Re: [U-Boot-Users] U-boot and UBI
Bernard,
Nigel Hathaway wrote:
Hoping to avoid re-inventing the wheel....
It would seem that there are a number of people who are
independently
porting UBI to U-Boot.
I expressed interest in doing so at the time but nothing happened
about
it unfortunately. I can't speak for anyone else though.
Bernard.
In the short term we've found a way to get round having to UBI and hence porting it to U-Boot (we have a NOR/NAND combination, and we've gone for the NAND as entirely jffs2).
However, the next spin of our product will use entirely NAND flash: it will use an SoC which has an internal ROMboot and can load U-Boot directly from NAND flash. We will have to go to UBI then (starting development early 2009).
I have been playing around with a board from Olimex: the SAM9-L9260 (it has an Atmel AT91SAM9260 on it). This has a ROMboot with U-Boot in NAND flash. The board I am using has an interesting feature: the block which U-Boot is configured to use for storing its environment just happens to be a bad block, so I can't change and store the U-Boot environment parameters on it.
Either the U-Boot that comes pre-flashed into the board (v1.2.0) is misconfigured, or that version of U-Boot has failed to take into account the possibility of the scenario described. Either way, there would appear to be some work to do to get U-boot up-to-date with Linux MTD state-of-the-art.
Nigel
There's a patch in the testing branch of u-boot-nand-flash to allow a range of blocks to be specified for the environment, with bad blocks being skipped. Another patch has been posted to allow the location of the environment to be specified in the OOB area of the boot block (which is guaranteed to be good).
-Scott
Nigel Hathaway
Scott Wood
