef CONFIG_NSCU - -int misc_init_r (void) -{ - volatile immap_t *immr = (immap_t *) CFG_IMMR; - - /* wake up ethernet module */ - immr->im_ioport.iop_pcpar &= ~0x0004; /* GPIO pin */ - immr->im_ioport.iop_pcdir |= 0x0004; /* output */ - immr->im_ioport.iop_pcso &= ~0x0004; /* for clarity */ - immr->im_ioport.iop_pcdat |= 0x0004; /* enable */ - - return (0); -} -#endif /* CONFIG_NSCU */
/* ---------------------------------------------------------------------------- */ /* TK885D specific initializaion */ diff --git a/include/configs/FPS850L.h b/include/configs/FPS850L.h index dd8051d..c9d6c91 100644 --- a/include/configs/FPS850L.h +++ b/include/configs/FPS850L.h @@ -211,6 +211,8 @@
#define CFG_USE_PPCENV /* Environment embedded in sect .ppcenv */
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/FPS860L.h b/include/configs/FPS860L.h index 1af28b3..bf20a0d 100644 --- a/include/configs/FPS860L.h +++ b/include/configs/FPS860L.h @@ -211,6 +211,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/HMI10.h b/include/configs/HMI10.h index 807781c..c58cb8c 100644 --- a/include/configs/HMI10.h +++ b/include/configs/HMI10.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2005 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this diff --git a/include/configs/SM850.h b/include/configs/SM850.h index d30c7bc..c896b58 100644 --- a/include/configs/SM850.h +++ b/include/configs/SM850.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -157,16 +157,21 @@ /*----------------------------------------------------------------------- * FLASH organization */ +/* use CFI flash driver */ +#define CFG_FLASH_CFI 1 /* Flash is CFI conformant */ +#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ +#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE, CFG_FLASH_BASE+flash_info[0].size } +#define CFG_FLASH_EMPTY_INFO +#define CFG_FLASH_USE_BUFFER_WRITE 1 #define CFG_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 67 /* max number of sectors on one chip */ - -#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +#define CFG_MAX_FLASH_SECT 71 /* max number of sectors on one chip */
#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ +#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ #define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Hardware Information Block */ diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 6311902..dc4582f 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -225,6 +225,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 53272e1..7ea7342 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -221,6 +221,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 812cea1..473c390 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -210,6 +210,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 512c55d..4de5a33 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -210,6 +210,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index 36e2fbf..2ba94c8 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -215,6 +215,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 2da1f3a..7699d51 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -250,6 +250,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index 87462a5..23d0dd6 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -214,6 +214,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 9dc8745..e8d2ec4 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2005 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -215,6 +215,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index c039e9d..74c815b 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -218,6 +218,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index cc5ee6d..a5fc38d 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2005 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -219,6 +219,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index bf3bbb2..9e14d99 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2005 + * (C) Copyright 2000-2008 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -259,6 +259,8 @@
+#define CONFIG_MISC_INIT_R /* Make sure to remap flashes correctly */ + /*----------------------------------------------------------------------- * Dynamic MTD partition support */ diff --git a/include/configs/virtlab2.h b/include/configs/virtlab2.h index 10dbed9..f3f43c3 100644 --- a/include/configs/virtlab2.h +++ b/include/configs/virtlab2.h @@ -219,6 +219,8 @@
Hi Wolfgang,
Please find some nitpicking comments below.
<snip>
- (C) Copyright 2000-2006
- (C) Copyright 2000-2008
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
@@ -21,16 +21,14 @@
- MA 02111-1307 USA
trlx = OR_TRLX;
scy *= 2;
- } else
trlx = 0;
* adjustment.
Indentation looks wrong here.
* are here for.
- else
And here. And other places below too.
Best regards, Stefan
Dear Stefan Roese,
In message 200809170611.45914.sr@denx.de you wrote: ...
* adjustment.
Indeed. I didn't see this when copy&pasting the code from the code from the old flash.c driver. Will send a separate cleanup patch.
Thanks for pointing out.
Stefan Roese
