[PATCH] armv8: ls1012a: RGMII ports require internal delay
The correct setting for the RGMII ports on LS1012ARDB is to enable delay on both Rx and Tx so the interface mode used should be PHY_INTERFACE_MODE_RGMII_ID
Signed-off-by: Chaitanya Sakinam chaitanya.sakinam@nxp.com Signed-off-by: Anji J anji.jagarlmudi@nxp.com --- board/freescale/ls1012ardb/eth.c | 2 +- drivers/net/pfe_eth/pfe_eth.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/freescale/ls1012ardb/eth.c b/board/freescale/ls1012ardb/eth.c index 5edcfcf..ca15349 100644 --- a/board/freescale/ls1012ardb/eth.c +++ b/board/freescale/ls1012ardb/eth.c @@ -112,7 +112,7 @@ int pfe_eth_board_init(struct udevice *dev) /* MAC2 */ pfe_set_phy_address_mode(priv->gemac_port, CONFIG_PFE_EMAC2_PHY_ADDR, - PHY_INTERFACE_MODE_RGMII_TXID); + PHY_INTERFACE_MODE_RGMII_ID); } break; case 0x2208: diff --git a/drivers/net/pfe_eth/pfe_eth.c b/drivers/net/pfe_eth/pfe_eth.c index 1b5d11e..6e22041 100644 --- a/drivers/net/pfe_eth/pfe_eth.c +++ b/drivers/net/pfe_eth/pfe_eth.c @@ -31,7 +31,7 @@ struct gemac_s gem_info[] = {
/* phy iface */ .phy_address = CONFIG_PFE_EMAC2_PHY_ADDR, - .phy_mode = PHY_INTERFACE_MODE_RGMII_TXID, + .phy_mode = PHY_INTERFACE_MODE_RGMII_ID, }, };
Chaitanya Sakinam
