[PATCH] test/py: saveenv: Add a test for saveenv command
Add test case for saveenv command in non-JTAG bootmode which saves the u-boot environment variables in persistent storage.
Signed-off-by: Love Kumar love.kumar@amd.com --- test/py/tests/test_saveenv.py | 125 ++++++++++++++++++++++++++++++++++ 1 file changed, 125 insertions(+) create mode 100644 test/py/tests/test_saveenv.py
diff --git a/test/py/tests/test_saveenv.py b/test/py/tests/test_saveenv.py new file mode 100644 index 000000000000..30d8148f8f3e --- /dev/null +++ b/test/py/tests/test_saveenv.py @@ -0,0 +1,125 @@ +# SPDX-License-Identifier: GPL-2.0 +# (C) Copyright 2023, Advanced Micro Devices, Inc. + +""" +Note: This test doesn't rely on boardenv_* configuration value but they can +change test behavior. + +# Setup env__saveenv_test_skip to True if saveenv test is not possible or +# desired and should be skipped. +env__saveenv_test_skip = True + +# This test will be also skipped if the bootmode is detected to JTAG. +""" + +import pytest +import re +import random +import ipaddress +import string +import uuid + +# Setup the env +def setup_saveenv_env(u_boot_console): + if u_boot_console.config.env.get('env__saveenv_test_skip', False): + pytest.skip('saveenv test is not enabled') + + output = u_boot_console.run_command('print modeboot') + m = re.search('modeboot=(.+?)boot', output) + if not m: + pytest.skip('bootmode cannnot be determined') + + bootmode = m.group(1) + if bootmode == 'jtag': + pytest.skip('skipping saveenv test due to jtag bootmode') + +# Check return code +def ret_code(u_boot_console): + return u_boot_console.run_command('echo $?') + +# Verify env variable +def check_env(u_boot_console, var_name, var_value): + if var_value: + output = u_boot_console.run_command(f'printenv {var_name}') + var_value = str(var_value) + if (var_value.startswith("'") and var_value.endswith("'")) or ( + var_value.startswith('"') and var_value.endswith('"') + ): + var_value = var_value.split(var_value[-1])[1] + assert var_value in output + assert ret_code(u_boot_console).endswith('0') + else: + u_boot_console.p.send(f'printenv {var_name}\n') + output = u_boot_console.p.expect(['not defined']) + assert output == 0 + assert ret_code(u_boot_console).endswith('1') + +# Set env variable +def set_env(u_boot_console, var_name, var_value): + u_boot_console.run_command(f'setenv {var_name} {var_value}') + assert ret_code(u_boot_console).endswith('0') + check_env(u_boot_console, var_name, var_value) + +@pytest.mark.buildconfigspec('cmd_saveenv') +def test_saveenv(u_boot_console): + """Test the saveenv command in non-JTAG bootmode. + It saves the U-Boot environment in persistent storage. + """ + setup_saveenv_env(u_boot_console) + + # Set env for random mac address + rand_mac = '%02x:%02x:%02x:%02x:%02x:%02x' % ( + random.randint(0, 255), + random.randint(0, 255), + random.randint(0, 255), + random.randint(0, 255), + random.randint(0, 255), + random.randint(0, 255), + ) + set_env(u_boot_console, 'mac_addr', rand_mac) + + # Set env for random IPv4 address + rand_ipv4 = ipaddress.IPv4Address._string_from_ip_int( + random.randint(0, ipaddress.IPv4Address._ALL_ONES) + ) + set_env(u_boot_console, 'ipv4_addr', rand_ipv4) + + # Set env for random IPv6 address + rand_ipv6 = ipaddress.IPv6Address._string_from_ip_int( + random.randint(0, ipaddress.IPv6Address._ALL_ONES) + ) + set_env(u_boot_console, 'ipv6_addr', rand_ipv6) + + # Set env for random number + rand_num = random.randrange(1, 10**9) + set_env(u_boot_console, 'num_var', rand_num) + + # Set env for uuid + uuid_str = uuid.uuid4().hex.lower() + set_env(u_boot_console, 'uuid_var', uuid_str) + + # Set env for random string including special characters + sc = "!#%&()*+,-./:;<=>?@[\]^_`{|}~" + rand_str = ''.join( + random.choices(' ' + string.ascii_letters + sc + string.digits, k=300) + ) + set_env(u_boot_console, 'str_var', f'"{rand_str}"') + + # Set env for empty string + set_env(u_boot_console, 'empty_var', '') + + # Save the env variables + u_boot_console.run_command('saveenv') + assert ret_code(u_boot_console).endswith('0') + + # Reboot + u_boot_console.run_command('reset', wait_for_reboot=True) + + # Verify the saved env variables + check_env(u_boot_console, 'mac_addr', rand_mac) + check_env(u_boot_console, 'ipv4_addr', rand_ipv4) + check_env(u_boot_console, 'ipv6_addr', rand_ipv6) + check_env(u_boot_console, 'num_var', rand_num) + check_env(u_boot_console, 'uuid_var', uuid_str) + check_env(u_boot_console, 'str_var', rand_str) + check_env(u_boot_console, 'empty_var', '')
[snip]
- if u_boot_console.config.env.get('env__saveenv_test_skip', False):
- output = u_boot_console.run_command('print modeboot')
- m = re.search('modeboot=(.+?)boot', output)
- if not m:
- bootmode = m.group(1)
- if bootmode == 'jtag':
This doesn't handle the case of "modeboot" being unset, which is how my hardware is.
Love Kumar
