[U-Boot-Users] [PATCH: cmdcfg: 11/19] lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely.
All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Jon Loeliger jdl@freescale.com --- lib_arm/board.c | 8 ++++---- lib_avr32/board.c | 2 +- lib_blackfin/board.c | 6 +++--- lib_generic/crc32.c | 5 +++-- lib_i386/board.c | 17 +++++++++-------- lib_m68k/board.c | 20 ++++++++++---------- lib_microblaze/board.c | 8 ++++---- lib_mips/board.c | 4 ++-- 8 files changed, 36 insertions(+), 34 deletions(-)
diff --git a/lib_arm/board.c b/lib_arm/board.c index babc254..69d4782 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -54,7 +54,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) void nand_init (void); #endif
@@ -296,7 +296,7 @@ void start_armboot (void) /* armboot_start is defined in the board-specific linker script */ mem_malloc_init (_armboot_start - CFG_MALLOC_LEN);
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) puts ("NAND: "); nand_init(); /* go init the NAND */ #endif @@ -378,7 +378,7 @@ void start_armboot (void) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -387,7 +387,7 @@ void start_armboot (void) #ifdef BOARD_LATE_INIT board_late_init (); #endif -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) puts ("Net: "); #endif diff --git a/lib_avr32/board.c b/lib_avr32/board.c index 265328a..822668c 100644 --- a/lib_avr32/board.c +++ b/lib_avr32/board.c @@ -328,7 +328,7 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) jumptable_init(); console_init_r();
-#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) puts("Net: "); #endif diff --git a/lib_blackfin/board.c b/lib_blackfin/board.c index 1538da3..d359710 100644 --- a/lib_blackfin/board.c +++ b/lib_blackfin/board.c @@ -297,7 +297,7 @@ void board_init_f(ulong bootflag) }
checkboard(); -#if defined(CONFIG_RTC_BF533) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_BF533) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE)) rtc_init(); #endif timer_init(); @@ -391,13 +391,13 @@ void board_init_r(gd_t * id, ulong dest_addr) if ((s = getenv("loadaddr")) != NULL) { load_addr = simple_strtoul(s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) if ((s = getenv("bootfile")) != NULL) { copy_filename(BootFile, s, sizeof(BootFile)); } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) puts("NAND: "); nand_init(); /* go init the NAND */ #endif diff --git a/lib_generic/crc32.c b/lib_generic/crc32.c index 3d99b69..84deba9 100644 --- a/lib_generic/crc32.c +++ b/lib_generic/crc32.c @@ -171,8 +171,9 @@ uLong ZEXPORT crc32(crc, buf, len) return crc ^ 0xffffffffL; }
-#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) || \ - ((CONFIG_COMMANDS & CFG_CMD_NAND) && !defined(CFG_NAND_LEGACY)) +#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) || \ + (((CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND)) \ + && !defined(CFG_NAND_LEGACY))
/* No ones complement version. JFFS2 (and other things ?) * don't use ones compliment in their CRC calculations. diff --git a/lib_i386/board.c b/lib_i386/board.c index 4175fdb..1efe81e 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -313,13 +313,14 @@ void start_i386boot (void) misc_init_r(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_PCMCIA) && !(CONFIG_COMMANDS & CFG_CMD_IDE) +#if ((CONFIG_COMMANDS & CFG_CMD_PCMCIA) || defined(CONFIG_CMD_PCMCIA)) + && !((CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE)) WATCHDOG_RESET(); puts ("PCMCIA:"); pcmcia_init(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) WATCHDOG_RESET(); puts("KGDB: "); kgdb_init(); @@ -348,7 +349,7 @@ void start_i386boot (void) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -356,25 +357,25 @@ void start_i386boot (void)
WATCHDOG_RESET();
-#if (CONFIG_COMMANDS & CFG_CMD_IDE) +#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) WATCHDOG_RESET(); puts("IDE: "); ide_init(); #endif /* CFG_CMD_IDE */
-#if (CONFIG_COMMANDS & CFG_CMD_SCSI) +#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) WATCHDOG_RESET(); puts("SCSI: "); scsi_init(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) +#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC) WATCHDOG_RESET(); puts("DOC: "); doc_init(); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) #if defined(CONFIG_NET_MULTI) WATCHDOG_RESET(); puts("Net: "); @@ -382,7 +383,7 @@ void start_i386boot (void) eth_initialize(gd->bd); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) && (0) +#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && (0) WATCHDOG_RESET(); # ifdef DEBUG puts ("Reset Ethernet PHY\n"); diff --git a/lib_m68k/board.c b/lib_m68k/board.c index 6aaf609..03ae18d 100644 --- a/lib_m68k/board.c +++ b/lib_m68k/board.c @@ -34,20 +34,20 @@ #include <asm/immap_5272.h> #endif
-#if (CONFIG_COMMANDS & CFG_CMD_IDE) +#if (CONFIG_COMMANDS & CFG_CMD_IDE) || defined(CONFIG_CMD_IDE) #include <ide.h> #endif -#if (CONFIG_COMMANDS & CFG_CMD_SCSI) +#if (CONFIG_COMMANDS & CFG_CMD_SCSI) || defined(CONFIG_CMD_SCSI) #include <scsi.h> #endif -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) #include <kgdb.h> #endif #ifdef CONFIG_STATUS_LED #include <status_led.h> #endif #include <net.h> -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) #include <cmd_bedbug.h> #endif #ifdef CFG_ALLOC_DPRAM @@ -584,7 +584,7 @@ void board_init_r (gd_t *id, ulong dest_addr) misc_init_r (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) WATCHDOG_RESET (); puts ("KGDB: "); kgdb_init (); @@ -620,7 +620,7 @@ void board_init_r (gd_t *id, ulong dest_addr) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -628,19 +628,19 @@ void board_init_r (gd_t *id, ulong dest_addr)
WATCHDOG_RESET ();
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) +#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC) WATCHDOG_RESET (); puts ("DOC: "); doc_init (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NAND) +#if (CONFIG_COMMANDS & CFG_CMD_NAND) || defined(CONFIG_CMD_NAND) WATCHDOG_RESET (); puts ("NAND: "); nand_init(); /* go init the NAND */ #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(FEC_ENET) +#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(FEC_ENET) WATCHDOG_RESET(); eth_init(bd); #endif @@ -659,7 +659,7 @@ void board_init_r (gd_t *id, ulong dest_addr) last_stage_init (); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) +#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) WATCHDOG_RESET (); bedbug_init (); #endif diff --git a/lib_microblaze/board.c b/lib_microblaze/board.c index c95125a..07fb0fa 100644 --- a/lib_microblaze/board.c +++ b/lib_microblaze/board.c @@ -40,7 +40,7 @@ extern int gpio_init (void); #ifdef CFG_INTC_0 extern int interrupts_init (void); #endif -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) extern int eth_init (bd_t * bis); extern int getenv_IPaddr (char *); #endif @@ -108,7 +108,7 @@ void board_init (void) bd_t *bd; init_fnc_t **init_fnc_ptr; gd = (gd_t *) CFG_GBL_DATA_OFFSET; -#if (CONFIG_COMMANDS & CFG_CMD_FLASH) +#if (CONFIG_COMMANDS & CFG_CMD_FLASH) || defined(CONFIG_CMD_FLASH) ulong flash_size = 0; #endif asm ("nop"); /* FIXME gd is not initialize - wait */ @@ -130,7 +130,7 @@ void board_init (void) } }
-#if (CONFIG_COMMANDS & CFG_CMD_FLASH) +#if (CONFIG_COMMANDS & CFG_CMD_FLASH) || defined(CONFIG_CMD_FLASH) bd->bi_flashstart = CFG_FLASH_BASE; if (0 < (flash_size = flash_init ())) { bd->bi_flashsize = flash_size; @@ -143,7 +143,7 @@ void board_init (void) } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) char *s, *e; int i; /* board MAC address */ diff --git a/lib_mips/board.c b/lib_mips/board.c index b7d3356..654c5af 100644 --- a/lib_mips/board.c +++ b/lib_mips/board.c @@ -399,7 +399,7 @@ void board_init_r (gd_t *id, ulong dest_addr) if ((s = getenv ("loadaddr")) != NULL) { load_addr = simple_strtoul (s, NULL, 16); } -#if (CONFIG_COMMANDS & CFG_CMD_NET) +#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) if ((s = getenv ("bootfile")) != NULL) { copy_filename (BootFile, s, sizeof (BootFile)); } @@ -410,7 +410,7 @@ void board_init_r (gd_t *id, ulong dest_addr) misc_init_r (); #endif
Jon Loeliger
