[U-Boot] [PATCH] sc520: fix build warning about unused temp var
Building the eNET_SRAM board fails for me: sc520_timer.c: In function 'sc520_udelay': sc520_timer.c:81:7: error: variable 'temp' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors make[1]: *** [sc520_timer.o] Error 1
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/x86/cpu/sc520/sc520_timer.c | 5 ++--- 1 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/x86/cpu/sc520/sc520_timer.c b/arch/x86/cpu/sc520/sc520_timer.c index 495a694..41f121f 100644 --- a/arch/x86/cpu/sc520/sc520_timer.c +++ b/arch/x86/cpu/sc520/sc520_timer.c @@ -78,10 +78,9 @@ void sc520_udelay(unsigned long usec) { int m = 0; long u; - long temp;
- temp = readw(&sc520_mmcr->swtmrmilli); - temp = readw(&sc520_mmcr->swtmrmicro); + readw(&sc520_mmcr->swtmrmilli); + readw(&sc520_mmcr->swtmrmicro);
do { m += readw(&sc520_mmcr->swtmrmilli);
Hi Mike,
long temp;
- readw(&sc520_mmcr->swtmrmilli);
- readw(&sc520_mmcr->swtmrmicro);
I really appreciate the effort you (and others) have put into fixing this and I really should have made a more formal response earlier (sorry), but here goes...
Although this will fix the build warning, the actual implementation of sc520_udelay is wrong and can produce a timeout which is up to 1000us short (which I think we can all agree is a bad thing). On top of this, there is an sc520 silicon bug which means even a technically correct software implementation may produce erroneous results (although from memory that produces a timeout which could be 1000us long which is better than a short timeout)
And then there is the fact that this is a depricated platform - There is only one physical sc520 board which U-Boot has ever been loaded onto and that is buried on a shelf in my study somewhere - I'm working on another x86 board at the moment, but I'm not at liberty to release the code yet. As soon as that is released, I'm going to remove the sc520 anyway
So do I apply this to fix the build warning knowing there is another more serious bug and knowing this arch is getting scrapped soon, or do I just leave it as is?
Regards,
Graeme
long temp;
readw(&sc520_mmcr->swtmrmicro); do { m += readw(&sc520_mmcr->swtmrmilli);
considering this warning breaks `MAKEALL` testing, it's adding noise to people trying to verify their own unrelated changes. so yes, i think this fix should be merged, or the code dropped. leaving it in between is negatively affecting others. -mike
Hi Mike,
OK, I will apply a send a pull request hopefully tonight
Regards,
Graeme
Hi Mike,
Applied
Regards,
Graeme
Graeme Russ
Mike Frysinger
