[U-Boot] [PATCH] ls2-2085a: Increase default hugepage count
* Increase default hugepage count to 256 from 16 * Note: default env variables are stored at 0x580200000/0x584200000 of size 0x2000
Signed-off-by: Ashish Kumar Ashish.Kumar@freescale.com --- include/configs/ls2080a_common.h | 2 +- include/configs/ls2080ardb.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 4ae7d11..a503934 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -272,7 +272,7 @@ unsigned long long get_qixis_addr(void); #define CONFIG_BOOTARGS "console=ttyS0,115200 root=/dev/ram0 " \ "earlycon=uart8250,mmio,0x21c0500" \ "ramdisk_size=0x2000000 default_hugepagesz=2m" \ - " hugepagesz=2m hugepages=16" + " hugepagesz=2m hugepages=256" #define CONFIG_BOOTCOMMAND "cp.b $kernel_start $kernel_load " \ "$kernel_size && bootm $kernel_load" #define CONFIG_BOOTDELAY 10 diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 116dbcd..356d254 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -333,7 +333,7 @@ unsigned long get_board_sys_clk(void); #define CONFIG_BOOTARGS "console=ttyS1,115200 root=/dev/ram0 " \ "earlycon=uart8250,mmio,0x21c0600" \ "ramdisk_size=0x2000000 default_hugepagesz=2m" \ - " hugepagesz=2m hugepages=16" + " hugepagesz=2m hugepages=256"
/* MAC/PHY configuration */ #ifdef CONFIG_FSL_MC_ENET
Signed-off-by: Ashish Kumar Ashish.Kumar@freescale.com --- arch/arm/dts/fsl-ls2080a-rdb.dts | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/dts/fsl-ls2080a-rdb.dts b/arch/arm/dts/fsl-ls2080a-rdb.dts index 1a1813b..71d1969 100644 --- a/arch/arm/dts/fsl-ls2080a-rdb.dts +++ b/arch/arm/dts/fsl-ls2080a-rdb.dts @@ -11,7 +11,7 @@ #include "fsl-ls2080a.dtsi"
/ { - model = "Freescale Layerscape 2080a RDB Board"; + model = "Freescale Layerscape 2085a RDB Board"; compatible = "fsl,ls2080a-rdb", "fsl,ls2080a";
aliases {
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Ashish Kumar Sent: Thursday, January 14, 2016 6:04 PM To: u-boot@lists.denx.de Cc: Ashish Kumar Ashish.Kumar@freescale.com Subject: [U-Boot] [PATCH] ls2-2085a: Increase default hugepage count
Please add description of this patch
--prabhakar
Ashish Kumar
Prabhakar Kushwaha
