[U-Boot] [PATCH 06/22] ppc4xx: remove DP405 board
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- arch/powerpc/cpu/ppc4xx/Kconfig | 4 - board/esd/dp405/Kconfig | 12 -- board/esd/dp405/MAINTAINERS | 6 - board/esd/dp405/Makefile | 13 --- board/esd/dp405/dp405.c | 112 ------------------ board/esd/dp405/flash.c | 85 -------------- configs/DP405_defconfig | 3 - doc/README.scrapyard | 2 + include/configs/DP405.h | 246 --------------------------------------- 9 files changed, 2 insertions(+), 481 deletions(-) delete mode 100644 board/esd/dp405/Kconfig delete mode 100644 board/esd/dp405/MAINTAINERS delete mode 100644 board/esd/dp405/Makefile delete mode 100644 board/esd/dp405/dp405.c delete mode 100644 board/esd/dp405/flash.c delete mode 100644 configs/DP405_defconfig delete mode 100644 include/configs/DP405.h
diff --git a/arch/powerpc/cpu/ppc4xx/Kconfig b/arch/powerpc/cpu/ppc4xx/Kconfig index e428d0e..e0eef94 100644 --- a/arch/powerpc/cpu/ppc4xx/Kconfig +++ b/arch/powerpc/cpu/ppc4xx/Kconfig @@ -125,9 +125,6 @@ config TARGET_CPCI405AB config TARGET_CPCI405DT bool "Support CPCI405DT"
-config TARGET_DP405 - bool "Support DP405" - config TARGET_DU405 bool "Support DU405"
@@ -244,7 +241,6 @@ source "board/csb472/Kconfig" source "board/dave/PPChameleonEVB/Kconfig" source "board/esd/cpci2dp/Kconfig" source "board/esd/cpci405/Kconfig" -source "board/esd/dp405/Kconfig" source "board/esd/du405/Kconfig" source "board/esd/du440/Kconfig" source "board/esd/hh405/Kconfig" diff --git a/board/esd/dp405/Kconfig b/board/esd/dp405/Kconfig deleted file mode 100644 index c0163ae..0000000 --- a/board/esd/dp405/Kconfig +++ /dev/null @@ -1,12 +0,0 @@ -if TARGET_DP405 - -config SYS_BOARD - default "dp405" - -config SYS_VENDOR - default "esd" - -config SYS_CONFIG_NAME - default "DP405" - -endif diff --git a/board/esd/dp405/MAINTAINERS b/board/esd/dp405/MAINTAINERS deleted file mode 100644 index 6833d8c..0000000 --- a/board/esd/dp405/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -DP405 BOARD -M: Matthias Fuchs matthias.fuchs@esd-electronics.com -S: Maintained -F: board/esd/dp405/ -F: include/configs/DP405.h -F: configs/DP405_defconfig diff --git a/board/esd/dp405/Makefile b/board/esd/dp405/Makefile deleted file mode 100644 index cfcfb66..0000000 --- a/board/esd/dp405/Makefile +++ /dev/null @@ -1,13 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# Objects for Xilinx JTAG programming (CPLD) -CPLD = ../common/xilinx_jtag/lenval.o \ - ../common/xilinx_jtag/micro.o \ - ../common/xilinx_jtag/ports.o - -obj-y = dp405.o flash.o ../common/misc.o $(CPLD) diff --git a/board/esd/dp405/dp405.c b/board/esd/dp405/dp405.c deleted file mode 100644 index 730ff21..0000000 --- a/board/esd/dp405/dp405.c +++ /dev/null @@ -1,112 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/processor.h> -#include <asm/io.h> -#include <command.h> -#include <malloc.h> - -DECLARE_GLOBAL_DATA_PTR; - -int board_early_init_f (void) -{ - /* - * IRQ 0-15 405GP internally generated; active high; level sensitive - * IRQ 16 405GP internally generated; active low; level sensitive - * IRQ 17-24 RESERVED - * IRQ 25 (EXT IRQ 0) CAN0; active low; level sensitive - * IRQ 26 (EXT IRQ 1) SER0 ; active low; level sensitive - * IRQ 27 (EXT IRQ 2) SER1; active low; level sensitive - * IRQ 28 (EXT IRQ 3) FPGA 0; active low; level sensitive - * IRQ 29 (EXT IRQ 4) FPGA 1; active low; level sensitive - * IRQ 30 (EXT IRQ 5) PCI INTA; active low; level sensitive - * IRQ 31 (EXT IRQ 6) COMPACT FLASH; active high; level sensitive - */ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - mtdcr(UIC0ER, 0x00000000); /* disable all ints */ - mtdcr(UIC0CR, 0x00000000); /* set all to be non-critical*/ - mtdcr(UIC0PR, 0xFFFFFF80); /* set int polarities */ - mtdcr(UIC0TR, 0x10000000); /* set int trigger levels */ - mtdcr(UIC0VCR, 0x00000001); /* set vect base=0,INT0 highest priority*/ - mtdcr(UIC0SR, 0xFFFFFFFF); /* clear all ints */ - - /* - * EBC Configuration Register: set ready timeout to 512 ebc-clks -> ca. 15 us - */ - mtebc (EBC0_CFG, 0xa8400000); /* ebc always driven */ - - /* - * Reset CPLD via GPIO13 (CS4) pin - */ - out_be32((void *)GPIO0_OR, - in_be32((void *)GPIO0_OR) & ~(0x80000000 >> 13)); - udelay(1000); /* wait 1ms */ - out_be32((void *)GPIO0_OR, - in_be32((void *)GPIO0_OR) | (0x80000000 >> 13)); - udelay(1000); /* wait 1ms */ - - return 0; -} - -int misc_init_r (void) -{ - /* adjust flash start and offset */ - gd->bd->bi_flashstart = 0 - gd->bd->bi_flashsize; - gd->bd->bi_flashoffset = 0; - - return (0); -} - - -/* - * Check Board Identity: - */ - -int checkboard (void) -{ - char str[64]; - int i = getenv_f("serial#", str, sizeof(str)); - unsigned char trans[16] = {0x0,0x8,0x4,0xc,0x2,0xa,0x6,0xe, - 0x1,0x9,0x5,0xd,0x3,0xb,0x7,0xf}; - unsigned char id1, id2, rev; - - puts ("Board: "); - - if (i == -1) - puts ("### No HW ID - assuming DP405"); - else - puts(str); - - id1 = trans[(~(in_be32((void *)GPIO0_IR) >> 5)) & 0x0000000f]; - id2 = trans[(~(in_be32((void *)GPIO0_IR) >> 9)) & 0x0000000f]; - - rev = in_8((void *)0xf0001000); - if (rev & 0x10) /* old DP405 compatibility */ - rev = in_8((void *)0xf0000800); - - switch (rev & 0xc0) { - case 0x00: - puts(" (HW=DP405"); - break; - case 0x80: - puts(" (HW=DP405/CO"); - break; - case 0xc0: - puts(" (HW=DN405"); - break; - } - printf(", ID=0x%1X%1X, PLD=0x%02X", id2, id1, rev & 0x0f); - - if ((rev & 0xc0) == 0xc0) { - printf(", C5V=%s", - in_be32((void *)GPIO0_IR) & 0x40000000 ? "off" : "on"); - } - puts(")\n"); - - return 0; -} diff --git a/board/esd/dp405/flash.c b/board/esd/dp405/flash.c deleted file mode 100644 index 23e8164..0000000 --- a/board/esd/dp405/flash.c +++ /dev/null @@ -1,85 +0,0 @@ -/* - * (C) Copyright 2001 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/ppc4xx.h> -#include <asm/processor.h> - -/* - * include common flash code (for esd boards) - */ -#include "../common/flash.c" - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long * addr, flash_info_t * info); -static void flash_get_offsets (ulong base, flash_info_t * info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - unsigned long size_b0; - int i; - uint pbcr; - unsigned long base_b0; - int size_val = 0; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size_b0 = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size_b0, size_b0<<20); - } - - /* Setup offsets */ - flash_get_offsets (-size_b0, &flash_info[0]); - - /* Re-do sizing to get full correct info */ - mtdcr(EBC0_CFGADDR, PB0CR); - pbcr = mfdcr(EBC0_CFGDATA); - mtdcr(EBC0_CFGADDR, PB0CR); - base_b0 = -size_b0; - switch (size_b0) { - case 1 << 20: - size_val = 0; - break; - case 2 << 20: - size_val = 1; - break; - case 4 << 20: - size_val = 2; - break; - case 8 << 20: - size_val = 3; - break; - case 16 << 20: - size_val = 4; - break; - } - pbcr = (pbcr & 0x0001ffff) | base_b0 | (size_val << 17); - mtdcr(EBC0_CFGDATA, pbcr); - - /* Monitor protection ON by default */ - (void)flash_protect(FLAG_PROTECT_SET, - -CONFIG_SYS_MONITOR_LEN, - 0xffffffff, - &flash_info[0]); - - flash_info[0].size = size_b0; - - return (size_b0); -} diff --git a/configs/DP405_defconfig b/configs/DP405_defconfig deleted file mode 100644 index 4d48276..0000000 --- a/configs/DP405_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_4xx=y -CONFIG_TARGET_DP405=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 4677b6b..6f7598f 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,6 +12,8 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= +DP405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu +CPCIISER4 ppc4xx 405gp - - Matthias Fuchs matthias.fuchs@esd.eu CMS700 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu ASH405 ppc4xx 405ep - - Matthias Fuchs matthias.fuchs@esd.eu AR405 ppc4xx 405gpr - - Matthias Fuchs matthias.fuchs@esd.eu diff --git a/include/configs/DP405.h b/include/configs/DP405.h deleted file mode 100644 index 68e4a7f..0000000 --- a/include/configs/DP405.h +++ /dev/null @@ -1,246 +0,0 @@ -/* - * (C) Copyright 2001-2003 - * Stefan Roese, esd gmbh germany, stefan.roese@esd-electronics.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_405EP 1 /* This is a PPC405 CPU */ -#define CONFIG_DP405 1 /* ...on a DP405 board */ - -#define CONFIG_SYS_TEXT_BASE 0xFFFD0000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 /* call board_early_init_f() */ -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r() */ - -#define CONFIG_SYS_CLK_FREQ 33333300 /* external frequency to pll */ - -#define CONFIG_BAUDRATE 9600 -#define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */ - -#undef CONFIG_BOOTARGS -#undef CONFIG_BOOTCOMMAND - -#define CONFIG_PREBOOT /* enable preboot variable */ - -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_BSP -#define CONFIG_CMD_ELF -#define CONFIG_CMD_I2C -#define CONFIG_CMD_EEPROM - -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_NFS - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ - -#define CONFIG_PRAM 2 /* reserve 2 kB "protected RAM" */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ - -#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ - -#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup*/ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_CONS_INDEX 1 /* Use UART0 */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* no external serial clock used */ -#define CONFIG_SYS_BASE_BAUD 691200 - -/* The following table includes the supported baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE \ - { 300, 600, 1200, 2400, 4800, 9600, 19200, 38400, \ - 57600, 115200, 230400, 460800, 921600 } - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ -#define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */ - -#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ - -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define FLASH_BASE0_PRELIM 0xFFC00000 /* FLASH bank #0 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1000 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_SYS_FLASH_WORD_SIZE unsigned short /* flash word size (width) */ -#define CONFIG_SYS_FLASH_ADDR0 0x5555 /* 1st address for flash config cycles */ -#define CONFIG_SYS_FLASH_ADDR1 0x2AAA /* 2nd address for flash config cycles */ -/* - * The following defines are added for buggy IOP480 byte interface. - * All other boards should use the standard values (CPCI405 etc.) - */ -#define CONFIG_SYS_FLASH_READ0 0x0000 /* 0 is standard */ -#define CONFIG_SYS_FLASH_READ1 0x0001 /* 1 is standard */ -#define CONFIG_SYS_FLASH_READ2 0x0002 /* 2 is standard */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_MONITOR_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_SYS_MONITOR_LEN (~(CONFIG_SYS_TEXT_BASE) + 1) -#define CONFIG_SYS_MALLOC_LEN (256 * 1024) - -#if (CONFIG_SYS_MONITOR_BASE < FLASH_BASE0_PRELIM) -# define CONFIG_SYS_RAMBOOT 1 -#else -# undef CONFIG_SYS_RAMBOOT -#endif - -/*----------------------------------------------------------------------- - * Environment Variable setup - */ -#define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ -#define CONFIG_ENV_OFFSET 0x100 /* environment starts at the beginning of the EEPROM */ -#define CONFIG_ENV_SIZE 0x700 /* 2048 bytes may be used for env vars*/ - /* total size of a CAT24WC16 is 2048 bytes */ - -/*----------------------------------------------------------------------- - * I2C EEPROM (CAT24WC16) for environment - */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_PPC4XX -#define CONFIG_SYS_I2C_PPC4XX_CH0 -#define CONFIG_SYS_I2C_PPC4XX_SPEED_0 400000 -#define CONFIG_SYS_I2C_PPC4XX_SLAVE_0 0x7F - -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM CAT28WC08 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ -/* mask of address bits that overflow into the "EEPROM chip address" */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 0x07 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 4 /* The Catalyst CAT24WC08 has */ - /* 16 byte page write mode using*/ - /* last 4 bits of the address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ - -/*----------------------------------------------------------------------- - * External Bus Controller (EBC) Setup - */ - -#define CAN_BA 0xF0000000 /* CAN Base Address */ - -/* Memory Bank 0 (Flash Bank 0, NOR-FLASH) initialization */ -#define CONFIG_SYS_EBC_PB0AP 0x92015480 -#define CONFIG_SYS_EBC_PB0CR 0xFFC5A000 /* BAS=0xFFC,BS=4MB,BU=R/W,BW=16bit */ - -/* Memory Bank 2 (8 Bit Peripheral: CAN, UART, RTC) initialization */ -#define CONFIG_SYS_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ -#define CONFIG_SYS_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */ - -/*----------------------------------------------------------------------- - * FPGA stuff - */ -/* FPGA program pin configuration */ -#define CONFIG_SYS_FPGA_PRG 0x04000000 /* JTAG TMS pin (ppc output) */ -#define CONFIG_SYS_FPGA_CLK 0x02000000 /* JTAG TCK pin (ppc output) */ -#define CONFIG_SYS_FPGA_DATA 0x01000000 /* JTAG TDO->TDI data pin (ppc output) */ -#define CONFIG_SYS_FPGA_INIT 0x00010000 /* unused (ppc input) */ -#define CONFIG_SYS_FPGA_DONE 0x00008000 /* JTAG TDI->TDO pin (ppc input) */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in data cache) - */ -/* use on chip memory ( OCM ) for temperary stack until sdram is tested */ -#define CONFIG_SYS_TEMP_STACK_OCM 1 - -/* On Chip Memory location */ -#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 -#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ -#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE /* Size of used area in RAM */ - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Definitions for GPIO setup (PPC405EP specific) - * - * GPIO0[0] - External Bus Controller BLAST output - * GPIO0[1-9] - Instruction trace outputs -> GPIO - * GPIO0[10-13] - External Bus Controller CS_1 - CS_4 outputs - * GPIO0[14-16] - External Bus Controller ABUS3-ABUS5 outputs -> GPIO - * GPIO0[17-23] - External Interrupts IRQ0 - IRQ6 inputs - * GPIO0[24-27] - UART0 control signal inputs/outputs - * GPIO0[28-29] - UART1 data signal input/output - * GPIO0[30-31] - EMAC0 and EMAC1 reject packet inputs - */ -/* GPIO Input: OSR=00, ISR=00, TSR=00, TCR=0 */ -/* GPIO Output: OSR=00, ISR=00, TSR=00, TCR=1 */ -/* Alt. Funtion Input: OSR=00, ISR=01, TSR=00, TCR=0 */ -/* Alt. Funtion Output: OSR=01, ISR=00, TSR=00, TCR=1 */ -#define CONFIG_SYS_GPIO0_OSRL 0x40000540 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_OSRH 0x00000110 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_ISR1L 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_ISR1H 0x14000045 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_TSRL 0x00000000 /* 0 ... 15 */ -#define CONFIG_SYS_GPIO0_TSRH 0x00000000 /* 16 ... 31 */ -#define CONFIG_SYS_GPIO0_TCR 0xB7FE0014 /* 0 ... 31 */ - -/* - * Default speed selection (cpu_plb_opb_ebc) in mhz. - * This value will be set if iic boot eprom is disabled. - */ -#define PLLMR0_DEFAULT PLLMR0_133_66_66_33 -#define PLLMR1_DEFAULT PLLMR1_133_66_66_33 - -#endif /* __CONFIG_H */
Matthias Fuchs
