[U-Boot] [PATCH 0/6] gpt: command: Add support for "gpt verify" command
Up till now "gpt" command was only able to write (i.e. restore) GPT partition on specified medium with information provided at "$partitions" env variable.
This patch series adds complementary feature - namely "gpt verify", which allows checking (at e.g. boot time) if previously created GPT layout is still correct.
This patch series clearly applies on top of u-boot/master: SHA1: cad04990715f7eaecd45196e84cf10e9e3248dae
It has been tested on Beaglebone Black development board (Sitara AM335x CPU).
Lukasz Majewski (6): gpt: command: Remove duplicated check for empty partition description gpt: command: cosmetic: Replace printf with puts gpt: doc: README: Update README entry for gpt verify extension gpt: doc: Update gpt command's help description gpt: part: Definition and declaration of GPT verification functions gpt: command: Extend gpt command to support GPT table verification
common/cmd_gpt.c | 106 ++++++++++++++++++++++++++++++++++++++----------------- disk/part_efi.c | 101 ++++++++++++++++++++++++++++++++++++++++++++++++++++ doc/README.gpt | 26 +++++++++++++- include/part.h | 35 ++++++++++++++++++ 4 files changed, 235 insertions(+), 33 deletions(-)
Exactly the same check is performed in set_gpt_info() function executed just after this check.
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- common/cmd_gpt.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index c56fe15..4da2de7 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -276,9 +276,6 @@ static int gpt_default(block_dev_desc_t *blk_dev_desc, const char *str_part) u8 part_count = 0; disk_partition_t *partitions = NULL;
- if (!str_part) - return -1; - /* fill partitions */ ret = set_gpt_info(blk_dev_desc, str_part, &str_disk_guid, &partitions, &part_count);
This code is not processing any data to serial console output and hence can be replaced with puts.
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- common/cmd_gpt.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 4da2de7..4c71125 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -281,11 +281,11 @@ static int gpt_default(block_dev_desc_t *blk_dev_desc, const char *str_part) &str_disk_guid, &partitions, &part_count); if (ret) { if (ret == -1) - printf("No partition list provided\n"); + puts("No partition list provided\n"); if (ret == -2) - printf("Missing disk guid\n"); + puts("Missing disk guid\n"); if ((ret == -3) || (ret == -4)) - printf("Partition list incomplete\n"); + puts("Partition list incomplete\n"); return -1; }
No, printf is fine, always. We went over this before and it's not a win to change things.
Hi Tom,
Ok, I see. Then I will drop this patch.
Best regards, Lukasz Majewski
./doc/README.gpt entry has been updated to explain usage of "gpt verify" command.
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- doc/README.gpt | 26 +++++++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/doc/README.gpt b/doc/README.gpt index 59fdeeb..9fe97b0 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -167,9 +167,33 @@ To restore GUID partition table one needs to:
2. Define 'CONFIG_EFI_PARTITION' and 'CONFIG_CMD_GPT'
-2. From u-boot prompt type: +3. From u-boot prompt type: gpt write mmc 0 $partitions
+Checking (validating) GPT partitions in U-Boot: +=============================================== + +Procedure is the same as above. The only change is at point 3. + +At u-boot prompt one needs to write: + gpt verify mmc 0 [$partitions] + +where [$partitions] is an optional parameter. + +When it is not provided, only basic checks based on CRC32 calculation for GPT +header and PTEs are performed. +When provided, additionally partition data - name, size and starting +offset (last two in LBA) - are compared with data defined in '$partitions' +environment variable. + +After running this command, return code is set to 0 if no errors found in +on non-volatile medium stored GPT. + +Following line can be used to assess if GPT verification has succeed: + +U-BOOT> gpt verify mmc 0 $partitions +U-BOOT> if test $? = 0; then echo "GPT OK"; else echo "GPT ERR"; fi + Useful info: ============
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- common/cmd_gpt.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 4c71125..be54eae 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -350,7 +350,10 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD(gpt, CONFIG_SYS_MAXARGS, 1, do_gpt, "GUID Partition Table", "<command> <interface> <dev> <partitions_list>\n" - " - GUID partition table restoration\n" - " Restore GPT information on a device connected\n" + " - GUID partition table restoration and validity check\n" + " Restore or verify GPT information on a device connected\n" " to interface\n" + " Example usage:\n" + " gpt write mmc 0 $partitions\n" + " gpt verify mmc 0 $partitions\n" );
Signed-off-by: Lukasz Majewski l.majewski@majess.pl Reviewed-by: Tom Rini trini@konsulko.com
This commit provides definition and declaration of GPT verification functions - namely gpt_verify_headers() and gpt_verify_partitions(). The former is used to only check CRC32 of GPT's header and PTEs. The latter examines each partition entry and compare attributes such as: name, start offset and size with ones provided at '$partitions' env variable.
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- disk/part_efi.c | 101 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/part.h | 35 ++++++++++++++++++++ 2 files changed, 136 insertions(+)
diff --git a/disk/part_efi.c b/disk/part_efi.c index 15627f2..59edf38 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -549,6 +549,107 @@ err: return ret; }
+static void gpt_convert_efi_name_to_char(char *s, efi_char16_t *es, int n) +{ + char *ess = (char *)es; + int i, j; + + memset(s, '\0', n); + + for (i = 0, j = 0; j < n; i += 2, j++) { + s[j] = ess[i]; + if (!ess[i]) + return; + } +} + +int gpt_verify_headers(block_dev_desc_t *dev_desc, gpt_header *gpt_head, + gpt_entry **gpt_pte) +{ + /* + * This function validates AND + * fills in the GPT header and PTE + */ + if (is_gpt_valid(dev_desc, + GPT_PRIMARY_PARTITION_TABLE_LBA, + gpt_head, gpt_pte) != 1) { + printf("%s: *** ERROR: Invalid GPT ***\n", + __func__); + return -1; + } + if (is_gpt_valid(dev_desc, (dev_desc->lba - 1), + gpt_head, gpt_pte) != 1) { + printf("%s: *** ERROR: Invalid Backup GPT ***\n", + __func__); + return -1; + } + + return 0; +} + +int gpt_verify_partitions(block_dev_desc_t *dev_desc, + disk_partition_t *partitions, int parts, + gpt_header *gpt_head, gpt_entry **gpt_pte) +{ + char efi_str[PARTNAME_SZ + 1]; + u64 gpt_part_size; + gpt_entry *gpt_e; + int ret, i; + + ret = gpt_verify_headers(dev_desc, gpt_head, gpt_pte); + if (ret) + return ret; + + gpt_e = *gpt_pte; + + for (i = 0; i < parts; i++) { + if (i == gpt_head->num_partition_entries) { + error("More partitions than allowed!\n"); + return -1; + } + + /* Check if GPT and ENV partition names match */ + gpt_convert_efi_name_to_char(efi_str, gpt_e[i].partition_name, + PARTNAME_SZ + 1); + + debug("%s: part: %2d name - GPT: %16s, ENV: %16s ", + __func__, i, efi_str, partitions[i].name); + + if (strncmp(efi_str, (char *)partitions[i].name, + sizeof(partitions->name))) { + error("Partition name: %s does not match %s!\n", + efi_str, (char *)partitions[i].name); + return -1; + } + + /* Check if GPT and ENV start LBAs match */ + debug("start LBA - GPT: %8llu, ENV: %8llu ", + le64_to_cpu(gpt_e[i].starting_lba), + (u64) partitions[i].start); + + if (le64_to_cpu(gpt_e[i].starting_lba) != partitions[i].start) { + error("Partition %s start: %llu does not match %llu!\n", + efi_str, le64_to_cpu(gpt_e[i].starting_lba), + (u64) partitions[i].start); + return -1; + } + + /* Check if GPT and ENV sizes match */ + gpt_part_size = le64_to_cpu(gpt_e[i].ending_lba) - + le64_to_cpu(gpt_e[i].starting_lba) + 1; + debug("size(LBA) - GPT: %8llu, ENV: %8llu\n", + gpt_part_size, (u64) partitions[i].size); + + if (le64_to_cpu(gpt_part_size) != partitions[i].size) { + error("Partition %s size: %llu does not match %llu!\n", + efi_str, gpt_part_size, (u64) partitions[i].size); + return -1; + } + } + + return 0; +} + int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf) { gpt_header *gpt_h; diff --git a/include/part.h b/include/part.h index 8ea9b30..4152052 100644 --- a/include/part.h +++ b/include/part.h @@ -264,6 +264,41 @@ int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf); * @return - '0' on success, otherwise error */ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf); + +/** + * gpt_verify_headers() - Function to read and CRC32 check of the GPT's header + * and partition table entries (PTE) + * + * As a side effect if sets gpt_head and gpt_pte so they point to GPT data. + * + * @param dev_desc - block device descriptor + * @param gpt_head - pointer to GPT header data read from medium + * @param gpt_pte - pointer to GPT partition table enties read from medium + * + * @return - '0' on success, otherwise error + */ +int gpt_verify_headers(block_dev_desc_t *dev_desc, gpt_header *gpt_head, + gpt_entry **gpt_pte); + +/** + * gpt_verify_partitions() - Function to check if partitions' name, start and + * size correspond to '$partitions' env variable + * + * This function checks if on medium stored GPT data is in sync with information + * provided in '$partitions' environment variable. Specificially, name, start + * and size of the partition is checked. + * + * @param dev_desc - block device descriptor + * @param partitions - partition data read from '$partitions' env variable + * @param parts - number of partitions read from '$partitions' env variable + * @param gpt_head - pointer to GPT header data read from medium + * @param gpt_pte - pointer to GPT partition table enties read from medium + * + * @return - '0' on success, otherwise error + */ +int gpt_verify_partitions(block_dev_desc_t *dev_desc, + disk_partition_t *partitions, int parts, + gpt_header *gpt_head, gpt_entry **gpt_pte); #endif
#endif /* _PART_H */
This commit adds support for "gpt verify" command, which verifies correctness of on-board stored GPT partition table. As the optional parameter one can provide '$partitons' environment variable to check if partition data (size, offset, name) is correct.
This command should be regarded as complementary one to "gpt restore".
Signed-off-by: Lukasz Majewski l.majewski@majess.pl --- common/cmd_gpt.c | 90 +++++++++++++++++++++++++++++++++++++++++--------------- 1 file changed, 66 insertions(+), 24 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index be54eae..ddad4b2 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -1,6 +1,9 @@ /* * cmd_gpt.c -- GPT (GUID Partition Table) handling command * + * Copyright (C) 2015 + * Lukasz Majewski l.majewski@majess.pl + * * Copyright (C) 2012 Samsung Electronics * author: Lukasz Majewski l.majewski@samsung.com * author: Piotr Wilczek p.wilczek@samsung.com @@ -15,6 +18,7 @@ #include <exports.h> #include <linux/ctype.h> #include <div64.h> +#include <memalign.h>
#ifndef CONFIG_PARTITION_UUIDS #error CONFIG_PARTITION_UUIDS must be enabled for CONFIG_CMD_GPT to be enabled @@ -297,6 +301,43 @@ static int gpt_default(block_dev_desc_t *blk_dev_desc, const char *str_part) return ret; }
+static int gpt_verify(block_dev_desc_t *blk_dev_desc, const char *str_part) +{ + ALLOC_CACHE_ALIGN_BUFFER_PAD(gpt_header, gpt_head, 1, + blk_dev_desc->blksz); + disk_partition_t *partitions = NULL; + gpt_entry *gpt_pte = NULL; + char *str_disk_guid; + u8 part_count = 0; + int ret = 0; + + /* fill partitions */ + ret = set_gpt_info(blk_dev_desc, str_part, + &str_disk_guid, &partitions, &part_count); + if (ret) { + if (ret == -1) { + puts("No partition list provided - only basic check\n"); + ret = gpt_verify_headers(blk_dev_desc, gpt_head, + &gpt_pte); + goto out; + } + if (ret == -2) + printf("Missing disk guid\n"); + if ((ret == -3) || (ret == -4)) + printf("Partition list incomplete\n"); + return -1; + } + + /* Check partition layout with provided pattern */ + ret = gpt_verify_partitions(blk_dev_desc, partitions, part_count, + gpt_head, &gpt_pte); + free(str_disk_guid); + free(partitions); + out: + free(gpt_pte); + return ret; +} + /** * do_gpt(): Perform GPT operations * @@ -312,39 +353,40 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) int ret = CMD_RET_SUCCESS; int dev = 0; char *ep; - block_dev_desc_t *blk_dev_desc; + block_dev_desc_t *blk_dev_desc = NULL;
- if (argc < 5) + if (argc < 4 || argc > 5) return CMD_RET_USAGE;
- /* command: 'write' */ - if ((strcmp(argv[1], "write") == 0) && (argc == 5)) { - dev = (int)simple_strtoul(argv[3], &ep, 10); - if (!ep || ep[0] != '\0') { - printf("'%s' is not a number\n", argv[3]); - return CMD_RET_USAGE; - } - blk_dev_desc = get_dev(argv[2], dev); - if (!blk_dev_desc) { - printf("%s: %s dev %d NOT available\n", - __func__, argv[2], dev); - return CMD_RET_FAILURE; - } + dev = (int)simple_strtoul(argv[3], &ep, 10); + if (!ep || ep[0] != '\0') { + printf("'%s' is not a number\n", argv[3]); + return CMD_RET_USAGE; + } + blk_dev_desc = get_dev(argv[2], dev); + if (!blk_dev_desc) { + printf("%s: %s dev %d NOT available\n", + __func__, argv[2], dev); + return CMD_RET_FAILURE; + }
+ if ((strcmp(argv[1], "write") == 0) && (argc == 5)) { puts("Writing GPT: "); - ret = gpt_default(blk_dev_desc, argv[4]); - if (!ret) { - puts("success!\n"); - return CMD_RET_SUCCESS; - } else { - puts("error!\n"); - return CMD_RET_FAILURE; - } + } else if ((strcmp(argv[1], "verify") == 0)) { + ret = gpt_verify(blk_dev_desc, argv[4]); + puts("Verify GPT: "); } else { return CMD_RET_USAGE; } - return ret; + + if (ret) { + puts("error!\n"); + return CMD_RET_FAILURE; + } + + puts("success!\n"); + return CMD_RET_SUCCESS; }
Note you're using puts and printf both here, please just switch to printf. But: Reviewed-by: Tom Rini trini@konsulko.com
I will fix this in v2. I also need to fix some issues with "$partitions" parsing code.
Anyway, thanks for review.
Best regards, Łukasz Majewski
This patch series clearly applies on top of u-boot/master: SHA1: 736d1746fb7b8f7cd70657a4a72db2b6bd8de40e
Lukasz Majewski (5): gpt: command: Remove duplicated check for empty partition description gpt: doc: README: Update README entry for gpt verify extension gpt: doc: Update gpt command's help description gpt: part: Definition and declaration of GPT verification functions gpt: command: Extend gpt command to support GPT table verification
common/cmd_gpt.c | 102 ++++++++++++++++++++++++++++++++++++--------------- disk/part_efi.c | 110 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ doc/README.gpt | 27 +++++++++++++- include/part.h | 35 ++++++++++++++++++ 4 files changed, 243 insertions(+), 31 deletions(-)
--- Changes for v2: - None --- common/cmd_gpt.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index e3c0297..6bea2c7 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -293,9 +293,6 @@ static int gpt_default(block_dev_desc_t *blk_dev_desc, const char *str_part) u8 part_count = 0; disk_partition_t *partitions = NULL;
--- Changes for v2: - Adjust README.gpt changes to the newest mainline --- doc/README.gpt | 27 ++++++++++++++++++++++++++- 1 file changed, 26 insertions(+), 1 deletion(-)
diff --git a/doc/README.gpt b/doc/README.gpt index 35902ce..db439f9 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -168,9 +168,34 @@ To restore GUID partition table one needs to:
+Checking (validating) GPT partitions in U-Boot: +=============================================== + +Procedure is the same as above. The only change is at point 3. + +At u-boot prompt one needs to write: + gpt verify mmc 0 [$partitions] + +where [$partitions] is an optional parameter. + +When it is not provided, only basic checks based on CRC32 calculation for GPT +header and PTEs are performed. +When provided, additionally partition data - name, size and starting +offset (last two in LBA) - are compared with data defined in '$partitions' +environment variable. + +After running this command, return code is set to 0 if no errors found in +on non-volatile medium stored GPT. + +Following line can be used to assess if GPT verification has succeed: + +U-BOOT> gpt verify mmc 0 $partitions +U-BOOT> if test $? = 0; then echo "GPT OK"; else echo "GPT ERR"; fi + + Partition type GUID: ====================
--- Changes for v2: - Provide support for situation where "start" attribute at '$partitions' env variable is not provided. --- disk/part_efi.c | 110 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/part.h | 35 ++++++++++++++++++ 2 files changed, 145 insertions(+)
diff --git a/disk/part_efi.c b/disk/part_efi.c index ea9c615..40f0b36 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -578,6 +578,116 @@ err: return ret; }
+static void gpt_convert_efi_name_to_char(char *s, efi_char16_t *es, int n) +{ + char *ess = (char *)es; + int i, j; + + memset(s, '\0', n); + + for (i = 0, j = 0; j < n; i += 2, j++) { + s[j] = ess[i]; + if (!ess[i]) + return; + } +} + +int gpt_verify_headers(block_dev_desc_t *dev_desc, gpt_header *gpt_head, + gpt_entry **gpt_pte) +{ + /* + * This function validates AND + * fills in the GPT header and PTE + */ + if (is_gpt_valid(dev_desc, + GPT_PRIMARY_PARTITION_TABLE_LBA, + gpt_head, gpt_pte) != 1) { + printf("%s: *** ERROR: Invalid GPT ***\n", + __func__); + return -1; + } + if (is_gpt_valid(dev_desc, (dev_desc->lba - 1), + gpt_head, gpt_pte) != 1) { + printf("%s: *** ERROR: Invalid Backup GPT ***\n", + __func__); + return -1; + } + + return 0; +} + +int gpt_verify_partitions(block_dev_desc_t *dev_desc, + disk_partition_t *partitions, int parts, + gpt_header *gpt_head, gpt_entry **gpt_pte) +{ + char efi_str[PARTNAME_SZ + 1]; + u64 gpt_part_size; + gpt_entry *gpt_e; + int ret, i; + + ret = gpt_verify_headers(dev_desc, gpt_head, gpt_pte); + if (ret) + return ret; + + gpt_e = *gpt_pte; + + for (i = 0; i < parts; i++) { + if (i == gpt_head->num_partition_entries) { + error("More partitions than allowed!\n"); + return -1; + } + + /* Check if GPT and ENV partition names match */ + gpt_convert_efi_name_to_char(efi_str, gpt_e[i].partition_name, + PARTNAME_SZ + 1); + + debug("%s: part: %2d name - GPT: %16s, ENV: %16s ", + __func__, i, efi_str, partitions[i].name); + + if (strncmp(efi_str, (char *)partitions[i].name, + sizeof(partitions->name))) { + error("Partition name: %s does not match %s!\n", + efi_str, (char *)partitions[i].name); + return -1; + } + + /* Check if GPT and ENV sizes match */ + gpt_part_size = le64_to_cpu(gpt_e[i].ending_lba) - + le64_to_cpu(gpt_e[i].starting_lba) + 1; + debug("size(LBA) - GPT: %8llu, ENV: %8llu ", + gpt_part_size, (u64) partitions[i].size); + + if (le64_to_cpu(gpt_part_size) != partitions[i].size) { + error("Partition %s size: %llu does not match %llu!\n", + efi_str, gpt_part_size, (u64) partitions[i].size); + return -1; + } + + /* + * Start address is optional - check only if provided + * in '$partition' variable + */ + if (!partitions[i].start) { + debug("\n"); + continue; + } + + /* Check if GPT and ENV start LBAs match */ + debug("start LBA - GPT: %8llu, ENV: %8llu\n", + le64_to_cpu(gpt_e[i].starting_lba), + (u64) partitions[i].start); + + if (le64_to_cpu(gpt_e[i].starting_lba) != partitions[i].start) { + error("Partition %s start: %llu does not match %llu!\n", + efi_str, le64_to_cpu(gpt_e[i].starting_lba), + (u64) partitions[i].start); + return -1; + } + } + + return 0; +} + int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf) { gpt_header *gpt_h; diff --git a/include/part.h b/include/part.h index 8b5ac12..720a867 100644 --- a/include/part.h +++ b/include/part.h @@ -267,6 +267,41 @@ int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf); * @return - '0' on success, otherwise error */ int write_mbr_and_gpt_partitions(block_dev_desc_t *dev_desc, void *buf); + +/** + * gpt_verify_headers() - Function to read and CRC32 check of the GPT's header + * and partition table entries (PTE) + * + * As a side effect if sets gpt_head and gpt_pte so they point to GPT data. + * + * @param dev_desc - block device descriptor + * @param gpt_head - pointer to GPT header data read from medium + * @param gpt_pte - pointer to GPT partition table enties read from medium + * + * @return - '0' on success, otherwise error + */ +int gpt_verify_headers(block_dev_desc_t *dev_desc, gpt_header *gpt_head, + gpt_entry **gpt_pte); + +/** + * gpt_verify_partitions() - Function to check if partitions' name, start and + * size correspond to '$partitions' env variable + * + * This function checks if on medium stored GPT data is in sync with information + * provided in '$partitions' environment variable. Specificially, name, start + * and size of the partition is checked. + * + * @param dev_desc - block device descriptor + * @param partitions - partition data read from '$partitions' env variable + * @param parts - number of partitions read from '$partitions' env variable + * @param gpt_head - pointer to GPT header data read from medium + * @param gpt_pte - pointer to GPT partition table enties read from medium + * + * @return - '0' on success, otherwise error + */ +int gpt_verify_partitions(block_dev_desc_t *dev_desc, + disk_partition_t *partitions, int parts, + gpt_header *gpt_head, gpt_entry **gpt_pte); #endif
Hi Lukasz,
Changes for v2:
I've got few comments to this code.
Probably print_efiname() could meet your requirements.
- char *ess = (char *)es;
- int i, j;
- memset(s, '\0', n);
- for (i = 0, j = 0; j < n; i += 2, j++) {
s[j] = ess[i];
if (!ess[i])
return;
- if (is_gpt_valid(dev_desc,
__func__);
return -1;
- if (is_gpt_valid(dev_desc, (dev_desc->lba - 1),
__func__);
return -1;
I've got an error for Trats2:
-------------------------------------------------------------- Trats2 # print partitions partitions=uuid_disk=${uuid_gpt_disk};name=csa-mmc,start=5MiB,size=8MiB,uuid=${u uid_gpt_csa-mmc};name=boot,size=60MiB,uuid=${uuid_gpt_boot};name=qboot,size=100M iB,uuid=${uuid_gpt_qboot};name=csc,size=150MiB,uuid=${uuid_gpt_csc};name=platfor m,size=1536MiB,uuid=${uuid_gpt_platform};name=data,size=3000MiB,uuid=${uuid_gpt_ data};name=ums,size=-,uuid=${uuid_gpt_ums} Trats2 # gpt write mmc 0 $partitions Writing GPT: success! Trats2 # gpt verify mmc 0 $partitions ERROR: Partition ums size: 20826079 does not match 0!
at disk/part_efi.c:662/gpt_verify_partitions() Verify GPT: error! Trats2 # --------------------------------------------------------------
The function set_gpt_info() in file common/cmd_gpt.c doesn't fill the 'partitions' as your code expects. There are some assumptions, respected by gpt_fill_pte(), like empty start, which you fixed, and case for which 'size' is empty (e.g. for the last partition) - which cause printing an error as above.
The function gpt_verify_partitions() should actually do the same what gpt_fill_pte() does, but it has no sense to duplicate the code.
- char efi_str[PARTNAME_SZ + 1];
- u64 gpt_part_size;
- gpt_entry *gpt_e;
- int ret, i;
- ret = gpt_verify_headers(dev_desc, gpt_head, gpt_pte);
- if (ret)
return ret;
- gpt_e = *gpt_pte;
To make proper verification in this function it would be better if you remove this loop and call function gpt_fill_pte() to fill some temporary 'gpt_e' array from the parsed env $partitions.
Then you can compare if the temporary created gpt array entries are equal to the device's gpt entries.
Then you don't need to take care about the assumptions to parsing $partitions - just compare two headers - if $partition will change, then you will see the difference in the gpt headers.
- for (i = 0; i < parts; i++) {
return -1;
PARTNAME_SZ + 1);
return -1;
return -1;
debug("\n");
continue;
return -1;
- int is_valid_gpt_buf(block_dev_desc_t *dev_desc, void *buf) { gpt_header *gpt_h;
- @return - '0' on success, otherwise error
- gpt_verify_headers() - Function to read and CRC32 check of the GPT's header
- As a side effect if sets gpt_head and gpt_pte so they point to GPT data.
- @param dev_desc - block device descriptor
- @param gpt_head - pointer to GPT header data read from medium
- @param gpt_pte - pointer to GPT partition table enties read from medium
- gpt_verify_partitions() - Function to check if partitions' name, start and
- This function checks if on medium stored GPT data is in sync with information
- provided in '$partitions' environment variable. Specificially, name, start
- and size of the partition is checked.
- @param partitions - partition data read from '$partitions' env variable
- @param parts - number of partitions read from '$partitions' env variable
#endif
Reviewed-by: Przemyslaw Marczak p.marczak@samsung.com
Signed-off-by: Lukasz Majewski l.majewski@majess.pl Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Przemyslaw Marczak p.marczak@samsung.com
Hello Tom,
Why merged so quickly?
I tested this patchset on my device and posted about the issues. [1]
This should be reworked, since the verify assumptions are too simple and doesn't fully match the GPT header creation. So this command will fail for some cases of write/verify sequence, depending on what the $partitions includes.
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg193216.html
On Tue, Nov 24, 2015 at 10:56:41AM +0100, Przemyslaw Marczak wrote:
Hello Tom,
Mainly because I skimmed things too quickly, sorry. Also in the future (and this applies to anyone that's a custodian, and people can also manage their own patches if they login) please update patches you're asking for changes on in patchwork, it really does help me keep an eye on things. Thanks!
Hi Tom,
Hello Tom,
OK, that's a good point.
--- Changes for v2: - Replace puts() with printf() --- common/cmd_gpt.c | 92 +++++++++++++++++++++++++++++++++++++++++--------------- 1 file changed, 67 insertions(+), 25 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 12419b6..460809c 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -1,6 +1,9 @@ /* * cmd_gpt.c -- GPT (GUID Partition Table) handling command * + * Copyright (C) 2015 + * Lukasz Majewski l.majewski@majess.pl + * * Copyright (C) 2012 Samsung Electronics * author: Lukasz Majewski l.majewski@samsung.com * author: Piotr Wilczek p.wilczek@samsung.com @@ -15,6 +18,7 @@ #include <exports.h> #include <linux/ctype.h> #include <div64.h> +#include <memalign.h>
#ifndef CONFIG_PARTITION_UUIDS #error CONFIG_PARTITION_UUIDS must be enabled for CONFIG_CMD_GPT to be enabled @@ -314,6 +318,43 @@ static int gpt_default(block_dev_desc_t *blk_dev_desc, const char *str_part) return ret; }
+static int gpt_verify(block_dev_desc_t *blk_dev_desc, const char *str_part) +{ + ALLOC_CACHE_ALIGN_BUFFER_PAD(gpt_header, gpt_head, 1, + blk_dev_desc->blksz); + disk_partition_t *partitions = NULL; + gpt_entry *gpt_pte = NULL; + char *str_disk_guid; + u8 part_count = 0; + int ret = 0; + + /* fill partitions */ + ret = set_gpt_info(blk_dev_desc, str_part, + &str_disk_guid, &partitions, &part_count); + if (ret) { + if (ret == -1) { + printf("No partition list provided - only basic check\n"); + ret = gpt_verify_headers(blk_dev_desc, gpt_head, + &gpt_pte); + goto out; + } + if (ret == -2) + printf("Missing disk guid\n"); + if ((ret == -3) || (ret == -4)) + printf("Partition list incomplete\n"); + return -1; + } + + /* Check partition layout with provided pattern */ + ret = gpt_verify_partitions(blk_dev_desc, partitions, part_count, + gpt_head, &gpt_pte); + free(str_disk_guid); + free(partitions); + out: + free(gpt_pte); + return ret; +} + /** * do_gpt(): Perform GPT operations * @@ -329,39 +370,40 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) int ret = CMD_RET_SUCCESS; int dev = 0; char *ep; - block_dev_desc_t *blk_dev_desc; + block_dev_desc_t *blk_dev_desc = NULL;
- /* command: 'write' */ - if ((strcmp(argv[1], "write") == 0) && (argc == 5)) { - dev = (int)simple_strtoul(argv[3], &ep, 10); - if (!ep || ep[0] != '\0') { - printf("'%s' is not a number\n", argv[3]); - return CMD_RET_USAGE; - } - blk_dev_desc = get_dev(argv[2], dev); - if (!blk_dev_desc) { - printf("%s: %s dev %d NOT available\n", - __func__, argv[2], dev); - return CMD_RET_FAILURE; - } - - puts("Writing GPT: "); + dev = (int)simple_strtoul(argv[3], &ep, 10); + if (!ep || ep[0] != '\0') { + printf("'%s' is not a number\n", argv[3]); + return CMD_RET_USAGE; + } + blk_dev_desc = get_dev(argv[2], dev); + if (!blk_dev_desc) { + printf("%s: %s dev %d NOT available\n", + __func__, argv[2], dev); + return CMD_RET_FAILURE; + }
+ if ((strcmp(argv[1], "write") == 0) && (argc == 5)) { + printf("Writing GPT: "); ret = gpt_default(blk_dev_desc, argv[4]); - if (!ret) { - puts("success!\n"); - return CMD_RET_SUCCESS; - } else { - puts("error!\n"); - return CMD_RET_FAILURE; - } + } else if ((strcmp(argv[1], "verify") == 0)) { + ret = gpt_verify(blk_dev_desc, argv[4]); + printf("Verify GPT: "); } else { return CMD_RET_USAGE; } - return ret; + + if (ret) { + printf("error!\n"); + return CMD_RET_FAILURE; + } + + printf("success!\n"); + return CMD_RET_SUCCESS; }
Hello Lukasz,
$partitions
... one to "gpt write" ?
Changes for v2:
- cmd_gpt.c -- GPT (GUID Partition Table) handling command
- Copyright (C) 2015
- Lukasz Majewski l.majewski@majess.pl
- Copyright (C) 2012 Samsung Electronics
- author: Lukasz Majewski l.majewski@samsung.com
- author: Piotr Wilczek p.wilczek@samsung.com
- ALLOC_CACHE_ALIGN_BUFFER_PAD(gpt_header, gpt_head, 1,
- disk_partition_t *partitions = NULL;
- gpt_entry *gpt_pte = NULL;
- char *str_disk_guid;
- u8 part_count = 0;
- int ret = 0;
Can you move the simple verify to the beginning?
if (!str_part) { ret = gpt_verify_headers(blk_dev_desc, gpt_head, &gpt_pte); goto out; }
- ret = set_gpt_info(blk_dev_desc, str_part,
- if (ret) {
if (ret == -1) {
&gpt_pte);
goto out;
if (ret == -2)
return -1;
- /* Check partition layout with provided pattern */
- ret = gpt_verify_partitions(blk_dev_desc, partitions, part_count,
- free(str_disk_guid);
- free(partitions);
- out:
- free(gpt_pte);
- return ret;
- do_gpt(): Perform GPT operations
- block_dev_desc_t *blk_dev_desc = NULL;
- if (argc < 5)
- if (argc < 4 || argc > 5) return CMD_RET_USAGE;
if (!ret) {
puts("success!\n");
} else {
puts("error!\n");
- } else if ((strcmp(argv[1], "verify") == 0)) {
} else { return CMD_RET_USAGE; }printf("Verify GPT: ");
- return ret;
if (ret) {
printf("error!\n");
So, I was going to say one thing here, but it turns out I guessed wrong about which part of the previous series still applied (it was 4/6, not 3/6, even 'tho #3 was not included in the v2 posts). In the future, unless you're just changing one patch in the series, please repost the whole thing, it makes applying easier (and you can just say Changes in vX: None in the changelog for the unchanged patch). Thanks!
Lukasz Majewski
Przemyslaw Marczak
