[U-Boot] [PATCH v2] arm64: mvebu: fix crash in EFI memory allocation
EFI memory allocation code return values that are not mapped by U-Boot MMU. This causes a crash when tftp calls efi_set_bootdev(). Fix this similarly to commit 0797f7f0b7e1 ("ARM: tegra: reserve unmapped RAM so EFI doesn't use it").
Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: Fix the CONFIG_NR_DRAM_BANKS=1 case --- arch/arm/mach-mvebu/arm64-common.c | 13 ++----------- arch/arm/mach-mvebu/include/mach/cpu.h | 9 +++++++++ board/Marvell/mvebu_armada-8k/board.c | 17 +++++++++++++++++ 3 files changed, 28 insertions(+), 11 deletions(-)
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index 47bbf69944ec..b82f33093a2c 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -17,19 +17,10 @@
DECLARE_GLOBAL_DATA_PTR;
-/* - * Not all memory is mapped in the MMU. So we need to restrict the - * memory size so that U-Boot does not try to access it. Also, the - * internal registers are located at 0xf000.0000 - 0xffff.ffff. - * Currently only 2GiB are mapped for system memory. This is what - * we pass to the U-Boot subsystem here. - */ -#define USABLE_RAM_SIZE 0x80000000 - ulong board_get_usable_ram_top(ulong total_size) { - if (gd->ram_size > USABLE_RAM_SIZE) - return USABLE_RAM_SIZE; + if (gd->ram_size > MVEBU_ARM64_USABLE_RAM_SIZE) + return MVEBU_ARM64_USABLE_RAM_SIZE;
return gd->ram_size; } diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index 85d7dd1610a8..e22a14977859 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -177,5 +177,14 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info); */ u32 get_ref_clk(void);
+/* + * Not all memory is mapped in the MMU. So we need to restrict the + * memory size so that U-Boot does not try to access it. Also, the + * internal registers are located at 0xf000.0000 - 0xffff.ffff. + * Currently only 2GiB are mapped for system memory. This is what + * we pass to the U-Boot subsystem in board_get_usable_ram_top(). + */ +#define MVEBU_ARM64_USABLE_RAM_SIZE 0x80000000 + #endif /* __ASSEMBLY__ */ #endif /* _MVEBU_CPU_H */ diff --git a/board/Marvell/mvebu_armada-8k/board.c b/board/Marvell/mvebu_armada-8k/board.c index e927e338ea6e..86f9d8a4a424 100644 --- a/board/Marvell/mvebu_armada-8k/board.c +++ b/board/Marvell/mvebu_armada-8k/board.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <i2c.h> +#include <efi_loader.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> @@ -154,6 +155,22 @@ int board_init(void)
int board_late_init(void) { + uint64_t unmapped_ram_start = gd->bd->bi_dram[0].start + + MVEBU_ARM64_USABLE_RAM_SIZE; + uint64_t unmapped_ram_size = gd->bd->bi_dram[0].size + - MVEBU_ARM64_USABLE_RAM_SIZE; + +#if CONFIG_IS_ENABLED(EFI_LOADER) + if (gd->bd->bi_dram[0].size > MVEBU_ARM64_USABLE_RAM_SIZE) + efi_add_memory_map(unmapped_ram_start, + unmapped_ram_size >> EFI_PAGE_SHIFT, + EFI_BOOT_SERVICES_DATA, false); + if (CONFIG_NR_DRAM_BANKS > 1 && gd->bd->bi_dram[1].start) + efi_add_memory_map(gd->bd->bi_dram[1].start, + gd->bd->bi_dram[1].size >> EFI_PAGE_SHIFT, + EFI_BOOT_SERVICES_DATA, false); +#endif + /* Pre-configure the USB ports (overcurrent, VBus) */ board_xhci_config();
Baruch Siach
