[U-Boot] [PATCH 0/4] ARM: kirkwood: lsxl: enable DM for SATA
Please note that this patchset depends on the following series: https://patchwork.ozlabs.org/cover/1055937/ (ARM: kirkwood: migrate to DM_USB) https://patchwork.ozlabs.org/patch/1054403/ (sata: sata_mv: Add DM support to enable CONFIG_BLK usage)
Michael Walle (4): sata: sata_mv: use correct format specifier in debug() sata: sata_mv: support kirkwood architecture sata: sata_mv: add orion-sata compatible string arm: kirkwood: lsxl: enable DM for SATA
configs/lschlv2_defconfig | 4 ++-- configs/lsxhl_defconfig | 4 ++-- drivers/ata/sata_mv.c | 10 +++++----- include/configs/lsxl.h | 23 ++++++++++------------- 4 files changed, 19 insertions(+), 22 deletions(-)
This fixes a compile error on kirkwood.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/ata/sata_mv.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index d13695d79e..87ea95f75d 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -727,7 +727,7 @@ static u32 ata_low_level_rw(struct udevice *dev, int port, lbaint_t blknr, u8 *addr; int max_blks;
- debug("%s: %ld %ld\n", __func__, blknr, blkcnt); + debug("%s: " LBAFU " " LBAFU "\n", __func__, blknr, blkcnt);
start = blknr; blks = blkcnt;
Reviewed-by: Chris Packham judge.packham@gmail.com
debug("%s: " LBAFU " " LBAFU "\n", __func__, blknr, blkcnt); start = blknr; blks = blkcnt;
-- 2.11.0
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Fix the worng include and offset macros.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/ata/sata_mv.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index 87ea95f75d..b691107dc0 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -44,11 +44,10 @@ #include <asm/io.h> #include <linux/mbus.h>
+#include <asm/arch/soc.h> #if defined(CONFIG_KIRKWOOD) -#include <asm/arch/kirkwood.h> #define SATAHC_BASE KW_SATA_BASE #else -#include <asm/arch/soc.h> #define SATAHC_BASE MVEBU_AXP_SATA_BASE #endif
@@ -218,8 +217,8 @@ struct crqb { #define CRQB_SECTCOUNT_COUNT_EXP_MASK (0xff << 8) #define CRQB_SECTCOUNT_COUNT_EXP_SHIFT 8
-#define MVSATA_WIN_CONTROL(w) (MVEBU_AXP_SATA_BASE + 0x30 + ((w) << 4)) -#define MVSATA_WIN_BASE(w) (MVEBU_AXP_SATA_BASE + 0x34 + ((w) << 4)) +#define MVSATA_WIN_CONTROL(w) (SATAHC_BASE + 0x30 + ((w) << 4)) +#define MVSATA_WIN_BASE(w) (SATAHC_BASE + 0x34 + ((w) << 4))
struct eprd { u32 phyaddr_low;
Typo worng -> wrong
It might be a better idea to update these defines to be definitions for these in the soc.h. We're already doing this for some other peripheral blocks between mach-kirkwood and mach-mvebu. On the other hand SATAHC_BASE already achieves this so maybe it's not worth bothering.
struct eprd { u32 phyaddr_low; -- 2.11.0
Typo worng -> wrong
I'm fine with this change for now. *If* we change something here, we might make the step towards address probing via DT. But that's some future work, if it's really worth it. As we most likely won't see new platforms with new addresses to support any more.
Thanks, Stefan
Thanks, Stefan
Thanks, Stefan
The kirkwood devices are compatible with this driver.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/ata/sata_mv.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c index b691107dc0..2a630d46c1 100644 --- a/drivers/ata/sata_mv.c +++ b/drivers/ata/sata_mv.c @@ -1079,6 +1079,7 @@ static int sata_mv_scan(struct udevice *dev)
static const struct udevice_id sata_mv_ids[] = { { .compatible = "marvell,armada-370-sata" }, + { .compatible = "marvell,orion-sata" }, { } };
-- 2.11.0
- { .compatible = "marvell,orion-sata" }, { } };
Thanks, Stefan
Thanks, Stefan
Switch from legacy IDE driver to sata_mv driver.
Signed-off-by: Michael Walle michael@walle.cc --- configs/lschlv2_defconfig | 4 ++-- configs/lsxhl_defconfig | 4 ++-- include/configs/lsxl.h | 23 ++++++++++------------- 3 files changed, 14 insertions(+), 17 deletions(-)
diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index e1ff355731..c550798bcd 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_CMD_FLASH is not set -CONFIG_CMD_IDE=y +CONFIG_CMD_SATA=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -26,7 +26,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lschlv2" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_MVSATA_IDE=y +CONFIG_SATA_MV=y CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 48678bdb8f..efcce455a4 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_BOARDINFO is not set # CONFIG_CMD_FLASH is not set -CONFIG_CMD_IDE=y +CONFIG_CMD_SATA=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -26,7 +26,7 @@ CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lsxhl" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_MVSATA_IDE=y +CONFIG_SATA_MV=y CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 72e62658d0..55c4e63325 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -76,9 +76,9 @@ "kernel_addr=0x00800000\0" \ "ramdisk_addr=0x01000000\0" \ "fdt_addr=0x00ff0000\0" \ - "bootcmd_legacy=ide reset " \ - "&& load ide ${hdpart} ${kernel_addr} /uImage.buffalo " \ - "&& load ide ${hdpart} ${ramdisk_addr} /initrd.buffalo "\ + "bootcmd_legacy=sata init " \ + "&& load sata ${hdpart} ${kernel_addr} /uImage.buffalo "\ + "&& load sata ${hdpart} ${ramdisk_addr} /initrd.buffalo "\ "&& bootm ${kernel_addr} ${ramdisk_addr}\0" \ "bootcmd_net=bootp ${kernel_addr} vmlinuz " \ "&& tftpboot ${ramdisk_addr} initrd.img " \ @@ -86,11 +86,11 @@ "&& tftpboot ${fdt_addr} " CONFIG_FDTFILE " " \ "&& bootz ${kernel_addr} " \ "${ramdisk_addr}:${ramdisk_len} ${fdt_addr}\0" \ - "bootcmd_hdd=ide reset " \ - "&& load ide ${hdpart} ${kernel_addr} /vmlinuz " \ - "&& load ide ${hdpart} ${ramdisk_addr} /initrd.img " \ + "bootcmd_hdd=sata init " \ + "&& load sata ${hdpart} ${kernel_addr} /vmlinuz " \ + "&& load sata ${hdpart} ${ramdisk_addr} /initrd.img " \ "&& setenv ramdisk_len ${filesize} " \ - "&& load ide ${hdpart} ${fdt_addr} /dtb " \ + "&& load sata ${hdpart} ${fdt_addr} /dtb " \ "&& bootz ${kernel_addr} " \ "${ramdisk_addr}:${ramdisk_len} ${fdt_addr}\0" \ "bootcmd_usb=usb start " \ @@ -131,13 +131,10 @@ #undef CONFIG_RESET_PHY_R #endif /* CONFIG_CMD_NET */
-#ifdef CONFIG_IDE -#undef CONFIG_SYS_IDE_MAXBUS -#define CONFIG_SYS_IDE_MAXBUS 1 -#undef CONFIG_SYS_IDE_MAXDEVICE -#define CONFIG_SYS_IDE_MAXDEVICE 1 -#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#ifdef CONFIG_SATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 #define CONFIG_SYS_64BIT_LBA +#define CONFIG_LBA48 #endif
#endif /* _CONFIG_LSXL_H */
- "bootcmd_legacy=sata init " \
"&& bootm ${kernel_addr} ${ramdisk_addr}\0" \ "bootcmd_net=bootp ${kernel_addr} vmlinuz " \ "&& tftpboot ${ramdisk_addr} initrd.img " \"&& load sata ${hdpart} ${ramdisk_addr} /initrd.buffalo "\
- "bootcmd_hdd=sata init " \
"&& setenv ramdisk_len ${filesize} " \"&& load sata ${hdpart} ${ramdisk_addr} /initrd.img " \
"&& bootz ${kernel_addr} " \ "${ramdisk_addr}:${ramdisk_len} ${fdt_addr}\0" \ "bootcmd_usb=usb start " \"&& load sata ${hdpart} ${fdt_addr} /dtb " \
Thanks, Stefan
Thanks, Stefan
I've compile tested this. I don't have a spare SATA drive to actually test it on my kirkwood board. I might be able to have a dig through my pile of boards and cobble something together.
-- 2.11.0
Chris Packham
Michael Walle
Stefan Roese
