[PULL u-boot] Please pull u-boot-amlogic-20211119
Hi Tom,
Here's a change to fix GPIO declaration in the Meson PINCTRL driver, and a couple of changes to handle boot errors when using the meson64 android config and permit recovering the board via fastboot when the boot media is invalid.
The CI job is at https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/9918
Thanks, Neil
The following changes since commit 8391a0f3d97c0300d7eafe7581b6712afb18f283:
Merge branch '2021-11-18-regression-fixes' (2021-11-18 18:25:19 -0500)
https://source.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20211119
for you to fetch changes up to 28f70cfcfd82ac509c8da772b74e5dc2df795fd2:
configs: meson64_android: add PANIC stage for SYSTEM fails (2021-11-19 18:15:26 +0100)
---------------------------------------------------------------- - pinctrl: Correct the driver GPIO declaration - meson64_android: handle errors on boot and run fastboot on boot failure
---------------------------------------------------------------- Neil Armstrong (2): configs: meson64_android: bypass other checks on run_fastboot=1 configs: meson64_android: add PANIC stage for SYSTEM fails
Simon Glass (1): pinctrl: meson: Correct the driver GPIO declaration
drivers/pinctrl/meson/pinctrl-meson-gx-pmx.c | 2 +- drivers/pinctrl/meson/pinctrl-meson-gx.h | 2 +- drivers/pinctrl/meson/pinctrl-meson-gxbb.c | 4 +-- drivers/pinctrl/meson/pinctrl-meson-gxl.c | 4 +-- include/configs/meson64_android.h | 47 +++++++++++++++++----------- 5 files changed, 35 insertions(+), 24 deletions(-)
On Fri, Nov 19, 2021 at 06:45:12PM +0100, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
