[U-Boot] [PATCH 1/5] fdt: add fdt_del_node_by_path() API
For removing node easily by path or alias.
Signed-off-by: Li Yang leoli@freescale.com --- common/fdt_support.c | 10 ++++++++++ include/fdt_support.h | 1 + 2 files changed, 11 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index f89a3ee..8f1186e 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -757,3 +757,13 @@ int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size) return -1; } #endif + +int fdt_del_node_by_path(void *fdt, const char *path) +{ + int off = fdt_path_offset(fdt, path); + + if (off >= 0) + return fdt_del_node(fdt, off); + else + return off; +} diff --git a/include/fdt_support.h b/include/fdt_support.h index 0a9dd0d..d0705d1 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -80,6 +80,7 @@ void set_working_fdt_addr(void *addr); int fdt_resize(void *blob);
int fdt_fixup_nor_flash_size(void *blob, int cs, u32 size); +int fdt_del_node_by_path(void *fdt, const char *path);
#endif /* ifdef CONFIG_OF_LIBFDT */ #endif /* ifndef __FDT_SUPPORT_H */
Signed-off-by: Li Yang leoli@freescale.com --- include/asm-ppc/fsl_law.h | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/fsl_law.h b/include/asm-ppc/fsl_law.h index 31bb754..34c56a2 100644 --- a/include/asm-ppc/fsl_law.h +++ b/include/asm-ppc/fsl_law.h @@ -46,6 +46,8 @@ enum law_size { LAW_SIZE_32G, };
+#define law_size_bits(sz) (__ilog2_u64(sz) - 1) + #ifdef CONFIG_FSL_CORENET enum law_trgt_if { LAW_TRGT_IF_PCIE_1 = 0x00, @@ -78,6 +80,7 @@ enum law_trgt_if { LAW_TRGT_IF_CCSR = 0x08, LAW_TRGT_IF_DDR_INTRLV = 0x0b, LAW_TRGT_IF_RIO = 0x0c, + LAW_TRGT_IF_RIO_2 = 0x0d, LAW_TRGT_IF_DDR = 0x0f, LAW_TRGT_IF_DDR_2 = 0x16, /* 2nd controller */ };
Add common board configuration code which uses serdes configuration information gotten from common fsl_serdes APIs to initialize peripheral ports like PCIE, SGMII and SRIO. Disable unused block when not configured.
Also update device trees to remove unused nodes to prevent these devices/buses being initialized in kernel.
Signed-off-by: Li Yang leoli@freescale.com --- cpu/mpc85xx/Makefile | 1 + cpu/mpc85xx/cpu_init.c | 14 ++-- cpu/mpc85xx/serdes.c | 217 ++++++++++++++++++++++++++++++++++++++++++ include/asm-ppc/fsl_serdes.h | 50 ++++++++++ 4 files changed, 275 insertions(+), 7 deletions(-) create mode 100644 cpu/mpc85xx/serdes.c
diff --git a/cpu/mpc85xx/Makefile b/cpu/mpc85xx/Makefile index 56de7eb..018ebc9 100644 --- a/cpu/mpc85xx/Makefile +++ b/cpu/mpc85xx/Makefile @@ -62,6 +62,7 @@ COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o COBJS-$(CONFIG_PCI) += pci.o COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o +COBJS-$(CONFIG_FSL_SERDES) += serdes.o
COBJS = $(COBJS-y) COBJS += cpu.o diff --git a/cpu/mpc85xx/cpu_init.c b/cpu/mpc85xx/cpu_init.c index 0041a60..05133d3 100644 --- a/cpu/mpc85xx/cpu_init.c +++ b/cpu/mpc85xx/cpu_init.c @@ -33,14 +33,11 @@ #include <asm/io.h> #include <asm/mmu.h> #include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> #include "mp.h"
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_MPC8536 -extern void fsl_serdes_init(void); -#endif - #ifdef CONFIG_QE extern qe_iop_conf_t qe_iop_conf_tab[]; extern void qe_config_iopin(u8 port, u8 pin, int dir, @@ -237,9 +234,7 @@ void cpu_init_f (void) /* Config QE ioports */ config_qe_ioports(); #endif -#if defined(CONFIG_MPC8536) - fsl_serdes_init(); -#endif + #if defined(CONFIG_FSL_DMA) dma_init(); #endif @@ -374,6 +369,11 @@ int cpu_init_r(void) qe_reset(); #endif
+ /* XXX: remove MPC8536 eventually */ +#if defined(CONFIG_FSL_SERDES) || defined(CONFIG_MPC8536) + fsl_serdes_init(); +#endif + #if defined(CONFIG_MP) setup_mp(); #endif diff --git a/cpu/mpc85xx/serdes.c b/cpu/mpc85xx/serdes.c new file mode 100644 index 0000000..87ec221 --- /dev/null +++ b/cpu/mpc85xx/serdes.c @@ -0,0 +1,217 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_pci.h> + +#ifdef CONFIG_PCIE1 +static struct pci_controller pcie1_hose; +#endif + +#ifdef CONFIG_PCIE2 +static struct pci_controller pcie2_hose; +#endif + +#ifdef CONFIG_PCIE3 +static struct pci_controller pcie3_hose; +#endif + +void mpc85xx_serdes_board_init(void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct fsl_pci_info pci_info[3]; + u32 devdisr, host_agent; + int first_free_busno = 0; + int num = 0; + int rio = 0; + + int pcie_ep; + + devdisr = in_be32(&gur->devdisr); + host_agent = (in_be32(&gur->porbmsr) & MPC85xx_PORBMSR_HA) >> 16; + + debug(" mpc85xx_serdes_board_init: devdisr=%x, host_agent=%x\n", + devdisr, host_agent); + + if (is_serdes_configured(SGMII_TSEC1)) + puts(" eTSEC1 is in sgmii mode.\n"); + if (is_serdes_configured(SGMII_TSEC2)) + puts(" eTSEC2 is in sgmii mode.\n"); + if (is_serdes_configured(SGMII_TSEC3)) + puts(" eTSEC3 is in sgmii mode.\n"); + + puts("\n"); +#ifdef CONFIG_PCIE1 + pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); + + if (is_serdes_configured(PCIE1) && !(devdisr & MPC85xx_DEVDISR_PCIE)) { + set_next_law(CONFIG_SYS_PCIE1_MEM_PHYS, + law_size_bits(CONFIG_SYS_PCIE1_MEM_SIZE), + LAW_TRGT_IF_PCIE_1); + set_next_law(CONFIG_SYS_PCIE1_IO_PHYS, + law_size_bits(CONFIG_SYS_PCIE1_IO_SIZE), + LAW_TRGT_IF_PCIE_1); + + SET_STD_PCIE_INFO(pci_info[num], 1); + printf(" PCIE1 used as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); + } else { + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); + printf(" PCIE1: disabled\n"); + } + puts("\n"); +#else + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ +#endif + +#ifdef CONFIG_PCIE2 + pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); + + if (is_serdes_configured(PCIE2) && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ + set_next_law(CONFIG_SYS_PCIE2_MEM_PHYS, + law_size_bits(CONFIG_SYS_PCIE2_MEM_SIZE), + LAW_TRGT_IF_PCIE_2); + set_next_law(CONFIG_SYS_PCIE2_IO_PHYS, + law_size_bits(CONFIG_SYS_PCIE2_IO_SIZE), + LAW_TRGT_IF_PCIE_2); + + SET_STD_PCIE_INFO(pci_info[num], 2); + printf(" PCIE2 used as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie2_hose, first_free_busno); + + } else { + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); + printf(" PCIE2: disabled\n"); + } + puts("\n"); +#else + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ +#endif + +#ifdef CONFIG_PCIE3 + pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_3, host_agent); + + if (is_serdes_configured(PCIE3) && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ + set_next_law(CONFIG_SYS_PCIE3_MEM_PHYS, + law_size_bits(CONFIG_SYS_PCIE3_MEM_SIZE), + LAW_TRGT_IF_PCIE_3); + set_next_law(CONFIG_SYS_PCIE3_IO_PHYS, + law_size_bits(CONFIG_SYS_PCIE3_IO_SIZE), + LAW_TRGT_IF_PCIE_3); + + SET_STD_PCIE_INFO(pci_info[num], 3); + printf(" PCIE3 used as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie3_hose, first_free_busno); + } else { + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); + printf(" PCIE3: disabled\n"); + } + puts("\n"); +#else + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ +#endif + +#ifdef CONFIG_SRIO + if (is_serdes_configured(SRIO1) && !(devdisr & MPC85xx_DEVDISR_SRIO)){ + set_next_law(CONFIG_SYS_SRIO1_MEM_PHYS, + law_size_bits(CONFIG_SYS_SRIO1_MEM_SIZE), + LAW_TRGT_IF_RIO); + + rio = 1; + printf(" SRIO1 enabled\n"); + } else { + printf(" SRIO1: disabled\n"); + } + + if (is_serdes_configured(SRIO2) && !(devdisr & MPC85xx_DEVDISR_SRIO)){ + set_next_law(CONFIG_SYS_SRIO2_MEM_PHYS, + law_size_bits(CONFIG_SYS_SRIO2_MEM_SIZE), + LAW_TRGT_IF_RIO_2); + + printf(" SRIO2 enabled\n"); + } else { + printf(" SRIO2: disabled\n"); + if (rio == 0) + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_SRIO); + + } +#else + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_SRIO); /* disable */ +#endif +} + +void ft_mpc85xx_serdes_board_setup(void *blob) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 devdisr = in_be32(&gur->devdisr); + +#ifdef CONFIG_PCIE1 + if (devdisr & MPC85xx_DEVDISR_PCIE) + fdt_del_node_by_path(blob, PCIE1_ALIAS_NAME); + else + ft_fsl_pci_setup(blob, PCIE1_ALIAS_NAME, &pcie1_hose); +#else + fdt_del_node_by_path(blob, PCIE1_ALIAS_NAME); +#endif +#ifdef CONFIG_PCIE2 + if (devdisr & MPC85xx_DEVDISR_PCIE2) + fdt_del_node_by_path(blob, PCIE2_ALIAS_NAME); + else + ft_fsl_pci_setup(blob, PCIE2_ALIAS_NAME, &pcie2_hose); +#else + fdt_del_node_by_path(blob, PCIE2_ALIAS_NAME); +#endif +#ifdef CONFIG_PCIE3 + if (devdisr & MPC85xx_DEVDISR_PCIE3) + fdt_del_node_by_path(blob, PCIE3_ALIAS_NAME); + else + ft_fsl_pci_setup(blob, PCIE3_ALIAS_NAME, &pcie3_hose); +#else + fdt_del_node_by_path(blob, PCIE3_ALIAS_NAME); +#endif +#ifdef CONFIG_SRIO + if (devdisr & MPC85xx_DEVDISR_SRIO) { + fdt_del_node_by_path(blob, SRIO1_ALIAS_NAME); + fdt_del_node_by_path(blob, SRIO2_ALIAS_NAME); + } else { + if (!is_serdes_configured(SRIO1)) + fdt_del_node_by_path(blob, SRIO1_ALIAS_NAME); + if (!is_serdes_configured(SRIO2)) + fdt_del_node_by_path(blob, SRIO2_ALIAS_NAME); + } +#else + fdt_del_node_by_path(blob, SRIO1_ALIAS_NAME); + fdt_del_node_by_path(blob, SRIO2_ALIAS_NAME); +#endif +} diff --git a/include/asm-ppc/fsl_serdes.h b/include/asm-ppc/fsl_serdes.h index 6da4b6f..b75d736 100644 --- a/include/asm-ppc/fsl_serdes.h +++ b/include/asm-ppc/fsl_serdes.h @@ -3,6 +3,7 @@
#include <config.h>
+#ifdef CONFIG_MPC83xx #define FSL_SERDES_CLK_100 (0 << 28) #define FSL_SERDES_CLK_125 (1 << 28) #define FSL_SERDES_CLK_150 (3 << 28) @@ -17,5 +18,54 @@ extern void fsl_setup_serdes(u32 offset, char proto, u32 rfcks, char vdd); #else static void fsl_setup_serdes(u32 offset, char proto, u32 rfcks, char vdd) {} #endif /* CONFIG_FSL_SERDES */ +#endif /* CONFIG_MPC83xx */ + +#ifdef CONFIG_MPC85xx +enum srds_prtcl { + NONE = 0, + PCIE1, + PCIE2, + PCIE3, + SRIO1, + SRIO2, + SGMII_TSEC1, + SGMII_TSEC2, + SGMII_TSEC3, +}; + +#if defined(CONFIG_MPC8548) +#define PCIE1_ALIAS_NAME "pci2" +#elif defined(CONFIG_MPC8536) +#define PCIE1_ALIAS_NAME "pci3" +#define PCIE2_ALIAS_NAME "pci2" +#define PCIE3_ALIAS_NAME "pci1" +#else +#define PCIE1_ALIAS_NAME "pci2" +#define PCIE2_ALIAS_NAME "pci1" +#define PCIE3_ALIAS_NAME "pci0" +#endif + +#define SRIO1_ALIAS_NAME "rio0" +#define SRIO2_ALIAS_NAME "rio1" + +extern void mpc85xx_serdes_board_init(void); +extern void ft_mpc85xx_serdes_board_setup(void *blob); + +#ifdef CONFIG_FSL_SERDES +extern void fsl_serdes_init(void); +extern int is_serdes_configured(enum srds_prtcl prtcl); +#else + +/* XXX: MPC8536 should eventually use CONFIG_FSL_SERDES */ +#ifndef CONFIG_MPC8536 +void fsl_serdes_init(void) {} +#endif + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return 1; +} +#endif /* CONFIG_FSL_SERDES */ +#endif /* CONFIG_MPC85xx */
#endif /* __FSL_SERDES_H */
Signed-off-by: Li Yang leoli@freescale.com --- cpu/mpc85xx/Makefile | 1 + cpu/mpc85xx/p2020_serdes.c | 89 ++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 90 insertions(+), 0 deletions(-) create mode 100644 cpu/mpc85xx/p2020_serdes.c
diff --git a/cpu/mpc85xx/Makefile b/cpu/mpc85xx/Makefile index 018ebc9..457a45f 100644 --- a/cpu/mpc85xx/Makefile +++ b/cpu/mpc85xx/Makefile @@ -63,6 +63,7 @@ COBJS-$(CONFIG_PCI) += pci.o COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_CPM2) += serial_scc.o COBJS-$(CONFIG_FSL_SERDES) += serdes.o +COBJS-$(CONFIG_P2020) += p2020_serdes.o
COBJS = $(COBJS-y) COBJS += cpu.o diff --git a/cpu/mpc85xx/p2020_serdes.c b/cpu/mpc85xx/p2020_serdes.c new file mode 100644 index 0000000..f52d744 --- /dev/null +++ b/cpu/mpc85xx/p2020_serdes.c @@ -0,0 +1,89 @@ +/* + * Copyright 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/immap_85xx.h> +#include <asm/io.h> +#include <asm/fsl_serdes.h> + +#define SRDS_MAX_LANES 4 + +static int serdes_cfg; +static int serdes_prtcl_map = 0; + +u8 serdes_cfg_tbl[][SRDS_MAX_LANES] = { + [0] = {PCIE1, NONE, NONE, NONE}, + [1] = {NONE, NONE, NONE, NONE}, + [2] = {PCIE1, PCIE2, PCIE3, PCIE3}, + [4] = {PCIE1, PCIE1, PCIE3, PCIE3}, + [6] = {PCIE1, PCIE1, PCIE1, PCIE1}, + [7] = {SRIO2, SRIO1, NONE, NONE}, + [8] = {SRIO2, SRIO2, SRIO2, SRIO2}, + [9] = {SRIO2, SRIO2, SRIO2, SRIO2}, + [10] = {SRIO2, SRIO2, SRIO2, SRIO2}, + [11] = {SRIO2, SRIO1, SGMII_TSEC2, SGMII_TSEC3}, + [12] = {SRIO2, SRIO1, SGMII_TSEC2, SGMII_TSEC3}, + [13] = {PCIE1, SRIO1, SGMII_TSEC2, SGMII_TSEC3}, + [14] = {PCIE1, PCIE2, SGMII_TSEC2, SGMII_TSEC3}, + [15] = {PCIE1, PCIE1, SGMII_TSEC2, SGMII_TSEC3}, +}; + +static const char *serdes_prtcl_str[] = { + [NONE] = "NA", + [PCIE1] = "PCIE1", + [PCIE2] = "PCIE2", + [PCIE3] = "PCIE3", + [SRIO1] = "SRIO1", + [SRIO2] = "SRIO2", + [SGMII_TSEC2] = "SGMII_TSEC2", + [SGMII_TSEC3] = "SGMII_TSEC3", +}; + +static enum srds_prtcl serdes_get_prtcl(int lane) +{ + return serdes_cfg_tbl[serdes_cfg][lane]; +} + +int is_serdes_configured(enum srds_prtcl prtcl) +{ + return (1 << prtcl) & serdes_prtcl_map; +} + +void fsl_serdes_init(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + int lane; + int i; + enum srds_prtcl lane_prtcl; + + serdes_cfg = (in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_IO_SEL) >> 19; + debug("Using SERDES configuration 0x%x, lane settings:\n", + serdes_cfg); + + for (lane = 0; lane < SRDS_MAX_LANES; lane++) { + lane_prtcl = serdes_get_prtcl(lane); + + serdes_prtcl_map |= (1 << lane_prtcl); + debug("%s ", serdes_prtcl_str[lane_prtcl]); + } + debug("\n"); +}
Setting up LAWs, PCIE, SRIO, SGMII intelligently based on the power-on serdes configuration.
Signed-off-by: Li Yang leoli@freescale.com --- board/freescale/p2020ds/law.c | 6 -- board/freescale/p2020ds/p2020ds.c | 126 ++----------------------------------- include/configs/P2020DS.h | 21 ++++++ 3 files changed, 27 insertions(+), 126 deletions(-)
diff --git a/board/freescale/p2020ds/law.c b/board/freescale/p2020ds/law.c index 28ed2ed..c90c9ae 100644 --- a/board/freescale/p2020ds/law.c +++ b/board/freescale/p2020ds/law.c @@ -29,12 +29,6 @@
struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), - SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), - SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), - SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_3), - SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), SET_LAW(PIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), }; diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index e38c014..64db0c1 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -27,7 +27,6 @@ #include <asm/mmu.h> #include <asm/cache.h> #include <asm/immap_85xx.h> -#include <asm/fsl_pci.h> #include <asm/fsl_ddr_sdram.h> #include <asm/io.h> #include <miiphy.h> @@ -37,6 +36,7 @@ #include <asm/fsl_law.h> #include <asm/mp.h> #include <netdev.h> +#include <asm/fsl_serdes.h>
#include "../common/pixis.h" #include "../common/sgmii_riser.h" @@ -180,120 +180,10 @@ phys_size_t fixed_sdram(void)
#endif
-#ifdef CONFIG_PCIE1 -static struct pci_controller pcie1_hose; -#endif - -#ifdef CONFIG_PCIE2 -static struct pci_controller pcie2_hose; -#endif - -#ifdef CONFIG_PCIE3 -static struct pci_controller pcie3_hose; -#endif - #ifdef CONFIG_PCI void pci_init_board(void) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info[3]; - u32 devdisr, pordevsr, io_sel, host_agent; - int first_free_busno = 0; - int num = 0; - - int pcie_ep, pcie_configured; - - devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - host_agent = (in_be32(&gur->porbmsr) & MPC85xx_PORBMSR_HA) >> 16; - - debug(" pci_init_board: devdisr=%x, io_sel=%x, host_agent=%x\n", - devdisr, io_sel, host_agent); - - if (!(pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) - printf(" eTSEC2 is in sgmii mode.\n"); - if (!(pordevsr & MPC85xx_PORDEVSR_SGMII3_DIS)) - printf(" eTSEC3 is in sgmii mode.\n"); - - puts("\n"); -#ifdef CONFIG_PCIE2 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)) { - SET_STD_PCIE_INFO(pci_info[num], 2); - printf(" PCIE2 connected to ULI as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie2_hose, first_free_busno); - - /* - * The workaround doesn't work on p2020 because the location - * we try and read isn't valid on p2020, fix this later - */ -#if 0 - /* - * Activate ULI1575 legacy chip by performing a fake - * memory access. Needed to make ULI RTC work. - * Device 1d has the first on-board memory BAR. - */ - - pci_hose_read_config_dword(hose, PCI_BDF(2, 0x1d, 0), - PCI_BASE_ADDRESS_1, &temp32); - if (temp32 >= CONFIG_SYS_PCIE3_MEM_BUS) { - void *p = pci_mem_to_virt(PCI_BDF(2, 0x1d, 0), - temp32, 4, 0); - debug(" uli1575 read to %p\n", p); - in_be32(p); - } -#endif - } else { - printf(" PCIE2: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ -#endif - -#ifdef CONFIG_PCIE3 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_3, host_agent); - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)) { - SET_STD_PCIE_INFO(pci_info[num], 3); - printf(" PCIE3 connected to Slot 1 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie3_hose, first_free_busno); - } else { - printf(" PCIE3: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ -#endif - -#ifdef CONFIG_PCIE1 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)) { - SET_STD_PCIE_INFO(pci_info[num], 1); - printf(" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", - pcie_ep ? "End Point" : "Root Complex", - pci_info[num].regs); - first_free_busno = fsl_pci_init_port(&pci_info[num++], - &pcie1_hose, first_free_busno); - } else { - printf(" PCIE1: disabled\n"); - } - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ -#endif + mpc85xx_serdes_board_init(); } #endif
@@ -523,6 +413,8 @@ int board_eth_init(bd_t *bis) #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) { + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 devdisr = in_be32(&gur->devdisr); phys_addr_t base; phys_size_t size;
@@ -533,14 +425,8 @@ void ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory(blob, (u64)base, (u64)size);
-#ifdef CONFIG_PCIE3 - ft_fsl_pci_setup(blob, "pci0", &pcie3_hose); -#endif -#ifdef CONFIG_PCIE2 - ft_fsl_pci_setup(blob, "pci1", &pcie2_hose); -#endif -#ifdef CONFIG_PCIE1 - ft_fsl_pci_setup(blob, "pci2", &pcie1_hose); +#ifdef CONFIG_FSL_SERDES + ft_mpc85xx_serdes_board_setup(blob); #endif #ifdef CONFIG_FSL_SGMII_RISER fsl_sgmii_riser_fdt_fixup(blob); diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index b48c199..406afc7 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -39,6 +39,7 @@ #define CONFIG_P2020DS 1 #define CONFIG_MP 1 /* support multiple processors */
+#define CONFIG_FSL_SERDES 1 /* Use common serdes init code */ #define CONFIG_FSL_ELBC 1 /* Has Enhanced localbus controller */ #define CONFIG_PCI 1 /* Enable PCI/PCIE */ #define CONFIG_PCIE1 1 /* PCIE controler 1 (slot 1) */ @@ -519,6 +520,26 @@ extern unsigned long calculate_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_ISA_IO_BASE_ADDRESS VIDEO_IO_OFFSET #endif
+#define CONFIG_SRIO + +/* SRIO1 uses the same window as PCIE2 mem window */ +#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull +#else +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xa0000000 +#endif +#define CONFIG_SYS_SRIO1_MEM_SIZE 0x20000000 /* 512M */ + +/* SRIO2 uses the same window as PCIE1 mem window */ +#define CONFIG_SYS_SRIO2_MEM_VIRT 0xc0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc40000000ull +#else +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc0000000 +#endif +#define CONFIG_SYS_SRIO2_MEM_SIZE 0x20000000 /* 512M */ + #define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */
applied to 85xx next
- k
Jerry,
If you can ack this I'll handling pulling this in via the 85xx tree.
- k
Jerry,
- k
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, gvb
Jerry Van Baren
Kumar Gala
Li Yang
