[U-Boot] [PATCH] README: clean up and document the Freescale QE/FMAN firmware macros
The Freescale QE and FMAN devices support uploading of firmware, and U-Boot can locate that firmware on different types of storage media. However, the current macros used for this code are inconsistent and poorly documented.
Note that some of the code managed by these macros have not yet been posted externally. Such code will be posted, but properly documenting the macros is the first step.
Signed-off-by: Timur Tabi timur@freescale.com --- README | 38 ++++++++++++++++++++++++++++++++++++++ 1 files changed, 38 insertions(+), 0 deletions(-)
diff --git a/README b/README index 0886987..f47cea1 100644 --- a/README +++ b/README @@ -3124,6 +3124,44 @@ Low Level (hardware related) configuration options: be used if available. These functions may be faster under some conditions but may increase the binary size.
+Freescale QE/FMAN Firmware Support: +----------------------------------- + +The Freescale QUICCEngine (QE) and Frame Manager (FMAN) both support the +loading of "firmware", which is encoded in the QE firmware binary format. +This firmware often needs to be loaded during U-Boot booting, so macros +are used to identify the storage device (NOR flash, SPI, etc) and the address +within that device. + +- CONFIG_SYS_FMAN_FW_ADDR + The address in the storage device where the firmware is located. The + meaning of this address depends on which CONFIG_SYS_QE_FW_IN_xxx macro + is also specified. + +- CONFIG_SYS_FMAN_FW_LENGTH + The maximum possible size of the firmware. The firmware binary format + has a field that specifies the actual size of the firmware, but it + might not be possible to read any part of the firmware unless some + local storage is allocated to hold the entire firmware first. + +- CONFIG_SYS_QE_FW_IN_NOR + Specifies that QE/FMAN firmware is located in NOR flash, mapped as + normal addressable memory via the LBC. CONFIG_SYS_FMAN_FW_ADDR is the + virtual address in NOR flash. + +- CONFIG_SYS_QE_FW_IN_NAND + Specifies that QE/FMAN firmware is located in NAND flash. + CONFIG_SYS_FMAN_FW_ADDR is the offset within NAND flash. + +- CONFIG_SYS_QE_FW_IN_MMC + Specifies that QE/FMAN firmware is located on the primary SD/MMC + device. CONFIG_SYS_FMAN_FW_ADDR is the byte offset on that device. + +- CONFIG_SYS_QE_FW_IN_SPIFLASH + Specifies that QE/FMAN firmware is located on the primary SPI + device. CONFIG_SYS_FMAN_FW_ADDR is the byte offset on that device. + + Building the Software: ======================
Wolfgang, if you're okay with the text in this patch, I will go ahead and make the corresponding changes to the code. I just want to make sure that there are no objections to these definitions before I work on the code itself.
Dear Tabi Timur-B04825,
In message CAOZdJXUUp6tA_J=_cvVDcd3bfqJMyYTg2s1DTX5mO2fWATNogA@mail.gmail.com you wrote:
s/have/has/ ?
Sorry, but I don't even understand this. What does "post externally" mean?
And why don't you add the documentation with the code?
s/have/has/ ?
Thanks.
Sorry, that's a term we use in Freescale. We have in-house code that has not yet been posted on this mailing list for the "official" U-Boot. That's what I mean by posting externally. I guess I need a better term for that. We also call that "upstream".
I haven't written the code yet. I want to make sure the idea is acceptable before I start implementing it. Plus, since our internal code is different than our "external" code, I need to manage both code bases independently.
Dear Timur Tabi,
I cannot comment on code or features I haven't seen yet. I suggest you submit the documentation when you submit the code.
Tabi Timur-B04825
Timur Tabi
