[PATCH 0/3] Random Number Generator fixes
This series aim to fix smccc bind issue and add a list command for RNG devices.
Weizhao Ouyang (3): firmware: psci: Fix bind_smccc_features psci check driver: rng: Fix SMCCC TRNG crash cmd: rng: Add rng list command
cmd/rng.c | 15 +++++++++++++++ drivers/firmware/psci.c | 2 +- drivers/rng/smccc_trng.c | 2 +- include/linux/arm-smccc.h | 1 + 4 files changed, 18 insertions(+), 2 deletions(-)
According to PSCI specification DEN0022F, PSCI_FEATURES is used to check whether the SMCCC is implemented by discovering SMCCC_VERSION.
Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- drivers/firmware/psci.c | 2 +- include/linux/arm-smccc.h | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/firmware/psci.c b/drivers/firmware/psci.c index c6b9efab41..894be8128d 100644 --- a/drivers/firmware/psci.c +++ b/drivers/firmware/psci.c @@ -135,7 +135,7 @@ static int bind_smccc_features(struct udevice *dev, int psci_method) PSCI_VERSION_MAJOR(psci_0_2_get_version()) == 0) return 0;
- if (request_psci_features(ARM_SMCCC_ARCH_FEATURES) == + if (request_psci_features(ARM_SMCCC_VERSION) == PSCI_RET_NOT_SUPPORTED) return 0;
diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index f44e9e8f93..453017eb5f 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -55,6 +55,7 @@ #define ARM_SMCCC_QUIRK_NONE 0 #define ARM_SMCCC_QUIRK_QCOM_A6 1 /* Save/restore register a6 */
+#define ARM_SMCCC_VERSION 0x80000000 #define ARM_SMCCC_ARCH_FEATURES 0x80000001
#define ARM_SMCCC_RET_NOT_SUPPORTED ((unsigned long)-1)
5.15.2 Implementation responsibilities
PSCI_FEATURES should report the presence of SMCCC_VERSION in privileged platform firmware compliant with PSCI v1.0 and later revisions.
Acked-by: Heinrich Schuchardt xypron.glpk@gmx.de
- if (request_psci_features(ARM_SMCCC_VERSION) == PSCI_RET_NOT_SUPPORTED) return 0;
Hi Weizhao,
I suggest we add checks on the SMCCC version like this:
if SMCCC_VERSION >= 1.1 assume SMCCC_ARCH_FEATURES is supported discover arch features and bind drivers/devices else error
For more details [1][2].
[1]: SMC Calling Convention 1.5 (https://developer.arm.com/documentation/den0028/latest/)
SMCCC_ARCH_FEATURES MANDATORY from SMCCC v1.1
The implementation of this function can be detected by checking the SMCCC version. This function is mandatory if SMCCC_VERSION indicates that version 1.1 or later is implemented.
[2]: Linux checks SMCCC v1.1: https://elixir.bootlin.com/linux/latest/source/drivers/firmware/psci/psci.c#...
Cheers, Abdellatif
Hi Abdellatif,
On Fri, Jan 26, 2024 at 7:20 PM Abdellatif El Khlifi abdellatif.elkhlifi@arm.com wrote:
Hi Weizhao,
Okay, I will add it.
BR, Weizhao
Cheers, Abdellatif
Fix a SMCCC TRNG null pointer crash due to a failed smccc feature binding.
Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- drivers/rng/smccc_trng.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rng/smccc_trng.c b/drivers/rng/smccc_trng.c index 3a4bb33941..3087cb991a 100644 --- a/drivers/rng/smccc_trng.c +++ b/drivers/rng/smccc_trng.c @@ -166,7 +166,7 @@ static int smccc_trng_probe(struct udevice *dev) struct smccc_trng_priv *priv = dev_get_priv(dev); struct arm_smccc_res res;
- if (!(smccc_trng_is_supported(smccc->invoke_fn))) + if (!smccc || !(smccc_trng_is_supported(smccc->invoke_fn))) return -ENODEV;
/* At least one of 64bit and 32bit interfaces is available */
Reviewed-by: Heinrich Schuchardt xypron.gpk@gmx.de
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Add rng list command to list all probed RNG device.
Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- cmd/rng.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/cmd/rng.c b/cmd/rng.c index 52f722c7af..4818133f94 100644 --- a/cmd/rng.c +++ b/cmd/rng.c @@ -18,6 +18,19 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) int devnum; struct udevice *dev; int ret = CMD_RET_SUCCESS; + int idx; + + if (argc == 2 && !strcmp(argv[1], "list")) { + uclass_foreach_dev_probe(UCLASS_RNG, dev) { + printf("RNG #%d - %s\n", dev->seq_, dev->name); + } + + if (!idx) { + printf("*** no RNG devices available ***\n"); + return CMD_RET_FAILURE; + } + return CMD_RET_SUCCESS; + }
switch (argc) { case 1: @@ -57,6 +70,8 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) }
U_BOOT_LONGHELP(rng, + "[list]\n" + " - list all the probe rng device\n" "[dev [n]]\n" " - print n random bytes(max 64) read from dev\n");
Thank you for your contribution.
Would the following be more accurate?
The 'rng list' command probes all RNG devices and list those devices that are successfully probed.
- int idx;
Please, put the definition into the code block where it is used.
- if (argc == 2 && !strcmp(argv[1], "list")) {
int idx = 0;
++idx;
if (!idx) {
If idx is not initialized, depending on the random value of idx on the stack you get a printout or not, e.g.
=> rng list RNG #0 - riscv_zkr RNG #1 - virtio-rng#8 *** no RNG devices available ***
Do we need the message to be so noisy? How about
log_err("No RNG device\n");
We prefer having an empty line before return statements.
Best regards
Heinrich
- "[list]\n"
- " - list all the probe rng device\n" "[dev [n]]\n" " - print n random bytes(max 64) read from dev\n");
On Thu, Jan 25, 2024 at 10:49 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Yeah.
int idx;
Sorry I imported the draft code, will remove it in the next version.
int idx = 0;
++idx;
if (!idx) {
Best regards
Heinrich
} switch (argc) { case 1:
"[list]\n"
BR, Weizhao
Weizhao Ouyang
