[PATCH] spi: dw: Use controller clock rate as maximum frequency
Currently the controller driver has maximum frequency in plat->frequency that is specified by "spi-max-frequency" DT property in the controller node. This is special to U-Boot and doesn't exist to Linux.
spi { spi-max-frequency = <A>; };
Usually the frequency should be specified by "spi-max-frequency" at the slave device node.
spi { slave { spi-max-frequency = <B>; }; };
The final maximum frequency is set to the smaller value of the controller node (A) and the slave device node (B).
Currently, if the property in the controller node is omitted, the default frequency is fixed at 500kHz. Even if the controller and the slave device allow the higher frequency than 500kHz, the maximum frequency can't exceed 500kHz.
The upper limit of the maximum frequency should be determined by the clock rate of the controller clock. And this patch determines the maximum frequency based on the clock rate if the controller node property isn't specified.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/spi/designware_spi.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c index 1c7d0ca310b6..637ea57eba24 100644 --- a/drivers/spi/designware_spi.c +++ b/drivers/spi/designware_spi.c @@ -250,15 +250,13 @@ static int dw_spi_of_to_plat(struct udevice *bus) if (!plat->regs) return -EINVAL;
- /* Use 500KHz as a suitable default */ + /* Specify fixed max-frequency as default */ plat->frequency = dev_read_u32_default(bus, "spi-max-frequency", - 500000); + 0);
if (dev_read_bool(bus, "spi-slave")) return -EINVAL;
- dev_info(bus, "max-frequency=%d\n", plat->frequency); - return request_gpio_cs(bus); }
@@ -362,12 +360,17 @@ static int dw_spi_probe(struct udevice *bus) u32 version;
priv->regs = plat->regs; - priv->freq = plat->frequency;
ret = dw_spi_get_clk(bus, &priv->bus_clk_rate); if (ret) return ret;
+ if (!plat->frequency) + plat->frequency = priv->bus_clk_rate; + + dev_info(bus, "max-frequency=%d\n", plat->frequency); + priv->freq = plat->frequency; + ret = dw_spi_reset(bus); if (ret) return ret;
On Wed, Oct 25, 2023 at 1:20 PM Kunihiko Hayashi hayashi.kunihiko@socionext.com wrote:
Applied to u-boot-spi/master
Hi Jagan,
Sorry for the old response, I couldn't see this patch in the current master branch. Could you please apply this if it is missing?
Thank you,
--- Best Regards Kunihiko Hayashi
Jagan Teki
Kunihiko Hayashi
