[U-Boot] [PATCH 0/4] Add support for treating compiler warnings as errors
To enforce a zero-warnings policy (e.g. in CI builds), all compiler warnings have to be treated as errors.
Extend Kbuild and buildman with according options to achieve this. Enable these new options in all Travis CI builds. All builds with compiler warnings will now fail. Only DTC warnings are still being ignored.
Example build which failed due to a compiler warning: https://travis-ci.org/danielschwierzeck/u-boot/jobs/333349371#L936
Daniel Schwierzeck (4): Kbuild: support W=[N,]err for passing '-Werror' to the compiler buildman: add option -E for treating compiler warnings as errors travis.yml: fix 'set +e' in build script travis.yml: run buildman with option -E
.travis.yml | 5 ++--- scripts/Makefile.extrawarn | 3 +++ tools/buildman/builder.py | 5 ++++- tools/buildman/builderthread.py | 2 ++ tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 3 ++- 6 files changed, 15 insertions(+), 5 deletions(-)
Extend the Kbuild's W=N option with an optional 'err' value. This will pass -Werror to the compiler to treat all warnings as errors. This is useful to enforce a zero-warnings policy.
The 'err' value can also be combined with the numerical values like this:
make W=1 make W=err make W=1,err
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
scripts/Makefile.extrawarn | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/scripts/Makefile.extrawarn b/scripts/Makefile.extrawarn index 1d3a570594..d8d93b7fe1 100644 --- a/scripts/Makefile.extrawarn +++ b/scripts/Makefile.extrawarn @@ -48,9 +48,12 @@ warning-3 += -Wswitch-default warning-3 += $(call cc-option, -Wpacked-bitfield-compat) warning-3 += $(call cc-option, -Wvla)
+warning-err := -Werror + warning := $(warning-$(findstring 1, $(KBUILD_ENABLE_EXTRA_GCC_CHECKS))) warning += $(warning-$(findstring 2, $(KBUILD_ENABLE_EXTRA_GCC_CHECKS))) warning += $(warning-$(findstring 3, $(KBUILD_ENABLE_EXTRA_GCC_CHECKS))) +warning += $(warning-$(findstring err, $(KBUILD_ENABLE_EXTRA_GCC_CHECKS)))
ifeq ("$(strip $(warning))","") $(error W=$(KBUILD_ENABLE_EXTRA_GCC_CHECKS) is unknown)
Hi Daniel,
2018-01-26 2:21 GMT+09:00 Daniel Schwierzeck daniel.schwierzeck@gmail.com:
ifeq ("$(strip $(warning))","") $(error W=$(KBUILD_ENABLE_EXTRA_GCC_CHECKS) is unknown) -- 2.16.1
I saw a similar patch before in linux-kbuild ML.
Kbuild provides a way to specify user-specific options. See the following lines in the top-level Makefile:
# Add user supplied CPPFLAGS, AFLAGS and CFLAGS as the last assignments KBUILD_CPPFLAGS += $(KCPPFLAGS) KBUILD_AFLAGS += $(KAFLAGS) KBUILD_CFLAGS += $(KCFLAGS)
"make W=err" is a shorthand of "make KCFLAGS=-Werror", right?
I tend to hesitate to add another way to do the same thing...
Hi Masahiro,
On 26.01.2018 02:09, Masahiro Yamada wrote:
Hi Daniel,
I didn't noticed that possibility, thanks for the pointer. I'll withdraw this patch and add a short pointer in the README instead.
Add a new option '-E' for treating all compiler warnings as errors. Eventually this will pass 'W=err' to Kbuild.
tools/buildman/builder.py | 5 ++++- tools/buildman/builderthread.py | 2 ++ tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 3 ++- 4 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index acb0810457..4e72b7d60d 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -212,7 +212,8 @@ class Builder: gnu_make='make', checkout=True, show_unknown=True, step=1, no_subdirs=False, full_path=False, verbose_build=False, incremental=False, per_board_out_dir=False, - config_only=False, squash_config_y=False): + config_only=False, squash_config_y=False, + warnings_as_errors=False): """Create a new Builder object
Args: @@ -237,6 +238,7 @@ class Builder: board rather than a thread-specific directory config_only: Only configure each build, don't build it squash_config_y: Convert CONFIG options with the value 'y' to '1' + warnings_as_errors: Treat all compiler warnings as errors """ self.toolchains = toolchains self.base_dir = base_dir @@ -270,6 +272,7 @@ class Builder: if not self.squash_config_y: self.config_filenames += EXTRA_CONFIG_FILENAMES
+ self.warnings_as_errors = warnings_as_errors self.col = terminal.Color()
self._re_function = re.compile('(.*): In function.*') diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index 9e8ca80c5b..4ce3f48c66 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -216,6 +216,8 @@ class BuilderThread(threading.Thread): args.append('-s') if self.builder.num_jobs is not None: args.extend(['-j', str(self.builder.num_jobs)]) + if self.builder.warnings_as_errors: + args.append('W=err') config_args = ['%s_defconfig' % brd.target] config_out = '' args.extend(self.builder.toolchains.GetMakeArguments(brd)) diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index 74247f0aff..6949d6bf2c 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -32,6 +32,8 @@ def ParseArgs(): help="Don't build, just configure each commit") parser.add_option('-e', '--show_errors', action='store_true', default=False, help='Show errors and warnings') + parser.add_option('-E', '--warnings-as-errors', action='store_true', + default=False, help='Treat all compiler warnings as errors') parser.add_option('-f', '--force-build', dest='force_build', action='store_true', default=False, help='Force build of boards even if already built') diff --git a/tools/buildman/control.py b/tools/buildman/control.py index 73b1a14fb6..3cac9f7cf6 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -263,7 +263,8 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None, incremental=options.incremental, per_board_out_dir=options.per_board_out_dir, config_only=options.config_only, - squash_config_y=not options.preserve_config_y) + squash_config_y=not options.preserve_config_y, + warnings_as_errors=options.warnings_as_errors) builder.force_config_on_failure = not options.quick if make_func: builder.do_make = make_func
`On 25 January 2018 at 10:21, Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
nit: I read 'eventually' as 'in a future patch'
How about 'This will cause buildman to pass ...' ?
The build script should not manipulate shell flags (especially '-e'). A non-zero exit value can also be catched with 'cmd || ret=$?'.
.travis.yml | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 2a98c4bb11..1e55e1b7f1 100644 --- a/.travis.yml +++ b/.travis.yml @@ -101,9 +101,8 @@ script: # # Exit code 129 means warnings only. - if [[ "${BUILDMAN}" != "" ]]; then - set +e; - tools/buildman/buildman -P ${BUILDMAN}; - ret=$?; + ret=0; + tools/buildman/buildman -P ${BUILDMAN} || ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret;
This forces all compiler warnings to be treated as errors.
.travis.yml | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/.travis.yml b/.travis.yml index 1e55e1b7f1..59d1dd99e8 100644 --- a/.travis.yml +++ b/.travis.yml @@ -102,7 +102,7 @@ script: # Exit code 129 means warnings only. - if [[ "${BUILDMAN}" != "" ]]; then ret=0; - tools/buildman/buildman -P ${BUILDMAN} || ret=$?; + tools/buildman/buildman -P -E ${BUILDMAN} || ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret;
But just checking that this actually passes at present?
Daniel Schwierzeck
Masahiro Yamada
