[U-Boot] [PATCH v2 0/3] efi_loader: correct media device paths
For each disk we need partition device path with partion number 0. The device node texts should match the UEFI spec.
v2: Do not generate optional device path with partion number 0 for the whole block device.
Heinrich Schuchardt (3): efi_loader: correctly determine if an MMC device is an SD-card efi_loader: correctly setup device paths for block devices efi_loader: correct DeviceNodeToText for media types
lib/efi_loader/efi_device_path.c | 35 +++++++++++++++++++++++++------- lib/efi_loader/efi_device_path_to_text.c | 30 +++++++++++++++++---------- lib/efi_loader/efi_disk.c | 7 +++++-- 3 files changed, 52 insertions(+), 20 deletions(-)
The SD cards and eMMC devices have different device nodes. The current coding interpretes all MMC devices as eMMC.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 no change --- lib/efi_loader/efi_device_path.c | 24 +++++++++++++++++++++--- 1 file changed, 21 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index b4e2f933cb..42fe6e1185 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -36,6 +36,24 @@ static const struct efi_device_path_vendor ROOT = { .guid = U_BOOT_GUID, };
+#if defined(CONFIG_DM_MMC) && defined(CONFIG_MMC) +/* + * Determine if an MMC device is an SD card. + * + * @desc block device descriptor + * @return true if the device is an SD card + */ +static bool is_sd(struct blk_desc *desc) +{ + struct mmc *mmc = find_mmc_device(desc->devnum); + + if (!mmc) + return false; + + return IS_SD(mmc) != 0U; +} +#endif + static void *dp_alloc(size_t sz) { void *buf; @@ -298,9 +316,9 @@ static void *dp_fill(void *buf, struct udevice *dev) struct blk_desc *desc = mmc_get_blk_desc(mmc);
sddp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; - sddp->dp.sub_type = (desc->if_type == IF_TYPE_MMC) ? - DEVICE_PATH_SUB_TYPE_MSG_MMC : - DEVICE_PATH_SUB_TYPE_MSG_SD; + sddp->dp.sub_type = is_sd(desc) ? + DEVICE_PATH_SUB_TYPE_MSG_SD : + DEVICE_PATH_SUB_TYPE_MSG_MMC; sddp->dp.length = sizeof(*sddp); sddp->slot_number = dev->seq;
According to the UEFI spec the numbering of partitions has to start with 1.
Partion number 0 is reserved for the optional device path for the complete block device.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 Do not generate optional device path with partion number 0. --- lib/efi_loader/efi_device_path.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 42fe6e1185..6461ea9abc 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -420,7 +420,7 @@ static void *dp_part_fill(void *buf, struct blk_desc *desc, int part) if (desc->part_type == PART_TYPE_ISO) { struct efi_device_path_cdrom_path *cddp = buf;
- cddp->boot_entry = part - 1; + cddp->boot_entry = part; cddp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; cddp->dp.sub_type = DEVICE_PATH_SUB_TYPE_CDROM_PATH; cddp->dp.length = sizeof(*cddp); @@ -434,7 +434,7 @@ static void *dp_part_fill(void *buf, struct blk_desc *desc, int part) hddp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; hddp->dp.sub_type = DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH; hddp->dp.length = sizeof(*hddp); - hddp->partition_number = part - 1; + hddp->partition_number = part; hddp->partition_start = info.start; hddp->partition_end = info.size; if (desc->part_type == PART_TYPE_EFI)
When converting device nodes and paths to text we should stick to the UEFI spec.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2 no change --- lib/efi_loader/efi_device_path_to_text.c | 30 +++++++++++++++++++----------- 1 file changed, 19 insertions(+), 11 deletions(-)
diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 7159c974d4..21c5678d20 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -90,7 +90,7 @@ static char *dp_msging(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_MSG_USB: { struct efi_device_path_usb *udp = (struct efi_device_path_usb *)dp; - s += sprintf(s, "Usb(0x%x,0x%x)", udp->parent_port_number, + s += sprintf(s, "USB(0x%x,0x%x)", udp->parent_port_number, udp->usb_interface); break; } @@ -124,10 +124,10 @@ static char *dp_msging(char *s, struct efi_device_path *dp) case DEVICE_PATH_SUB_TYPE_MSG_MMC: { const char *typename = (dp->sub_type == DEVICE_PATH_SUB_TYPE_MSG_SD) ? - "SDCard" : "MMC"; + "SD" : "eMMC"; struct efi_device_path_sd_mmc_path *sddp = (struct efi_device_path_sd_mmc_path *)dp; - s += sprintf(s, "%s(Slot%u)", typename, sddp->slot_number); + s += sprintf(s, "%s(%u)", typename, sddp->slot_number); break; } default: @@ -147,18 +147,26 @@ static char *dp_media(char *s, struct efi_device_path *dp)
switch (hddp->signature_type) { case SIG_TYPE_MBR: - s += sprintf(s, "HD(Part%d,Sig%08x)", - hddp->partition_number, - *(uint32_t *)sig); + s += sprintf( + s, "HD(%d,MBR,0x%08x,0x%llx,0x%llx)", + hddp->partition_number, + *(uint32_t *)sig, + (unsigned long long int)hddp->partition_start, + (unsigned long long int)hddp->partition_end); break; case SIG_TYPE_GUID: - s += sprintf(s, "HD(Part%d,Sig%pUl)", - hddp->partition_number, sig); + s += sprintf( + s, "HD(%d,GPT,%pUl,0x%llx,0x%llx)", + hddp->partition_number, sig, + (unsigned long long int)hddp->partition_start, + (unsigned long long int)hddp->partition_end); break; default: - s += sprintf(s, "HD(Part%d,MBRType=%02x,SigType=%02x)", - hddp->partition_number, hddp->partmap_type, - hddp->signature_type); + s += sprintf( + s, "HD(%d,0x%02x,0,0x%llx,0x%llx)", + hddp->partition_number, hddp->partmap_type, + (unsigned long long int)hddp->partition_start, + (unsigned long long int)hddp->partition_end); break; }
